05-Layer 3—IP Services Configuration Guide
HomeSupportSwitchesS6520XP-EI-G SeriesTechnical DocumentsConfigure & DeployConfiguration GuidesH3C S6520XP-EI-G Switch Series Configuration Guides--R7756Pxx-6W10005-Layer 3—IP Services Configuration Guide
07-IP forwarding basics configuration
07-IP forwarding basics configuration 74.78 KB
Configuring IP forwarding basic settings························································ 1
About FIB table······························································································································· 1
Saving the IP forwarding entries to a file··························································································· 2
Enabling SNMP notifications for FIB events······················································································ 2
Display and maintenance commands for FIB table············································································ 3
Configuring load sharing··················································································· 4
Configuring load sharing mode········································································································ 4
Enabling local-first load sharing······································································································· 5
Display and maintenance commands for load sharing······································································· 5
About FIB table
A device uses the FIB table to make packet forwarding decisions.
A device selects optimal routes from the routing table, and puts them into the FIB table. Each FIB entry specifies the next hop IP address and output interface for packets destined for a specific subnet or host.
For more information about the routing table, see Layer 3—IP Routing Configuration Guide.
Use the display fib command to display the FIB table. The following example displays the entire FIB table.
<Sysname> display fib
Destination count: 8 FIB entry count: 8
Flag:
  R:Relay     F:FRR
Destination/Mask   Nexthop         Flag     OutInterface/Token       Label
0.0.0.0/32         127.0.0.1       UH       InLoop0                  Null
127.0.0.0/8        127.0.0.1       U        InLoop0                  Null
127.0.0.0/32       127.0.0.1       UH       InLoop0                  Null
127.0.0.1/32       127.0.0.1       UH       InLoop0                  Null
127.255.255.255/32 127.0.0.1       UH       InLoop0                  Null
224.0.0.0/4        0.0.0.0         UB       NULL0                    Null
224.0.0.0/24       0.0.0.0         UB       NULL0                    Null
255.255.255.255/32 127.0.0.1       UH       InLoop0                  Null
A FIB entry includes the following items:
·     Destination—Destination IP address.
·     Mask—Network mask. The mask and the destination address identify the destination network. A logical AND operation between the destination address and the network mask yields the address of the destination network. For example, if the destination address is 192.168.1.40 and the mask 255.255.255.0, the address of the destination network is 192.168.1.0. A network mask includes a certain number of consecutive 1s. It can be expressed in dotted decimal format or by the number of the 1s.
·     Nexthop—IP address of the next hop.
·     Flag—Route flag.
·     OutInterface—Output interface.
·     Token—MPLS Label Switched Path index number.
·     Label—Inner label.
The feature automatically creates the file if you specify a nonexistent file. If the file already exists, this feature overwrites the file content.
This feature triggers one-time saving of the IP forwarding entries.
To automatically save the IP forwarding entries periodically, configure a schedule for the device to automatically run the ip forwarding-table save command. For information about scheduling a task, see Fundamentals Configuration Guide.
To save the IP forwarding entries to a file, execute the following command in any view:
ip forwarding-table save filename filename
This feature enables the FIB module to generate SNMP notifications for critical FIB events, such as the exceeding of the message queue length threshold. The SNMP notifications are sent to the SNMP module.
You can enable specific SNMP notifications for FIB events as needed. If you do not specify any SNMP notification types, the command enables all types of SNMP notifications.
·     With ecmp-limit specified, when the number of ECMP routes learned by a device exceeds the upper limit, the device sends an SNMP notification that carries the module number to the SNMP module.
·     With entry-consistency specified, if the FIB software and hardware entries on a module are inconsistent, the device sends an SNMP notification that carries the module number to the SNMP module.
·     With entry-limit specified, when the number of FIB entries exceeds the upper limit, the device sends an SNMP notification that carries the FIB entry module name to the SNMP module.
·     With deliver-failed specified, when FIB entry deployment to the hardware fails, the device sends an SNMP notification that carries the entry VRF, IP address type, IP address, mask, and failure reason to the SNMP module.
For the SNMP notifications to be sent correctly, you must also configure SNMP. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
2.     Enable SNMP notifications for FIB events.
snmp-agent trap enable fib [ deliver-failed | ecmp-limit | entry-consistency | entry-limit ] *
By default, SNMP notifications for FIB events are enabled.
Display FIB entries.
display fib [ vpn-instance vpn-instance-name ] [ ip-address [ mask | mask-length ] ]
In the per-flow load sharing mode, the device forwards flows over equal-cost routes. Packets of one flow travel along the same routes. You can configure the device to identify a flow based on the following criteria: source IP address, destination IP address, source port number, destination port number, IP protocol number, and ingress port.
In a complex network, when the traffic is not load shared equally, you can use the algorithm keyword to specify an algorithm to improve the load sharing.
In the per-packet load sharing mode, the device forwards packets over equal-cost routes.
For MPLS packets, the device supports only source IP-based per-flow load sharing and destination IP-based per-flow load sharing.
By default, the device performs per-flow load sharing based on the following criteria: source IP address, destination IP address, source port number, destination port number, and IP protocol number. The first fragment and the other fragments of the same packet might be forwarded through different output ports. When the result of packet fragment reassembly is strongly related to the packet forwarding path, packet fragment reassembly might fail. To resolve this issue, re-execute the ip load-sharing mode command without specifying the dest-port and src-port keywords.
2.     Configure load sharing.
ip load-sharing mode per-flow [ algorithm algorithm-number  [ dest-ip | dest-port | ingress-port | ip-pro | src-ip | src-port ] * | tunnel { inner | outer } ] { global | slot slot-number }
By default, the device performs per-flow load sharing based on the following criteria: source IP address, destination IP address, source port number, destination port number, IP protocol number, and ingress port.
3.     Display the load sharing path selected for a flow.
display ip load-sharing path ingress-port interface-type interface-number packet-format { ipv4oe dest-ip ip-address [ src-ip ip-address ] | ipv6oe dest-ipv6 ipv6-address [ src-ipv6 ipv6-address | flow-label flow-label ] } [ dest-port port-id | ip-pro protocol-id | src-port port-id | vpn-instance vpn-instance-name ] *
The option settings in this command must match both the options displayed in the display ip load-sharing mode command and the field values in load shared packets. If the option settings do not meet the requirement, the path displayed by this command might be different from the real path for load sharing.
Local-first load sharing distributes traffic preferentially across the output interfaces on the receiving IRF member device if output interfaces for multiple equal-cost routes are on different members. This feature enhances packets forwarding efficiency.
2.     Enable local-first load sharing.
ip load-sharing local-first enable
By default, local-first load sharing is enabled.
Display the load sharing mode in use.
display ip load-sharing mode slot slot-number
