- 14-Security Configuration Guide
- 01-ACL configuration
- 02-Time range configuration
- 03-User profile configuration
- 04-Public key management
- 05-PKI configuration
- 06-IPsec configuration
- 07-SSH configuration
- 08-SSL configuration
- 09-Session management
- 10-Attack detection and prevention configuration
- 11-ARP attack protection configuration
- 12-ND attack defense configuration
- 13-Crypto engine configuration
- 14-Connection limit configuration
- 15-Password control configuration
- 16-APR configuration
| 09-Session management | 168.61 KB |
Restrictions and guidelines: Session management configuration
Session management tasks at a glance
Setting the session aging time for different protocol states
Setting the session aging time for different application layer protocols or applications
Specifying persistent sessions
Enabling top session statistics for IPv4 sessions
Enabling top session statistics for IPv6 sessions
Configuring session usage alarm logging
Configuring alarms for abrupt session changes
Configuring alarms for abrupt session table usage changes
Configuring alarms for abrupt session creation rate changes
Configuring alarms for abrupt session attempt rate changes
Enabling ALG to process IP fragments and TCP segments
Enabling destination address matching for SIP relation entries
Setting the aging time for SIP-SDP or SUNRPC session relation entries
Display and maintenance commands for session management
Managing sessions
About session management
Session management is a common module, providing basic services for attack detection and protection ,to implement their session-based services.
Session management defines packet exchanges at transport layer as sessions. It updates session states and ages out sessions according to data flows from the initiators or responders. Session management allows multiple features to process the same service packet.
Session management operation
Session management tracks the session status by inspecting the transport layer protocol information. It performs unified status maintenance and management of all connections based on session tables and relation tables.
When a connection request passes through the device from a client to a server, the device creates a session entry. The entry can contain the request and response information, such as:
· Source IP address and port number.
· Destination IP address and port number.
· Transport layer protocol.
· Application layer protocol.
· Protocol state of the session.
A multichannel protocol requires that the client and the server negotiate a new connection based on an existing connection to implement an application. Session management enables the device to create a relation entry for each connection during the negotiation phase. The entry is used to associate the connection with the application. Relation entries will be removed after the associated connections are established.
If the destination IP address of a packet is a multicast IP address, the packet will be forwarded out of multiple ports. When a multicast connection request is received on an inbound interface, the device performs the following operations:
· Creates a multicast session entry on the inbound interface.
· Creates a corresponding multicast session entry for each outbound interface.
Unless otherwise stated, "session entry" in this chapter refers to both unicast and multicast session entries.
Session management functions
Session management enables the device to provide the following functions:
· Creates sessions for protocol packets, updates session states, and sets aging time for sessions in different protocol states.
· Sets aging time for sessions based on application layer protocols.
· Supports ICMP/ICMPv6 error packet mapping, enabling the device to search for original sessions according to the payloads in the ICMP/ICMPv6 error packets.
Because error packets are generated due to host errors, the mapping can help speed up the aging of the original sessions.
· Supports persistent sessions, which are kept alive for a long period of time.
· Supports session management for the control channels and dynamic data channels of application layer protocols, for example, FTP.
For a TCP session in ESTABLISHED state, the priority order of the associated aging time is as follows:
· Aging time for persistent sessions.
· Aging time for sessions of application layer protocols.
· Aging time for sessions in different protocol states.
If the device has excessive sessions, do not set the aging time shorter than the default for a certain protocol state or an application layer protocol. Short aging time settings can make the device slow in response.
To configure session management, perform the following tasks:
1. Configure session management timers
¡ Setting the session aging time for different protocol states
¡ Setting the session aging time for different application layer protocols or applications
¡ Specifying persistent sessions
2. Configuring session statistics collection
¡ Enabling top session statistics for IPv4 sessions
¡ Enabling top session statistics for IPv6 sessions
3. Configuring session usage alarm logging
4. Configuring alarms for abrupt session changes
5. Enabling ALG to process IP fragments and TCP segments
6. Enabling destination address matching for SIP relation entries
If a session in a certain protocol state has no packet hit before the aging time expires, the device automatically removes the session.
1. Enter system view.
2. Set the session aging time for different protocol states.
session aging-time state { fin | icmp-reply | icmp-request | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | syn | tcp-close | tcp-est | tcp-time-wait | udp-open | udp-ready } time-value
The default aging time for sessions in different protocol states is as follows:
¡ FIN_WAIT: 30 seconds.
¡ ICMP-REPLY: 30 seconds.
¡ ICMP-REQUEST: 60 seconds.
¡ ICMPv6-REPLY: 30 seconds.
¡ ICMPv6-REQUEST: 60 seconds.
¡ RAWIP-OPEN: 30 seconds.
¡ RAWIP-READY: 60 seconds.
¡ TCP SYN-SENT and SYN-RCV: 30 seconds.
¡ TCP-CLOSE: 2 seconds.
¡ TCP ESTABLISHED: 3600 seconds.
¡ TCP-TIME-WAIT: 2 seconds.
¡ UDP-OPEN: 30 seconds.
¡ UDP-READY: 60 seconds.
The aging time for sessions of different application layer protocols or applications are valid for TCP sessions in ESTABLISHED state or UDP sessions in READY state. For sessions used by other application layer protocols, the aging time for sessions in different protocol states applies.
2. Set the session aging time for different application layer protocols.
session aging-time application application-name time-value
By default, the aging time is 1200 seconds for sessions of application layer protocols or applications except for the following sessions:
¡ BOOTPC sessions: 120 seconds.
¡ BOOTPS sessions: 120 seconds.
¡ DNS sessions: 30 seconds.
¡ FTP sessions: 3600 seconds.
¡ FTP-DATA sessions: 240 seconds.
¡ GPRS-DATA sessions: 60 seconds.
¡ GPRS-SIG sessions: 60 seconds.
¡ GTP-CONTROL sessions: 60 seconds.
¡ GTP-USER sessions: 60 seconds.
¡ H.225 sessions: 3600 seconds.
¡ H.245 sessions: 3600 seconds.
¡ HTTPS sessions: 600 seconds.
¡ ILS sessions: 3600 seconds.
¡ L2TP sessions: 120 seconds.
¡ MGCP-CALLAGENT sessions: 60 seconds.
¡ MGCP-GATEWAY sessions: 60 seconds.
¡ NETBIOS-DGM sessions: 3600 seconds.
¡ NETBIOS-NS sessions: 3600 seconds.
¡ NETBIOS-SSN sessions: 3600 seconds.
¡ NTP sessions: 120 seconds.
¡ PPTP sessions: 3600 seconds.
¡ QQ sessions: 120 seconds.
¡ RAS sessions: 300 seconds.
¡ RIP sessions: 120 seconds.
¡ RSH sessions: 60 seconds.
¡ RTSP session: 3600 seconds.
¡ SCCP sessions: 3600 seconds.
¡ SIP sessions: 300 seconds.
¡ SNMP sessions: 120 seconds.
¡ SNMPTRAP sessions: 120 seconds.
¡ SQLNET sessions: 600 seconds.
¡ STUN sessions: 600 seconds.
¡ SYSLOG sessions: 120 seconds.
¡ TACACS-DS sessions: 120 seconds.
¡ TFTP sessions: 60 seconds.
¡ WHO sessions: 120 seconds.
¡ XDMCP sessions: 3600 seconds.
This task is only for TCP sessions in ESTABLISHED state. You can specify TCP sessions that match the permit statements in the specified ACL as persistent sessions, and set longer lifetime or never-age-out persistent sessions.
A persistent session is not removed until one of the following events occurs:
· The session entry ages out.
· The device receives a connection close request from the initiator or responder.
· You manually clear the session entries.
2. Specify persistent sessions.
session persistent acl [ ipv6 ] acl-number [ aging-time time-value ]
This task enables the device to collect the number of IPv4 sessions for session-based services based on the session creation rate and the number of concurrent sessions, and rank the sessions by source address and by destination address.
To view the ranking results, log in to the device management page through the Web interface.
If you specify a source or destination IPv4 address for the top session statistics policy, the system collects statistics for only IPv4 sessions that match the specified address. If you do not specify any source or destination IPv4 address, the system collects statistics for all sessions.
2. Enter top IPv4 session statistics policy view.
session ip-top-count policy
3. Specify a source IPv4 address matching criterion for the top session statistics policy.
source-ip subnet subnet-ip-address mask-length
By default, no source IPv4 address matching criterion is specified.
4. Specify a destination IPv4 address matching criterion for the top session statistics policy.
destination-ip subnet subnet-ip-address mask-length
By default, no destination IPv4 address matching criterion is specified.
5. Return to system view.
6. Enable top session statistics for IPv4 sessions.
session ip-top-count enable
By default, top session statistics for IPv4 sessions is disabled.
This task enables the device to collect the number of IPv6 sessions for session-based services based on the session creation rate and the number of concurrent sessions, and rank the sessions by source address and by destination address.
If you specify a source or destination IPv6 address for the top session statistics policy, the system collects statistics for only IPv6 sessions that match the specified address. If you do not specify any source or destination IPv6 address, the system collects statistics for all sessions.
2. Enter top IPv6 session statistics policy view.
session ipv6-top-count policy
source-ip subnet subnet-ipv6-address prefix-length
By default, no source IPv6 address matching criterion is specified.
4. Specify a destination IPv6 address matching criterion for the top session statistics policy.
destination-ip subnet subnet-ipv6-address prefix-length
By default, no destination IPv6 address matching criterion is specified.
6. Enable top session statistics for IPv6 sessions.
session ipv6-top-count enable
By default, top session statistics for IPv6 sessions is disabled.
Perform this task for the device to send alarm logs for crossing of the following alarm thresholds:
· Session entry usage alarm threshold.
· Relation entry usage alarm threshold.
The device sends alarms when the relation entry usage or session entry usage exceeds or drops below the corresponding alarm threshold.
2. Enable session usage alarm logging
session alarm-log enable
By default, session usage alarm logging is disabled.
3. Set the session entry usage alarm threshold.
session usage threshold threshold-value
By default, the session entry usage alarm threshold is 95%.
4. Set the relation entry usage alarm threshold.
session relation-table-usage threshold threshold-value
By default, the relation entry usage alarm threshold is 95%.
Perform this task for the device to generate alarms for abrupt increase or drop in the session table usage. With this feature enabled, the system collects the session table usage at an interval of 10 seconds and checks whether the following indicators reach the corresponding alarm thresholds:
· Session table usage change in percentage—Obtained by dividing the difference between the session entry counts at the beginning and end of a collection interval by the session entry count at the beginning of the collection interval.
· Base session table usage in percentage—Obtained by dividing the session entry count at the beginning of a collection interval by the supported maximum number of session entries.
If both of the following conditions are met in a detection interval, the system generates an alarm for the abrupt change of the session table usage:
· The session table usage change threshold is reached.
· The base session table usage threshold is crossed.
2. Enable alarms for abrupt session table usage changes.
session alarm usage-abrupt enable
By default, alarms are disabled for abrupt session table usage changes.
3. Set the alarm thresholds for abrupt session table usage changes.
session alarm usage-abrupt threshold threshold-value [ base-threshold base-value ]
By default, the session table usage change threshold is 20%, and the base session table usage threshold is 10%.
Perform this task for the device to generate alarms for abrupt increase or drop in the session creation rate. With this feature enabled, the system collects the session creation rate at an interval of 10 seconds and checks whether the following indicators reach the corresponding alarm thresholds:
· Session creation rate change in percentage—Obtained by dividing the difference between the session creation rates at the beginning and end of a collection interval by the session creation rate at the beginning of the collection interval.
· Base session creation rate in percentage—Obtained by dividing the session creation rate at the beginning of a collection interval by 100000.
If both of the following conditions are met in a detection interval, the system generates an alarm for the abrupt change of the session creation rate:
· The session creation rate change threshold is reached.
· The base session creation rate threshold is crossed.
2. Enable alarms for abrupt session creation rate changes.
session alarm rate-abrupt enable
By default, alarms are disabled for abrupt session creation rate changes.
3. Set the alarm thresholds for abrupt session creation rate changes.
session alarm rate-abrupt threshold threshold-value [ base-threshold base-value ]
By default, the session creation rate change threshold is 20%, and the base session creation rate threshold is 10%.
Perform this task for the device to generate alarms for abrupt increase or drop in the session creation attempt rate. With this feature enabled, the system collects the session creation attempt rate at an interval of 10 seconds and checks whether the following indicators reach the corresponding alarm thresholds:
· Session attempt rate change in percentage—Obtained by dividing the difference between the session creation attempt rates at the beginning and end of a collection interval by the session creation attempt rate at the beginning of the collection interval.
· Base session attempt rate in percentage—Obtained by dividing the session creation attempt rate at the beginning of a collection interval by 100000.
If both of the following conditions are met in a detection interval, the system generates an alarm for the abrupt change of the session creation attempt rate:
· The session attempt rate change threshold is reached.
· The base session attempt rate threshold is crossed.
2. Enable alarms for abrupt session attempt rate changes.
session alarm try-rate-abrupt enable
By default, alarms are disabled for abrupt session attempt rate changes.
3. Set the alarm thresholds for abrupt session attempt rate changes.
session alarm try-rate-abrupt threshold threshold-value [ base-threshold base-value ]
By default, the session attempt rate change threshold is 20%, and the base session attempt rate threshold is 10%.
This task enables ALG to process IP fragments and TCP segments of specified protocols. In the current software version, ALG can process only IP fragments and TCP segments of SIP.
This feature does not take effect on TCP segments processed by NAT.
2. Enable ALG to process IP fragments and TCP segments.
session alg fragment sip
By default, ALG does not process IP fragments and TCP segments.
In an SIP network, data traffic does not match destination addresses when matching the relation table entries. In this case, if a client is to access multiple servers through multiple outbound interfaces, incorrect match of the relation entries might cause the traffic to be forwarded incorrectly.
This feature requires the data traffic to match the destination addresses when matching the relation entries, which helps to forward traffic correctly.
2. Enable destination address matching for SIP relation entries.
session relation-table match destination-ip sip enable
By default, destination address matching is disabled for SIP relation entries.
For SIP-SDP (SIP-RTCP and SIP-RTP), if the session that creates a relation entry ages out before the relation entry ages out, the relation entry will also age out. If the session ages out after the relation entry ages out the relation entry ages out according to the configured aging time. For SUNRPC, if no traffic matches a session relation entry during the aging time, the session relation entry will age automatically.
2. Set the aging time for SIP-SDP or SUNRPC session relation entries.
session relation-table aging-time application [ sip-sdp | sunrpc ] time-value
By default, the aging time for SIP-SDP session relation entries is 3 days and the aging time for SUNRPC session relation entries is 115200 seconds.
Task |
Command |
Display APP ID change statistics. |
display session alg-app-change |
Display the aging time for sessions of different application layer protocols. |
display session aging-time application |
Display the aging time for sessions in different protocol states. |
display session aging-time state |
Display the configuration information about top session statistics for IPv4 sessions. |
display session ip-top-count policy |
Display the configuration information about top session statistics for IPv6 sessions. |
display session ipv6-top-count policy |
Display relation table entries. |
display session relation-table { ipv4 | ipv6 } [ count number ] [ { application application-name | destination-ip destination-ip | destination-port destination-port | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-ip source-ip | source-port source-port } * ] |
Display the aging time for SIP-SDP and SUNRPC session relation entries. |
display session relation-table aging-time application |
Display unicast session statistics. |
display session statistics [ history-max | summary ] |
Display IPv4 unicast session statistics. |
display session statistics ipv4 [ [ responder ] { application application-name | destination-ip destination-ip | destination-port destination-port | destination-zone destination-zone-name | interface interface-type interface-number | protocol { dccp | dns | ftp | gtp | h323 | http | icmp | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp } | security-policy-rule rule-name | source-ip source-ip | source-port source-port | source-zone source-zone-name | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmp-reply | icmp-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } } * ] |
Display IPv6 unicast session statistics. |
display session statistics ipv6 [ [ responder ] { application application-name | destination-ip destination-ip | destination-port destination-port | destination-zone destination-zone-name | interface interface-type interface-number | protocol { dccp | dns | ftp | gtp | h323 | http | icmpv6 | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp } | security-policy-rule rule-name | source-ip source-ip | source-port source-port | source-zone source-zone-name | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } } * ] |
Display multicast session statistics. |
display session statistics multicast |
Display session statistics summary. |
display session statistics summary all |
Display IPv4 unicast session table entries. |
display session table ipv4 [ [ responder ] { application application-name | destination-ip start-destination-ip [ end-destination-ip ] | destination-port start-destination-port [ end-destination-port ] | destination-zone destination-zone-name | interface interface-type interface-number | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | security-policy-rule rule-name | security-policy-rule-id rule-id | source-ip start-source-ip [ end-source-ip ] | source-port start-source-port [ end-source-port ] | source-zone source-zone-name | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmp-reply | icmp-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } } * ] [ verbose | brief ] |
Display IPv6 unicast session table entries. |
display session table ipv6 [ [ responder ] { application application-name | destination-ip start-destination-ip [ end-destination-ip ] | destination-port start-destination-port [ end-destination-port ] | destination-zone destination-zone-name | interface interface-type interface-number | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | security-policy-rule rule-name | security-policy-rule-id rule-id | source-ip start-source-ip [ end-source-ip ] | source-port start-source-port [ end-source-port ] | source-zone source-zone-name | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } } * ] [ verbose | brief ] |
Display IPv4 multicast session table entries. |
display session table multicast ipv4 [ [ responder ] { destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port } * ] [ verbose ] |
Display IPv6 multicast session table entries. |
display session table multicast ipv6 [ [ responder ] { destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port } * ] [ verbose ] |
Display top session statistics. |
display session top-statistics { last-1-hour | last-24-hours | last-30-days } |
Clear APP ID change statistics. |
reset session alg-app-change |
Clear relation table entries. |
reset session relation-table [ ipv4 | ipv6 ] [ { application application-name | destination-ip destination-ip | destination-port destination-port | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-ip source-ip | source-port source-port } * ] |
Clear unicast session statistics. |
reset session statistics |
Clear multicast session table entries. |
reset session statistics multicast |
Clear IP unicast session table entries. |
reset session table |
Clear IPv4 unicast session table entries. |
reset session table ipv4 [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port start-source-port [ end-source-port ] ] [ destination-port start-destination-port [ end-destination-port ] ] |
Clear IPv6 unicast session table entries. |
reset session table ipv6 [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port start-source-port [ end-source-port ] ] [ destination-port start-destination-port [ end-destination-port ] ] |
Clear IP multicast session table entries. |
reset session table multicast |
Clear IPv4 multicast session table entries. |
reset session table multicast ipv4 [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] |
Clear IPv6 multicast session table entries. |
reset session table multicast ipv6 [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] |
