H3C WA6100 Series Access Points Hardware Information and Specifications-6W101
HomeSupportWirelessWA6100 Series Access PointsProduct LiteratureHardware Information & SpecificationsH3C WA6100 Series Access Points Hardware Information and Specifications-6W101
01-Text
01-Text 1.06 MB
Product overview
The WA6100 AP series includes the following models:
Table 1 WA6100 AP series
Product code
Product model
Remarks
EWP-WA6120
WA6120
Indoor AP
EWP-WA6120H
WA6120H
EWP-WA6126
WA6126
EWP-WA6120X
WA6120X
Outdoor AP
Chassis views and technical specifications
WA6120
Chassis view
Chassis view
Figure 1 Chassis view
Chassis dimensions
Figure 2 Chassis dimensions
Ports
The AP provides the following ports:
·     One console port.
·     One GE/PoE port.
·     One power port.
The AP also has a reset button and a security slot. The security slot is 7 × 3 mm (0.28 × 0.12 in) in size.
Figure 3 Ports on the AP
(1) Security slot
(2) GE/PoE port
(3) Power port
Figure 4 Left view
(1) Reset button
(2) Console port
Technical specifications
Table 2 Technical specifications
Item
Specification
Dimensions (H × W × D)
32 × 180 × 180 mm (1.26 × 7.09 × 7.09 in), mounting bracket excluded
Weight
500g
Power consumption
·     Standby: 5.4W
·     Operating: ≤ 12.95 W
Antenna
Built-in antenna:
·     2.4 GHz: 3 dBi gain
·     5.0 GHz: 4 dBi gain
Protocol
·     IEEE802.11a/b/g/n/ac/ax
·     IEEE802.3af
Operating temperature
-10°C to +55°C (14°F to 131°F)
Storage temperature
–40°C to +70°C (–40°F to +158°F)
Operating humidity
5% RH to 95% RH, noncondensing
Storage humidity
Protection class
IP41
Console port
Used by technical personnel only for device configuration and management.
GE/PoE
100/1000M Ethernet copper port, used for connecting the AP to an uplink device for Internet or MAN access. It can also receive PoE power from the uplink device.
When the AP operates in fit mode, the port is represented by interface number GE1/0/1 in the MAP file and GigabitEthernet 1 for configuration on the AC.
54V DC
Power port, used for receiving +54 VDC power from a local power source.
Reset button
The function of the reset button varies by duration in which it is pressed. For more information, see "LED description for the reset button."
LEDs
Yellow/green/blue. For more information about the LED status in different AP operating modes, see "LED descriptions for single-LED APs"
WA6120H
Chassis view
Chassis view
Figure 5 Chassis view
Chassis dimensions
Figure 6 Chassis dimensions
Ports
·     One console port
·     Four 10/100/1000M Ethernet copper ports
·     One 54 VDC power port
·     One Uplink/PoE port
·     One USB port
It also provides a reset button (RST).
Figure 7 Ports on the AP
(1) 10/100/1000M Ethernet copper ports
Figure 8 Left view
(1) Reset button (RST)
(2) Console port
(3) USB port
Figure 9 Rear view
(1) Uplink/PoE port
(2) 54 VDC power port
Table 3 Technical specifications
Item
Specification
39 × 86 × 160 mm (1.54 × 3.39 × 6.30 in, excluding the mounting bracket)
Weight
350 g (12.35 oz)
Power consumption
·     Standby: 6.3 W
·     Operating:
¡     ≤ 32.06 W (PoE_OUT/USB included)
¡     ≤ 14.56 W (PoE_OUT/USB excluded)
Antenna
Built-in antenna:
·     5 GHz: 5 dBi gain
Standards
·     802.11ax, 802.11ac, 802.11n
·     802.3af
-10°C to 55°C (14°F to 131°F)
Storage temperature
Operating humidity
Storage humidity
Protection class
IP41
Console port
10/100/1000M Ethernet copper port.
When the AP operates in fit mode, the ports are represented interface numbers GE1/0/2 to GE1/0/5 in the MAP file and GigabitEthernet 2 to GigabitEthernet 5 on the AC.
Uplink/PoE port
10/100/1000M Ethernet copper port, used for connecting the AP to an uplink device for Internet or MAN access. It can also receive PoE power from the uplink device.
When the AP operates in fit mode, the port is represented by interface number GE1/0/1 in the MAP file and GigabitEthernet 1 on the AC.
Power port (54 V)
Used for receiving +54 VDC power from a local power source.
USB port
USB 2.0
Reset button
LEDs
Yellow/green. For more information about the LED status in different AP operating modes, see "LED descriptions for multi-LED APs."
WA6120X
Chassis view
Chassis view
Figure 10 Chassis view
Chassis dimensions
Figure 11 Chassis dimensions
Ports
·     Two 100/1000M Ethernet copper ports
Figure 12 Ports on the AP
(1) Reset button
(2) GE1/PoE port
(3) GE2
(4) Power port
(5) Grounding screw
Table 4 Technical specifications
Item
Specification
250 × 101 × 110 mm (9.84 × 3.98 × 4.33 in)
Weight
1.1 kg (2.43 lb)
Antenna
Built-in omnidirectional antenna:
·     2.4 G: 3 dBi gain
·     5.0 G: 5 dBi gain
Power consumption
·     Standby: 6.28 W
·     Operating: ≤ 16.32 W
Protocol
–30°C to +55°C (–22°F to +131°F)
Storage temperature
–40°C to +85°C (–40°F to +185°F)
Operating humidity
0% RH to 100% RH, noncondensing
Storage humidity
Protection class
IP67
GE1/PoE
10/100/1000M Ethernet copper port, which can receive PoE power.
The port is represented by interface GE1/0/1 in the MAP file and GigabitEthernet 1 for configuration on the AC.
GE2
The port is represented by interface GE1/0/2 in the MAP file and GigabitEthernet 2 for configuration on the AC.
DC54V
Power port, used for receiving +54V power from a local power source.
Reset button
LEDs
Yellow/green/blue. For more information about the LED status in different AP operating modes, see "LED descriptions for single-LED APs."
WA6126
Chassis view
Chassis view
Figure 13 Chassis view
Chassis dimensions
Figure 14 Chassis dimensions
Ports
·     One console port
·     One 10/100/1000M Ethernet copper port
·     One 100/1000/2500M Ethernet copper port
·     One USB port
Figure 15 Ports on the AP
(1) Reset button
(2) USB port
(3) Console port
(4) 10/100/1000M Ethernet copper port
(5) 100/1000/2500M Ethernet copper port
(6) Power port
Table 5 Technical specifications
Item
35 × 185 × 185 mm (1.38 × 7.28 × 7.28 in)
Weight
650 g (22.93 oz)
Power consumption
·     Standby: 7 W
·     Operating:≤ 17.6 W (USB excluded)
Antenna
·     2.4 GHz: 4 dBi gain
·     5 GHz: 4 dBi gain
Protocol
·     IEEE802.3at
–10°C to +55°C (32°F to 113°F)
Storage temperature
–40°C to +70°C (–40°F to +185°F)
Operating humidity
Storage humidity
Protection class
IP41
Console port
2.5GE/PoE+
100/1000M/2.5G Ethernet copper port, used for connecting the AP to an uplink device for Internet or MAN access. It can also receive PoE power from the uplink device.
When the AP operates in fit AP mode, the port is represented by interface number SGE1/0/1 in the MAP file and smartrate-Ethernet 1 for configuration on the AC.
GE
When the AP operates in fit AP mode, the port is represented by interface number GE1/0/1 in the MAP file and GigabitEthernet 1 for configuration on the AC.
USB port
USB 3.0-compliant USB port.
54V DC
Reset button
LEDs
About LEDs
The LED status includes the color and flashing frequency of the LEDs, which indicates the AP operating status.
APs can be classified into single-LED APs and multi-LED APs based on the LED quantity.
Figure 16 Single-LED AP (WA6120 as an example)
Figure 17 Multi-LED AP (WA6120H as an example)
Table 6 Wi-Fi 6 AP models
AP series
Models
Wi-Fi 6
WA6500 AP series
WA6120, WA6120X, WA6126
See "LED descriptions for single-LED APs"
WA6120H
See "LED descriptions for multi-LED APs."
The description for the status LED on an AP varies by AP operating mode. For information about the operating modes supported by an AP, see the release notes.
LED descriptions before modification
This section is applicable to the WA6500A AP series in versions earlier than 2616.
Table 7 LED description (fit mode)
LED color
Status
N/A
Off
No power is present or the LED has been turned off from the CLI.
Yellow
Steady on
The AP is initializing, or an initialization exception has occurred.
Flashing (twice per second)
The Ethernet ports are down and no mesh links are established.
Green
Steady on
The AP has started up and registered with an AC, but is in standby state (does not have any associated clients).
Flashing (once every two seconds)
The AP has started up, but has not registered to any AC.
The AP is upgrading the image.
Blue
Flashing (once per second)
The radios have associated clients.
Table 8 LED description (cloud mode)
LED color
Status
N/A
Off
Yellow
Steady on
Green
Steady on
The AP is in standby state, has connected to Cloudnet, but does not have any associated clients.
The AP has connected to Cloudnet, and the radios have associated clients.
Blue
Steady on
The AP is in standby state, has not connected to Cloudnet, and does not have any associated clients.
The AP has not connected to Cloudnet, but the radios have associated clients.
LED descriptions after modification
This section is applicable to the WA6500A AP series in 2616 and later versions.
Table 9 LED description
LED color
Status
N/A
Off
Yellow
Steady on
Green
Steady on
The AP is in standby state and does not have any associated clients.
The AP has started up in fit mode, but has not registered to any AC.
Blue
The descriptions for the status LEDs on an AP vary by AP operating mode. For information about the operating modes supported by an AP, see the release notes.
This section is applicable to the following APs:
WA6500A AP series in versions earlier than 2616..
Table 10 LED description
LED
Color
Status
Power status LED
N/A
Off
Yellow
Steady on
·     The system software is starting.
·     An initialization exception has occurred.
Green
The AP is operating in cloud mode and has connected to Cloudnet.
Steady on
The AP is in standby state. (The fit AP has registered with an AC.)
Alternating between yellow and green
The AP is operating in cloud mode and has not connected to Cloudnet.
Radio status LED
N/A
Off
The radios are disabled or the LED has been turned off from the CLI.
Yellow
A radio has been enabled but does not have associated clients.
Green
A radio has associated clients.
LED for a copper or fiber Ethernet port (such as a 1000M, 2.5G, 5G, or 10G port)
N/A
Off
No link is present on the port.
Yellow
Steady on
Negotiation has succeeded on the port, and the port is operating at a reduced speed.
The port is operating correctly at a reduced speed.
Green
Steady on
Negotiation has succeeded on the port, and the port is operating at the maximum speed.
The port is operating correctly at the maximum speed.
PON
Green
Steady on
Normal PON link.
The ONU is registering.
Off
The ONU is not registered.
Table 11 LED description
LED
Color
Status
Power status LED
N/A
Off
Yellow
Steady on
Green
Steady on
Radio status LED
N/A
Off
Yellow
Green
N/A
Off
Yellow
Steady on
Green
Steady on
PON
Green
Steady on
Normal PON link.
Off
Table 12 LED description for the reset button
Reset button
Press and hold duration (seconds)
LED color
LED status
RESET
0 to 5
Green
Steady on
Reset the AP.
5 to 20
Green
Restore to the factory defaults.
20 to 30
Yellow
The AP is operating in fit mode.
The AP is operating in anchor AC mode.
Flashing (four times per second)
The AP is operating in cloud mode.
> 30
Yellow
Green
The AP is switching from fit mode to cloud mode.
Note:
After you release the button, if the AP has switched from fit mode to cloud mode, it will restart for the new mode to take effect.
