| 01-Hardware Information and Specifications | 3.60 MB |
1 Product models and technical specifications
Technical specifications for the S5580S-EI and S5580X-EI switches
Technical specifications for the S5580X-HI switch series
3 Removable component compatibility matrixes
180W power supplies (PSR180-12A-F and PSR180-12A-B)
180W power supply (PSR180-12D-B)
600W power supply (PSR600-54A-B)
920W power supply (PSR920-54A-B)
1600W power supply (PSR1600-54A-B)
SFP+ port (applicable to chassis)
SFP+ port (applicable to expansion cards)
SFP28 port (applicable to chassis)
SFP28 port (applicable to expansion cards)
10/100/1000BASE-T Ethernet port
5G/2.5G/1000BASE-T autosensing Ethernet port
10G/5G/2.5G/1000BASE-T autosensing Ethernet port
Ports on an LSPM6FWD firewall module
Ports on an LSWM2EC EPS scanner module
Ports on an LSWM2-iMC intelligent network management module
LEDs on an LSPM6FWD firewall module
LEDs on an LSWM2EC EPS scanner module
LEDs on an LSWM2-iMC intelligent network management module
10/100/1000 1000BASE-T autosensing Ethernet port LED
5G/2.5G/1000BASE-T autosensing Ethernet port LED
10G/5G/2.5G/1000BASE-T autosensing Ethernet port LED
Product models
Table1-1 Switch series and models
Model |
Product code (PID) |
S5580S-EI switch series |
Non-PoE model |
S5580S-24T6Y-EI |
LS-5580S-24T6X-EI |
S5580S-48T6X-EI |
LS-5580S-48T6X-EI |
S5580X-EI switch series |
Non-PoE model |
S5580X-24T6Y-EI |
LS-5580X-24T6Y-EI |
S5580X-48T6Y-EI |
LS-5580X-48T6Y-EI |
S5580X-HI switch series |
PoE model |
S5580X-32P4X4YC-HI |
LS-5580X-32P4X4YC-HI |
S5580X-48P4YC-HI |
LS-5580X-48P4YC-HI |
Non-PoE model |
S5580X-32S8T4X4YC-HI |
LS-5580X-32S8T4X4YC-HI |
S5580X-48S4YC-HI |
LS-5580X-48S4YC-HI |
S5580X-32T4X4YC-HI |
LS-5580X-32T4X4YC-HI |
S5580X-48T4YC-HI |
LS-5580X-48T4YC-HI |
NOTE: · Switches of the same model but different PIDs might differ in hardware and software features. You can view the PID of a switch on the label located on its rear panel or top panel. · To obtain the purchase information, see the data sheet for the switch at https://www.h3c.com/en/Products_and_Solutions/InterConnect/Switches/ and pay attention to the switch lifecycle management announcement at https://www.h3c.com/en/Support/Policy_Dynamics/Management_Strategy/Products_End_of_Life_Announcement/Switches/. · For information about switch and software compatibility, see the release notes. |
Table1-2 Technical specifications for the S5580S-EI and S5580X-EI switches
Item |
S5580S-24T6X-EI |
S5580S-48T6X-EI |
S5580X-24T6Y-EI |
S5580X-48T6Y-EI |
Physical specifications |
Dimensions (H × W × D) |
43.6 × 440 × 360 mm (1.72 × 17.32 × 14.17 in) |
Dimensions (H × W × D, with package materials) |
95 × 560 × 542 mm (3.74 × 22.05 × 21.34 in) |
Weight (fully configured with power supplies and fan trays) |
≤ 4.5 kg (9.92 lb) |
Technical specifications |
Memory (RAM) |
2 GB |
Flash |
4 GB |
Port types and quantity |
Console port |
1 × serial console port |
USB port |
1 |
1 |
1 |
1 |
Management Ethernet port |
1 |
1 |
1 |
1 |
SFP28 port |
N/A |
N/A |
6 |
6 |
SFP+ port |
6 |
6 |
N/A |
N/A |
SFP port |
8 (The eight SFP ports form combo interfaces with the 10/100/1000 BASE-T autosensing Ethernet ports numbered 17 through 24, respectively.) |
N/A |
N/A |
10/100/1000 BASE-T autosensing Ethernet port |
24 (The 10/100/1000 BASE-T autosensing Ethernet ports numbered 17 through 24 form combo interfaces with their corresponding SFP ports, respectively.) |
48 |
48 |
Fan tray, power supply, and expansion card slots |
Power supply slot |
2, on the rear panel |
Fan tray slot |
N/A |
N/A |
Power supply specifications |
Power input |
AC input, DC input Note: The switch does not support HVDC input. For DC input, you can use a –48 VDC power source in the equipment room or an RPS (H3C RPS1600-A). |
Power specifications |
See "Removable power supplies" |
Power consumption |
Power consumption (static) Data collection standard: no load |
· Single AC input: 16 W · Single DC input: 20 W · Dual AC inputs: 18 W · Dual DC inputs: 27 W |
· Single AC input: 17 W · Single DC input: 20 W · Dual AC inputs: 19 W · Dual DC inputs: 27 W |
· Single AC input: 14 W · Single DC input: 18 W · Dual AC inputs: 16 W · Dual DC inputs: 25 W |
· Single AC input: 17 W · Single DC input: 21 W · Dual AC inputs: 19 W · Dual DC inputs: 28 W |
Power consumption (with typical configuration) Data collection standard: fully configured with copper cables or network cables, at 30% load |
· Single AC input: 26 W · Dual AC inputs: 29 W · Single DC input: 29 W · Dual DC inputs: 36 W |
· Single AC input: 39 W · Dual AC inputs: 41 W · Single DC input: 40 W · Dual DC inputs: 47 W |
· Single AC input: 26 W · Dual AC inputs: 29 W · Single DC input: 28 W · Dual DC inputs: 36 W |
· Single AC input: 41 W · Dual AC inputs: 43 W · Single DC input: 41 W · Dual DC inputs: 48 W |
Power consumption (full load) Data collection standard: fully configured with transceiver modules or network cables, at 100% load |
· Single AC input: 51 W · Single DC input: 52 W · Dual AC inputs: 53 W · Dual DC inputs: 58 W |
· Single AC input: 54 W · Single DC input: 49 W · Dual AC inputs: 56 W · Dual DC inputs: 61 W |
· Single AC input: 53 W · Single DC input: 54 W · Dual AC inputs: 56 W · Dual DC inputs: 61 W |
· Single AC input: 62 W · Single DC input: 61 W · Dual AC inputs: 63 W · Dual DC inputs: 67 W |
Thermal consumption |
Thermal consumption (static) Data collection standard: no load |
· Single AC input: 54 BTU/h · Single DC input: 69 BTU/h · Dual AC inputs: 62 BTU/h · Dual DC inputs: 92 BTU/h |
· Single AC input: 58 BTU/h · Single DC input: 69 BTU/h · Dual AC inputs: 65 BTU/h · Dual DC inputs: 92 BTU/h |
· Single AC input: 48 BTU/h · Single DC input: 62 BTU/h · Dual AC inputs: 55 BTU/h · Dual DC inputs: 86 BTU/h |
· Single AC input: 58 BTU/h · Single DC input: 72 BTU/h · Dual AC inputs: 65 BTU/h · Dual DC inputs: 96 BTU/h |
Thermal consumption (typical) Data collection standard: fully configured with copper cables or network cables, at 30% load |
· Single AC input: 89 BTU/h · Single DC input: 99 BTU/h · Dual AC inputs: 99 BTU/h · Dual DC inputs: 123 BTU/h |
· Single AC input: 133 BTU/h · Single DC input: 140 BTU/h · Dual AC inputs: 137 BTU/h · Dual DC inputs: 161 BTU/h |
· Single AC input: 89 BTU/h · Single DC input: 99 BTU/h · Dual AC inputs: 96 BTU/h · Dual DC inputs: 123 BTU/h |
· Single AC input: 140 BTU/h · Single DC input: 147 BTU/h · Dual AC inputs: 140 BTU/h · Dual DC inputs: 164 BTU/h |
Thermal consumption (full load) Data collection standard: fully configured with transceiver modules or network cables, at 100% load |
· Single AC input: 174 BTU/h · Single DC input: 178 BTU/h · Dual AC inputs: 181 BTU/h · Dual DC inputs: 198 BTU/h |
· Single AC input: 185 BTU/h · Single DC input: 168 BTU/h · Dual AC inputs: 191 BTU/h · Dual DC inputs: 209 BTU/h |
· Single AC input: 181 BTU/h · Single DC input: 185 BTU/h · Dual AC inputs: 191 BTU/h · Dual DC inputs: 209 BTU/h |
· Single AC input: 212 BTU/h · Single DC input: 209 BTU/h · Dual AC inputs: 245 BTU/h · Dual DC inputs: 229 BTU/h |
Heat dissipation |
Heat dissipation method |
Air cooling |
Ventilation aisle |
Fixed fan trays, from the port side to the power supply side |
Front-to-rear or rear-to-front airflow, determined by the selected fan tray model |
Reliability and availability |
Power supply redundancy |
1+1 |
Fan tray redundancy |
N/A |
Fully configure the switch with fan trays |
Hot swapping |
Power supplies support hot swapping. |
Power supplies and fan trays support hot swapping. |
Mean Time Between Failure (MTBF) (year) |
120.16 |
105.7 |
111.92 |
101.92 |
Mean time to repair (MTTR) (hour) |
1 |
Availability |
99.999915% |
99.9999% |
99.999918% |
99.99991% |
Environment specifications |
Sound pressure level at 27°C (80.6°F) |
26.6 dB |
Altitude |
–60 m to +5000 m (–196.85 ft to +16404.20 ft) |
Operating temperature |
–5°C to +50°C (23°F to 122°F) NOTE: The maximum acceptable temperature decreases by 0.33°C (32.59°F) for every 100 m (328.08 ft) increase in altitude from 0 m (0 ft). |
Storage temperature |
–40°C to +70°C (–40°F to +158°F) |
Relative humidity |
5% RH to 95% RH, noncondensing |
Compliance |
Product compliance |
· Safety standards · EMC standards · Environmental and eco-friendly standards |
Table1-3 Technical specifications for S5580X-HI non-PoE models
Item |
S5580X-48S4YC-HI |
S5580X-48T4YC-HI |
44 × 440 × 360 mm (1.73 × 17.32 × 14.17 in) |
Weight (fully configured with power supplies, fan trays, and expansion cards) |
≤ 6.6 kg (14.55 lb) |
≤ 6.7 kg (14.77 lb) |
Memory (RAM) |
4 GB |
Flash |
4 GB |
Console port |
USB port |
1 |
1 |
SFP28 port |
4 |
4 |
4 |
4 |
SFP+ port |
4 |
N/A |
4 |
N/A |
SFP port |
32 (The SFP ports numbered 25 through 32 form combo interfaces with their corresponding 10/100/1000 BASE-T autosensing Ethernet ports, respectively.) |
48 |
32 |
N/A |
8 (The eight 10/100/1000 BASE-T autosensing Ethernet ports form combo interfaces with the SFP ports numbered 25 through 32, respectively.) |
N/A |
24 |
48 |
Expansion card slot |
1, on the rear panel |
Power supply slot |
Fan tray slot |
Power input |
Power consumption |
· Single AC input: 29 W · Single DC input: 30 W · Dual AC inputs: 36 W · Dual DC inputs: 36 W |
· Single AC input: 29 W · Single DC input: 34 W · Dual AC inputs: 36 W · Dual DC inputs: 39 W |
· Single AC input: 32 W · Single DC input: 34 W · Dual AC inputs: 39 W · Dual DC inputs: 39 W |
· Single AC input: 34 W · Single DC input: 35 W · Dual AC inputs: 42 W · Dual DC inputs: 41 W |
· Single AC input: 54 W · Dual AC inputs: 63 W · Single DC input: 55 W · Dual DC inputs: 61 W |
· Single AC input: 44 W · Dual AC inputs: 51 W · Single DC input: 47 W · Dual DC inputs: 52 W |
· Single AC input: 50 W · Dual AC inputs: 58 W · Single DC input: 51 W · Dual DC inputs: 57 W |
· Single AC input: 55 W · Dual AC inputs: 62 W · Single DC input: 56 W · Dual DC inputs: 61 W |
· Single AC input: 108 W · Single DC input: 108 W · Dual AC inputs: 112 W · Dual DC inputs: 113 W |
· Single AC input: 135 W · Single DC input: 135 W · Dual AC inputs: 139 W · Dual DC inputs: 140 W |
· Single AC input: 90 W · Single DC input: 90 W · Dual AC inputs: 96 W · Dual DC inputs: 95 W |
· Single AC input: 94 W · Single DC input: 95 W · Dual AC inputs: 100 W · Dual DC inputs: 100 W |
· Single AC input: 98 BTU/h · Dual AC inputs: 122 BTU/h · Single DC input: 102 BTU/h · Dual DC inputs: 122 BTU/h |
· Single AC input: 98 BTU/h · Dual AC inputs: 122 BTU/h · Single DC input: 116 BTU/h · Dual DC inputs: 133 BTU/h |
· Single AC input: 109 BTU/h · Dual AC inputs: 133 BTU/h · Single DC input: 116 BTU/h · Dual DC inputs: 133 BTU/h |
· Single AC input: 116 BTU/h · Dual AC inputs: 143 BTU/h · Single DC input: 139 BTU/h · Dual DC inputs: 139 BTU/h |
· Single AC input: 184 BTU/h · Dual AC inputs: 214 BTU/h · Single DC input: 187 BTU/h · Dual DC inputs: 208 BTU/h |
· Single AC input: 150 BTU/h · Dual AC inputs: 174 BTU/h · Single DC input: 160 BTU/h · Dual DC inputs: 177 BTU/h |
· Single AC input: 170 BTU/h · Dual AC inputs: 197 BTU/h · Single DC input: 174 BTU/h · Dual DC inputs: 194 BTU/h |
· Single AC input: 187 BTU/h · Dual AC inputs: 211 BTU/h · Single DC input: 208 BTU/h · Dual DC inputs: 208 BTU/h |
· Single AC input: 368 BTU/h · Dual AC inputs: 382 BTU/h · Single DC input: 368 BTU/h · Dual DC inputs: 385 BTU/h |
· Single AC input: 460 BTU/h · Dual AC inputs: 474 BTU/h · Single DC input: 460 BTU/h · Dual DC inputs: 477 BTU/h |
· Single AC input: 300 BTU/h · Dual AC inputs: 327 BTU/h · Single DC input: 307 BTU/h · Dual DC inputs: 324 BTU/h |
· Single AC input: 320 BTU/h · Dual AC inputs: 341 BTU/h · Single DC input: 341 BTU/h · Dual DC inputs: 341 BTU/h |
Heat dissipation |
Air cooling |
Ventilation aisle |
1+1 |
Hot swapping |
Power supplies and fan trays support hot swapping. Expansion cards support hot swapping, but do not hot swap an expansion card when the switch is starting up. |
MTBF (year) |
117.69 |
134.3 |
124.08 |
122.75 |
MTTR (hour) |
1 |
Availability |
99.999908% |
99.999915% |
99.999903% |
99.999907% |
40.8 dB |
41.5 dB |
40.3 dB |
44.9 dB |
Altitude |
Relative humidity |
Compliance |
Table1-4 Technical specifications for S5580X-HI PoE switch models
Item |
S5580X-48P4YC-HI |
150 × 658 × 556 mm (5.91 × 25.91 × 21.89 in) |
≤ 7.9 kg (17.42 lb) |
≤ 8.1 kg (17.86 lb) |
Memory (RAM) |
4 GB |
Flash |
4 GB |
Console port |
USB port |
1 |
1 |
SFP28 port |
4 |
4 |
SFP+ port |
4 |
N/A |
32 (support PoE) |
48 (support PoE) |
Power supply slot |
Fan tray slot |
Power input |
AC input Note: The switch does not support HVDC input. |
PoE power capacity |
Maximum PoE power per port |
90 W |
90 W |
Total PoE power capacity |
Depends on the power supply configuration, as shown in Table1-5. |
Power consumption |
· Single AC input: 48 W · Dual AC inputs: 59 W |
· Single AC input: 54 W · Dual AC inputs: 66 W |
· Single AC input: 69 W · Dual AC inputs: 77 W |
· Single AC input: 78 W · Dual AC inputs: 87 W |
· Single AC input: 163 BTU/h · Dual AC inputs: 201 BTU/h |
· Single AC input: 184 BTU/h · Dual AC inputs: 225 BTU/h |
· Single AC input: 235 BTU/h · Dual AC inputs: 262 BTU/h |
· Single AC input: 266 BTU/h · Dual AC inputs: 296 BTU/h |
· Single AC input: 5834 BTU/h · Dual AC inputs: 10922 BTU/h |
· Single AC input: 5684 BTU/h · Dual AC inputs: 10901 BTU/h |
Heat dissipation |
Air cooling |
Ventilation aisle |
From the power supply side to the port side |
1+1 |
Hot swapping |
MTBF (year) |
87.14 |
84.56 |
MTTR (hour) |
1 |
Availability |
99.999869% |
99.999865% |
35 dB |
35 dB |
Altitude |
Relative humidity |
Compliance |
Table1-5 Power consumption of the S5580X-HI switch series (full load)
Power supply configuration |
S5580X-48P4YC-HI |
1 × PSR600-54A-B |
638 W |
635 W |
1 × PSR920-54A-B |
1014 W |
1008 W |
1 × PSR1600-54A-B (90 VAC to 176 VAC) |
997 W |
1026 W |
1 × PSR1600-54A-B (176 VAC to 290 VAC) |
1710 W |
1666 W |
2 × PSR600-54A-B |
1292 W |
1277 W |
2 × PSR920-54A-B |
2004 W |
1996 W |
2 × PSR1600-54A-B (90 VAC to 176 VAC) |
2020 W |
2010 W |
2 × PSR1600-54A-B (176 VAC to 290 VAC) |
3201 W |
3195 W |
Table1-6 PoE power capacity of the S5580X-HI switch series
S5580X-48P4YC-HI |
Max PoE power capacity per port |
1 × PSR600-54A-B |
470 W |
90 W |
470 W |
90 W |
1 × PSR920-54A-B |
790 W |
90 W |
790 W |
90 W |
790 W |
90 W |
790 W |
90 W |
1470 W |
90 W |
1470 W |
90 W |
2 × PSR600-54A-B |
1040 W |
90 W |
1040 W |
90 W |
1 × PSR600-54A-B and 1 × PSR920-54A-B |
1040 W |
90 W |
1040 W |
90 W |
2 × PSR920-54A-B |
1620 W |
90 W |
1620 W |
90 W |
1 × PSR920-54A-B and 1 × PSR1600-54A-B (90 VAC to 176 VAC) |
1280 W |
90 W |
1280 W |
90 W |
1 × PSR920-54A-B and 1 × PSR1600-54A-B (176 VAC to 290 VAC) |
1620 W |
90 W |
1620 W |
90 W |
1620 W |
90 W |
1620 W |
90 W |
1 × PSR1600-54A-B (90 VAC to 176 VAC) and 1 × PSR1600-54A-B (176 VAC to 290 VAC) |
1620 W |
90 W |
1620 W |
90 W |
2870 W |
90 W |
2870 W |
90 W |
IMPORTANT: Do not install a PSR600-54A-B and a PSR1600-54A-B on the same switch. |
2 Chassis views
S5580S-24T6X-EI
Figure2-1 Front panel
(1) 10/100/1000BASE-T autosensing Ethernet port LED |
(2) 100/1000BASE-X SFP port LED |
(3) Management Ethernet port |
(4) Console port |
(5) Mode button |
(6) USB port |
(7) System status LED (SYS) |
(8) SFP+ port |
(9) SFP+ port LED |
(10) Mode LED (MODE) |
(11) Removable power supply 2 status LED (PWR2) |
(12) Removable power supply 1 status LED (PWR1) |
(13) Management Ethernet port LED (LINK/ACT) |
(14) SFP port |
(15) 10/100/1000BASE-T autosensing Ethernet port |
(1) Grounding screw |
(2) Removable power supply 1 |
(3) Removable power supply 2 |
The S5580S-24T6X-EI switch came with power supply slot PWR1 empty and power supply slot PWR2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-2, two CA-70A12 power supplies are installed in the power supply slots.
S5580S-48T6X-EI
Figure2-3 Front panel
(2) SFP+ port LED |
(3) Console port |
(4) Mode LED (MODE) |
(5) System status LED (SYS) |
(6) Removable power supply 1 status LED (PWR1) |
(7) Removable power supply 2 status LED (PWR2) |
(8) Mode button |
(9) USB port |
(10) Management Ethernet port LED (LINK/ACT) |
(11) Management Ethernet port |
(12) SFP+ port |
(13) 10/100/1000BASE-T autosensing Ethernet port |
The S5580S-48T6X-EI switch came with power supply slot PWR1 empty and power supply slot PWR2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-4, two CA-70A12 power supplies are installed in the power supply slots.
S5580X-24T6Y-EI
Figure2-5 Front panel
(2) SFP port LED |
(4) Console port |
(5) Mode button |
(6) USB port |
(8) Mode LED (MODE) |
(9) Removable power supply 2 status LED (PWR2) |
(10) Removable power supply 1 status LED (PWR1) |
(11) SFP28 port LED |
(12) SFP28 port |
(14) SFP port |
(2) Removable fan tray 1 |
(3) Removable fan tray 2 |
(4) Removable power supply 1 |
(5) Removable power supply 2 |
The S5580X-24T6Y-EI switch came with power supply slot PWR1 empty and power supply slot PWR2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-6, two CA-70A12 power supplies are installed in the power supply slots.
The S5580X-24T6Y-EI switch came with the two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-6, two FAN-40F-1-F fan trays are installed in the fan tray slots.
S5580X-48T6Y-EI
Figure2-7 Front panel
(2) SFP28 port |
(3) Console port |
(8) Mode button |
(9) USB port |
(12) SFP28 port LED |
The S5580X-48T6Y-EI switch came with power supply slot PWR1 empty and power supply slot PWR2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-8, two CA-70A12 power supplies are installed in the power supply slots.
The S5580X-48T6Y-EI switch came with the two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-8, two FAN-40F-1-F fan trays are installed in the fan tray slots.
Figure2-9 Front panel
(1) SFP port |
(2) SFP port LED |
(3) 10/100/1000 BASE-T autosensing Ethernet port |
(4) 10/100/1000 1000BASE-T autosensing Ethernet port LED |
(5) Management Ethernet port |
(6) Console port |
(7) Mode button |
(8) USB port |
(9) System LED (SYS) |
(11) SFP28 port |
(13) Expansion module LED (SLOT) |
(14) Removable power supply 2 status LED (PWR2) |
(15) Removable power supply 1 status LED (PWR1) |
(16) Management Ethernet port LED (LINK/ACT) |
(17) SFP + port |
(18) SFP + port LED |
(2) Expansion module |
(3) Removable fan tray 1 |
(4) Removable fan tray 2 |
(5) Removable power supply 1 |
(6) Removable power supply 2 |
The S5580X-32S8T4X4YC-HI switch came with power supply slot PWR1 empty and power supply slot PWR2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-10, two PSR180-12A-B power supplies are installed in the power supply slots.
The S5580X-32S8T4X4YC-HI switch came with the two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-10, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
S5580X-48S4YC-HI
Figure2-11 Front panel
(1) SFP port |
(2) SFP port LED |
(4) Console port |
(5) Mode button |
(6) USB port |
(7) System LED (SYS) |
(9) SFP28 port |
(10) SFP28 port LED |
(11) Expansion module LED (SLOT) |
(12) Removable power supply 2 status LED (PWR2) |
(13) Removable power supply 1 status LED (PWR1) |
(14) Management Ethernet port LED (LINK/ACT) |
The S5580X-48S4YC-HI switch came with power supply slot PWR1 empty and power supply slot PWR2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-12, two PSR180-12A-B power supplies are installed in the power supply slots.
The S5580X-48S4YC-HI switch came with the two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-12, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
S5580X-32T4X4YC-HI
Figure2-13 Front panel
(1) 10/100/1000 BASE-T autosensing Ethernet port |
(2) 10/100/1000 1000BASE-T autosensing Ethernet port LED |
(4) Console port |
(5) Mode button |
(6) USB port |
(9) SFP28 port |
(15) SFP+ port |
(16) SFP+ port LED |
The S5580X-32T4X4YC-HI switch came with power supply slot PWR1 empty and power supply slot PWR2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-14, two PSR180-12A-B power supplies are installed in the power supply slots.
The S5580X-32T4X4YC-HI switch came with the two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-14, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
S5580X-48T4YC-HI
Figure2-15 Front panel
(4) Console port |
(5) Mode button |
(6) USB port |
(9) SFP28 port |
The S5580X-48T4YC-HI switch came with power supply slot PWR1 empty and power supply slot PWR2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-16, two PSR180-12A-B power supplies are installed in the power supply slots.
The S5580X-48T4YC-HI switch came with the two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-16, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
S5580X-32P4X4YC-HI
Figure2-17 Front panel
(1) 10/100/1000 BASE-T-POE++ autosensing Ethernet port |
(2) 10/100/1000 BASE-T-POE++ autosensing Ethernet port LED |
(3) Management Ethernet port LED (LINK/ACT) |
(4) Management Ethernet port |
(5) Console port |
(6) Mode button |
(7) USB port |
(8) System LED (SYS) |
(9) Mode LED (MODE) |
(10) Expansion module LED (SLOT) |
(14) SFP28 port |
(15) SFP28 port LED |
(17) SFP+ port |
The S5580X-32P4X4YC-HI switch came with power supply slot PWR1 empty and power supply slot PWR2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-18, two PSR920-54A-B power supplies are installed in the power supply slots.
The S5580X-32P4X4YC-HI switch came with the two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-18, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
S5580X-48P4YC-HI
Figure2-19 Front panel
(5) Console port |
(6) Mode button |
(7) USB port |
(14) SFP28 port LED |
(15) SFP28 port |
The S5580X-48P4YC-HI switch came with power supply slot PWR1 empty and power supply slot PWR2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-20, two PSR920-54A-B power supplies are installed in the power supply slots.
The S5580X-48P4YC-HI switch came with the two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-20, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
Some switch models support removable components. Table3-1 describes the removable components available for the switch.
Table3-1 Compatibility matrix between S5580S-EI&S5580X-EI switches and removable components
Removable component model |
S5580S-24T6X-EI S5580S-48T6X-EI |
S5580X-24T6Y-EI S5580X-48T6Y-EI |
Removable power supplies |
CA-70A12 |
Supported |
Supported |
PSR75-12A |
Supported |
Supported |
PSR180-12D-B |
Supported |
Supported |
Removable fan trays |
FAN-40B-1-F |
N/A |
Supported |
FAN-40F-1-F |
N/A |
Supported |
Table3-2 Compatibility matrix between S5580X-HI switches and removable components
S5580X-32S8T4X4YC-HI S5580X-48S4YC-HI S5580X-32T4X4YC-HI S5580X-48T4YC-HI |
PSR180-12A-F |
Supported |
N/A |
PSR180-12A-B |
Supported |
N/A |
PSR180-12D-B |
Supported |
N/A |
PSR600-54A-B |
N/A |
Supported |
PSR920-54A-B |
N/A |
Supported |
PSR1600-54A-B |
N/A |
Supported |
LSPM1FANSA-SN |
Supported |
N/A |
LSPM1FANSB-SN |
Supported |
Supported |
Expansion cards |
LSWM2MGT8P |
Supported |
Supported |
LSWM2XMGT8P |
Supported |
Supported |
LSWM2ZQP2P |
Supported |
Supported |
LSWM2ZSP8P |
Supported |
Supported |
LSPM6FWD |
Supported |
Supported |
LSWM2EC |
Supported |
Supported |
LSWM2-iMC |
Supported |
Supported |
LSWM2QP2P |
Supported |
Supported |
LSWM2SP8P |
Supported |
Supported |
LSWM4SP8PM |
Supported |
Supported |
CAUTION: · You can power on the switch only when the switch has all fan trays of the same model installed. · Do not install a PSR600-54A-B and a PSR1600-54A-B on the same switch. |
NOTE: · For non-PoE switches, you can install one power supply, or two power supplies for 1+1 redundancy on the switch. You can install an AC power supply and a DC power supply on the same switch. · For PoE switches, you can install one power supply, or two power supplies for 1+1 redundancy on the switch. PoE capabilities vary by power supply configuration. When a power supply fails, PoE capabilities of the switch might decrease. For more information about PoE power capacity, see Table1-6. When a power supply fails, the PoE capability of the switch might degrade. · The removable components available for the switch series are subject to change over time. For the most recent list of removable components for the switch, see the release notes. |
4 Removable power supplies
70W power supply (CA-70A12)
View
Figure4-1 CA-70A12 AC power supply view
Functions
The CA-70A12 is an AC and DC input and DC output power supply. It provides a maximum output of 70 W.
Table4-1 CA-70A12 power supply features
Feature |
Protection function |
Protection against input overcurrent, input undervoltage, output overvoltage, output current limiting, output shortcircuit, and overtemperature conditions. |
Support for redundancy |
Two power supplies can be connected in parallel to achieve 1+1 redundancy and load balancing. |
Support for hot swapping |
You can remove one of the power supplies in 1+1 redundancy when the switch is operating. |
Table4-2 Technical specifications
Item |
Specification |
Dimensions (H × W × D, including the handle) |
41.1 × 101.6 × 207 mm (1.62 × 4.00 × 8.15 in) |
Weight |
0.6 kg (1.32 lb) |
Rated input voltage range |
AC input: 100 VAC to 240 VAC @ 50 Hz or 60 Hz HVDC input: 240 VDC |
Max input voltage range |
AC input: 90 VAC to 290 VAC @ 47 Hz to 63 Hz HVDC input: 180 VDC to 320 VDC |
Rated input current |
N/A |
Rated output current |
5.83 A |
Rated output voltage |
12 V |
Rated output power |
70 W |
Melting current of power supply fuse |
10 A/250 V |
75W power supply (PSR75-12A)
View
Figure4-2 PSR75-12A power supply view
(1) Mounting screws |
(2) Power input receptacle |
(3) Power cord retainer clip |
(4) Handle |
Functions
The PSR75-12A is an AC and DC input and DC output power supply. It provides a maximum output of 75 W.
Table4-3 PSR75-12A power supply features
Feature |
Table4-4 Technical specifications
Item |
Specification |
Weight |
0.72 kg (1.59 lb) |
N/A |
6.3 A |
12 V |
75 W |
3.15 A/250 V |
View
Figure4-3 PSR180-12A-B AC power supply view
The PSR180-12A-F and PSR180-12A-B AC power supplies are similar in views except for their marks.
Functions
The PSR180-12A-F and PSR180-12A-B are AC power supplies with AC input and DC output. The power supplies provide an output voltage of 12 V and a maximum output of 180 W.
1. Features provided by the PSR180-12A-F and PSR180-12A-B power supplies
Feature |
You can remove one of the power supplies in 1+1 redundancy when the switch is operating correctly. |
Table4-5 Technical specifications
Item |
Specification |
Weight |
0.8 kg (1.76 lb) |
Rated AC input voltage range |
100 VAC to 240 VAC @ 50 or 60 Hz |
Max AC input voltage range |
90 VAC to 290 VAC @ 47 to 63 Hz |
N/A |
15 A |
12 V |
180 W |
6.3 A/250 V |
View
Figure4-4 PSR180-12D-B DC power supply view
Functions
The PSR180-12D-B is a DC power supply with DC input and DC output. It provides an output voltage of 12 V and a maximum output of 180 W.
Table4-6 PSR180-12D-B power supply features
Feature |
Table4-7 Technical specifications
Item |
Specification |
Weight |
1 kg (2.20 lb) |
–48 VDC to –60 VDC |
–36 VDC to –72 VDC |
N/A |
15 A |
12 V |
180 W |
8 A/125 V |
View
Figure4-5 PSR600-54A-B AC power supply view
For information about the status LEDs, see "Status LEDs on a 600W/920W/1600W power supply."
Functions
The PSR600-54A-B is an AC and HVDC input and DC output power supply.
1. PSR600-54A-B power supply features
Feature |
Table4-8 Technical specifications
Item |
Specification |
40.2 × 73.5 × 213.8 mm (1.58 × 2.89 × 8.42 in) |
Weight |
1 kg (2.20 lb) |
AC input: 100 VAC to 240 VAC @ 50 or 60 Hz HVDC input: 240 VDC |
AC input: 90 VAC to 290 VAC @ 47 to 63 Hz HVDC input: 180 to 320 VDC |
N/A |
11 A |
56 V |
600 W |
10 A/250 V |
View
Figure4-6 PSR920-54A-B AC power supply view
Functions
The PSR920-54A-B is an AC and HVDC input and DC output power supply.
1. Features provided by the PSR920-54A-B power supply
Feature |
Table4-9 Technical specifications
Item |
Specification |
Weight |
1 kg (2.20 lb) |
N/A |
16.5 A |
56 V |
920 W |
16 A/250 V |
View
Figure4-7 PSR1600-54A-B AC power supply view
Functions
The PSR1600-54A-B is an AC and HVDC input and DC output power supply.
1. Features provided by the PSR1600-54A-B power supply
Feature |
Table4-10 Technical specifications
Item |
Specification |
Weight |
1 kg (2.20 lb) |
N/A |
· AC input: ¡ 17 A: 90 to 176 V @ 47 to 63 Hz ¡ 29 A: 176 to 290 V @ 47 to 63 Hz · HVDC input: 29 A |
56 V |
· AC input: ¡ 950 W: 90 to 176 V @ 47 to 63 Hz ¡ 1600 W: 176 to 290 V @ 47 to 63 Hz · HVDC input: 29 A |
16 A/125 V |
5 Removable fan trays
FAN-40B-1-F
View
Figure5-1 FAN-40B-1-F fan tray view
For information about the status LED, see Table7-47.
Functions
The FAN-40B-1-F fan tray blows air from the power supply side to the port side. The fan tray features small size, fast heat dissipation, and hot swapping, and can automatically adjust the fan speed based on the device temperature.
1. Technical specifications
Item |
Specification |
40 × 40 × 105 mm (1.57 × 1.57 × 4.13 in) |
Fan quantity |
1 |
Weight |
N/A |
Airflow direction |
Air drawn in from the fan tray faceplate |
Fan speed |
15600±10% R.P.M |
Max airflow |
20.56 CFM (0.58 m3/min) |
Input voltage |
12 V |
Max power consumption |
N/A |
FAN-40F-1-F
View
Figure5-2 FAN-40F-1-F fan tray view
Functions
The FAN-40F-1-F fan tray draws air from the port side to the power supply side. The fan tray features small size, fast heat dissipation, and hot swapping, and can automatically adjust the fan speed based on the device temperature.
Item |
Specification |
Fan quantity |
1 |
Weight |
N/A |
Airflow direction |
Air exhausted from the fan tray faceplate |
Fan speed |
15600±10% R.P.M |
Max airflow |
Input voltage |
12 V |
N/A |
LSPM1FANSA-SN
View
Figure5-3 LSPM1FANSA-SN fan tray view
For information about the status LED, see Table7-48.
Functions
The LSPM1FANSA-SN fan tray blows air from the power supply side to the port side. The fan tray features small size, fast heat dissipation, and hot swapping, and can automatically adjust the fan speed based on the device temperature.
Item |
Specification |
40 × 40.6 × 105 mm (1.57 × 1.60 × 4.13 in) |
Fan quantity |
1 |
Weight |
N/A |
Airflow direction |
Fan speed |
20000 R.P.M |
Max airflow |
20 CFM (0.57 m3/min) |
Input voltage |
12 V |
9.8 W |
LSPM1FANSB-SN
View
Figure5-4 LSPM1FANSB-SN fan tray view
Functions
The LSPM1FANSB-SN fan tray draws air from the port side to the power supply side. The fan tray features small size, fast heat dissipation, and hot swapping, and can automatically adjust the fan speed based on the device temperature.
Item |
Specification |
Fan quantity |
1 |
Weight |
N/A |
Airflow direction |
Fan speed |
20000 R.P.M |
Max airflow |
Input voltage |
12 V |
9.8 W |
6 Expansion cards
LSWM2QP2P
About LSWM2QP2P
The LSWM2QP2P interface module provides two QSFP+ ports.
Figure6-1 LSWM2QP2P interface module view
Ports and LEDs
For information about the ports and transceiver modules and cables available for the ports, see "QSFP+ port."
For information about the LEDs, see "QSFP+ port LED."
Item |
Specification |
40.1 × 95 × 147.5 mm (1.58 × 3.74 × 5.81 in) |
Weight |
0.4 kg (0.88 lb) |
Power consumption (static) |
9 W |
Power consumption (with typical configuration) |
10 W |
Power consumption (fully configured) |
14 W |
LSWM2MGT8P
About LSWM2MGT8P
The LSWM2MGT8P interface module provides eight 5G/2.5G/1000BASE-T autosensing Ethernet ports.
Figure6-2 LSWM2MGT8P interface module view
Ports and LEDs
For information about the ports, see "5G/2.5G/1000BASE-T autosensing Ethernet port."
For information about the LEDs, see "5G/2.5G/1000BASE-T autosensing Ethernet port LED."
LSWM2XMGT8P
About LSWM2XMGT8P
The LSWM2XMGT8P interface module provides eight 10G/5G/2.5G/1000BASE-T autosensing Ethernet ports.
Figure6-3 LSWM2XMGT8P interface module view
Ports and LEDs
For information about the ports, see "10G/5G/2.5G/1000BASE-T autosensing Ethernet port."
For information about the LEDs, see "10G/5G/2.5G/1000BASE-T autosensing Ethernet port LED."
LSWM2ZQP2P
About LSWM2ZQP2P
The LSWM2ZQP2P interface module provides two QSFP28 ports.
Figure6-4 LSWM2ZQP2P interface module view
Ports and LEDs
For information about the ports and transceiver modules and cables available for the ports, see "QSFP28 port."
For information about the LEDs, see "QSFP28 port LED."
LSWM2ZSP8P
About LSWM2ZSP8P
The LSWM2ZSP8P interface module provides eight SFP28 ports.
Figure6-5 LSWM2ZSP8P interface module view
Ports and LEDs
For information about the ports and transceiver modules and cables available for the ports, see "SFP28 port (applicable to expansion cards)."
For information about the LEDs, see "SFP28 port LED."
LSPM6FWD
About LSPM6FWD
The LSPM6FWD is a fourth-generation high performance firewall module. It provides features including firewall, VPN, content filtering, content identification, URL filtering, and NAT. By using this module on a switch, you can enhance the switch security capabilities without changing the network topology.
Figure6-6 LSPM6FWD front panel
(1) Management Ethernet port LED (ACT/LINK) |
(2) 10/100/1000BASE-T management Ethernet port |
(3) System status LED (SYS) |
(4) Console port (CONSOLE) |
(5) Captive screw |
Ports and LEDs
For information about the ports, see "Ports on an LSPM6FWD firewall module."
For information about the LEDs, see "LEDs on an LSPM6FWD firewall module."
Item |
Specification |
44.1 × 95 × 197.8 mm (1.74 × 3.74 × 7.79 in) |
Weight |
0.688 kg (1.52 lb) |
N/A |
N/A |
50 W |
LSWM2EC
About LSWM2EC
The LSWM2EC EPS scanner module scans network-wide endpoints as instructed by the EPS server for port type and operating system type automatically and sends scanning results to the EPS server. Upon receiving the port information, the EPS server provides a baseline management over the endpoints that access the network system. By using this module on a switch, you can save hardware resources, increase the number of endpoints that can be scanned, and perform incremental scanning.
Figure6-7 LSWM2EC EPS scanner module view
Ports and LEDs
For information about the ports, see "Ports on an LSWM2EC EPS scanner module."
For information about the LEDs, see "LEDs on an LSWM2EC EPS scanner module."
Item |
Specification |
Processor |
Intel C3758, 2.2 GHz |
DDR |
8G DDR4 |
Flash |
64GB EMMC |
Operating system |
Linux |
Maximum number of endpoints that can be scanned |
2500 |
Ports |
· 1 × management Ethernet port (MGMT) · 1 × console port · 2 × USB 3.0 ports |
41.1 × 95 × 197.5 mm (1.62 × 3.74 × 7.78 in) |
Weight |
0.5 kg (1.10 lb) |
14 W |
N/A |
30 W |
LSWM2-iMC
About LSWM2-iMC
The LSWM2-iMC intelligent network management module provides endpoint admission management for small- and medium-sized campus networks. The module aims to provide network management solutions that integrate the terminal users, resources, and network services for network administrators.
Running on the Intelligent Management Center (IMC) platform, the module implements comprehensive management over endpoint users by using End-user Intelligent Access (EIA) and Endpoint Admission Defense (EAD). For more information about IMC, EIA, and EAD, see H3C IMC Getting Started Guide.
Figure6-8 LSWM2-iMC intelligent network management module view
Ports and LEDs
For information about the ports, see "Ports on an LSWM2-iMC intelligent network management module."
For information about the LEDs, see "LEDs on an LSWM2-iMC intelligent network management module."
Item |
Specification |
Processor |
DDR |
16GB DDR4 |
SSD |
480GB EMMC |
Operating system |
Linux |
Ports |
Weight |
0.5 kg (1.10 lb) |
16 W |
N/A |
33 W |
LSWM2SP8P/LSWM2SP8PM
About LSWM2SP8P and LSWM2SP8PM
The LSWM2SP8PM and LSWM2SP8P interface cards each provide eight SFP+ ports. The SFP+ ports on the LSWM2SP8PM interface card support MACsec. The views of LSWM2SP8P and LSWM2SP8PM are the same. The following figure uses the LSWM2SP8PM as an example.
Figure6-9 LSWM2SP8PM interface card view
Ports and LEDs
For information about the ports and transceiver modules and cables available for the ports, see "SFP+ port (applicable to expansion cards)."
For information about the LEDs, see "SFP+ port LED."
7 Ports and LEDs
Ports
Console port
Table7-1 Console port specifications (1)
Item |
Specification |
Connector type |
RJ-45 |
Compliant standard |
EIA/TIA-232 |
Transmission baud rate |
9600 bps (default) to 115200 bps |
Services |
· Provides connection to an ASCII terminal · Provides connection to the serial port of a local PC running terminal emulation program |
Compatible switch models |
All switch models |
Table7-2 Console port specifications (2)
Item |
Specification |
Connector type |
RJ-45 |
RS-232 |
Transmission medium and max transmission distance |
Common asynchronous serial interface cable, with a maximum transmission distance of 15 m (49.21 ft) |
Services |
· Provides connection to an ASCII terminal · Provides connection to the serial port of a local PC running terminal emulation program · Supports command line interface (CLI) |
Compatible expansion cards |
LSPM6FWD |
Table7-3 Management Ethernet port specifications
Item |
Specification |
Connector type |
RJ-45 |
Port transmission rate |
· 10 Mbps, half/full duplex · 100 Mbps, half/full duplex · 1000 Mbps, full duplex · MDI/MDI-X autosensing |
Transmission medium |
Category 5 or above twisted pair cable |
Max transmission distance |
100 m (328.08 ft) |
IEEE 802.3i, IEEE 802.3u, and IEEE 802.3ab |
Functions and services |
Connects to a local PC or a remote management station for software and Boot ROM upgrade, and network management |
All switch models |
USB port
Table7-4 USB port specifications
Item |
Specification |
Port type |
USB 2.0 |
OHC |
Uploads and downloads data at a rate up to 480 Mbps |
Accesses the file system on the flash of the switch, for example, to upload or download application and configuration files |
All device switch models |
NOTE: USB devices from different vendors vary in compatibilities and drivers. H3C does not guarantee correct operation of USB devices from other vendors on the switch. If a USB device fails to operate on the switch, replace it with one from another vendor. |
SFP port
Table7-5 SFP port specifications
Item |
Specification |
Port type |
SFP port |
Compatible transceiver modules and cables |
· GE SFP transceiver modules and cables in Table7-6 · FE SFP transceiver modules in Table7-7 |
S5580S-24T6X-EI, S5580X-24T6Y-EI, S5580X-32S8T4X4YC-HI, S5580X-48S4YC-HI |
Restrictions |
· Only the S5580X-24T6Y-EI and S5580X-48T6Y-EI switches support SFP-25G-SR-MM850-H, SFP-25G-LR-SM1310-I, and SFP-25G-CSR-MM850. · To use transceiver modules with a maximum transmission distance ≥ 80 km (49.71 miles) on an S5580X-32T4X4YC-HI or S5580X-48T4YC-HI switch, make sure the ambient temperature is ≤ 45°C (113°F). · To use transceiver modules with a maximum transmission distance ≥ 80 km (49.71 miles) on an S5580X-32S8T4X4YC-HI switch, make sure the ambient temperature is ≤ 45°C (113°F). When the switch is fully configured with fiber ports, make sure the number of transceiver modules (SFP-GE-T or SFP-GE-T-D) on GE SFP copper ports or transceiver modules with a maximum transmission distance ≥ 40 km (24.86 miles) does not exceed 12. · To use transceiver modules with a maximum transmission distance ≥ 80 km (49.71 miles) on an S5580X-48S4YC-HI switch, make sure the ambient temperature is ≤ 45°C (113°F). When the switch is fully configured with fiber ports, make sure the number of transceiver modules (SFP-GE-T or SFP-GE-T-D) on GE SFP copper ports or transceiver modules with a maximum transmission distance ≥ 40 km (24.86 miles) does not exceed 20. |
Table7-6 GE SFP transceiver modules and cables available for the 100/1000BASE-X SFP ports
GE SFP transceiver module and cable |
Central wavelength (nm) |
Connector |
Cable/Fiber type and diameter (µm) |
Modal bandwidth (MHz × km) |
GE SFP transceiver modules |
SFP-GE-T |
N/A |
RJ-45 |
Twisted pair cable |
N/A |
100 m (328.08 ft) |
SFP-GE-SX-MM850-A |
850 |
LC |
50/125, MMF |
500 |
550 m (1804.46 ft) |
400 |
500 m (1640.42 ft) |
62.5/125, MMF |
200 |
275 m (902.23 ft) |
160 |
200 m (656.17 ft) |
SFP-GE-LX-SM1310-A |
1310 |
LC |
9/125, SMF |
N/A |
10 km (6.21 miles) |
50/125, MMF |
500 or 400 |
62.5/125, MMF |
500 |
SFP-GE-LH20-SM1310-I |
1310 |
LC |
9/125, SMF |
N/A |
20 km (12.43 miles) |
SFP-GE-LH40-SM1310-I |
1310 |
LC |
9/125, SMF |
N/A |
40 km (24.86 miles) |
SFP-GE-LH40-SM1310 |
1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH40-SM1550 |
1550 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH80-SM1550 |
1550 |
LC |
9/125, SMF |
N/A |
80 km (49.71 miles) |
SFP-GE-LH100-SM1550 |
1550 |
LC |
9/125, SMF |
N/A |
100 km (62.14 miles) |
SFP-GE-LX-SM1310-BIDI |
Tx: 1310 Rx: 1490 |
LC |
9/125, SMF |
N/A |
SFP-GE-LX-SM1490-BIDI |
Tx: 1490 Rx: 1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH40-SM1310-BIDI |
Tx: 1310 Rx: 1550 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH40-SM1550-BIDI |
Tx: 1550 Rx: 1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH70-SM1490-BIDI |
Tx: 1490 Rx: 1550 |
LC |
9/125, SMF |
N/A |
70 km (43.50 miles) |
SFP-GE-LH70-SM1550-BIDI |
Tx: 1550 Rx: 1490 |
LC |
9/125, SMF |
N/A |
GE SFP cable |
SFP-STACK-Kit |
N/A |
N/A |
SFP cable |
N/A |
1.5 m (4.92 ft) |
IMPORTANT: The SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules, SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules, and SFP-GE-LH70-SM1490-BIDI and SFP-GE-LH70-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses the SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use the SFP-GE-LX-SM1490-BIDI transceiver module. |
Table7-7 FE SFP transceiver modules available for the 100/1000BASE-X SFP ports
FE SFP transceiver module |
Connector |
Fiber diameter (µm) |
SFP-FE-SX-MM1310-A |
1310 |
LC |
50/125, MMF |
2 km (1.24 miles) |
62.5/125, MMF |
SFP-FE-LX-SM1310-A |
1310 |
LC |
9/125, SMF |
15 km (9.32 miles) |
SFP-FE-LH40-SM1310 |
1310 |
LC |
9/125, SMF |
SFP-FE-BX15-U-SM1310 |
1310 |
LC |
9/125, SMF |
SFP-FE-LH80-SM1550 |
1550 |
LC |
9/125, SMF |
SFP-FE-LX-SM1310-BIDI |
Tx: 1310 Rx: 1550 |
LC |
9/125, SMF |
SFP-FE-LX-SM1550-BIDI |
Tx: 1550 Rx: 1310 |
LC |
9/125, SMF |
IMPORTANT: The SFP-FE-LX-SM1310-BIDI and SFP-FE-LX-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses the SFP-FE-LX-SM1310-BIDI transceiver module, the other end must use the SFP-FE-LX-SM1550-BIDI transceiver module. |
NOTE: · As a best practice, use H3C transceiver modules and network cables for the switch. · The H3C transceiver modules and network cables are subject to change over time. For the most recent list of H3C transceiver modules and cables, contact H3C Support or marketing staff. · For the specifications of H3C transceiver modules and network cables, see H3C Transceiver Modules User Guide. |
Table7-8 SFP+ port specifications
Item |
Specification |
Port type |
SFP+ port |
· GE SFP transceiver modules and cables in Table7-6 · 10-GE SFP+ transceiver modules and cables in Table7-9 |
S5580S-24T6X-EI, S5580S-48T6X-EI |
Restrictions and guidelines |
· To use transceiver modules with a maximum transmission distance ≥ 80 km (49.71 miles) on an S5580X-32T4X4YC-HI or S5580X-48T4YC-HI switch, make sure the ambient temperature is ≤ 45°C (113°F). · To use transceiver modules with a maximum transmission distance ≥ 80 km (49.71 miles) on an S5580X-32S8T4X4YC-HI switch, make sure the ambient temperature is ≤ 45°C (113°F). When the switch is fully configured with fiber ports, make sure the number of transceiver modules with a maximum transmission distance ≥ 40 km (24.86 miles) does not exceed 12. |
Table7-9 10-GE SFP+ transceiver modules and cables available for the SFP+ ports on the chassis
Transceiver module/cable model |
Connector |
SFP+ transceiver modules |
SFP-XG-SX-MM850-D |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-LX-SM1310 |
1310 |
LC |
9/125, SMF |
N/A |
SFP-XG-LX-SM1310-D |
1310 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH40-SM1550 |
1550 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH80-SM1550 |
1550 |
LC |
9/125, SMF |
N/A |
SFP-XG-LX-SM1270-BIDI |
Tx: 1270 Rx: 1330 |
LC |
9/125, SMF |
N/A |
SFP-XG-LX-SM1330-BIDI |
Tx: 1330 Rx: 1270 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH40-SM1270-BIDI |
Tx: 1270 Rx: 1330 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH40-SM1330-BIDI |
Tx: 1330 Rx: 1270 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH80-SM1490-BIDI |
Tx: 1490 Rx: 1550 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH80-SM1550-BIDI |
Tx: 1550 Rx: 1490 |
LC |
9/125, SMF |
N/A |
SFP+ copper cables |
LSWM1STK |
N/A |
N/A |
SFP+ copper cable |
N/A |
0.65 m (2.13 ft) |
LSWM2STK |
N/A |
N/A |
SFP+ copper cable |
N/A |
1.2 m (3.94 ft) |
LSWM3STK |
N/A |
N/A |
SFP+ copper cable |
N/A |
3 m (9.84 ft) |
LSTM1STK |
N/A |
N/A |
SFP+ copper cable |
N/A |
5 m (16.40 ft) |
SFP+ fiber cables |
SFP-XG-D-AOC-7M |
N/A |
N/A |
SFP+ fiber cable |
N/A |
7 m (22.97 ft) |
SFP-XG-D-AOC-10M |
N/A |
N/A |
SFP+ fiber cable |
N/A |
10 m (32.81 ft) |
SFP-XG-D-AOC-20M |
N/A |
N/A |
SFP+ fiber cable |
N/A |
20 m (65.62 ft) |
NOTE: · As a best practice, use H3C transceiver modules and network cables for the switch. · The H3C transceiver modules and network cables are subject to change over time. For the most recent list of H3C transceiver modules and cables, contact H3C Support or marketing staff. · The SFP-XG-LX-SM1270-BIDI and SFP-XG-LX-SM1330-BIDI transceiver modules must be used in pairs. For example, if one end uses the SFP-XG-LX-SM1270-BIDI transceiver module, the other end must use the SFP-XG-LX-SM1330-BIDI transceiver module. · For the specifications of H3C transceiver modules and network cables, see H3C Transceiver Modules User Guide. |
Figure7-1 SFP+ cable
(1) Connector |
(2) Pull latch |
Table7-10 SFP+ port specifications
Item |
Specification |
Port type |
SFP+ port |
· 10-GE SFP+ transceiver modules and cables in Table7-11 and Table7-12 · GE SFP transceiver modules and cables in Table7-13 and Table7-14 |
LSWM4SP8PM, LSWM2SP8PM, LSWM2SP8P |
Connector |
SFP-XG-LX-SM1310 |
1310 |
LC |
9/125, SMF |
N/A |
1310 |
LC |
9/125, SMF |
N/A |
SFP-XG-LX-SM1310-E |
1310 |
LC |
9/125, SMF |
N/A |
SFP-XG-SX-MM850-A |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-SX-MM850-D |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-SX-MM850-E |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
LSWM1STK |
N/A |
N/A |
N/A |
N/A |
0.65 m (2.13 ft) |
LSWM2STK |
N/A |
N/A |
N/A |
N/A |
1.2 m (3.94 ft) |
LSWM3STK |
N/A |
N/A |
N/A |
N/A |
3 m (9.84 ft) |
LSTM1STK |
N/A |
N/A |
N/A |
N/A |
5 m (16.40 ft) |
Connector |
SFP-XG-LX-SM1310 |
1310 |
LC |
9/125, SMF |
N/A |
1310 |
LC |
9/125, SMF |
N/A |
1310 |
LC |
9/125, SMF |
N/A |
SFP-XG-SX-MM850-A |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-SX-MM850-D |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-SX-MM850-E |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
LSWM1STK |
N/A |
N/A |
N/A |
N/A |
0.65 m (2.13 ft) |
LSWM2STK |
N/A |
N/A |
N/A |
N/A |
1.2 m (3.94 ft) |
LSWM3STK |
N/A |
N/A |
N/A |
N/A |
3 m (9.84 ft) |
LSTM1STK |
N/A |
N/A |
N/A |
N/A |
5 m (16.40 ft) |
Connector |
SFP-GE-SX-MM850-A |
850 |
LC |
50/125, MMF |
500 |
400 |
62.5/125, MMF |
200 |
275 m (902.23 ft) |
160 |
220 m (721.78 ft) |
SFP-GE-SX-MM850-D |
850 |
LC |
50/125, MMF |
500 |
400 |
62.5/125, MMF |
200 |
275 m (902.23 ft) |
160 |
220 m (721.78 ft) |
1310 |
LC |
9/125, SMF |
N/A |
50/125, MMF |
500/400 |
62.5/125, MMF |
500 |
SFP-GE-LX-SM1310-D |
1310 |
LC |
9/125, SMF |
N/A |
1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH40-SM1310-D |
1310 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH80-SM1550-D |
1550 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
Tx: 1310 Rx: 1490 |
LC |
9/125, SMF |
N/A |
Tx: 1490 Rx: 1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-T |
N/A |
RJ-45 |
N/A |
100 m (328.08 ft) |
SFP-GE-T-D |
N/A |
RJ-45 |
N/A |
100 m (328.08 ft) |
SFP copper cable |
SFP-STACK-Kit |
N/A |
N/A |
N/A |
N/A |
1.5 m (4.92 ft) |
Connector |
SFP-GE-SX-MM850-A |
850 |
LC |
50/125, MMF |
500 |
400 |
62.5/125, MMF |
200 |
275 m (902.23 ft) |
160 |
220 m (721.78 ft) |
SFP-GE-SX-MM850-D |
850 |
LC |
50/125, MMF |
500 |
400 |
62.5/125, MMF |
200 |
275 m (902.23 ft) |
160 |
220 m (721.78 ft) |
1310 |
LC |
9/125, SMF |
N/A |
50/125, MMF |
500/400 |
62.5/125, MMF |
500 |
1310 |
LC |
9/125, SMF |
N/A |
1310 |
LC |
9/125, SMF |
N/A |
1310 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH70-SM1550 |
1550 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
Tx: 1310 Rx: 1490 |
LC |
9/125, SMF |
N/A |
Tx: 1490 Rx: 1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-T |
N/A |
RJ-45 |
N/A |
100 m (328.08 ft) |
SFP-GE-T-D |
N/A |
RJ-45 |
N/A |
100 m (328.08 ft) |
SFP copper cable |
SFP-STACK-Kit |
N/A |
N/A |
N/A |
N/A |
1.5 m (4.92 ft) |
Table7-15 SFP28 port specifications
Item |
Specification |
Port type |
SFP28 port |
10-GE SFP+ transceiver modules and cables in Table7-9 25-GE SFP28 transceiver modules and cables in 2 |
S5580X-24T6Y-EI, S5580X-48T6Y-EI, S5580X-HI switch series |
Restrictions |
· Only the S5580X-24T6Y-EI and S5580X-48T6Y-EI switches support SFP-25G-SR-MM850-H, SFP-25G-LR-SM1310-I, and SFP-25G-CSR-MM850. · To use transceiver modules with a maximum transmission distance ≥ 80 km (49.71 miles) on an S5580X-32T4X4YC-HI or S5580X-48T4YC-HI switch, make sure the ambient temperature is ≤ 45°C (113°F). · To use transceiver modules with a maximum transmission distance ≥ 80 km (49.71 miles) on an S5580X-32S8T4X4YC-HI switch, make sure the ambient temperature is ≤ 45°C (113°F). When the switch is fully configured with fiber ports, make sure the number of transceiver modules (SFP-GE-T or SFP-GE-T-D) on GE SFP copper ports or transceiver modules with a maximum transmission distance ≥ 40 km (24.86 miles) does not exceed 12. · To use transceiver modules with a maximum transmission distance ≥ 80 km (49.71 miles) on an S5580X-48S4YC-HI switch, make sure the ambient temperature is ≤ 45°C (113°F). When the switch is fully configured with fiber ports, make sure the number of transceiver modules (SFP-GE-T or SFP-GE-T-D) on GE SFP copper ports or transceiver modules with a maximum transmission distance ≥ 40 km (24.86 miles) does not exceed 12. |
2. 25-GE SFP28 transceiver modules and cables available for the SFP28 ports on the chassis
Connector |
SFP28 transceiver modules |
SFP-25G-SR-MM850 |
850 |
LC |
50/125, MMF |
2000 |
70 m (229.66 ft) |
4700 |
100 m (328.08 ft) |
SFP-25G-SR-MM850-H |
850 |
LC |
50/125, MMF |
2000 |
70 m (229.66 ft) |
4700 |
100 m (328.08 ft) |
SFP-25G-LR-SM1310 |
1310 |
LC |
9/125, SMF |
N/A |
SFP-25G-LR-SM1310-I |
1310 |
LC |
9/125, SMF |
N/A |
SFP-25G-CSR-MM850 |
850 |
LC |
50/125, MMF |
2000 |
200 m (656.17 ft) |
> 3500 |
300 m (984.25 ft) |
> 5500 |
400 m (1312.34 ft) |
SFP28 copper cables |
SFP-25G-D-CAB-1M |
N/A |
N/A |
SFP28 copper cable |
N/A |
1 m (3.28 ft) |
SFP-25G-D-CAB-3M |
N/A |
N/A |
N/A |
3 m (9.84 ft) |
SFP-25G-D-CAB-5M |
N/A |
N/A |
N/A |
5 m (16.40 ft) |
SFP28 fiber cables |
SFP-25G-D-AOC-3M |
N/A |
N/A |
SFP28 fiber cable |
N/A |
3 m (9.84 ft) |
SFP-25G-D-AOC-5M |
N/A |
N/A |
SFP28 fiber cable |
N/A |
5 m (16.40 ft) |
SFP-25G-D-AOC-7M |
N/A |
N/A |
SFP28 fiber cable |
N/A |
7 m (22.97 ft) |
SFP-25G-D-AOC-10M |
N/A |
N/A |
SFP28 fiber cable |
N/A |
10 m (32.81 ft) |
SFP-25G-D-AOC-20M |
N/A |
N/A |
SFP28 fiber cable |
N/A |
20 m (65.62 ft) |
Table7-16 SFP28 port specifications
Item |
Specification |
Port type |
SFP28 port |
LSWM2ZSP8P |
2. 25G SFP28 transceiver modules and cables available for the SFP28 ports on the LSWM2ZSP8P interface module
Connector |
SFP-25G-SR-MM850 |
850 |
LC |
50/125, MMF |
2000 |
· FEC negotiation disabled: 30 m (98.43 ft) · FEC negotiation enabled: 70 (229.66 ft) |
4700 |
· FEC negotiation disabled: 40 m (131.23 ft) · FEC negotiation enabled: 100 m (328.08 ft) |
SFP-25G-D-CAB-1M |
N/A |
N/A |
SFP28 cable |
N/A |
1 m (3.28 ft) |
SFP-25G-D-CAB-3M |
N/A |
N/A |
SFP28 cable |
N/A |
3 m (9.84 ft) |
SFP-25G-D-CAB-5M |
N/A |
N/A |
SFP28 cable |
N/A |
5 m (16.40 ft) |
NOTE: · As a best practice, use H3C transceiver modules and cables for the switch. · The H3C transceiver modules and cables are subject to change over time. For the most recent list of H3C transceiver modules and cables, contact your H3C Support or marketing staff. · For more information about H3C transceiver modules and cables, see H3C Transceiver Modules User Guide. |
(1) Connector |
(2) Pull latch |
QSFP+ port
The LSWM2QP2P interface module provides two QSFP+ ports. Install QSFP+ transceiver modules and cables as described in Table7-17.
Table7-17 QSFP+ transceiver modules and cables available for the QSFP+ ports
Connector |
QSFP+ transceiver modules |
QSFP-40G-LR4-WDM1300 |
Four lanes: · 1271 · 1291 · 1311 · 1331 |
LC |
9/125, SMF |
N/A |
QSFP-40G-CSR4-MM850 |
850 |
MPO |
50/125, MMF |
2000 |
300 m (984.25 ft) |
4700 |
400 m (1312.33 ft) |
QSFP-40G-SR4-MM850 |
850 |
MPO |
9/125, SMF |
2000 |
100 m (328.08 ft) |
4700 |
150 m (492.12 ft) |
QSFP-40G-BIDI-SR-MM850 |
Two lanes: · 850 · 900 |
LC |
50/125, MMF |
2000 |
100 m (328.08 ft) |
4700 |
150 m (492.12 ft) |
QSFP-40G-LR4L-WDM1300 |
LC |
50/125, SMF |
2000 |
100 m (328.08 ft) |
4700 |
150 m (492.12 ft) |
QSFP-40G-ER4-WDM1300 |
LC |
50/125, SMF |
N/A |
2 km (1.24 miles) |
QSFP-40G-BIDI-WDM850 |
Four lanes: · 850 · 880 · 910 · 940 |
MMF |
50/125, SMF |
2000 |
240 m (787.40 ft) |
4700 |
350 m (1148.29 ft) |
QSFP+ copper cables |
LSWM1QSTK0 |
N/A |
N/A |
QSFP+ copper cable |
N/A |
1 m (3.28 ft) |
LSWM1QSTK1 |
N/A |
N/A |
N/A |
3 m (9.84 ft) |
LSWM1QSTK2 |
N/A |
N/A |
N/A |
5 m (16.40 ft) |
QSFP+ fiber cables |
QSFP-40G-D-AOC-3M |
N/A |
N/A |
QSFP+ fiber cable |
N/A |
3 m (9.84 ft) |
QSFP-40G-D-AOC-7M |
N/A |
N/A |
QSFP+ fiber cable |
N/A |
7 m (22.97 ft) |
SFP-40G-D-AOC-10M |
N/A |
N/A |
QSFP+ fiber cable |
N/A |
10 m (32.81 ft) |
QSFP-40G-D-AOC-20M |
N/A |
N/A |
QSFP+ fiber cable |
N/A |
20 m (65.62 ft) |
(1) QSFP+ module |
(2) Pull latch |
QSFP28 port
The LSWM2ZQP2P interface module provides two QSFP28 ports. Install QSFP28 transceiver modules and cables in Table7-18 or QSFP+ transceiver modules and cables in Table7-17.
Table7-18 QSFP28 transceiver modules and cables available for the QSFP28 ports
Connector |
QSFP-100G-SR4-MM850 |
850 |
MPO |
50/125, MMF |
2000 |
70 m (229.66 ft) |
4700 |
100 m (328.08 ft) |
QSFP-100G-LR4-WDM1300 |
Four lanes: · 195.56 · 1300.05 · 1304.58 · 1309.14 |
LC |
9/125, SMF |
2000 |
70 m (229.66 ft) |
N/A |
QSFP-100G-ER4L-WDM1300 |
LC |
9/125, SMF |
N/A |
2 km (1.24 miles) |
QSFP-100G-BIDI-MM850 |
Two lanes: · 855 · 908 |
LC |
50/125, MMF |
2000 |
70 m (229.66 ft) |
4700 |
100 m (328.08 ft) |
QSFP28 copper cables |
QSFP-100G-D-CAB-1M |
N/A |
N/A |
QSFP28 copper cable |
N/A |
1 m (3.28 ft) |
QSFP-100G-D-CAB-3M |
N/A |
N/A |
N/A |
3 m (9.84 ft) |
QSFP-100G-D-CAB-5M |
N/A |
N/A |
N/A |
5 m (16.40 ft) |
QSFP28 fiber cables |
QSFP-100G-D-AOC-7M |
N/A |
N/A |
QSFP28 fiber cable |
N/A |
7 m (22.97 ft) |
QSFP-100G-D-AOC-10M |
N/A |
N/A |
N/A |
10 m (32.81 ft) |
QSFP-100G-D-AOC-20M |
N/A |
N/A |
N/A |
20 m (65.62 ft) |
(1) QSFP28 module |
(2) Pull latch |
Table7-19 10/100/1000BASE-T Ethernet port specifications
Item |
Specification |
Connector type |
RJ-45 |
Rate, duplex mode, and auto-MDI/MDI-X |
100 m (328.08 ft) |
All switch models except for S5580X-48S4YC-HI |
Table7-20 5G/2.5G/1000BASE-T autosensing Ethernet port specifications
Item |
Specification |
Connector type |
RJ-45 |
· 5 Gbps, full duplex · 2.5 Gbps, full duplex · 1 Gbps, full duplex · MDI/MDI-X autosensing |
· 5G mode: ¡ 55 m (180.45 ft) over a Category 5e unshielded twisted pair (UTP) cable ¡ 100 m (328.08 ft) over a Category 5e shielded twisted pair (STP) cable ¡ 100 m (328.08 ft) over a Category 6 twisted pair cable ¡ 100 m (328.08 ft) over a Category 6a twisted pair cable · 2.5G mode: 100 m (328.08 ft) over a Category 5e or above twisted pair cable |
Standard |
· IEEE 802.3an · IEEE 802.3ab |
Table7-21 10G/5G/2.5G/1000BASE-T autosensing Ethernet port specifications
Item |
Specification |
Connector type |
RJ-45 |
· 10G mode: ¡ 55 m (180.45 ft) over a Category 6 UTP cable ¡ 100 m (328.08 ft) over a Category 6 STP cable ¡ 100 m (328.08 ft) over a Category 6a twisted pair cable · 5G mode: ¡ 55 m (180.45 ft) over a Category 5e UTP cable ¡ 100 m (328.08 ft) over a Category 5e STP cable ¡ 100 m (328.08 ft) over a Category 6 twisted pair cable ¡ 100 m (328.08 ft) over a Category 6a twisted pair cable · 2.5G mode: 100 m (328.08 ft) over a Category 5e or above twisted pair cable |
Standard |
Combo interface
Table7-22 Combo interface specifications
Item |
Specification |
Interface type |
Combo interface |
Interface composition |
A combo interface contains a 100/1000BASE-X SFP port and a 10/100/1000BASE-T autosensing Ethernet port. Only one of these two ports can operate at a time. |
S5580X-24T6Y-EI, S5580S-24T6X-EI, S5580X-32S8T4X4YC-HI |
Table7-23 Console port specifications
Item |
Specification |
Connector type |
RJ-45 |
RS-232 |
≤ 15 m (49.21 ft) over a common asynchronous serial interface cable |
Services |
· Provides connection to an ASCII terminal · Provides connection to the serial port of a local PC running terminal emulation program · Supports CLI |
Table7-24 10/100/1000BASE-T copper Ethernet port specifications
Item |
Specification |
Connector type |
RJ-45 |
802.3, 802.3u, and 802.3ab |
Port type |
Transmission distance |
100 m (328.08 ft) |
Rate and duplex mode |
· 10 Mbps, half/full duplex · 100 Mbps, half/full duplex · 1000 Mbps, full duplex |
Table7-25 Console port specifications
Item |
Specification |
Connector type |
RJ-45 |
EIA/TIA-232 |
115200 bps |
Services |
Table7-26 Management Ethernet port specifications
Item |
Specification |
Connector type |
RJ-45 |
· 1000 Mbps, full duplex · 100 Mbps, full duplex · 10 Mbps, full duplex |
Supported |
100 m (328.08 ft) |
IEEE 802.3i, 802.3u, and 802.3ab |
Connects to a local PC or remote station for network management or software upgrade |
Table7-27 USB port specifications
Item |
Specification |
Port type |
USB 3.0 |
xHCI |
5 Gbps |
Uploads or downloads files, such as software image file and configuration file, from the flash file system on the module. |
Table7-28 Console port specifications
Item |
Specification |
Connector type |
RJ-45 |
EIA/TIA-232 |
115200 bps |
Services |
Table7-29 Management Ethernet port specifications
Item |
Specification |
Connector type |
RJ-45 |
Supported |
Category-5 or above twisted pair cable |
100 m (328.08 ft) |
Table7-30 USB port specifications
Item |
Specification |
Port type |
USB 3.0 |
xHCI |
5 Gbps |
LEDs
System status LED
The system status LED shows the operating state of the switch.
Table7-31 System status LED description
LED mark |
Status |
SYS |
Steady green |
The switch has started correctly. |
Flashing green |
The switch is performing power-on self test (POST). |
Steady red |
The switch has failed POST or is faulty. |
Off |
The switch is powered off. |
Power supply status LED
For switches that support removable power supplies, the power supply status LEDs on the switch front panel indicate the operating state of the power supplies.
Table7-32 Power supply status LED description
LED mark |
Status |
PWR1/PWR2 |
Steady green |
A power supply is installed in the power supply slot, and the power supply is outputting power correctly. |
Steady yellow |
A power supply is installed in the power supply slot, but the power supply has failed or no power is input to the power supply. |
Off |
No power supply is installed in the power supply slot. |
Mode LED
For the switch model that has a mode button, the mode LED (MODE) works in conjunction with the port status LEDs to show more information about the switch.
The mode LED indicates the type of information that the port status LEDs are showing.
You can use the mode button to change the indication of the mode LED.
Table7-33 Mode LED description
LED mark |
Status |
MODE |
Steady green |
The port status LEDs indicate port rates. |
Flashing green (PoE model) |
The port status LEDs indicate the PoE power supply status. |
Table7-34 Management Ethernet port LED description
LED mark |
Status |
LINK/ACT |
Steady green |
A 1000 Mbps link is present on the port. |
Flashing green |
The port is sending or receiving data at 1000 Mbps. |
Steady yellow |
A 10/100 Mbps link is present on the port. |
Flashing yellow) |
The port is sending or receiving data at 10/100 Mbps. |
Off |
No link is present on the port. |
Table7-35 Description for the LEDs on an LSPM6FWD firewall module
LED mark |
Status |
LINK/ACT |
Steady green |
Flashing green |
The port is receiving or sending data at 1000 Mbps. |
Steady yellow |
Flashing yellow |
The port is receiving or sending data at 10/100 Mbps. |
Off |
ACT/LINK |
Off |
Steady green |
A link is present on the port. |
Flashing green |
The port is sending or receiving data. |
Table7-36 Management port LED description
LED status |
Steady green |
A 1000/100/10 Mbps link is present on the port. |
Flashing green |
The port is sending or receiving data at 1000/100/10 Mbps. |
Off |
Table7-37 Management port LED description
LED status |
Steady green |
Flashing green |
Off |
The 10/100/1000BASE-T autosensing Ethernet port LEDs work in conjunction with the mode LED to indicate the operating state of the ports from different aspects, as shown in Table7-38.
Table7-38 10/100/1000BASE-T autosensing Ethernet port LED description
Ethernet port LED status |
Mode LED (MODE) status |
Ethernet port LED |
Steady green (Link/Active mode) |
Steady green |
Flashing green |
Steady yellow |
Flashing yellow |
Off |
Flashing green (PoE mode) |
Steady green |
PoE power supply is normal. |
Flashing green (1 Hz) |
· The maximum PoE power provided by the port fails to meet the power requirement of the PD. · The remaining power of the switch fails to meet the power supply requirement of the port. |
Steady yellow |
The port has failed to supply power. |
Flashing yellow (3 Hz) |
POST has failed on the port. |
Off |
The port is not supplying power through PoE. |
The LSWM2MGT8P interface module provides eight 5G/2.5G/1000BASE-T autosensing Ethernet ports. Table7-39 shows the description for the 5G/2.5G/1000BASE-T autosensing Ethernet port LEDs.
Table7-39 5G/2.5G/1000BASE-T autosensing Ethernet port LED description
LED status |
Steady green |
A 5 Gbps link is present on the port. |
Flashing green |
The port is sending or receiving data at 5 Gbps. |
Steady yellow |
A 1/2.5 Gbps link is present on the port. |
Flashing yellow |
The port is sending or receiving data at 1/2.5 Gbps. |
Off |
The LSWM2XMGT8P interface module provides eight 10G/5G/2.5G/1000BASE-T autosensing Ethernet ports. Table7-40 shows the description for the 10G/5G/2.5G/1000BASE-T autosensing Ethernet port LEDs.
Table7-40 10G/5G/2.5G/1000BASE-T autosensing Ethernet port LED description
LED status |
Steady green |
A 10 Gbps link is present on the port. |
Flashing green |
The port is sending or receiving data at 10 Gbps. |
Steady yellow |
A 1/2.5/5 Gbps link is present on the port. |
Flashing yellow |
The port is sending or receiving data at 1/2.5/5 Gbps. |
Off |
SFP port LED
Table7-41 SFP port LED description
LED status |
Steady green |
Flashing green |
Steady yellow |
A 100 Mbps link is present on the port. |
Flashing yellow |
The port is sending or receiving data at 100 Mbps. |
Off |
SFP+ port LED
Table7-42 SFP+ port LED description
SFP+ port LED status |
Steady green |
Flashing green |
Steady yellow |
A 1 Gbps link is present on the port. |
Flashing yellow |
The port is sending or receiving data at 1 Gbps. |
Off |
No link is present on the port. The MODE LED is operating in PoE mode (supported only on PoE models). |
SFP28 port LED
Table7-43 SFP28 port LED description
SFP28 port LED status |
Steady green |
A 25 Gbps link is present on the port. |
Flashing green |
The port is sending or receiving data at 25 Gbps. |
Steady yellow |
Flashing yellow |
Off |
QSFP+ port LED
The LSWM2QP2P interface module provides two QSFP+ ports. Table7-44 shows the description for the QSFP+ port LEDs.
Table7-44 QSFP+ port LED description
LED status |
Steady green |
A module has been installed in the port. A link is present on the port and the port is operating at 40 Gbps. |
Flashing green |
The port is sending or receiving data at 40 Gbps. |
Steady yellow |
A module has been installed in the port. A link is present on the port and the port is operating at 10 Gbps. |
Flashing yellow |
Off |
No module has been installed or no link is present on the port. |
QSFP28 port LED
The LSWM2ZQP2P interface module provides two QSFP28 ports. Table7-45 shows the description for the QSFP28 port LEDs.
Table7-45 QSFP28 port LED description
LED status |
Steady green |
A module has been installed in the port. A link is present on the port and the port is operating at 100 Gbps. |
Flashing green |
The port is sending or receiving data at 100 Gbps. |
Steady yellow |
Flashing yellow |
Off |
Expansion card status LED
For switch models that support expansion cards, the expansion card status LED on the front panel indicates the operating status of the expansion card.
Table7-46 Expansion card status LED description
LED mark |
Status |
SLOT |
Steady green |
The expansion card is operating correctly. |
Flashing yellow |
The switch does not support the expansion card model, or the expansion card is faulty. |
Off |
The expansion slot is empty. |
Status LED on a fan tray
Table7-47 Description for the status LED on a FAN-40B-1-F/FAN-40F-1-F fan tray
Status |
Off |
The fan tray is operating correctly. |
Steady yellow |
The fan tray is operating incorrectly. |
Table7-48 Description for the status LED on an LSPM1FANSA-SN/LSPM1FANSB-SN fan tray
Status |
Off |
Steady on |
The PSR600-54A-B, PSR920-54A-B, and PSR1600-54A-B power supplies each have two status LEDs to indicate the power input and output status.
Table7-49 Description for the status LEDs on a 600W/920W/1600W power supply
LED |
Mark |
Status |
Output status LED |
OUT OK |
Steady green |
Normal power output. |
Steady red |
Abnormal power output. |
Off |
No power output |
Input status LED |
IN OK |
Steady green |
Normal power input. |
Steady red |
Abnormal power input. |
Off |
No power input. |
8 Cooling system
To dissipate heat timely and enhance system stability, the switch uses a high-performance cooling system. Consider the site ventilation design when you plan the installation site for the switch.
For switches that support removable fan trays, you can provide airflow from the power supply side to the port side or from the port side to the power supply side for the switch by using different fan trays. For heat dissipation, you must install two fan trays of the same model for the switch. Table8-1 describes fan trays available for the switch.
Table8-1 Fan trays available for the switch
Device model |
Fan tray type |
Airflow direction |
Removable fan tray: LSBM1FAN4020B (FAN-40B-1-F) |
From the power supply side to the port side (S5580X-48T6Y-EI as an example) |
Removable fan tray: LSBM1FAN4020F (FAN-40F-1-F) |
From the port side to the power supply side (S5580X-48T6Y-EI as an example) |
Fixed fan trays |
From the left side and port side to the right side (S5580S-24T6X-EI as an example) |
Removable fan tray: LSPM1FANSA-SN |
From the port side to the power supply side (S5580X-48T4YC-HI as an example) |
S5580X-32S8T4X4YC-HI S5580X-48S4YC-HI S5580X-32T4X4YC-HI S5580X-48T4YC-HI S5580X-32P4X4YC-HI S5580X-48P4YC-HI |
Removable fan tray: LSPM1FANSB-SN |
From the power supply side to the port side (S5580X-48T4YC-HI as an example) |
