07-IP Multicast Command Reference
HomeSupportSwitchesS10500X-G SeriesReference GuidesCommand ReferencesH3C S10500X-G Switch Series Command References-R7756Pxx-6W10007-IP Multicast Command Reference
11-IPv6 multicast routing and forwarding commands
The device supports MDCs only when it operates in the standard mode. For information about MDCs, see Virtual Technologies Configuration Guide.
acl (IPv6 multicast flow policy view)
Use acl to configure the multicast group range in which an IPv6 multicast flow policy takes effect.
Use undo acl to restore the default.
acl { ipv6-acl-number | name ipv6-acl-name }
undo acl
An IPv6 multicast flow policy does not take effect on any multicast groups.
ipv6-acl-number: Specifies an IPv6 basic or advanced ACL by its number, in the range of 2000 to 3999. If the ACL does not exist or does not have contain rules, the IPv6 multicast flow policy does not take effect on any multicast groups.
name ipv6-acl-name: Specifies an IPv6 basic or advanced ACL by its name. The acl-name argument is a case-insensitive string of 1 to 63 characters and must begin with an English letter. To avoid confusion, make sure the argument is not all. If the ACL does not exist or does not have contain rules, the IPv6 multicast flow policy does not take effect on any multicast groups.
This command is not supported by the default IPv6 multicast flow policy.
If a multicast group matches the ACL specified in an IPv6 multicast flow policy, the estimated bandwidth configured in the policy is used for the multicast flows of the multicast group.
In a basic ACL rule, the source parameter specifies a multicast group range. Among the other optional parameters, only the fragment keyword and the time-range time-range-name option take effect.
In an advanced ACL rule, the source parameter specifies a multicast source range, and the destination parameter specifies a multicast group range. Among the other optional parameters, only the fragment keyword and the time-range time-range-name option take effect.
An ACL rule containing the vpn-instance vpn-instance option does not take effect.
Example
# Configure an IPv6 multicast flow policy to take effect on the multicast group range FF03::101/128.
[Sysname] acl ipv6 basic 2000
[Sysname-acl-ipv6-basic-2000] rule permit source ff03::101 128
[Sysname] ipv6 multicast routing
[Sysname-mrib6] flow-policy name abc
[Sysname-mrib6-flow-policy-abc] acl 2000
flow-policy (IPv6 MRIB view)
bandwidth (IPv6 multicast flow policy view)
Use bandwidth to set the estimated bandwidth for IPv6 multicast flows.
bandwidth bandwidth { gbps | kbps | mbps }
undo bandwidth
The estimated bandwidth for IPv6 multicast flows is 0.
bandwidth: Specifies the estimated bandwidth in the range of 1 to 10000.
gbps: Specifies Gbps as the bandwidth unit.
kbps: Specifies kbps as the bandwidth unit.
Mbps: Specifies Mbps as the bandwidth unit.
The estimated bandwidth is selected for IPv6 multicast flows as follows:
1.     If the multicast group of an IPv6 multicast flow matches the ACL specified in a custom IPv6 multicast flow policy, the estimated bandwidth configured in the policy is selected for the multicast flow.
2.     If the multicast group of an IPv6 multicast flow does not match an ACL in any custom IPv6 multicast flow policy, the estimated bandwidth configured in the default policy is selected for the multicast flow.
3.     If the default policy is not created or the estimated bandwidth is not configured in the default policy, the estimated bandwidth for the multicast flow is 0.
Example
# Set the estimated bandwidth to 200 Mbps for IPv6 multicast flow policy abc.
[Sysname-mrib6-flow-policy-abc] bandwidth 200 mbps
delete ipv6 rpf-route-static
Use delete ipv6 rpf-route-static to delete all static IPv6 multicast routes.
delete ipv6 rpf-route-static [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command deletes all static IPv6 multicast routes on the public network.
This command deletes all static IPv6 multicast routes. To delete a single static IPv6 multicast route, use the undo ipv6 rpf-route-static command.
# Delete all static IPv6 multicast routes on the public network.
[Sysname] delete ipv6 rpf-route-static
This will erase all ipv6 multicast static routes and their configurations, you must reconfigure all ipv6 static routes.
Are you sure?[Y/N]:y
display ipv6 mrib interface
Use display ipv6 mrib interface to display information about interfaces maintained by the IPv6 MRIB.
display ipv6 mrib [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about interfaces maintained by the IPv6 MRIB on the public network.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about all interfaces maintained by the IPv6 MRIB.
# Display information about interfaces maintained by the IPv6 MRIB on the public network.
<Sysname> display ipv6 mrib interface
 Interface: Vlan-interface1
     Index: 0x00004444
     Current state: up
     MTU: 1500
     Type: BROADCAST
     Protocol: PIM-DM
     PIM protocol state: Enabled
     Address list:
          1. Local address : FE80:7:11::1/10
             Remote address: ::
             Reference     : 1
             State         : NORMAL
             Flags         : 0x0
Interface name.
Index
Index number of the interface.
Current state
Current status of the interface: up or down.
MTU
MTU value.
Interface type:
·     BROADCAST—Broadcast link interface.
·     LOOP—Loopback interface.
·     REGISTER—Register interface.
This field is empty if the interface is Null 0.
Protocol
Protocol running on the interface: PIM-DM, PIM-SM, MLD, or PROXY.
PIM protocol state
Whether IPv6 PIM is enabled: Enabled or Disabled.
Address list
Interface address list.
Local address
Local IP address.
Remote address
Remote end IP address. This field is displayed only when the interface is vlink type.
Reference
Number of times that the address has been used.
Status of the interface address: NORMAL or DEL.
Flags
Interface attribute:
·     0x0—The interface is in normal status.
·     0x1—The interface address is being deleted.
display ipv6 multicast boundary
Use display ipv6 multicast boundary to display IPv6 multicast boundary information.
display ipv6 multicast [ vpn-instance vpn-instance-name ] boundary { group [ ipv6-group-address [ prefix-length ] ] | scope [ scope-id ] } [ interface interface-type interface-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv6 multicast boundary information on the public network.
group: Displays the IPv6 multicast boundary information for the specified groups.
ipv6-group-address: Specifies an IPv6 multicast group address in the range of FFxy::/16, where "x" and "y" represent any hexadecimal numbers in the range of 0 to F. If you do not specify an IPv6 multicast group, this command displays IPv6 multicast boundary information for all IPv6 multicast groups.
prefix-length: Specifies an address prefix length in the range of 8 to 128. The default is 128.
scope: Displays the IPv6 multicast group boundary information in the admin-scoped zone.
scope-id: Specifies an admin-scope zone by its ID in the range of 3 to 15, which is identified by the scope field in the IPv6 multicast group address. If you do not specify an admin-scoped zone, this command displays IPv6 multicast boundary information for all IPv6 admin-scoped zones.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays IPv6 multicast boundary information for all interfaces.
# Display IPv6 multicast boundary information of all IPv6 multicast groups for all interfaces on the public network.
<Sysname> display ipv6 multicast boundary group
 Boundary                                                 Interface
 FF1E::/64                                                Vlan1
# Display IPv6 multicast boundary information in all IPv6 admin-scope zones for all interfaces on the public network.
<Sysname> display ipv6 multicast boundary scope
 Boundary            Interface
        3            Vlan-interface1
Boundary
IPv6 multicast group or IPv6 admin-scoped zone associated with the IPv6 multicast boundary.
Boundary interface associated with the IPv6 multicast boundary.
display ipv6 multicast fast-forwarding cache
Use display ipv6 multicast fast-forwarding cache to display IPv6 multicast fast forwarding entries.
In standalone mode:
display ipv6 multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache [ ipv6-source-address | ipv6-group-address ] * [ slot slot-number ]
In IRF mode:
display ipv6 multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache [ ipv6-source-address | ipv6-group-address ] * [ chassis chassis-number slot slot-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv6 multicast fast forwarding entries on the public network.
ipv6-source-address: Specifies an IPv6 multicast source address.
ipv6-group-address: Specifies an IPv6 multicast group address. The value range for this argument is FFxy::/16 (excluding FFx1::/16 and FFx2::/16), where "x" and "y" represent any hexadecimal numbers in the range of 0 to F.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 multicast fast forwarding entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6 multicast fast forwarding entries for the global active MPU. (In IRF mode.)
# Display IPv6 multicast fast forwarding entries on the public network.
<Sysname> display ipv6 multicast fast-forwarding cache
Total 1 entries, 1 matched
(FE1F:60::200, FF0E::1)
Status     : Enabled
Source port: 2001                   Destination port: 2002
Protocol   : 2                      Flag            : 0x2
Incoming interface: Vlan-interface1
List of 1 outgoing interfaces:
Vlan-interface2
Status: Enabled               Flag: 0x14
Total number of (S, G) entries, and the total number of matching (S, G) entries.
(S, G) entry.
Protocol
Protocol number.
Flag
Flag for the (S, G) entry or the outgoing interface of the entry.
This field displays one flag or the sum of multiple flags. In this example, the value 0x2 means that the entry has only one flag 0x2. The value 0x14 means that the outgoing interface has flags 0x10 and 0x4.
The following flags are available for an entry:
·     0x1—The entry is created because of packets passed through between cards.
·     0x2—The entry is added by IPv6 multicast forwarding.
The following flags are available for an outgoing interface:
·     0x1—The interface is added to the entry because of packets passed through between cards.
·     0x2—The interface is added to an existing entry.
·     0x4—The MAC address of the interface is needed for fast forwarding.
·     0x8—The interface is an outgoing interface associated with the incoming VLAN.
·     0x10—The interface is associated with the entry.
·     0x20—The interface is to be deleted.
Status
Status of the (S, G) entry or the outgoing interface:
·     Enabled—Available.
·     Disabled—Unavailable.
Incoming interface
Incoming interface of the (S, G) entry.
Outgoing interface list of the (S, G) entry.
reset ipv6 multicast fast-forwarding cache all
display ipv6 multicast flow-policy info
Use display ipv6 multicast flow-policy info to display link selection information for IPv6 multicast flow policies.
display ipv6 multicast [ vpn-instance vpn-instance-name ] flow-policy info [ interface interface-type interface-number | source source-address | group group-address | policy { default | name policy-name } ] *
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays link selection information for IPv6 multicast flow policies on the public network.
interface interface-type interface-number: Displays link selection information for IPv6 multicast flow policies on an interface.
source source-address: Displays link selection information for IPv6 multicast flow policies for a multicast source.
group group-address: Displays link selection information for IPv6 multicast flow policies for a multicast group. The value range for the group-address argument is FFxy::/16, where "x" and "y" represent any hexadecimal numbers in the range of 0 to F.
policy default: Specifies the default IPv6 multicast flow policy.
policy name policy-name: Specifies a custom IPv6 multicast flow policy by its name, a case-insensitive string of 1 to 63 characters.
If you do not specify the source, group, or policy parameter, this command displays link selection information for all IPv6 multicast flow policies.
# Display link selection information for all IPv6 multicast flow policies on the public network.
<Sysname> display ipv6 multicast flow-policy info
Total 2 interfaces, 2 matched
  Vlan-interface100:
    Available bandwidth: 100M
    Used bandwidth: 30M (30%)
    Total 4 entries, 4 matched
    Flow bandwidth: 5M
      Total 2 entries, 2 matched
        (100::1, ff03::101)
        Flow policy: video1
        (100::1, ff03::102)
        Flow policy: audio2
    Flow bandwidth: 10M
       (100::1, ff03::111)
         Flow policy: audio1
       (100::1, ff03::112)
         Default flow policy
  Vlan-interface200:
    Used bandwidth: 10M (10%)
    Flow bandwidth: 10M
      (100::1, ff03::103)
        Flow policy: video3
Total number of interfaces enabled with IPv6 PIM and number of matching interfaces.
Available bandwidth
Total available multicast bandwidth on the interface.
Used bandwidth
Used multicast bandwidth in percentage on the interface.
Total number of (S, G) entries that have selected the interface as an upstream interface and number of matching  (S, G) entries.
Flow bandwidth
Estimated bandwidth configured in an IPv6 multicast flow policy.
Total number of (S, G) entries for the IPv6 multicast flow policy and number of matching (S, G) entries.
(100::1, ff03::101)
(S, G) entry for the IPv6 multicast flow.
Flow policy
Name of the custom IPv6 multicast flow policy.
Default flow policy
Name of the default IPv6 multicast flow policy.
ipv6 flow-ucmp unicast reserved-bandwidth
display ipv6 multicast forwarding event
Use display ipv6 multicast forwarding event to display statistics of IPv6 multicast forwarding events.
In standalone mode:
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding event [ slot slot-number ]
In IRF mode:
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding event [ chassis chassis-number slot slot-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays statistics of IPv6 multicast forwarding events on the public network.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays statistics of IPv6 multicast forwarding events for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays statistics of IPv6 multicast forwarding events for the global active MPU. (In IRF mode.)
# Display statistics of IPv6 multicast forwarding events on the public network.
<Sysname> display ipv6 multicast forwarding event
Total active events sent: 0
Total inactive events sent: 0
Total NoCache events sent: 2
Total NoCache events dropped: 0
Total WrongIF events sent: 0
Total WrongIF events dropped: 0
Total SPT switch events sent: 0
NoCache rate limit: 1024 packets/s
WrongIF rate limit: 1 packets/10s
Total timer of register suppress timeout: 0
Table 5 Command output
Number of times that entry-active events have been sent.
Number of times that entry-inactive events have been sent.
Number of times that NoCache events have been sent.
Number of times that NoCache events have been dropped.
Number of times that WrongIF events have been sent.
Number of times that WrongIF events have been dropped.
Number of times that SPT-switch events have been sent.
NoCache rate limit
Rate limit for sending NoCache events, in pps.
WrongIF rate limit
Rate limit for sending WrongIF events, in packets per 10 seconds.
Number of times that the registration suppression has timed out in total.
reset ipv6 multicast forwarding event
display ipv6 multicast forwarding-table
Use display ipv6 multicast forwarding-table to display IPv6 multicast forwarding entries.
In standalone mode:
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number  | slot slot-number | statistics ] *
In IRF mode:
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | chassis chassis-number slot slot-number | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number | statistics ] *
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv6 multicast forwarding entries on the public network.
prefix-length: Specifies an address prefix length. The default value is 128. For an IPv6 multicast group address, the value range for this argument is 8 to 128. For an IPv6 multicast source address, the value range for this argument is 0 to 128.
incoming-interface: Specifies the IPv6 forwarding entries that contain the specified incoming interface.
outgoing-interface: Specifies the IPv6 forwarding entries that contain the specified outgoing interface.
exclude: Specifies the IPv6 forwarding entries that do not contain the specified interface in the outgoing interface list.
include: Specifies the IPv6 forwarding entries that contain the specified interface in the outgoing interface list.
match: Specifies the IPv6 forwarding entries that contain only the specified interface in the outgoing interface list.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 multicast forwarding entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6 multicast forwarding entries for the global active MPU. (In IRF mode.)
statistics: Displays statistics for the IPv6 multicast forwarding table.
# Display IPv6 multicast forwarding entries on the public network.
<Sysname> display ipv6 multicast forwarding-table
00001. (1::1, ff0e::1)
     Flags: 0x0
     Incoming interface: Vlan-interface10
     Backup incoming interface: Vlan-interface11
     List of 1 outgoing interface:
       1: Vlan-interface20
     Matched 19648 packets(20512512 bytes), Wrong If 0 packet
Table 6 Command output
00001
Sequence number of the (S, G) entry.
(1::1, ff0e::1)
(S, G) entry.
Flags
Entry flag.
This field displays one flag or the sum of multiple flags. In this example, the value 0x0 means that the entry has only one flag 0x0.
·     0x0—The entry is in correct state.
·     0x1—The entry is in inactive state.
·     0x2—The entry is null.
·     0x4—The entry fails to update.
·     0x8—The outgoing interface information fails to update for the entry.
·     0x20—A register outgoing interface is available.
·     0x40—The entry is to be deleted.
·     0x80—The entry is in registration suppression state.
·     0x100—The entry is being deleted.
·     0x200—The entry is in GR state.
·     0x800—The entry has the associated ND entry for the IPv6 multicast source address.
·     0x4000000—The entry is created by the MLD proxy.
Uptime
Length of time for which the (S, G) entry has been up.
Timeout in
Length of time in which the (S, G) entry will time out.
Backup incoming interface of the (S, G) entry. If the primary incoming interface of the (S, G) entry fails, IPv6 multicast data arrived at the backup incoming interface will be forwarded to receivers.
Outgoing sub-VLAN
Outgoing sub-VLAN of the super VLAN when the incoming interface of the (S, G) entry is the VLAN interface of this super VLAN.
Matched 19648 packets (20512512 bytes), Wrong If 0 packet
Number of packets (bytes) that match the (S, G) entry, and number of packets with incoming interface errors.
The numbers are displayed as 0 if an outgoing interface of the (S, G) entry is on the specified slot.
Forwarded 19648 packets (20512512 bytes)
Number of packets (bytes) that have been forwarded.
reset ipv6 multicast forwarding-table
display ipv6 multicast routing-table
Use display ipv6 multicast routing-table to display IPv6 multicast routing entries.
display ipv6 multicast [ vpn-instance vpn-instance-name ] routing-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number ] *
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv6 multicast routing entries on the public network.
prefix-length: Specifies an address prefix length. The default is 128. For an IPv6 multicast group address, the value range for this argument is 8 to 128. For an IPv6 multicast source address, the value range for this argument is 0 to 128.
incoming-interface: Displays the IPv6 routing entries that contain the specified incoming interface.
outgoing-interface: Displays the IPv6 routing entries that contain the specified outgoing interface.
exclude: Displays the IPv6 routing entries that do not contain the specified interface in the outgoing interface list.
include: Displays the IPv6 routing entries that contain the specified interface in the outgoing interface list.
match: Displays the IPv6 routing entries that contain only the specified interface in the outgoing interface list.
IPv6 multicast routing entries are the basis of IPv6 multicast forwarding. You can use this command to view the establishment state of (S, G) entries.
# Display IPv6 multicast routing entries on the public network.
<Sysname> display ipv6 multicast routing-table
 Total 1 entries
 00001. (2001::2, FFE3::101)
       Uptime: 00:00:14
       Upstream Interface: Vlan-interface1
       Backup Upstream Interface: Vlan-interface4
       List of 2 downstream interfaces
           1:  Vlan-interface2
           2:  Vlan-interface3
Table 7 Command output
Total 1 entries
Total number of (S, G) entries.
00001
(S, G) entry.
Uptime
Upstream Interface
Upstream interface at which the (S, G) packets should arrive.
Backup upstream interface of the (S, G) entry. If the primary upstream interface of the (S, G) entry fails, multicast data arrived at the backup upstream interface will be forwarded to receivers.
List of downstream interfaces that forward (S, G) packets.
reset ipv6 multicast routing-table
display ipv6 multicast routing-table static
Use display ipv6 multicast routing-table static to display static IPv6 multicast routing entries.
display ipv6 multicast [ vpn-instance vpn-instance-name ] routing-table static [ ipv6-source-address [ prefix-length ] ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays static IPv6 multicast routing entries on the public network.
prefix-length: Specifies the address prefix length in the range of 0 to 128. The default is 128.
This command displays only valid static IPv6 multicast routing entries.
# Display static IPv6 multicast routing entries on the public network.
<Sysname> display ipv6 multicast routing-table static
Destinations: 2        Routes: 4
Destination/Prefix: 2::100/128
  Pre: 10
  RPF neighbor                             Interface
  100::2                                   Vlan11
  125:0:3::3                               Vlan12
 Destination/Prefix: 3::100/128
  Pre: 20
  100::3                                   Vlan13
  125:0:3::4                               Vlan14
Table 8 Command output
Destinations
Number of IPv6 multicast destination addresses.
Routes
Number of routes.
Destination/Mask
Destination address and its prefix length.
Pre
Route preference.
RPF neighbor
IPv6 address of the RPF neighbor to the reachable destination.
Outgoing interface to the reachable destination.
display ipv6 multicast rpf-info
Use display ipv6 multicast rpf-info to display RPF information for an IPv6 multicast source.
display ipv6 multicast [ vpn-instance vpn-instance-name ] rpf-info ipv6-source-address [ ipv6-group-address ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays RPF information for an IPv6 multicast source on the public network.
ipv6-group-address: Specifies an IPv6 multicast group address in the range of FFxy::/16 (excluding FFx1::/16 and FFx2::/16), where "x" and "y" represent any hexadecimal numbers in the range of 0 to F.
# Display RPF information for IPv6 multicast source 2001::101 on the public network.
<Sysname> display ipv6 multicast rpf-info 2001::101
 RPF information about source 2001::101:
     RPF interface: Vlan-interface1, RPF neighbor: FE80::A01:101:1
     Backup RPF interface: Vlan-interface2, backup RPF neighbor: FE80::A01:101:2
     Referenced prefix/prefix length: 2001::/64
     Referenced route type: igp
     Load splitting rule: disable
     Source AS: 0
     C-multicast route target: 0x0000000000000000
Table 9 Command output
RPF information of the IPv6 multicast source 2001::101.
RPF interface
Type and number of the RPF interface.
RPF neighbor
IPv6 address (link-local address) of the RPF neighbor.
Referenced route and its prefix length.
Type of the referenced route:
·     igp—IPv6 IGP unicast route.
·     egp—IPv6 EGP unicast route.
·     unicast (direct) —IPv6 directly connected unicast route.
·     unicast—Other IPv6 unicast route, such as IPv6 unicast static route.
·     mbgp—IPv6 MBGP route.
RPF route selection rule:
·     Route preference.
·     Longest prefix match.
Load splitting rule
Whether load splitting is enabled.
Source AS
AS number of the source-side PE.
Route target attribute value of the C-multicast route.
Use flow-policy to create an IPv6 multicast flow policy and enter its view, or enter the view of an existing IPv6 multicast flow policy.
Use undo flow-policy to delete IPv6 multicast flow policies.
flow-policy { default | name policy-name }
undo flow-policy { all | default | name policy-name }
No IPv6 multicast flow policies exist.
IPv6 MRIB view
all: Deletes all IPv6 multicast flow policies.
Operating mechanism
The device selects the link with the smallest bandwidth usage as the optimal link if the following conditions exist:
·     ECMP routes between the device and an upstream device.
·     The multicast load-splitting mode is flow-ucmp.
If two links have the same bandwidth usage, the link with the higher next-hop IPv6 address is selected.
The bandwidth usage is calculated according to the following formula: Bandwidth usage = (Used bandwidth+Estimated bandwidth)/(Total interface bandwidth x (1–Unicast reserved bandwidth)).
·     The estimated bandwidth is configured by the bandwidth command in IPv6 multicast flow policy view.
·     The total interface bandwidth is configured by the bandwidth command in interface view.
·     The unicast reserved bandwidth is configured by the flow-ucmp unicast reserve-bandwidth or ipv6 multicast flow-ucmp unicast reserve-bandwidth command.
For this command to take effect, you must configure the multicast load-splitting mode as flow-ucmp.
Adding, deleting, or modifying an IPv6 multicast flow policy does not affect the link selection results of existing multicast flows and affects link selection for only new multicast flows. Before configuring the multicast load-splitting mode as flow-ucmp, you must plan the configuration of an IPv6 multicast flow policy and the unicast reserved bandwidth configuration.
The change of link bandwidth and the change in the number of ECMP routes do not affect the route selection of existing multicast flows.
This feature does not affect multicast source-side link selection, link selection in IPv6 PIM-DM, RPT link selection in IPv6 PIM-SM, or local RP link selection.
If both IPv4 and IPv6 multicast flows exist in the network, increase the unicast reserved bandwidth as needed to avoid congestion.
# Create an IPv6 multicast flow policy named abc and enter its view.
# Create the default IPv6 multicast flow policy and enter its view.
[Sysname-mrib6] flow-policy default
acl (IPv6 multicast flow policy)
bandwidth
flow-ucmp unicast reserve-bandwidth (IPv6 MRIB view)
Use flow-ucmp unicast reserve-bandwidth to set the global IPv6 unicast reserved bandwidth percentage.
Use undo flow-ucmp unicast reserve-bandwidth to restore the default.
flow-ucmp unicast reserve-bandwidth percentage
The global IPv6 unicast reserved bandwidth percentage is not set.
IPv6 MRIB view
percentage: Specifies the global IPv6 unicast reserved bandwidth percentage in the range of 1 to 100.
Execute this command when IPv6 unicast traffic and IPv6 multicast traffic coexist in the network. The available bandwidth for multicast traffic is calculated based on the total interface bandwidth and the configured IPv6 unicast reserved bandwidth percentage. For example, if the total interface bandwidth is 100 kbps and the IPv6 unicast reserved bandwidth percentage is 20% (20 kbps), the available bandwidth for multicast traffic is 80 kbps.
The flow-ucmp unicast reserve-bandwidth command takes effect on all interfaces, and the ipv6 multicast flow-ucmp unicast reserve-bandwidth command takes effect only on the current interface. If you execute both commands, the latter has higher priority.
Example
# Set the global IPv6 unicast reserved bandwidth percentage to 50%.
[Sysname-mrib6] flow-ucmp unicast reserve-bandwidth 50
ipv6 mtrace-service port
Use ipv6 mtrace-service port to specify the UDP port number used by IPv6 mtrace.
Use undo ipv6 mtrace-service port to restore the default.
ipv6 mtrace-service port number
IPv6 mtrace uses UDP port number 10240.
number: Specifies a UDP port number to be used by IPv6 mtrace, in the range of 1024 to 49151.
For successful IPv6 mtrace, do not specify a UDP port number used by other modules.
You must specify the same UDP port number on all devices on the traced path. Additionally, the specified UDP port number must be the same as that specified in the mtrace v2 command.
# Specify 12345 as the UDP port number used by IPv6 mtrace.
[sysname] ipv6 mtrace-service port 12345
mtrace v2 ipv6
Use ipv6 multicast boundary to configure an IPv6 multicast forwarding boundary.
Use undo ipv6 multicast boundary to delete an IPv6 multicast forwarding boundary.
ipv6 multicast boundary { ipv6-group-address prefix-length | scope { scope-id | admin-local | global | organization-local | site-local } }
undo ipv6 multicast boundary { ipv6-group-address prefix-length| all | scope { scope-id | admin-local | global | organization-local | site-local } }
An interface is not an IPv6 multicast forwarding boundary.
Interface view
prefix-length: Specifies the address prefix length in the range of 8 to 128.
all: Specifies all IPv6 multicast boundaries configured on the interface.
scope-id: Specifies the ID of an admin-scoped zone, in the range of 3 to 15, which is identified by the scope field in the IPv6 multicast group address.
admin-local: Specifies the scoped zone as admin-local, which has a scope ID of 4.
global: Specifies the scoped zone as global, which has a scope ID of 14.
organization-local: Specifies the scoped zone as organization-local, which has a scope ID of 8.
site-local: Specifies the scoped zone as site-local, which has a scope ID of 5.
A multicast forwarding boundary sets the boundary condition for the IPv6 multicast groups in the specified address range. If the destination address of an IPv6 multicast packet matches the set boundary condition, the packet is not forwarded.
An interface can act as a forwarding boundary for multiple IPv6 multicast groups in different address ranges. You can implement this by using this command on the interface for each multicast address range. These multicast groups must be in the same scope. The latest configuration of a scope overwrites the previous one.
You do not need to enable IPv6 multicast routing before you execute this command.
Assume that Set A and Set B are both IPv6 multicast forwarding boundary sets with different address ranges, and that B is a subset of A. A takes effect on the interface no matter whether A is configured earlier or later than B.
# Configure VLAN-interface 100 as the forwarding boundary of IPv6 multicast groups in the range of FF03::/16.
[Sysname-Vlan-interface100] ipv6 multicast boundary ff03:: 16
# Configure VLAN-interface 100 as the forwarding boundary of IPv6 multicast groups in the admin-local scope.
[Sysname-Vlan-interface100] ipv6 multicast boundary scope 4
ipv6 multicast extranet select-rpf
Use ipv6 multicast extranet select-rpf to configure an IPv6 MVPN extranet RPF selection policy.
Use undo ipv6 multicast extranet select-rpf to delete an IPv6 MVPN extranet RPF selection policy.
ipv6 multicast extranet select-rpf [ vpn-instance vpn-instance-name ] { source ipv6-source-address prefix-length | group ipv6-group-address  prefix-length }*
undo ipv6 multicast extranet select-rpf [ vpn-instance vpn-instance-name ] { source ipv6-source-address prefix-length | group ipv6-group-address  prefix-length }*
No IPv6 MVPN extranet RPF selection policies are configured.
IPv6 MRIB view
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the IPv6 multicast source belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. The PIM routing entry will select this VPN instance for the upstream RPF neighbor. If the multicast source belongs to the public network, do not specify this option.
source ipv6-source-address: Specifies a source address in the policy, which can an IPv6 multicast source address or the address of the RP designated to multicast groups. If you do not specify this option, all multicast traffic that matches the multicast group in the policy in the source VPN instance will be directed to the receiver VPN instance.
group ipv6-group-address: Specifies an IPv6 multicast group address in the policy. The address range is FFxy::/16 (excluding FFx1::/16 and FFx2::/16), where "x" and "y" represent any hexadecimal numbers in the range of 0 to F. If you do not this option, all multicast traffic that matches the source address in the policy in the source VPN instance will be directed to the receiver VPN instance.
prefix-length: Specifies an IPv6 address prefix length. For an IPv6 multicast group address, the value range for this argument is 8 to 128. For an IPv6 multicast source address, the value range for this argument is 0 to 128.
MVPN extranet RPF routing policies are used for multicast transmission when multicast sources and receivers are located in different VPNs.
The IPv6 PIM modes in the source VPN instance and the receiver VPN instance must be the same. Only IPv6 PIM-SM and IPv6 PIM-SSM are supported.
As a best practice, if IPv6 PIM-SM is used for MVPN extranet solution to implement inter-VPN multicast transmission for multiple IPv6 multicast groups, configure a dedicated RP for these groups. In addition, specify the address of the RP as the source address in RPF selection policies.
In IPv6 PIM-SM mode, you can configure only one RPF selection policy for a multicast group in a VPN instance.
To implement source-specific RPF selection in MVPN extranet, you must configure two MVPN extranet RPF routing policies as follows:
·     In one policy, specify the address of the RP designated to the multicast group that requires inter-VPN multicast communication as the source address.
·     In the other policy, specify the multicast source in the source VPN instance as the source address.
To implement source-and-group-specific RPF selection in MVPN extranet, you must configure two MVPN extranet RPF routing policies as follows:
·     In one policy, specify the address of the RP designated to the multicast group as the source address, and specify the multicast group.
·     In the other policy, specify the multicast source in the source VPN instance as the source address, and specify the multicast group.
·     Make sure the multicast groups in the two policies are the same to avoid inter-VPN multicast transmission failure.
If an IPv6 MVPN extranet RPF selection policy with only the multicast group address specified is configured in the receiver VPN instance, the intra-VPN multicast traffic transmission will be interrupted.
IPv6 multicast source addresses in different MVPN extranet RPF routing policies cannot be the same, but they can be overlapped with each other. The same restriction applies to the IPv6 multicast group addresses in different MVPN extranet RPF routing policies. If multiple routing policies exist for an (S, G) entry, the device selects the policy in which the IPv6 multicast group address has the longest prefix. If multiple policies have the same prefix length, the device selects the policy in which the IPv6 multicast source address has the longest prefix.
# Configure an IPv6 MVPN extranet RPF selection policy to direct multicast traffic from VPN instance vpn-source to VPN instance vpn-receiver.
[Sysname] ipv6 multicast routing vpn-instance vpn-receiver
[Sysname-mrib6-vpn-receiver] ipv6 multicast extranet select-rpf vpn-instance vpn-source source 5555::55 64
[Sysname-mrib6-vpn-receiver] ipv6 multicast extranet select-rpf vpn-instance vpn-source source 1:1:1::1 64
ipv6 multicast cpu-forwarding max-copy-count
Use ipv6 multicast cpu-forwarding max-copy-count to set the maximum number of copied IPv6 multicast packets during software forwarding.
Use undo ipv6 multicast cpu-forwarding max-copy-count to restore the default.
ipv6 multicast cpu-forwarding max-copy-count count
The maximum number of copied IPv6 multicast packets during software forwarding is 5.
count: Specifies the maximum number of copied IPv6 multicast packets during software forwarding. The value range for this argument is 1 to 36.
Setting a greater limit will cause high CPU usage and degrade forwarding performance. Setting a small limit will cause IPv6 multicast packets to be dropped.
CAUTION
CAUTION:
Perform this task under the guidance of H3C Support.
# Set the maximum number to 3 for copied IPv6 multicast packets during software forwarding.
[Sysname] ipv6 multicast cpu-forwarding max-copy-count 3
Use ipv6 multicast flow-ucmp unicast reserve-bandwidth to set the IPv6 unicast reserved bandwidth percentage on an interface.
Use undo ipv6 multicast flow-ucmp unicast reserve-bandwidth to restore the default.
ipv6 multicast flow-ucmp unicast reserve-bandwidth percentage
The IPv6 unicast reserved bandwidth percentage is not set on an interface.
Interface view
percentage: Specifies the IPv6 unicast reserved bandwidth percentage in the range of 1 to 100.
For this command to take effect, you must use the load-splitting command to configure the multicast load-splitting mode.
Example
# Set the IPv6 unicast reserved bandwidth percentage to 50% on VLAN interface 100.
[Sysname-Vlan-interface100] ipv6 multicast flow-ucmp unicast reserve-bandwidth 50
ipv6 flow-ucmp unicast reserve-bandwidth
ipv6 multicast forwarding-table cache-unknown per-entry
Use ipv6 multicast forwarding-table cache-unknown per-entry to set the maximum number of unknown IPv6 multicast packets that can be cached for an (S, G) entry.
Use undo ipv6 multicast forwarding-table cache-unknown per-entry to restore the default.
ipv6 multicast forwarding-table cache-unknown per-entry per-entry-limit
The device can cache only one unknown IPv6 multicast packet for an (S, G) entry.
per-entry-limit: Specifies the maximum number of unknown IPv6 multicast packets that can be cached for an (S, G) entry. The value range for this argument is 0 to 256. If you set the value to 0, the device cannot cache unknown IPv6 multicast packets.
# Set the maximum number to 20 for unknown IPv6 multicast packets that can be cached for an (S, G) entry.
[Sysname] ipv6 multicast forwarding-table cache-unknown per-entry 20
ipv6 multicast forwarding-table cache-unknown total
Use ipv6 multicast forwarding-table cache-unknown total to set the maximum number of all unknown IPv6 multicast packets that can be cached.
Use undo multicast forwarding-table cache-unknown total to restore the default.
ipv6 multicast forwarding-table cache-unknown total total-limit
undo ipv6 multicast forwarding-table cache-unknown total
The device can cache 1024 unknown IPv6 multicast packets in total.
total-limit: Specifies the maximum number of all unknown IPv6 multicast packets that can be cached. The value range for this argument is 0 to 65535. If you set the value to 0, the device cannot cache unknown IPv6 multicast packets.
As a best practice, set the value in this command to be far greater than the value set in the ipv6 multicast forwarding-table cache-unknown per-entry command.
# Set the maximum number to 10000 for all unknown IPv6 multicast packets that can be cached.
[Sysname] ipv6 multicast forwarding-table cache-unknown total 10000
ipv6 multicast frr mode
Use ipv6 multicast frr mode to set the IPv6 multicast FRR mode.
Use undo ipv6 multicast frr mode to restore the default.
ipv6 multicast frr mode [ by-entry | by-iif ]
The IPv6 multicast FRR mode is by-entry.
by-entry: Specifies the by-entry mode. In this mode, IPv6 multicast FRR periodically monitors IPv6 multicast traffic on primary and backup incoming interfaces by entry.
by-iif: Specifies the by-incoming interface mode. In this mode, IPv6 multicast FRR periodically monitors IPv6 multicast traffic for different (S, G) entries by pair of primary and backup incoming interfaces.
With IPv6 multicast FRR enabled, the device will add a primary incoming interface and a backup incoming interface for each (S, G) entry during entry creation. It will periodically monitor IPv6 multicast traffic on the primary and backup incoming interfaces of all entries. If no IPv6 multicast traffic is detected on the primary incoming interface, the device determines that the primary incoming interface fails and uses the backup incoming interface for IPv6 multicast forwarding.
As a best practice, set the IPv6 multicast FRR mode to by-incoming interface if the device has a large number of IPv6 multicast entries and most entries have the same primary and backup incoming interfaces.
In the current software version, only IPv6 PIM supports multicast FRR. For more information about IPv6 PIM FRR, see PIM configuration in IP Multicast Configuration Guide.
# Set the IPv6 multicast FRR mode to by-incoming interface.
[Sysname] ipv6 multicast frr mode by-iif
rpf-frr enable
ipv6 multicast frr monitor cycle
Use ipv6 multicast frr monitor cycle to set the primary/backup link monitoring interval for IPv6 multicast FRR.
Use undo ipv6 multicast frr monitor cycle to restore the default.
ipv6 multicast frr monitor cycle monitor-time
The primary/backup link monitoring interval is 200 milliseconds.
monitor-time: Specifies the primary/backup link monitoring interval in milliseconds. Valid values are 10, 20, 40, 100, 200, and 500.
Before executing this command, execute the rpf-frr enable command to enable PIM FRR.
With IPv6 multicast FRR enabled, the device will add a primary incoming interface and a backup incoming interface for each (S, G) entry during entry creation. It will periodically monitor multicast traffic on the primary and backup incoming interfaces of all entries. If no multicast traffic is detected on the primary incoming interface, the device determines that the primary incoming interface fails and uses the backup incoming interface for multicast forwarding. You can set the internal at which multicast FRR monitors the states of the primary and backup links.
As a best practice to prevent the CPU from being overloaded, set the monitoring interval to a larger value if there are many multicast entries. As a best practice to prevent the device from determining link failures mistakenly when the multicast traffic rate is small, also set the monitoring interval to a larger value if there are many multicast entries.
# Set the primary/backup link monitoring interval to 20 milliseconds.
[Sysname] ipv6 multicast frr monitor cycle 20
rpf-frr enable
ipv6 multicast frr wtr
Use ipv6 multicast frr wtr to configure traffic switchback from the backup link to the primary link for IPv6 multicast FRR.
Use undo ipv6 multicast frr wtr to restore the default.
ipv6 multicast frr wtr { wtr-time | disable }
Traffic switchback is disabled and the wait-to-restore (WTR) time is 60 seconds.
wtr-time: Specifies the wait-to-restore (WTR) time in the range of 60 to 1800 seconds.
disable: Disables traffic switchback.
To prevent multicast traffic from being switched back before the multicast entries are created for the primary link, do not set too short a wait-to-restore (WTR) time.
Multicast packets might be lost or duplicate multicast packets might exist during a traffic switchback. As a best practice, do not configure traffic switchback for multicast services requiring high reliability.
# Set the WTR time to 800 seconds.
[Sysname] ipv6 multicast frr wtr 800
rpf-frr enable
Use ipv6 multicast routing to enable IPv6 multicast routing and enter IPv6 MRIB view.
Use undo ipv6 multicast routing to disable IPv6 multicast routing.
ipv6 multicast routing [ vpn-instance vpn-instance-name ]
undo ipv6 multicast routing [ vpn-instance vpn-instance-name ]
IPv6 multicast routing is disabled.
parameters
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command enables IPv6 multicast routing on the public network.
Other Layer 3 IPv6 multicast commands take effect only when IPv6 multicast routing is enabled on the public network or for the VPN instance to which the device belongs.
The device does not forward any IPv6 multicast packets before IPv6 multicast routing is enabled.
# Enable IPv6 multicast routing on the public network, and enter IPv6 MRIB view.
[Sysname-mrib6]
# Enable IPv6 multicast routing for VPN instance mvpn, and enter IPv6 MRIB view.
[Sysname] ipv6 multicast routing vpn-instance mvpn
[Sysname-mrib6-mvpn]
Use ipv6 rpf-route-static to configure a static IPv6 multicast route.
Use undo ipv6 rpf-route-static to delete a static IPv6 multicast route.
ipv6 rpf-route-static [ vpn-instance vpn-instance-name ] ipv6-source-address prefix-length { ipv6-rpf-nbr-address | interface-type interface-number } [ preference preference ]
undo ipv6 rpf-route-static [ vpn-instance vpn-instance-name ] ipv6-source-address prefix-length { ipv6-rpf-nbr-address | interface-type interface-number }
No static IPv6 multicast routes exist.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command configures a static IPv6 multicast route on the public network.
ipv6-rpf-nbr-address: Specifies an RPF neighbor by its IPv6 address.
interface-type interface-number: Specifies an interface by its type and number. The interface connects the RPF neighbor.
preference: Sets a route preference in the range of 1 to 255. The default is 1.
If the interface connected to an RPF neighbor is not a point-to-point interface, you must specify the interface by its IP address. This type of interfaces includes Layer 3 Ethernet, Layer 3 aggregate, loopback, and VLAN interfaces.
The configured static IPv6 multicast route might not take effect when one of the following conditions exists:
·     The outgoing interface iteration fails.
·     The specified interface is not in the public network or the same VPN instance as the current interface.
·     The specified interface is not a point-to-point interface.
·     The specified interface is down.
If multiple static IPv6 multicast routes within the same IPv6 multicast source address range are available, only the one with the highest route preference can become active. You can use the display ipv6 multicast routing-table static command to verify that the configured static IPv6 multicast route has taken effect.
The undo ipv6 rpf-route-static command deletes the specified static IPv6 multicast route. To delete all static IPv6 multicast routes, use the delete ipv6 rpf-route-static command.
# Configure a static IPv6 multicast route to IPv6 multicast source 101::0/64 and specify the interface with IP address 106::7 as the RPF neighbor on the public network.
[Sysname] ipv6 rpf-route-static 101::0 64 106::7
load-splitting (IPv6 MRIB view)
Use load-splitting to enable IPv6 multicast load splitting.
Use undo load-splitting to restore the default.
load-splitting { balance-ecmp | balance-ucmp | ecmp | flow-ucmp |source | source-group | ucmp }
undo load-splitting
IPv6 multicast load splitting is disabled.
IPv6 MRIB view
balance-ecmp: Enables IPv6 multicast load balancing based on ECMP paths. Multicast traffic is evenly distributed among ECMP paths.
balance-ucmp: Enables IPv6 multicast load balancing based on links. Multicast traffic is evenly distributed among links.
ecmp: Enables IPv6 multicast load splitting based on ECMP paths.
flow-ucmp: Enables IPv6 multicast load splitting based on the bandwidth usage of multicast flows.
source: Enables IPv6 multicast load splitting based on IPv6 multicast source.
source-group: Enables IPv6 multicast load splitting based on IPv6 multicast source and group.
ucmp: Enables IPv6 multicast load splitting based on links.
To use the flow-ucmp multicast load-splitting mode, you must first configure an IPv6 multicast flow policy and the IPv6 unicast reserved bandwidth percentage. Adding, deleting, or modifying an IPv6 multicast flow policy does not affect the link selection results of existing IPv6 multicast flows and affects link selection for only new IPv6 multicast flows.
On a network with ECMP routes, specify the balance-ecmp, ecmp, flow-ucmp, source, or source-group keyword. On a network with UCMP routes, specify the balance-ucmp or ucmp keyword.
·     If you specify the ecmp keyword, adding or deleting ECMP routes severely affects IPv6 multicast forwarding.
·     If you specify the source or source-group keyword, adding or deleting ECMP routes slightly affects IPv6 multicast forwarding. Specify either of the keywords on a network with unstable equal cost links.
·     If you specify the balance-ecmp or balance-ucmp keyword, the device uses a polling mechanism for IPv6 multicast load balancing. ECMP or UCMP-based IPv6 multicast load balancing provides better stability and balance than ECMP or UCMP-based IPv6 multicast load sharing.
·     If you specify the flow-ucmp keyword, adding or deleting ECMP routes slightly affects IPv6 multicast forwarding. Specify this keyword on a network with unstable equal-cost links. It provides better stability and balance than the ucmp multicast load-sharing mode.
# Enable IPv6 multicast load splitting based on IPv6 multicast source on the public network.
[Sysname-mrib6] load-splitting source
longest-match (IPv6 MRIB view)
Use longest-match to specify the longest prefix match principle for RPF route selection.
Use undo longest-match to restore the default.
longest-match
undo longest-match
Route preference is used for RPF route selection. The route with the highest route preference is used as the RPF route.
IPv6 MRIB view
This command enables the device to use the matching route with the longest prefix as the RPF route.
# Specify the longest prefix match principle for RPF route selection on the public network.
[Sysname-mrib6] longest-match
mtrace v2 ipv6
Use mtrace v2 ipv6 to trace an IPv6 multicast path through mtrace2.
mtrace v2 ipv6 [ vpn-instance vpn-instance-name ] { source-address | group-address } * [ destination address | port number | wait-time time | max-hop count ] * [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command traces an IPv6 multicast path on the public network.
source-address: Specifies an IPv6 multicast source by its IPv6 address.
group-address: Specifies an IPv6 multicast group by its IPv6 address. The value range for this argument is FFxy::/16 (excluding FFx1::/16 and FFx2::/16), where "x" and "y" represent any hexadecimal numbers from 0 to F.
destination address: Specifies the destination address of IPv6 mtrace. The default destination address is FF02::2.
port number: Specifies a UDP port number for IPv6 mtrace, in the range of 1024 to 49151. The default value is 10240.
wait-time time: Specifies the length of time that the client waits for a Reply message. The value range for the time argument is 1 to 65535 seconds and the default value is 10 seconds. If the client does not receive a Reply message within the waiting time, the client initiates a hop-by-hop IPv6 mtrace.
max-hop count: Specifies the maximum number of the hops to be traced. The value range for the count argument is 1 to 255 and the default value is 255. If the maximum number of hops is reached on a device, the device directly sends a Reply message to the client and the mtrace is terminated.
verbose: Displays detailed information about IPv6 mtrace. If you do not specify this keyword, the command displays brief information about IPv6 mtrace.
To perform a non-group-specific mtrace, specify an IPv6 multicast source and a destination. The mtrace starts from the destination and ends at the device directly connected to the source.
To perform a non-source-specific mtrace, specify an IPv6 multicast group and a destination. The mtrace starts from the destination and ends at the RP associated with the group.
To perform a source-and-group-specific mtrace, specify both an IPv6 multicast source and an IPv6 multicast group. If you also specify a destination, the mtrace starts from the destination and ends at the device directly connected to the source. If you do not specify a destination, the mtrace starts from the upstream device of the client and ends at the device directly connected to the source.
An IPv6 mtrace process stops if the maximum number of the hops to be traced is reached.
If the client does not receive a Reply message within the waiting time, the client initiates a hop-by-hop mtrace to determine which device on the path encountered an error. It sends a Query message with the hops field set to 1 and waits for a Reply message. If the client receives a Reply message within the waiting time, it sends a Query message with the hops field value increased by 1 and waits for a Reply message. This process continues until the client does not receive a Reply message within the waiting time any more.
# Use mtrace2 to trace the path along which IPv6 multicast data of group FF1E::1 travels from source 10::7 to destination 50::5 and display brief mtrace information.
<Sysname> mtrace v2 ipv6 10::7 ff1e::1 destination 50::5
 Mtrace from 10::7 to 50::5 via group ff1e::1, 255 hops at most, press
CTRL_C to break.
 Querying full reverse path...
  Hop  Local address                       Protocol       Time    Fwd code
    0  50::1                               PIM-SM(OSPF)   50 s    NO_ERROR
   -1  40::1                               PIM-SM(OSPF)   40 s    NO_ERROR
   -2  30::1                               PIM-SM(OSPF)   60 s    NO_ERROR
   -3  20::1                               PIM-SM(OSPF)   55 s    NO_ERROR
   -4  10::1                               PIM-SM(OSPF)   30 s    NO_ERROR
Table 10 Command output
Hop
Number of the hop. 0 represents the last hop, -1 represents the hop before the last hop, and so on.
Local address
IPv6 address of this hop on the traced path.
Protocol
Multicast routing protocol used between this device and the previous-hop device:
·     PIM-SM.
·     PIM-DM.
Unicast routing protocol used between this device and the previous-hop device:
·     LOCAL—Direct route.
·     STATIC ROUTE—Static route.
·     RIP.
·     ISIS.
·     OSPF.
·     BGP.
Time
Length of time used to transmit an mtrace message between this device and the previous-hop device, in seconds.
Fwd code
Forwarding code or error code:
·     NO_ERROR—No error.
·     WRONG_IF—The interface on which the mtrace message arrives is not in the outgoing interface list of the multicast data.
·     PRUNE_SENT—This device has sent a prune message to the upstream device.
·     PRUNE_RCVD—This device has received a prune message from the downstream device.
·     SCOPED—A multicast border is configured on the incoming interface or outgoing interface of the multicast data.
·     NO_ROUTE—This device does not have any route for the source or the RP.
·     WRONG_LAST_HOP—This device is not the expected last-hop device.
·     REACHED_RP—This device is the RP for the (*, G) multicast data.
·     RPF_IF—The mtrace message arrived on the RPF interface for the multicast data.
·     NO_MULTICAST—The mtrace message arrived on an interface that is not enabled with IP multicast.
·     NO_SPACE—No space is available for inserting a response data block in the packet.
# Use mtrace2 to trace the path along which IPv6 multicast data of group FF1E::1 travels from source 10::7 to destination 50::5 and display detailed mtrace information.
<Sysname> mtrace v2 ipv6 10::7 ff1e::1 destination 50::5 verbose
 Mtrace from 10::7 to 50::5 via group ff1e::1, 255 hops at most, use query
ID 12345, client port 50001, press CTRL_C to break.
    0: Incoming interface ID: 1501
       Outgoing interface ID: 1502
       Local address: 50::1
       Remote address: FE80::A27B:99FF:FECB:207
       Input multicast packets: 111
       Output multicast packets: 111
       Forwarded packets for the (S, G) pair: 22
       Multicast protocol in use: PIM-SM
       Unicast protocol in use: OSPF
       Forwarding code: NO_ERROR
       Time used (s): 50
   -1: Incoming interface ID: 1601
       Outgoing interface ID: 1602
       Local address: 40::1
       Remote address: FE80::A27B:99FF:FECB:206
       Time used (s): 50
Table 11 Command output
n
Index of the incoming interface of the IPv6 multicast data.
Index of the outgoing interface of the IPv6 multicast data.
Local address
Remote address
IPv6 address of the upstream device.
Statistics of packets received on the incoming interface of the IPv6 multicast data.
Statistics of packets forwarded through the outgoing interface of the IPv6 multicast data.
Statistics of forwarded (S, G) packets.
Multicast routing protocol running on the incoming interface of the multicast data.
Unicast routing protocol running on the incoming interface of the multicast data.
Forwarding code
Time used (s)
Length of time for transmitting the mtrace message from the previous-hop device to this device.
Use reset ipv6 multicast fast-forwarding cache to clear IPv6 multicast fast forwarding entries.
In standalone mode:
reset ipv6 multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache { { ipv6-source-address | ipv6-group-address } * | all } [ slot slot-number ]
In IRF mode:
reset ipv6 multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache { { ipv6-source-address | ipv6-group-address } * | all } [ chassis chassis-number slot slot-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears IPv6 multicast fast forwarding entries on the public network.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears IPv6 multicast fast forwarding entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears IPv6 multicast fast forwarding entries for the global active MPU. (In IRF mode.)
all: Specifies all IPv6 multicast fast forwarding entries.
# Clear all IPv6 multicast fast forwarding entries on the public network.
<Sysname> reset ipv6 multicast fast-forwarding cache all
# Clear the IPv6 multicast fast forwarding entry for IPv6 multicast source and group (FE1F:20::2, FF0E::1) on the public network.
<Sysname> reset ipv6 multicast fast-forwarding cache fe1f:20::2 ff0e::1
Use reset ipv6 multicast forwarding event to clear statistics for IPv6 multicast forwarding events.
reset ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding event
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears statistics for the IPv6 multicast forwarding events on the public network.
# Clear statistics for the IPv6 multicast forwarding events on the public network.
<Sysname> reset ipv6 multicast forwarding event
Use reset ipv6 multicast forwarding-table to clear IPv6 multicast forwarding entries.
reset ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table { { ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface { interface-type interface-number } } * | all }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears IPv6 multicast forwarding entries on the public network.
prefix-length: Specifies the address prefix length. The default value is 128. For an IPv6 multicast group address, the value range for this argument is 8 to 128. For an IPv6 multicast source address, the value range for this argument is 0 to 128.
incoming-interface: Specifies the IPv6 multicast forwarding entries that contain the specified incoming interface.
all: Specifies all IPv6 multicast forwarding entries.
When you clear an IPv6 multicast forwarding entry, the associated IPv6 multicast routing entry is also cleared.
# Clear IPv6 multicast forwarding entries for IPv6 multicast group FF0E::1 on the public network.
<Sysname> reset ipv6 multicast forwarding-table ff0e::1
Use reset ipv6 multicast routing-table to clear IPv6 multicast routing entries.
reset ipv6 multicast [ vpn-instance vpn-instance-name ] routing-table { { ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number } * | all }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears IPv6 multicast routing entries on the public network.
incoming-interface: Specifies the IPv6 multicast routing entries that contain the specified incoming interface.
all: Specifies all IPv6 multicast routing entries.
When you clear an IPv6 multicast routing entry, the associated IPv6 multicast forwarding entry is also cleared.
# Clear IPv6 multicast routing entries for IPv6 multicast group FF03::101 on the public network.
<Sysname> reset ipv6 multicast routing-table ff03::101
