H3C S9820-64H Switch Hardware Information and Specifications-6W102
HomeSupportSwitchesS9820 SeriesProduct LiteratureHardware Information & SpecificationsH3C S9820-64H Switch Hardware Information and Specifications-6W102
01-Hardware Information and Specifications
01-Hardware Information and Specifications 1.01 MB
1 Product model and technical specifications
Product model
The H3C S9820-64H switch is a high-density intelligent 100G switch developed for data center and high-end campus networks, providing powerful hardware forwarding capacity and abundant data center features.
The switch provides the following ports and removable components:
·     100G QSFP28 ports.
·     Two 1G management Ethernet ports (one fiber port and one copper port).
·     Removable fan trays in redundancy mode. By using different fan trays, you can change the airflow direction of the chassis to adapt to ventilation needs.
·     Removable power supplies in redundancy mode.
The S9820-64H switch model is available with multiple product codes. To identify the product code of your switch, use the product barcode on its rear panel. The S9820-64H switch model is available with the LS-9820-64H or LS-9820-64H-H1 product code. If the switch is referred to as the S9820-64H switch, the information applies to the S9820-64H switch with either of the codes. If the switch is referred to as the S9820-64H (LS-9820-64H) or LS-9820-64H switch, the information applies only to the S9820-64H switch with the LS-9820-64H product code.
Technical specifications
Table1-1 Technical specifications
Item
S9820-64H
Product code
·     LS-9820-64H
·     LS-9820-64H-H1
Dimensions (H × W × D)
88.1 × 440 × 540 mm (3.47 × 17.32 × 21.26 in)
Weight
≤ 27 kg (59.52 lb) (including three fan trays and four power supplies, excluding transceiver modules and cables)
Console port
·     1 × mini USB console port
·     1 × serial console port
Management Ethernet port
·     1 × 10/100/1000BASE-T copper port
·     1 × SFP port
USB port
1
QSFP28 port
64
Fan tray slot
3
Power supply slot
4
Minimum power consumption
(For the power consumption data collection standard, see Table1-2)
·     Dual AC inputs: 336 W
·     Triple AC inputs: 349 W
·     Quadruple AC inputs: 365 W
·     Dual DC inputs: 329 W
·     Triple DC inputs: 338 W
·     Quadruple DC inputs: 352 W
Typical power consumption
·     Dual AC inputs: 519 W
·     Triple AC inputs: 523 W
·     Quadruple AC inputs: 537 W
·     Dual DC inputs: 508 W
·     Triple DC inputs: 511 W
·     Quadruple DC inputs: 521 W
Maximum power consumption
·     Dual AC inputs: 935 W
·     Triple AC inputs: 934 W
·     Quadruple AC inputs: 948 W
·     Dual DC inputs: 906 W
·     Triple DC inputs: 904 W
·     Quadruple DC inputs: 914 W
Chassis leakage current compliance
·     UL60950-1
·     EN60950-1
·     IEC60950-1
·     GB4943.1
Operating altitude
–60 m to +5000 m (–196.85 ft to +16404.20 ft)
Operating temperature
0°C to 45°C (32°F to 113°F)
Note:
The allowed maximum temperature decreases by 0.33 °C (32.59°F) as the altitude increases by 100 m (328.08 ft) from 0 m (0 ft).
Operating humidity
5% to 95%, noncondensing
Storage altitude
Storage temperature
–40°C to +70°C (–40°F to +158°F)
Storage humidity
5% RH to 95% RH, noncondensing
Fire resistance compliance
·     UL60950-1
·     EN60950-1
·     IEC60950-1
·     GB4943.1
Table1-2 Power consumption data collection standard
Item
Configuration
·     Two power supplies
·     No transceiver modules/cables installed in ports
·     Fully configured with copper cables
·     Fully configured with transceiver modules
Load
N/A
50% load
100% load
2 Chassis views
Figure2-1 S9820-64H front panel
(1) QSFP28 port
(2) QSFP28 port LED
Figure2-2 S9820-64H rear panel
(1) Serial console port
(2) Mini USB console port
(3) USB port
(4) System status LED (SYS)
(5) Fan tray 1
(6) Fan tray 2
(7) Fan tray 3
(8) Power supply 1
(9) Power supply 3
(10) Power supply 4
(11) Power supply 2
(12) Fiber management Ethernet port LED (LINK/ACT)
(13) Copper management Ethernet port LED (LINK/ACT)
(14) Copper management Ethernet port (numbered 0)
(15) Fiber management Ethernet port (numbered 1)
The switch came with power supply slots PWR2 and PWR4 empty and power supply slots PWR1 and PWR3 installed with filler panels. You can install two to four power supplies for the switch as needed. In Figure2-2, LSVM1AC650 AC power supplies are installed in the four power supplies slots.
The switch came with the three fan tray slots empty. You must install three fan trays of the same model for the switch. In Figure2-2, LSWM1BFANSC fan trays are installed in the three fan tray slots.
The switch supports shipping with fan trays and power supplies installed. To purchase a switch preinstalled with fans trays and power supplies, contact marketing staff.
Figure2-3 S9820-64H left panel
(1) Primary grounding point
(2) Auxiliary grounding point
3 Removable components
The switch uses removable power supplies and fan trays. Table3-1 describes the removable components available for the switch.
Table3-1 Removable components available for the switch
Part No.
S9820-64H
Power supplies
LSVM1AC650
0231A0QM
Yes
LSVM1DC650
0231A0QP
Yes
Fan trays
LSWM1BFANSC
0231A2Y7
Yes
LSWM1BFANSC-SN
0231AG9G
Yes, in Release 6616 and later Release versions. For the support of ESS and Feature versions, contact H3C Support.
LSWM1BFANSCB
0231A2Y6
Yes
LSWM1BFANSCB-SN
0231AG9K
The system can read electronic label information from the LSWM1BFANSC-SN and LSWM1BFANSCB-SN fan trays.
Power supplies
WARNING
WARNING!
When the switch has power supplies in redundancy, you can replace a power supply without powering off the switch. To avoid device damage and personal injury, make sure the power supply is powered off before you replace it.
The switch can operate correctly with two power supplies. You can install three or four power supplies on the switch for 2+1 or 2+2 redundancy, respectively.
You can install both LSVM1AC650 and LSVM1DC650 power supplies on the switch.
Table3-2 Power supply specifications
Power supply model
Specifications
Remarks
LSVM1AC650
·     Rated AC input voltage: 100 VAC to 240 VAC @ 50 Hz or 60 Hz
·     Max AC input voltage: 90 VAC to 264 VAC @ 47 Hz to 63 Hz
·     Rated HVDC input voltage: 240 VDC
·     Max HVDC input voltage: 190 VDC to 290 VDC
·     Max output power: 650 W
·     Melting current of power supply fuse: 10 A, 250 V
For more information about the power supplies, see H3C LSVM1AC650 & LSVM1DC650 Power Modules User Manual.
LSVM1DC650
·     Rated input voltage: –40 VDC to –60 VDC
·     Max input voltage: –40 VDC to –72 VDC
·     Melting current of power supply fuse: 30 A, 250 V
Fan trays
CAUTION
CAUTION:
For adequate heat dissipation, you must install three fan trays of the same model for the switch.
Table3-3 Fan tray specifications
Fan tray model
Item
Specifications
·     LSWM1BFANSC/LSWM1BFANSC-SN (air intake on fan tray panel)
·     LSWM1BFANSCB/LSWM1BFANSCB-SN (air exhaust on fan tray panel)
Dimensions (including the fan tray handle)
80 × 80 × 232.6 mm (3.15 × 3.15 × 9.16 in)
Fan speed
13300 R.P.M
Max airflow
120 CFM (3.40 m3/min)
57 W
Documentation reference
H3C LSWM1BFANSC & LSWM1BFANSCB Fan Trays User Guide
H3C LSWM1BFANSC-SN & LSWM1BFANSCB-SN Fan Trays User Guide
4 Ports and LEDs
As a best practice, use H3C transceiver modules and cables for the switch. H3C transceiver modules and cables are subject to change over time. For the most up-to-date list of H3C transceiver modules and cables, contact H3C Support or marketing staff.
For information about the specifications and views of H3C transceiver modules and cables, see H3C Transceiver Modules User Guide.
Ports
Console port
The switch has two console ports: a serial console port and a mini USB console port.
Table4-1 Console port specifications
Item
Console port
Connector type
RJ-45
USB mini-Type B
Compliant standard
EIA/TIA-232
USB 2.0
Transmission baud rate
9600 bps (default) to 115200 bps
Services
·     Provides connection to an ASCII terminal.
·     Provides connection to the serial port of a local or remote (through a pair of modems) PC running terminal emulation program.
·     Provides connection to the USB port of a local PC running terminal emulation program.
The switch has two management Ethernet ports: a copper management port and a SFP management port. You can connect the ports to a local PC for software loading and debugging or to a remote management station for remote management.
Table4-2 Management Ethernet port specifications
Item
Specification
Connector type
·     10/100/1000BASE-T management port: RJ-45.
·     SFP management port: LC.
Port transmission rate
¡     10/100 Mbps, half/full duplex, MDI/MDI-X auto-sensing.
¡     1000 Mbps, full duplex, MDI/MDI-X auto-sensing.
·     SFP management port: 1000/100 Mbps, full duplex.
Transmission medium and max transmission distance
·     10/100/1000BASE-T management port: 100 m (328.08 ft) over category-5 UTP cable.
·     SFP management port: See FE SFP transceiver modules in Table4-3 and GE SFP transceiver modules in Table4-4.
Functions and services
Software upgrade and network management.
FE SFP modules
Table4-3 FE SFP transceiver modules available for the SFP management port
Central wavelength (nm)
Connector
Fiber type and diameter (µm)
Max transmission distance
SFP-FE-SX-MM1310-A
1310
LC
Multi-mode, 50/125
2 km (1.24 miles)
Multi-mode, 62.5/125
SFP-FE-LX-SM1310-A
1310
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-LH40-SM1310
1310
LC
Single-mode, 9/125
40 km (24.86 miles)
Table4-4 GE SFP transceiver modules available for the available for the SFP management port
Connector
Cable/Fiber type and diameter (µm)
Modal bandwidth (MHz × km)
SFP-GE-T
SFP-GE-T-D
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-SX-MM850-A
SFP-GE-SX-MM850-D
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
200 m (656.17 ft)
SFP-GE-LX-SM1310-A
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
Multi-mode, 50/125
500 or 400
550 m (1804.46 ft)
500
550 m (1804.46 ft)
SFP-GE-LX-SM1310-D
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310
SFP-GE-LH40-SM1310-D
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
SFP-GE-LH80-SM1550-D
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550
LC
Single-mode, 9/125
N/A
100 km (62.14 miles)
USB port
The switch has one OHCI-compliant USB 2.0 port that can upload and download data at a rate up to 480 Mbps. You can use this USB port to access the file system on the Flash of the switch, for example, to upload or download application and configuration files.
The USB port supplies power as per USB 2.0 specifications. Use only USB 2.0-compliant USB devices for the USB port. The port might not identity USB devices that are not compliant with USB 2.0.
USB devices from different vendors vary in compatibilities and drivers. H3C does not guarantee correct operation of USB devices from other vendors on the switch. If a USB device fails to operate on the switch, replace it with one from another vendor.
QSFP28 port
The switch provides 64 QSFP28 ports. A QSFP28 port with a split-capable 100-GE transceiver module or cable installed can be split into four 25-GE breakout interfaces to improve port density. A QSFP28 port with a split-capable 40-GE transceiver module or cable installed can be split into four 10-GE breakout interfaces to improve port density.
On the S9820-64H switch, only odd-numbered interfaces can be split. When an odd-numbered interface is split, the interface with the number as the odd number + 1 is deleted.
You can install the following transceiver modules and cables in the QSFP28 ports:
·     QSFP28 transceiver modules in Table4-5.
·     QSFP28 copper cables in Table4-6.
·     QSFP28 fiber cables in Table4-7.
·     QSFP28 to SFP28 copper cables in Table4-8.
·     QSFP+ transceiver modules in Table4-9.
·     QSFP+ copper cables in Table4-10.
·     QSFP+ fiber cables in Table4-11.
·     QSFP+ to SFP+ copper cables in Table4-12.
Table4-5 QSFP28 transceiver modules available for the QSFP28 ports
Connector
Modal bandwidth (MHz*km)
Maximum transmission distance
QSFP-100G-SR4-MM850
850
MPO (PC polished, 12-fiber)
Multi-mode, 50/125
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
QSFP-100G-PSM4-SM1310
1295 to 1325
MPO (APC polished, 12-fiber)
Single-mode, 9/125
N/A
0.5 km (0.31 miles)
QSFP-100G-CWDM4-SM1300-A
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
2 km (1.24 miles)
QSFP-100G-ER4L-WDM1300
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
QSFP-100G-LR4-WDM1300
QSFP-100G-LR4-WDM1300-A
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
QSFP-100G-LR4L-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
2 km (1.24 miles)
QSFP-100G-SWDM4-MM850
Four lanes:
·     850
·     880
·     910
·     940
LC
Multi-mode, 50/125
2000
75 m (246.06 ft)
4700
100 m (328.08 ft)
QSFP-100G-BIDI-MM850 (end of sale)
Two lanes:
·     855
·     908
LC
Multi-mode, 50/125
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
IMPORTANT
IMPORTANT:
·     The QSFP-100G-SWDM4-MM850 transceiver module is supported only in E6553 and later.
·     The QSFP-100G-BIDI-MM85 and QSFP-100G-ER4L-WDM1300 transceiver modules are supported only in R6607 and later.
Table4-6 QSFP28 copper cables available for the QSFP28 ports
QSFP28 copper cable
Cable length
QSFP-100G-D-CAB-1M
1 m (3.28 ft)
QSFP-100G-D-CAB-3M
3 m (9.84 ft)
QSFP-100G-D-CAB-5M
5 m (16.40 ft)
Table4-7 QSFP28 fiber cables available for the QSFP28 ports
QSFP28 fiber cable
Cable length
QSFP-100G-D-AOC-7M
7 m (22.97 ft)
QSFP-100G-D-AOC-10M
10 m (32.81 ft)
QSFP-100G-D-AOC-20M
20 m (65.62 ft)
Table4-8 QSFP28 to SFP28 copper cables available for the QSFP28 ports
Cable length
QSFP-100G-4SFP-25G-CAB-1M
1 m (3.28 ft)
QSFP-100G-4SFP-25G-CAB-3M
3 m (9.84 ft)
QSFP-100G-4SFP-25G-CAB-5M
5 m (16.40 ft)
Table4-9 QSFP+ transceiver modules available for the QSFP28 ports
Connector
QSFP-40G-SR4-MM850
850
MPO (PC-polished, 12-core)
Multi-mode, 50/125
2000
100 m (328.08 ft)
4700
150 m (492.13 ft)
QSFP-40G-CSR4-MM850
850
Multi-mode, 50/125
2000
300 m (984.25 ft)
4700
400 m (1312.34 ft)
QSFP-40G-LR4-PSM1310
1310
MPO (APC-polished, 12-core)
Single-mode, 9/125
N/A
10 km (6.21 miles)
QSFP-40G-BIDI-SR-MM850
850
LC
Multi-mode, 50/125
2000
100 m (328.08 ft)
4700
150 m (492.13 ft)
QSFP-40G-BIDI-WDM850
Four lanes:
·     850
·     880
·     910
·     940
LC
Multi-mode, 50/125
2000
240 m (787.40 ft)
4700
350 m (1148.29 ft)
QSFP-40G-ER4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
QSFP-40G-LR4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
QSFP-40G-LR4L-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
2 km (1.24 miles)
Table4-10 QSFP+ copper cables available for the QSFP28 ports
QSFP+ copper cable
LSWM1QSTK0
1 m (3.28 ft)
LSWM1QSTK1
3 m (9.84 ft)
LSWM1QSTK2
5 m (16.40 ft)
Table4-11 QSFP+ fiber cables available for the QSFP28 ports
QSFP+ fiber cable
Cable length
QSFP-40G-D-AOC-3M
3 m (9.84 ft)
QSFP-40G-D-AOC-7M
7 m (22.97 ft)
QSFP-40G-D-AOC-10M
10 m (32.81 ft)
QSFP-40G-D-AOC-20M
20 m (65.62 ft)
Table4-12 QSFP+ to SFP+ copper cables available for the QSFP28 ports
LSWM1QSTK3
1 m (3.28 ft)
LSWM1QSTK4
3 m (9.84 ft)
LSWM1QSTK5
5 m (16.40 ft)
·     You can use a QSFP-40G-SR4-MM850 or QSFP-40G-CSR4-MM850 transceiver module to connect a QSFP+ port to four SFP+ ports. The QSFP+ transceiver module and SFP+ transceiver modules to be connected must be the same in specifications, including central wavelength and fiber type.
·     MPO connectors include physical contact (PC) connectors with a flat-polished face and angle-polished contact (APC) connectors with an angle-polished face (8°).
·     The QSFP-40G-LR4L-WDM1300 and QSFP-40G-ER4-WDM1300 transceiver modules are supported only in E6553 and later.
·     The QSFP-40G-BIDI-WDM850 transceiver module is supported only in R6607 and later.
LEDs
System status LED
The system status LED shows the operating status of the switch.
Table4-13 System status LED description
LED mark
Status
SYS
Steady green
The switch is operating correctly.
Flashing green
The switch is performing power-on self test (POST).
Steady red
The system has failed to pass POST or a fault has occurred.
Flashing blue (3 Hz)
Helps you to locate the switch.
To locate the switch in the rack, execute the locator blink blink-time command. The LED then flashes blue at 3 Hz.
Off
The switch is powered off or has failed to start up.
QSFP28 port LED
Table4-14 QSFP28 port LED description
LED status
Steady green
A transceiver module or cable has been correctly installed in the port. The port has a link and is operating at 100 Gbps.
Flashing green
The port is sending or receiving data at 100 Gbps.
Steady yellow
A transceiver module or cable has been correctly installed in the port. The port has a link and is operating at 10 Gbps, 25 Gbps, or 40 Gbps.
Flashing yellow (3 Hz)
The port is sending or receiving data at 10 Gbps, 25 Gbps, or 40 Gbps.
Off
No transceiver module or cable has been installed in the port, or no link is present on the port.
Management Ethernet port LEDs
The switch provides a LINK/ACT LED for each management Ethernet port to indicate their operating status.
Table4-15 Management Ethernet port LED description
LED mark
Status
LINK/ACT
Off
No link is present on the port.
Steady green
The port is operating at 1000 Mbps.
Flashing green
The port is receiving or sending data at 1000 Mbps.
Steady yellow
The port is operating at 100 Mbps.
Flashing yellow
The port is receiving or sending data at 100 Mbps.
Fan tray alarm LEDs
The LSWM1BFANSC, LSWM1BFANSC-SN, LSWM1BFANSCB, and LSWM1BFANSCB-SN fan trays each provide an alarm LED.
Table4-16 Description for the alarm LED
Status
On
The fan tray is faulty.
Off
The fan tray is operating correctly or no power is present.
5 Cooling system
CAUTION
CAUTION:
·     The chassis and power supplies use separate air aisles. Make sure the two aisles are not blocked when the switch is operating.
·     The cooling system has been thoroughly tested and verified. You can install power supplies and fan modules as needed, and the installation can meet the heat dissipation requirements.
To dissipate heat timely and ensure system stability, the switch uses the front-rear air aisle cooling system. Consider the site ventilation design when you plan the installation site for the switch.
Table5-1 Fan tray options for the switch
Available fan trays
Airflow direction
From the power supply side to the port side
From the port side to the power supply side
Figure5-1 Airflow from the power supply side to the port side (with LSWM1BFANSC/LSWM1BFANSC-SN fan trays)
Figure5-2 Airflow from the port side to the power supply side (with LSWM1BFANSCB/LSWM1BFANSCB-SN fan trays)
