- 05-Layer 3—IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-RIP commands
- 04-OSPF commands
- 05-IS-IS commands
- 06-BGP commands
- 07-Policy-based routing commands
- 08-IPv6 static routing commands
- 09-RIPng commands
- 10-OSPFv3 commands
- 11-IPv6 policy-based routing commands
- 12-Routing policy commands
- 13-DCN commands
- 14-Dual-stack PBR commands
| 08-IPv6 static routing commands | 149.99 KB |
delete ipv6 static-routes all
Use delete ipv6 static-routes all to delete all IPv6 static routes.
delete ipv6 [ vpn-instance vpn-instance-name ] static-routes all
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command deletes all IPv6 static routes for the public network.
CAUTION: Deleting all IPv6 static routes with caution. This operation might cause network connectivity failure and packet forwarding failure. |
When you use this command, the system will prompt you to confirm the operation before deleting all the IPv6 static routes.
# Delete all IPv6 static routes.
[Sysname] delete ipv6 static-routes all
This will erase all IPv6 static routes and their configurations, you must reconfigure all static routes.
Are you sure?[Y/N]:y
ipv6 route-static
display ipv6 route-static nib
Use display ipv6 route-static nib to display IPv6 static route next hop information.
display ipv6 route-static nib [ nib-id ] [ verbose ]
nib-id: Specifies a NIB by its ID, a hexadecimal string in the range of 1 to ffffffff.
verbose: Displays detailed IPv6 static route next hop information. If you do not specify this keyword, the command displays brief IPv6 static route next hop information.
# Display brief IPv6 static route next hop information.
<Sysname> display ipv6 route-static nib
Total number of nexthop(s): 35
NibID: 0x21000000 Sequence: 0
Type: 0x41 Flushed: Yes
Age: 00h01m50s
UserKey0: 0x0 VrfNthp: 0
UserKey1: 0x0 Nexthop: 2::3
IFIndex: 0x0 LocalAddr: ::
NewUK0: 0x0 NewUK1: 0x0
NewUK2: 0x0 NewUK3: 0x0
NewUK4: 0x0 NewUK5: 0x0
NewUK6: 0x0 NewUK7: 0x0
TopoNthp: Invalid ExtType: 0x0
FIRType: Normal Threshold: 0
NibID: 0x21000001 Sequence: 1
Age: 00h01m50s
UserKey1: 0x0 Nexthop: 3::4
NibID |
ID of the NIB. |
Sequence |
Sequence number of the NIB. |
Type |
Type of the NIB. |
Flushed |
Indicates whether the route with the NIB has been flushed to the FIB. |
Age |
Elapsed time since the next hop information was last updated. |
UserKey0 |
Reserved data 1. |
UserKey1 |
Reserved data 2. |
VrfNthp |
Index of the VPN instance to which the next hop belongs. This field displays 0 if the next hop is on the public network. |
Nexthop |
Next hop address. |
IFIndex |
Interface index |
LocalAddr |
Local interface address. |
NewUK0 |
New reserved data 1. |
NewUK1 |
New reserved data 2. |
NewUK2 |
New reserved data 3. |
NewUK3 |
New reserved data 4. |
NewUK4 |
New reserved data 5. |
NewUK5 |
New reserved data 6. |
NewUK6 |
New reserved data 7. |
NewUK7 |
New reserved data 8. |
TopoNthp |
This field is not supported in the current software version. Index of the topology that contains the next hop. This field displays 0 if the next hop is on the public network. This field displays Invalid if the next hop is on an IPv6 network, because the router does not support non-base topologies. |
ExtType |
NIB extension type. |
FIRType |
This field is not supported in the current software version. Type of the link for the next hop in FIR ECMP mode: · Normal. · Primary. · Secondary. |
Threshold |
Bandwidth usage level of primary links in FIR ECMP mode. |
# Display detailed IPv6 static route next hop information.
<Sysname> display ipv6 route-static nib verbose
Age: 00h01m50s
RefCnt: 1 FlushRefCnt: 0
Flag: 0x12 Version: 1
ExtFlag: 0x0
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 2::3
RelyDepth: 2 RealNexthop: ::
Interface: NULL0 LocalAddr: ::
TunnelCnt: 0 Vrf: default-vrf
TunnelID: N/A Topology:
Weight: 0 Flags: 0x0
RealFIRType: Normal RealThres: 0
Age: 00h01m50s
ExtFlag: 0x0
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 3::4
RelyDepth: 1 RealNexthop: ::
Interface: Vlan11 LocalAddr: ::
Total number of nexthop(s) |
Total number of NIBs. |
NibID |
NIB ID. |
Sequence |
NIB sequence number. |
Type |
NIB type. |
Flushed |
Age |
UserKey0 |
Reserved data 1. |
UserKey1 |
Reserved data 2. |
VrfNthp |
Nexthop |
Next hop address. |
IFIndex |
Interface index |
LocalAddr |
NewUK0 |
NewUK1 |
NewUK2 |
NewUK3 |
NewUK4 |
NewUK5 |
NewUK6 |
NewUK7 |
TopoNthp |
Non-base topologies are not supported in the current software version. Index of the topology that contains the next hop. This field displays 0 if the next hop is on the public network. This field displays Invalid if the next hop is on an IPv6 network, because the router does not support non-base topologies. |
ExtType |
FIRType |
Threshold |
RefCnt |
Reference count of the next hop. |
FlushRefCnt |
Reference count of the next hop that is flushed to the FIB. |
Flag |
Flag of the next hop. |
Version |
Version of the next hop. |
ExtFlag |
Extended flag of the next hop. |
x nexthop(s) |
Number of next hops. |
PrefixIndex |
Prefix index of the next hop for an ECMP route. |
OrigNexthop |
Original next hop. |
RealNexthop |
Real next hop. |
Output interface. |
localAddr |
RelyDepth |
Recursion depth. |
TunnelCnt |
Number of tunnels after route recursion. |
Vrf |
VPN instance name. For the public network, this field displays default-vrf. |
TunnelID |
ID of the tunnel after route recursion. |
Topology |
This field is not supported in the current software version. Topology name. This field is blank for IPv6, because IPv6 does not support non-base topologies. |
Weight |
ECMP route weight. This field displays 0 for non-ECMP routes. |
Flags |
Flags of the next hop. |
RealFIRType |
This field is not supported in the current software version. Type of the link for the real next hop in FIR ECMP mode: · Normal. · Primary. · Secondary. The real next hop is the direct next hop found after route recursion. |
RealThres |
Bandwidth usage level of the primary link to which the real next hop is attached in FIR ECMP mode. |
display ipv6 route-static routing-table
Use display ipv6 route-static routing-table to display IPv6 static routing table information.
display ipv6 route-static routing-table [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays IPv6 static routing table information for the public network.
ipv6-address: Specifies the destination IPv6 address.
prefix-length: Specifies the prefix length in the range of 0 to 128.
# Display IPv6 static routing table information.
<Sysname> display ipv6 route-static routing-table
Total number of routes: 5
Status: * - valid
*Destination: 1::1/128
NibID: 0x21000000 NextHop: 2::2
MainNibID: N/A BkNextHop: N/A
BkNibID: N/A Interface: Vlan-interface11
TableID: 0xa BkInterface: N/A
Flag: 0x80d0a BfdSrcIp: N/A
DbIndex: 0x3 BfdIfIndex: 0x0
Type: Normal BfdVrfIndex: 0
TrackIndex: 0xffffffff Label: NULL
Preference: 60 vrfIndexDst: 0
BfdMode: N/A vrfIndexNH: 0
Permanent: 0 Tag: 0
MicroSegID: 0 RecurseMaskLen: N/A
FIRLicense: Unrestricted
*Destination: 1::1234/128
BkNibID: N/A Interface: NULL0
DbIndex: 0x1 BfdIfIndex: 0x0
Permanent: 0 Tag: 0
Destination |
Destination address/prefix. |
NibID |
ID of the NIB. |
MainNibID |
ID of the primary next hop for static route FRR. |
BkNibID |
ID of the backup next hop for static route FRR. |
NextHop |
Next hop address. |
BkNextHop |
Backup next hop address. |
Output interface of the route. |
BkInterface |
Backup output interface. |
TableID |
ID of the table to which the route belongs. |
DbIndex |
Index of the database to which the route belongs. |
Type |
Route type: · Normal. · DHCP. · IPSGT. |
BfdSrcIp |
Source IPv6 address of the indirect BFD session. |
BfdIfIndex |
Index of the interface where BFD is enabled. |
BfdVrfIndex |
Index of the VPN instance where BFD is enabled. This field displays 0 if BFD is enabled for the public network. |
BfdMode |
BFD session mode: · N/A—No BFD session is configured. · Ctrl—Control packet mode. |
TrackIndex |
NQA Track index. |
vrfIndexDst |
Index of the VPN instance to which the destination belongs. For the public network, this field displays 0. |
vrfIndexNH |
Index of the VPN instance to which the next hop belongs. For the public network, this field displays 0. |
Permanent |
Permanent static route flag. 1 indicates a permanent static route. |
FIRType |
Threshold |
This field is not supported in the current software version. Bandwidth usage level of primary links in FIR ECMP mode. |
MicroSegID |
This field is not supported in the current software version. Microsegment ID in the route. |
RecurseMaskLen |
Exact mask length for route recursion. If the device uses the longest match principle for route recursion, this field displays N/A. |
FIRLicense |
This field is not supported in the current software version. License process status for the static route FIR mode: · Unrestricted—The static route FIR mode is not controlled by license. · Disconnected—The static route FIR mode is controlled by license, but the static route is not connected to the license process. Please check whether the license process is abnormal. · Active—The license for controlling the static route FIR mode is active. · Inactive—The license for controlling the static route FIR mode is inactive. For more information about licenses, see license management in Fundamentals Configuration Guide. |
ipv6 route-static
Use ipv6 route-static to configure an IPv6 static route.
Use undo ipv6 route-static to remove an IPv6 static route.
ipv6 route-static ipv6-address prefix-length interface-type interface-number [ next-hop-address ] [ bfd control-packet [ bfd-source ipv6-address ] | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ipv6 route-static ipv6-address prefix-length interface-type interface-number next-hop-address track-nd [ preference preference ] [ tag tag-value ] [ description text ]
ipv6 route-static ipv6-address prefix-length [ vpn-instance d-vpn-instance-name ] next-hop-address [ recursive-lookup host-route ] [ bfd control-packet bfd-source ipv6-address | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
undo ipv6 route-static ipv6-address prefix-length [ interface-type interface-number [ next-hop-address ] | [ vpn-instance d-vpn-instance-name ] next-hop-address ] [ preference preference ]
ipv6 route-static ipv6-address prefix-length vpn-instance d-vpn-instance-name [ preference preference ] [ tag tag-value ] [ description text ]
undo ipv6 route-static ipv6-address prefix-length [ vpn-instance d-vpn-instance-name ] [ preference preference ]
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length interface-type interface-number [ next-hop-address ] [ bfd control-packet [ bfd-source ipv6-address ] | permanent | track track-entry-number ] } [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length interface-type interface-number next-hop-address track-nd [ preference preference ] [ tag tag-value ] [ description text ]
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length { next-hop-address [ recursive-lookup host-route ] [ public ] [ bfd control-packet bfd-source ipv6-address | permanent | track track-entry-number ] | vpn-instance d-vpn-instance-name next-hop-address [ recursive-lookup host-route ] [ bfd control-packet bfd-source ipv6-address | permanent | track track-entry-number ] } [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
undo ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length [ interface-type interface-number [ next-hop-address ] | next-hop-address [ public ] | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference ]
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length { public | vpn-instance d-vpn-instance-name } [ preference preference ] [ tag tag-value ] [ description text ]
undo ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length [ public | vpn-instance d-vpn-instance-name ] [ preference preference ]
No IPv6 static route is configured.
ipv6-address prefix-length: Specifies the IPv6 address and prefix length.
interface-type interface-number: Specifies an output interface by its type and number. If the output interface is an NBMA interface or broadcast interface and not a point-to-point (P2P) interface, the next hop address must be specified.
next-hop-address: Specifies the next hop IPv6 address.
recursive-lookup host-route: Specifies only host routes for IPv6 static route recursion.
bfd: Enables BFD to detect reachability of the static route's next hop.
control-packet: Specifies the BFD control packet mode.
bfd-source ipv6-address: Specifies the source IPv6 address of BFD packets.
permanent: Specifies the IPv6 route as a permanent IPv6 static route. After you specify this keyword, the static route will always be active, even if the output interface is down.
track track-entry-number: Associates the IPv6 static route with a track entry specified by its number in the range of 1 to 1024. For more information about Track, see High Availability Configuration Guide.
public: Specifies the public network. If you specify this keyword following the next-hop-address argument, the next hop is on the public network. The device searches for the output interface in the public network based on the next hop address for packets matching the IPv6 static route. If you specify the next-hop-address argument without specifying the public keyword, the device searches for the output interface in the source VPN instance based on the next hop address for packets matching the IPv6 static route. If you specify the public keyword without specifying the next-hop-address argument, the device searches for the output interface in the public network for packets matching the IPv6 static route.
vpn-instance d-vpn-instance-name: Specifies a destination MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify the next-hop-address argument following this option, the device searches for the output interface in the specified destination VPN instance for packets matching the IPv6 static route. If you specify the next-hop-address argument and this option, the device searches for the output interface in the specified destination VPN instance based on the specified next hop address for packets matching the IPv6 static route. If you specify a destination VPN instance without specifying a next hop address, the destination VPN instance cannot be the same as the source VPN instance.
track-nd: Associates the IPv6 static route with the ND entry corresponding to the next hop of the IPv6 static route. If you specify this keyword and the ND entry corresponding to the next hop of the IPv6 static route does not exist, the system will not activate the IPv6 static route. If you do not specify this keyword, the activation status of the IPv6 static route is irrelevant to the ND entry. As a best practice when you use this keyword, use the ipv6 route-static nd-request command to configure the device to periodically send ND requests to the next hop of the IPv6 static route to prevent the ND entry from aging and causing the IPv6 static route to become inactive.
preference preference: Specifies a preference for IPv6 static routes, in the range of 1 to 255. The default is 60.
tag tag-value: Sets a tag for marking the static route, in the range of 1 to 4294967295. The default is 0. Tags of routes are used for route control in routing policies. For more information about routing policies, see Layer 3—IP Routing Configuration Guide.
recursive-lookup: Enables support for next hop recursion loops for the IPv6 static route. If you do not specify this keyword, the device does not support next hop recursion loops for the IPv6 static route.
description text: Configures a description for the IPv6 static route, which consists of 1 to 60 characters, including special characters such as the space, but excluding the question mark (?).
vpn-instance s-vpn-instance-name: Specifies a source MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. Each VPN has its own routing table, and the configured static route is installed in the routing tables of the specified VPNs.
An IPv6 static route that has the destination address configured as ::/0 (a prefix length of 0) is the default IPv6 route. If the destination address of an IPv6 packet does not match any entry in the routing table, this default route is used to forward the packet.
Follow these guidelines to configure the output interface, next hop address, or both for a static route:
· If the output interface is a broadcast interface or an NBMA interface, the next hop address must be specified.
· If the output interface is a P2P interface, you can specify only the output interface. You do not need to change the configuration of the route even if the peer address is changed.
Follow these guidelines when you configure BFD for IPv6 static routes:
· If you specify a source IPv6 address for BFD packets on the local device, you must specify that IPv6 address as the next hop IPv6 address on the peer device.
· If you specify a non-P2P output interface and a direct next hop, specify the bfd-source ipv6-address option as a best practice. Make sure the source IPv6 address of BFD packets meets the following requirements:
¡ The address is the same as the IPv6 address of the output interface.
¡ The address is on the same network segment as the next hop IPv6 address of the same type.
For example, if the next hop IPv6 address is a link-local address, the source IPv6 address of BFD packets must also be a link-local address.
· Enabling BFD for a flapping route could worsen the route flapping situation. Therefore, use it with caution. For more information about BFD, see High Availability Configuration Guide.
To specify the recursive-lookup host-route keyword, you must use the ipv6 nd route-direct advertise command to enable ND direct route advertisement to advertise 128-bit host routes on the following interfaces:
· The output interface corresponding to the next hop of the static route.
· The peer interface connected to the output interface.
For IPv6 static routing-Track-NQA collaboration, you must configure the same VPN instance ID for the next hop to be detected and the NQA operation.
A recursion loop occurs when an IPv6 static route recurses to a related route whose destination address contains the destination address of the IPv6 static route. For example, a recursion loop occurs when the IPv6 static route destined for 4::2/64 recurses to a related route whose destination address is 4::2/48.
· If the recursive-lookup keyword is not specified, the recursion loop results in route recursion failure. The device further looks up for a related route.
· If the recursive-lookup keyword is specified, the device determines that the recursion succeeds if the output interface of the related route is an interface directly connected to the device.
If the output interface of an IPv6 static route is found through recursion loops, routing protocols on the device cannot advertise the IPv6 static route to other devices.
The recursive-lookup host-route and recursive-lookup keywords are mutually exclusive. You cannot specify both of the keywords.
# Configure an IPv6 static route, with the destination address 1:1:2::/64 and next hop 1:1:3::1.
[Sysname] ipv6 route-static 1:1:2:: 64 1:1:3::1
display ipv6 routing-table protocol
ipv6 nd route-direct advertise (Layer 3—IP Services Command Reference)
ipv6 route-static default-preference
Use ipv6 route-static default-preference to set a default preference for IPv6 static routes.
Use undo ipv6 route-static default-preference to restore the default.
ipv6 route-static default-preference default-preference
The default preference of IPv6 static routes is 60.
default-preference: Specifies a default preference for IPv6 static routes, in the range of 1 to 255.
If no preference is specified for an IPv6 static route, the default preference applies.
When the default preference is reconfigured, it applies only to newly added IPv6 static routes.
# Set a default preference of 120 for IPv6 static routes.
[Sysname] ipv6 route-static default-preference 120
Use ipv6 route-static nd-request to enable periodic sending of ND requests to the next hops of IPv6 static routes.
Use undo ipv6 route-static nd-request to disable periodic sending of ND requests to the next hops of IPv6 static routes.
ipv6 route-static nd-request [ interval interval ]
Periodic sending of ND requests to the next hops of IPv6 static routes is disabled.
interval: Specifies an ND request sending interval in the range of 1 to 300 seconds. The default value is 5.
As a best practice, use this command when the following types of IPv6 static routes exist on the device:
· IPv6 static routes that recurse to host routes, which include the following IPv6 static routes:
¡ IPv6 static routes with the recursive-lookup host-route keywords specified to recurse only to host routes.
¡ IPv6 static routes that recurse to host routes according to routing policies (configured by using the protocol nexthop recursive-lookup command).
The device might delete the ND entry for the next hop host address of an IPv6 static route after that entry ages out because the device cannot update that entry in time. As a result, the device does not have the host route of the directly connected device in the IPv6 routing table for that IPv6 static route. In this case, route recursion fails and that IPv6 static route cannot be activated.
· IPv6 static routes with the track-nd keyword specified to associate their next hops with the ND entries for these next hops. The device might delete the ND entry for the next hop address of an IPv6 static route after that entry ages out because the device cannot update that entry in time. As a result, that IPv6 static route cannot be activated.
For IPv6 static routes that recurse to host routes, the ipv6 route-static nd-request command enables the device to periodically send ND requests to the next hops of the IPv6 static routes that meet the following requirements:
· The IPv6 static routes have no output interfaces specified.
· The IPv6 static routes fail the next-hop recursion.
When the device receives an ND response from the next hop host of an IPv6 static route, it automatically performs the following operations:
1. Adds the host route to the routing table.
2. Activates the IPv6 static route that recurses to the host route.
3. Stops sending ND requests to the host.
For IPv6 static routes with the track-nd keyword specified, the ipv6 route-static nd-request command enables the device to periodically send ND requests to the next hops of the IPv6 static routes associated with next hop ND entries. When the device receives an ND response from the next hop of an IPv6 static route, it automatically activates that IPv6 static route and stops sending ND requests to the next hop of that IPv6 static route.
For more information about ND, see IPv6 neighbor discovery in Layer 3—IP Services Configuration Guide.
# Enable sending of ND requests to the next hops of IPv6 static routes and set the sending interval to 10 seconds.
[Sysname] ipv6 route-static nd-request interval 10
ipv6 route-static
