H3C SecCenter SMP
Release time:2026-01-04
HomeSupportSecurityH3C SecCenter SMPSoftware DownloadSecCenter SMP
H3C SecCenterSMP-E1704P06 Release Notes
Introduction· 1
Version information· 1
Version number 1
Version history· 1
Hardware and software compatibility matrix· 1
Upgrade restrictions and guidelines· 2
Hardware feature updates· 2
Software feature updates· 2
Software feature updates in SecCenterSMP-E1704P07· 2
MIB updates· 2
Operation changes· 2
Restrictions and cautions· 2
Licensing· 3
About licensing· 3
Registering and installing licenses· 3
Open problems and workarounds· 3
List of resolved problems· 4
Resolved problems in SecCenterSMP-E1704P07· 4
Resolved problems in SecCenterSMP-E1704P06· 4
Resolved problems in SecCenterSMP-E1704P05· 5
Troubleshooting resources· 5
Related documentation· 6
Documentation set 6
Obtaining documentation· 6
Technical support 6
Appendix A Feature list 7
Hardware features· 7
Software features· 7
Appendix B Upgrading software· 9
List of tables
Table 1 Compatibility matrix. 1
Table 2 Software features of SMP. 7
Introduction
This document describes the features, restrictions and guidelines, open problems, and workarounds for version SecCenterSMP-E1704P07. Before you use this version on a live network, back up the configuration and test the version to avoid software upgrade affecting your live network.
Use this document in conjunction with the documents listed in Related documentation.
Version information
Version number
Version history
Version number
Last version
Release date
Release type
Remarks
2025/12/30
ESS
Fixed bugs.
2025/11/26
ESS
Fixed bugs.
SecCenterSMP-E1704P04
2024/09/29
ESS
Fixed bugs.
CAUTION:
To avoid an upgrade failure, use the following to verify the hardware and software compatibility before performing an upgrade.
Item
H3C SecCenterSMP series
Model
SecCenterSMP
Installation file
SecCenterSMP_E1704P07.iso (package for virtualized deployment)
SecCenterSMP_E1704P07.tar.gz(package for upgrad)
Server version
H3Linux 1.1.1
Installation host OS
N/A
Browsers
Google Chrome 57 or higher
Ucenter
E0713
Ucenter-IOM E0711
Remarks
N/A
Only E1704P05、E1704P06 can be upgraded to E1704P07.
SMP is a software product and contains no hardware features.
Add features
·            Compatible device syslog.
·            Device System/Interface Traffic Monitoring and Export.
Modified features
None
Removed features
None.
MIB updates
N/A
Operation changes
N/A
For browsers
To get better display, use browsers Google Chrome 57 or higher.
For the operating system
Set the time zone in the operating system to Shanghai East 8 district.
For device version compatibility
·            Compatible device versions are D032 and D045.
·            Configure the device to use the local time in the log timestamp. If you configure the device to use the standard GMT, the log timestamp displayed on the SMP will be different from that on the device.
·            The system supports receiving a maximum of 10000 log messages per second from devices. Exceeding logs will be dropped.
Licensing
About licensing
H3C offers licensing options for you to deploy features and expand resource capacity on an as needed basis. To use license-based features, purchase licenses from H3C and install the licenses.
To register and transfer licenses, access H3C license services at http://www.h3c.com/en/License.
For information about registering licenses, installing activation files, and transferring licenses, see H3C SecCenter SMP Licensing Guide-5W100.
202206281627
·            Symptom: The device cannot be upgraded from the Web interface.
·            Condition: None.
·            Workaround: None. Contact Technical Support for help.
202204220794
·            Symptom: The System Settings > Logging page and the Log Audit pages contain Chinese.
·            Condition: This symptom occurs when you generate logs in the Chinese version and switch from the Chinese language to the English language.
·            Workaround: None. This issue does not affect the functionality of the feature and will be fixed in a later version
202508070314
·            Symptom: Monitored Asset > Service Settings> Intrusion Prevention Deletion Error
·            Condition: Concurrent synchronous operations.
·            Workaround: During concurrent operations, there is a delay in policy deletion.  If an error occurs, wait 30 seconds and refresh the page. The policy will be properly deleted and will not affect usage.
202512151142
·            Symptom: Log module adds device syslog
·            Condition: None.
202512151169
·            Symptom: Device Monitoring Details Page> System Traffic Measurement and Interface Details Module> Add Export CSV Function
·            Condition: None.
202512151206
·            Symptom: Add the "Device Fault Alarm" functional module
·            Condition: None.
202511190078
·            Symptom: Mail Server Configuration - SMTP should be able to send emails without configuring a password (password entry changed to optional).
·            Condition: None.
202511190037
·            Symptom: SMP overseas version regional configuration request supports overseas countries, prioritizing Kazakhstan.
·            Condition: None.
202508070434
·            Symptom: Global Security Business Configuration - Anti-Virus Policy - New Policy Page Action Configuration Option Error  Global Security Service Configuration -- IP Address Management -- IP Address Group -- Edit Exception
·            Condition: add new Anti-Virus Policy .
202508070425
·            Symptom: Global Security Service Configuration -- IP Address Management -- IP Address Group -- Edit Exception
·            Condition: None .
202508070340
·            Symptom: Error when referencing users and user groups while adding or editing security policies.
·            Condition: None .
202508070305
·            Symptom: Static route, deletion exception
·            Condition: None .
202505290133
·            Symptom: Radius authentication logic optimization; login to the platform is not allowed after authentication fails.
·            Condition: None .
202508070262
·            Symptom: When adding a virtual device, selecting a parameter template from the dropdown fails to load the pre-configured parameter template.
·            Condition: None .
202403010314
·            Symptom: In the security policy list page, some column names are in Chinese:
·            Condition: None.
202409190744
·            Symptom: Add IPS comprehensive report:
·            Condition: None.
To obtain troubleshooting resources for the product:
1.      Access Technical Documents at http://www.h3c.com/en/Technical_Documents.
2.      Select the device category and model.
3.      Select the Maintain or Maintenance menu.
Documentation set
·            H3C SecCenter SMP Web Configuration Guides(E1704)-5W100
·            H3C SecCenter SMP Configuration Examples (E1704)-5W100
·            H3C SecCenter SMP FAQ(E1704)-5W100
·            H3C SecCenter SMP Troubleshooting Guide(E1704)-5W100
To obtain related documents from the H3C website at
https://www.h3c.com/en/Support/Resource_Center/Technical_Documents/
Technical support
To obtain technical assistance, contact H3C by using one of the following methods:
·            Email:
h3cts@h3c.com (countries and regions except Hong Kong, China)
service_hk@h3c.com (Hong Kong, China)
·            Technical support hotline number. To obtain your local technical support hotline number, go to the H3C Service Hotlines website: https://www.h3c.com/en/Support/Online_Help/Service_Hotlines/
To access documentation, go to the H3C website at http://www.h3c.com/en/.
Hardware features
Software features
Categories
Features
Dashboard
CPU Usage
Memory Usage
Session Trend
IPS Attack Destination IPs
IPS Attack Source and Destination IPs
IPS Blocked Events
Attack Trend Chart
Device Log Receiving Trend Chart
Alarm Events
Alarm Events
Alarm Rules
Alarm Notification Policies
Alarm Notification Records
Log Audit
Vulnerability Attack Log
Virus Attack Log
NAT Session Log
NAT444 Port Block Log
NAT444 Session Log
Application Audit Logs
Security Analysis
Security Event Analysis
Reports
Report Files
Report Tasks
Report Templates
O&M
Areas
Device Groups
Monitored Assets
Security Services
Signature Libraries
System Settings
Global Settings
System Monitoring
Roles & Privileges
Logging
Customization
System Info
Licenses
Hierarchy
For how to perform an upgrade, contact Technical Support.
