11-High Availability Command Reference
HomeSupportSwitchesS5590XP-HI-G SeriesTechnical DocumentsReference GuidesCommand ReferencesH3C S5590XP-HI-G Switch Series Command References--R7756Pxx-6W10011-High Availability Command Reference
14-Reth interface and redundancy group commands
14-Reth interface and redundancy group commands 220.07 KB
1 Reth interface commands
The device supports MDCs only when operating in standalone mode. For more information about MDCs, see MDC configuration in Virtual Technologies Configuration Guide.
1.1.1  bandwidth
Use bandwidth to set the expected bandwidth for a Reth interface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth is 10000 kbps for a Reth interface.
Reth interface view
# Set the expected bandwidth to 50 kbps for Reth 1.
[Sysname] interface reth 1
[Sysname-Reth1] bandwidth 50
1.1.2  default
Use default to restore the default settings for a Reth interface.
default
Reth interface view
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you execute it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions.
To resolve this problem:
Use the display this command in interface view to identify these commands.
Use their undo forms or follow the command reference to restore their default settings.
If the restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for Reth 1.
[Sysname-Reth1] default
1.1.3  description
The description of a Reth interface is interface-name plus Interface (for example, Reth1 Interface).
Reth interface view
# Configure the description of Reth 1 as master-interface.
[Sysname-Reth1] description master-interface
1.1.4  display interface reth
Use display interface reth to display Reth interface information.
display interface [ reth [ interface-number ] ] [ brief [ description | down ] ]
reth [ interface-number ]: Specifies Reth interfaces. The interface-number argument specifies an existing Reth interface by its number. If you do not specify the reth keyword, the command displays information about all interfaces. If you specify the reth keyword without the interface-number argument, the command displays information about all Reth interfaces.
down: Displays information about interfaces in down state and the causes for the down state. If you do not specify this keyword, the command displays information about interfaces in all states.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 25 characters of each interface description.
# Display detailed information about Reth 1.
<Sysname> display interface reth 1
Reth1
Current state: UP
Line protocol state: UP
Description: Reth1 Interface
Bandwidth: 10000kbps
IP packet frame type: Ethernet II, hardware address: 0cda-41b5-cf30
IPv6 packet frame type: Ethernet II, hardware address: 0cda-41b5-cf30
Physical: Reth, baudrate: 10000000 bps
表1-1 Command output
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The interface is both administratively and physically up. A Reth interface is both administratively and physically up when a minimum of one member interface is administratively and physically up.
Line protocol state
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer.
Description of the interface.
Bandwidth
Expected bandwidth of the interface.
MTU of the interface.
The interface is not assigned an IP address and cannot process IP packets.
IP address of the interface and type of the address in parentheses.
Possible IP address types include:
·     Primary—Manually configured primary IP address.
·     Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed.
·     DHCP-Allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3IP Services Configuration Guide.
·     BOOTP-AllocatedBOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3IP Services Configuration Guide.
·     PPP-Negotiated—IP address assigned by a PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2WAN Access Configuration Guide.
·     Unnumbered—IP address borrowed from another interface.
·     Cellular-Allocated—IP address allocated through the modem manufacturer's proprietary protocol. For more information, see 3G/4G modem management in Layer 2WAN Access Configuration Guide.
·     MAD—IP address assigned to an IRF member device for MAD on the interface. For more information, see IRF configuration in Virtual Technologies Configuration Guide.
·     MTunnel—IP address of the multicast tunnel interface (MTI), which is the same as the IP address of the MVPN source interface. For more information, see multicast VPN configuration in IP Multicast Configuration Guide.
IPv4 packet framing format.
hardware address
MAC address of the interface.
IPv6 packet framing format.
Physical
Interface type.
Information about the urgent output queue:
·     Size—Number of packets in the queue.
·     Length—Maximum number of packets that the queue can contain.
·     Discards—Number of dropped packets.
Information about the protocol output queue:
Information about the FIFO output queue:
Last time when the reset counters interface command was used to clear the interface statistics.
If the reset counters interface command has never been used on the interface since the device startup, this field displays Never.
Last 300 second input:  0 bytes/sec, 0 bits/sec, 0 packets/sec
Last 300 second output:  0 bytes/sec, 0 bits/sec, 0 packets/sec
Average incoming and outgoing traffic rate for the last 300 seconds.
Incoming traffic statistics on the interface:
·     Number of packets.
·     Number of bytes.
·     Number of dropped packets due to insufficient receive buffer.
Outgoing traffic statistics on the interface:
·     Number of bytes.
·     Number of dropped packets due to insufficient send buffer.
Brief information on interfaces in route mode
Brief information about Layer 3 interfaces.
Abbreviated interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
# Display brief information about Reth 1.
<Sysname> display interface reth 1 brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP           Description
Reth1                DOWN DOWN     --
# Display the causes for the down state of Reth 1.
<Sysname> display interface reth 1 brief down
Reth1                DOWN Not connected
表1-2 Command output
Interface name.
Link
Protocol
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Primary IP
Cause
Cause for the physical link state of an interface to be DOWN:
·     Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty).
1.1.5  display reth interface
Use display reth interface to display information about the member interfaces of a Reth interface.
display reth interface reth interface-number
reth interface-number: Specifies a Reth interface by its number. The value range for the interface-number argument is 1 to 2.
# Display information about the member interfaces of Reth 1.
<Sysname> display reth interface reth 1
Reth1 :
  Redundancy group  : aaa
  Member         Physical status       Forwarding status      Presence status
  GE1/1/0/1      UP                    Active                 Normal
  GE1/1/0/2      UP                    Inactive               Normal
表1-3 Command output
Redundancy group
The redundancy group to which the Reth interface belongs.
If the Reth interface is not in any redundancy group, this field displays N/A.
Member
Name of the member interface.
Physical status
Physical status of the member interface:
·     Down (redundancy down)—The interface has been shut down by the Reth module.
·     Down—The interface is administratively up but physically down possibly because no physical link is present or the link has failed.
Forwarding status
Forwarding status of the member interface:
·     Active—The member interface can forward packets.
·     Inactive—The member interface cannot forward packets.
Presence status
Status of the member interface:
·     Normal—The member interface exists.
·     Absent—The member interface does not exist.
1.1.6  interface reth
Use interface reth to create a Reth interface and enter its view, or enter the view of an existing Reth interface.
Use undo interface reth to delete a Reth interface.
undo interface reth interface-number
No Reth interfaces exist.
interface-number: Specifies a Reth interface by its number. The value range for this argument is 1 to 2.
To use the Reth interface feature on an MPU, make sure it has a minimum of two management Ethernet interfaces.
After you assign a management Ethernet interface to a Reth interface, you cannot log in through this management Ethernet interface.
You cannot delete a Reth interface if it has member interfaces.
# Create Reth 1 and enter its view.
[Sysname-Reth1]
1.1.7  member interface
Use member interface to assign a member interface to a Reth interface.
Use undo member interface to remove a member interface from a Reth interface.
member interface interface-type interface-number priority priority
undo member interface interface-type interface-number
A Reth interface does not have member interfaces.
Reth interface view
interface-type interface-number: Specifies an interface by its type and number. The interface must be a management Ethernet interface.
priority: Specifies an interface priority in the range of 1 to 255. The higher the value, the higher the interface priority.
You can assign a maximum of two member interfaces to a Reth interface. An interface can belong to only one Reth interface.
As a best practice, assign interfaces of the same type and same speed to a Reth interface.
When the two member interfaces of a Reth interface are up, the system chooses the interface with the higher priority as the active interface to forward packet. The interface with the lower priority is inactive and cannot forward packets.
Do not specify a Reth interface as the outgoing interface in IPv6 static neighbor entries if its member interfaces contain subinterfaces. For more information about IPv6 static neighbor entries, see Layer 3—IP Services Configuration Guide.
# Assign M-GigabitEthernet 0/0/0 and M-GigabitEthernet 0/0/1 to Reth 1, and set their priority to 100 and 50, respectively.
[Sysname-Reth1] member interface M-GigabitEthernet 0/0/0 priority 100
[Sysname-Reth1] member interface M-GigabitEthernet 0/0/1 priority 50
1.1.8  mtu
Use mtu to set the MTU of a Reth interface.
mtu size
undo mtu
The MTU is 1500 bytes for a Reth interface.
Reth interface view
size: Specifies the MTU in bytes. The value range for this argument is 46 to 1500.
The MTU size of a Reth interface affects the fragmentation and reassembly of IP packets on the interface.
For the configured MTU size to take effect, execute the shutdown command, and then the undo shutdown command on the interface.
# Set the MTU to 200 bytes for Reth 1.
[Sysname-Reth1] mtu 200
1.1.9  reset counters interface reth
Use reset counters interface reth to clear statistics for Reth interfaces.
reset counters interface [ reth [ interface-number ] ]
reth [ interface-number ]: Specifies Reth interfaces. The interface-number argument specifies an existing Reth interface by its number. If you do not specify the reth keyword, the command clears statistics for all interfaces. If you specify the reth keyword without the interface-number argument, the command clears statistics for all Reth interfaces.
Use this command to clear history statistics before you collect traffic statistics for a time period.
# Clear statistics for Reth 1.
<Sysname> reset counters interface reth 1
1.1.10  shutdown
Use shutdown to shut down a Reth interface.
Use undo shutdown to bring up a Reth interface.
shutdown
A Reth interface is not manually shut down.
Reth interface view
This command disconnects all links set up on a Reth interface. Make sure you are fully aware of its impacts when you use it on a live network.
# Shut down Reth 1.
[Sysname-Reth1] shutdown
2 Redundancy group commands
The redundancy group feature is supported only in IRF mode.
2.1.1  bind chassis
Use bind chassis to bind a redundancy group node to an IRF member device.
Use undo bind chassis to remove the binding between a redundancy group node and an IRF member device.
bind chassis chassis-number
undo bind chassis
A redundancy group node is not bound to an IRF member device.
Redundancy group node view
chassis-number: Specifies an IRF member device by its member ID.
You can create only one-to-one bindings between redundancy group nodes and IRF member devices.
The node in a binding can use interfaces of the bound IRF member device as members. Member interfaces on one node of a redundancy group back up the member interfaces on the other node.
You cannot change the binding for a node if the node has member interfaces.
# Bind node 1 in redundancy group aaa to IRF member device 3.
[Sysname] redundancy group aaa
[Sysname-redundancy-group-aaa] node 1
[Sysname-redundancy-group-aaa-node1] bind chassis 3
2.1.2  display redundancy group
Use display redundancy group to display redundancy group information.
display redundancy group [ group-name ]
group-name: Specifies a redundancy group by its name, a case-sensitive string of 1 to 15 characters. If you do not specify a redundancy group, this command displays information about all redundancy groups.
# Display information about redundancy group aaa.
<Sysname> display redundancy group aaa
Redundancy group aaa (ID 1):
  Node ID      Slot        Priority   Status           Track weight
  1            Slot1       100        Secondary        -255
  2            Slot2       99         Primary          255
Preempt delay time remained   : 0    min
Preempt delay timer setting   : 1    min
Remaining hold-down time      : 0    sec
Hold-down timer setting       : 300  sec
Manual switchover request     : No
Member interfaces:
    Reth1          Reth2
Member failover groups:
Node 1:
  Node member     Physical status
    GE1/0/2       DOWN
    GE1/0/4       DOWN(redundancy down)
  Track info:
    Track    Status       Reduced weight     Interface
    1        Negative     255                GE1/0/2(Fault)
    2        Negative     255                GE1/0/4
Node 2:
    GE2/0/2      UP
    GE2/0/4      UP
  Track info:
    3        Positive     55                 GE2/0/2
    4        Positive     55                 GE2/0/4
表2-1 Command output
Priority
Priority of the node.
Status
Node status:
·     Primary—The primary node. It can forward packets.
·     Secondary—The secondary node. When the high-priority node acts as the secondary node, all its member interfaces are shut down by the Reth module and cannot forward packets. When the low-priority node acts as the secondary node, all its member interfaces can forward packets.
Track weight
Weight of the node.
Remaining preemption delay time in minutes.
Configured preemption delay timer in minutes.
Remaining hold-down time in seconds.
Configured hold-down timer in seconds.
Manual switchover request:
·     Yes—A request is issued.
·     No—No request is issued.
Member interfaces
Reth interfaces in the redundancy group.
Node 1
Detailed information about the redundancy group node.
Physical status
Physical status of the member interfaces on the node:
·     Down (redundancy down)—The interface is shut down by the Reth module.
Track info
Information about the track entries associated with the node.
Track
Track entry number.
Status
Track entry status.
Reduced weight
Weight decrement rate of the node.
The interface excluded from the shutdown action by the Reth module.
If the interface has failed, this field displays Fault. If the interface is not present, this field displays Absent.
2.1.3  hold-down-interval
Use hold-down-interval to set the hold-down timer for a redundancy group.
Use undo hold-down-interval to restore the default.
hold-down-interval second
The hold-down timer is 1 second for a redundancy group.
Redundancy group view
second: Specifies the hold-down timer in the range of 0 to 1800 seconds.
Set the hold-down timer to prevent frequent switchovers. The hold-down timer specifies the minimum interval between two switchovers. This timer starts when a switchover is finished. The redundancy group can perform another switchover only after the hold-down timer expires.
# Set the hold-down timer to 300 seconds for redundancy group aaa.
[Sysname-redundancy-group-aaa] hold-down-interval 300
2.1.4  member interface
Use member interface to assign a Reth interface to a redundancy group.
Use undo member interface to remove a Reth interface from a redundancy group.
member interface reth interface-number
undo member interface reth interface-number
A redundancy group does not contain Reth interfaces.
reth interface-number: Specifies an existing Reth interface by its number. The value range for the interface-number argument is 1 to 2.
You can assign a Reth interface to only one redundancy group.
# Assign Reth 1 to redundancy group aaa.
[Sysname-redundancy-group-aaa] member interface reth 1
2.1.5  node
Use node to create a redundancy group node and enter its view, or enter the view of an existing redundancy group node.
Use undo node to remove a redundancy group node.
node node-id
undo node node-id
No redundancy group nodes exist.
node-id: Specifies a redundancy group node ID in the range of 1 to 2.
You can create a maximum of two nodes for a redundancy group. One is the primary node, and the other is the secondary node.
Before you delete a redundancy group node, you must remove the binding between the node and its IRF member device.
# Create node 1 for redundancy group aaa.
bind chassis
2.1.6  preempt-delay
Use preempt-delay to set the preemption delay timer for a redundancy group.
Use undo preempt-delay to restore the default.
preempt-delay min
undo preempt-delay
The preemption delay timer is 1 minute for a redundancy group.
min: Specifies the preemption delay timer in the range of 0 to 12 minutes. If you set this timer to 0 seconds, manual and automatic switchovers to the high-priority node are disabled.
The preemption delay timer specifies the delay before a switchover to the high-priority node occurs after the switchover is triggered. The delay allows the system to process events (such as interface state changes) required for the switchover.
# Set the preemption delay timer to 2 minutes for redundancy group aaa.
[Sysname-redundancy-group-aaa] preempt-delay 2
2.1.7  priority
Use priority to set the priority of a redundancy group node.
Use undo priority to restore the default.
priority priority
undo priority
The priority of a redundancy group node is 1.
priority: Specifies the priority in the range of 1 to 255. The higher the value, the higher the priority.
By default, the high-priority node is the primary node, and the low-priority node is the secondary node. If both nodes have the same priority, the lower-numbered node is the primary node.
# Set the priority to 3 for node 1 of redundancy group aaa.
[Sysname-redundancy-group-aaa-node1] priority 3
2.1.8  redundancy group
Use redundancy group to create a redundancy group and enter its view, or enter the view of an existing redundancy group.
Use undo redundancy group to remove a redundancy group.
redundancy group group-name
undo redundancy group group-name
No redundancy groups exist.
group-name: Specifies a redundancy group name, a case-sensitive string of 1 to 15 characters.
Before you delete a redundancy group, make sure all its Reth interfaces and nodes are removed.
# Create redundancy group aaa and enter its view.
2.1.9  snmp-agent trap enable rddc
Use snmp-agent trap enable rddc to enable SNMP notifications for redundancy groups.
Use undo snmp-agent trap enable rddc to disable SNMP notifications for redundancy groups.
SNMP notifications are enabled for redundancy groups.
This command enables SNMP notifications for the following events:
·     A manual switchover is performed.
·     An interface goes down.
·     A faulty interface is recovered.
For redundancy group event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Enable SNMP notifications for redundancy groups.
[Sysname] snmp-agent trap enable rddc
2.1.10  switchover request
Use switchover request to request a switchover to the low-priority node.
switchover request
Use this command to request a switchover to the low-priority node when both of the redundancy group nodes are operating correctly. This command can be used in scenarios where component replacement is required for the high-priority node.
# Request a switchover to the low-priority node for redundancy group aaa.
[Sysname-redundancy-group-aaa] switchover request
switchover reset
2.1.11  switchover reset
Use switchover reset to request a switchover to the high-priority node.
switchover reset
Use this command to request a switchover to the high-priority node when both of the redundancy group nodes are operating correctly.
# Request a switchover to the high-priority node for redundancy group aaa.
[Sysname-redundancy-group-aaa] switchover reset
switchover request
2.1.12  track
Use track to associate a track entry with a redundancy group node.
Use undo track to remove the association between a track entry and a redundancy group node.
track track-entry-number [ reduced weight-reduced ] [ interface interface-type interface-number ]
undo track track-entry-number
A redundancy group node is not associated with track entries.
track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
reduced weight-reduced: Specifies the weight decrement rate in the range of 1 to 255. The default is 255.
interface interface-type interface-number: Specifies an interface by its type and number. The interface will be excluded from the shutdown action by the Reth module. If you do not specify this option, no interface is excluded from the shutdown action by the Reth module. You must specify the tracked interface for this option if the interface has one of the following roles:
·     Member of the redundancy group.
·     Member of a Reth interface in the redundancy group.
You can associate a maximum of 64 track entries with a redundancy group node.
As a best practice, associate a redundancy group node with an existing track entry. If the track entry does not exist, a switchover might occur.
Do not exclude a subinterface from the shutdown action if both the subinterface and its main interface have one of the following roles on the high-priority node:
When the Reth module shuts down the main interface, the subinterface is also shut down. The shutdown subinterface cannot recover automatically to trigger an automatic switchover.
# Associate track entries 1 and 2 with redundancy group node 1. Exclude Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2 from the shutdown action by the Reth module.
[Sysname] track 1 interface ten-gigabitethernet 3/0/1
[Sysname] track 2 interface ten-gigabitethernet 3/0/2
[Sysname-redundancy-group-aaa-node1] track 1 reduced 50 interface ten-gigabitethernet 3/0/1
[Sysname-redundancy-group-aaa-node1] track 2 reduced 50 interface ten-gigabitethernet 3/0/2
