- 01-Fundamentals Configuration Guide
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-Device management configuration
- 09-Tcl configuration
- 10-Python configuration
- 11-Automatic configuration
- 12-License management
| 00-Preface | 111.71 KB |
Preface
This configuration guide describes features and tasks that help you get started with the device, including:
· CLI.
· RBAC, device login, and device access control.
· Management of the device, file systems, and configuration files.
· FTP and TFTP.
· Software upgrade.
· Automatic configuration.
· Tcl and Python.
· License management.
· Audience
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
