- 11-High Availability Command Reference
- 01-Ethernet OAM commands
- 02-DLDP commands
- 03-RRPP commands
- 04-ERPS commands
- 05-Smart Link commands
- 06-Monitor Link commands
- 07-Error code detection commands
- 08-VRRP commands
- 09-VSRP commands
- 10-Reth interface and redundancy group commands
- 11-BFD commands
- 12-Track commands
- 13-Process placement commands
- 14-Interface collaboration commands
| 09-VSRP commands | 149.37 KB |
VSRP commands
VSRP peer commands
display vsrp peer
Use display vsrp peer to display VSRP group information.
display vsrp peer [ peer-name ]
peer-name: Specifies a VSRP group by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSRP group, this command displays information about all VSRP groups.
# Display information about VSRP group pname.
<Sysname> display vsrp peer pname
VSRP peer name: pname
TCP status: Connected
Peer IP: 11.0.0.3
Local IP: 10.0.0.3
Port: 6000
Track ID: 5
Track status: Positive
# Display information about all VSRP groups.
VSRP peer name: pname1
Peer IP: 11.0.0.3
Local IP: 10.0.0.3
Port: 6000
Track ID: 5
VSRP peer name: pname2
TCP status: Disconnected
Peer IP: 10.0.0.2
Local IP: 11.0.0.2
Port: 5000
Track ID: 5
Track status: Negative
VSRP peer name |
Name of a VSRP group. |
TCP status |
TCP control channel state: Connected or Disconnected. |
Peer IP |
Peer IP address for VSRP channels. |
Local IP |
Local IP address for VSRP channels. |
Port |
Port number for the TCP control channel. |
Track ID |
ID of the track entry associated with the VSRP group. |
Track status |
Track entry state: · Positive. · NotReady. · Negative. |
peer
Use peer to configure the IPv4 TCP parameters for establishing VSRP channels to the peer.
Use undo peer to restore the default.
peer peer-ip-address local local-ip-address [ port port-id ]
undo peer
No IPv4 VSRP channels are established to the peer.
VSRP peer view
peer-ip-address: Specifies the IPv4 address of the peer.
local local-ip-address: Specifies the IPv4 address of the local device.
port port-id: Specifies the TCP port number for establishing the control channel. The value range is 1024 to 65535 and the default is 60032. The specified port number cannot be one that is in use.
You must specify different unicast IPv4 addresses for the peer device and the local device in a VSRP group. The IPv4 addresses cannot be all zeros or loopback addresses.
If you have multiple VSRP groups, make sure their IP address pairs are unique.
To change the TCP parameters for VSRP channel establishment, first execute the undo form of the command to remove the existing IPv4 VSRP channels.
# Specify channel establishment parameters for VSRP group pname. Set the local IPv4 address to 11.0.0.2, the peer IPv4 address to 10.0.0.1, and the TCP port number for the control channel to 7000.
[Sysname] vsrp peer pname
[Sysname-vsrp-peer-pname] peer 10.0.0.1 local 11.0.0.2 port 7000
peer ipv6
Use peer ipv6 to configure the IPv6 TCP parameters for establishing VSRP channels to the peer.
peer ipv6 peer-ipv6-address local local-ipv6-address [ port port-id ]
undo peer [ ipv6 ]
No IPv6 VSRP channels are established to the peer.
VSRP peer view
peer-ipv6-address: Specifies the IPv6 address of the peer.
local local-ipv6-address: Specifies the IPv6 address of the local device.
You must specify different IPv6 unicast addresses for the peer device and the local device in a VSRP group. The IPv6 addresses cannot be all zeros or loopback addresses.
The specified IP addresses are also used to establish data channels. You can specify TCP ports for establishing data channels by service type in system view.
For a VSRP peer, you can specify one IPv4 or IPv6 address pair. You cannot set up both IPv4 and IPv6 VSRP channels with a VSRP peer. To change the TCP parameters for VSRP channel establishment, first remove the existing TCP connection. The undo peer command deletes both IPv4 and IPv6 TCP connections. The undo peer ipv6 command deletes only the IPv6 TCP connection. As a best practice, use the undo peer command.
# Specify the channel establishment parameters for VSRP group pname. Set the local IPv6 address to 1::1, the peer IPv6 address to 2::2, and the TCP port number for the control channel to 7000.
[Sysname-vsrp-peer-pname] peer ipv6 2::2 local 1::1 port 7000
track
Use track to associate a VSRP group with a track entry.
Use undo track to restore the default.
track track-entry-number
undo track
A VSRP group is not associated with any track entry.
VSRP peer view
track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
By default, a VSRP group can detect the state of the failover link based only on the state of the TCP control channel.
You can associate a VSRP group with a track entry to identify the state of the failover link.
· When the track entry is in Positive or NotReady state, a device in the VSRP group attempts to establish a TCP control channel to the peer.
· When the track entry changes to Negative state, the device terminates the TCP control channel.
A VSRP group takes effect only when a TCP control channel is established.
For more information about track entries, see High Availability Configuration Guide.
# Associate VSRP group pname with track entry 10.
[Sysname-vsrp-peer-pname] track 10
vsrp peer
Use vsrp peer to create a VSRP group and enter VSRP peer view, or enter the VSRP peer view of an existing VSRP group.
Use undo vsrp peer to remove a VSRP group.
vsrp peer peer-name
undo vsrp peer peer-name
No VSRP groups exist.
You can create a maximum of 64 VSRP groups on the device.
If a VSRP instance exists on a VSRP group, you must use the undo backup id command to remove that VSRP instance before you can remove the VSRP group.
# Create a VSRP group named pname and enter VSRP peer view.
VSRP instance commands
backup id
Use backup id to specify a backup ID for a VSRP instance.
Use undo backup id to restore the default.
backup id backup-id peer peer-name
undo backup id
A VSRP instance has no backup ID.
VSRP instance view
backup-id: Specifies a VSRP instance by its backup ID in the range of 1 to 1024.
A VSRP instance can be associated with only one VSRP group. The backup ID uniquely identifies a VSRP instance in a VSRP group.
You must specify the same backup ID for a VSRP instance on both devices in a VSRP group.
When you specify a backup ID for a VSRP instance, make sure the following conditions are met:
· The associated VSRP group already exists.
· The backup ID is unique in the VSRP group.
To specify a new backup ID for a VSRP instance, first execute the undo form of the command to remove the existing backup ID setting.
# Specify the backup ID of VSRP instance aaa as 5 in VSRP group pname.
[Sysname] vsrp instance aaa
[Sysname-vsrp-instance-aaa] backup id 5 peer pname
backup mode
Use backup mode to set the backup mode for a VSRP instance.
Use undo backup mode to restore the default.
backup mode { hot | warm }
undo backup mode
A VSRP instance operates in hot backup mode.
VSRP instance view
hot: Specifies hot backup mode.
warm: Specifies warm backup mode.
In hot backup mode, the backup device issues backup information to the data plane immediately upon receiving the information from the master. This allows the VSRP instance to perform a fast master and backup switchover to enable the backup to forward packets when the master fails.
In warm backup mode, the backup device does not issue received backup information to the data plane immediately. When the master fails and a switchover occurs, the backup begins to set backup information to the data plane. As a result, the switchover takes longer in warm backup mode than in hot backup mode.
# Set VSRP instance aaa to operate in warm backup mode.
[Sysname-vsrp-instance-aaa] backup mode warm
bind vrrp ipv6 vrid
Use bind vrrp ipv6 vrid to bind a VSRP instance to an IPv6 VRRP group.
Use undo bind vrrp ipv6 to restore the default.
bind vrrp ipv6 vrid virtual-router-id interface interface-type interface-number
undo bind vrrp ipv6
A VSRP instance is not bound to any IPv6 VRRP group.
VSRP instance view
virtual-router-id: Specifies an IPv6 VRRP group by its virtual router ID in the range of 1 to 255.
A VSRP instance is bound to an IPv6 VRRP group to determine the device role (master or backup) in a VSRP group.
You can bind a VSRP instance to only one IPv6 VRRP group. The IPv6 VRRP group can be on any interface.
# Bind VSRP instance aaa to IPv6 VRRP group 2 on Ten-GigabitEthernet 3/0/1.
[Sysname-vsrp-instance-aaa] bind vrrp ipv6 vrid 2 interface ten-gigabitethernet 3/0/1
bind vrrp vrid
Use bind vrrp vrid to bind a VSRP instance to an IPv4 VRRP group.
Use undo bind vrrp to restore the default.
bind vrrp vrid virtual-router-id interface interface-type interface-number
undo bind vrrp
A VSRP instance is not bound to any IPv4 VRRP group.
VSRP instance view
virtual-router-id: Specifies an IPv4 VRRP group by its virtual router ID in the range of 1 to 255.
A VSRP instance is bound to an IPv4 VRRP group to determine the device role (master or backup) in a VSRP group.
You can bind a VSRP instance to only one IPv4 VRRP group. The IPv4 VRRP group can be on any interface.
# Bind VSRP instance aaa to IPv4 VRRP group 2 on Ten-GigabitEthernet 3/0/1.
[Sysname-vsrp-instance-aaa] bind vrrp vrid 2 interface ten-gigabitethernet 3/0/1
display vsrp instance
Use display vsrp instance to display VSRP instance information.
display vsrp instance [ instance-name ]
instance-name: Specifies a VSRP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSRP instance, this command displays information about all VSRP instances.
# Display information about VSRP instance aaa.
<Sysname> display vsrp instance aaa
VSRP instance name: aaa
Backup ID: 10
Bound VRID: VRRP VRID 1 interface Ten-GigabitEthernet3/0/1
Instance status: Master
Local status: Master
Peer status: Backup
Backup mode: Warm
Traffic backup interval: 10(minutes)
Traffic backup threshold: 50(MB)
NAS IP: 10.0.0.1
NAS port: Ten-GigabitEthernet3/0/2
NAS ID: h3c
# Display information about all VSRP instances.
Backup ID: 10
Instance status : Master
Peer status: Backup
Backup mode: Warm
NAS IP: 10.0.0.1
NAS ID: h3c
VSRP instance name: bbb
Backup ID: 10
Bound VRID: VRRP VRID 2 interface Ten-GigabitEthernet3/0/3
Peer status: Backup
Backup mode: Warm
Traffic backup interval: 5(minutes)
Traffic backup threshold: 100(MB)
NAS IP: 10.0.0.2
NAS port: Ten-GigabitEthernet3/0/4
NAS ID: h3c
VSRP peer name |
Name of a VSRP group associated with the VSRP instance. |
Bound VRID |
Number of the VRRP group bound to the VSRP instance. |
Instance status |
VSRP instance state: · Master—The device acts as the master in the VSRP instance. · Backup—The device acts as the backup in the VSRP instance. · Down—The device is not running in the VSRP instance. |
Local status |
Local device state: · Master—The local device is acting as the master. · Backup—The local device is acting as the backup. · Init—The local device is in initialized state. · Down—The state of the local device is unknown. |
Peer status |
Peer state: · Master—The peer is acting as the master. · Backup—The peer is acting as the backup. · Init—The peer is in initialized state. · Down—The state of the peer is unknown. |
Backup mode |
VSRP instance backup mode: Hot or Warm. |
Traffic backup threshold |
Traffic threshold that triggers a traffic backup. |
NAS IP |
Logical NAS IP address. |
NAS port |
Logical NAS port. |
NAS ID |
Logical host name. |
nas
Use nas to configure NAS parameters.
Use undo nas to remove the NAS parameters.
nas { id host-name | ip ip-address | port interface-type interface-number }
undo nas [ id | ip | port ]
No NAS parameters are configured.
VSRP instance view
id host-name: Specifies a logical host name, a case-insensitive string of 1 to 127 characters.
ip ip-address: Specifies a logical unicast IP address. The IP address cannot be all zeros or a loopback address.
port interface-type interface-number: Specifies a logical interface by its type and number. It can be a Layer 3 Ethernet interface or a Layer 3 aggregate interface. The logical interface can be an interface that does not belong to the device. Make sure the logical interface number contains three segments in interface-type A/B/C format.
This command specifies NAS parameters for outgoing packets. This command enables devices in a VSRP group to share parameters when the devices have the following settings:
· The same NAS-IP-address, NAS-Port, and host name in packets sent to the RADIUS server.
· The same Option 82 in packets sent to the DHCP server.
In this way, the VSRP group is not required to be authenticated again after a master and backup switchover.
# Specify the logical IP address as 2.2.2.2.
[Sysname-vsrp-instance-aaa] nas ip 2.2.2.2
# Specify the logical interface as Ten-GigabitEthernet 3/0/1.
[Sysname-vsrp-instance-aaa] nas port ten-gigabitethernet 3/0/1
# Specify the logical host name as bbb.
[Sysname-vsrp-instance-aaa] nas id bbb
traffic backup
Use traffic backup to set a traffic backup interval or a traffic threshold that triggers a traffic backup.
Use undo traffic backup to remove the specified traffic backup interval or traffic threshold settings.
traffic backup { interval interval-value | threshold threshold-value } *
undo traffic backup [ interval | threshold ]
A VSRP instance backs up traffic at an interval of 10 minutes or when the traffic reaches 50 MB.
VSRP instance view
interval interval-value: Specifies a traffic backup interval in the range of 0 to 1440 minutes.
threshold threshold-value: Specifies a traffic threshold that triggers a traffic backup. The value range for the threshold-value argument is 0 to 100000 MB.
A VSRP instance backs up service data at the specified interval or when the specified traffic threshold is reached.
If traffic is not required to be backed up, set both the interval-value argument and the threshold-value argument to 0.
# Configure VSRP instance aaa to back up traffic every 50 minutes.
[Sysname-vsrp-instance-aaa] traffic backup interval 50
# Configure VSRP instance aaa to back up traffic when the traffic reaches 200 MB.
[Sysname-vsrp-instance-aaa] traffic backup threshold 200
# Set the traffic backup interval and the traffic threshold to the default value for VSRP instance aaa.
[Sysname-vsrp-instance-aaa] undo traffic backup
vsrp instance (system view)
Use vsrp instance to create a VSRP instance and enter its view, or enter the view of an existing VSRP instance.
Use undo vsrp instance to remove a VSRP instance.
vsrp instance instance-name
undo vsrp instance instance-name
No VSRP instances exist.
A VSRP instance is associated with a service module. To enable a VSRP instance to function, you must configure the following items for the VSRP instance:
· A VSRP group.
· A bound VRRP group.
· The backup mode.
· The traffic backup interval or traffic threshold.
The device supports a maximum of 1024 VSRP instances.
# Create a VSRP instance named aaa, and enter VSRP instance view.
IPv6 virtual address commands
ipv6 virtual-address
Use ipv6 virtual-address to specify a virtual IPv6 address for an interface that is associated with a VSRP instance.
Use undo ipv6 virtual-address to restore the default.
ipv6 virtual-address ipv6-address vsrp vsrp-instance
No virtual IPv6 address is configured.
Layer 3 Ethernet interface/subinterface view
VLAN interface view
ipv6-address: Specifies a virtual IPv6 address. The virtual IPv6 address must be a link local address that can be used as the gateway address by hosts in a LAN.
vsrp vsrp-instance: Specifies a VSRP instance by its name, a case-sensitive string of 1 to 31 characters.
Use this command when you enable VSRP for IPv6 IPoE or DHCPv6 services on an interface. For VSRP to operate correctly, specify the same VSRP instance in this command and in the ipv6 subscriber vsrp-instance or the ipv6 dhcp vsrp-instance command. If different VSRP instances are specified, the hosts in the LAN cannot access the Internet after a master and backup switchover.
For the original link local address of the device to take effect, do not use this command when VSRP is disabled for IPv6 IPoE or DHCPv6 on the interface.
To enable VSRP to operate correctly, do not use this command on the same interface where a VRRP group is configured.
# Specify virtual IPv6 address fe80::10 for Ten-GigabitEthernet 3/0/1 that is associated with VSRP instance aaa.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] ipv6 virtual-address fe80::10 vsrp aaa
DHCP VSRP commands
dhcp vsrp port
Use dhcp vsrp port to specify a TCP port number for VSRP to establish data channels for DHCPv4 server or relay agent service backup.
Use undo dhcp vsrp port to restore the default.
dhcp vsrp port port-number
undo dhcp vsrp port
TCP port 60037 is used to establish data channels for DHCPv4 server or relay agent service backup.
port-number: Specifies a TCP port number in the range of 1 to 65535. The TCP port cannot be used by other services or be a well-known port.
To back up data for a DHCPv4 address pool, the master DHCPv4 server must establish a TCP data channel with the backup DHCPv4 server.
To back up DHCPv4 relay agent data for a client-side interface, the master DHCPv4 relay agent must establish a TCP data channel with the backup DHCPv4 relay agent.
You can use this command to change the TCP port number for establishing the data channel.
# Specify TCP port 30000 for VSRP to establish data channels for DHCPv4 server or relay agent service backup.
[Sysname] dhcp vsrp port 30000
dhcp vsrp-instance
Use dhcp vsrp-instance to associate a client-side interface on the DHCPv4 server with a VSRP instance.
Use undo dhcp vsrp-instance to remove the VSRP instance association.
dhcp vsrp-instance vsrp-instance-name
The client-side interfaces on the DHCPv4 server are not associated with VSRP instances.
vsrp-instance-name: Specifies a VSRP instance by its name, a case-sensitive string of 1 to 31 characters.
You can specify a nonexistent VSRP instance for this command, but this command takes effect only after the VSRP instance is created.
Use this command on the master and backup DHCPv4 servers to match their interfaces that connect to the same client.
You can associate an interface or subinterface with only one VSRP instance.
You can associate a VSRP instance with one interface or multiple subinterfaces on the same interface.
If a VSRP instance has been associated with one interface, you must remove the VSRP instance from that interface before you can specify it on another interface.
# Associate Ten-GigabitEthernet 3/0/1 with VSRP instance vsrp1.
[Sysname-Ten-GigabitEthernet3/0/1] dhcp vsrp-instance vsrp1
ipv6 dhcp vsrp port
Use ipv6 dhcp vsrp port to specify a TCP port number for VSRP to establish data channels for DHCPv6 server or relay agent service backup.
Use undo ipv6 dhcp vsrp port to restore the default.
ipv6 dhcp vsrp port port-number
TCP port 60039 is used to establish data channels for DHCPv6 server or relay agent service backup.
To back up data for a DHCPv6 address pool, the master DHCPv6 server must establish a TCP data channel with the backup DHCPv6 server.
To back up DHCPv6 relay agent data for a client-side interface, the master DHCPv6 relay agent must establish a TCP data channel with the backup DHCPv6 relay agent.
# Specify TCP port 30000 for VSRP to establish data channels for DHCPv6 server or relay agent service backup.
[Sysname] ipv6 dhcp vsrp port 30000
Use ipv6 dhcp vsrp-instance to associate a client-side interface on the DHCPv6 server with a VSRP instance.
Use undo ipv6 dhcp vsrp-instance to remove the VSRP instance association.
ipv6 dhcp vsrp-instance vsrp-instance-name
The client-side interfaces on the DHCPv6 server are not associated with VSRP instances.
Use this command on the master and backup DHCPv6 servers to match their interfaces that connect to the same client.
[Sysname-Ten-GigabitEthernet3/0/1] ipv6 dhcp vsrp-instance vsrp1
virtual-duid
Use virtual-duid to generate a virtual DUID for a DHCPv6 server.
Use undo virtual-duid to restore the default.
virtual-duid { enterprise-number enterprise-number identifier identifier | hardware-type hardware-type address address }
undo virtual-duid
No virtual DUID is generated for a DHCPv6 server.
DHCPv6 address pool view
enterprise-number enterprise-number: Specifies a registered private enterprise number. The value range for the enterprise-number argument is 0 to FFFFFFFF in hexadecimal format.
identifier identifier: Specifies a device identifier in hexadecimal format. The number of hexadecimal digits must be an even number between 2 and 128.
hardware-type hardware-type: Specifies the hardware type, a hexadecimal number in the range of 0 to FFFF.
address address: Specifies a link layer address in hexadecimal format. The number of hexadecimal digits must be an even number between 2 to 128.
By default, the master and backup DHCPv6 servers use their respective DUIDs for DHCP communication. For DHCPv6 clients to correctly renew leases or release IPv6 addresses after a switchover, use this command to generate the same virtual DUID for the master and the backup.
# Configure DHCPv6 address pool pool1 to use the virtual DUID generated based on enterprise number 1 and identifier 1234.
[Sysname] ipv6 dhcp pool pool1
[Sysname-dhcp6-pool-pool1] virtual-duid enterprise-number 1 identifier 1234
vsrp-instance (DHCPv4/DHCPv6 address pool view)
Use vsrp-instance to associate a DHCPv4 or DHCPv6 address pool with a VSRP instance.
Use undo vsrp-instance to remove the VSRP instance association.
undo vsrp-instance
A DHCPv4 or DHCPv6 address pool is not associated with a VSRP instance.
DHCPv4 or DHCPv6 address pool view
When you execute this command, the master and backup DHCPv4 or DHCPv6 servers establish a data channel to back up address pool data.
You can specify a nonexistent VSRP instance, but this command takes effect only when the specified VSRP instance exists.
# Associate DHCPv4 address pool p1 with VSRP instance vsrp1.
[Sysname] dhcp server ip-pool p1
[Sysname-dhcp-pool-p1] vsrp-instance vsrp1
# Associate DHCPv6 address pool p1 with VSRP instance vsrp1.
[Sysname] ipv6 dhcp pool p1
[Sysname-dhcp6-pool-p1] vsrp-instance vsrp1
