H3C US300 Switch Series Hardware Information and Specifications-6W100
HomeSupportSMBAolynk SwitchWeb Managed SwitchUS300 SeriesTechnical DocumentsProduct LiteratureHardware Information & SpecificationsH3C US300 Switch Series Hardware Information and Specifications-6W100
01-Text
01-Text 816.44 KB
1 Product models and technical specifications
Product models
This manual is applicable to the following Ethernet switch products:
Product series
Product code
Product model
US300 series
Non-PoE models
LS-US300-8G2F
US300-8G2F
LS-US300-16G4F
US300-16G4F
LS-US300-24G4F
US300-24G4F
PoE models
LS-US300-8G2F-HP
US300-8G2F-HP
LS-US300-16G4F-HP
US300-16G4F-HP
LS-US300-24G4F-HP
US300-24G4F-HP
Technical specifications
Table1-1 Technical specifications for non-PoE switch models
Item
US300-8G2F
US300-16G4F
US300-24G4F
Physical specifications
Dimensions (H × W × D)
43.6 × 226 × 160 mm (1.72 × 8.90 × 6.30 in)
43.6 × 330 × 230 mm (1.72 × 12.99 × 9.06 in)
43.6 × 440 × 160 mm (1.72 × 17.32 × 6.30 in)
Dimensions (H × W × D, with package materials)
103 × 351 × 275 mm (4.06 × 13.82 × 10.83 in)
114 × 437 × 355 mm (4.49 × 17.20 × 13.98 in)
106 × 525 × 296 mm (4.17 × 20.67 × 11.65 in)
Weight
≤ 1.0kg (2.20 lb)
≤ 1.9 kg (4.19 lb)
≤ 1.9 kg (4.19 lb)
Memory (RAM)
1 GB
Flash
256 MB
Port types and quantity
Console port
1
10/100/1000BASE-T autosensing Ethernet ports
8
16
24
SFP ports
2
4
4
Power supply specifications
Power input type
AC input
Input voltage
·     Rated voltage range: 100 VAC to 240 VAC @ 50/60 Hz
·     Maximum voltage range: 90 VAC to 264 VAC @ 47 to 63 Hz
Chassis leakage current compliance
UL62368-1/EN62368 -1/IEC62368 -1/UL60950-1/EN60950-1/IEC60950-1/GB4943.1
Melting current of power supply fuse
3.15 A @ 250 V
2 A @ 250 V
2 A @ 250 V
System power consumption
Power consumption (static)
Collection standard: No load
6 W
6 W
7 W
Power consumption (typical)
Collection standard: Fully-equipped with power cables or network cables, 30% load
8 W
12 W
12 W
Power consumption (full load)
Collection standard: Fully-equipped with transceiver modules or network cables, 100% load
10 W
15 W
15 W
System thermal consumption
Thermal consumption (static)
21 BTU/h
21 BTU/h
24 BTU/h
Thermal consumption (typical)
Collection standard: Fully-equipped with cables or network cables, 30% load
28 BTU/h
41 BTU/h
41 BTU/h
Thermal consumption (full load)
35 BTU/h
52 BTU/h
52 BTU/h
Heat dissipation
Heat dissipation method
Fanless, passive cooling
Reliability and availability
Mean Time Between Failures (MTBF) (years)
111.0728521
108.4951013
86.61368667
Mean Time To Repair (MTTR) (hours)
1
Availability
99.9998972%
99.9998948%
99.9998726%
Environment specifications
Altitude
0 to 5000 m (0 to 16404.20 ft)
Operating temperature
–5ºC to +50ºC (23°F to 122°F)
The allowed maximum temperature decreases by 0.33 °C (0.59°F) as the altitude increases by 100 m (328.08 ft) from 0 m (0 ft).
Storage temperature
–40°C to +70°C (–40°F to +158°F)
Relative humidity (non-condensing)
5% to 95%
Compliance
Product compliance
·     Safety standards
·     EMC standards
·     Environmental and eco-friendly standards
Table1-2 Technical specifications for PoE switch models
Item
US300-8G2F-HP
US300-16G4F-HP
US300-24G4F-HP
43.6 × 440 × 260 mm (1.72 × 17.32 × 10.24 in)
125 × 558 × 384 mm (4.92 × 21.97 × 15.12 in)
135 × 558 × 384 mm (5.32 × 21.97 × 15.12 in)
Weight
≤ 2.1 kg (4.63 lb)
≤ 3.5 kg (7.72 lb)
≤ 3.6 kg (7.94 lb)
Memory (RAM)
1 GB
Flash
256 MB
Console port
1
8
16
24
SFP ports
2
4
4
Power input type
AC input
Input voltage
·     Maximum voltage range: 90 VAC to 290 VAC @ 47 to 63 Hz
6.3 A @ 250 V
8 A @ 250 V
10 A @ 250 V
8 W
12 W
12 W
11 W
18 W
18 W
156 W
299 W
434 W
PoE power capacity
Maximum PoE power per port
35 W
35 W
35 W
Total PoE power
130 W
255 W
410 W
28 BTU/h
41 BTU/h
41 BTU/h
38 BTU/h
62 BTU/h
62 BTU/h
532 BTU/h
1020 BTU/h
1480 BTU/h
Heat dissipation
Air cooling
Air cooling
Ventilation aisle
N/A
Left to right (facing the front panel)
MTBF (years)
83.23152
100.9327
48.7126
MTTR (hours)
1
Availability
99.9998628%
99.9998869%
99.9997657%
Sound pressure level at 27°C (80.6°F)
N/A
35.3 dB
35.4 dB
Altitude
Storage temperature
5% to 95%
Compliance
Product compliance
·     Safety standards
·     EMC standards
2 Chassis views
US300-8G2F
Figure2-1 US300-8G2F front panel
(1) 10/100/1000BASE-T autosensing Ethernet port
(2) Console port (CONSOLE)
(3) 10/100/1000BASE-T autosensing Ethernet port LEDs
(4) SFP port LEDs
(5) System status LED (SYS)
(6) Reset button (RESET)
(7) SFP port
Figure2-2 US300-8G2F rear panel
(1) Grounding screw
(2) AC power receptacle
US300-8G2F-HP
Figure2-3 US300-8G2F-HP front panel
(3) Mode button
(4) 10/100/1000BASE-T autosensing Ethernet port LEDs
(5) SFP port LEDs
(6) System status LED (SYS)
(7) Port mode LED (MODE)
(8) Reset button (RESET)
(9) SFP port
Figure2-4 US300-8G2F-HP rear panel
(1) AC power receptacle
(2) Grounding screw
US300-16G4F
Figure2-5 US300-16G4F front panel
(4) SFP port LEDs
(9) SFP port
Figure2-6 US300-16G4F rear panel
(2) Grounding screw
US300-16G4F-HP
Figure2-7 US300-16G4F-HP front panel
(3) Mode button
(5) SFP port LEDs
(9) SFP port
Figure2-8 US300-16G4F-HP rear panel
(2) Grounding screw
US300-24G4F
Figure2-9 US300-24G4F front panel
(4) SFP port LEDs
(7) SFP port
Figure2-10 US300-24G4F rear panel
(1) Grounding screw
US300-24G4F-HP
Figure2-11 US300-24G4F-HP front panel
(3) Mode button
(5) SFP port LEDs
(9) SFP port
Figure2-12 US300-24G4F-HP rear panel
(2) Grounding screw
3 Buttons, ports, and LEDs
Buttons
Reset button
The switch provides one reset button on the front panel. For more information, see Table3-1.
Table3-1 Methods for using the reset button
Item
Services
Reset button
·     To restart the switch, press and hold the button for 1 to 5 seconds and release the button.
·     To restore the factory default and restart the switch, press and hold the button for over 5 seconds and release the button when the SYS LED flashes red rapidly (8 Hz).
·     To enhance switch security and prevent misuse of the reset button, execute the undo push-button reset enable command to disable the reset button.
Ports
Console port
Table3-2 Console port specifications
Item
Connector type
RJ-45
Compliant standard
EIA/TIA-232
Operating mode
Duplex Universal Asynchronous Receiver/Transmitter (UART)
Speed
9600 bps (default) to 115200 bps
Supported services
·     Provides connection to an ASCII terminal.
·     Provides connection to the serial port of a local terminal (for example, a PC) running a terminal emulation program.
Compatible switch models
All models
Table3-3 10/100/1000BASE-T autosensing Ethernet port specifications
Item
Port name
All models
Connector type
RJ-45
The 10/100/1000BASE-T autosensing Ethernet ports are mainly used for transmitting and receiving 1000/100/10 Mbps copper port services.
Compliant standard
IEEE 802.3i, 802.3u, 802.3ab
Transmission rate, duplex mode, and auto MDI/MDI-X
·     10 Mbps, half/full duplex
·     100 Mbps, half/full duplex
·     1000 Mbps, full duplex
·     MDI/MDI-X autosensing
Maximum transmission distance
100 m (328.08 ft)
Transmission medium
Category 5 and above twisted pair cable
SFP port
Table3-4 SFP port specifications
Item
Port name
SFP fiber Ethernet port
All models
Connector type
LC/RJ-45
Available transceiver modules and cables
GE SFP transceiver modules and cables listed in Table3-5
N/A
Table3-5 GE SFP transceiver modules and cables available for the SFP ports
Transceiver module/cable type
Transceiver module/cable model
Central wavelength
Connector type
Cable specifications
Mode bandwidth (MHz*km)
SFP module
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-T-D
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-T-S
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-SX-MM850-A
850 nm
LC
50/125 µm, MMF
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125 µm, MMF
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-D
850 nm
LC
50/125 µm, MMF
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125 µm, MMF
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-S
850 nm
LC
50/125 µm, MMF
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125 µm, MMF
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
50/125 µm, MMF
500/400
550 m (1804.46 ft)
62.5/125 µm, MMF
500
550 m (1804.46 ft)
SFP-GE-LX-SM1310-D
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-S
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-F
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-GE-LX10-SM1310
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310
1310 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-D
1310 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-I
1310 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-S
1310 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH20-SM1310-I
1310 nm
LC
9/125 µm, SMF
N/A
20 km (12.43 miles)
SFP-GE-LH40-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP-GE-LH80-SM1550-D
1550 nm
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
100 km (62.14 miles)
SFP-GE-LX-SM1310-BIDI
Tx: 1310 nm
Rx: 1490 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI
Tx: 1490 nm
Rx: 1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310-BIDI
Tx: 1310 nm
Rx: 1550 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550-BIDI
Tx: 1550 nm
Rx: 1310 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH70-SM1490-BIDI
Tx: 1490 nm
Rx: 1550 nm
LC
9/125 µm, SMF
N/A
70 km (43.50 miles)
SFP-GE-LH70-SM1550-BIDI
Tx: 1550 nm
Rx: 1490 nm
LC
9/125 µm, SMF
N/A
70 km (43.50 miles)
SFP-GE-LX-SM1310-BIDI-I
Tx: 1310 nm
Rx: 1490 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI-I
Tx: 1490 nm
Rx: 1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-BIDI-S
Tx: 1310 nm
Rx: 1490 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI-S
Tx: 1490 nm
Rx: 1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP cable
SFP-STACK-Kit
N/A
N/A
SFP cable
N/A
1.5 m (4.92 ft)
SFP-STACK-Kit-S
N/A
N/A
SFP cable
N/A
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
The SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules, the SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules, the SFP-GE-LH70-SM1490-BIDI and SFP-GE-LH70-SM1550-BIDI transceiver modules, the SFP-GE-LX-SM1310-BIDI-I and SFP-GE-LX-SM1490-BIDI-I transceiver modules, and the SFP-GE-LX-SM1310-BIDI-S and SFP-GE-LX-SM1490-BIDI-S transceiver modules must be used in pairs. For example, if one end uses the SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use the SFP-GE-LX-SM1490-BIDI transceiver module.
LEDs
System status LED
Through the system status LED, you can preliminarily determine the working state of the switch. For more information, see Table3-6.
Table3-6 System status LED description
LED mark
Status
SYS
Steady green
The switch is operating correctly.
Flashing green
The switch is performing power-on self test (POST).
Steady red
The switch has failed POST or the switch is faulty.
Off
The switch is powered off or has not started up correctly.
Port mode LED
For models providing a mode button, the mode LED (MODE) works in conjunction with the port LEDs to show more information about the switch.
·     The mode LED indicates the type of information that the port LEDs are showing.
·     You can use the mode button to change the indication of the mode LED.
·     After you press the mode button to set the mode LED to PoE mode, the mode LED will automatically switch back to speed mode after 45 seconds.
Table3-7 Port mode LED description
LED mark
LED status
MODE
Steady green
The Ethernet port LEDs are showing link state of the ports.
Flashing green
The port status LEDs indicate the PoE power supply status of the ports.
SFP port LED
Table3-8 SFP port LED description
 LED status
Steady green
A module has been installed and a link is present on the port.
Flashing green
The port is receiving or transmitting data.
Off
·     No module has been installed or no link is present on the port.
·     The port mode LED is operating in PoE mode (only for PoE models).
Table3-9 10/100/1000BASE-T autosensing Ethernet port LED description for non-PoE models
LED status
Steady green
A link is present on the port.
Flashing green
The port is receiving or sending data.
Off
No link is present on the port.
Table3-10 10/100/1000BASE-T autosensing Ethernet port LED description for PoE models
LED status
Ethernet port LED
Steady green (Link/Active)
Steady green
Flashing green
Off
Flashing green (PoE mode)
Steady green
The PoE power supply is normal.
Flashing green (1 Hz)
·     The maximum PoE power provided by the port fails to meet the power requirement of the PD.
·     PoE power supply overcurrent, overvoltage, or shortcircuit occurs.
·     The remaining power of the switch fails to meet the power supply requirement of the port.
Off
The port is not connected to a PD or PoE is not enabled on the port.
4 Cooling system
To dissipate heat timely and enhance system stability, the switch uses a high-performance cooling system. Consider the site ventilation design when you plan the installation site for the switch.
Table4-1 Cooling system
Switch model
Fan type
Airflow direction
·     US300-16G4F-HP
·     US300-24G4F-HP
Fixed fans
·     US300-8G2F
·     US300-8G2F-HP
·     US300-16G4F
·     US300-24G4F
Fanless
Silent operation and passive cooling
