04-Layer 2—LAN Switching Configuration Guide
HomeSupportSwitchesS5590XP-HI-G SeriesTechnical DocumentsConfigure & DeployConfiguration GuidesH3C S5590XP-HI-G Switch Series Configuration Guides--R7756Pxx-6W10004-Layer 2—LAN Switching Configuration Guide
09-Loop detection configuration
09-Loop detection configuration 232.38 KB
Configuring loop detection
About loop detection
The loop detection mechanism performs periodic checking for Layer 2 loops. The mechanism immediately generates a log when a loop occurs so that you are promptly notified to adjust network connections and configurations. You can configure loop detection to shut down the looped interface. Logs are maintained in the information center. For more information, see Network Management and Monitoring Configuration Guide.
Loop detection mechanism
The device detects loops by sending detection frames and then checking whether these frames return to any interface on the device. If they do, the device considers that the interface is on a looped link.
Loop detection usually works within a VLAN. If a detection frame is returned with a different VLAN tag than it was sent out with, an inter-VLAN loop has occurred. To remove the loop, examine the QinQ or VLAN mapping configuration for incorrect settings. For more information about QinQ and VLAN mapping, see "Configuring QinQ" and "Configuring VLAN mapping."
Figure 1 Ethernet frame header for loop detection
The Ethernet frame header of a loop detection packet contains the following fields:
·     DMACDestination MAC address of the frame, which is the multicast MAC address 010f-e200-0007. When a loop detection-enabled device receives a frame with this destination MAC address, it performs the following operations:
¡     Sends the frame to the CPU.
¡     Floods the frame in the VLAN from which the frame was originally received.
·     SMACSource MAC address of the frame, which is the bridge MAC address of the sending device.
·     TPIDType of the VLAN tag, with the value of 0x8100.
·     TCIInformation of the VLAN tag, including the priority and VLAN ID.
·     TypeProtocol type, with the value of 0x8918.
Figure 2 Inner frame header for loop detection
The inner frame header of a loop detection packet contains the following fields:
·     CodeProtocol sub-type, which is 0x0001, indicating the loop detection protocol.
·     VersionProtocol version, which is always 0x0000.
·     LengthLength of the frame. The value includes the inner header, but excludes the Ethernet header.
·     ReservedThis field is reserved.
Frames for loop detection are encapsulated as TLV triplets.
Table 1 TLVs supported by loop detection
TLV
Remarks
End of PDU
End of a PDU.
Optional.
Device ID
Bridge MAC address of the sending device.
Required.
Port ID
ID of the PDU sending interface.
Optional.
Port Name
Name of the PDU sending interface.
Optional.
System Name
Device name.
Optional.
Chassis ID
Chassis ID of the sending interface.
Optional.
Slot ID
Slot ID of the sending interface.
Optional.
Sub Slot ID
Sub-slot ID of the sending interface.
Optional.
Loop detection interval
Loop detection is a continuous process as the network changes. Loop detection frames are sent at the loop detection interval to determine whether loops occur on interfaces and whether loops are removed.
Loop protection actions
When the device detects a loop on an interface, it generates a log but performs no action on the interface by default. You can configure the device to take one of the following actions:
·     Block—Disables the interface from learning MAC addresses and blocks the interface.
·     No-learning—Disables the interface from learning MAC addresses.
·     Shutdown—Shuts down the interface to disable it from receiving and sending any frames.
·     VLAN-block—Blocks traffic of the VLAN where the loop is detected on the interface.
Loop detection allows you to use protected VLANs to block traffic on a per-VLAN basis. After you configure a VLAN as a protected VLAN, the device periodically sends loop detection packets in the VLAN. If the device receives a self-sent loop detection packet with the protected VLAN ID included on any interface, the device generates a log and blocks traffic of the VLAN on all interfaces configured with the VLAN-block action.
Loop protection delay
The loop protection delay enables the device to wait for a period of time before taking loop protection actions on looped interfaces. On a network protected by loop detection, the shutdown or block action taken on a looped interface of an upstream device might cause traffic interruption to its downstream devices. To minimize the impacts of loop detection on downstream traffic, set the loop protection delay on the upstream devices. This delay allows the downstream devices to remove loops before the upstream devices take an action.
Interface status auto recovery
When the device configured with the block or no-learning loop action detects a loop on an interface, it performs the action and waits three loop detection intervals. If the device does not receive a loop detection frame within three loop detection intervals, it performs the following operations:
·     Automatically sets the interface to the forwarding state.
·     Notifies the user of the event.
When the device configured with the shutdown action detects a loop on an interface, the following events occur:
1.     The device automatically shuts down the interface.
2.     The device automatically sets the interface to the forwarding state after the detection timer set by using the shutdown-interval command expires. For more information about the shutdown-interval command, see Fundamentals Command Reference.
3.     The device shuts down the interface again if a loop is still detected on the interface when the detection timer expires.
This process is repeated until the loop is removed.
The device performs the following operations if it has not received any loop detection packets in a blocked protected VLAN before three loop detection intervals expire:
·     Enables interfaces to forward traffic from the VLAN.
·     Generates a log message to report that the loop has been removed.
Incorrect recovery can occur when loop detection frames are discarded to reduce the load. To avoid this, use the shutdown action, or manually remove the loop.
Restriction and guidelines: M-LAG configuration
Member devices in an M-LAG system must have the same loop detection configuration.
Loop detection tasks at a glance
To configure loop detection, perform the following tasks:
1.     Enabling loop detection
¡     Enabling loop detection globally
¡     Enabling loop detection on an interface
2.     Configuring protected VLANs
To use the VLAN-block action, you must first configure protected VLANs. Do not perform this task if you use any other loop protection action.
3.     (Optional) Setting the loop protection action
¡     Setting the global loop protection action
¡     Setting the loop protection action on an interface
4.     (Optional) Setting the loop detection interval
5.     (Optional) Setting the loop protection delay timer
¡     Setting the global loop protection delay timer
¡     Setting the loop protection delay timer on an interface
Restrictions and guidelines for loop detection configuration
You can enable loop detection globally or on a per-interface basis. When an interface receives a detection frame in any VLAN, the loop protection action is triggered on that interface, regardless of whether loop detection is enabled on it.
If you have enabled loop detection globally, do not set the loop protection action to block when you configure loop detection on a per-interface basis.
2.     Globally enable loop detection.
loopback-detection global enable vlan { vlan-id--list | all }
By default, loop detection is globally disabled.
2.     Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view.
3.     Enable loop detection on the interface.
loopback-detection enable vlan { vlan-id--list | all }
By default, loop detection is disabled on interfaces.
2.     Configure protected VLANs.
loopback-detection protected-vlan vlan-id-list
By default, no protected VLANs are configured for loop detection.
Restrictions and guidelines for loop protection action configuration
You can set the loop protection action globally or on a per-interface basis. The global action applies to all interfaces. An interface-specific action applies to the interface on which it is configured. On an interface, the interface-specific action takes precedence over the global action.
2.     Set the global loop protection action.
loopback-detection global action shutdown
By default, the device generates a log but performs no action on the interface on which a loop is detected.
2.     Enter interface view.
3.     Set the loop protection action on the interface.
loopback-detection action { block | no-learning | shutdown | vlan-block }
To use the VLAN-block action, you must first configure protected VLANs and enable loop detection for the VLANs.
Support for the keywords of this command varies by interface type. For more information, see Layer 2LAN Switching Command Reference.
With loop detection enabled, the device sends loop detection frames at the loop detection interval. A shorter interval offers more sensitive detection but consumes more resources. Consider the system performance and loop detection speed when you set the loop detection interval.
2.     Set the loop detection interval.
loopback-detection interval-time interval
The default setting is 30 seconds.
Restrictions and guidelines for loop protection delay timer configuration
The global delay timer applies to all interfaces enabled with loop detection. An interface-specific delay timer applies to the interface on which it is configured. On an interface, the interface-specific delay timer takes precedence over the global delay timer.
To prevent interfaces from going down or coming up concurrently, set the loop protection delay timer to different values on different devices or on different interfaces of the same device.
2.     Set the global loop protection delay timer.
loopback-detection global delay-timer time
By default, loop protection delay is disabled globally.
3.     Set the loop protection delay timer on the interface.
By default, loop protection delay is disabled on an interface.
Display and maintenance commands for loop detection
Display the loop detection configuration and status.
display loopback-detection [ loop-info ]
Loop detection configuration examples
Example: Configuring basic loop detection functions
As shown in Figure 3, configure loop detection on Device A to meet the following requirements:
·     Device A generates a log as a notification.
·     Device A automatically shuts down the interface on which a loop is detected.
Figure 3 Network diagram
1.     Configure Device A:
# Create VLAN 100, and globally enable loop detection for the VLAN.
[DeviceA] vlan 100
[DeviceA-vlan100] quit
[DeviceA] loopback-detection global enable vlan 100
# Configure GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 as trunk ports, and assign them to VLAN 100.
[DeviceA] interface GigabitEthernet 1/0/1
[DeviceA-GigabitEthernet1/0/1] port trunk permit vlan 100
[DeviceA-GigabitEthernet1/0/2] port trunk permit vlan 100
# Set the global loop protection action to shutdown.
[DeviceA] loopback-detection global action shutdown
# Set the loop detection interval to 35 seconds.
[DeviceA] loopback-detection interval-time 35
2.     Configure Device B:
# Create VLAN 100.
[DeviceB] vlan 100
[DeviceB–vlan100] quit
[DeviceB-GigabitEthernet1/0/1] port trunk permit vlan 100
[DeviceB-GigabitEthernet1/0/2] port trunk permit vlan 100
3.     Configure Device C:
# Create VLAN 100.
<DeviceC> system-view
[DeviceC] vlan 100
[DeviceC–vlan100] quit
[DeviceC-GigabitEthernet1/0/1] port trunk permit vlan 100
[DeviceC-GigabitEthernet1/0/2] port link-type trunk
[DeviceC-GigabitEthernet1/0/2] port trunk permit vlan 100
# View the system logs on devices, for example, Device A.
[DeviceA]
%Feb 24 15:04:29:663 2019 DeviceA LPDT/4/LPDT_LOOPED:  A loop was detected on GigabitEthernet1/0/1.
%Feb 24 15:04:29:664 2019 DeviceA LPDT/4/LPDT_VLAN_LOOPED: A loop was detected on GigabitEthernet1/0/1 in VLAN 100.
%Feb 24 15:04:29:667 2019 DeviceA LPDT/4/LPDT_LOOPED: A loop was detected on GigabitEthernet1/0/2.
%Feb 24 15:04:29:668 2019 DeviceA LPDT/4/LPDT_VLAN_LOOPED: A loop was detected on GigabitEthernet1/0/2 in VLAN 100.
%Feb 24 15:04:44:243 2019 DeviceA LPDT/5/LPDT_VLAN_RECOVERED: A loop was removed on GigabitEthernet1/0/1 in VLAN 100.
%Feb 24 15:04:44:243 2019 DeviceA LPDT/5/LPDT_RECOVERED: All loops were removed on GigabitEthernet1/0/1.
%Feb 24 15:04:44:248 2019 DeviceA LPDT/5/LPDT_VLAN_RECOVERED: A loop was removed on GigabitEthernet1/0/2 in VLAN 100.
%Feb 24 15:04:44:248 2019 DeviceA LPDT/5/LPDT_RECOVERED: All loops were removed on GigabitEthernet1/0/2.
·     Device A detected loops on GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 within a loop detection interval.
·     Loops on GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 were removed.
# Use the display loopback-detection command to display the loop detection configuration and status on devices, for example, Device A.
[DeviceA] display loopback-detection
Loop detection is enabled.
Global loop detection interval is 35 second(s).
Loop is detected on following interfaces:
  Interface                      Action mode     VLANs/VSI
  GigabitEthernet1/0/1           Shutdown        100
  GigabitEthernet1/0/2           Shutdown        100
The output shows that the device has removed the loops from GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 according to the shutdown action.
# Display the status of GigabitEthernet 1/0/1 on devices, for example, Device A.
[DeviceA] display interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 current state: DOWN (Loop detection down)
The output shows that GigabitEthernet 1/0/1 is already shut down by the loop detection module.
# Display the status of GigabitEthernet 1/0/2 on devices, for example, Device A.
[DeviceA] display interface gigabitethernet 1/0/2
GigabitEthernet1/0/2 current state: DOWN (Loop detection down)
The output shows that GigabitEthernet 1/0/2 is already shut down by the loop detection module.
Example: Configuring loop detection for protected VLANs
As shown in Figure 4, configure loop detection on Device A to meet the following requirements:
·     Device A automatically blocks a protected VLAN on an interface if a loop is detected in the VLAN on the interface.
Figure 4 Network diagram
# Create VLAN 100, configure it as a protected VLAN, and then globally enable loop detection for the VLAN.
[DeviceA] vlan 100
[DeviceA–vlan100] quit
[DeviceA] loopback-detection protected-vlan 100
# Enable VLAN-block mode on GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2.
[DeviceA-GigabitEthernet1/0/1] undo stp enable
[DeviceA-GigabitEthernet1/0/1] loopback-detection action vlan-block
# Create VLAN 100.
[DeviceB] vlan 100
[DeviceB] interface GigabitEthernet 1/0/1
# Create VLAN 100.
[DeviceC] vlan 100
[DeviceC] interface GigabitEthernet 1/0/1
# View the system logs on Device A.
[DeviceA]
The output shows that Device A detected loops in VLAN 100 on GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 within a loop detection interval.
# Use the display loopback-detection command to display the loop detection configuration and status on Device A.
  GigabitEthernet1/0/1           VLAN-block      100
  GigabitEthernet1/0/2           VLAN-block      100
The output shows that the device has taken the VLAN-block action to remove the loops in VLAN 100 from GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2.
Example: Configuring loop detection on an M-LAG system
As shown in Figure 5, configure loop detection on the M-LAG system formed by Device A and Device B to meet the following requirements:
·     Generates a log as a notification.
·     Automatically shuts down the interface on which a loop is detected.
Figure 5 Network diagram
# Create VLAN 100.
[DeviceA] vlan 100
# Configure M-LAG system settings.
[DeviceA] m-lag system-mac 1-1-1
[DeviceA] m-lag system-number 1
[DeviceA] m-lag system-priority 123
# Configure M-LAG keepalive packet parameters.
[DeviceA] m-lag keepalive ip destination 1.1.1.1 source 1.1.1.2
# Set the link mode of GigabitEthernet 1/0/6 to Layer 3, and assign the interface an IP address. The IP address will be used as the source IP address of keepalive packets.
[DeviceA] interface gigabitethernet 1/0/6
[DeviceA-GigabitEthernet1/0/6] port link-mode route
[DeviceA-GigabitEthernet1/0/6] ip address 1.1.1.2 24
[DeviceA-GigabitEthernet1/0/6] quit
# Exclude the interface used for M-LAG keepalive detection (GigabitEthernet 1/0/6) from the shutdown action by M-LAG MAD.
[DeviceA] drni m-lag exclude interface gigabitethernet 1/0/6
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 3, and specify it as the M-LAG peer-link interface.
[DeviceA] interface bridge-aggregation 3
[DeviceA-Bridge-Aggregation3] link-aggregation mode dynamic
[DeviceA-Bridge-Aggregation3] port m-lag peer-link 1
[DeviceA-Bridge-Aggregation3] quit
# Assign GigabitEthernet 1/0/5 to aggregation group 3.
[DeviceA] interface gigabitethernet 1/0/5
[DeviceA-GigabitEthernet1/0/5] port link-aggregation group 3
[DeviceA-GigabitEthernet1/0/5] quit
# Set the link type of Bridge-Aggregation 3 to trunk, and assign it to VLAN 100.
[DeviceA-Bridge-Aggregation3] port link-type trunk
[DeviceA-Bridge-Aggregation3] port trunk permit vlan 100
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 4, and assign it to M-LAG group 4.
[DeviceA] interface bridge-aggregation 4
[DeviceA-Bridge-Aggregation4] link-aggregation mode dynamic
[DeviceA-Bridge-Aggregation4] port m-lag group 4
[DeviceA-Bridge-Aggregation4] quit
# Assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to aggregation group 4.
[DeviceA-GigabitEthernet1/0/1] port link-aggregation group 4
[DeviceA-GigabitEthernet1/0/2] port link-aggregation group 4
# Set the link type of Bridge-Aggregation 4 to trunk, and assign it to VLAN 100.
[DeviceA-Bridge-Aggregation4] port link-type trunk
[DeviceA-Bridge-Aggregation4] port trunk permit vlan 100
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 5, and assign it to M-LAG group 5.
[DeviceA] interface bridge-aggregation 5
[DeviceA-Bridge-Aggregation5] link-aggregation mode dynamic
[DeviceA-Bridge-Aggregation5] port m-lag group 5
[DeviceA-Bridge-Aggregation5] quit
# Assign GigabitEthernet 1/0/3 and GigabitEthernet 1/0/4 to aggregation group 5.
[DeviceA-GigabitEthernet1/0/3] port link-aggregation group 5
[DeviceA] interface gigabitethernet 1/0/4
[DeviceA-GigabitEthernet1/0/4] port link-aggregation group 5
[DeviceA-GigabitEthernet1/0/4] quit
# Set the link type of Bridge-Aggregation 5 to trunk, and assign it to VLAN 100.
[DeviceA-Bridge-Aggregation5] port link-type trunk
[DeviceA-Bridge-Aggregation5] port trunk permit vlan 100
# Disable the spanning tree feature.
[DeviceA] undo stp global enable
# Enable loop detection for VLAN 100 globally, set the global loop protection action to shutdown, and set the loop detection interval to 35 seconds.
2.     Configure Device B in the same way Device A is configured. Set the M-LAG system number to 2, and set the source and destination IP addresses of keepalive packets to 1.1.1.1 and 1.1.1.2, respectively. (Details not shown.)
[DeviceC] undo stp global enable
# Create VLAN 100.
[DeviceC] vlan 100
[DeviceC-vlan100] quit
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 4.
[DeviceC] interface bridge-aggregation 4
[DeviceC-Bridge-Aggregation4] link-aggregation mode dynamic
[DeviceC-Bridge-Aggregation4] quit
# Assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/4 to aggregation group 4.
[DeviceC] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/4
[DeviceC-if-range] port link-aggregation group 4
[DeviceC-if-range] quit
[DeviceC-Bridge-Aggregation4] port link-type trunk
[DeviceC-Bridge-Aggregation4] port trunk permit vlan 100
# Set the link type of GigabitEthernet 1/0/5 to trunk, and assign it to VLAN 100.
[DeviceC] interface gigabitethernet 1/0/5
[DeviceC-GigabitEthernet1/0/5] port link-type trunk
[DeviceC-GigabitEthernet1/0/5] port trunk permit vlan 100
[DeviceC-GigabitEthernet1/0/5] quit
4.     Configure Device D:
<DeviceD> system-view
[DeviceD] undo stp global enable
# Create VLAN 100.
[DeviceD] vlan 100
[DeviceD-vlan100] quit
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 5.
[DeviceD] interface bridge-aggregation 5
[DeviceD-Bridge-Aggregation5] link-aggregation mode dynamic
[DeviceD-Bridge-Aggregation5] quit
# Assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/4 to aggregation group 5.
[DeviceD] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/4
[DeviceD-if-range] port link-aggregation group 5
[DeviceD-if-range] quit
[DeviceD-Bridge-Aggregation5] port link-type trunk
[DeviceD-Bridge-Aggregation5] port trunk permit vlan 100
[DeviceD] interface gigabitethernet 1/0/5
[DeviceD-GigabitEthernet1/0/5] port link-type trunk
[DeviceD-GigabitEthernet1/0/5] port trunk permit vlan 100
[DeviceD-GigabitEthernet1/0/5] quit
5.     Configure Device E:
<DeviceE> system-view
[DeviceE] undo stp global enable
# Create VLAN 100.
[DeviceE] vlan 100
[DeviceE-vlan100] quit
# Set the link type of GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to trunk, and assign them to VLAN 100.
[DeviceE] interface gigabitethernet 1/0/1
[DeviceE-GigabitEthernet1/0/1] port link-type trunk
[DeviceE-GigabitEthernet1/0/1] port trunk permit vlan 100
[DeviceE-GigabitEthernet1/0/1] quit
[DeviceE] interface gigabitethernet 1/0/2
[DeviceE-GigabitEthernet1/0/2] port link-type trunk
[DeviceE-GigabitEthernet1/0/2] port trunk permit vlan 100
[DeviceE-GigabitEthernet1/0/2] quit
[DeviceA]
%Aug  1 03:28:48:110 2019 DeviceA LPDT/4/LPDT_LOOPED: A loop was detected on
 Bridge-Aggregation4.
%Aug  1 03:28:48:191 2019 DeviceA LPDT/4/LPDT_VLAN_LOOPED: A loop was detect
ed on Bridge-Aggregation4 in VLAN 100.
%Aug  1 03:28:48:194 2019 DeviceA LPDT/4/LPDT_LOOPED: A loop was detected on
 Bridge-Aggregation5.
%Aug  1 03:28:48:288 2019 DeviceA LPDT/4/LPDT_VLAN_LOOPED: A loop was detect
ed on Bridge-Aggregation5 in VLAN 100.
%Aug  1 03:28:48:290 2019 DeviceA LPDT/5/LPDT_VLAN_RECOVERED: A loop was rem
oved on Bridge-Aggregation4 in VLAN 100.
%Aug  1 03:28:48:291 2019 DeviceA LPDT/5/LPDT_RECOVERED: All loops were remo
ved on Bridge-Aggregation4.
%Aug  1 03:28:48:302 2019 DeviceA LPDT/5/LPDT_VLAN_RECOVERED: A loop was rem
oved on Bridge-Aggregation5 in VLAN 100.
%Aug  1 03:28:48:304 2019 DeviceA LPDT/5/LPDT_RECOVERED: All loops were remo
ved on Bridge-Aggregation5.
·     Device A detected loops on Bridge-Aggregation 4 and Bridge-Aggregation 5 within a loop detection interval.
·     Loops on Bridge-Aggregation 4 and Bridge-Aggregation 5 were removed.
  Bridge-Aggregation4             Shutdown        100
  Bridge-Aggregation5             Shutdown        100
The output shows that the device has removed the loops from Bridge-Aggregation 4 and Bridge-Aggregation 5 according to the shutdown action.
# Verify that Bridge-Aggregation 4 has been shut down by loop detection.
[DeviceA] display interface Bridge-Aggregation 4
Bridge-Aggregation4
The interface has assigned a M-LAG group.
Current state: DOWN (Loopback detection down)
# Verify that Bridge-Aggregation 5 has been shut down by loop detection.
[DeviceA] display interface Bridge-Aggregation 5
Bridge-Aggregation5
# Verify that loops have been removed on Device B. (Details not shown.)
