11-High Availability Configuration Guide
HomeSupportSwitchesS6520XP-EI-G SeriesTechnical DocumentsConfigure & DeployConfiguration GuidesH3C S6520XP-EI-G Switch Series Configuration Guides--R7756Pxx-6W10011-High Availability Configuration Guide
10-BFD configuration
10-BFD configuration 340.27 KB
Configuring BFD·· 1
About BFD·· 1
Mechanism·· 1
Single-hop detection and multihop detection· 2
BFD session modes· 2
Hardware BFD·· 3
Supported features· 3
Protocols and standards· 3
Restrictions and guidelines: BFD configuration· 4
BFD tasks at a glance· 4
Configuring BFD sessions in echo packet mode(software BFD) 5
About BFD session creation methods· 5
Restrictions and guidelines· 5
Creating a static BFD session· 5
Configuring detection time settings· 7
Configuring BFD sessions in control packet mode(software BFD) 8
About BFD session creation methods· 8
Restrictions and guidelines· 9
Configuring the session establishment mode· 9
Configuring the detection mode· 9
Creating a static BFD session· 10
Configuring detection time settings· 11
Configuring the authentication mode· 14
Configuring the destination port number for multihop BFD control packets· 15
Configuring the notification delay timer for session establishment failures· 15
Enabling the echo function· 16
Configuring the TTL value for BFD packets· 16
Configuring BFD sessions in control packet mode (hardware BFD) 17
About BFD session creation methods· 17
Restrictions and guidelines· 18
Creating a static BFD session· 18
Configuring parameters for single-hop BFD sessions· 20
Configuring parameters for multihop BFD sessions· 21
Configuring BFD session flapping suppression· 21
Configuring a BFD template· 22
Enabling SNMP notifications for BFD·· 23
Display and maintenance commands for BFD·· 23
Configuring BFD
About BFD
Bidirectional forwarding detection (BFD) provides a general-purpose, standard, medium- and protocol-independent fast failure detection mechanism. It can detect and monitor the connectivity of forwarding paths to detect communication failures quickly so that measures can be taken to ensure service continuity and enhance network availability.
BFD can uniformly and quickly detect the failures of the bidirectional forwarding paths between two devices for upper-layer protocols such as routing protocols. The hello mechanism used by upper-layer protocols needs seconds to detect a link failure, while BFD can provide detection measured in milliseconds.
Mechanism
BFD establishes a session between two network devices to detect failures on the bidirectional forwarding paths between the devices and provide services for upper-layer protocols. BFD provides no neighbor discovery mechanism. Protocols that BFD services notify BFD of devices to which it needs to establish sessions. After a session is established, if no BFD control packet is received from the peer within the negotiated BFD interval, BFD notifies a failure to the protocol, which then takes appropriate measures.
Figure 1 describes the operation of BFD for OSPF.
1.     OSPF discovers neighbors by sending Hello packets and establishes neighbor relationships.
2.     After establishing neighbor relationships, OSPF notifies BFD of the neighbor information, including destination and source addresses.
3.     BFD uses the information to establish BFD sessions.
Figure 1 BFD session establishment
Figure 2 describes the BFD fault detection process.
1.     BFD detects a link failure and tears down the session.
2.     BFD notifies the neighbor unreachability to OSPF.
3.     OSPF terminates the neighbor relationship on the link.
Figure 2 BFD fault detection
BFD establishes sessions in echo packet mode or control packet mode depending on the BFD packets used.
BFD can be used for single-hop and multihop detections.
·     Single-hop detection—Detects the IP connectivity between two directly connected systems, for example, Device A and Device B as shown in Figure 3.
Figure 3 Single-hop detection
·     Multihop detection—Detects any of the paths between two systems, for example, Device A and Device B as shown in Figure 4. These paths have multiple hops, and might overlap.
Figure 4 Multihop detection
BFD session modes
BFD sessions use control packets.
Control packets are encapsulated into UDP packets with port number 3784 for single-hop detection or port number 4784 for multihop detection.
The two ends of the link negotiate the establishment of BFD sessions by using the session parameters carried in control packets. Session parameters include session discriminators, desired minimum packet sending and receiving intervals, and local BFD session state.
Hardware BFD
Software BFD uses the CPU to receive and send BFD packets and to maintain the BFD state machine. Software BFD greatly consumes CPU resources and cannot support a large number of BFD sessions.
Hardware BFD uses hardware chips to process CPU-intensive tasks, such as receiving and sending BFD packets and fault detection. Hardware BFD improves CPU utilization and can support a large number of BFD sessions.
The Hardware mode field in the output from the display bfd session verbose command indicates whether BFD packets are processed in hardware:
·     Enabled—BFD packets are processed in hardware.
·     Disabled—BFD packets are processed in software.
You can take the following actions to disable hardware BFD:
·     Execute commands that are not supported by hardware BFD.
·     Remove cards that support hardware BFD.
When you disable hardware BFD, the BFD session might flap. Before performing this operation, make sure you understand its potential impact on the network.
Supported features
Table 1 shows the features supported by BFD.
Table 1 Features supported by BFD
Feature
Reference
Link aggregation
Ethernet link aggregation in Layer 2—LAN Switching Configuration Guide
IPv4 static routing
Static routing in Layer 3IP Routing Configuration Guide
IPv6 static routing
IPv6 static routing in Layer 3IP Routing Configuration Guide
RIP
RIP in Layer 3IP Routing Configuration Guide
OSPF
OSPF in Layer 3IP Routing Configuration Guide
OSPFv3
OSPFv3 in Layer 3IP Routing Configuration Guide
IS-IS
IS-IS in Layer 3IP Routing Configuration Guide
BGP
BGP in Layer 3IP Routing Configuration Guide
PIM
PIM in IP Multicast Configuration Guide
IPv6 PIM
IPv6 PIM in IP Multicast Configuration Guide
Track
"Configuring Track"
·     RFC 5880, Bidirectional Forwarding Detection (BFD)
·     RFC 5881, Bidirectional Forwarding Detection (BFD) for IPv4 and IPv6 (Single Hop)
·     RFC 5882, Generic Application of Bidirectional Forwarding Detection (BFD)
·     RFC 5883, Bidirectional Forwarding Detection (BFD) for Multihop Paths
·     RFC 7130, Bidirectional Forwarding Detection (BFD) on Link Aggregation Group (LAG) Interfaces
·     As a best practice to avoid BFD session flapping due to CPU scheduling and ensure network stability when using software BFD, follow these guidelines:
¡     Configure the minimum interval for receiving BFD packets greater than 100 milliseconds.
¡     Configure the minimum interval for sending BFD packets greater than 100 milliseconds.
¡     Configure the BFD detection time multiplier greater than 3.
·     A management Ethernet interface supports only the BFD MAD feature. You cannot configure other BFD-associated features for the interface. For more information about BFD MAD, see IRF configuration in Virtual Technologies Configuration Guide.
·     If the BFD session detection time setting is smaller than the IRF link down report delay setting in an IRF environment, BFD session flapping might occur. As a best practice to avoid this situation, edit the IRF link down report delay setting. Make sure the IRF link down report delay setting is smaller than the BFD session detection time setting. For more information about the IRF link down report delay feature, see IRF configuration in Virtual Technologies Configuration Guide.
·     By default, the device runs BFD version 1 and is compatible with BFD version 0. You cannot change the BFD version to 0 through commands. When the peer device runs BFD version 0, the local device automatically switches to BFD version 0.
·     After a BFD session is established, the two ends negotiate BFD parameters, including minimum sending interval, minimum receiving interval, initialization mode, and packet authentication, by exchanging negotiation packets. They use the negotiated parameters without affecting the session status.
·     As a best practice, use control-packet-mode BFD session on a downstream device to detect connectivity with an M-LAG device. Echo-packet-mode BFD sessions might fail to detect link failures.
·     BFD session flapping might occur on an aggregate interface with member ports on different IRF member devices. When the master device, which receives and sends BFD packets, is removed or restarted, a subordinate device might not immediately take over. For example, a subordinate device will not take over when the subordinate device has a short detection time or a large number of BFD sessions.
·     When the device interoperates with a device from another vendor, follow these restrictions and guidelines:
¡     As a best practice to avoid BFD session establishment failures, make sure the detection time multiplier is not greater than 15.
¡     If the BFD negotiation packet parameter (such as minimum transmission interval or minimum receiving interval) for the device from another vendor is greater than 1023 milliseconds, you can configure only software BFD, and cannot configure hardware BFD.
All the BFD tasks are optional.
1.     Configuring BFD sessions in echo packet mode(software BFD)
¡     Creating a static BFD session
¡     Configuring detection time settings
2.     Configuring BFD sessions in control packet mode(software BFD)
¡     Configuring the session establishment mode
¡     Configuring the authentication mode
¡     Configuring the destination port number for multihop BFD control packets
¡     Configuring the notification delay timer for session establishment failures
¡     Enabling the echo function
¡     Configuring the TTL value for BFD packets
3.     Configuring BFD sessions in control packet mode (hardware BFD)
¡     Configuring parameters for single-hop BFD sessions
¡     Configuring parameters for multihop BFD sessions
4.     Configuring BFD session flapping suppression
5.     Configuring a BFD template
6.     Enabling SNMP notifications for BFD
A BFD session can be created manually by using the bfd static command or created dynamically through collaboration between an application module and BFD.
To avoid echo packet loss, do not configure the echo packet mode on a device with uRPF enabled. For more information about uRPF, see Security Configuration Guide.
A static BFD session in echo packet mode can be used to perform single-hop detection or multihop detection.
You need to create a static BFD session in echo packet mode on only the local device to perform detection.
When creating a static BFD session, you must specify a peer IPv4 or IPv6 address. The system checks only the format of the IP address but not its correctness. If the peer IPv4 or IPv6 address is incorrect, the static BFD session cannot be established.
Different static BFD sessions cannot have the same local discriminator.
As a best practice, specify the source IP address for echo packets when creating a static BFD session. If you do not specify the source IP address, the device uses the IP address specified in the bfd echo-source-ip or bfd echo-source-ipv6 command as the source IP address of echo packets.
Creating a static BFD session for single-hop detection
2.     Configure the source IP address of echo packets.
¡     Configure the source IP address of echo packets.
bfd echo-source-ip ip-address
By default, no source IPv4 address is configured for echo packets.
As a best practice, do not configure the source IPv4 address to be on the same network segment as any local interfaces. This can avoid network congestion caused a large number of ICMP redirect packets sent from the peer.
¡     Configure the source IPv6 address of echo packets.
By default, no source IPv6 address is configured for echo packets.
The source IPv6 address of echo packets can only be a global unicast address.
3.     Create a static BFD session and enter static BFD session view.
IPv4:
bfd static session-name [ peer-ip ipv4-address interface interface-type interface-number destination-ip ipv4-address [ source-ip ipv4-address ] one-arm-echo [ discriminator { auto | local local-value } ] ]
IPv6:
bfd static session-name [ peer-ipv6 ipv6-address interface interface-type interface-number destination-ipv6 ipv6-address [ source-ipv6 ipv6-address ] one-arm-echo [ discriminator { auto | local local-value } ] ]
4.     (Optional.) Specify a local discriminator for the static BFD session.
discriminator local local-value
By default, no local discriminator is specified.
You can use this command only if you do not specify a local discriminator when creating a static BFD session.
Creating a static BFD session for multihop detection
2.     (Optional.) Configure the source IP address of echo packets.
¡     Configure the source IPv4 address of echo packets.
As a best practice, do not configure the source IPv4 address to be on the same network segment as any local interfaces. If you configure such a source IPv4 address, a large number of ICMP redirect packets might be sent from the peer, resulting in link congestion.
IPv4:
bfd static session-name [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] destination-ip ipv4-address [ source-ip ipv4-address ] one-arm-echo[ discriminator { auto | local local-value } ] ]
IPv6:
bfd static session-name [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] destination-ipv6 ipv6-address [ source-ipv6 ipv6-address ] one-arm-echo [ discriminator { auto | local local-value } ] ]
When creating a BFD session in echo packet mode, you can configure the minimum interval for receiving BFD echo packets and the detection time multiplier for the device.
When the same BFD session (with the same source IP address, destination IP address, interface, VPN, and destination port number) is associated with multiple upper layer applications, BFD selects the detection time settings for the BFD session as follows:
1.     Minimum values of the following settings:
¡     Settings configured in static BFD session view.
¡     Settings configured in the BFD template specified by the upper layer application.
¡     Settings configured by the upper layer application.
2.     Settings configured in interface view or system view.
3.     Default settings.
When a BFD session is associated with only one upper layer application, BFD selects the detection time settings for the BFD session as follows:
1.     BFD selects the detection time settings for the BFD session based on whether the upper layer application supports using a BFD template and configuring detection time settings:
¡     If a BFD template is specified and detection time settings are also configured for the upper layer application, BFD selects the settings configured in the specified BFD template.
¡     If a BFD template is specified for the upper layer application that does not support configuring detection time settings, BFD selects the settings configured in the specified BFD template.
¡     If detection time settings are configured for the upper layer application that does not support using a BFD template, BFD selects the configured settings.
Configure detection time settings for single-hop BFD detection
2.     Enter interface view or static BFD session view.
¡     Enter interface view.
¡     Enter static BFD session view.
The static BFD session must already exist.
To configure parameters for a static BFD session, you must enter its view.
3.     Set the minimum interval for receiving BFD echo packets.
The default setting is 400 milliseconds.
4.     Set the detection time multiplier.
bfd detect-multiplier value
The default setting is 5.
Configure detection time settings for multihop BFD detection
2.     (Optional.) Enter static BFD session view.
bfd multi-hop min-echo-receive-interval interval
BFD sessions in control packet mode can be created statically or established dynamically.
BFD sessions are distinguished by the local discriminator and remote discriminator in control packets. The main difference between a statically created session and a dynamically established session is that they obtain the local discriminator and remote discriminator in different ways.
·     The local discriminator and remote discriminator of a static BFD session are specified manually in the bfd static command or in the commands that associate specific applications with BFD.
·     The local discriminator of a dynamic BFD session is assigned by the device, and the remote discriminator is obtained during BFD session negotiation. The device can automatically assign the local discriminator to the BFD session in the following conditions:
¡     The auto keyword is specified for the bfd static command.
¡     The local and remote discriminators are not specified for the BFD session associated with a specific application.
After an upper-layer protocol is configured to support BFD, the device automatically creates BFD sessions in control packet mode. You do not need to perform this task.
BFD version 0 does not support the following commands:
·     bfd session init-mode.
·     bfd authentication-mode.
·     bfd demand enable.
·     bfd echo enable.
BFD can use the following operating modes to establish a session:
·     Active mode—BFD actively sends BFD control packets regardless of whether any BFD control packet is received from the peer.
·     Passive mode—BFD does not send control packets until a BFD control packet is received from the peer.
At least one end must operate in active mode for a BFD session to be established.
2.     Configure the BFD session establishment mode.
By default, BFD uses the active mode to establish a session.
After a BFD session is established, the two ends can operate in the following modes:
·     Asynchronous mode—The device periodically sends BFD control packets. The device considers that the session is down if it does not receive any BFD control packets within the detection interval.
·     Demand mode—The Demand mode can be used to reduce the overhead when a large number of BFD sessions exist.
¡     If the peer end is operating in Asynchronous mode (default), the peer end stops sending BFD control packets after receiving control packets with the D bit set. In this scenario, BFD detects only the link between the local end and the peer end. The device considers that the session is down if it does not receive any BFD control packets within the detection interval.
¡     If the peer end is operating in Demand mode, both ends stop sending BFD control packets. In this scenario, the system uses features other than BFD, such as Hello packets and hardware CC, to verify the connectivity to another system.
The bfd demand enable command cannot take effect when any of the following conditions exist:
·     Echo-packet-mode BFD sessions exist on the device.
·     SBFD sessions exist on the device.
·     BFD sessions for detecting aggregate links exist on the device.
·     After the bfd detect-interface source-ip command is configured, the bfd detect-interface first-fail-timer and bfd detect-interface special-processing commands are configured.
Do not execute the bfd detect-interface first-fail-timer or bfd detect-interface special-processing command in Demand mode. If you do so, the Demand mode might not take effect on the interface whose state is associated with BFD.
2.     Enter interface view.
3.     Specify the Demand mode for the BFD session.
bfd demand enable
By default, a BFD session is in Asynchronous mode.
A static BFD session can be used for single-hop detection and multihop detection. By working with Track, a static BFD session can provide fast failure detection. For more information about Track association with BFD, see "Configuring Track."
Restrictions and guidelines for static BFD session configuration
If a static BFD session is created on the remote end, the static BFD session must be created on the local end.
2.     Create a static BFD session and enter static BFD session view.
IPv4:
bfd static session-name peer-ip ipv4-address interface interface-type interface-number source-ip ipv4-address [ discriminator { auto | local local-value remote remote-value } ]
For a static BFD session to be established, specify the IPv4 address of the peer interface where the static BFD session resides for the peer-ip ipv4-address option. Specify the IPv4 address of the local interface where the static BFD session resides for the source-ip ipv4-address option.
IPv6:
bfd static session-name peer-ipv6 ipv6-address interface interface-type interface-number source-ipv6 ipv6-address [ discriminator { auto | local local-value remote remote-value } ]
For a static BFD session to be established, specify the IPv6 address of the peer interface where the static BFD session resides for the peer-ipv6 ipv6-address option. Specify the IPv6 address of the local interface where the static BFD session resides for the source-ipv6 ipv6-address option.
3.     (Optional.) Specify the local and remote discriminators for the static BFD session.
discriminator { local local-value | remote remote-value }
By default, no local discriminator or remote discriminator is specified for a static BFD session.
Use this command only if you do not specify the local or remote discriminator when creating a static BFD session.
Create a static BFD session for multihop detection
IPv4:
bfd static session-name peer-ip ipv4-address [ vpn-instance vpn-instance-name ] source-ip ipv4-address [ discriminator { auto |local local-value remote remote-value } ] [ track-interface interface-type interface-number ]
IPv6:
bfd static session-name peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] source-ipv6 ipv6-address [ discriminator { auto | local local-value remote remote-value } ] [ track-interface interface-type interface-number ]
When creating a BFD session in control packet mode, you can configure the minimum interval for receiving and transmitting BFD control packets and the detection time multiplier for the device.
You can use the bfd min-receive-interval and bfd min-control-interval commands to set the minimum interval for receiving single-hop BFD control packets.
·     If you execute both the bfd min-receive-interval and bfd min-control-interval commands, the bfd min-receive-interval command takes effect.
·     If you execute neither the bfd min-receive-interval nor bfd min-control-interval command, the default setting of the bfd min-receive-interval command takes effect.
·     If you execute either the bfd min-receive-interval or bfd min-control-interval command, the configured value takes effect.
You can use the bfd min-transmit-interval and bfd min-control-interval commands to set the minimum interval for transmitting single-hop BFD control packets.
·     If you execute both the bfd min-transmit-interval and bfd min-control-interval commands, the bfd min-transmit-interval command takes effect.
·     If you execute neither the bfd min-transmit-interval nor bfd min-control-interval command, the default setting of the bfd min-transmit-interval command takes effect.
·     If you execute either the bfd min-transmit-interval or bfd min-control-interval command, the configured value takes effect.
You can use the bfd multi-hop min-receive-interval and bfd multi-hop min-control-interval commands to set the minimum interval for receiving multihop BFD control packets.
·     If you execute both the bfd multi-hop min-receive-interval and bfd multi-hop min-control-interval commands, the bfd multi-hop min-receive-interval command takes effect.
·     If you execute neither the bfd multi-hop min-receive-interval nor bfd multi-hop min-control-interval command, the default setting of the bfd multi-hop min-receive-interval command takes effect.
·     If you execute either the bfd multi-hop min-receive-interval or bfd multi-hop min-control-interval command, the configured value takes effect.
You can use the bfd multi-hop min-transmit-interval and bfd multi-hop min-control-interval commands to set the minimum interval for transmitting multihop BFD control packets.
·     If you execute both the bfd multi-hop min-transmit-interval and bfd multi-hop min-control-interval commands, the bfd multi-hop min-transmit-interval command takes effect.
·     If you execute neither the bfd multi-hop min-transmit-interval nor bfd multi-hop min-control-interval command, the default setting of the bfd multi-hop min-transmit-interval command takes effect.
·     If you execute either the bfd multi-hop min-transmit-interval or bfd multi-hop min-control-interval command, the configured value takes effect.
3.     Set the minimum interval for receiving echo packets.
4.     Set the minimum interval for transmitting and receiving single-hop BFD control packets.
¡     Set the minimum interval for transmitting single-hop BFD control packets.
¡     Set the minimum interval for receiving single-hop BFD control packets.
5.     Set the minimum interval for transmitting and receiving single-hop BFD control packets.
bfd min-control-interval interval
6.     Set the single-hop detection time multiplier.
3.     Set the multihop detection time multiplier.
4.     Set the minimum interval for transmitting and receiving multihop BFD control packets.
¡     Set the minimum interval for transmitting multihop BFD control packets.
¡     Set the minimum interval for receiving multihop BFD control packets.
5.     Set the minimum interval for transmitting and receiving multihop BFD control packets.
bfd multi-hop min-control-interval interval
You can configure authentication settings, including algorithm and key, to enhance BFD session security.
Configure the authentication mode for a single-hop BFD session
3.     Configure the authentication mode for single-hop control packets.
bfd authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher cipher-string | plain plain-string }
By default, no authentication mode is configured for single-hop control packets.
Configure the authentication mode for a multihop BFD session
3.     Configure the authentication mode for multihop BFD control packets.
bfd multi-hop authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher cipher-string | plain plain-string }
By default, no authentication mode is configured for multihop BFD control packets.
IANA assigned port number 4784 to BFD for multihop BFD detection in control packet mode. By default, H3C devices use 4784 as the destination port number for multihop BFD control packets, while devices from other vendors might use 3784. To avoid BFD session establishment failures, make sure the devices on both ends of the BFD session use the same destination port number for multihop BFD control packets.
This command applies to only new multihop BFD sessions in control packet mode.
2.     Configure the destination port number for multihop BFD control packets.
The default setting is 4784.
By default, BFD does not notify upper-layer protocols of session establishment failures. The notification is required in some scenarios. For example, upon a session establishment failure in an aggregate link, the aggregate link can place the associated member port in Unselected state based on the failure notification. You can configure the delay timer for BFD to notify upper-layer protocols of session establishment failures.
This feature does not apply to BFD sessions in echo packet mode.
2.     Set the delay timer for BFD to notify upper-layer protocols of session establishment failures.
bfd init-fail-timer seconds
CAUTION
CAUTION:
For session establishment failures caused by configuration mismatches at the two ends, this command can cause the upper-layer protocol to act incorrectly. Therefore, use this command with caution. BFD status mismatch and BFD authentication configuration mismatch are examples of configuration mismatches.
When you use Asynchronous mode BFD to detect the connectivity between directly connected devices, you can enable the echo function. This function enables the local system to periodically send echo packets to the remote system and reduces the control packet receiving rate to save bandwidth usage. The remote system loops back the echo packets to the local system without processing them. If the local system does not receive echo packets looped back from the remote system in a consecutive number of times, the local system declares the BFD session down.
This function is supported only for single-hop detection.
This function does not take effect on BFD sessions associated with interface states.
3.     Enable the echo function.
By default, the echo function is disabled.
When you connect an H3C device to a third-party device, for successful BFD session negotiation, make sure the TTL value settings for BFD packets on both ends of the BFD session are the same. When the device receives a BFD packet in DOWN or INIT state from its peer, it verifies the TTL value of the packet and performs one of the following actions:
·     For a single-hop BFD session, if the device receives a packet that carries a TTL value that is different from the TTL value specified with the bfd ttl command, the device drops the packet.
·     For a multihop BFD session, if the device receives a packet that carries a TTL value that is greater than the TTL value specified with the bfd ttl command, the device drops the packet.
·     If the BFD session is already up, the device sets the BFD session state to AdminDown, which triggers a BFD session renegotiation.
·     The bfd ttl command does not take effect on BFD sessions in echo packet mode.
·     For an IPv4 or IPv6 addresswith different mask lengths or prefix lengths, the device uses the TTL value specified with the longest mask or prefix length.
·     For an IPv4 or IPv6 subnet, the TTL value of single-hop BFD packets must be greater than the TTL value of multihop BFD packets.
2.     Specify the TTL value for BFD packets.
bfd { peer-ip ipv4-address mask-length | peer-ipv6 ipv6-address prefix-length } ttl { single-hop | multi-hop } ttl-value
By default, the TTL value of single-hop BFD packets is 255 and the TTL value of multihop BFD packets is 64.
·     If you execute either the bfd min-receive-interval or bfd min-contrsol-interval command, the configured value takes effect.
In an M-LAG network, the device does not support multihop BFD.
Hardware BFD does not support the bfd echo enable command.
IPv4:
IPv6:
IPv4:
IPv6:
bfd detect-multiplier interval
7.     (Optional.) Set the delay timer for BFD to notify upper-layer protocols of session establishment failures.
a.     Return to system view.
b.     Set the delay timer for BFD to notify upper-layer protocols of session establishment failures.
CAUTION
CAUTION:
3.     Configure the destination port number for multihop BFD control packets.
This command is supported only in system view.
4.     Set the multihop detection time multiplier.
6.     Set the minimum interval for transmitting and receiving multihop BFD control packets.
CAUTION
CAUTION:
When BFD detects a link failure, it tears down the BFD session and notifies the upper-layer protocol of the failure. When the upper-layer protocol re-establishes a neighbor relationship, the BFD session comes up again. BFD session flaps occur when a link fails and recovers repeatedly, which consumes significant system resources and causes network instability.
This feature allows you to suppress BFD session flapping by using the initial-interval, secondary-interval, and maximum-interval arguments.
·     A BFD session is suppressed within the specified interval. The suppression time does not exceed the maximum-interval.
·     After a BFD session goes down for the second time, it cannot be re-established within the initial-interval.
·     After a BFD session goes down for the third time, it cannot be re-established within the secondary-interval.
·     After a BFD session goes down for the fourth time and at any later time, the following rules apply:
¡     If secondary-interval × 2n-3 is smaller than or equal to the maximum-interval, the BFD session cannot be re-established within the secondary-interval × 2n-3.
¡     If secondary-interval × 2n-3 is greater than the maximum-interval, the BFD session cannot be re-established within the maximum-interval.
The letter n, starting from 4, is the number of times the BFD session flaps.
2.     Configure BFD session flapping suppression.
bfd dampening [ maximum maximum-interval initial initial-interval secondary secondary-interval ]
By default, BFD sessions are not suppressed.
The values for the initial-interval and secondary-interval arguments cannot be greater than or equal to the value for the maximum-interval argument.
Perform this task to specify BFD parameters in a template for sessions without next hops.
2.     Create a BFD template and enter BFD template view.
bfd template template-name
3.     (Optional.) Configure the authentication mode for BFD control packets.
By default, no authentication is performed.
5.     Set the minimum interval for transmitting and receiving BFD control packets.
¡     Set the minimum interval for transmitting BFD control packets.
¡     Set the minimum interval for receiving BFD control packets.
6.     Set the minimum interval for transmitting and receiving BFD control packets.
To report critical BFD events to an NMS, enable SNMP notifications for BFD. For BFD event notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
2.     Enable SNMP notifications for BFD.
snmp-agent trap enable bfd
By default, SNMP notifications are enabled for BFD.
Execute the display command in any view and the reset command in user view.
Display BFD session information.
display bfd session [ discriminator local local-value | static session-name | verbose ]
display bfd session [ [ dynamic ] [ control | echo ] [ ip ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] [ ipv6 ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] [ lsp | te | pw ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] | [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] ] [ verbose ] ]
display bfd session [ [ static ] [ ip ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] [ verbose ]
display bfd session [ [ static ] [ ipv6 ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ]
Display the TTL values for BFD packets.
display bfd ttl
Clear BFD session statistics.
reset bfd session statistics
