H3C WA7200 Series Access Points Hardware Information and Specifications-6W102
HomeSupportWirelessWA7200 Series Access PointsTechnical DocumentsProduct LiteratureHardware Information & SpecificationsH3C WA7200 Series Access Points Hardware Information and Specifications-6W102
01-Text
01-Text 1.30 MB
Product overview
The WA7200 AP series includes the following models:
Table1-1 WA7200 AP series
Product code
Product model
Remarks
EWP-WA7220-HI-FIT
WA7220-HI
Indoor AP
EWP-WA7220CE
WA7220CE
EWP-WA7232-FIT
WA7232
EWP-WA7220X-FIT
WA7220X
Outdoor AP
AP views, ports, and technical specifications
WA7220CE
AP view and dimensions
Figure1-1 AP view
Figure1-2 AP dimensions
Ports
The AP provides the following ports:
·     One 10GE/SFP port.
·     One GE/PoE+ port.
·     Three GE ports.
·     One RS-485/232 (console) port.
·     One power receptacle (12 to 36 VDC).
The AP also provides a reset button.
Figure1-3 Ports
(1) Power receptacle (12 to 36 VDC)
(2) RS-485/232 (console) port
(3) 10GE/SFP port
(4) Reset button
(5) GE1/PoE+ Port
(6) GE port
Technical specifications
Table1-2 Technical specifications
Item
Specification
Dimensions (H × W × D)
38 × 179.5 × 128 mm (1.50 × 7.07 × 5.04 in, excluding the mounting bracket)
Weight
1.15 kg (2.54 lb)
Power consumption
≤ 18 W
Antenna
External antenna
Standard compliance
·     IEEE802.11a/b/g/n/ac/ax/be
·     IEEE802.3at
Powering option
·     12 to 36 VDC power source
·     PoE compliant with 802.3at
Operating temperature
–40°C to +60°C (–40°F to +140°F)
Storage temperature
–40°C to +85°C (–40°F to +185°F)
Operating humidity
5% RH to 95% RH, noncondensing
Storage humidity
Operating altitude
–60 m to +5000 m (–196.85 ft to +16404.20 ft)
Used by technical personnel only for device configuration and management.
GE
10/100/1000M copper Ethernet port.
GE1/PoE+
The 100/1000M copper Ethernet port is used for connecting the device to an uplink device for Internet or MAN access. It can operate at 1 Gbps and also act as an 802.3at-compliant PoE+ port.
10GE/SFP
1000M/2.5G/5G/10G fiber port.
Used for receiving 12 VDC to 36 VDC power from a local power source.
Reset button
The function of the reset button varies by duration for which it is pressed. For more information, see "LED description for the reset button."
LEDs
Yellow/green/blue. For more information about the LED status in different AP operating modes, see "LED descriptions for single-LED APs."
WA7220-HI
Figure1-4 AP view
Figure1-5 AP dimensions
Ports
·     One 54 VDC power receptacle.
·     One 2.5GE1/PoE+ port.
·     One 2.5GE2/PSE port.
·     One console port.
·     One USB port.
The AP also provides a reset button and a security slot with a size of 7 × 3 mm (0.28 × 0.12 in).
Figure1-6 Ports (1)
(1) 54 VDC power receptacle
(2) 2.5GE1/PoE+ port
(3) 2.5GE2/PSE port
(4) Console port
(5) USB port
(6) Security slot
Figure1-7 Ports (2)
(1) Reset button
Table1-3 Technical specifications
Item
Specification
40 × 220 × 220 mm (1.57 × 8.66 × 8.66 in, excluding the mounting bracket)
Weight
0.67 kg (1.48 lb)
Power consumption
Support for local DC power supply and PoE power supply:
·     Local power supply:
¡     ≤ 33.9 W (including PoE_OUT/USB)
¡     ≤ 16.4 W (excluding PoE_OUT/USB)
·     PoE power reception compliant with 802.3at:
¡     ≤ 26.1 W (PoE_OUT port supplying power, radios in 1×1 MIMO mode, and excluding USB)
¡     ≤ 18.9 W (PoE_OUT port not supplying power and including USB)
·     PoE power reception compliant with 802.3af: ≤ 13.6 W (PoE_OUT port not supplying power, radios in 1×1 MIMO mode, and including USB)
Antenna
Built-in antenna
Standard compliance
·     802.11a/b/g/n/ac/ax/be
·     802.3af/at
Powering option
IEEE802.3af/at powering standard-compliant:
·     Power adapter
·     PoE+ (802.3at)
·     PoE (802.3af)
–10°C to +50°C (14°F to 122°F)
Storage temperature
–40°C to +70°C (–40°F to +158°F)
Operating humidity
Storage humidity
Operating altitude
Console port
2.5GE1/PoE+
100M/1000M/2.5G copper Ethernet port, used for connecting the AP to an uplink device for Internet or MAN access. It can also act as a standard PoE port.
When the AP operates in fit AP mode, the port is represented by interface number SGE1/0/1 in the MAP file and Smartrate-Ethernet 1 for configuration on the AC.
2.5GE2/PSE
100/1000/2500M copper Ethernet port, used for connecting a downlink device. The AP can supply power through this port to a standard PD.
When the AP operates in fit AP mode, the port is represented by interface number Smartrate-Ethernet 1/0/2 in the MAP file and Smartrate-Ethernet 2 for configuration on the AC.
USB port
Compliant with USB 2.0.
Note:
By default, the USB port is disabled. To enable the USB port, execute the usb enable command in AP view.
Power port (54VDC)
Used for receiving power from a local power source.
Reset button
LEDs
WA7220X
Figure1-8 AP view
Figure1-9 AP dimensions
Ports
·     One 2.5GE/PoE+ port.
·     One 10GE/P+SFP port.
·     One USB port.
·     One console port.
The AP also provides a reset button and a security screw hole.
Figure1-10 Ports
(1) Grounding screw
(2) 2.5GE/PoE+ Port
(3) 10GE/P+SFP port
(4) USB port
(5) Console port
(6) Reset button
(7) Security screw hole
Table1-4 Technical specifications
Item
Specification
260 × 260 × 84 mm (10.24 × 10.24 × 3.31 in)
Weight
2.1 kg (4.63 lb)
System power consumption
31 W
Antenna
Built-in antenna
Standard compliance
Storage temperature
Operating humidity
0% RH to 100% RH
Storage humidity
0% RH to 100% RH
IP rating
IP68
2.5GE/PoE+
The 100M/1000M/2.5G copper Ethernet port is used for connecting the device to an uplink device for Internet or MAN access. It can also act as a standard PoE port.
10GE/P+SFP
1000M/2.5G/5G/10G hybrid copper-fiber port.
Console port
USB port
Used for data writing and reading or charging.
Reset button
The function of the reset button varies by duration for which it is pressed. For more information, see "LED description for the reset button"
LED
Yellow/green/blue. For more information about the LED status in different AP operating modes, see "LED descriptions for single-LED APs"
WA7232
Figure1-11 AP view
WA7232室内放装型Wi-Fi 7(802.11be)无线接入设备
Figure1-12 AP dimensions
Ports
·     One console port.
·     One USB port.
Figure1-13 Ports (1)
(2) 10GE/P+SFP port
(3) 2.5GE/PoE+ port
(4) Console port
(5) Security slot
Figure1-14 Ports (2)
(1) USB port
(2) Reset button
Table1-5 Technical specifications
Item
Specification
46.2 × 240 × 240 mm (1.82 × 9.46 × 9.45 in, excluding the mounting bracket)
Weight
0.85 kg (1.87 lb)
Power consumption
¡     25.4 W (including USB)
¡     22.9 W (excluding USB)
·     Hybrid copper-fiber interface at power receiving with 802.3at:
Antenna
Built-in antenna
Standard compliance
·     802.3at
Powering option
·     Power adapter
·     PoE
·     Hybrid copper-fiber transceiver module
Storage temperature
Operating humidity
Storage humidity
Operating altitude
Console port
10GE/P+SFP
100M/1000M/2.5G/5G/10G hybrid copper-fiber port.
2.5GE/PoE+
USB port
Note:
Power port (54VDC)
Reset button
LEDs
LEDs
The description for the status LED on the AP varies by AP operating mode. For information about the operating modes supported by the AP, see the release notes.
The LED status includes the color and flashing frequency of the LEDs, which indicates the AP operating status.
The AP has only one LED.
Figure1-15 Single-LED AP(WA7220-HI as an example)
Table1-6 AP LEDs
AP series
Models
Wi-Fi 7
WA7200 AP series
WA7220CE, WA7220-HI, WA7220X
For the LED descriptions, see "LED descriptions for single-LED APs."
LED descriptions before version changes
For the LED descriptions for the AP in versions earlier than 2614P02, see Table1-7, Table1-8, and Table1-9.
Table1-7 LED description (fit mode)
LED color
Status
N/A
Off
No power is present or the LED has been turned off from the CLI.
Yellow
Steady on
The AP is initializing, or an initialization exception has occurred.
Flashing (twice per second)
The Ethernet ports are down and no mesh links are established.
Green
Steady on
The AP has started up and registered with an AC, but is in standby state (does not have any associated clients).
Flashing (once every two seconds)
The AP has started up, but has not registered to any AC.
The AP is upgrading the image.
Blue
Flashing (once per second)
A radio has associated clients and the number of associated clients is less than the threshold.
Alternating between green and blue
The number of associated clients has exceeded the threshold.
Table1-8 LED description (cloud mode)
LED color
Status
N/A
Off
Yellow
Steady on
Green
Steady on
The AP is in standby state, has connected to Cloudnet, but does not have any associated clients.
The AP has connected to Cloudnet, and the radios have associated clients. The number of associated clients is less than the threshold.
Blue
Steady on
The AP is in standby state, has not connected to Cloudnet, and does not have any associated clients.
The AP has not connected to Cloudnet, but the radios have associated clients. The number of associated clients is less than the threshold.
Table1-9 LED description (anchor AC mode)
LED color
Status
N/A
Off
Yellow
Steady on
Green
Steady on
The AP has started up and is in standby state, but does not have any associated clients.
Blue
LED descriptions after version changes
For the LED descriptions for the AP in 2614P02 and later versions, see Table1-10.
Table1-10 LED description
LED color
Status
N/A
Off
Yellow
Steady on
Green
Steady on
The AP is in standby state and does not have any associated clients.
The AP has started up in fit mode, but has not registered to any AC.
Blue
Table1-11 LED description for the reset button
Reset button
Press and hold duration (seconds)
LED color
Status
RESET
0 to 5
Green
Steady on
Reset the AP.
5 to 20
Green
Restore to the factory defaults.
20 to 30
Yellow
The AP is operating in fit mode.
The AP is operating in anchor AC mode.
Flashing (four times per second)
The AP is operating in cloud mode.
> 30
Yellow
Green
The AP is switching from fit mode to cloud mode.
Note:
After you release the button, if the AP has switched from fit mode to cloud mode, it will restart for the new mode to take effect.
Transceiver modules
Common transceiver modules
Transceiver module, fiber connector, and optical fiber views
To connect a fiber port, use an SFP transceiver module and optical fibers with LC connectors.
Figure1-16 SFP transceiver module
Figure1-17 Optical fiber with LC connectors
(1) LC connector
(2) Optical fiber
10G transceiver module
Table1-12 SFP-XG-CPRI-IR-SM1310 transceiver module specifications
Item
Central wavelength
1310 nm
Maximum transmission distance
1.4 km (0.87 miles)
Data rate
4920 to 10310 Mbps
Connector type
LC
Fiber mode
SMF
Fiber diameter
9/125 μm
Tx optical power
–8.2 to +0.5 dBm
2.5G transceiver module
Table1-13 SFP-2.5G-LX10-SM1310-DR-I transceiver module specifications
Item
Central wavelength
1310 nm
10 km (6.21 miles)
Data rate
1228.8 to 2457.6 Mbps
Connector type
LC
Fiber mode
SMF
Fiber diameter
9/125 μm
Tx optical power
–7 to +2 dBm
Hybrid copper-fiber transceiver modules
Hybrid copper-fiber transceiver module and hybrid copper-fiber connector views
Hybrid copper-fiber transceiver modules support both optical and electrical transmission and PoE power supply. To connect a hybrid copper-fiber port, use a hybrid copper-fiber transceiver module and a hybrid copper-fiber cable with hybrid copper-fiber connectors.
Figure1-18 Hybrid copper-fiber transceiver module
Figure1-19 Hybrid copper-fiber cable with hybrid copper-fiber connectors
(1) Hybrid copper-fiber connector
(2) Hybrid copper-fiber cable
GE hybrid copper-fiber transceiver module
Table1-14 H3C-LS5M1SFPPOE-SFP GE hybrid copper-fiber transceiver module specifications
Item
H3C-LS5M1SFPPOE-SFP
Operating wavelength
1310 nm
10 km (6.21 miles)
Data rate
1.25 Gbps
Connector type
LC
Maximum power consumption
1.0 W
Operating temperature range
Tx optical power
–9 to –1 dBm
10GE hybrid copper-fiber transceiver module
Table1-15 H3C-LS5M1SFPPOEA-SFP 10GE multi-rate hybrid copper-fiber transceiver module specifications
Item
1310 nm
1.4 km (0.87 miles)
Data rate
10.3125 Gbps
Connector type
LC
1.2 W
Tx optical power
–8.2 to +0.5 dBm
Receive Sensitivity Values
Receive sensitivity is the minimum signal receive power at the antenna port required for correct wireless device operation. A lower receive sensitivity value indicates better receive performance of the wireless device.
WA7220CE
Table1-16 Receive Sensitivity Values
Radio
5GHz Radio
2.4GHz Radio
Rx sensitivity (dBm) NSS1
802.11/11b
1 Mbps
-100
11 Mbps
-92
802.11a/g
6 Mbps
-97
-97
24 Mbps
-88
-88
54 Mbps
-79
-79
802.11n HT20
MCS0
-98
-97
MCS4
-89
-87
MCS7
-79
-77
802.11n HT40
MCS0
-95
-94
MCS4
-86
-84
MCS7
-76
-75
802.11ac VHT20
MCS0
-98
MCS4
-88
MCS7
-79
MCS8
-75
MCS9
802.11ac VHT40
MCS0
-95
MCS4
-86
MCS7
-76
MCS8
-74
MCS9
-71
802.11ac VHT80
MCS0
-92
MCS4
-83
MCS7
-73
MCS8
-70
MCS9
-67
802.11ac VHT160
MCS0
-89
MCS4
-77
MCS7
-70
MCS8
-66
MCS9
-64
802.11ax HE20
MCS0
-98
-96
MCS4
-88
-86
MCS7
-78
-78
MCS8
-77
-76
MCS9
-75
-74
MCS10
-73
-71
MCS11
-69
-67
802.11ax HE40
MCS0
-95
-94
MCS4
-86
-85
MCS7
-76
-75
MCS8
-73
-72
MCS9
-70
-69
MCS10
-68
-67
MCS11
-65
-64
802.11ax HE80
MCS0
-92
MCS4
-82
MCS7
-71
MCS8
-69
MCS9
-66
MCS10
-64
MCS11
-62
802.11ax HE160
MCS0
-89
MCS4
-79
MCS7
-69
MCS8
-66
MCS9
-63
MCS10
-61
MCS11
-58
802.11be EHT20
MCS0
-98
MCS4
-89
MCS7
-80
MCS8
-78
MCS9
-75
MCS10
-71
MCS11
-68
MCS12
-65
MCS13
-62
802.11be EHT40
MCS0
-95
MCS4
-88
MCS7
-77
MCS8
-75
MCS9
-72
MCS10
-68
MCS11
-65
MCS12
-63
MCS13
-60
802.11be EHT80
MCS0
-92
MCS4
-84
MCS7
-74
MCS8
-72
MCS9
-69
MCS10
-66
MCS11
-63
MCS12
-60
MCS13
-58
802.11be EHT160
MCS0
-89
MCS4
-80
MCS7
-70
MCS8
-68
MCS9
-65
MCS10
-63
MCS11
-60
MCS12
-58
MCS13
-56
WA7220-HI
Table1-17 Receive Sensitivity Values
Radio
6GHz Radio
5GHz Radio
2.4GHz Radio
802.11/11b
1 Mbps
-100
11 Mbps
-92
802.11a/g
6 Mbps
-96
-97
24 Mbps
-87
-88
54 Mbps
-77
-79
802.11n HT20
MCS0
-97
-97
MCS4
-87
-87
MCS7
-78
-78
802.11n HT40
MCS0
-94
-95
MCS4
-83
-85
MCS7
-74
-76
802.11ac VHT20
MCS0
-97
MCS4
-87
MCS7
-78
MCS8
-74
MCS9
802.11ac VHT40
MCS0
-94
MCS4
-84
MCS7
-75
MCS8
-72
MCS9
-69
802.11ac VHT80
MCS0
-91
MCS4
-81
MCS7
-72
MCS8
-69
MCS9
-65
802.11ac VHT160
MCS0
-87
MCS4
-77
MCS7
-69
MCS8
-66
MCS9
-63
802.11ax HE20
MCS0
-95
-97
-97
MCS4
-85
-87
-87
MCS7
-76
-78
-78
MCS8
-73
-76
-76
MCS9
-70
-73
-73
MCS10
-68
-70
-70
MCS11
-65
-67
-67
802.11ax HE40
MCS0
-92
-94
-95
MCS4
-82
-84
-85
MCS7
-74
-75
-76
MCS8
-71
-72
-74
MCS9
-68
-69
-71
MCS10
-66
-67
-68
MCS11
-63
-64
-65
802.11ax HE80
MCS0
-89
-91
MCS4
-79
-81
MCS7
-71
-72
MCS8
-68
-70
MCS9
-65
-67
MCS10
-63
-64
MCS11
-60
-61
802.11ax HE160
MCS0
-86
-87
MCS4
-76
-78
MCS7
-68
-70
MCS8
-66
-68
MCS9
-63
-65
MCS10
-60
-62
MCS11
-56
-58
802.11be EHT20
MCS0
-94
-96
-97
MCS4
-84
-86
-87
MCS7
-76
-78
-79
MCS8
-73
-75
-76
MCS9
-70
-72
-73
MCS10
-68
-70
-71
MCS11
-65
-67
-68
MCS12
-62
-63
MCS13
-58
-59
802.11be EHT40
MCS0
-92
-93
-95
MCS4
-82
-83
-85
MCS7
-73
-74
-76
MCS8
-71
-72
-74
MCS9
-68
-69
-71
MCS10
-65
-66
-68
MCS11
-62
-63
-65
MCS12
-60
-61
MCS13
-57
-58
802.11be EHT80
MCS0
-89
-90
MCS4
-79
-80
MCS7
-71
-72
MCS8
-68
-70
MCS9
-65
-67
MCS10
-63
-64
MCS11
-60
-61
MCS12
-57
-59
MCS13
-54
-56
802.11be EHT160
MCS0
-86
-87
MCS4
-76
-77
MCS7
-68
-69
MCS8
-66
-67
MCS9
-63
-64
MCS10
-60
-61
MCS11
-56
-57
MCS12
-55
-56
MCS13
-53
-54
802.11be EHT320
MCS0
-83
MCS4
-74
MCS7
-66
MCS8
-64
MCS9
-61
MCS10
-57
MCS11
-53
MCS12
-53
MCS13
-52
WA7220X
Table1-18 Receive Sensitivity Values
Radio
5GHz Radio
2.4GHz Radio
802.11/11b
1 Mbps
-100
11 Mbps
-92
802.11a/g
6 Mbps
-97
-97
24 Mbps
-88
-87
54 Mbps
-78
-79
802.11n HT20
MCS0
-98
-98
MCS4
-86
-86
MCS7
-79
-78
802.11n HT40
MCS0
-95
-95
MCS4
-83
-83
MCS7
-76
-76
802.11ac VHT20
MCS0
-98
MCS4
-86
MCS7
-79
MCS8
-75
MCS9
802.11ac VHT40
MCS0
-95
MCS4
-83
MCS7
-76
MCS8
-71
MCS9
-70
802.11ac VHT80
MCS0
-92
MCS4
-80
MCS7
-73
MCS8
-69
MCS9
-67
802.11ac VHT160
MCS0
-89
MCS4
-77
MCS7
-70
MCS8
-66
MCS9
-64
802.11ax HE20
MCS0
-98
-97
MCS4
-86
-87
MCS7
-79
-78
MCS8
-75
-75
MCS9
-73
-73
MCS10
-70
-70
MCS11
-68
-68
802.11ax HE40
MCS0
-95
-95
MCS4
-83
-83
MCS7
-76
-76
MCS8
-71
-73
MCS9
-70
-71
MCS10
-67
-68
MCS11
-65
-65
802.11ax HE80
MCS0
-92
MCS4
-80
MCS7
-73
MCS8
-69
MCS9
-67
MCS10
-66
MCS11
-63
802.11ax HE160
MCS0
-89
MCS4
-77
MCS7
-70
MCS8
-66
MCS9
-64
MCS10
-52
MCS11
-59
802.11be EHT20
MCS0
-98
MCS4
-86
MCS7
-79
MCS8
-75
MCS9
-73
MCS10
-70
MCS11
-68
MCS12
-65
MCS13
-61
802.11be EHT40
MCS0
-95
MCS4
-83
MCS7
-76
MCS8
-71
MCS9
-70
MCS10
-67
MCS11
-65
MCS12
-62
MCS13
-59
802.11be EHT80
MCS0
-92
MCS4
-80
MCS7
-73
MCS8
-69
MCS9
-67
MCS10
-66
MCS11
-63
MCS12
-60
MCS13
-58
802.11be EHT160
MCS0
-89
MCS4
-77
MCS7
-70
MCS8
-66
MCS9
-64
MCS10
-52
MCS11
-59
MCS12
-57
MCS13
-55
WA7232
Table1-19 Receive Sensitivity Values
Radio
6GHz Radio
5GHz Radio
2.4GHz Radio
802.11/11b
1 Mbps
-99
11 Mbps
-92
802.11a/g
6 Mbps
-95
-97
24 Mbps
-86
-89
54 Mbps
-77
-79
802.11n HT20
MCS0
-95
-97
MCS4
-86
-88
MCS7
-76
-79
802.11n HT40
MCS0
-92
-95
MCS4
-83
-85
MCS7
-73
-76
802.11ac VHT20
MCS0
-95
MCS4
-86
MCS7
-76
MCS8
-72
MCS9
802.11ac VHT40
MCS0
-92
MCS4
-83
MCS7
-73
MCS8
-71
MCS9
-68
802.11ac VHT80
MCS0
-89
MCS4
-79
MCS7
-69
MCS8
-67
MCS9
-64
802.11ac VHT160
MCS0
-86
MCS4
-76
MCS7
-67
MCS8
-65
MCS9
-62
802.11ax HE20
MCS0
-96
-95
-97
MCS4
-87
-85
-87
MCS7
-77
-76
-78
MCS8
-74
-74
-76
MCS9
-71
-72
-73
MCS10
-68
-69
-71
MCS11
-65
-66
-68
802.11ax HE40
MCS0
-94
-92
-95
MCS4
-84
-83
-84
MCS7
-74
-73
-75
MCS8
-72
-70
-73
MCS9
-69
-68
-71
MCS10
-67
-65
-68
MCS11
-63
-62
-65
802.11ax HE80
MCS0
-90
-89
MCS4
-81
-80
MCS7
-71
-70
MCS8
-68
-67
MCS9
-65
-64
MCS10
-63
-62
MCS11
-61
-60
802.11ax HE160
MCS0
-87
-86
MCS4
-78
-76
MCS7
-68
-67
MCS8
-66
-64
MCS9
-63
-61
MCS10
-60
-59
MCS11
-57
-56
802.11be EHT20
MCS0
-95
-94
MCS4
-86
-84
MCS7
-77
-75
MCS8
-74
-73
MCS9
-71
-71
MCS10
-68
-69
MCS11
-65
-66
MCS12
-63
-63
MCS13
-60
-59
802.11be EHT40
MCS0
-93
-92
MCS4
-84
-82
MCS7
-74
-73
MCS8
-72
-70
MCS9
-69
-68
MCS10
-66
-67
MCS11
-63
-64
MCS12
-60
-61
MCS13
-57
-58
802.11be EHT80
MCS0
-90
-89
MCS4
-81
-79
MCS7
-72
-71
MCS8
-69
-69
MCS9
-66
-66
MCS10
-64
-64
MCS11
-62
-61
MCS12
-59
-58
MCS13
-56
-55
802.11be EHT160
MCS0
-87
-86
MCS4
-78
-77
MCS7
-69
-68
MCS8
-66
-65
MCS9
-63
-63
MCS10
-60
-61
MCS11
-58
-58
MCS12
-55
-55
MCS13
-52
-53
802.11be EHT320
MCS0
-84
MCS4
-74
MCS7
-65
MCS8
-63
MCS9
-60
MCS10
-58
MCS11
-55
MCS12
-52
MCS13
-49
