11-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S9820-G & S9825-G & S9855-G Switch Series Command References-R8336P05-6W10011-Network Management and Monitoring Command Reference
01-Sampler commands
01-Sampler commands 46.73 KB
Sampler commands
display sampler
Use display sampler to display configuration information for a sampler.
display sampler [ sampler-name ] [ slot slot-number ]
sampler-name: Specifies a sampler by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a sampler, this command displays configuration information for all samplers.
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
# Display the configuration information about sampler 256.
<Sysname> display sampler 256
 Sampler name: 256
  Mode: random;  Packet-interval: 8; IsNpower: Y
Sampler name
Name of the sampler.
Mode
Sampling mode. In the current software version, only the random mode is supported. .
Packet-interval
Sampling rate.
IsNpower
Y indicates that the sampling rate is 2 to the nth power.
sampler
Use sampler to create a sampler.
Use undo sampler to delete a sampler.
sampler sampler-name mode random packet-interval n-power rate
undo sampler sampler-name
No samplers exist.
random: Specifies the random sampling mode. A sampler in this mode randomly selects a packet out of a group of packets. Which packet is selected for each sampling varies.
n-power: Specifies the sampling rate as 2 to the nth power.
rate: Specifies the sampling rate. The sampling rate is 2 to the nth power, where n is the value of the rate argument. For example, if the rate argument is set to 8, one packet is selected from 256 (2 to the 8th power) packets in each sampling. The value range for the rate argument is 0 to 14. In the current software version, the maximum value supported is 8. When the value for this argument is great, the actual sampling rate has certain errors. The greater the value, the greater the errors.
# Create sampler abc in random sampling mode. Set the sampling rate to 8 to select one packet from 256 packets in each sampling.
[Sysname] sampler abc mode random packet-interval  n-power 8
