- 01-AAA configuration
- 02-802.1X configuration
- 04-Portal configuration
- 05-Web authentication configuration
- 06-Triple authentication configuration
- 07-Port security configuration
- 08-User profile configuration
- 10-Keychain configuration
- 11-Public key management
- 12-PKI configuration
- 13-IPsec configuration
- 14-SSH configuration
- 15-SSL configuration
- 16-Object group configuration
- 17-Attack detection and prevention configuration
- 18-TCP attack prevention configuration
- 19-IP source guard configuration
- 20-ARP attack protection configuration
- 21-ND attack defense configuration
- 22-uRPF configuration
- 23-SAVI configuration
- 24-SAVA configuration
- 25-MFF configuration
- 26-Crypto engine configuration
- 27-FIPS configuration
- 28-MACsec configuration
- 29-802.1X client configuration
- 30-Microsegmentation configuration
- 31-IP-SGT mapping configuration
| 16-Object group configuration | 55.00 KB |
Configuring an IPv4 address object group
Configuring an IPv6 address object group
Display and maintenance commands for object groups
Configuring object groups
About object groups
An object group is a group of objects that can be used by an ACL, object policy, or object group to identify packets. Object groups are divided into the following types:
· IPv4 address object group—A group of IPv4 address objects used to match the IPv4 address in a packet or match the user from whom a packet comes.
· IPv6 address object group—A group of IPv6 address objects used to match the IPv6 address in a packet or match the user from whom a packet comes.
1. Enter system view.
2. Configure an IPv4 address object group and enter its view.
object-group ip address object-group-name
The system has one default IPv4 address object group named any.
3. (Optional.) Configure a description for the IPv4 address object group.
By default, an object group does not have a description.
4. Configure an IPv4 address object.
[ object-id ] network { host { address ip-address | name host-name } | subnet ip-address { mask-length | mask } }
2. Configure an IPv6 address object group and enter its view.
object-group ipv6 address object-group-name
The system has one default IPv6 address object group named any.
3. (Optional.) Configure a description for the IPv6 address object group.
4. Configure an IPv6 address object.
[ object-id ] network { host { address ipv6-address | name host-name } | subnet ipv6-address prefix-length }
Task |
Command |
Display information about object groups. |
display object-group [ { { ip | ipv6 } address } [ default ] [ name object-group-name ] | name object-group-name ] |
Display IPv4 or IPv6 addresses for host names. |
display object-group { ip | ipv6 } host { object-group-name object-group-name | name host-name } * [ slot slot-number ] |
Display information about the IP address corresponding to the kernel host name. |
display object-group kernel { ip | ipv6 } host { object-group-name object-group-name | name host-name } * [ slot slot-number ]
