- 11-Network Management and Monitoring Configuration Guide
- 01-Sampler configuration
- 02-sFlow configuration
- 03-EPA configuration
- 04-NetAnalysis configuration
- 05-System maintenance and debugging configuration
- 06-NQA configuration
- 07-iNQA configuration
- 08-NTP configuration
- 09-PTP configuration
- 10-SNMP configuration
- 11-RMON configuration
- 12-NETCONF configuration
- 13-Ansible configuration
- 14-CWMP configuration
- 15-EAA configuration
- 16-Process monitoring and maintenance configuration
- 17-Mirroring configuration
- 18-Information center configuration
- 19-Packet capture configuration
- 20-VCF fabric configuration
- 21-Cloud connection configuration
- 22-SQA configuration
- 23-eMDI configuration
- 24-TCP connection trace configuration
- 25-NetStream configuration
| 04-NetAnalysis configuration | 240.50 KB |
Configuring NetAnalysis for RoCEv2 traffic
About NetAnalysis for RoCEv2 traffic
NetAnalysis for RoCEv2 traffic tasks at a glance
Setting the mode of RoCEv2 traffic analysis
Enabling RoCEv2 traffic statistics collection
Enabling RoCEv2 packet loss analysis globally
Enabling AI ECN for RoCEv2 traffic statistics collection
Setting the interval for reporting RoCEv2 traffic statistics to the NDA
Setting the sampling rate for RoCEv2 packets
Setting the aging timer for inactive RoCEv2 flows
Enabling the NetAnalysis statistics feature for RoCEv2 traffic within a VXLAN tunnel
Enabling the global packet loss analysis feature for RoCEv2 traffic within a VXLAN tunnel
Display and maintenance commands for NetAnalysis for RoCEv2 traffic
NetAnalysis for RoCEv2 traffic configuration examples
Example: Configuring NetAnalysis to analyze RoCEv2 traffic
Configuring NetAnalysis for UDP traffic
About NetAnalysis for UDP traffic
NetAnalysis for UDP traffic tasks at a glance
Enabling UDP traffic statistics collection
Specifying the number of blocks for segment analysis of UDP traffic
Setting the aging timer for inactive UDP flow
Display and maintenance commands for NetAnalysis for UDP traffic
NetAnalysis for UDP traffic configuration examples
Example: Configuring NetAnalysis to analyze UDP traffic
About NetAnalysis
NetAnalysis is a network traffic monitoring and analysis technology that performs in-depth analysis of service flows to obtain performance statistics about the service flows, such as packet loss rate and latency. NetAnalysis can send the analysis results to a NetAnalysis processor for analysis and display, which helps you monitor the network operation status and locate network faults.
NetAnalysis architecture
A typical NetAnalysis system consists of the following elements:
· NetAnalysis data exporter (NDE)—Uses an ACL to match the service flows to be analyzed and replicates them to a NetAnalysis processor.
· NetAnalysis processor (NAP)—Receives, processes, and analyzes service flows and outputs the results to a NetAnalysis data analyzer.
· NetAnalysis data analyzer (NDA)—Provides a Web interface for obtaining, displaying, and analyzing service flow data.
Typically, an NDE and an NAP are collocated on a device. As shown in Figure 1, when a service flow and its return traffic are forwarded along the same path, all devices on the path obtain bidirectional traffic of the service flow. You can configure NetAnalysis on these devices to analyze the flow to obtain performance statistics such as packet loss rate and latency.
NetAnalysis workflow
As shown in Figure 2, NetAnalysis works as follows:
1. The NDE uses ACLs to match the service flows monitored by NetAnalysis and replicates the service flows to the NAP.
2. The NAP creates a flow table for each received service flow to analyze it if the service flow meets CM connection setup requirements. The NAP drops a service flow if the service flow does not meet those requirements or the NAP is overloaded. For more information about CM connection setup, see "CM connection setup."
3. The NAP encapsulates the analysis results into packets destined for the NDA and sends the packets to the NDA for analysis and display.
Remote direct memory access (RDMA) is a direct memory access technology used in InfiniBand networks to resolve the delay of data processing on servers. RDMA transmits data directly through the network from one system to another system without involving either one's operating system. CPUs do not process the data in transmission, which increases the bandwidth and reduces latency and resource usage.
RDMA over converged Ethernet version 2 (RoCEv2) is an RDMA technology used on Ethernet networks. RoCEv2 is widely used to reduce the latency caused by CPU processing and improve application performance in TCP/IP transmission for high-performance computing, distributed storage, and AI. In these scenarios, multiple nodes might send packets simultaneously to the same node, and the burst of traffic will congest queues or even cause packet loss on the destination node. As a result, the network latency increases, and traffic throughput drops. To resolve the issues, configure NetAnalysis to monitor the status of RoCEv2 networks by analyzing RoCEv2 flow data such as packet loss, latency, throughput, and forwarding path.
RoCEv2 packet format
RoCEv2 is a network layer protocol that enables Layer 3 communication between broadcast domains. RoCEv2 encapsulates packets based on the UDP encapsulation. Figure 3 shows the format of an RoCEv2 packet.
An RoCEv2 packet contains the following fields:
· Ethernet header—Includes the source and destination MAC addresses.
· IP header—Includes the source and destination IP addresses.
· UDP header—Includes the source and destination port numbers. The destination port number is fixed at 4791.
· InfiniBand base transport header—Includes key fields monitored by NetAnalysis.
· IB payload.
· ICRC and FCS.
The InfiniBand base transport header contains the following fields:
· Opcode—RoCEv2 packet type indicating the operation mode. Available values for this field include the following:
¡ ConnectMsg—The packet is used for setting up an RoCEv2 connection. The connection is called a communication management (CM) connection. Devices in an RoCEv2 network transmit data packets through CM connections.
¡ Send—The packet is sent to the remote end without specifying where the receiver stores data.
¡ Write—The packet carries the address, key, and length of data to be written to the remote end.
¡ Read—The packet carries the address, key, and length of data to be read from the remote end. RoCEv2 packets of the Send, Write, and Read types are analyzed during throughput analysis.
¡ ACK—The packet is a response message returned by the receiver. Based on the ACK extended transport header unique to RoCEv2 ACK packets, an ACK packet can be one of the following types:
- Common ACK packet indicating that data is received successfully.
- NAK packet that indicates packet loss.
· Dest QP—Destination QP that identifies an RoCEv2 flow. This field is similar to the destination port number. It is a key value used by NetAnalysis to create an RoCEv2 flow table.
· PSN—Sequence number of the RoCEv2 packet. Packet loss is determined by checking whether the PSNs of packets are consecutive. If packet loss occurs, the receiver returns an NAK packet.
CM connection setup
RDMA sets up CM connections based on RoCE packets or TCP packets with custom fields. NetAnalysis can analyze the RoCE packets and TCP packets used for CM connection setup. The analysis process does not differ much between the packet types. The following information uses RoCE packet-based CM connection setup as an example.
Figure 4 shows the process of CM connection setup.
Figure 4 CM connection setup process
The CM connection setup procedure is as follows:
1. The client sends a Connect Request to the server to request RoCEv2 connection setup.
2. After receiving the Connect Request, the server replies with a Connect Reply. After receiving this packet, the client determines that an RoCEv2 connection has been set up with the server.
3. The client sends a ReadyToUse packet to the server. After receiving this packet, the server determines that the CM connection is set up successfully.
RoCEv2 flow analysis
After NetAnalysis is enabled to collect RoCEv2 traffic statistics on the device, the NDE issues rules for matching RoCEv2 packets based on the Opcode field. The NAP creates flow entries to form an RoCEv2 flow table based on the 4-tuple information in RoCEv2 connection setup packets. The 4-tuple information is the IP address of the client, IP address of the server, QP of the client, and QP of the server.
The NAP collects statistics about key fields in the flow table that is created based on the RoCEv2 data packets sent by the NDE, and analyzes the statistics to obtain characteristics of the RoCEv2 flow. You can view the statistics in the flow table on the device, and the statistics are exported to the NDA for display and analysis after the flow ages out.
RoCEv2 flow aging
The RoCEv2 flow aging mechanism allows the device to output flow statistics to the NDA. After NetAnalysis is enabled to analyze RoCEv2 traffic, the device saves flow statistics in the RoCEv2 cache. When an RoCEv2 flow ages out, the device exports the related flow statistics to the NDA and deletes the flow statistics from the RoCEv2 cache to save cache space.
Only inactive RoCEv2 flows age out. The device starts an inactive flow aging timer after receiving a packet for a flow. If the device has not received any packet for the flow when the timer expires, the flow ages out. To save cache space, the device will delete the sessions for inactive flows and notifies the NDA of the deletion events.
RoCEv2 flow filtering
NetAnalysis can use ACLs to filter the RoCEv2 flows that traverse the device. You can use this feature to collect statistics about the RoCEv2 flows of interest. For more information about ACLs, see ACL and QoS Configuration Guide.
To configure NetAnalysis to analyze RoCEv2 traffic, perform the following tasks:
1. Setting the mode of RoCEv2 traffic analysis
2. Enabling RoCEv2 traffic statistics collection
3. Enabling RoCEv2 packet loss analysis globally
4. (Optional.) Enabling AI ECN for RoCEv2 traffic statistics collection
5. (Optional.) Setting the interval for reporting RoCEv2 traffic statistics to the NDA
6. (Optional.) Setting the sampling rate for RoCEv2 packets
7. (Optional.) Setting the aging timer for inactive RoCEv2 flows
8. (Optional.) Enabling the NetAnalysis statistics feature for RoCEv2 traffic within a VXLAN tunnel
9. (Optional.) Enabling the global packet loss analysis feature for RoCEv2 traffic within a VXLAN tunnel
As shown in Figure 5, NetAnalysis can use either of the following modes for RoCEv2 traffic analysis when multiple paths exist between an RoCEv2 client and an RoCEv2 server:
· Bidirectional mode—NetAnalysis monitors bidirectional traffic sent between the server and the client. Based on the 4-tuple information in CM connection setup packets, NetAnalysis can collect RoCEv2 traffic statistics based on sessions and provide the session-specific RTT and lost packet count.
· Unidirectional mode—NetAnalysis monitors the traffic sent from the client to the server to obtain the 3-tuple information used for creating RoCEv2 flow entries. In this mode, NetAnalysis collects RoCEv2 traffic statistics based on flows and provides only packet throughput information.
As a best practice to ensure correct RoCEv2 traffic analysis, configure the mode of RoCEv2 traffic analysis as follows:
· Enable bidirectional mode on the devices attached to the server and the client (Device C and Device D).
· Enable unidirectional mode on the intermediate devices (Device A and Device B).
Figure 5 Mode of RoCEv2 traffic analysis
For NetAnalysis features to take effect, first set the mode of RoCEv2 traffic analysis.
When you change the mode of RoCEv2 traffic analysis, all NetAnalysis configuration and the RoCEv2 cache are cleared. Make sure you are fully aware of the impact of this operation when you perform it on a live network.
If you set the bidirectional mode, the ACL specified in the netanalysis rocev2 statistics command must match both client-to-server traffic and server-to-client traffic.
When you specify the session keyword in the netanalysis rocev2 mode command, the device analyzes RoCEv2 traffic based on session information (five-tuple and Opcode field) for NetAnalysis and packet loss, and sends the results to the NAP. In this case, you cannot configure NetAnalysis statistics or packet loss analysis separately on RoCEv2 traffic.
1. Enter system view.
2. Set the mode of RoCEv2 traffic analysis.
netanalysis rocev2 mode { bidir | single } [ session ]
By default, RoCEv2 traffic analysis is disabled, and the mode of RoCEv2 traffic analysis is not set.
Perform this task to enable NetAnalysis to analyze RoCEv2 traffic and send the analysis results to the NAP. You can use an ACL to match the RoCEv2 traffic of interest. The deny or permit action in the ACL does not take effect. NetAnalysis supports the following rules of advanced ACLs:
· Rule 1—Matches the UDP protocol and destination IPv4 address.
· Rule 2—Matches the UDP protocol and source IPv4 address.
· Rule 3—Matches the UDP protocol and source and destination IPv4 addresses.
To ensure correct collection and reporting of RoCEv2 traffic statistics, use the rules supported by NetAnalysis. For more information about ACLs, see ACL and QoS Configuration Guide.
2. Enable RoCEv2 traffic statistics collection.
netanalysis rocev2 statistic { global | acl name acl-name }
By default, RoCEv2 traffic statistics collection is disabled.
This task enables the device to perform RoCEv2 packet loss analysis for all received RoCEv2 packets.
For RoCEv2 packet loss analysis to take effect, first enable bidirectional mode for RoCEv2 traffic analysis.
2. Enable RoCEv2 packet loss analysis globally.
netanalysis rocev2 drop global
By default, RoCEv2 packet loss analysis is disabled globally.
AI ECN allows the device to collect RoCEv2 traffic statistics on a per-session basis on the outgoing interfaces for RoCEv2 traffic and send the RoCEv2 traffic statistics to the NDA. Based on the RoCEv2 traffic statistics, the NDA automatically adjusts the ECN threshold for lossless queues to ensure low latency and high throughput for lossless traffic. For more information about ECN, see QoS configuration in ACL and QoS Configuration Guide.
2. Enable AI ECN for RoCEv2 traffic statistics collection.
netanalysis rocev2 ai-ecn enable
By default, AI ECN is disabled for RoCEv2 traffic statistics collection.
Perform this task to adjust the interval at which the device reports RoCEv2 traffic statistics to the NDA.
2. Set the interval for reporting RoCEv2 traffic statistics to the NDA.
netanalysis rocev2 report-interval interval
By default, the device reports RoCEv2 traffic statistics to the NDA at an interval of 10 seconds.
A sampling rate allows the device to sample one packet from a number of RoCEv2 packets for analysis. For example, if you configure the sampling rate as 1000, the device samples 1 packet from 1000 RoCEv2 packets.
For the sampling rate to take effect, first set the mode of RoCEv2 traffic analysis.
2. Set the sampling rate for RoCEv2 packets.
netanalysis rocev2 sampling-rate rate
By default, no sampling rate is set for RoCEv2 packets.
When an inactive RoCEv2 flow ages out, the device outputs the related traffic statistics to the NDA, deletes these traffic statistics from the RoCEv2 cache, and deletes the related flow entries.
2. Set the aging timer for inactive RoCEv2 flows.
netanalysis rocev2 timeout inactive seconds
By default, the aging timer for inactive RoCEv2 flows is set to 30 seconds.
To understand and optimize network performance, and to enhance the transmission speed and reliability, you can configure the NetAnalysis statistics feature for RoCEv2 traffic within a VXLAN tunnel.
By using this feature, you can perform NetAnalysis statistical analysis on RoCEv2 traffic at the VXLAN tunnel edges and intermediate nodes. The device characterizes each traffic flow's data, including volume, bandwidth, and latency, and uploads the analysis results.
The specified RoCEv2 traffic is matched through ACL rules, but the designated deny or permit actions do not take effect. Currently, only the following advanced ACL rules are supported:
· rule1—Configures only the UDP protocol and destination IPv4 address.
· rule2—Configures only the UDP protocol and source IPv4 address.
· rule3—Configures only the UDP protocol, source IPv4 address, and destination IPv4 address.
Unsupported ACL rules do not take effect, preventing NAP from receiving the matched traffic flows. For more information about ACL rule configuration, see ACL and QoS Configuration Guide.
This feature only supports collecting statistics of VXLAN tunnel traffic within a data center network and does not support collecting statistics of VXLAN-DCI tunnel traffic between data centers.
Enabling the NetAnalysis statistics feature for RoCEv2 traffic on VXLAN tunnel intermediate nodes
2. Enable the NetAnalysis statistics feature for RoCEv2 traffic on VXLAN tunnel intermediate nodes.
netanalysis rocev2 vxlan statistics { acl name acl-name | global }
By default, the NetAnalysis statistics feature is disabled for RoCEv2 traffic on VXLAN tunnel intermediate nodes.
Enabling the NetAnalysis statistics feature for RoCEv2 traffic at the VXLAN tunnel edges
2. Enable the NetAnalysis statistics feature for RoCEv2 traffic at the VXLAN tunnel edges.
netanalysis rocev2 vxlan-ip statistics { acl name acl-name | global }
By default, the NetAnalysis statistics feature is disabled for RoCEv2 traffic at the VXLAN tunnel edges.
In a VXLAN network with RoCEv2, ensuring zero packet loss for network traffic is crucial. You can configure this feature to analyze packet loss for decapsulated RoCEv2 traffic at both intermediate and edge nodes within the VXLAN tunnel.
For this feature to take effect, you must first set the mode of RoCEv2 traffic analysis to bidirectional.
This feature only supports packet loss analysis on RoCEv2 traffic in VXLAN tunnels within a data center network and does not support packet loss analysis on RoCEv2 traffic in VXLAN-DCI tunnels between data centers.
Enabling the global packet loss analysis feature for RoCEv2 traffic on VXLAN tunnel intermediate nodes
2. Enable the global packet loss analysis feature for RoCEv2 traffic on VXLAN tunnel intermediate nodes.
netanalysis rocev2 vxlan drop global
By default, the global packet loss analysis feature is disabled for RoCEv2 traffic on VXLAN tunnel intermediate nodes.
Enabling the global packet loss analysis feature for RoCEv2 traffic at the VXLAN tunnel edges
2. Enable the global packet loss analysis feature for RoCEv2 traffic at the VXLAN tunnel edges.
netanalysis rocev2 vxlan-ip drop global
By default, the global packet loss analysis feature is disabled for RoCEv2 traffic at the VXLAN tunnel edges.
Task |
Command |
Display configuration and status of the RoCEv2 cache. |
display netanalysis rocev2 cache [ destination destination-ip | dstvxlan-id dstvxlan-id | source source-ip | srcvxlan-id srcxlan-id ]* |
Display RoCEv2 traffic statistics. |
display netanalysis rocev2 statistics |
Clear RoCEv2 traffic statistics. |
reset netanalysis rocev2 statistics |
As shown in Figure 6, configure NetAnalysis on the device to analyze the bidirectional RoCEv2 traffic sent between the server and the client and output the RoCEv2 traffic statistics to the NDA.
1. Assign an IP address to each interface, as shown in Figure 6. (Details not shown.)
2. Configure NetAnalysis to analyze RoCEv2 traffic:
# Enable bidirectional RoCEv2 traffic analysis.
[Device] netanalysis rocev2 mode bidir
# Enable global RoCEv2 traffic statistics collection.
[Device] netanalysis rocev2 statistics global
# Display configuration and status of the RoCEv2 cache after the device has been operating for a period of time.
[Device] display netanalysis rocev2 cache
S2D: source to destination D2S: destination to source
RTT: round trip time RPT: packet throughput in read mode
WPT: packet throughput in write mode SPT: packet throughput in send mode
I: input O: output L: local R: remote
NetAnalysis cache information:
Flow created at Service type
Src IP Src QP S2D RTT S2D RPT S2D SPT/WPT
S2D NAK Pkts S2D Interface(I) S2D Interface(O)
S2D Src VXLAN ID S2D Dst VXLAN ID
Dst IP Dst QP D2S RTT D2S RPT D2S SPT/WPT
D2S NAK Pkts D2S Interface(I) D2S Interface(O)
D2S Src VXLAN ID D2S Dst VXLAN ID
01/22/2019 09:08:15 RC
11.110.2.2 93309 50 11 11
2 Vlan-int100(L) Vlan-int200(L)
10 10
12.110.2.2 85353 50 11 11
8373 Vlan-int200(L) Vlan-int100(L)
10 10
# Display RoCEv2 traffic statistics.
[Device] display netanalysis rocev2 statistics
Last statistics resetting time: Never
Received packets: 1833088
Active Aged Created Reported
(Sessions) (Sessions) (Sessions) (Sessions)
RoCEv2
2 0 2 10
User Datagram Protocol (UDP) is a connectionless, datagram-oriented, simple transport layer protocol. Due to its low latency and high efficiency, UDP is widely used in applications that require high real-time performance, have relatively low data reliability requirements, or provides transmission reliability functions. Use NetAnalysis to perform intelligent traffic monitoring and analysis of UDP traffic, allowing analyzing path information of UDP traffic and monitoring the state of the UDP network.
UDP packet format
UDP is a transport layer protocol that transmits data by splitting it into datagrams and adding destination and source port numbers. UDP is encapsulated based on the IP protocol, and the packet format is shown in Figure 7.
The meanings of each field in a UDP packet are as follows:
· Ethernet Header: Carries the source MAC address and the destination MAC address.
· IP Header: The main fields in the IP header include the following:
¡ Protocol: Indicates the protocol used by the data in the IP packet.
¡ Identification: Used to identify and distinguish different IP datagrams on the same host. Every time the host sends a UDP packet, the value of the Identification field increases by 1.
¡ Source IP.
¡ Destination IP.
· UDP Header: Includes the following fields:
¡ Source Port.
¡ Destination Port.
¡ Length: Length of the UDP packet. The minimum value is 8 bytes. If the length value is 8, it indicates that the UDP packet only contains the UDP header with no UDP data.
¡ Checksum: Used to verify the correctness of UDP packets during transmission.
· UDP Data: Data in the UDP packet.
UDP flow analysis
By segmenting the sequence numbers of UDP packets, a UDP flow can be divided into multiple blocks. NetAnalysis statistics collection for UDP traffic analyzes UDP flows based on the block granularity.
With NetAnalysis enabled for UDP traffic, the NAP analyzes all UDP packets contained in the first UDP Block received. It forms a flow entry based on the quintuple key values (source port ID , source IP address, destination port ID, destination IP address, and UDP protocol) to create a UDP flow table.
After establishing a UDP flow table based on the first UDP Block, the NAP compiles statistics on some key fields in the flow table using subsequent UDP Blocks sent by NDE. Based on the statistical result, the NAP obtains information about the UDP flow. You can view the statistics in the flow table on the device. The statistical result will be sent to NDA for further display and analysis after the flow ages out.
UDP flow aging
UDP flow aging is a method by which the device outputs flow statistical information to NDA. When NetAnalysis is enabled for UDP traffic, the device first stores the flow statistics in the NetAnalysis buffer. When the flow information stored on the device ages, the device sends the flow statistics to the NDA and clears the corresponding information in the buffer.
When the device continuously receives a UDP flow, the NetAnalysis statistics collection function for UDP traffic periodically outputs flow analysis results to NDA based on the Block granularity. If the inactive time of a UDP flow (time collapsed since the last packet was received) exceeds the set inactive aging time, the device considers the flow to be inactive (the flow has stopped). Then, the device sends the current flow table to NDA and deletes it from the buffer to release space for incoming flows. This process is called the aging of inactive flows.
UDP flow filtering
NetAnalysis statistics collection for UDP traffic can be used in conjunction with ACL. It can match UDP traffic according to ACL rules, so that NetAnalysis for UDP traffic analyzes only the packets matching the ACL. Use this method for NetAnalysis to analyze only specific traffic, better meeting diverse user statistical requirements. For more information about ACL, see ACL and QoS Configuration Guide.
To configure NetAnalysis to analyze UDP traffic, perform the following tasks:
1. Enabling UDP traffic statistics collection
2. (Optional.) Specifying the number of blocks for segment analysis of UDP traffic
3. (Optional.) Setting the aging timer for inactive UDP flow
Perform this task to enable NetAnalysis to analyze UDP traffic and send the analysis results to the NAP. You can use an ACL to match the UDP traffic of interest. The deny or permit action in the ACL does not take effect. NetAnalysis supports the following rules of advanced ACLs:
· Rule 4—Matches the UDP protocol, source and destination IPv4 addresses, and UDP destination ports.
NetAnalysis statistics collection does not support RoCEv2 packets with a destination UDP port number of 4791.
Procedures
2. Enable UDP traffic statistics collection.
netanalysis udp statistics [ vxlan { single-tagged | untagged } ] acl name acl-name inbound
By default, UDP traffic statistics collection is disabled.
If you specify the single-tagged keyword, only Layer 2 VXLAN packets can be counted, and you must specify the Ethernet access mode for the AC.
NetAnalysis for UDP traffic performs analysis on UDP flows based on the Block granularity. Each UDP flow contains multiple UDP packets. With each packet sent, the Identification field increases by 1. The field value determines the UDP packet sequence number. In a UDP flow, UDP packets have sequence numbers ranging from 0 to 65535. By segmenting the sequence numbers of UDP packets, a UDP flow can be divided into multiple blocks. The NAP creates a flow table for the received UDP block and analyzes all UDP packets contained in the block.
Procedures
2. Specify the number of blocks for segment analysis of UDP traffic.
netanalysis udp identification block block-number
By default, the number of blocks for segment analysis of UDP traffic is 256.
With NetAnalysis statistics collection for UDP traffic enabled, the device must also send the UDP flow table containing the statistical results to the specified NDA to complete further processing and visualization of the flow information. When an inactive UDP flow ages out, the device outputs the related traffic statistics to the NDA, deletes these traffic statistics from the UDP cache, and deletes the related flow entries.
Procedures
2. Set the aging timer for inactive UDP flow.
netanalysis udp timeout inactive seconds
By default, the aging timer for inactive UDP flow is 30 seconds.
Task |
Command |
Display configuration and status of the UDP cache. |
display netanalysis udp cache [ destination destination-ip | interface interface-type interface-number | source source-ip | vni vxlan-id ]* |
Display UDP traffic statistics. |
display netanalysis udp statistics |
Clear UDP traffic statistics. |
reset netanalysis udp statistics |
As shown in Figure 8, configure NetAnalysis on the device to analyze the bidirectional UDP traffic sent between the server and the client and output the UDP traffic statistics to the NDA.
Procedures
1. Assign an IP address to each interface, as shown in Figure 8. (Details not shown.)
2. Configure an ACL:
# Create an IPv4 advanced ACL numbered 3001 and named abc.
[Device] acl number 3001 name abc
# Create an ACL rule to allow UDP packets from 1.1.1.0/16 to 2.2.2.0/16 to pass.
[Device-acl-ipv4-adv-3001] rule permit udp source 1.1.1.0 0.0.255.255 destination 2.2.2.0 0.0.255.255
3. Configure NetAnalysis to analyze UDP traffic:
# Enable UDP traffic analysis on packets matching the specified ACL in the inbound direction.
[Device] netanalysis udp statistics acl name abc inbound
After the device has been running for a while, check the statistics of the UDP flow.
# Display configuration and status of the UDP cache after the device has been operating for a period of time.
<Device> display netanalysis udp cache source 1.1.1.2 destination 2.2.2.2
Flow created at Direction
Src IP Dst IP Src Port Dst Port
Interface VNI Block Id Block Timestamp
Receive Packets Receive Bytes
10/22/2023 09:08:15 inbound
1.1.1.2 2.2.2.2 1000 2000
Vlan-int100 N/A 10 100000000
5000 6000000
# Display UDP traffic statistics.
<Device> display netanalysis udp statistics
Received packets: 2833088
(Flows) (Flows) (Flows) (Flows)
UDP
4 0 2 20
