12-Network Management and Monitoring Configuration Guide
HomeSupportSwitchesS5590XP-HI-G SeriesTechnical DocumentsConfigure & DeployConfiguration GuidesH3C S5590XP-HI-G Switch Series Configuration Guides--R7756Pxx-6W10012-Network Management and Monitoring Configuration Guide
25-EPS agent configuration
25-EPS agent configuration 164.31 KB
Configuring EPS agent
About EPS and EPS agent
H3C iMC Endpoints Profiling System (EPS) detects, identifies, and monitors network-wide endpoints, including cameras, PCs, servers, switches, routers, firewalls, APs, printers, and ATMs. New endpoints and abnormal endpoints can be timely discovered and identified.
As shown in Figure 1, an EPS system contains the EPS server, scanners, and endpoints.
Figure 1 EPS network architecture
EPS server
The EPS server is a server installed with the iMC EPS component. It acts as the console to assign instructions to scanners, receive scan results, compare scan results with baselines, and support change auditing.
Scanner
A scanner is a device installed with iMC EScan and enabled with EPS agent. The scanner scans and manages endpoints by following the instruction of the EPS server and reports scan results to the EPS server.
EPS agent is based on the Comware platform and integrates the EPS scanner function. This chapter describes how to configure EPS agent.
Endpoint
An endpoint refers to a device scanned by a scanner. EPS supports user-defined endpoint types and the following system-defined endpoint types: camera, PC, server, switch, router, firewall, AP, printer, ATM, unknown, and other.
Before you configure EPS agent, execute the display boot-loader command to determine whether the scanner feature image EScan is displayed in the Current software images field. If EScan is not installed, install it by using the boot-loader, install, or issu command, and then relog in to the device.
For more information about the display boot-loader and boot-loader commands, see software upgrade commands in Fundamentals Command Reference. For more information about the install and issu commands, see ISSU commands in Fundamentals Command Reference.
After you enable EPS agent for the scanner on a slot, the scanner scans and manages connected, reachable endpoints in its ARP table by following the instructions of the EPS server.
2.     Configure EPS server parameters
eps server ip-address port port-number [ key { cipher | simple } key-value ] [ log-level level-value ] [ use-server-setting ]
By default, EPS server parameters are not configured.
3.     Enable EPS agent.
eps agent enable [ slot slot-number ]
By default, EPS agent is disabled.
Display and maintenance commands for EPS agent
Display scanned endpoint information.
display eps agent discovery [ slot slot-number ]
EPS agent configuration examples
Example: Configuring EPS agent
As shown in Figure 2, configure the scanner to enable it to scan endpoints based on the instruction of the EPS server.
Figure 2 Network diagram
# Display system version information, and prepare the EScan feature image file compatible with the current boot image file and system image file.
<Device> display version
H3C Comware Software, Version 7.1.070, Demo 01
Copyright (c) 2004-2019 New H3C Technologies Co., Ltd. All rights reserved.
H3C XXX uptime is 0 weeks, 0 days, 5 hours, 33 minutes
Last reboot reason : Cold reboot
Boot image: flash:/boot-01.bin
Boot image version: 7.1.070, Demo 01
  Compiled Oct 20 2019 16:00:00
System image: flash:/system-01.bin
System image version: 7.1.070, Demo 01
# Download the EScan feature image file EScan.bin from TFTP server 192.168.1.1.
<Device> tftp 192.168.1.1 get escan.bin
Press CTRL+C to abort.
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 11.3M    0 11.3M    0     0   155k      0 --:--:--  0:01:14 --:--:--  194k
Writing file...Done.
# Install EScan.bin on all IRF member devices and commit software changes. In this example, EScan.bin is installed on slot 1.
<Device> install activate feature flash:/escan.bin slot 1
Verifying the file flash:/escan.bin on slot 1....Done.
Identifying the upgrade methods....Done.
flash:/escan.bin
  Running Version             New Version
  None                        Demo 01
  Slot                        Upgrade Way
  1                           Service Upgrade
This operation might take several minutes, please wait....................Done.
<Device> install commit
This operation will take several minutes, please wait.......................Done.
# Relog in to the device.
# Specify 20.1.1.2 and 4500 as the IP address and port number of the EPS server, respectively.
[Sysname] eps server 20.1.1.2 port 4500
# Enable EPS agent on slot 1.
[Sysname] eps agent enable slot 1
# Display EPS scanner information.
[Sysname] display eps agent
EPS agent information:
  Slot       Port number
  1          12000
EPS server information:
  IP address        : 20.1.1.2
  Port number       : 4500
  Cipher key        : $c$3$rGn++lJ/vHnkk1oQDAKX9NLIz+4vXONZXCRTpQ==
  Log level         : 5
  Use server setting: Yes
# Verify that the scanned information is displayed on slot 1 after the EPS server issues a scan instruction.
[Sysname] display eps agent discovery slot 1
IP-Address        MAC-Address        OS-Type  OS-ver   Vendor    Product
100.100.100.100  cc:ef:48:9b:5f:c1 IOS       12.X     Cisco     C3560E
