11-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6520X-HI[EI][SI]&S6520-SI&S5560X-HI&S5000-EI&MS4600 Command References-R68xx-6W10111-Network Management and Monitoring Command Reference
12-EPA commands
12-EPA commands 76.44 KB
EPA commands
display epa monitor-information
Use display epa monitor-information to display endpoint association and disassociation information detected by EPA.
display epa monitor-information [ online | offline ] [ device device-id | mac mac-address [ vlan vlan-id ] ] [ verbose ]
online: Displays endpoint association information.
offline: Displays endpoint disassociation information.
device device-id: Specifies a device by its bridge MAC address in the H-H-H format. In a SmartMC network, you can specify the bridge MAC address of a member to display only information about endpoints connecting to the member.
mac mac-address: Specifies an endpoint by its MAC address in the H-H-H format.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094. If you do not specify this option, the command displays information in all VLANs.
verbose: Displays detailed information about identified endpoints. If you do not specify this keyword, the command displays brief information.
In a SmartMC network, you can execute this command on the commander or on a member.
·     If you execute this command on the commander, you can view information on all devices in the network or information on a specific device.
·     If you execute this command on a member, you can view only association events of endpoints connecting to the member.
In a non-SmartMC network, this command displays information only on the device on which the command is executed. For more information about SmartMC, see Network Management and Monitoring Configuration Guide.
If an endpoint has multiple IP addresses, only one IP address is displayed.
# In a SmartMC network, display endpoint association and disassociation information on the member device with ID 3cf5-cc97-772f.
<Sysname> display epa monitor-information device 3cf5-cc97-772f
Auto identification : Disabled
Local device type   : SmartMC TM
Local device ID     : ae05-0607-eaaa
Endpoint information:
  Access device ID    MAC address     VLAN    Interface                  Status
  3cf5-cc97-772f      0e74-e2fb-0400  11      GigabitEthernet1/0/1       Online
  3cf5-cc97-772f      5caf-2e5f-0100  11      GigabitEthernet1/0/1       Offline
# In a non-SmartMC network, display endpoint association and disassociation information on the current device.
Local device type   : Self-managed
Local device ID     : d461-fe34-15c0
  d461-fe34-15c0     0026-ba12-3456  1      GigabitEthernet1/0/1         Online
  d461-fe34-15c0     2064-3211-1111  1      GigabitEthernet1/0/1         Online
# (Devices not supporting automatic endpoint identification) In a SmartMC network, display detailed endpoint information on the commander.
<Sysname> display epa monitor-information verbose
Auto identification: Disabled
Total endpoints identified by EPA: 1
Access device ID: ac74-0935-9dbe
  MAC address   : 1cab-3464-ad82              VLAN  : 100
  IP address    : 1.1.1.1
  Interface     : GigabitEthernet1/0/1        Status: Online
  Category      : Camera                      Vendor: -
  OS            : -
# (Devices not supporting automatic endpoint identification) In a non-SmartMC network, display detailed endpoint information on the current device.
Access device ID: d461-fe34-15c0
  MAC address   : 0026-ba12-3456                   VLAN  : 1
  OS            : -
# (Devices supporting automatic endpoint identification) In a SmartMC network, display detailed endpoint information on the commander.
Auto identification: Enabled
Total endpoints identified by EPA: 2
  OS            : -
  MAC address: 0000-0000-0002             VLAN  : 1
  IP address    : 1.1.1.2
  Interface     : GigabitEthernet1/0/1       Status: Offline
  Category      : Phone                      Vendor: Samsung
  OS            : Android
# (Devices supporting automatic endpoint identification) In a non-SmartMC network, display detailed endpoint information on the current device.
Auto identification : Enabled
  OS            : -
  MAC address   : 2064-3211-1111                   VLAN  : 1
  Category      : Smartphone                       Vendor: Samsung
  OS            : Android
Auto identification
State of automatic endpoint identification.
Local device type
Local device type. Options include:
·     Self-managedIndicates a device in a non-SmartMC network.
·     SmartMC TMIndicates the commander in a SmartMC network.
·     SmartMC TCIndicates a member in a SmartMC network.
Local device ID
Local device ID (bridge MAC address).
Access device ID
ID (bridge MAC address) of the connected device.
MAC address
MAC address of the endpoint.
VLAN
VLAN in which the endpoint resides.
Interface to which the endpoint is connected.
Status
Endpoint status. Options include:
·     Online.
·     Offline.
Category
Endpoint category. This field is fixed at Camera for static endpoint identification.
Vendor
Vendor of the endpoint. This field displays a hyphen (-) if the vendor fails to be obtained.
OS
OS of the endpoint. This field displays a hyphen (-) if the OS fails to be obtained.
epa monitor-rule
epa auto-identify enable
Use epa auto-identify enable to enable automatic endpoint identification.
Use undo epa auto-identify enable to disable automatic endpoint identification.
Automatic endpoint identification is disabled.
Automatic endpoint identification works with BYOD. When an endpoint accesses the network, EPA obtains fingerprint information from the authentication request of an endpoint and matches the fingerprint with the BYOD endpoint identification rules. If a match is found, EPA considers that the endpoint is online and records the MAC address, endpoint category, and vendor of the endpoint.
For automatic endpoint identification to take effect, you must complete BYOD-related settings.
After you modify a fingerprint entry, the modified parameters are reflected for matching online endpoints only if they log out and log in again.
# Enable automatic endpoint identification.
[Sysname] epa auto-identify enable
display byod rule (Security Command Reference)
epa monitor-rule
Use epa monitor-rule to create a static endpoint identification rule.
Use undo epa monitor-rule to remove a static endpoint identification rule.
epa monitor-rule [ monitor-rule-id ] mac mac-address [ mask mac-mask ] [ vlan vlan-id ]
undo epa monitor-rule { monitor-rule-id | mac mac-address [ mask mac-mask ] [ vlan vlan-id ] }
No static endpoint identification rules exist.
monitor-rule-id: Specifies the rule ID in the range of 1 to 1024. If you do not specify this argument, the command assigns the smallest available ID to the rule.
mac mac-address: Specifies the MAC address of the endpoint to monitor, in the H-H-H format.
mask mac-mask: Specifies a MAC address mask, in the H-H-H format.
vlan vlan-id: Specifies the VLAN in which the endpoint will be monitored. The vlan-id argument represents the VLAN ID in the range of 1 to 4094. If you do not specify this option, the command creates a rule that monitors the endpoint in all VLANs.
In a SmartMC network, you can execute this command only on the commander. The commander will deploy the rule to all members to monitor associations and disassociations of the specified endpoint in the entire network.
In a non-SmartMC network, this command enables the device to monitor associations and disassociations of the specified endpoint only on the device itself.
# Create a static endpoint identification rule to monitor endpoints whose MAC address starts with 0e74 in all VLANs.
[Sysname] epa monitor-rule mac 0e74-e2fb-0400 mask ffff-0000-0000
epa online-offline-log disable
Use epa online-offline-log disable to disable EPA logging.
Use undo epa online-offline-log disable to enable EPA logging.
EPA logging is enabled.
By default, the EPA module logs endpoint associations and disassociations. If a monitored endpoint comes online or goes offline frequently, the device will generate a large number of log entries. In this case, to avoid affecting device performance, disable EPA logging as a best practice.
# Disable EPA logging.
[Sysname] epa online-offline-log disable
epa monitor-rule
