- 02-Fundamentals Configuration Guide
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-Automatic configuration
- 09-Python configuration
- 10-Tcl configuration
| 07-Software upgrade configuration | 102.19 KB |
Restrictions and guidelines: Software upgrade
Upgrading device software by using the boot loader method
Specifying startup images and completing the upgrade
Synchronizing startup images from the master device to subordinate devices
Display and maintenance commands for software image settings
Upgrading software
About software upgrade
Software upgrade enables you to upgrade a software version, add new features, and fix software bugs. This chapter describes software types and release forms, compares software upgrade methods, and provides the procedures for upgrading software from the CLI.
Software types
The following software types are available:
· BootWare image—Also called the Boot ROM image. This image contains a basic segment and an extended segment.
¡ The basic segment is the minimum code that bootstraps the system.
¡ The extended segment enables hardware initialization and provides system management menus. When the device cannot start up correctly, you can use the menus to load software and the startup configuration file or manage files.
Typically, the BootWare image is integrated into the Boot image to avoid software compatibility errors.
· Comware image—Includes the following image subcategories:
¡ Boot image—A .bin file that contains the Linux operating system kernel. It provides process management, memory management, file system management, and the emergency shell.
¡ System image—A .bin file that contains the Comware kernel and standard features, including device management, interface management, configuration management, and routing.
¡ Feature image—A .bin file that contains advanced or customized software features. You can purchase feature images as needed.
¡ Patch image—A .bin file that is released for fixing bugs without rebooting the device. A patch image does not add or remove features.
Patch images have the following types:
- Incremental patch images—Multiple incremental patch images can coexist on the device at the same time. A new patch image can cover all, part, or none of the functions provided by an old patch image.
- Non-incremental patch images—Only one non-incremental patch image can coexist on the device. The device uninstalls the old non-incremental patch image before installing a new non-incremental patch image. A new non-incremental patch image covers all functions provided by an old non-incremental patch image.
An incremental patch image and a non-incremental patch image can coexist on the device.
Comware images that have been loaded are called current software images. Comware images specified to load at the next startup are called startup software images.
BootWare image, boot image, and system image are required for the device to operate.
Software release forms
Software images are released in one of the following forms:
· Separate .bin files. You must verify compatibility between software images.
· As a whole in one .ipe package file. The images in an .ipe package file are compatible. The system decompresses the file automatically, loads the .bin images and sets them as startup software images.
NOTE: Software image file names use the model-comware version-image type-release format. This document uses boot.bin and system.bin as boot and system image file names. |
Upgrade methods
Upgrade method |
Software types |
Remarks |
Upgrading from the CLI by using the boot loader method |
· BootWare image · Comware images (excluding patches) |
This method is disruptive. You must reboot the entire device to complete the upgrade. |
Upgrading from the BootWare menu |
· BootWare image · Comware images |
Use this method when the device cannot start up correctly. To use this method, first connect to the console port and power cycle the device. Then, press Ctrl+B at prompt to access the BootWare menu. For more information about upgrading software from the BootWare menu, see the release notes for the software version. Use this method only when you do not have any other choice. |
This chapter covers only upgrading software from the CLI by using the boot loader method.
Software image loading
Startup software images
To upgrade software, you must specify the upgrade files as the startup software images for the device to load at next startup. You can specify two lists of software images: one main and one backup. The device first loads the main startup software images. If the main startup software images are not available, the devices loads the backup startup software images.
Image loading process at startup
At startup, the device performs the following operations after loading and initializing BootWare:
1. Loads main images.
2. If any main image does not exist or is invalid, loads the backup images.
3. If any backup image does not exist or is invalid, checks the main or backup boot image.
4. If both the main and backup boot images do not exist or are invalid, the device cannot start up.
As a best practice, store the startup images in a fixed storage medium. If you store the startup images in a hot swappable storage medium, do not remove the hot swappable storage medium during the startup process.
1. Use the display version command to verify the current BootWare image version and startup software version.
2. Use the release notes for the upgrade software version to evaluate the upgrade impact on your network and verify the following items:
¡ Software and hardware compatibility.
¡ Version and size of the upgrade software.
¡ Compatibility of the upgrade software with the current BootWare image and startup software image.
3. Use the release notes to verify whether the software images require a license. If licenses are required, register and activate licenses for each license-based software image. For more information about licensing, see "Managing licenses."
4. Use the dir command to verify that the storage medium has sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete command. For more information, see "Managing file systems."
In an IRF fabric, verify that all IRF member devices have sufficient storage space for the upgrade images.
5. Use FTP or TFTP to transfer the upgrade image file to the root directory of a file system. For more information about FTP and TFTP, see "Configuring FTP" or "Configuring TFTP." For more information about file systems, see "Managing file systems."
Perform the following steps in user view:
1. Specify main or backup startup images for all member devices.
¡ Use an .ipe file:
boot-loader file ipe-filename { all | slot slot-number } { backup | main }
¡ Use .bin files:
boot-loader file boot filename system filename [ feature filename&<1-30> ] { all | slot slot-number } { backup | main }
2. Save the running configuration.
save
This step ensures that all configuration changes can survive a reboot.
For more information about the command, see configuration file management in Fundamentals Command Reference.
3. Reboot the IRF fabric.
reboot
4. (Optional.) Verify the software image settings.
display boot-loader [ slot slot-number ]
Verify that the current software images are the same as the startup software images.
Perform this task when the startup images on subordinate devices are not the same version as those on the master device.
This task synchronizes startup images that are running on the master device to subordinate devices. If any of the startup images does not exist or is invalid, the synchronization fails.
The startup images synchronized to subordinate devices are set as main startup images, regardless of whether the source startup images are main or backup.
1. Synchronize startup images from the master to subordinate devices.
boot-loader update { all | slot slot-number }
2. Reboot the subordinate devices.
reboot slot slot-number [ force ]
Task |
Command |
Display current software images and startup software images. |
display boot-loader [ slot slot-number ] |
Software upgrade examples
Example: Upgrading device software
As shown in Figure 1, use the file startup-a2105.ipe to upgrade software images for the IRF fabric.
# Configure IP addresses and routes. Make sure the IRF fabric and the TFTP server can reach each other. (Details not shown.)
# Configure TFTP settings on both the IRF fabric and the TFTP server. (Details not shown.)
# Display information about the current software images.
<Sysname> display version
# Back up the current software images. If the CFcard has insufficient space, you can skip this step.
<Sysname> copy boot.bin boot_backup.bin
<Sysname> copy system.bin system_backup.bin
# Specify boot_backup.bin and system_backup.bin as the backup startup image files for all IRF member devices. Skip this step if you have not backed up the current software images.
<Sysname> boot-loader file boot cfa0:/boot_backup.bin system cfa0:/system_backup.bin slot 1 backup
<Sysname> boot-loader file boot cfa0:/boot_backup.bin system cfa0:/system_backup.bin slot 2 backup
# Use TFTP to download the startup-a2105.ipe image file from the TFTP server to the root directory of the flash memory on the master device.
<Sysname> tftp 2.2.2.2 get startup-a2105.ipe
# Specify startup-a2105.ipe as the main startup image file for all IRF member devices.
<Sysname> boot-loader file cfa0:/startup-a2105.ipe slot 1 main
<Sysname> boot-loader file cfa0:/startup-a2105.ipe slot 2 main
# Verify the startup image settings.
<Sysname> display boot-loader
# Reboot the IRF fabric to complete the upgrade.
<Sysname> reboot
# Verify that the IRF fabric is running the correct software.
