H3C S5590-HI[EI] Switch Series Hardware Information and Specifications-6W106
HomeSupportSwitchesS5590-EI SeriesProduct LiteratureHardware Information & SpecificationsH3C S5590-HI[EI] Switch Series Hardware Information and Specifications-6W106
00-Preface
00-Preface 59.69 KB
Preface
Hardware Information and Specifications describes product models, technical specifications, ports,and LEDs.
Audience
·     Network planners.
·     Technical support and servicing engineers.
·     Network administrators.
Conventions
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Examples in this document might use devices that differ from your device in hardware model, configuration, or software version. It is normal that the physical port numbers, sample output, screenshots, and other information in the examples differ from what you have on your device.
Documentation feedback
We appreciate your comments.
