13-Telemetry Command Reference
HomeSupportSwitchesS10500X-G SeriesReference GuidesCommand ReferencesH3C S10500X-G Switch Series Command References-R7756Pxx-6W10013-Telemetry Command Reference
05-INT commands
05-INT commands 128.36 KB
INT commands
display telemetry ifa
Use display telemetry ifa to display INT configuration.
# (Common INT.) Display the INT configuration on the entry node.
<Sysname> display telemetry ifa
  Telemetry ifa status          : Enabled
  Telemetry ifa packet-drop     : Disabled
  Telemetry ifa device-id       : 10.1.1.10
  Telemetry ifa role:
    Ten-GigabitEthernet3/0/1: Ingress
# (Common INT.) Display the INT configuration on the transit node.
  Telemetry ifa role:
    Ten-GigabitEthernet3/0/1: Transit
# (Common INT.) Display the INT configuration on the exit node.
  Telemetry ifa role:
    Ten-GigabitEthernet3/0/1: Egress
  Telemetry ifa collector:
    Source IP: 20.0.0.2
    Destination IP: 30.0.0.1
    Source-port: 12
    Destination-port: 14
# (Flexible INT.) Display the INT configuration on the entry node.
  Telemetry ifa action:
      Telemetry ifa 1 acl 2000 action mirror-to-processor sampler samp
# (Flexible INT.) Display the INT configuration on the transit node.
      Telemetry ifa 1 acl user-defined 5000 action add-metadata
# (Flexible INT.) Display the INT configuration on the exit node.
      Telemetry ifa 1 acl user-defined 5000 action add-metadata drop
    Source IP: 20.0.0.2
    Source-port: 12
Telemetry ifa role
INT role:
·     Ingress—Entry node.
·     Transit—Transit node.
·     Egress—Exit node.
Telemetry ifa global role
Global INT role, which can only be Transit-egress (transit node and exit node).
Global INT packet dropping: Enabled or Disabled.
Encapsulation parameters for INT packets.
Flexible INT configuration:
·     ifa 1—Action ID.
·     action add-metadata—Action of adding collected data on the transit node.
·     action add-metadata drop—Action of adding collected data and dropping original INT packets on the exit node.
telemetry ifa action add-metadata
Use telemetry ifa action add-metadata to configure an action of adding collected data to incoming INT packets on the transit node.
Use undo telemetry ifa to delete an action.
telemetry ifa ifa-id [ acl [ ipv6 | mac | user-defined ] { acl-number | name acl-name } action add-metadata
undo telemetry ifa ifa-id
No action is configured.
Interface view
ifa-id: Specifies an action ID in the range of 1 to 32.
acl: Specifies an ACL. If you do not specify this keyword, the command mirrors all packets.
·     ipv6: Specifies an IPv6 ACL.
·     mac: Specifies a Layer 2 ACL.
·     user-defined: Specifies a user-defined ACL.
·     acl-number: Specifies an ACL by its number. The following are available value ranges:
¡     2000 to 2999 for basic ACLs.
¡     3000 to 3999 for advanced ACLs.
¡     4000 to 4999 for Layer 2 ACLs.
¡     5000 to 5999 for user-defined ACLs.
·     name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters.
This command adds collected data to INT packets matching the specified ACL for calculating the transmission delay of the network.
If an ACL is used on the entry node to match original packets, the ACL specified in this command must have the same traffic match rules.
If the specified ACL does not exist or does not have any rules, no traffic will match the ACL.
If the vpn-instance vpn-instance-name option is specified in an ACL rule, the rule takes effect only on VPN packets. If the vpn-instance vpn-instance-name option is not specified in an ACL rule, the rule takes effect on both non-VPN packets and VPN packets.
When specifying an ACL by its number, follow these rules:
·     To specify an IPv4 ACL, specify the acl-number argument.
·     To specify an IPv6 ACL, you must first specify the ipv6 keyword and then specify the ACL number.
·     To specify a Layer 2 or user-defined ACL, you must first specify the related keyword and then specify the ACL number.
When specifying an ACL by its name, follow these rules:
·     To specify an IPv4 ACL, specify the name acl-name option.
·     To specify an IPv6, Layer 2, or user-defined ACL, you must first specify the related keyword and then specify the ACL name.
This command and the telemetry ifa role command are mutually exclusive on an interface.
You can execute this command multiple times to configure different actions for different traffic types. If you execute this command multiple times with the same ifa-id, the most configuration takes effect.
# Configure an action of adding collected data to incoming INT packets on Ten-GigabitEthernet 3/0/1.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] telemetry ifa 1 acl user-defined 5001 action add-metadata
acl (ACL and QoS Command Reference)
telemetry ifa role
telemetry ifa action add-metadata drop
Use telemetry ifa acl action add-metadata drop to configure an action of adding collected data to incoming INT packets and dropping original INT packets on the exit node.
telemetry ifa ifa-id [ acl [ ipv6 | mac | user-defined ] { acl-number | name acl-name } action add-metadata drop
Interface view
sampler sampler-name: Specifies a sampler by its name, a case-insensitive string of 1 to 31 characters. If you do not specify this option, the command mirrors all packets.
# Configure an action of adding collected data to incoming INT packets and dropping original INT packets on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] telemetry ifa 1 acl 3000 action add-metadata drop
telemetry ifa role
telemetry ifa action mirror-to-processor
Use telemetry ifa action mirror-to-processor to configure an action of mirroring incoming packets to the INT processor on the entry node.
Use undo telemetry ifa action mirror-to-processor to delete an action.
telemetry ifa ifa-id [ acl [ ipv6 | mac | user-defined ] { acl-number | name acl-name } ] action mirror-to-processor [ sampler sampler-name ]
Interface view
When specifying an ACL, follow these restrictions and guidelines:
·     If the specified ACL does not exist or does not have any rules, no traffic will match the ACL.
·     If the vpn-instance vpn-instance-name option is specified in an ACL rule, the rule takes effect only on VPN packets. If the vpn-instance vpn-instance-name option is not specified in an ACL rule, the rule takes effect on both non-VPN packets and VPN packets.
·     To specify an IPv6 ACL, you must specify both its ACL number and the ipv6 keyword.
·     To specify a Layer 2 or user-defined ACL, you can specify its ACL number without the mac or user-defined keyword.
·     To specify an IPv6, Layer 2, or user-defined ACL, you can specify both its ACL name and the related keyword.
A sampler selects a packet from sequential packets and sends the packet to other service modules for processing. You can reference a nonexistent sampler and then create the sampler. For more information about sampler, see Network Management and Monitoring Configuration Guide.
# Configure an action of mirroring incoming packets matching the specified ACL to the INT processor on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] telemetry ifa 1 acl 3000 action mirror-to-processor sampler S1
telemetry ifa role
telemetry ifa collector
Use telemetry ifa collector to configure the addressing parameters to encapsulate in INT packets sent to the collector.
Use undo telemetry ifa collector to restore the default.
telemetry ifa collector source source-address destination dest-address source-port port destination-port port [ vlan vlan-id ]
No addressing parameters are configured for INT packets.
source source-address: Specifies the source IP address for INT packets.
destination dest-address: Specifies the destination IP address for INT packets.
source-port port: Specifies the source port number for INT packets, in the range of 1 to 65535.
destination-port port: Specifies the destination port number for INT packets, in the range of 1 to 65535.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094. If you do not specify a VLAN ID, VLAN ID 0 is used.
Use this command on the exit node. The exit node uses the addressing parameters to find the outgoing interface for INT packets and sends the packets to the collector.
Do not specify the IP address of the management Ethernet port on the local device for the destination dest-address option.
# Specify source IP address 1.1.1.1, destination IP address 2.2.2.2, source port number 67, and destination port number 68 for INT packets.
[Sysname] telemetry ifa collector source 1.1.1.1 destination 2.2.2.2 source-port 67 destination-port 68
telemetry ifa device-id
telemetry ifa role
Use telemetry ifa device-id to specify a device ID for an INT node.
Use undo telemetry ifa device-id to restore the default.
telemetry ifa device-id address
An INT node does not have a device ID.
address: Specifies an IPv4 address as the device ID. You can specify any IPv4 address other than 0.0.0.0. As a best practice, specify the loopback address of the device as the device ID.
# Specify IPv4 address 10.1.1.10 as the device ID.
[Sysname] telemetry ifa device-id 10.1.1.10
telemetry ifa role
telemetry ifa global enable
Use telemetry ifa global enable to enable INT globally.
Use undo telemetry ifa global enable to disable INT globally.
INT is enabled globally.
# Enable INT globally.
[Sysname] telemetry ifa global enable
telemetry ifa role
telemetry ifa global packet-drop
Use telemetry ifa global packet-drop to enable global INT packet dropping.
Use undo telemetry ifa global packet-drop to disable global INT packet dropping.
Global INT packet dropping is disabled.
Execute this command if you do not want to send INT packets to the downstream node.
# Enable global INT packet dropping.
[Sysname] telemetry ifa global packet-drop
telemetry ifa role (interface view)
Use telemetry ifa role to specify an INT role for an interface.
Use undo telemetry ifa role to restore the default.
telemetry ifa role { egress | ingress | transit }
An interface does not take any INT role.
Interface view
egress: Specifies the interface as an egress interface.
ingress: Specifies the interface as an ingress interface.
transit: Specifies the interface as a transit interface.
For common INT, specify the interface on the entry node as the ingress interface. Specify the interface on the transit node as the transit interface. Specify the interface on the exit node as the egress interface.
Interfaces in different roles take different actions on incoming packets.
·     The ingress interface adds a timestamp and encapsulates the packet as an INT packet.
·     The transit interface adds a timestamp for the INT packet.
·     The egress interface adds a timestamp, encapsulates the INT packet according to the specified addressing parameters, and sends it to the collector.
# Specify Ten-GigabitEthernet 3/0/1 as the transit interface.
[Sysname-Ten-GigabitEthernet3/0/1] telemetry ifa role transit
telemetry ifa role (system view)
Use telemetry ifa role to specify an INT role for all interfaces.
telemetry ifa role transit-egress
transit-egress: Specifies the interface as an egress interface and a transit interface.
This command takes effect only in a VXLAN network. The device automatically selects an INT role for an interface according to the device role in the VXLAN network. As shown in Figure 1, the interface on the border device in a VXLAN network selects a role according to the INT packets received:
·     The interface acts as an egress interface for packets with the outer destination IP address as the IP address of the local device (packets that need VXLAN termination, for example, packets from site 1 to the Internet).
·     The interface acts as a transit interface for packets with the outer destination IP address as an IP address other than the IP address of the local device (packets that do not need VXLAN termination, for example, packets from site 1 to site 2).
Figure 1 Global INT role
This command and the telemetry ifa role or telemetry ifa action command can be executed at the same time. The interface role setting in interface view has higher priority over that in system view.
# Specify the interface role as transit-egress globally.
[Sysname] telemetry ifa role transit-egress
