| 07-BFD commands | 388.82 KB |
bfd detect-interface first-fail-timer
bfd detect-interface source-ip
bfd detect-interface special-processing
bfd multi-hop authentication-mode
bfd multi-hop destination-port
bfd multi-hop detect-multiplier
bfd multi-hop min-control-interval
bfd multi-hop min-echo-receive-interval
bfd multi-hop min-receive-interval
bfd multi-hop min-transmit-interval
bfd session-negotiation delay-upon-down
bfd session-negotiation delay-upon-reboot
display bfd session route-aggregation
BFD commands
Basic BFD commands
bfd authentication-mode
Use bfd authentication-mode to configure the BFD authentication mode for single-hop BFD control packets.
Use undo bfd authentication-mode to restore the default.
bfd authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher | plain } string
Single-hop BFD control packets are not authenticated.
Interface view
BFD template view
Static BFD session view
hmac-md5: Specifies the HMAC MD5 algorithm.
hmac-mmd5: Specifies the HMAC Meticulous MD5 algorithm.
hmac-msha1: Specifies the HMAC Meticulous SHA1 algorithm.
hmac-sha1: Specifies the HMAC SHA1 algorithm.
m-md5: Specifies the Meticulous MD5 algorithm.
m-sha1: Specifies the Meticulous SHA1 algorithm.
md5: Specifies the MD5 algorithm.
sha1: Specifies the SHA1 algorithm.
simple: Specifies the simple authentication mode.
key-id: Sets the authentication key ID in the range of 1 to 255.
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 33 to 53 characters.
Application scenarios
Use this command to enhance BFD session security.
BFD session negotiation can succeed only when both ends have consistent BFD session authentication settings.
A static BFD session supports this command only when it is in IPv4 or IPv6 control packet mode used for single-hop detection.
BFD version 0 does not support this command. The configuration does not take effect.
# Configure VLAN-interface 11 to perform simple authentication for single-hop BFD control packets, setting the authentication key ID to 1 and plaintext key to 123456.
[Sysname-Vlan-interface11] bfd authentication-mode simple 1 plain 123456
bfd dampening
Use bfd dampening to configure BFD session flapping suppression.
Use undo bfd dampening to disable BFD session flapping suppression.
bfd dampening [ maximum maximum-interval initial initial-interval secondary secondary-interval ]
undo bfd dampening
BFD sessions are not suppressed.
maximum-interval: Specifies the maximum amount of time a BFD session is suppressed, in the range of 1 to 3600 seconds. The default is 20 seconds.
initial-interval: Specifies the amount of time a BFD session is suppressed for the first time. The value range for the initial-interval argument is 1 to 3600 seconds. The default is 6 seconds.
secondary-interval: Specifies the amount of time a BFD session is suppressed for the second time. The value range for the secondary-interval argument is 1 to 3600 seconds. The default is 10 seconds.
When BFD detects a link failure, it tears down the BFD session and notifies the upper-layer protocol of the failure. When the upper-layer protocol re-establishes a neighbor relationship, the BFD session comes up again. BFD session flaps occur when a link fails and recovers repeatedly, which consumes significant system resources and causes network instability.
Operating mechanism
This command allows you to suppress BFD session flapping by using the initial-interval, secondary-interval, and maximum-interval arguments.
· A BFD session is suppressed within the specified interval. The suppression time does not exceed the maximum-interval.
· After a BFD session goes down for the second time, it cannot be re-established within the initial-interval.
· After a BFD session goes down for the third time, it cannot be re-established within the secondary-interval.
· After a BFD session goes down for the fourth time and at any later time, the following rules apply:
¡ If secondary-interval × 2n-3 is smaller than or equal to the maximum-interval, the BFD session cannot be re-established within the secondary-interval × 2n-3.
¡ If secondary-interval × 2n-3 is greater than the maximum-interval, the BFD session cannot be re-established within the maximum-interval.
The letter n, starting from 4, is the number of times the BFD session flaps.
# Enable BFD session flapping suppression, and set the maximum-interval, initial-interval, and secondary-interval to 12 seconds, 4 seconds, and 8 seconds, respectively.
[Sysname] bfd dampening maximum 12 initial 4 secondary 8
bfd demand enable
Use bfd demand enable to enable the Demand BFD session mode.
Use undo bfd demand enable to restore the default.
bfd demand enable
The BFD session is in Asynchronous mode.
Interface view
BFD supports the Asynchronous and Demand detection modes. By default, the BFD session operates in Asynchronous mode. If a large number of BFD sessions exist in the system, you can specify the Demand mode to prevent periodic sending of BFD control packets from affecting system operations.
Operating mechanism
In Demand mode, the device periodically sends BFD control packets. If the peer end is operating in Asynchronous mode (default), the peer end stops sending BFD control packets. If the peer end is operating in Demand mode, both ends stop sending BFD control packets. When the connectivity to another system needs to be verified explicitly, a system sends several BFD control packets with the Poll (P) bit set at the negotiated transmit interval. If no response is received within the detection interval, the session is considered down. If the connectivity is found to be up, no more BFD control packets are sent until the next command is issued. As a best practice, use the bfd echo enable command to enable the echo function for the device to periodically send echo packets to detect link connectivity. If the device does not receive echo packets from the peer within the detection time, it considers the session down.
In Asynchronous mode, the device periodically sends BFD control packets. The device considers that the session is down if it does not receive any BFD control packets within a specific interval.
The bfd demand enable command cannot take effect when any of the following conditions exist:
· Echo-packet-mode BFD sessions exist on the device.
· BFD sessions for detecting aggregate links exist on the device.
· After the bfd detect-interface source-ip command is configured, the bfd detect-interface first-fail-timer and bfd detect-interface special-processing commands are configured.
# Enable the Demand BFD session mode on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd demand enable
bfd echo enable
Use bfd detect-interface first-fail-timer to configure the timer that delays reporting the first BFD session establishment failure to the data link layer.
Use undo bfd detect-interface first-fail-timer to restore the default.
bfd detect-interface first-fail-timer seconds
The first BFD session establishment failure is not reported to the data link layer.
Interface view
seconds: Specifies the timeout time that reports the first BFD session establishment failure to the data link layer. The value range for this argument is 1 to 10000 seconds.
With the bfd detect-interface source-ip command configured, the local end attempts to establish a BFD session for detecting the interface state. The first BFD session for detecting the interface state fails to be established when the following conditions exist:
· The remote end is not configured with the bfd detect-interface source-ip command.
· The local and remote ends have mismatching BFD authentication settings.
You can use this command for the following purposes:
· Disable the data link layer for the interface.
· Fast locate the interface where the first attempt to establish the BFD session for detecting interface state failed.
Operating mechanism
If the BFD session fails to be established when the timer expires, BFD reports the failure to the data link layer and sets the data link layer state of the interface to DOWN(BFD). This behavior rapidly identifies the interfaces for which BFD sessions fail to be established. In this case, the BFD session state is displayed as Down in the display bfd session command output. The line protocol state of the interface is displayed as DOWN(BFD) in the display interface command output.
If the local end is configured with the bfd detect-interface source-ip command, the BFD session for detecting the local interface state fails to be established when the following conditions exist:
# Configure the timer that delays reporting the first BFD session establishment failure as 10 seconds.
[Sysname] interface hundredgige 1/1/1
[Sysname-HundredGigE1/1/1] bfd detect-interface first-fail-timer 10
display interface (Interface Command Reference)
Use bfd detect-interface source-ip to associate the interface state with BFD.
Use undo bfd detect-interface to remove the association between the interface state and BFD.
bfd detect-interface source-ip ip-address [ discriminator local local-value remote remote-value ] [ template template-name ]
The interface state is not associated with BFD. BFD does not set the link layer protocol of the interface to DOWN(BFD) state when detecting a failure.
Interface view
ip-address: Specifies the source IP address for BFD control packets.
discriminator: Specifies BFD session discriminators. If you do not specify discriminators, the device obtains BFD session discriminators through autonegotiation.
local local-value: Specifies the local discriminator. The value range for the local-value argument is 1 to 32768.
remote remote-value: Specifies the remote discriminator in the range of 1 to 4294967295.
template template-name: Specifies a template by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a template, the BFD session uses the BFD parameters configured in interface view.
By creating a BFD session for single-hop detection through exchange of BFD control packets, this feature implements fast link detection. When BFD detects a link fault, it sets the link layer protocol state to DOWN(BFD). This behavior helps applications relying on the link layer protocol state achieve fast convergence.
Recommended configuration
The source IP address of control packets is specified manually, and the destination IP address is fixed at 224.0.0.184. As a best practice, specify the IP address of the interface as the source IP address. If the interface does not have an IP address, specify a unicast IP address other than 0.0.0.0 as the source IP address.
You can associate the state of the following interfaces with BFD:
· Layer 2 Ethernet interfaces.
· Layer 3 Ethernet interfaces.
This command must be executed on both ends of the link for a BFD session to be established.
If you execute both the bfd detect-interface and bfd echo enable commands for an interface, only the bfd detect-interface command takes effect.
To associate the interface state with BFD successfully and avoid session state exceptions, as a best practice, do not set demand mode for the BFD session.
If the peer device does not support obtaining BFD session discriminators through autonegotiation, you must specify the discriminators on both the local and peer devices. Without the discriminators, the BFD session cannot come up.
The BFD session discriminators must match on the local and peer devices. For example, if you configure bfd detect-interface source-ip 20.1.1.1 discriminator local 513 remote 514 on the local device, you must configure bfd detect-interface source-ip 20.1.1.2 discriminator local 514 remote 513 on the peer device.
The local discriminators of BFD sessions for interfaces on the same device must be different.
The echo function does not take effect on BFD sessions associated with interface states.
# Create a BFD session to detect the state of HundredGigE 1/1/1, and specify the source IP address as 20.1.1.1.
[Sysname-HundredGigE1/1/1] bfd detect-interface source-ip 20.1.1.1
Use bfd detect-interface special-processing to enable special processing for BFD sessions.
Use undo bfd detect-interface special-processing to disable special processing for BFD sessions.
bfd detect-interface special-processing [ admin-down | authentication-change | session-up ] *
undo bfd detect-interface special-processing [ admin-down | authentication-change | session-up ] *
All types of special processing for BFD sessions are disabled.
Interface view
admin-down: Notifies a session down event to the data link layer upon receipt of a BFD packet with the State field as AdminDown. This keyword helps rapidly discover interfaces that BFD sessions are manually shut down. If you do not specify this keyword, the device sets the BFD session state to Down, but does not notify the session down event to the data link layer.
authentication-change: Immediately sets the session to down state upon a local authentication information change. This keyword helps rapidly discover interfaces with authentication information changes. If you do not specify this keyword, the device sets the session to down state if authentication information inconsistency still persists after a period of time.
session-up: Ignores authentication information inconsistency when the local session is up. If there is a large number of BFD sessions, examining authentication information consistency affects device performance. If you do not specify this keyword, the device examines authentication information in incoming BFD packets when the local session state is up. If the authentication information does not match on the two ends, the BFD session is declared down.
If you do not specify any parameters, this command enables or disables all types of special processing.
When the authentication mode for BFD packets is M-MD5, M-SHA1, HMAC-MMD5, or HMAC-MSHA1, configuring the bfd detect-interface special-processing session-up command on only the local or remote end will cause BFD session flapping. To avoid this issue, perform one of the following tasks:
· Change the authentication mode for BFD packets.
· Configure the bfd detect-interface special-processing session-up command on both of the local and remote ends.
# Enable all types of special processing for BFD sessions on HundredGigE 1/1/1.
[Sysname-HundredGigE1/1/1] bfd detect-interface special-processing admin-down authentication-change session-up
bfd detect-multiplier
Use bfd detect-multiplier to set the single-hop detection time multiplier for control packet mode and echo packet mode.
Use undo bfd detect-multiplier to restore the default.
bfd detect-multiplier value
The single-hop detection time multiplier for control packet mode and echo packet mode is 5.
Interface view
BFD template view
value: Specifies a detection time multiplier. The value range for this argument is 3 to 15.
You can adjust the detection time multiplier based on the actual network condition in order to adjust the BFD detection time.
Operating mechanism
The detection time multiplier determines the maximum number of concurrent BFD packets (including control packets and echo packets) that can be discarded.
Table 1 Actual detection interval calculation method
Mode |
Actual detection interval of the sender |
Echo packet mode |
Detection time multiplier of the sender × actual packet sending interval of the sender |
Control packet mode BFD session in asynchronous mode |
Detection time multiplier of the receiver × MAX (minimum receiving interval supported by the sender, minimum sending interval supported by the receiver) |
Control packet mode BFD session in demand mode |
Detection time multiplier of the sender × MAX (minimum sending interval supported by the sender, minimum receiving interval supported by the receiver) |
Operating mechanism
The timers for BFD sessions in different directions are independently negotiated. Bidirectional session timers can be different.
When the BFD session is valid, the control packet transmission interval and detection time can be renegotiated at any time without affecting the session status.
Only the following static BFD sessions support this command:
· Static BFD sessions in IPv4 control packet mode used for single-hop detection.
· Static BFD sessions in IPv4 echo packet mode used for single-hop detection.
· Static BFD sessions in IPv6 control packet mode used for single-hop detection.
· Static BFD sessions in IPv6 echo packet mode used for single-hop detection.
# Set the single-hop detection time multiplier for control packet mode and echo packet mode to 6 on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd detect-multiplier 6
bfd echo enable
Use bfd echo enable to enable the echo function.
Use undo bfd echo enable to disable the echo function.
undo bfd echo [ receive | send ] enable
The echo function is disabled.
Interface view
receive: Specifies the echo packet receiving capability.
send: Specifies the echo packet sending capability.
If you enable the echo function for a BFD session in which control packets are sent and the session comes up, BFD performs the following operations:
· Periodically sends echo packets to detect link connectivity.
· Decreases the control packet receiving rate at the same time.
Operating mechanism
To enable only the echo packet receiving capability, use the bfd echo receive enable command.
To enable only the echo packet sending capability, use the bfd echo send enable command.
If you do not specify the receive or send keyword, the command enables both the echo packet receiving and sending capabilities.
The echo function does not take effect on control-mode BFD sessions established with IPv6 link-local addresses.
# Enable the echo function on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd echo enable
bfd echo-source-ip
Use bfd echo-source-ip to configure the source IP address of BFD echo packets.
Use undo bfd echo-source-ip to remove the configured source IP address of BFD echo packets.
bfd echo-source-ip ip-address
No source IP address is configured for BFD echo packets.
ip-address: Specifies the source IP address of BFD echo packets. The source IP address must be a valid unicast IPv4 address in dotted decimal notation.
The source IP address cannot be on the same network segment as any local interface's IP address. Otherwise, a large number of ICMP redirect packets might be sent from the peer, resulting in link congestion.
# Configure the source IP address of BFD echo packets as 8.8.8.8.
[Sysname] bfd echo-source-ip 8.8.8.8
bfd echo-source-ipv6
Use bfd echo-source-ipv6 to configure the source IPv6 address of BFD echo packets.
Use undo bfd echo-source-ipv6 to remove the configured source IPv6 address of BFD echo packets.
No source IPv6 address is configured for BFD echo packets.
ipv6-address: Specifies the source IPv6 address for BFD echo packets.
The source IPv6 address of echo packets can only be a global unicast address.
The source IPv6 address cannot be on the same network segment as any local interface's IP address. Otherwise, a large number of ICMP redirect packets might be sent from the peer, resulting in link congestion.
# Configure the source IPv6 address of BFD echo packets as 80::2.
[Sysname] bfd echo-source-ipv6 80::2
bfd event-log enable
Use bfd event-log enable to enable BFD event logging.
Use undo bfd event-log enable to disable BFD event logging.
bfd event-log enable { down [ log-size ] | driver-packet [ detection-abnormal-autostop ] }
undo bfd event-log enable { down | driver-packet }
BFD event logging is disabled.
down: Enables logging for BFD session down events.
log-size: Specifies the maximum number of BFD session down event logs allowed, which takes value 0 or is in the range of 200 to 60000. The default is 1000. To disable BFD session down event logging, set the value for the log-size argument to 0.
driver-packet: Enables logging for driver packet-sending events.
detection-abnormal-autostop: Logs a BFD error that occurs and then immediately disables logging for driver packet-sending events. BFD errors include the following types:
· The BFD detection timer times out.
· A BFD session goes down.
If you do not specify this option, driver packet-sending events are logged until the logging is administratively disabled.
Use this feature to enable the device to record the following types of BFD event logs to help you locate the reason for BFD session state anomalies:
· BFD session down events.
· Driver packet-sending events.
You can repeat this command to modify the maximum number of logs allowed for BFD session down events. After modification, the device clears recorded logs.
The device can record a maximum number of 8192 logs for driver packet-sending events.
# Enable BFD session down event logging, and set the maximum number of BFD session down event logs allowed to 500.
[Sysname] bfd event-log enable down 500
bfd init-fail-timer
Use bfd init-fail-timer to set the delay timer for BFD to notify upper-layer protocols of session establishment failures.
Use undo bfd init-fail-timer to restore the default.
bfd init-fail-timer seconds
BFD does not notify upper-layer protocols of session establishment failures.
seconds: Specifies the delay time in the range of 5 to 600 seconds. After the delay time, BFD notifies the upper-layer protocol of session establishment failures.
CAUTION: For session establishment failures caused by configuration mismatches at the two ends, this command can cause the upper-layer protocol to act incorrectly. Therefore, use this command with caution. BFD status mismatch and BFD authentication configuration mismatch are examples of configuration mismatches. |
In some cases, for an upper-layer protocol to act correctly, BFD must notify the upper-layer protocol of session establishment failures. For example, with this command configured, the link aggregation module can promptly set the state of a member port from Selected to Unselected in the case of a link failure.
This command takes effect only for control packet mode.
# Set the delay timer to 10 seconds for BFD to notify upper-layer protocols of session establishment failures.
[Sysname] bfd init-fail-timer 10
bfd min-control-interval
Use bfd min-control-interval to set the minimum interval for transmitting and receiving single-hop BFD control packets.
Use undo bfd min-control-interval to restore the default.
bfd min-control-interval interval
The minimum interval for transmitting and receiving single-hop BFD control packets is 400 milliseconds.
Interface view
BFD template view
interval: Specifies the minimum interval for transmitting and receiving single-hop BFD control packets, in milliseconds. The value range for this argument is 3 to 1000.
Use this command to prevent the control packet sending rate and receiving rate of the local end from exceeding the device capability.
The actual BFD control packet sending interval of the peer end takes the greater value between the following values:
· Minimum interval for transmitting BFD control packets on the peer end.
· Minimum interval for receiving BFD control packets on the local end.
The actual BFD control packet transmitting interval on the local end is the greater value between the following values:
· Minimum interval for transmitting BFD control packets on the local end.
· Minimum interval for receiving BFD control packets on the peer end.
You can use the bfd min-receive-interval and bfd min-control-interval commands to adjust the minimum interval for receiving single-hop BFD control packets. Follow these guidelines when you configure the commands:
· If you configure both the bfd min-receive-interval and bfd min-control-interval commands, the time interval configured by the bfd min-receive-interval command takes precedence.
· If you do not configure the bfd min-receive-interval or bfd min-control-interval command, the device uses the default value for the bfd min-receive-interval command as the minimum interval for receiving single-hop BFD control packets.
· If you configure either the bfd min-receive-interval or bfd min-control-interval command, the device uses the value configured for that command as the minimum interval for receiving single-hop BFD control packets.
You can use the bfd min-transmit-interval and bfd min-control-interval commands to adjust the minimum interval for transmitting single-hop BFD control packets. Follow these guidelines when you configure the commands:
· If you configure both the bfd min-transmit-interval and bfd min-control-interval commands, the time interval configured by the bfd min-transmit-interval command takes precedence.
· If you do not configure the bfd min-transmit-interval or bfd min-control-interval command, the device uses the default value for the bfd min-transmit-interval command as the minimum interval for transmitting single-hop BFD control packets.
· If you configure either the bfd min-transmit-interval or bfd min-control-interval command, the device uses the value configured for that command as the minimum interval for transmitting single-hop BFD control packets.
# Set the minimum interval for transmitting and receiving single-hop BFD control packets to 500 milliseconds on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd min-control-interval 500
bfd min-echo-receive-interval
Use bfd min-echo-receive-interval to set the minimum interval for receiving BFD echo packets.
Use undo bfd min-echo-receive-interval to restore the default.
The minimum interval for receiving BFD echo packets is 400 milliseconds.
Interface view
interval: Specifies the minimum interval for receiving BFD echo packets, in milliseconds. The value takes 0 or is in the range of 100 to 1000. The value takes 0 or is in the range of 100 to 1000.
This command sets the BFD echo packet receiving interval, which is the actual BFD echo packet sending interval.
The local end stops sending echo packets after autonegotiation with the remote end if the following conditions are met:
· The echo packet mode is enabled on the local end.
· The minimum interval for receiving BFD echo packets is set to 0 milliseconds on the remote end.
# Set the minimum interval for receiving BFD echo packets to 500 milliseconds on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd min-echo-receive-interval 500
Use bfd min-receive-interval to set the minimum interval for receiving single-hop BFD control packets.
Use undo bfd min-receive-interval to restore the default.
The minimum interval for receiving single-hop BFD control packets is 400 milliseconds.
Interface view
BFD template view
interval: Specifies the minimum interval for receiving single-hop BFD control packets, in milliseconds. The value range for this argument is 3 to 1000. The value range is 100 to 1000.
Use this command to prevent the control packet sending rate of the peer end from exceeding the control packet receiving rate of the local end.
The actual control packet sending interval of the peer end takes the greater value between the following values:
# Set the minimum interval for receiving single-hop BFD control packets to 500 milliseconds on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd min-receive-interval 500
Use bfd min-transmit-interval to set the minimum interval for transmitting single-hop BFD control packets.
Use undo bfd min-transmit-interval to restore the default.
The minimum interval for transmitting single-hop BFD control packets is 400 milliseconds.
Interface view
BFD template view
interval: Specifies the minimum interval for transmitting single-hop BFD control packets, in milliseconds. The value range is 100 to 1000.
Use this command to prevent the BFD packet sending rate from exceeding the device capability.
# Set the minimum interval for transmitting single-hop BFD control packets to 500 milliseconds on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd min-transmit-interval 500
Use bfd multi-hop authentication-mode to configure the authentication mode for multihop BFD control packets.
Use undo bfd multi-hop authentication-mode to restore the default.
bfd multi-hop authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher | plain } string
No authentication is performed.
A static BFD session supports this command only when it is in IPv4 or IPv6 control packet mode used for multihop detection.
# Configure the simple authentication mode for multihop BFD control packets, setting the authentication key ID to 1 and key to 123456.
[Sysname] bfd multi-hop authentication-mode simple 1 plain 123456
bfd static
Use bfd multi-hop destination-port to configure the destination port number for multihop BFD control packets.
Use undo bfd multi-hop destination-port to restore the default.
The destination port number for multihop BFD control packets is 4784.
port-number: Specifies the destination port number of multihop BFD control packets, 3784 or 4784.
IANA assigned port number 4784 to BFD for multihop BFD detection in control packet mode. By default, H3C devices use 4784 as the destination port number for multihop BFD control packets, while devices from other vendors might use 3784. To avoid BFD session establishment failures, make sure the devices on both ends of the BFD session use the same destination port number for multihop BFD control packets.
This command applies to only new multihop BFD sessions in control packet mode.
# Specify the destination port number for multihop BFD control packets as 3784.
[Sysname] bfd multi-hop destination-port 3784
Use bfd multi-hop detect-multiplier to set the multihop detection time multiplier for control packet mode and echo packet mode.
Use undo bfd multi-hop detect-multiplier to restore the default.
The multihop detection time multiplier for control packet mode and echo packet mode is 5.
value: Specifies the multihop detection time multiplier. The value range for this argument is 3 to 15.
Operating mechanism
The detection time multiplier determines the maximum number of concurrent BFD control packets that can be discarded.
Table 2 Actual detection interval calculation method
Mode |
· Static BFD sessions in IPv4 control packet mode used for multihop detection.
· Static BFD sessions in IPv4 echo packet mode used for multihop detection.
· Static BFD sessions in IPv6 control packet mode used for multihop detection.
· Static BFD sessions in IPv6 echo packet mode used for multihop detection.
# Set the multihop detection time multiplier to 6.
[Sysname] bfd multi-hop detect-multiplier 6
bfd static
Use bfd multi-hop min-control-interval to set the minimum interval for transmitting and receiving multihop BFD control packets.
Use undo bfd multi-hop min-control-interval to restore the default.
bfd multi-hop min-control-interval interval
The minimum interval for transmitting and receiving multihop BFD control packets is 400 milliseconds.
interval: Specifies the minimum interval for transmitting and receiving multihop BFD control packets, in milliseconds. The value range for this argument is 3 to 1000.
You can use the bfd multi-hop min-receive-interval and bfd multi-hop min-control-interval commands to adjust the minimum interval for receiving multihop BFD control packets. Follow these guidelines when you configure the commands:
· If you configure both the bfd multi-hop min-receive-interval and bfd multi-hop min-control-interval commands, the time interval configured by the bfd multi-hop min-receive-interval command takes precedence.
· If you do not configure the bfd multi-hop min-receive-interval or bfd multi-hop min-control-interval command, the device uses the default value for the bfd multi-hop min-receive-interval command as the minimum interval for receiving multihop BFD control packets.
· If you configure either the bfd multi-hop min-receive-interval or bfd multi-hop min-control-interval command, the device uses the value configured for that command as the minimum interval for receiving multihop BFD control packets.
You can use the bfd multi-hop min-transmit-interval and bfd multi-hop min-control-interval commands to adjust the minimum interval for transmitting multihop BFD control packets. Follow these guidelines when you configure the commands:
· If you configure both the bfd multi-hop min-transmit-interval and bfd multi-hop min-control-interval commands, the time interval configured by the bfd multi-hop min-transmit-interval command takes precedence.
· If you do not configure the bfd multi-hop min-transmit-interval or bfd multi-hop min-control-interval command, the device uses the default value for the bfd multi-hop min-transmit-interval command as the minimum interval for transmitting multihop BFD control packets.
· If you configure either the bfd multi-hop min-transmit-interval or bfd multi-hop min-control-interval command, the device uses the value configured for that command as the minimum interval for transmitting multihop BFD control packets.
# Set the minimum interval for transmitting and receiving multihop BFD control packets to 500 milliseconds.
[Sysname] bfd multi-hop min-control-interval 500
Use bfd multi-hop min-echo-receive-interval to set the minimum interval for receiving multihop BFD echo packets.
Use undo bfd multi-hop min-echo-receive-interval to restore the default.
bfd multi-hop min-echo-receive-interval interval
The minimum interval for receiving multihop BFD echo packets is 400 milliseconds.
interval: Specifies the minimum interval for receiving multihop BFD echo packets, in milliseconds. The value for this argument takes 0 or is in the range of 100 to 1000.
The interval for receiving multihop BFD echo packets is also the interval for sending multihop BFD echo packets. By executing this command, you can control both the receiving interval and sending interval for multihop BFD echo packets.
A static BFD session supports this command only when it is in IPv4 or IPv6 echo packet mode used for multihop detection.
# Set the minimum interval for receiving multihop BFD echo packets to 500 milliseconds.
[Sysname] bfd multi-hop min-echo-receive-interval 500
bfd static
Use bfd multi-hop min-receive-interval to set the minimum interval for receiving multihop BFD control packets.
Use undo bfd multi-hop min-receive-interval to restore the default.
The minimum interval for receiving multihop BFD control packets is 400 milliseconds.
interval: Specifies the minimum interval for receiving multihop BFD control packets, in milliseconds. The value range for this argument is 3 to 1000. The value range is 100 to 1000.
Use this command to prevent the packet sending rate of the peer end from exceeding the packet receiving capability (minimum control packet receiving interval) of the local end. If the receiving capability is exceeded, the peer end dynamically adjusts the BFD control packet sending interval to the minimum control packet receiving interval of the local end.
# Set the minimum interval for receiving multihop BFD control packets to 500 milliseconds.
[Sysname] bfd multi-hop min-receive-interval 500
bfd static
Use bfd multi-hop min-transmit-interval to set the minimum interval for transmitting multihop BFD control packets.
Use undo bfd multi-hop min-transmit-interval to restore the default.
The minimum interval for transmitting multihop BFD control packets is 400 milliseconds.
interval: Specifies the minimum interval for transmitting multihop BFD control packets, in milliseconds. The value range for this argument is 3 to 1000. The value range is 100 to 1000.
# Set the minimum interval for transmitting multihop BFD control packets to 500 milliseconds.
[Sysname] bfd multi-hop min-transmit-interval 500
bfd static
bfd session init-mode
Use bfd session init-mode to configure the mode for establishing a BFD session.
Use undo bfd session init-mode to restore the default.
BFD uses the active mode.
active: Specifies the active mode. In active mode, BFD actively transmits BFD control packets to the remote device, regardless of whether it receives a BFD control packet from the remote device.
passive: Specifies the passive mode. In passive mode, BFD does not actively transmit a BFD control packet to the remote end; it transmits a BFD control packet only after receiving a BFD control packet from the remote end.
A minimum of one end must operate in active mode for a BFD session to be established.
# Configure the session establishment mode as passive.
[Sysname] bfd session init-mode passive
Use bfd session-negotiation delay-upon-down to enable session negotiation delay for down BFD sessions and set a delay timer.
Use undo bfd session-negotiation delay-upon-down to restore the default.
bfd session-negotiation delay-upon-down interval
Session negotiation delay is disabled for down BFD sessions.
interval: Specifies a delay timer in the range of 1 to 1200 seconds.
If an upper-layer protocol uses BFD to detect the active path, an active/standby path switchover is triggered after the active path goes down. If the BFD session comes up before the active path recovers, the traffic on the standby path will be switched over to the active path. In this case, traffic loss will occur.
Operating mechanism
The session negotiation delay function starts a delay timer for each BFD session from up to down state and each newly created session. Before the timer expires, the device does not perform session negotiation on each BFD session. The delay timer allows the active path to recover completely before the BFD session comes up again.
# Enable session negotiation delay for down BFD sessions and set the delay timer to 6 seconds.
[Sysname] bfd session-negotiation delay-upon-down 6
display bfd session
Use bfd session-negotiation delay-upon-reboot to enable BFD session negotiation delay upon a device reboot and set a delay timer.
Use undo bfd session-negotiation delay-upon-reboot to restore the default.
bfd session-negotiation delay-upon-reboot interval
BFD session negotiation delay upon a device reboot is disabled.
If an upper-layer protocol uses BFD to detect the active path, an active/standby path switchover is triggered upon a device reboot. If the BFD session comes up after a device reboot, the traffic on the standby path will be switched over to the active path. In this case, traffic loss will occur if the active path of the upper-layer protocol has not recovered completely.
Operating mechanism
The session negotiation delay function starts a delay timer when the device reboots successfully. Before this timer expires, the device does not perform session negotiation on BFD sessions in down state or newly created sessions. The delay timer allows the active path to recover completely before the BFD session comes up again.
If both the bfd session-negotiation delay-upon-reboot and bfd session-negotiation delay-upon-down commands are executed, the device uses the longer delay time configured in the two commands after a reboot.
# Enable BFD session negotiation delay upon a device reboot and set the delay timer to 6 seconds.
[Sysname] bfd session-negotiation delay-upon-reboot 6
display bfd session
bfd static
Use bfd static to create a static BFD session and enter its view, or enter the view of an existing static BFD session.
Use undo bfd static to delete a static BFD session and all its settings.
For IPv4 single-hop detection with control packets:
bfd static session-name [ peer-ip ipv4-address interface interface-type interface-number source-ip ipv4-address [ discriminator { auto | local local-value remote remote-value } ] ]
bfd static session-name [ bind-route-aggregation peer-ip ipv4-address interface interface-type interface-number source-ip ipv4-address discriminator auto ]
For IPv4 multihop detection with control packets:
bfd static session-name [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] source-ip ipv4-address [ discriminator { auto | local local-value remote remote-value } ] [ track-interface interface-type interface-number ] ]
For IPv4 single-hop detection with echo packets:
bfd static session-name [ peer-ip ipv4-address interface interface-type interface-number destination-ip ipv4-address [ source-ip ipv4-address ] one-arm-echo [ discriminator { auto | local local-value } ] ]
For IPv4 multihop detection with echo packets:
bfd static session-name [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] destination-ip ipv4-address [ source-ip ipv4-address ] one-arm-echo [ discriminator { auto | local local-value } ] ]
For IPv6 single-hop detection with control packets:
bfd static session-name [ peer-ipv6 ipv6-address interface interface-type interface-number source-ipv6 ipv6-address[ discriminator { auto | local local-value remote remote-value } ] ]
bfd static session-name [ bind-route-aggregation peer-ipv6 ipv6-address interface interface-type interface-number source-ipv6 ipv6-address discriminator auto ]
For IPv6 multihop detection with control packets:
bfd static session-name [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] source-ipv6 ipv6-address [ discriminator { auto | local local-value remote remote-value } ] [ track-interface interface-type interface-number ] ]
For IPv6 single-hop detection with echo packets:
bfd static session-name [ peer-ipv6 ipv6-address interface interface-type interface-number destination-ipv6 ipv6-address [ source-ipv6 ipv6-address ] one-arm-echo [ discriminator { auto | local local-value } ] ]
For IPv6 multihop detection with echo packets:
bfd static session-name [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] destination-ipv6 ipv6-address [ source-ipv6 ipv6-address ] one-arm-echo [ discriminator { auto | local local-value } ] ]
undo bfd static session-name
No static BFD sessions exist.
session-name: Specifies a static BFD session name, a case-sensitive string of 1 to 64 characters.
peer-ip ipv4-address: Specifies the peer IPv4 address in dotted decimal notation. It must be a valid unicast IPv4 address. The peer IPv4 address and the source IPv4 address determine the path to be detected.
peer-ipv6 ipv6-address: Specifies the peer IPv6 address. The peer IPv6 address and the source IPv6 address determine the path to be detected.
bind-route-aggregation: Creates a static BFD session for detecting the aggregate link of a Layer 3 aggregate interface.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the static BFD session belongs to the public network.
interface interface-type interface-number: Specifies an interface by its type and number. BFD uses the specified interface as the outgoing interface for outgoing packets.
destination-ip ipv4-address: Specifies the IPv4 destination address for echo packets, in dotted decimal notation. The IPv4 destination address must be a valid unicast IPv4 address of the local device.
destination-ipv6 ipv6-address: Specifies the IPv6 destination address for echo packets. The IPv6 destination address must be the IP address of the local device.
one-arm-echo: Specifies the echo packet mode for the static BFD session.
source-ip ipv4-address: Specifies the source IPv4 address for control packets, in dotted decimal notation. It must be a valid unicast IPv4 address.
source-ipv6 ipv6-address: Specifies the source IPv6 address for control packets.
local local-value: Specifies the local discriminator in the range of 1 to 32768.
auto: Enables the device to automatically assign local discriminator values to static BFD sessions.
track-interface interface-type interface-number: Specifies an interface monitored by the static BFD session. When the monitored interface fails, the static BFD session changes to the down state. If you do not specify an interface, the static BFD session does not monitor any interfaces. A static BFD session supports monitoring the following interface types:
· Layer 3 Ethernet interfaces and their subinterfaces.
· Layer 2 aggregate interfaces and their member ports.
· Layer 3 aggregate interfaces and their subinterfaces and member ports.
A static BFD session can be used for single-hop detection and multihop detection. By working with Track, a static BFD session can provide fast failure detection. For more information about Track association with BFD, see Track in High Availability Configuration Guide.
Recommended configuration (for a VPN VPWS dual-homed network)
In a VPN VPWS dual-homed network, when the AC of a DF fails, the BDF cannot quickly detect the failure to take over. To solve this problem, you can configure a static BFD session on the DF to monitor the AC state and execute the evpn track bfd command on the BDF. The takeover process occurs as follows:
1. When the AC of the DF fails, the DF sets the static BFD session to the down state and notifies the BDF.
2. The BDF quickly takes over as the DF, which minimizes packet loss.
For more information about EVPN VPWS networking and DF election, see EVPN VPWS configuration in EVPN Configuration Guide.
Recommended configuration (for Ethernet link aggregation)
To use BFD to detect an aggregate link, choose one as needed:
· Method 1: Execute the link-aggregation bfd command to enable BFD for an aggregation group.
· Method 2: Execute the bfd static command with the bind-route-aggregation keyword specified to create static BFD sessions for detecting an aggregate link and its member links.
If you use Method 1, the Ethernet link aggregation module will mistakenly consider the aggregation link unavailable when the BFD session goes down due to the failure of a single member link. To avoid this issue, use Method 2. To perform multihop detection, use Method 1, because Method 2 only supports single-hop detection.
The operating mechanisms and restrictions and guidelines of the two methods are as shown in Table 3. You can choose only one of the methods.
Table 3 Methods of using BFD to detect an aggregate link
Method |
Operating mechanism |
Single-hop/multihop detection |
Restrictions and guidelines |
Method 1 |
Create a BFD session for detecting the aggregate link. Each member interface of the aggregate link takes turns to send BFD packets. |
Only single-hop detection is supported. |
· Make sure the source and destination IP addresses are configured in pairs between the two ends of the aggregate link. For example, if you execute link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2 at the local end, execute link-aggregation bfd ipv4 source 2.2.2.2 destination 1.1.1.1 at the peer end. The source and destination IP addresses must be different unicast addresses other than 0.0.0.0. · You can configure only one static BFD session to detect the aggregate link of an aggregate interface. · You cannot execute the link-aggregation bfd command for aggregate sub-interfaces. |
Method 2 |
1. Create a static BFD session to associate with the aggregated link. 2. Create a static BFD sub-session for detecting each member interface of the aggregated link. 3. The BFD session is in up state as long as a sub-session is in up state, indicating the aggregated link is available. The BFD session goes down only when all sub-sessions are in down state, indicating the aggregated link is unavailable. |
· Make sure the source and destination IP addresses are configured in pairs between the two ends. For example, if you execute bfd static abc bind-route-aggregation peer-ipv4 1.1.1.1 interface route-aggregation 1 source-ipv4 1.1.1.2 discriminator auto at the local end, execute bfd static abc bind-route-aggregation peer-ipv4 1.1.1.2 interface route-aggregation 1 source-ipv4 1.1.1.1 discriminator auto at the peer end. The source and destination IP addresses must be different unicast addresses other than 0.0.0.0. · You can configure only one static BFD session to detect the aggregate link of an aggregate interface. · You cannot execute the bfd static bind-route-aggregation command for aggregate sub-interfaces. · If you associate an aggreatate interface with a VPN instance or remove the association, the device will delete the BFD session and create a BFD session again. |
If the peer device creates a static BFD session in control packet mode, you must use this command the local device to create a static BFD session. The BFD session discriminators must match on the local and peer devices. For example, if you configure bfd static abc peer-ip 20.1.1.1 vpn-instance vpn1 source-ip 20.1.1.2 discriminator local 513 remote 514 on the local device, you must configure bfd static bcd peer-ip 20.1.1.2 vpn-instance vpn1 source-ip 20.1.1.1 discriminator local 514 remote 513 on the peer device.
When creating a static BFD session, you must specify a peer IP address. The system checks only the format of the IP address but not its correctness. If the peer IPv4 or IPv6 address is incorrect, the static BFD session cannot be established.
If you do not specify the local discriminator or remote discriminator when creating a static BFD session, you must perform either of the following tasks for the BFD session to take effect:
· Use the discriminator command to specify the local discriminator and remote discriminator for the static BFD session.
· Execute the undo bfd static command and then execute the bfd static command to re-create the static BFD session with the local and remote discriminators specified.
The bfd static session-name command without any parameters specified can only be used to enter the view of an existing static BFD session.
If you use a static BFD session in control packet mode to perform single-hop detection, make sure the following requirements are met for the BFD session to be successfully established:
· The IP address of the peer interface where the static BFD session resides is used as the peer IP address.
· The IP address of the local interface where the static BFD session resides is used as the source IP address.
To modify a static BFD session, delete the static BFD session and then configure a new static BFD session.
Different static BFD sessions cannot have the same local discriminator.
To specify the TTL value for BFD packets by using the bfd ttl command after creating a static BFD session for detecting the aggregate link by using the bfd static bind-route-aggregation command, follow these restrictions and guidelines:
· To make sure the static BFD session goes up correctly, specify different peer-ip options in the bfd ttl and bfd static bind-route-aggregation commands.
· To make sure the static BFD session goes up correctly, specify different peer-ipv6 options in the bfd ttl and bfd static bind-route-aggregation commands.
# Create a static BFD session and enter its view. The static BFD session detects the link with the outgoing interface VLAN-interface 10 and the next hop 1.1.1.2. The source IP address for the session is 1.1.1.1, the local discriminator is 1537, and the remote discriminator is 2048.
[Sysname] bfd static abc peer-ip 1.1.1.2 interface vlan-interface 10 source-ip 1.1.1.1 discriminator local 1537 remote 2048
[Sysname-bfd-static-session-abc]
# Create a static BFD session in echo mode and enter its view. The static BFD session detects the path between 1.1.1.1 and 1.1.1.2 and uses VLAN-interface 10 to send BFD packets with source IP address 9.9.9.9 and destination IP address is 1.1.1.2.
[Sysname] bfd static abc peer-ip 1.1.1.1 interface vlan-interface 11 destination-ip 1.1.1.2 source-ip 9.9.9.9 one-arm-echo discriminator auto
bfd ttl
discriminator
evpn track bfd (EVPN Command Reference)
track bfd
bfd template
Use bfd template to create a BFD template and enter its view, or enter the view of an existing BFD template.
Use undo bfd template to delete the BFD template.
bfd template template-name
undo bfd template template-name
No BFD templates exist.
template-name: Specifies the template name, a case-sensitive string of 1 to 63 characters.
# Create BFD template bfd1 and enter BFD template view.
[Sysname] bfd template bfd1
[Sysname-bfd-template-bfd1]
bfd ttl
Use bfd ttl to specify the TTL value for BFD packets.
Use undo bfd ttl to restore the default.
bfd { peer-ip ipv4-address mask-length | peer-ipv6 ipv6-address prefix-length } ttl { single-hop | multi-hop } ttl-value
undo bfd { peer-ip ipv4-address mask-length | peer-ipv6 ipv6-address prefix -length } ttl { single-hop | multi-hop }
The TTL value of a single-hop BFD packet is 255. The TTL value of a multihop BFD packet is 64.
peer-ip ipv4-address mask-length: Specifies a peer IPv4 address range for the BFD session. The ipv4-address argument represents a valid unicast IPv4 address in dotted decimal notion. The mask-length argument represents the mask length in the range of 8 to 32.
peer-ipv6 ipv6-address prefix-length: Specifies a peer IPv6 address range for the BFD session. The ipv6-address argument represents an IPv6 address. The prefix-length argument represents a prefix length in the range of 16 to 128.
single-hop: Specifies single-hop BFD sessions.
multi-hop: Specifies multihop BFD sessions.
ttl-value: Specifies the TTL value for BFD packets. The value range for this argument is 1 to 255.
When you connect an H3C device to a third-party device, for successful BFD session negotiation, make sure the TTL value settings for BFD packets on both ends of the BFD session are the same.
Operating mechanism
When the device receives a BFD packet in DOWN or INIT state from its peer, it verifies the TTL value of the packet and performs one of the following actions:
· For a single-hop BFD session, if the device receives a packet that carries a TTL value that is different from the TTL value specified with this command, the device drops the packet.
· For a multihop BFD session, if the device receives a packet that carries a TTL value that is greater than the TTL value specified with this command, the device drops the packet.
· If the BFD session is already up, the device sets the BFD session state to AdminDown, which triggers a BFD session renegotiation.
Follow these guidelines when you set the TTL value for BFD packets:
· This command does not take effect on BFD sessions in echo packet mode.
· For an IPv4 or IPv6 address with different mask lengths or prefix lengths, the device uses the TTL value specified with the longest mask or prefix length. For example, if the peer IP address of a BFD session is 10.10.10.1 and the following commands are configured, the device uses TTL value 253 for BFD packets.
¡ bfd peer-ip 10.10.10.0 23 ttl single-hop 254
¡ bfd peer-ip 10.10.10.0 24 ttl single-hop 253
· For an IPv4 or IPv6 subnet, the TTL value of single-hop BFD packets must be greater than the TTL value of multihop BFD packets.
# Set the TTL value of single-hop BFD packets to 254, and specify the peer IP address of the BFD session as 10.10.10.0 and the mask length as 24.
[Sysname] bfd peer-ip 10.10.10.0 24 ttl single-hop 254
bfd static
display bfd ttl
discriminator
Use discriminator to specify the local discriminator and remote discriminator for a static BFD session.
Use undo discriminator to remove the local discriminator and remote discriminator for the static BFD session.
discriminator { local local-value | remote remote-value }
undo discriminator { local local-value | remote remote-value }
No local discriminator or remote discriminator is specified for a static BFD session.
Use this command only if you do not specify the discriminators when creating a static BFD session.
To modify the local or remote discriminator of a static BFD session, execute the undo discriminator command to delete the local or remote discriminator and then the discriminator command to specify a new local or remote discriminator.
# Create local discriminator 1537 and remote discriminator 2048 for static BFD session abc.
[Sysname-bfd-static-session-abc] discriminator local 1537
[Sysname-bfd-static-session-abc] discriminator remote 2048
bfd static
display bfd session
Use display bfd session to display BFD session information.
display bfd session [ discriminator local local-value | static session-name | verbose ]
display bfd session [ [ dynamic ] [ control | echo ] [ ip ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] [ ipv6 ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] [ lsp | te | pw ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] | [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] ] [ verbose ] ]
display bfd session [ [ static ] [ ip ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] [ verbose ]
display bfd session [ [ static ] [ ipv6 ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ]
discriminator local local-value: Specifies a BFD session by its local discriminator. The value range for the local-value argument is 1 to 4294967295.
static session-name: Specifies a static BFD session by its name, a case-sensitive string of 1 to 64 characters.
dynamic: Specifies dynamic BFD sessions.
static: Specifies static BFD sessions.
control: Specifies BFD sessions in control packet mode.
echo: Specifies BFD sessions in echo mode.
ip: Specifies BFD sessions used to detect IPv4 links.
ipv6: Specifies BFD sessions used to detect IPv6 links.
lsp: Specifies BFD sessions used to detect MPLS LSPs.
te: Specifies BFD sessions used to detect MPLS TE tunnels.
pw: Specifies BFD sessions used to detect PWs.
state: Displays BFD sessions by session state.
down: Specifies BFD sessions in Down state.
admin-down: Specifies BFD sessions in AdminDown state.
init: Specifies BFD sessions in Init state.
up: Specifies BFD sessions in Up state.
discriminator remote remote-value: Specifies a BFD session by its remote discriminator in the range of 1 to 4294967295.
peer-ip ipv4-address: Specifies a BFD session by the peer IPv4 address in dotted decimal notation.
peer-ipv6 ipv6-address: Specifies a BFD session by the peer IPv6 address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays the BFD sessions of the public network.
verbose: Displays detailed BFD session information.
If you do not specify the dynamic or static keyword, this command displays all dynamic and static BFD sessions.
# Display brief information about all BFD sessions.
<Sysname> display bfd session
Total sessions: 6 Up sessions: 6 Init mode: Active
513/513 1.1.1.1 1.1.1.2 Up 2297ms Vlan100
IPv6 session working in control packet mode:
Local discr: 513 Remote discr: 513
Source IP: FE80::20C:29FF:FED4:7171
Destination IP: FE80::20C:29FF:FE72:AC4D
Session state: Up Interface: Vlan100
Hold time: 2142ms
MPLS LSP session working in control packet mode:
32773/32770 1.1.1.9 3.3.3.9 Up 0ms N/A
IPv4 static session working in control packet mode:
1600/1600 1.1.1.1 1.1.1.2 Up 2290ms Vlan100
IPv6 static session working in control packet mode:
Local discr: 1700 Remote discr: 1700
Hold time: 2142ms
MPLS PW session working in control packet mode:
20481/20481 2.2.2.2 127.0.0.1 Up 2489ms N/A
Total Session Num |
Total number of BFD sessions. |
Up Session Num |
Total number of active BFD sessions. |
Init Mode |
BFD operating mode: Active or passive. |
IPv4 session working in control packet mode |
BFD session type and operating mode: · IPv4 session working in control packet mode. · IPv4 session working in echo mode. · IPv6 session working in control packet mode. · IPv6 session working in echo mode. · MPLS LSP session working in control packet mode—BFD session in control packet mode used to detect failures in an LSP. · MPLS LSP session working in echo mode—BFD session in echo packet mode used to detect failures in an LSP. · IPv4 static session working in control packet mode. · IPv6 static session working in control packet mode. · MPLS PW session working in control packet mode—BFD session in control packet mode used to detect failures of an LDP PW or static PW. · MPLS PW session working in echo mode—BFD session in echo mode used to detect failures of an LDP PW or static PW. · MPLS PW static session working in control packet mode—Static BFD session in control packet mode used to detect failures of an LDP PW or static PW. |
LD/RD |
Local discriminator/Remote discriminator of the session. |
SourceAddr |
Source IP address of the session. |
DestAddr |
Destination IP address of the session. |
Session State/State |
Session state: Down, Init, or Up. |
Name of the interface of the session. |
Hold Time/Holdtime |
Length of time before the session detection timer expires, in milliseconds. For a BFD session in Down state, this field displays 0ms. |
Local discr |
Local discriminator of the session. |
Remote discr |
Source IP |
Source IPv6 address of the session. |
Destination IP |
Destination IPv6 address of the session. |
# Display detailed BFD session information.
<Sysname> display bfd session verbose
Source IP: 1.1.1.1 Destination IP: 1.1.1.2
Destination port: 3784 Session state: Up
Interface: Vlan-interface100
Min Tx interval: 500ms Actual Tx interval: 500ms
Min Rx interval: 500ms Detection time: 2500ms
Rx count: 42 Tx count: 43
Connection type: Direct Up duration: 00:00:20
Hold time: 2078ms Auth mode: None
Detect mode: Async Slot: 1
Protocol: OSPF
Version: 1 TTL: 255
Diag info: No Diagnostic
Hardware mode: Disable
Tracked interface: Vlan-interface100
Rx count: 38 Tx count: 38
Connection type: Direct Up duration: 00:00:15
Hold time: 2211ms Auth mode: None
Detection mode: Async Slot: 1
Protocol: OSPFv3
Version: 1 TTL: 255
Local discr: 32774 Remote discr: 32770
Source IP: 1.1.1.9 Destination IP: 3.3.3.9
Destination port: 4784 Session state: Up
Interface: N/A
Min Tx interval: 1000ms Actual Tx interval: 3000ms
Min Rx interval: 1000ms Detection time: 150000ms
Rx count: 1 Tx count: 13
Connection type: Indirect Up duration: 00:00:36
Hold time: 0ms Auth mode: None
Protocol: MPLS_LSPV
Version: 1 TTL: 255
Session name: aaaa
Local discr: 1600 Remote discr: 1600
Protocol: STATIC_IPv4
Version: 1 TTL: 255
Session name: bbbb
Protocol: STATIC_IPv6
Version: 1 TTL: 255
Local discr: 20481 Remote discr: 20481
Source IP: 2.2.2.2 Destination IP: 127.0.0.1
Interface: N/A
Rx count: 72 Tx count: 73
Connection type: Indirect Up duration: 00:00:30
Hold time: 2489ms Auth mode: None
Protocol: MPLS_LSPV
Version: 1 TTL: 255
Table 5 Command output
Total sessions |
Up sessions |
Init mode |
BFD session type and operating mode: · IPv4 session working in control packet mode. · IPv4 session working in echo mode. · IPv6 session working in control packet mode. · IPv6 session working in echo mode. · MPLS LSP session working in control packet mode—BFD session in control packet mode used to detect failures in an LSP. · MPLS LSP session working in echo mode—BFD session in echo mode used to detect failures in an LSP. · IPv4 static session working in control packet mode. · IPv6 static session working in control packet mode. · MPLS PW session working in control packet mode. · MPLS PW session working in echo mode. · MPLS PW static session working in control packet mode. |
Local discr |
Remote discr |
Source IP |
Destination IP |
Destination port |
Destination port number in BFD packets defined in Comware: · The destination port number in single-hop BFD control packets is 3784. · The destination port number in single-hop or multihop BFD echo packets is 3785. · The destination port number in multihop BFD control packets is 4784. · The destination port number in BFD control packets for association between link aggregation and BFD is 6784. The device uses the destination port number in incoming packets that are not defined in Comware as the destination port number in outgoing BFD packets. |
Session state |
Session state: Down, AdmDown, Init, or Up. |
Min Tx interval |
Minimum transmit interval. |
Min Rx interval |
Minimum receive interval. |
Actual Tx interval |
Actual transmit interval in milliseconds. After you enable BFD session negotiation delay, this field displays a hyphen (-) before the timer expires. |
Detection time |
Actual session detection timer. |
Rx count |
Number of packets received. |
Tx count |
Number of packets sent. |
Hold time |
Length of time before session detection timer expires. For a BFD session in down state, this field displays 0ms. |
Auth mode |
Session authentication mode. Options include: · None—No authentication. · Simple—Simple authentication. · MD5—Use the MD5 algorithm for authentication. · MMD5—Use the Meticulous MD5 algorithm for authentication. · SHA1—Use the SHA1 algorithm for authentication. · MSHA1—Use the Meticulous SHA1 algorithm for authentication. · HMAC-MD5—Use the HMAC-based MD5 algorithm for authentication. · HMAC-MMD5—Use the HMAC-based Meticulous MD5 algorithm for authentication. · HMAC-SHA1—Use the HMAC-based SHA1 algorithm for authentication. · HMAC-MSHA1—Use the HMAC-based Meticulous SHA1 algorithm for authentication. Changing the session authentication mode triggers smooth authentication migration. During this process, BFD sends packets carrying both the old and new authentication modes. The BFD session state remains up. During the smooth authentication migration process, this field displays Old_Authentication_Mode(New_Authentication_Mode), for example, Simple(MD5). |
Connection type |
Connection type of the interface: Direct or Indirect. |
Up duration |
Time period for which the session has been up. |
Detect mode |
Detection mode: · Async—Asynchronous mode. · Demand—Demand mode. · Async/Echo—Asynchronous mode with echo detection enabled. · Demand/Echo—Demand mode with echo detection enabled. |
Slot |
ID of the device where the BFD session resides. |
Protocol |
Protocol associated with BFD: · OSPF. · ISIS_BR_L1—IS-IS with the network type as broadcast and the router type as Level 1. · ISIS_BR_L2—IS-IS with the network type as broadcast and the router type as Level 2. · ISIS_P2P—IS-IS with the network type as P2P. · ISIS6_BR_L1—IPv6 IS-IS with the network type as broadcast and the router type as Level 1. · ISIS6_BR_L2—IPv6 IS-IS with the network type as broadcast and the router type as Level 2. · ISIS6_P2P—IPv6 IS-IS with the network type as P2P. · BGP. · MPLS_RSVP. · STATIC4—IPv4 static routing. · TRACK—Track. · RIP. · IPFRR—FIB IP FRR. · MAD. · MPLS_LSPV. · OSPFv3. · BGP4+. · PIM. · PIM6—IPv6 PIM. · STATIC6—IPv6 static routing. · RIPNG—RIPng. · Interface—Interface state. · TUNNEL. · VTEP. · LAGG—Link aggregation. · STATIC_IPv4—IPv4 static BFD session. · STATIC_IPv6—IPv6 static BFD session. |
TTL |
TTL value of BFD packets. |
Diag info |
Diagnostic information about the session: · No Diagnostic. · Control Detection Time Expired—A control-mode BFD session goes down because local detection times out. · Echo Function Failed—An echo-mode BFD session goes down, because local detection times out or the source IP address of echo packets is deleted. · Neighbor Signaled Session Down—The remote end notifies the local end of BFD session down. · Administratively Down—The local system prevents a BFD session from being established. |
Hardware mode |
Whether BFD packets are processed in hardware: · Enabled. · Disable—BFD packets are processed in software. |
Tracked interface |
Interface monitored by the static BFD session. |
Remaining delay time |
Remaining session negotiation delay time in seconds. If you do not enable BFD session negotiation delay, or the timer has expired, this field is not displayed. |
bfd static
display bfd session route-aggregation
Use display bfd session route-aggregation to display information about static BFD sessions created to detect the aggregate links and member links of Layer 3 aggregate interfaces.
display bfd session route-aggregation [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies the type and number of a Layer 3 aggregate interface. If you do not specify this option, the command displays information about all Layer 3 aggregate interfaces.
# Display information about static BFD sessions created to detect the aggregate links and member links of all Layer 3 aggregate interfaces.
Total up/down main sessions : 1/0
Total up/down sub sessions : 3/0
Session name : lagg
Session state : Up
Local discr : 32833
Source IP : 192.168.1.1
Destination IP : 192.168.1.2
Interface : Route-Aggregation1
Min Tx interval : 400ms
Min Rx interval : 400ms
Auth mode : None
Up duration : 00:00:08
Connection type : Direct
Detection mode : Async
Protocol : STATIC_IPv4/LAGG(MAIN)
Slot : 1
Version : 1
Diag info : No Diagnostic
Sub Session Count : 3
Sub session number : 1
Session state : Up
Local discr : 32834
Remote discr : 32834
Interface : HundredGigE1/1/1
Actual Tx interval : 400ms
Detection time : 2000ms
Rx count : 28
Tx count : 52
Hold time : 1621ms
Auth mode : None
Protocol : LAGG(SUB)/STATIC_IPv4
Slot : 1
Version : 1
Sub session number : 2
Session state : Up
Local discr : 32835
Remote discr : 32835
Interface : HundredGigE1/1/2
Rx count : 28
Tx count : 52
Hold time : 1925ms
Auth mode : None
Slot : 1
Version : 1
Sub session number : 3
Session state : Up
Local discr : 32836
Remote discr : 32836
Interface : HundredGigE1/1/3
Rx count : 28
Tx count : 52
Hold time : 1705ms
Auth mode : None
Slot : 1
Version : 1
Table 6 Command output
Total up/down main sessions |
Total number of static main BFD sessions in Up/Down state. |
Total up/down sub sessions |
Total number of static sub BFD sessions in Up/Down state. |
Session state |
Session state. Options include Down, Init, and Up. |
Local discr |
Local disclaimer of the session. |
Remote discr |
Source IP |
Destination IP |
Name and number of the interface on which the session is created. |
Min Tx interval |
Minimum transmission interval in milliseconds. |
Min Rx interval |
Minimum receiving interval in milliseconds. |
Auth mode |
Session authentication mode. Options include: · None—No authentication. · Simple—Simple authentication. · MD5—Use the MD5 algorithm for authentication. · MMD5—Use the Meticulous MD5 algorithm for authentication. · SHA1—Use the SHA1 algorithm for authentication. · MSHA1—Use the Meticulous SHA1 algorithm for authentication. · HMAC-MD5—Use the HMAC-based MD5 algorithm for authentication. · HMAC-MMD5—Use the HMAC-based Meticulous MD5 algorithm for authentication. · HMAC-SHA1—Use the HMAC-based SHA1 algorithm for authentication. · HMAC-MSHA1—Use the HMAC-based Meticulous SHA1 algorithm for authentication. · Changing the session authentication mode triggers smooth authentication migration. During this process, BFD sends packets carrying both the old and new authentication modes. The BFD session state remains up. During the smooth authentication migration process, this field displays Old_Authentication_Mode(New_Authentication_Mode), for example, Simple(MD5). |
Up duration |
Session up duration in the hh:mm:ss format. |
Connection type |
Connection type of the interface. Options include: · Direct—Direct connection. · Indirect—Indirect connection. |
Detection mode |
Detection mode. Options include: · Async—Asynchronous mode. · Demand—Query mode. · Async/Echo—Asynchronous mode enabled with the echo function. · Demand/Echo—Query mode enabled with the echo function. |
Protocol |
Protocol used for BFD collaboration. Options include: · STATIC_IPv4/LAGG(MAIN)—Detect the static BFD main session for the IPv4 aggregate link of the aggregate interface. · STATIC_IPv6/LAGG(MAIN)—Detect the static BFD main session for the IPv6 aggregate link of the aggregate interface. · LAGG(SUB)/STATIC_IPv4—Detect the static BFD sub session for the IPv4 member link of the aggregate interface. · LAGG(SUB)/STATIC_IPv6—Detect the static BFD sub session for the IPv6 member link of the aggregate interface. |
Slot |
Slot number of the card where the BFD session resides. Slot number of the card where the BFD session resides. |
Version |
BFD session version. |
Diag info |
Session diagnosis information. Options include: · No Diagnostic—No diagnosis information. · Control Detection Time Expired—The local detection timer of the control session expired and the session is down. · Echo Function Failed—The local detection timer of the Echo session expired or the source IP address of the Echo packets is deleted. The session is down. · Neighbor Signaled Session Down—The peer notified the local end of the BFD session down event. · Administratively Down—The local system prevents the BFD session from being established. |
Sub Session Count |
Number of static BFD sub sessions. |
Sub session number |
Number of the static BFD sub session. |
Actual transmission interval in milliseconds. |
Detection time |
Actual detection interval in milliseconds. |
Rx count |
Number of received packets. |
Tx count |
Number of sent packets. |
Hold time |
Remaining time before session detection times out. When the BFD session is in down state, this field displays 0ms. |
display bfd ttl
Use display bfd ttl to display the TTL values for BFD packets.
display bfd ttl
# Display the TTL values for BFD packets.
<Sysname> display bfd ttl
Peer IP Mask length Type TTL value
10.10.10.0 24 single-hop 255
10.1.1.0 25 multi-hop 254
Peer IPv6 Prefix length Type TTL value
10:1:: 64 single-hop 255
11:1:: 96 multi-hop 255
Table 7 Command output
Peer IP |
Peer IPv4 address of the BFD session. |
Peer IPv6 |
Peer IPv6 address of the BFD session. |
Mask length |
Mask length of the IPv4 address. |
Prefix length |
Prefix length of the IPv6 address. |
Type |
Detection type of the BFD session: · single-hop—Single-hop detection. · multi-hop—Multihop detection. |
TTL value |
bfd ttl
reset bfd session statistics
Use reset bfd session statistics to clear the BFD session statistics.
# Clear the BFD session statistics.
<Sysname> reset bfd session statistics
snmp-agent trap enable bfd
Use snmp-agent trap enable bfd to enable SNMP notifications for BFD.
Use undo snmp-agent trap enable bfd to disable SNMP notifications for BFD.
All SNMP notifications are enabled for BFD.
To report critical BFD events to an NMS, enable SNMP notifications for BFD. For BFD event notifications to be sent correctly, you must also configure SNMP as described in the network management and monitoring configuration guide for the device.
# Disable SNMP notifications for BFD.
[Sysname] undo snmp-agent trap enable bfd
