09-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S9820-G & S9825-G & S9855-G Switch Series Command References-R8336P05-6W10009-Security Command Reference
27-IP-SGT mapping commands
27-IP-SGT mapping commands 126.28 KB
display ipsgt map
Use display ipsgt map to display IP-SGT mapping entries deployed by the EIA server.
display ipsgt map [ critical ] [ ip [ ipv4-address ] | ipv6 [ ipv6-address ] ] [ microsegment microsegment-id ] [ vpn-instance vpn-instance-name ]
critical: Displays fail-permit IP-SGT mapping entries.
ip [ ipv4-address ]: Specifies an IPv4 address. If you do not specify this option, this command displays all IPv4 IP-SGT mapping entries.
ipv6 [ ipv6-address ]: Specifies an IPv6 address. If you do not specify this option, this command displays all IPv6 IP-SGT mapping entries.
microsegment microsegment-id: Specifies a microsegment ID in the range of 1 to 65535.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string in the range of 1 to 31 characters. If you do not specify this option, this command displays IP-SGT mapping entries in the public network.
If you do not specify any keyword or parameter, this command displays all IP-SGT mapping entries.
# Display all IP-SGT entries.
<Sysname> display ipsgt map
Total IPv4 IP-SGT entries: 1
 Microsegment ID: 1
   IPv4 address             VPN-instance
   1.1.1.1                   N/A
Total IPv6 IP-SGT entries: 1
Microsegment ID: 2
   IPv6 address             VPN-instance
   11::5                     N/A
# Display all fail permit IP-SGT mapping entries.
<Sysname> display ipsgt map critical
Total IPv4 critical IP-SGT entries: 1
 Microsegment ID: 1
   IPv4 address             VPN instance
   1.1.1.1                  N/A
Total IPv6 critical IP-SGT entries: 1
 Microsegment ID: 2
   IPv6 address             VPN instance
   11::5                    N/A
Filed
Total number of IPv4 IP-SGT mapping entries.
Total number of IPv6 IP-SGT mapping entries.
Total number of IPv4 fail-permit IP-SGT mapping entries.
Total number of IPv6 fail-permit IP-SGT mapping entries.
VPN-instance
VPN instance name. This field displays N/A if the entry does not belong to any VPN.
ipsgt enable
ipsgt on-demand
display ipsgt on-demand
Use display ipsgt on-demand to display the subnets for on-demand IP-SGT mapping.
display ipsgt on-demand [ ip [ ipv4-address { mask-length | mask } ] | ipv6 [ ipv6-address prefix-length ] ] [ vpn-instance vpn-instance-name ]
ip [ ipv4-address { mask-length | mask }: Specifies an IPv4 subnet. If you do not specify the ipv4-address argument, this command displays all IPv4 on-demand mapping subnets. The ipv4-address argument represents the IPv4 address, the mask-length argument represents the mask length in the range of 0 to 31, and the mask argument represents the mask in dotted decimal notation. The mask cannot be 255.255.255.255.
ip [ ipv6-address prefix-length ]: Specifies an IPv6 subnet. If you do not specify the ipv6-address argument, this command displays all IPv6 on-demand mapping subnets. The ipv6-address argument represents the IPv6 address and the prefix-length argument represents the prefix length in the range of 0 to 127.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string in the range of 1 to 31 characters. If you do not specify this option, this command displays on-demand mapping entries in the public network.
If you do not specify any parameters, this command displays all IPv4 and IPv6 on-demand mapping subnets.
# Display all the IPv4 and IPv6 subnets for on-demand IP-SGT mapping.
<Sysname> display ipsgt on-demand
Total IPv4 on-demand networks: 1
  IPv4 address              Mask                    VPN-instance
  1.1.1.1                   255.255.255.0           N/A
Total IPv6 on-demand networks: 1
  IPv6 address              Prefix length           VPN-instance
  11::5                     64                      N/A
Total number of IPv4 on-demand mapping subnets.
Total number of IPv6 on-demand mapping subnets.
VPN-instance
ipsgt on-demand
display ipsgt state
Use display ipsgt state to display the operating status of IP-SGT mapping.
display ipsgt state
# Display the operating status of IP-SGT mapping.
<Sysname> display ipsgt state
 Global IP-SGT parameters:
   IP-SGT: Enabled
   Connection status with:
       EIA server: Connected
       IPv4 routing management: Connected
       IPv6 routing management: Connected
   IP-SGT URL
       https://1.1.1.1/ipsgtmgr/vim    active
       https://2.1.1.1/ipsgtmgr/vim    inactive
IP-SGT
Enabling status:
·     Enabled.
·     Disabled.
Connection status.
EIA server
Connection status with the EIA cloud server:
·     Connected.
·     Disconnected.
Connection status with the IPv4 routing management module:
·     Connected.
·     Disconnected.
Connection status with the IPv6 routing management module:
·     Connected.
·     Disconnected.
IP-SGT URL
URL deployed by the EIA server for establishing an IP-SGT tunnel. Tunnel states include:
·     active.
·     inactive.
The two tunnels displayed in the information indicate the establishment of active and standby IP-SGT tunnels. The active and standby tunnels are not established simultaneously. The standby tunnel is used when the active tunnel fails and returns to backup state when the active tunnel becomes normal.
ipsgt enable
display ipsgt statistics
Use display ipsgt statistics to display IP-SGT mapping packet statistics.
# Display IP-SGT mapping packet statistics.
<Sysname> display ipsgt statistics
Messages received
  Add mapping:                          1
  Delete mapping:                       1
  Batch backup start:                   0
  Batch backup end:                     0
  Invalid:                               0
Messages sent
  Add mapping:                          1
  Delete mapping:                       1
  Update mapping:                       0
  Add critical                          0
  Delete critical:                      0
  Update critical:                      0
  Add On-demand network:                1
  Delete on-demand Network:             1
  Batch backup start:                   1
  Batch backup mapping:                 1
  Batch backup critical:                0
  Batch backup end:                     1
Messages received
Numbers of packets received from the EIA server. Available packet types include:
·     Add mappingAdd IP-SGT entry.
·     Delete mappingDelete IP-SGT entry.
·     Batch backup start—Start backing up IP-SGT entries in batch.
·     Batch backup end—End backing up IP-SGT entries in batch.
·     InvalidDiscover invalid entries.
Messages sent
Numbers of packets sent to the routing management module. Available packet types include:
·     Add mappingAdd IP-SGT entries.
·     Delete mappingDelete IP-SGT entries.
·     Update mappingUpdate IP-SGT entries.
·     Add critical—Add IP-SGT critical user entries.
·     Delete critical—Delete IP-SGT critical user entries.
·     Update critical—Update IP-SGT critical user entries.
·     Add On-demand networkAdd on-demand mapping subnets.
·     Delete on-demand networkDelete on-demand mapping subnets.
·     Batch backup startStart backing up IP-SGT entries in batch.
·     Batch backup mappingBack up IP-SGT entries in batch.
·     Batch backup critical—Back up IP-SGT critical user entries in batch.
·     Batch backup endFinish backing up IP-SGT entries in batch.
reset ipsgt statistics
ipsgt enable
Use ipsgt enable to enable IP-SGT mapping.
Use undo ipsgt enable to disable IP-SGT mapping.
ipsgt enable
undo ipsgt enable
IP-SGT mapping is disabled.
By default, only the authenticator can receive access policies deployed by the server and control user access based on the policies.
This feature enables a device to act as an executor to receive the IP address-microsegment ID mapping entries sent by the EIA server. During traffic packet forwarding, the executor identifies the source or destination IP address of the packet, obtains the microsegment ID, and then processes the packet based on the group policy specified by the microsegment ID. For more information about the microsegmentation and group policies, see Security Configuration Guide.
# Enable the IP-SGT mapping.
[Sysname] ipsgt enable
display ipsgt
ipsgt max-critical-map
Use ipsgt max-critical-map to specify the maximum number of fail-permit IP-SGT mapping entries that the device can store.
Use undo ipsgt max-critical-map to restore the default.
ipsgt max-critical-map max-number
The maximum number of fail-permit IP-SGT mapping entries that the device can store is not configured.
Predefined user views
max-number: Specifies the maximum number of fail-permit IP-SGT mapping entries that the device can store. The value range of the maximum number is 1 to 600000.
User guidelines
Application scenarios
With the authenticator separated from the executor and the authenticator unable to communicate with the EIA server, users can still access some of the resources if fail permit (such as critical microsegment) is enabled. However, since the EIA server cannot authorize microsegments, even if the IP-SGT subscription tunnel operates correctly between the executor and the EIA server, the EIA server does not deploy the fail-permit IP-SGT mapping entries to the executor.
When the fail-permit user traffic hits an on-demand address segment, because the executor does not have the fail-permit IP-SGT mapping entries, it cannot fast forward the traffic through hardware. The traffic must be sent to CPU for software forwarding. In this case, a large volume of the fail-permit traffic might cause high CPU usage.
Operation mechanism
Configure static settings (execute the member command in microsegment view) to add the user to the specified microsegment. After the configuration, IP-SGT module generates IP-SGT mapping entries for the user automatically and reports the entries to the route management module. The route management module will deploy a FIB forwarding table to the executor and the executor driver will store the corresponding IP-SGT mapping entries based on the table. In this case, the executor can fast forward the subsequent consistent flows and this can avoid a high CPU usage. For more information about the member command, see "Configuring microsegments."
Storing a large number of fail-permit entries on the executor might cause a high hardware resource usage and affect the correct operation of other services. In this case, you can use this feature to specify the maximum number of fail-permit entries on the device.
When fail permit is enabled for the authentication module and IP-SGT module at the same time:
·     If the authenticator is separated from the executor, IP-SGT fail permit take precedence.
·     If one device acts as the authenticator and the executor at the same time, critical microsegment of the authentication module takes precedence. When critical VLAN or critical VSI is enabled for the authentication module, IP-SGT fail permit takes precedence.
# Specify the maximum number of fail-permit IP-SGT mapping entries that can be stored as 4000.
[Sysname] ipsgt max-critical-map 4000
ipsgt on-demand
Use ipsgt on-demand to specify a subnet for on-demand IP-SGT mapping.
Use undo ipsgt on-demand to delete a subnet for on-demand IP-SGT mapping.
ipsgt on-demand { ip ipv4-address { mask-length | mask } | ipv6 ipv6-address prefix-length } [ vpn-instance vpn-instance-name ]
undo ipsgt on-demand [ ip [ ipv4-address { mask-length | mask } ] | ipv6 [ ipv6-address prefix-length ] ] [ vpn-instance vpn-instance-name ]
No subnet is specified for on-demand IP-SGT mapping.
ip [ ipv4-address { mask-length | mask }: Specifies an IPv4 subnet. The ipv4-address argument represents the IPv4 address, the mask-length argument represents the mask length in the range of 0 to 31, and the mask argument represents the mask in dotted decimal notation. The mask cannot be 255.255.255.255.
ip [ ipv6-address prefix-length ]: Specifies an IPv6 subnet. The ipv6-address argument represents the IPv6 address and the prefix-length argument represents the prefix length in the range of 0 to 127.
vpn-instance vpn-instance-name: Specifies the VPN instance by its name, a case-sensitive string in the range of 1 to 31 characters. If you do not specify this option, this command displays on-demand subnets in the public network.
By default, the device stores all the IP-SGT mapping entries deployed by the EIA server as hardware entries. This enables the device to fast obtain the microsegment ID and group policy for packet processing and improves the forwarding efficiency. However, if the device is on a link that has few packet exchanges, storing all mapping entries wastes hardware resources.
After enabling IP-SGT mapping, you can execute this command to specify subnets for on-demand IP-SGT mapping on the executor. The hardware stores the on-demand mapping entries only when the user IP address belongs to the specified subnets. In this way, the device can fast obtain the microsegment ID and group policy for packet processing and avoid resources waste.
If you do not specify any keyword or parameter for the undo command, the command deletes all on-demand IPv4 and IPv6 subnets.
# Specify subnet 20.20.20.1/24 for on-demand IP-SGT mapping.
[Sysname] ipsgt on-demand ip 20.20.20.1 24
ipsgt enable
Use reset ipsgt statistics to clear IP-SGT mapping packet statistics.
# Clear IP-SGT mapping packet statistics.
<Sysname> reset ipsgt statistics
snmp-agent trap enable ipsgt
Use snmp-agent trap enable ipsgt to enable SNMP notifications for IP-SGT mapping.
Use undo snmp-agent trap enable ipsgt to restore the default.
SNMP notifications are disabled for IP-SGT mapping.
Guidelines
To report critical IP-SGT events (such as connection or disconnection between the executor and the EIA server) to an NMS, enable SNMP notifications for IP-SGT mapping. For IP-SGT event notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for IP-SGT mapping.
[Sysname] snmp-agent trap enable ipsgt
