03-Layer 2—LAN Switching Configuration Guide
HomeSupportSwitchesS9850-G SeriesTechnical DocumentsConfigure & DeployConfiguration GuidesH3C S6850-G&S6805-G&S9850-G Switch Series Configuration Guides-R8307Pxx-6W10103-Layer 2—LAN Switching Configuration Guide
16-Service loopback group configuration
16-Service loopback group configuration 48.02 KB
Configuring service loopback groups
About service loopback groups
A service loopback group loops packets sent out by the device back to the device. This feature must work with other features. In the current software version, a service loopback group can be applied only to the EVPN VXLAN gateway service.
Restrictions and guidelines: Service loopback group configuration
When you apply service loopback groups to features, follow these restrictions and guidelines:
·     You can apply a service loopback group to a feature once the group is created. The service loopback group will process services for the feature.
·     Do not delete a service loopback group that is being used by a feature.
Configuring a service loopback group
2.     Create a service loopback group and specify its service type.
service-loopback group group-id type  vsi-gateway
You can configure only one service loopback group for a service type.
Display and maintenance commands for service loopback groups
Display information about service loopback groups.
display service-loopback group [ group-id ]
