04-Layer 3—IP Services Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S6520X-HI[EI][SI]&S6520-SI&S5560X-HI&S5000-EI&MS4600 Configuration Guides-R68xx-6W10104-Layer 3—IP Services Configuration Guide
07-IP forwarding basics configuration
07-IP forwarding basics configuration 85.29 KB
Configuring IP forwarding basic settings························································ 1
About FIB table······························································································································· 1
Saving the IP forwarding entries to a file··························································································· 2
Forwarding specific packets received from VXLAN tunnels in hardware·············································· 2
Enabling SNMP notifications for FIB events······················································································ 3
Enabling SNMP notifications for IP forwarding events······································································· 3
Display and maintenance commands for FIB table············································································ 4
Configuring load sharing··················································································· 5
About load sharing·························································································································· 5
Specifying a shift value for the load sharing calculation result···························································· 5
Enabling local-first load sharing······································································································· 5
Enabling symmetric load sharing······································································································ 6
About FIB table
A device uses the FIB table to make packet forwarding decisions.
A device selects optimal routes from the routing table, and puts them into the FIB table. Each FIB entry specifies the next hop IP address and output interface for packets destined for a specific subnet or host.
For more information about the routing table, see Layer 3—IP Routing Configuration Guide.
Use the display fib command to display the FIB table. The following example displays the entire FIB table.
<Sysname> display fib
Destination count: 8 FIB entry count: 8
Flag:
  R:Relay     F:FRR
Destination/Mask   Nexthop         Flag     OutInterface/Token       Label
0.0.0.0/32         127.0.0.1       UH       InLoop0                  Null
127.0.0.0/8        127.0.0.1       U        InLoop0                  Null
127.0.0.0/32       127.0.0.1       UH       InLoop0                  Null
127.0.0.1/32       127.0.0.1       UH       InLoop0                  Null
127.255.255.255/32 127.0.0.1       UH       InLoop0                  Null
224.0.0.0/4        0.0.0.0         UB       NULL0                    Null
224.0.0.0/24       0.0.0.0         UB       NULL0                    Null
255.255.255.255/32 127.0.0.1       UH       InLoop0                  Null
A FIB entry includes the following items:
·     Destination—Destination IP address.
·     Mask—Network mask. The mask and the destination address identify the destination network. A logical AND operation between the destination address and the network mask yields the address of the destination network. For example, if the destination address is 192.168.1.40 and the mask 255.255.255.0, the address of the destination network is 192.168.1.0. A network mask includes a certain number of consecutive 1s. It can be expressed in dotted decimal format or by the number of the 1s.
·     Nexthop—IP address of the next hop.
·     Flag—Route flag.
·     OutInterface—Output interface.
·     Token—MPLS Label Switched Path index number.
·     Label—Inner label.
The feature automatically creates the file if you specify a nonexistent file. If the file already exists, this feature overwrites the file content.
This feature triggers one-time saving of the IP forwarding entries.
To automatically save the IP forwarding entries periodically, configure a schedule for the device to automatically run the ip forwarding-table save command. For information about scheduling a task, see Fundamentals Configuration Guide.
To save the IP forwarding entries to a file, execute the following command in any view:
ip forwarding-table save filename filename
By default, the device forwards ARP and MLD packets received from VXLAN tunnels to the CPU for processing when acting as a VTEP in a distributed EVPN gateway network. If a large number of such packets are received, packet loss might occur because of software rate limit, which might cause service exceptions on downlink devices.
To resolve this issue, you can enable the device to forward ARP and MLD packets received from VXLAN tunnels in hardware without delivering them to the CPU.
Traffic forwarding issues might occur if you use this command together with either of the following commands:
·     flooding disable all all-direction
·     flooding disable broadcast all-direction
To make sure the device can forward traffic correctly, perform the following steps before you enable this feature:
1.     Check the configuration for the flooding disable all all-direction and flooding disable broadcast all-direction commands.
2.     If either command exists, do the following:
a.     Execute the undo flooding disable command to enable flooding on the device.
b.     Execute the flooding disable all command to disable the device from flooding any types of traffic received from ACs to VXLAN tunnel interfaces of the VSI.
c.     Configure port isolation for the ACs to confine their flooding traffic.
To ensure access to slient devices, such as dumb terminals, you must also execute the undo mac-address static source-check enable command to disable the static source check feature. If you cannot identify whether silient devices exist, disable static source check as a best practice.
3.     Enter system view.
4.     Enable hardware forwarding for specific packets received from VXLAN tunnels.
forwarding vxlan-packet inner-protocol { ipv4 | ipv6 } *
By default, packets received from VXLAN tunnels are delivered to the CPU for processing.
This feature enables the FIB module to generate SNMP notifications for critical FIB events, such as the exceeding of the message queue length threshold. The SNMP notifications are sent to the SNMP module.
You can enable specific SNMP notifications for FIB events as needed. If you do not specify any SNMP notification types, the command enables all types of SNMP notifications.
·     With ecmp-limit specified, when the number of ECMP routes learned by a module exceeds the upper limit, the device sends an SNMP notification that carries the module number to the SNMP module.
·     With entry-consistency specified, if the FIB software and hardware entries on a module are inconsistent, the device sends an SNMP notification that carries the module number to the SNMP module.
·     With entry-limit specified, when the number of FIB entries exceeds the upper limit, the device sends an SNMP notification that carries the FIB entry module name to the SNMP module.
·     With deliver-failed specified, when FIB entry deployment to the hardware fails, the device sends an SNMP notification that carries the entry VRF, IP address type, IP address, mask, and failure reason to the SNMP module.
For the SNMP notifications to be sent correctly, you must also configure SNMP. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
2.     Enable SNMP notifications for FIB events.
snmp-agent trap enable fib [ deliver-failed | ecmp-limit | entry-consistency | entry-limit ] *
By default, SNMP notifications for FIB events are enabled.
This feature enables the IP forwarding module to generate SNMP notifications for critical IP forwarding events. The SNMP notifications are sent to the SNMP module. For the SNMP notifications to be sent correctly, you must also configure SNMP. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
You can enable SNMP notifications for the following IP forwarding events as needed:
·     After you enable SNMP notifications about TTL timeout, the device checks the number of dropped packets at the specified time interval. An SNMP notification is generated and sent to the SNMP module when the number of dropped packets reaches or exceeds the specified threshold.
·     After you enable SNMP notifications about MBUF allocation failures, an SNMP notification is generated and sent to the SNMP module when MBUF allocation fails.
If you do not specify any parameters, the command enables all types of SNMP notifications for IP forwarding events.
After you disable the SNMP notifications for IP forwarding events, the device sends only logs to the device's information center module. In this case, you can configure the log output destinations and output rules to view the log information of the basic IPv6 modules. For more information about configuring the information center, see information center configuration in Network Management and Monitoring Configuration Guide.
2.     Enable SNMP notifications for IP forwarding events.
snmp-agent trap enable ip-forwarding [ ttl-expired | mbuf-alloc ]
By default, SNMP notifications for IP forwarding events are enabled.
Display FIB entries.
display fib [ vpn-instance vpn-instance-name ] [ ip-address [ mask | mask-length ] ]
About load sharing
If a routing protocol finds multiple equal-cost best routes to the same destination, the device forwards packets over the equal-cost routes to implement load sharing.
If traffic is not shared equally, you can use the shift shift-number option to adjust the load sharing calculation result.
The priority of slot-specific load balancing is higher than the global load balancing method. The global configuration takes effect only on slots that are not specified with a load balancing method.
The feature does not support configuring per-flow load sharing based on source IP address, destination IP address, source port number, destination port number, or ingress port. To resolve this issue, execute the link-aggregation global load-sharing mode command. For more information, see Ethernet link aggregation configuration in Layer 2LAN Switching Configuration Guide.
2.     Specify a shift value for the load sharing calculation result.
ip load-sharing mode per-flow algorithm algorithm-number shift shift-number { global | slot slot-number }
By default, the shift value is 0 for the load sharing calculation result.
Local-first load sharing distributes traffic preferentially across the output interfaces on the receiving IRF member device if output interfaces for multiple equal-cost routes are on different members. This feature enhances packets forwarding efficiency.
2.     Enable local-first load sharing.
ip load-sharing local-first enable
By default, local-first load sharing is enabled.
Symmetric load sharing ensures that bidirectional traffic specific to a source and destination address pair flow along the same path.
2.     Enable symmetric load sharing.
ip load-sharing symmetric enable
By default, symmetric load sharing is disabled.
