04-Layer 3—IP Services Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S5135S-EI & S5136S-EI Switch Series Configuration Guide-R68xx-6W10104-Layer 3—IP Services Configuration Guide
13-IPv6 fast forwarding configuration
13-IPv6 fast forwarding configuration 59.00 KB
Configuring IPv6 fast forwarding
About IPv6 fast forwarding
Fast forwarding reduces route lookup time and improves packet forwarding efficiency by using a high-speed cache and data-flow-based technology. It identifies a data flow by using the following fields:
·     Source IPv6 address.
·     Destination IPv6 address.
·     Source port number.
·     Destination port number.
·     Protocol number.
After a flow's first packet is forwarded through the routing table, fast forwarding creates an entry and uses the entry to forward subsequent packets of the flow.
Configuring the aging time for IPv6 software fast forwarding entries
The IPv6 fast forwarding table uses an aging timer for each forwarding entry. If an entry is not updated before the timer expires, the device deletes the entry. If an entry has a hit within the aging time, the aging timer restarts.
2.     Set the aging time for IPv6 fast forwarding entries on the software side.
ipv6 fast-forwarding aging-time aging-time
By default, the aging time is 30 seconds for IPv6 fast forwarding entries on the software side.
Configuring IPv6 fast forwarding load sharing for software
IPv6 software fast forwarding load sharing enables the device to identify a data flow by using the packet information.
If IPv6 fast forwarding load sharing is disabled on the software side, the device identifies a data flow by the packet information and the input interface.
2.     Configure IPv6 fast forwarding load sharing on the software side. Choose one option as needed:
¡     Enable IPv6 fast forwarding load sharing on the software side.
Ipv6 fast-forwarding load-sharing
¡     Disable IPv6 fast forwarding load sharing on the software side.
undo ipv6 fast-forwarding load-sharing
By default, IPv6 fast forwarding load sharing is enabled on the software side.
Display and maintenance commands for IPv6 fast forwarding
Display the aging time of the IPv6 fast forwarding entries.
display ipv6 fast-forwarding aging-time
Display IPv6 fast forwarding entries.
display ipv6 fast-forwarding cache [ ipv6-address ] [ slot slot-number ]
Clear the IPv6 fast forwarding table.
reset ipv6 fast-forwarding cache [ slot slot-number ]
