11-ACL and QoS Command Reference
HomeSupportRoutersCR16000-M1A SeriesCR16000-M1A SeriesTechnical DocumentsReference GuidesCommand ReferencesH3C CR16000-M1A Router Command Reference-R8630Pxx-6W10011-ACL and QoS Command Reference
04-HQoS commands
04-HQoS commands 205.05 KB
HQoS commands
Forwarding class commands
display qos forwarding-class
Use display qos forwarding-class to display forwarding classes.
display qos forwarding-class [ name fc-name ]
name fc-name: Specifies a forwarding class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a forwarding class, the command displays all forwarding classes.
# Display forwarding class BE.
<Sysname> display qos forwarding-class name BE
Forwarding class: BE, ID: 0
# Display all forwarding classes.
Forwarding class: AF, ID: 1
Forwarding class: EF, ID: 2
Forwarding class: NC, ID: 3
remark forwarding-class
Use remark forwarding-class to configure an action of marking a forwarding class.
Use undo remark forwarding-class to restore the default.
remark forwarding-class { id fc-id | name fc-name }
No action of marking forwarding classes is configured.
Traffic behavior view
id fc-id: Specifies a forwarding class by its ID. The value range for fc-id is 0 to 7.  Only predefined forwarding classes can be specified.
name fc-name: Specifies a forwarding class by its name. Only these predefined forwarding classes can be specified: BE, L2, AF, L1, H2, EF, H1, and NC.
If you execute this command multiple times in the same traffic behavior, the most recent configuration takes effect.
The remark forwarding-class and remark apn-id-ipv6 instance commands are mutually exclusive in the same traffic behavior.
# Mark traffic with forwarding class BE.
[Sysname] traffic behavior testtb
[Sysname-behavior-testtb] remark forwarding-class name BE
Forwarding group commands
display qos forwarding-group
Use display qos forwarding-group to display forwarding groups.
display qos forwarding-group [ name fg-name ]
name fg-name: Specifies a forwarding group by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a forwarding group, the command displays all forwarding groups.
# Display forwarding group testfg1, which has child forwarding groups.
<Sysname> display qos forwarding-group name testfg1
Forwarding group: testfg1, ID: 10
 Match: qos-local-id 1
  Forwarding group: fg2-1, ID: 3, profile: fcprofile1
# Display forwarding group testfg2, which has nested forwarding classes.
<Sysname> display qos forwarding-group name testfg2
Forwarding group: testfg2, ID: 10
 Forwarding class: BE, ID: 0, profile: fcprofile1
 Forwarding class: AF, ID: 1, profile: fcprofile2
 Forwarding class: EF, ID: 2, profile: fcprofile3
 Forwarding class: NC, ID: 3, profile: fcprofile4
forwarding-class
Use forwarding-class to nest a forwarding class in a forwarding group and specify a forwarding profile for the forwarding class.
Use undo forwarding-class to remove a nested forwarding class from a forwarding group.
forwarding-class fc-name profile fp-name
undo forwarding-class fc-name
A user-defined forwarding group does not have nested forwarding classes.
Forwarding group view
profile fp-name: Specifies a forwarding profile by its name, a case-sensitive string of 1 to 31 characters.
You cannot modify or remove the predefined forwarding classes nested in the predefined forwarding group.
The forwarding profile to be associated must already exist.
You cannot nest a forwarding class in a forwarding group with child forwarding groups nested.
# Nest forwarding class BE in forwarding group testfg and specify forwarding profile testfp for this forwarding class.
[Sysname] qos forwarding-group testfg
[Sysname-hqos-fg-testfg] forwarding-class BE profile testfp
forwarding-group (forwarding group match criterion view)
Use forwarding-group to perform the following tasks:
·     Nest a forwarding group (child) in a match criterion of another forwarding group (parent).
·     Specify a forwarding profile for the child forwarding group.
Use undo forwarding-group to remove the nested forwarding group.
forwarding-group sub-fg-name profile fp-name
undo forwarding-group sub-fg-name
A user-defined forwarding group does not have child forwarding groups.
Forwarding group match criterion view
sub-fg-name: Specifies a child forwarding group by its name, a case-sensitive string of 1 to 31 characters.
The child forwarding group and the forwarding profile to be specified must already exist.
You cannot nest a forwarding group in a forwarding group with forwarding classes nested.
A forwarding group with forwarding groups nested cannot be nested in another forwarding group.
# Configure the match criterion local QoS ID 2 for forwarding group testfg. Nest forwarding group subfg in forwarding group testfg, and specify forwarding profile testfp for forwarding group subfg.
[Sysname-hqos-fg-testfg] match qos-local-id 2
[Sysname-hqos-fg-testfg-match] forwarding-group subfg profile testfp
match
Use match to configure a match criterion for a parent forwarding group and enter forwarding group match criterion view, or enter the view of an existing match criterion.
Use undo match to delete the configured match criterion.
match match-criteria
undo match match-criteria
No match criteria exist.
match-criteria: Specifies a match criterion. Table 1 shows the available match criteria.
Table 1 Available match criteria
Option
qos-local-id local-id-list
Matches a local QoS ID.
The local-id-list argument specifies a space-separated list of up to 8 local QoS ID items. Each item specifies a local QoS ID or a range of local QoS IDs in the form of local-id1 to local-id2. The value range for local QoS IDs is 1 to 4095. The ID for local-id2 must be equal to or greater than the ID for local-id1.
Executing the match command only leads you to the forwarding group match criterion view. The configured match criterion takes effect only after a child forwarding group is configured in that view.
You cannot configure the group mode for a forwarding group with forwarding classes nested.
Removing a match criterion also removes the child forwarding group and its associated forwarding profile.
# Configure the match criterion local QoS ID 2 and enter forwarding group match criterion view.
forwarding-group profile (scheduler-policy match criterion view)
Use qos forwarding-group to create a user-defined forwarding group and enter its view, or enter the view of an existing forwarding group.
Use undo qos forwarding-group to delete a user-defined forwarding group.
qos forwarding-group fg-name
undo qos forwarding-group fg-name
No user-defined forwarding groups exist.
fg-name: Specifies a forwarding group name, a case-sensitive string of 1 to 31 characters. This argument cannot be the name of the predefined forwarding group (default).
You cannot modify or delete the predefined forwarding group default (numbered 0).
The system supports a maximum number of 8191 user-defined forwarding groups.
To delete a forwarding group nested in another forwarding group or a scheduler policy, first remove the nesting.
# Create a forwarding group named testfg.
Drop profile commands
display qos drop-profile
Use display qos drop-profile to display drop profiles.
display qos drop-profile [ name dp-name ]
name dp-name: Specifies a drop profile by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a drop profile, the command displays all drop profiles.
# Display drop profile testdp.
<Sysname> display qos drop-profile name testdp
Drop profile: testdp, ID: 10
 Green thresholds: 50/60/30(min/max/prob)
 Yellow thresholds: 50/60/30(min/max/prob)
 Red thresholds: 50/60/30(min/max/prob)
 Weighting constant: 2
Green thresholds
Drop parameters for green packets.
Yellow thresholds
Drop parameters for yellow packets.
Red thresholds
Drop parameters for red packets.
min/max/prob
Lower threshold, upper threshold, and drop probability.
When the average queue length reaches the lower threshold, newly arriving packets are randomly dropped at the drop probability
When the average queue length reaches the upper threshold, all newly arriving packets are dropped.
Weighting constant
Exponent for average queue length calculation.
green
Use green to set drop parameters for green packets.
Use undo green to restore the default.
green low-limit low-limit high-limit high-limit discard-probability discard-prob
undo green
The lower threshold is 0, the upper threshold is 512, and the drop probability 10.
Drop profile view
low-limit low-limit: Specifies the lower threshold in number of packets. When the average queue length reaches the threshold, newly arriving packets are randomly dropped. The value range for low-limit is 0 to 912000.
high-limit high-limit: Specifies the upper threshold in number of packets. When the average queue length reaches the upper threshold, all newly arriving packets are dropped. The value range for high-limit is 0 to 912000. The upper threshold must be higher than the lower threshold.
discard-probability discard-prob: Specifies the drop probability. Setting discard-prob to 100 causes tail drop to take effect. The value range for discard-prob is 0 to 100.
# Configure drop parameters for green packets.
[Sysname] qos drop-profile testdp
[Sysname-hqos-dp-testdp] green low-limit 500 high-limit 700 discard-probability 40
qos drop-profile
Use qos drop-profile to create a user-defined drop profile and enter its view, or enter the view of an existing drop profile.
Use undo qos drop-profile to delete a user-defined drop profile.
qos drop-profile dp-name
undo qos drop-profile dp-name
No user-defined drop profiles exist.
dp-name: Specifies a drop profile name, a case-sensitive string of 1 to 31 characters. This argument cannot be the name of the predefined drop profile (default).
You cannot modify or delete the predefined drop profile default (numbered 0).
To delete a drop profile referenced by a forwarding profile, first remove the drop profile from the forwarding profile.
# Create a drop profile named testdp.
[Sysname-dp-testdp]
red
Use red to configure drop parameters for red packets.
Use undo red to restore the default.
red low-limit low-limit high-limit high-limit discard-probability discard-prob
undo red
Drop profile view
low-limit low-limit: Specifies the lower threshold in number of packets. When the average queue length reaches the lower threshold, newly arriving packets are randomly dropped. The value range for low-limit is 0 to 912000.
# Configure drop parameters for red packets.
[Sysname-hqos-dp-testdp] red low-limit 500 high-limit 700 discard-probability 40
weighting-constant
Use weighting-constant to set the exponent for average queue length calculation.
Use undo weighting-constant to restore the default.
weighting-constant exponent
The exponent for average queue length calculation is 8.
Drop profile view
exponent: Specifies the exponent for average queue length calculation. The value range for this argument is 1 to 16.
The greater the exponent, the less sensitive the average queue length is to real-time queue length changes.
# Set the exponent for average queue length calculation to 2.
[Sysname-hqos-dp-testdp] weighting-constant 2
yellow
Use yellow to configure drop parameters for yellow packets.
Use undo yellow to restore the default.
yellow low-limit low-limit high-limit high-limit discard-probability discard-prob
undo yellow
Drop profile view
high-limit high-limit: Specifies the upper threshold in number of packets. When the average queue length reaches the upper threshold, all newly-arriving packets are dropped. The value range for high-limit is 0 to 912000. The upper threshold must be higher than the lower threshold.
# Configure drop parameters for yellow packets.
[Sysname-hqos-dp-testdp] yellow low-limit 500 high-limit 700 discard-probability 40
Forwarding profile commands
bandwidth
Use bandwidth to set the minimum guaranteed bandwidth for a forwarding profile.
bandwidth bandwidth-value
undo bandwidth
No minimum guaranteed bandwidth is set in a forwarding profile.
Forwarding profile view
bandwidth-value: Specifies the minimum guaranteed bandwidth in kbps. The value range for this argument is 8 to 300000000.
# Set the minimum guaranteed bandwidth to 2000 kbps for forwarding profile testfp.
[Sysname] qos forwarding-profile testfp
[Sysname-hqos-fp-testfp] bandwidth 2000
display qos forwarding-profile
Use display qos forwarding-profile to display forwarding profiles.
display qos forwarding-profile [ name fp-name ]
name fp-name: Specifies a forwarding profile by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a forwarding profile, the command displays all forwarding profiles.
# Display forwarding profile testfp.
<Sysname> display qos forwarding-profile name testfp
Forwarding profile: testfp, ID: 10
 GTS: CIR 100(kbps), CBS 50(Bytes), PIR 150(kbps)
 Bandwidth: 1000(kbps)
 Drop profile: default
Bandwidth
Minimum guaranteed bandwidth.
drop-profile
Use drop-profile to use a drop profile in a forwarding profile.
Use undo drop-profile to restore the default.
undo drop-profile
A forwarding profile does not use any drop profile and uses tail drop.
dp-name: Specifies an existing drop profile by its name, a case-sensitive string of 1 to 31 characters.
# Use drop profile testdp in forwarding profile testfp.
[Sysname-hqos-fp-testfp] drop-profile testfp
gts
Use gts to configure GTS parameters for a forwarding profile.
Use undo gts to restore the default.
gts cir cir-value [ cbs cbs-value ] [ pir pir-value ]
undo gts
No GTS configuration exists in a forwarding profile.
cir-value: Specifies the CIR in kbps. The value range for cir-value is 300 to 300000000.
cbs cbs-value: Specifies the CBS in the range of 4096 to 16000000 bytes.
pir pir-value: Specifies the PIR in the range of 300 to 300000000 kbps. If the PIR is not configured, only one rate is used for traffic policing.
# Configure GTS parameters for forwarding profile testfp.
[Sysname-hqos-fp-testfp] gts cir 1000 cbs 1000 pir 2000
Use qos forwarding-profile to create a user-defined forwarding profile and enter its view, or enter the view of an existing forwarding profile.
Use undo qos forwarding-profile to delete a user-defined forwarding profile.
qos forwarding-profile fp-name
undo qos forwarding-profile fp-name
No user-defined forwarding profiles exist.
fp-name: Specifies a forwarding profile name, a case-sensitive string of 1 to 31 characters. This argument cannot be the name of the predefined forwarding profile (default).
You cannot modify or delete the predefined forwarding profile default.
# Create a forwarding profile named testfp.
sp
Use sp to enable SP queuing for a forwarding profile.
Use undo sp to restore the default.
sp
undo sp
No SP queuing configuration exists in a forwarding profile.
# Enable SP queuing for forwarding profile testfp.
[Sysname-hqos-fp-testfp] sp
wfq
Use wfq to configure WFQ queuing for a forwarding profile.
Use undo wfq to restore the default.
wfq [ weight weight-value ]
undo wfq
No WFQ queuing configuration exists in a forwarding profile.
weight weight-value: Specifies the scheduling weight in the range of 1 to 63. The default is 1.
WFQ queues with the same priority are scheduled according to their weights. The weight of a WFQ queue determines the percentage of bandwidth assigned to the queue.
# Configure WFQ queuing for forwarding profile testfp.
[Sysname-hqos-fp-testfp] wfq weight 2
Scheduler policy commands
display qos scheduler-policy
Use display qos scheduler-policy to display scheduler policies.
display qos scheduler-policy [ name sp-name ]
name sp-name: Specifies a scheduler policy by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a scheduler policy, the command displays all scheduler policies.
# Display scheduler policy test_sp.
<Sysname> display qos scheduler-policy name test_sp
SP -- Scheduler policy      FG -- Forwarding group     FC -- Forwarding class
FP -- Forwarding profile    L  -- Layer
SP: test_sp (0)
 |  Scheduler unit: byte-count
 |  Match: group
 +--FG(L1): default(0)
 |   |      FP: default(0)
 |   +--FC: BE(0)
 |   |      FP: default(0)
 |   +--FC: L2(1)
 |   |      FP: default(0)
 |   +--FC: AF(2)
 |   |      FP: default(0)
 |   +--FC: L1(3)
 |   |      FP: default(0)
 |   +--FC: H2(4)
 |   |      FP: default(0)
 |   +--FC: EF(5)
 |   |      FP: default(0)
 |   +--FC: H1(6)
 |   |      FP: default(0)
 |   +--FC: NC(7)
 |          FP: default(0)
 |  Match: group
 +--FG(L1): fg1-1(101)
 |   |      FP: fp1-1(10)
 |   |  Match: qos-local-id 2 to 10
 |   +--FG(L2): fg2-1(1)
 |   |   |      FP: fp2(9)
 |   |   +--FC: BE(0)
 |   |   |      FP: fp3-0(1)
 |   |   +--FC: L2(1)
 |   |   |      FP: fp3-1(2)
 |   |   +--FC: AF(2)
 |   |   |      FP: fp3-2(3)
 |   |   +--FC: L1(3)
 |   |   |      FP: fp3-3(4)
 |   |   +--FC: H2(4)
 |   |   |      FP: fp3-4(5)
 |   |   +--FC: EF(5)
 |   |   |      FP: fp3-5(6)
 |   |   +--FC: H1(6)
 |   |   |      FP: fp3-6(7)
 |   |   +--FC: NC(7)
 |   |          FP: fp3-7(8)
 |   |  Match: qos-local-id 11 to 20
 |   +--FG(L2): fg2-2(2)
 |       |      FP: fp2(9)
 |       +--FC: BE(0)
 |       |      FP: fp3-0(1)
 |       +--FC: L2(1)
 |       |      FP: fp3-1(2)
 |       +--FC: AF(2)
 |       |      FP: fp3-2(3)
 |       +--FC: L1(3)
 |       |      FP: fp3-3(4)
 |       +--FC: H2(4)
 |       |      FP: fp3-4(5)
 |       +--FC: EF(5)
 |       |      FP: fp3-5(6)
 |       +--FC: H1(6)
 |       |      FP: fp3-6(7)
 |       +--FC: NC(7)
 |              FP: fp3-7(8)
 |  Match: qos-local-id 21 to 30
 +--FG(L1): fg1-2(102)
     |      FP: fp1-2(11)
     +--FG(L2): fg2-3(3)
         |      FP: fp2(9)
         +--FC: BE(0)
         |      FP: fp3-0(1)
         +--FC: L2(1)
         |      FP: fp3-1(2)
         +--FC: AF(2)
         |      FP: fp3-2(3)
         +--FC: L1(3)
         |      FP: fp3-3(4)
         +--FC: H2(4)
         |      FP: fp3-4(5)
         +--FC: EF(5)
         |      FP: fp3-5(6)
         +--FC: H1(6)
         |      FP: fp3-6(7)
         +--FC: NC(7)
                FP: fp3-7(8)
match
The match mode is used for configuring match criteria.
group
The group mode is used for configuring match criteria.
Number in the brackets
ID of the field (forwarding class/forwarding group/forwarding profile/scheduler policy).
display qos scheduler-policy diagnosis interface
Use display qos scheduler-policy diagnosis interface to display diagnosis information about scheduler policies applied to interfaces.
In standalone mode:
display qos scheduler-policy diagnosis interface [ interface-type interface-number ] [ outbound ]
outbound: Specifies scheduler policies applied to the outbound direction.
If you do not specify an interface, the command displays diagnosis information about scheduler policies applied to all interfaces.
# Display diagnosis information about the scheduler policy applied to the outbound direction of  Ten-GigabitEthernet 0/0/15.
<Sysname> display qos scheduler-policy diagnosis interface ten-gigabitethernet 0/0/15 outbound
Interface: Ten-GigabitEthernet0/0/15
Direction: Outbound
SP: 1(0)
 |  Match: group
 |   |      FP: default(0)
 |   |      Status: Success
 |   +--FC: BE(0)
 |   |      FP: default(0)
 |   |      Status: Success
 |   +--FC: L2(1)
 |   |      FP: default(0)
 |   |      Status: Success
 |   +--FC: AF(2)
 |   |      FP: default(0)
 |   |      Status: Success
 |   +--FC: L1(3)
 |   |      FP: default(0)
 |   |      Status: Success
 |   +--FC: H2(4)
 |   |      FP: default(0)
 |   |      Status: Success
 |   +--FC: EF(5)
 |   |      FP: default(0)
 |   |      Status: Success
 |   +--FC: H1(6)
 |   |      FP: default(0)
 |   |      Status: Success
 |   +--FC: NC(7)
 |          FP: default(0)
 |          Status: Success
 |  Match: group
 |   |      FP: fp1-1(10)
 |   |      Status: Success
 |   |   |      FP: fp2(9)
 |   |   |      Status: Success
 |   |   +--FC: BE(0)
 |   |   |      FP: fp3-0(1)
 |   |   +--FC: L2(1)
 |   |   |      FP: fp3-1(2)
 |   |   +--FC: AF(2)
 |   |   |      FP: fp3-2(3)
 |   |   +--FC: L1(3)
 |   |   |      FP: fp3-3(4)
 |   |   +--FC: H2(4)
 |   |   |      FP: fp3-4(5)
 |   |   +--FC: EF(5)
 |   |   |      FP: fp3-5(6)
 |   |   +--FC: H1(6)
 |   |   |      FP: fp3-6(7)
 |   |   +--FC: NC(7)
 |   |          FP: fp3-7(8)
 |   |          Status: Success
 |       |      FP: fp2(9)
 |       |      Status: Success
 |       +--FC: BE(0)
 |       |      FP: fp3-0(1)
 |       |      Status: Success
 |       +--FC: L2(1)
 |       |      FP: fp3-1(2)
 |       |      Status: Success
 |       +--FC: AF(2)
 |       |      FP: fp3-2(3)
 |       |      Status: Success
 |       +--FC: L1(3)
 |       |      FP: fp3-3(4)
 |       |      Status: Success
 |       +--FC: H2(4)
 |       |      FP: fp3-4(5)
 |       |      Status: Success
 |       +--FC: EF(5)
 |       |      FP: fp3-5(6)
 |       |      Status: Success
 |       +--FC: H1(6)
 |       |      FP: fp3-6(7)
 |       |      Status: Success
 |       +--FC: NC(7)
 |              FP: fp3-7(8)
 |              Status: Success
     |      FP: fp1-2(11)
     |      Status: Success
     +--FG(L2): fg2-3(3)
         |      FP: fp2(9)
         |      Status: Success
         +--FC: BE(0)
         |      FP: fp3-0(1)
         |      Status: Success
         +--FC: L2(1)
         |      FP: fp3-1(2)
         |      Status: Success
         +--FC: AF(2)
         |      FP: fp3-2(3)
         |      Status: Success
         +--FC: L1(3)
         |      FP: fp3-3(4)
         |      Status: Success
         +--FC: H2(4)
         |      FP: fp3-4(5)
         |      Status: Success
         +--FC: EF(5)
         |      FP: fp3-5(6)
         |      Status: Success
         +--FC: H1(6)
         |      FP: fp3-6(7)
         |      Status: Success
         +--FC: NC(7)
                FP: fp3-7(8)
                Status: Success
Table 5 Command output
Status
Issuing status of a forwarding profile:
·     Incomplete—Incomplete match criteria.
·     Success—All contents have been issued successfully.
·     Inactive—A forwarding profile does not take effect.
·     If a forwarding profile has failed to be issued completely, the following possible reasons are displayed:
¡     Insufficient resources.
¡     Conflicting match rule.
¡     Not support.
¡     GTS Failed—The GTS parameters failed to be issued to a forwarding class or forwarding group.
¡     WRED Failed—The WRED parameters failed to be issued to a forwarding class or forwarding group.
¡     Queue Failed—The queuing algorithm failed to be issued to a forwarding class or forwarding group.
¡     Bandwidth Failed—The minimum guaranteed bandwidth failed to be issued to a forwarding class or forwarding group.
display qos scheduler-policy interface
Use display qos scheduler-policy interface to display the statistics and configuration for scheduler policies applied to interfaces.
display qos scheduler-policy interface [ interface-type interface-number ] [ outbound ]
If you do not specify an interface, the command displays the statistics and configuration for scheduler policies applied to all interfaces.
If per-queue traffic accounting is disabled on an interface, the command displays only the configuration for scheduler policies.
# Display the configuration and statistics for the scheduler policy applied to the outbound direction of Ten-GigabitEthernet 0/0/15.
<Sysname> display qos scheduler-policy interface ten-gigabitethernet 0/0/15 outbound
Direction: Outbound
SP: sp(0)
 |  Match: group
     |      FP: default(0)
     |      Forwarded: 0 packets, 0 bytes
     |      Forwarded green: 0 packets, 0 bytes
     |      Forwarded yellow: 0 packets, 0 bytes
     |      Forwarded red: 0 packets, 0 bytes
     |      Dropped: 0 packets, 0 bytes
     |      Dropped green: 0 packets, 0 bytes
     |      Dropped yellow: 0 packets, 0 bytes
     |      Dropped red: 0 packets, 0 bytes
     +--FC: BE(0)
     |      FP: default(0)
     |      Current queue length: 0 packets
     +--FC: L2(1)
     |      FP: default(0)
     +--FC: AF(2)
     |      FP: default(0)
     +--FC: L1(3)
     |      FP: default(0)
     +--FC: H2(4)
     |      FP: default(0)
     +--FC: EF(5)
     |      FP: default(0)
     +--FC: H1(6)
     |      FP: default(0)
     +--FC: NC(7)
            FP: default(0)
Table 6 Command output
Forwarded green
Number of forwarded green packets/bytes.
Forwarded yellow
Number of forwarded yellow packets/bytes.
Forwarded red
Number of forwarded red packets/bytes.
Dropped
Number of dropped packets/bytes.
Tail dropped
Number of tail-dropped packets/bytes.
Dropped green
Number of dropped green packets/bytes.
Dropped yellow
Number of dropped yellow packets/bytes.
Dropped red
Number of dropped red packets/bytes.
Use forwarding-group profile to nest a forwarding group in a match criterion of a scheduler policy and specify a forwarding profile for the forwarding group.
Use undo forwarding-group to remove the nested forwarding group from a match criterion of a scheduler policy.
forwarding-group fg-name profile fp-name
undo forwarding-group fg-name
The predefined forwarding group is nested in a scheduler policy in group mode.
Scheduler policy match criterion view
The forwarding group to be nested in a scheduler policy and the forwarding profile to be specified for the forwarding group must already exist.
You cannot remove the predefined forwarding group automatically nested in a scheduler policy.
# Configure the match criterion local QoS ID 1 for scheduler policy testsp. Nest forwarding group testfg in scheduler policy testsp, and specify the forwarding profile testfp for forwarding group testfg.
[Sysname] qos scheduler-policy testsp
[Sysname-hqos-sp-testsp] match qos-local-id 1
[Sysname-hqos-sp-testsp-match] forwarding-group testfg profile testfp
match
match
Use match to configure a match criterion for a scheduler policy and enter its view, or enter the view of an existing scheduler policy match criterion.
Use undo match to delete the configured match criteria.
match { match-criteria | group }
undo match { match-criteria | group }
A user-defined scheduler policy has no match criteria.
Scheduler policy view
match-criteria: Specifies a match criterion. match shows the available match criteria.
Table 7 Available match criteria
Option
group: Specifies that a Layer 1 forwarding group uses the union of the match criteria of its Layer 2 forwarding groups.
Executing the match command only leads you to the scheduler policy match criterion view. The configured match criterion takes effect only after a child forwarding group is configured in that view.
Removing a match criterion for a scheduler policy also removes the nested forwarding groups and their associated forwarding profiles for the scheduler policy.
A forwarding group with nested forwarding classes cannot uses the group mode. The predefined forwarding group nested in a scheduler policy has used the group mode by default. You cannot modify or remove the match criteria of the predefined forwarding group.
# Configure the match criterion local QoS IDs 1 to 4 for scheduler policy testsp.
[Sysname-hqos-sp-testsp] match qos-local-id 1 to 4
qos apply scheduler-policy
Use qos apply scheduler-policy to apply a scheduler policy to an interface.
Use undo qos apply scheduler-policy to remove a scheduler policy from an interface.
qos apply scheduler-policy sp-name outbound
undo qos apply scheduler-policy sp-name outbound
No scheduler policy is applied to an interface.
Interface view
outbound: Applies a scheduler policy to the outbound direction of an interface.
Only one scheduler policy can be applied to an interface.
Regardless of the direction, the scheduler policy applied to an interface is mutually exclusive with the following QoS features configured on the interface:
·     Queue-based GTS.
·     Interface WRED.
·     Hardware queue scheduling.
# Apply scheduler policy testsp to the outbound direction of Ten-GigabitEthernet 0/0/15.
[Sysname] interface ten-gigabitethernet 0/0/15
[Sysname-Ten-GigabitEthernet0/0/15] qos apply scheduler-policy testsp outbound
Use qos scheduler-policy to create a user-defined scheduler policy and enter its view, or enter the view of an existing scheduler policy.
Use undo qos scheduler-policy to delete a user-defined scheduler policy.
qos scheduler-policy sp-name
undo qos scheduler-policy sp-name
No user-defined scheduler policies exist.
sp-name: Specifies a scheduler policy name, a case-sensitive string of 1 to 31 characters.
The system supports a maximum number of 256 user-defined scheduler policies.
# Create a scheduler policy named testsp.
scheduler-unit
Use scheduler-unit to specify the scheduling unit for a scheduler policy.
Use undo scheduler-unit to restore the default.
qos scheduler-unit { byte-count | weight }
undo scheduler-unit
The scheduling unit for a scheduler policy is byte-count.
byte-count: Allocates bandwidth based on the number of bytes.
weight: Allocates bandwidth based on the number of packets.
# Set the scheduling unit to byte-count for scheduler policy named testsp.
[Sysname-hqos-sp-testsp] scheduler-unit byte-count
