12-Network Management and Monitoring Command Reference
HomeSupportRouters5G IPRAN Access RoutersReference GuidesCommand ReferencesH3C RA5300[5300-X][5300-AC] Routers Command Reference-R7752-6W10212-Network Management and Monitoring Command Reference
11-Network synchronization commands
11-Network synchronization commands 122.60 KB
display network-clock source
Use display network-clock source to display information about the clock sources.
# Display information about the clock sources.
<Sysname> display network-clock source
Traced reference: XGE2/0/0
Reference   State   Priority  SSM level Force SSM Sa-Bit  LPU port  Frequency
BITS0       Lost    255       Unknown   ON        4       N/A       2 Mbps
XGE2/0/0    Normal  10        Unknown   OFF       N/A     Yes       N/A
Traced reference
Traced clock source.
If a clock source is traced, the network clock monitoring module distributes its timing signal to all interface cards.
If no clock source has been traced, this field displays N/A.
Reference
Clock source:
Line clock source. The value is the line clock input port. This information is displayed only when a line clock input port is configured.
State of the clock source:
·     Normal—The clock source is operating correctly.
·     Lost—The clock source is not available or is in an error condition.
Priority
Priority of the clock source.
SSM level
SSM quality level in descending order:
·     PRC—G.811 primary reference clock.
·     SSU-A—G.812 primary-level SSU.
·     SSU-B—G.812 second-level SSU.
·     SEC—SDH equipment clock.
·     DNU—Do not use for synchronization.
·     Unknown—Unknown quality level.
Force SSM
Whether to use the manually assigned SSM quality level:
·     ON—Uses the manually assigned SSM quality level.
·     OFF—Extracts the SSM quality level from the received timing signal.
Sa bit
Sa bit used by BITS to transmit the SSM:
·     sa4—Bit Sa4.
·     sa5—Bit Sa5.
·     sa6—Bit Sa6.
·     sa7—Bit Sa7.
·     sa8—Bit Sa8.
This field displays N/A for line clock sources, because line clocks do not support the Sa bit configuration.
LPU port
Whether the line clock input port takes effect:
·     Yes—The line clock input port takes effect.
·     No—The line clock input port does not take effect.
This field displays N/A for BITS 0 clock source.
Frequency
Frequency of the BITS clock:
·     2 Mbps.
·     2 MHz.
display network-clock status
Use display network-clock status to display the operating state of the network clock monitoring module.
# Display the operating state of the network clock monitoring module.
<Sysname> display network-clock status
Mode              : Auto
Reference         : N/A
Traced reference  : N/A
Lock mode         : Unknown
SSM output level  : SSUB
SSM control enable: On
Mode
Clock reference selection mode:
·     Auto—Automatic reference selection.
·     Manual—Manual reference selection.
Reference
Manually specified clock reference. This field displays N/A if no clock reference has been specified.
Traced reference
Clock reference that has been selected and traced. This field displays N/A if no clock reference has been selected.
Lock mode
Phase lock state of the clock monitoring module:
·     Freerun—Freerun mode.
·     Locked—Locked (traced) mode.
·     Holdover—Holdover state.
·     Pre-locked—Pre-locked mode.
·     Lost—The clock signal has been lost.
·     Unknown—No timing signal is available. The network clock monitoring module is in an exceptional condition.
SSM output level
Signal quality level of the clock source in the SSM, by descending order of quality:
SSM control enable
Contribution of SSM to automatic reference selection:
·     On—SSM is used in the selection process.
·     Off—SSM is not used in the selection process.
network-clock source forcessm
Use network-clock source forcessm to configure the method for setting the quality level of a clock source.
Use undo network-clock source forcessm to restore the default.
network-clock source { bits0 | lpuport interface-type interface-number | ptp } forcessm { off | on }
undo network-clock source { bits0 | lpuport interface-type interface-number | ptp } forcessm
The network clock monitoring module sets the quality level of a clock source to the user-assigned value. It does not extract the quality level from the SSM sent by the clock source.
bits0: Specifies the BITS 0 clock.
lpuport interface-type interface-number: Specifies a line clock. The interface-type interface-number arguments specify the type and number of the line clock input port.
ptp: Specifies the PTP clock.
off: Sets the quality level of a clock source to the value extracted from the SSM sent by the clock source.
on: Sets the quality level of a clock source to the user-assigned value.
# Set the quality level of BITS 0 to the value extracted from the SSM sent by the clock source.
[Sysname] network-clock source bits0 forcessm off
network-clock source frequency
Use network-clock source frequency to set the frequency of a BITS clock.
Use undo network-clock source frequency to restore the default.
network-clock source bits0 frequency { bps-2m | hz-2m }
undo network-clock source bits0 frequency
The frequency of a BITS clock is 2 Mbps.
bps-2m: Sets the frequency to 2 Mbps.
hz-2m: Sets the frequency to 2 MHz.
# Set the frequency to 2 MHz for BITS 0.
[Sysname] network-clock source bits0 frequency hz-2m
network-clock source priority
Use network-clock source priority to set the priority of a clock source.
Use undo network-clock source priority to restore the default.
network-clock source { bits0 | lpuport interface-type interface-number | ptp } priority priority
undo network-clock source { bits0 | lpuport interface-type interface-number | ptp } priority
All clock sources have a priority of 255.
priority priority: Sets a priority value in the range of 1 to 255. The lower the value, the higher quality the timing signal.
# Assign a priority of 3 to BITS 0.
[Sysname] network-clock source bits0 priority 3
network-clock source sa-bit
Use network-clock source sa-bit to set the Sa bit used to transmit the SSM for a BITS clock.
Use undo network-clock source sa-bit to restore the default.
network-clock source bits0 sa-bit { sa4 | sa5 | sa6 | sa7 | sa8 }
undo network-clock source bits0 sa-bit
BITS clocks use Sa4 to transmit the SSM.
sa-bit: Specifies an Sa bit.
·     sa4—Specifies bit Sa4.
·     sa5—Specifies bit Sa5.
·     sa6—Specifies bit Sa6.
·     sa7—Specifies bit Sa7.
·     sa8—Specifies bit Sa8.
# Specify Sa5 as the SSM bit for BITS 0.
[Sysname] network-clock source bits0 sa-bit sa5
network-clock source ssm
Use network-clock source ssm to assign an SSM quality level to a clock source.
Use undo network-clock source ssm to restore the default.
network-clock source { bits0 | lpuport interface-type interface-number | ptp } ssm { dnu | prc | sec | ssua | ssub | unknown }
undo network-clock source { bits0 | lpuport interface-type interface-number | ptp } ssm
The SSM quality level is unknown for all clock sources.
dnu: Sets the SSM quality level to DNU SSM quality level. DNU clock sources cannot participate in automatic clock reference selection.
prc: Sets the SSM quality level to G.811 primary reference clock.
sec: Sets the SSM quality level to SDH equipment clock.
ssua: Sets the SSM quality level to G.812 primary-level SSU.
ssub: Sets the SSM quality level to G.812 second-level SSU.
unknown: Sets the SSM quality level to unknown.
For the manually assigned SSM quality level to take effect, you must configure the network-clock source forcessm on command.
It takes time for an SSM quality level change to take effect. To verify the effectiveness of the change, use the display network-clock source command or check the log.
# Set the SSM quality level of BITS 0 to DNU.
[Sysname] network-clock source bits0 ssm dnu
network-clock ssmcontrol
Use network-clock ssmcontrol to control the use of SSM quality level in the automatic reference selection process.
Use undo network-clock ssmcontrol to restore the default.
network-clock ssmcontrol { off | on }
The SSM quality level is ignored in the automatic reference selection process.
off: Ignores the SSM quality level in clock reference selection.
on: Includes the SSM quality level as a factor for clock reference selection.
This command takes effect for automatic clock reference selection.
# Include the SSM quality level into the automatic clock reference selection process.
[Sysname] network-clock ssmcontrol on
network-clock ssm
network-clock work-mode
Use network-clock work-mode to set the clock reference selection mode.
Use undo network-clock work-mode to restore the default.
network-clock work-mode { auto | manual source { bits0 | lpuport interface-type interface-number } }
Automatic reference selection mode applies.
auto: Enables automatic reference selection.
manual source: Enables manual reference selection.
bits0: Specifies BITS 0 as the reference.
lpuport interface-type interface-number: Specifies a line clock input port as the reference. The interface-type interface-number arguments specify an interface by its type and number.
It takes time for a clock reference selection mode change to take effect. To verify the effectiveness of the change, use the display network-clock status command or check the log.
# Specify BITS 0 as the clock reference.
[Sysname] network-clock work-mode manual source bits0
# Enable automatic reference selection.
[Sysname] network-clock work-mode auto
network-clock lpuport
Synchronous Ethernet commands
display esmc
Use display esmc to display ESMC information.
display esmc [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the command displays ESMC information for all interfaces.
ESMC information is not available for interfaces in asynchronous mode.
# Display ESMC information for all interfaces.
<Sysname> display esmc
Interface   : Ten-GigabitEthernet2/0/0
Mode        : Synchronous
ESMC status : Enable
ESMC bundle : 3
Port status : Up
Duplex mode : Full
QL received : QL-SEC
QL sent     : QL-PRC
ESMC information packets received : 2195
ESMC information packets sent     : 6034
ESMC event packets received       : 1
ESMC event packets sent           : 16
ESMC information rate             : 1 packets/sec
ESMC expiration                   : 5 seconds
Interface that receives ESMC messages.
Mode
Ethernet interface mode:
·     Synchronous—Synchronous mode.
·     on-Synchronous—Asynchronous mode.
ESMC status
Whether ESMC is enabled:
·     Enable—ESMC is enabled.
·     Disable—ESMC is disabled.
ESMC bundle
ESMC bundle to which the interface is assigned.
This field displays N/A if the interface is not assigned to any ESMC bundle.
Duplex mode
Duplex mode of the interface:
·     Full—The interface is operating in full-duplex mode.
·     Half—The interface is operating in half-duplex mode.‌
QL received
QL sent
Quality level in the ESMC packet most recently received or sent on the interface:
·     UNK—Unknown quality level.
Number of received or sent ESMC information packets.
Number of received or sent ESMC event packets.
Transmission rate of ESMC information packets.
The value is fixed at 1 pps.
ESMC expiration
ESMC expiration timer. The timer is fixed at 5 seconds.
esmc enable
synchronous mode
esmc bundle
Use esmc bundle to assign an interface to an ESMC bundle.
Use undo esmc bundle to remove an interface from the ESMC bundle.
esmc bundle bundle-number
undo esmc bundle
An interface is not assigned to an ESMC bundle.
Ethernet interface view
FlexE physical interface view
bundle-number: Specifies an ESMC bundle by its number. The value range for the bundle-number argument is 1 to 64.
If a device has multiple interfaces directly connected to the peer device and the interfaces are enabled with SyncE and ESMC, assign these interfaces to an ESMC bundle. This configuration will prevent SyncE clock loops.
When the device selects one interface in an ESMC bundle for clock synchronization, the priority of ESMC messages sent from all interfaces in the bundle is set to DNU. This prevents the peer device from synchronizing with the clock of the device by using the clock information from these interfaces and ensures that no clock loops will be produced.
For this command to take effect, you must first configure the synchronous mode command.
# Assign Ten-GigabitEthernet2/0/0 to ESMC bundle 3.
[Sysname] interface ten-gigabitethernet 2/0/0
[Sysname-Ten-GigabitEthernet2/0/0] synchronous mode
[Sysname-Ten-GigabitEthernet2/0/0] esmc bundle 3
esmc enable
synchronous mode
esmc enable
Use esmc enable to enable the Ethernet synchronization messaging channel (ESMC) on an Ethernet interface.
Use undo esmc enable to disable the Ethernet synchronization messaging channel (ESMC) on an Ethernet interface.
esmc enable
undo esmc enable
ESMC is disabled on Ethernet interfaces.
Before you can enable ESMC, you must configure the interface to operate in synchronous mode.
# Enable ESMC on Ten-GigabitEthernet 2/0/0.
[Sysname-Ten-GigabitEthernet2/0/0] esmc enable
display esmc
synchronous mode
synce state
Use synce state to set the clock mode on a copper GE port.
Use undo synce state to restore the default.
synce state { master | slave }
undo synce state
The clock mode of a GE copper port is automatically negotiated.
master: Specifies the master clock mode.
slave: Specifies the slave clock mode.
To avoid a negotiation result that conflicts with your clock synchronization trail design, manually set the clock mode.
·     To derive timing from the upstream clock, set the clock mode to slave.
·     To provide timing for the downstream clock, set the clock mode to master.
# Configure Ten-GigabitEthernet 2/0/0 to operate in master mode.
[Sysname-Ten-GigabitEthernet2/0/0] synce state master
synchronous mode
Use synchronous mode to enable the synchronous mode on an Ethernet interface.
Use undo synchronous mode to restore the default.
synchronous mode
Ethernet interfaces are regular Ethernet interfaces in non-synchronous mode. They do not extract timing signals, send, forward, or process ESMC packets.
You can configure an interface as a line clock input port only after you enable the synchronous mode on the interface.
# Enable the synchronous mode on Ten-GigabitEthernet 2/0/0.
display esmc
esmc enable
