| 05-HH3C-PBR-MIB | 121.35 KB |
HH3C-PBR-MIB
About this MIB
Use this MIB to obtain and configure PBR information.
MIB file name
hh3c-pbr.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cPBR(113)
Scalar objects
hh3cPBRNexthopTrapEnabled
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPBRNexthopTrapEnabled (1.3.6.1.4.1.25506.2.113.1.1.1) |
read-write |
TruthValue |
Standard MIB values. |
Enable notifications when the next hop becomes unreachable. |
Not supported |
hh3cPBRLocalPolicy
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPBRLocalPolicy (1.3.6.1.4.1.25506.2.113.1.1.2) |
read-write |
DisplayString |
DisplayString(SIZE (0..19)) |
Apply the PBR policy to locally generated packets. |
Not supported |
hh3cPBRIPv6NexthopTrapEnabled
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPBRIPv6NexthopTrapEnabled (1.3.6.1.4.1.25506.2.113.1.1.3) |
read-write |
TruthValue |
Enable notifications when the IPv6 next hop becomes unreachable. |
Not supported |
hh3cPBRNexthopAddrType
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPBRNexthopAddrType (1.3.6.1.4.1.25506.2.113.1.2.1.1) |
accessible-for-notify |
INTEGER |
ipv4(1), ipv6(2), |
Next hop address type. |
As per the MIB. |
hh3cPBRNexthopAddr
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPBRNexthopAddr (1.3.6.1.4.1.25506.2.113.1.2.1.2) |
OCTET STRING |
OCTET STRING (0..255) |
Next hop address. |
As per the MIB. |
Tabular objects
hh3cPBRMibPolicyNodeTable
About this table
This table is used to create a policy node and configure match criteria and actions for the policy.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are hh3cPBRMibPolicyNodeAddrType, hh3cPBRMibPolicyName, and hh3cPBRMibPolicyNodeId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPBRMibPolicyNodeAddrType (1.3.6.1.4.1.25506.2.113.2.1.1.1) |
not-accessible |
InetAddressType |
unknown(0), ipv4(1), ipv6(2) |
Address type of the policy node. |
Supports IPv4, IPv6, and Dual-stack. |
hh3cPBRMibPolicyName (1.3.6.1.4.1.25506.2.113.2.1.1.2) |
not-accessible |
DisplayString |
DisplayString (SIZE (1..19)) |
PBR policy name. |
As per the MIB. |
hh3cPBRMibPolicyNodeId (1.3.6.1.4.1.25506.2.113.2.1.1.3) |
not-accessible |
Integer32 |
Integer32(0..65535) |
Policy node ID. |
As per the MIB. |
hh3cPBRMibPolicyNodeMode (1.3.6.1.4.1.25506.2.113.2.1.1.4) |
read-create |
TruthValue |
Match mode of the policy node. |
As per the MIB. |
hh3cPBRMibPolicyNodeRowStatus (1.3.6.1.4.1.25506.2.113.2.1.1.5) |
read-create |
RowStatus |
active(1), createAndGo(4), destroy(6) |
Operation type of the policy node. |
As per the MIB. |
hh3cPBRMibMinPktLen (1.3.6.1.4.1.25506.2.113.2.1.1.6) |
read-write |
Integer32 |
Integer32(1..65535) |
Minimum IP packet length of the packet length match criterion on the policy node. |
Not supported |
hh3cPBRMibMaxPktLen (1.3.6.1.4.1.25506.2.113.2.1.1.7) |
read-write |
Integer32 |
Maximum IP packet length of the packet length match criterion on the policy node. |
Not supported |
hh3cPBRMibQosId (1.3.6.1.4.1.25506.2.113.2.1.1.8) |
read-write |
Integer32 |
Integer32(1..4095) |
Local QoS ID match criterion of the policy node. |
As per the MIB. |
hh3cPBRMibQosIdMode (1.3.6.1.4.1.25506.2.113.2.1.1.9) |
read-write |
INTEGER |
invalid(1) normal(2), qppb(3) |
Local QoS ID mode of the policy node. |
As per the MIB. |
hh3cPBRMibVxlanId (1.3.6.1.4.1.25506.2.113.2.1.1.10) |
read-write |
Integer32 |
Integer32(0.. 16777215) |
VXLAN ID match criterion of the policy mode. |
Not supported |
hh3cPBRMibDescription (1.3.6.1.4.1.25506.2.113.2.1.1.11) |
read-write |
DisplayString |
DisplayString(SIZE (0..127)) |
Policy node description. |
As per the MIB. |
hh3cPBRMibApplyContinue (1.3.6.1.4.1.25506.2.113.2.1.1.12) |
read-write |
TruthValue |
Action that compares packets with the next policy node upon failure on the current node. |
Not supported |
hh3cPBRMibApplyFailDropNextHop (1.3.6.1.4.1.25506.2.113.2.1.1.13) |
read-write |
TruthValue |
Action that drops matching packets when all next hops on a policy node are invalid |
As per the MIB. |
hh3cPBRMibApplyIpDf (1.3.6.1.4.1.25506.2.113.2.1.1.14) |
read-write |
Integer32 |
0 or 1 |
Action that sets the Don't Fragment (DF) bit in the IP header of matching packets. |
Not supported |
hh3cPBRMibApplyLoadShareNextHop (1.3.6.1.4.1.25506.2.113.2.1.1.15) |
read-write |
TruthValue |
Action that enables load sharing among multiple next hops. |
As per the MIB. |
hh3cPBRMibApplyLoadShareOutIf (1.3.6.1.4.1.25506.2.113.2.1.1.16) |
read-write |
TruthValue |
Action that enables load sharing among multiple output interfaces. |
Not supported |
hh3cPBRMibApplyLSDefaultNextHop (1.3.6.1.4.1.25506.2.113.2.1.1.17) |
read-write |
TruthValue |
Action that enables load sharing among multiple default next hops. |
As per the MIB. |
hh3cPBRMibApplyLSDefaultOutIf (1.3.6.1.4.1.25506.2.113.2.1.1.18) |
read-write |
TruthValue |
Action that enables load sharing among multiple default output interfaces. |
As per the MIB. |
hh3cPBRMibApplyStatisticsValue (1.3.6.1.4.1.25506.2.113.2.1.1.19) |
read-write |
TruthValue |
Action that enables match counting on a policy node. |
As per the MIB. |
hh3cPBRMibIfPolicyTable
About this table
This table is used to implement interface PBR.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are hh3cPBRMibPolicyAddressType and ifIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPBRMibPolicyAddressType (1.3.6.1.4.1.25506.2.113.2.2.1.1) |
not-accessible |
InetAddressType |
Address type of interface PBR. |
hh3cPBRMibAppliedPolicyName (1.3.6.1.4.1.25506.2.113.2.2.1.2) |
read-create |
DisplayString |
Policy name of interface PBR. |
As per the MIB. |
hh3cPBRMibIfPolicyRowStatus (1.3.6.1.4.1.25506.2.113.2.2.1.3) |
read-create |
RowStatus |
Operation type of interface PBR. |
As per the MIB. |
hh3cPBRMibIfPolicyShareMode (1.3.6.1.4.1.25506.2.113.2.2.1.4) |
read-create |
TruthValue |
Resource sharing mode of interface PBR. |
As per the MIB. |
hh3cPBRMibMatchAclTable
About this table
This table is used to set ACL match criterions for a policy node.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPBRMibAclGroupId (1.3.6.1.4.1.25506.2.113.2.3.1.1) |
read-write |
Integer32 |
ACL number. |
As per the MIB. |
hh3cPBRMibAclGroupName (1.3.6.1.4.1.25506.2.113.2.3.1.2) |
read-write |
STRING |
STRING(SIZE (0..63)) |
ACL name. |
As per the MIB. |
hh3cPBRMibAclGroupVersion (1.3.6.1.4.1.25506.2.113.2.3.1.3) |
read-write |
INTEGER |
invalid(1) ipv4(2), ipv6(3), userdefined (4) |
ACL rule version |
As per the MIB. |
hh3cPBRMibApplyPrecedenceTable
About this table
This table is used to set an IP precedence.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPBRMibApplyPrecedenceValue (1.3.6.1.4.1.25506.2.113.2.4.1.1) |
read-write |
Integer32 |
0 to 7 |
Precedence for IP packets. |
routine (0) priority (1) immediate (2) flash (3) flash-override (4) critical (5) internet (6) network (7) |
hh3cPBRMibApplyNexthopTable
About this table
This table is used to set next hops for matching packets on a policy node.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are hh3cPBRMibPolicyNodeAddrType, hh3cPBRMibPolicyName, hh3cPBRMibPolicyNodeId, and hh3cPBRMibApplyNexthopIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPBRMibApplyNexthopIndex (1.3.6.1.4.1.25506.2.113.2.5.1.1) |
not-accessible |
Integer32 |
Integer32(0..2147483647) |
Index of the default next hop. |
As per the MIB. |
hh3cPBRMibApplyNexthopVpnName (1.3.6.1.4.1.25506.2.113.2.5.1.2) |
read-create |
DisplayString |
DisplayString (SIZE (0..31)) |
VPN instance name of the next hop. |
As per the MIB. |
hh3cPBRMibApplyNexthopAddressType (1.3.6.1.4.1.25506.2.113.2.5.1.3) |
read-create |
InetAddressType |
ipv4(1), ipv6(2), |
Supports IPv4 and IPv6. |
hh3cPBRMibApplyNexthopAddress (1.3.6.1.4.1.25506.2.113.2.5.1.4) |
read-create |
InetAddress |
Next hop address. |
As per the MIB. |
hh3cPBRMibApplyNexthopTrackId (1.3.6.1.4.1.25506.2.113.2.5.1.5) |
read-create |
Integer32 |
ID of the track entry associated with the next hop. |
As per the MIB. |
hh3cPBRMibApplyNexthopDirect (1.3.6.1.4.1.25506.2.113.2.5.1.6) |
read-create |
TruthValue |
Effective condition of the next hop that it must be directly connected. |
As per the MIB. |
hh3cPBRMibApplyNexthopRowStatus (1.3.6.1.4.1.25506.2.113.2.5.1.7) |
read-create |
RowStatus |
Operation type of the next hop. |
As per the MIB. |
hh3cPBRMibApplyNexthopInboundVpn (1.3.6.1.4.1.25506.2.113.2.5.1.8) |
read-create |
TruthValue |
VPN instance of the inbound interface associated with the next hop. |
As per the MIB. |
hh3cPBRMibApplyNexthopWeight (1.3.6.1.4.1.25506.2.113.2.5.1.9) |
read-create |
Integer32 |
Integer32(1..100) |
Load sharing weight for the next hop. |
As per the MIB. |
hh3cPBRMibApplyNexthopPathId (1.3.6.1.4.1.25506.2.113.2.5.1.10) |
read-create |
Integer32 |
Integer32(1..16777215) |
Service chain path ID of the next hop. |
As per the MIB. |
hh3cPBRMibApplyNexthopPathIndex (1.3.6.1.4.1.25506.2.113.2.5.1.11) |
read-create |
Integer32 |
Integer32(1..255) |
Service chain node index of the next hop. |
As per the MIB. |
hh3cPBRMibApplyDefaultNexthopTable
About this table
This table is used to set default next hops for matching packets on a policy node.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are hh3cPBRMibPolicyNodeAddrType, hh3cPBRMibPolicyName, hh3cPBRMibPolicyNodeId, and hh3cPBRMibApplyDefaultNexthopIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPBRMibApplyDefaultNexthopIndex (1.3.6.1.4.1.25506.2.113.2.6.1.1) |
not-accessible |
Integer32 |
As per the MIB. |
hh3cPBRMibApplyDefaultNexthopVpnName (1.3.6.1.4.1.25506.2.113.2.6.1.2) |
read-create |
DisplayString |
VPN instance name of the default next hop. |
As per the MIB. |
hh3cPBRMibApplyDefaultNexthopAddressType (1.3.6.1.4.1.25506.2.113.2.6.1.3) |
read-create |
InetAddressType |
ipv4(1), ipv6(2), |
Default next hop address type. |
hh3cPBRMibApplyDefaultNexthopAddress (1.3.6.1.4.1.25506.2.113.2.6.1.4) |
read-create |
InetAddress |
Default next hop address. |
As per the MIB. |
hh3cPBRMibApplyDefaultNexthopTrackId (1.3.6.1.4.1.25506.2.113.2.6.1.5) |
read-create |
Integer32 |
ID of the track entry associated with the default next hop. |
As per the MIB. |
hh3cPBRMibApplyDefaultNexthopDirect (1.3.6.1.4.1.25506.2.113.2.6.1.6) |
read-create |
TruthValue |
Effective condition of the default next hop that it must be directly connected. |
As per the MIB. |
hh3cPBRMibApplyDefaultNexthopRowStatus (1.3.6.1.4.1.25506.2.113.2.6.1.7) |
read-create |
RowStatus |
Operation type of the default next hop. |
As per the MIB. |
hh3cPBRMibApplyDefNexthopInbVpn (1.3.6.1.4.1.25506.2.113.2.6.1.8) |
read-create |
TruthValue |
VPN instance of the inbound interface associated with the default next hop. |
As per the MIB. |
hh3cPBRMibApplyDefNexthopPathId (1.3.6.1.4.1.25506.2.113.2.6.1.9) |
read-create |
Integer32 |
Service chain path ID of the default next hop. |
As per the MIB. |
hh3cPBRMibApplyDefNexthopPathInd (1.3.6.1.4.1.25506.2.113.2.6.1.10) |
read-create |
Integer32 |
Integer32(1..255) |
Service chain node index of the default next hop. |
As per the MIB. |
