- 01-AAA configuration
- 02-802.1X configuration
- 04-Portal configuration
- 05-Port security configuration
- 06-Password control configuration
- 07-Keychain configuration
- 08-Public key management
- 09-PKI configuration
- 10-IPsec configuration
- 11-SSH configuration
- 12-SSL configuration
- 13-Object group configuration
- 14-Attack detection and prevention configuration
- 15-TCP attack prevention configuration
- 16-IP source guard configuration
- 17-ARP attack protection configuration
- 18-ND attack defense configuration
- 19-uRPF configuration
- 20-SAVI configuration
- 21-SAVA configuration
- 22-MFF configuration
- 23-FIPS configuration
- 24-MACsec configuration
- 25-Microsegmentation configuration
- 26-TC configuration
- 27-CloudSec configuration
- 28-IP-SGT mapping configuration
| 25-Microsegmentation configuration | 339.57 KB |
Components of microsegmentation
Restrictions and guidelines: Microsegmentation configuration
Microsegmentation tasks at a glance
Prerequisites for microsegmentation configuration
Configuring an aggregate microsegment
Configuring the microsegment extended community attribute
Configuring the network address match method for microsegments
Enabling SNMP notifications for microsegmentation
Display and maintenance commands for microsegmentation
Microsegmentation configuration examples
Example: Configuring microsegmentation
Example: Configuring microsegmentation in an EVPN network
About microsegmentation
The microsegmentation feature, also called group-based security segregation, controls traffic based on groups the traffic assigned to. For example, you can group servers in data centers based on specific criteria and apply traffic control policies to different groups.
Basic concepts
Microsegment
A microsegment groups endpoints (such as servers) based on specific criteria. Each microsegment has a globally unique ID.
Group-based policy
A group-based policy (GBP) is a microsegment-based traffic control policy can be implemented by using the following functions:
· PBR—A policy node corresponds to a GBP and controls communication between microsegments through the apply next-hop or apply output-interface null0 action. For more information about PBR, see Layer 3—IP Routing Configuration Guide.
· QoS policy—A class-behavior association corresponds to a GBP and controls communication between microsegments through the filter deny or filter permit action in the traffic behavior. For more information about QoS policy, see QoS configuration ACL and QoS Configuration Guide.
· Packet filtering—A packet filter corresponds to a GBP and controls communication between microsegments through the permit or deny rule in an ACL. For more information about packet filtering, see ACL configuration ACL and QoS Configuration Guide.
As shown in Figure 1, the microsegmentation feature contains the microsegment, ACL, and GBP settings. A GBP can be a QoS policy, a packet filter, or a PBR policy node.
This feature controls whether members in different microsegments can communicate. The GBP takes effect on the local end of a link. To control bidirectional traffic, configure this feature on both ends. Intermediate nodes do not require the configuration of this feature.
This feature can be used in IP, VXLAN, and EVPN networks. The configurations are slightly different in different networks.
· In an IP network, all settings must be configured on the Layer 3 gateway devices. In a VXLAN or EVPN network, all settings must be configured on the VTEPs.
· In an EVPN network, if the microsegment settings are automatically synchronized to the remote end through the BGP extended community attribute in the MAC/IP advertisement route, you do not need to configure microsegment settings on the remote end.
Figure 1 Microsegmentation configuration workflow
How microsegmentation works
The microsegmentation feature works in the same way in IP, VXLAN, and EVPN networks. As shown in Figure 2, this section takes unidirectional traffic in an IP network as an example to illustrate how this feature works. This example uses a QoS policy as the GBP.
1. After receiving a packet sent from Host A to Host D, Device A obtains its source IP address (192.168.1.2) and destination IP address (192.168.1.5).
2. Device A searches the FIB table for the source IP address according to the longest match rule and determines that Host A belongs to microsegment 1.
3. Device A searches the FIB table for the destination IP address according to the longest match rule and determines that Host B belongs to microsegment 2.
4. Device A matches microsegment 1 and microsegment 2 against ACLs and executes one of the following actions in the QoS policy on matching packets:
¡ Forwards matching packets if the action is filter permit.
¡ Drops matching packets if the action is filter deny.
Figure 2 Forwarding of Layer 3 packets in an IP network
The microsegmentation feature works in the same way for cross-device packet forwarding.
When you use this feature to control unidirectional inter-VPN traffic, follow these restrictions and guidelines:
· On the source PE device, if the route guiding traffic forwarding is a network route, you must add the destination address of the route to a microsegment as a member.
· On the destination PE device, if the route is a host route, you must add the destination address of the route to a microsegment as a member.
To configure microsegmentation, perform the following tasks:
2. (Optional.) Configuring an aggregate microsegment
Choose one option as needed:
¡ Configuring packet filtering
5. (Optional.) Configuring the microsegment extended community attribute
Perform this task in an EVPN network to avoid extended community attribute conflicts.
6. (Optional.) Configuring the network address match method for microsegments
7. (Optional.) Enabling SNMP notifications for microsegmentation
This feature can be used in IP, VXLAN, and EVPN networks. For information about configuring these features, see the relevant configuration guides.
Configuring a microsegment
To control bidirectional traffic, follow these rules:
· In an IP or VXLAN network, configure the same microsegment settings on the two ends.
· In an EVPN network, configure a microsegment only on the local end. When distributing a MAC/IP advertisement route, the device carries the microsegment ID in the BGP extended community attribute. If the members (IP addresses) are in the distributed route, the microsegment settings are automatically synchronized to the remote end. The synchronized microsegment settings directly take effect on the remote end and are not subject to the microsegment enable command. If you also configure a microsegment on the remote end,, the synchronized microsegment settings overwrite the configured ones in the case of any setting differences.
For more information about MAC/IP advertisement routes, see EVPN overview in EVPN Configuration Guide.
1. Enter system view.
2. Create a microsegment and enter microsegment view.
microsegment microsegment-id [ name microsegment-name ]
3. Add a member to the microsegment.
member ipv4 ipv4-address { mask | mask-length } [ vpn-instance vpn-instance-name ]
member ipv6 ipv6-address prefix-length [ vpn-instance vpn-instance-name ]
By default, a microsegment does not contain members.
4. (Optional.) Add users connected through the corresponding AC by mapping the microsegment interface to a VSI.
xconnect vsi
By default, a microsegment is not bound to any VSI.
The information about added users is not displayed in the display microsegment command output.
For more information about the xconnect vsi command, see VXLAN Command Reference.
5. Return to system view.
6. Enable microsegmentation.
microsegment enable
By default, microsegmentation is disabled.
An aggregate microsegment is a group of microsegments with contiguous IDs. The ID of the aggregate microsegment is the start microsegment ID. You can use a mask to specify the member microsegments for an aggregate microsegment.
As shown in Figure 3, microsegments 8 through 15 can communicate with one another. To prevent communication between microsegments 12 and 14 and between microsegments 13 and 14, you can use an aggregate microsegment instead of reconfiguring microsegment settings. In this example, you can combine microsegments 12 and 13 to create an aggregate microsegment with ID 12, and use a GBP to prevent communication between aggregate microsegment 12 and microsegment 14.
Figure 3 Microsegment aggregation
2. Create an aggregate microsegment and enter its view.
microsegment aggregation aggregation-id mask-length mask-length [ name aggregation-name ]
Configuring an ACL
To control bidirectional traffic, you must configure an ACL on both ends and configure an ACL rule with swapped source and destination microsegments on the two ends.
If you use a PBR policy node or a QoS policy as the GBP, the ACL rules must be permit rules. The apply action or QoS action is taken on matching packets.
If you use a packet filter as the GBP, the ACL rules can be permit or deny rules. Matching packets are permitted or denied.
2. Create an IPv4 or IPv6 advanced ACL and enter its view. Choose one option as needed:
¡ acl [ ipv6 ] number acl-number [ name acl-name ] [ match-order { auto | config } ]
¡ acl [ ipv6 ] { advanced | basic } { acl-number | name acl-name } [ match-order { auto | config } ]
3. Configure a rule.
For more information, see the rule command in ACL and QoS Command Reference.
In the rule command, the destination microsegment microsegment-id and source microsegment microsegment-id options must be specified, and other parameters can be configured as needed.
Configuring a GBP
Configuring PBR
You can control communication between microsegments by referencing an ACL and specifying a next hop (permitting traffic) or the output interface NULL0 (dropping traffic) in a PBR policy.
To control bidirectional traffic, you must configure PBR on both ends.
2. Create a node for a policy, and enter its view.
3. Set an ACL match criterion for the node.
By default, no ACL match criterion is set.
4. Configure an action for the node. Choose one option as needed:
¡ Set a next hop.
apply next-hop ip-address
¡ Set NULL0 as the output interface.
By default, no action is configured.
6. Enter interface view.
7. Specify the policy for interface PBR.
ip policy-based-route policy-name [ share-mode ]
By default, no interface policy is applied to an interface.
Configuring a QoS policy
You can use the traffic filtering action in a QoS policy to control communication between microsegments.
2. Define a traffic class.
a. Create a traffic class and enter traffic class view.
b. Configure a match criterion.
if-match acl [ ipv6 ] { acl-number | name acl-name }
By default, no match criterion is configured.
Only IPv4 and IPv6 advanced ACLs can be used to match packets.
c. Return to system view.
3. Define a traffic behavior.
a. Create a traffic behavior and enter traffic behavior view.
b. Configure a traffic filtering action.
filter { deny | permit }
By default, no traffic filtering action is configured.
4. Define a QoS policy.
a. Create a QoS policy and enter QoS policy view.
qos policy policy-name
b. Associate the traffic class with the traffic behavior in the QoS policy.
classifier classifier-name behavior behavior-name
By default, a traffic class is not associated with a traffic behavior.
5. Apply the QoS policy to an interface.
a. Enter interface view.
b. Apply the QoS policy to the inbound direction of the interface.
qos apply policy policy-name inbound [ share-mode ]
By default, no QoS policy is applied to an interface.
You can apply an ACL to the inbound direction of an interface to control communication between microsegments.
2. Enter interface view.
3. Apply an ACL to the inbound direction of the interface.
packet-filter [ ipv6 ] { acl-number | name acl-name } inbound [ share-mode ]
By default, no ACL is applied to an interface.
A MAC/IP advertisement route carries microsegment IDs in a BGP extended community attribute and advertises microsegment settings to a peer through the extended community attribute. For more information about MAC/IP advertisement routes, see EVPN overview in EVPN Configuration Guide.
To avoid attribute conflicts, you can perform this task to modify the microsegment extended community attribute value.
2. Enter BGP instance view.
3. Set the microsegment extended community attribute value.
extcommunity-type microsegment-id microsegment-type-value
The default setting is 83ff (hexadecimal).
4. (Optional.) Display the microsegment extended community attribute value in BGP EVPN routes and the microsegment ID.
display bgp l2vpn evpn
For more information about this command, see EVPN commands in EVPN Command Reference.
5. (Optional.) Display the microsegment IDs carried in routes.
display ip routing-table
For more information about this command, see IP basics commands in Layer 3—IP Routing Command Reference.
The device determines the segment membership of packets by matching the source and destination IP addresses of packets. The following match methods are available:
· Exact match—The mask lengths of the source and destination IP addresses must be equal to those of members in microsegments. For example, a packet sourced from 10.10.10.1/24 matches member 10.10.10.0/24 instead of 10.10.10.0/23.
· Longest match—The mask lengths of the source and destination IP addresses can be greater than or equal to those of members in microsegments. For example, a packet sourced from 10.10.10.1/24 matches member 10.10.10.0/16.
The device uses different match methods for different member types of microsegments:
· Host addresses (IPv4 addresses with a 32-bit mask and IPv6 addresses with a 128-bit prefix) use the longest match method, which cannot be modified.
· The default route (0.0.0.0/0 or 0::0/0) uses the exact match method, which cannot be modified.
· Network addresses (IPv4 addresses with a 1-bit to 31-bit mask and IPv6 addresses with a 1-bit to 127-bit prefix) use the exact match method by default. If you execute the microsegment subnet-match longest command, the longest match method is used. If you execute the microsegment subnet-match disable command, no microsegment member can be matched.
The longest match method helps you simplify configuration when you need to add a large number of network addresses to a microsegment. For example, to match network addresses 10.10.10.0/24, 10.10.20.0/24, and 10.10.30.0/24 to microsegment 1, you need to execute only the member ipv4 10.10.10.0/16 command if you use longest match.
2. Configure the network address match method for microsegments.
microsegment subnet-match { disable | longest }
By default, exact match is used for network addresses.
To report critical microsegmentation events to an SNMP NMS, enable SNMP notifications for microsegmentation.
For microsegmentation SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about configuring SNMP, see Network Management and Monitoring Configuration Guide.
2. Enable SNMP notifications for microsegmentation.
snmp-agent trap enable microsegment
By default, SNMP notifications are enabled for microsegmentation.
Task |
Command |
Display aggregate microsegment configuration. |
display microsegment aggregation [ aggregation-id | name aggregation-name ] |
Display microsegment configuration. |
display microsegment [ microsegment-id | name microsegment-name ] |
As shown in Figure 4, configure microsegmentation to meet the following requirements:
· Host A, Host B, and the general server can access the file server.
· Host A and the general server cannot access each other. Host B and the general server cannot access each other.
Table 1 Interface label and interface name mappings
Interface label |
Interface name |
Interface2 |
HundredGigE1/1/2 |
Interface3 |
HundredGigE1/1/3 |
Analysis
1. Add Host A and Host B to microsegment 1.
2. Add the general server to microsegment 2, and add the file server to microsegment 3.
3. Configure a QoS policy to allow microsegment 1 and microsegment 3 to communicate, allow microsegment 2 and microsegment 3 to communicate, and prevent microsegment 1 and microsegment 2 from communicating.
Make sure the mask length of the packet's source and destination addresses matches the address mask length of the microsegment members during configuration. Otherwise, the microsegment members specified in the ACL rules may fail to match the packets.
· If the mask length of the packet's source and destination addresses is greater than that of the microsegment member addresses, you must configure the subnet address matching method for microsegment as longest match. Otherwise, the microsegment members specified in the ACL rules will not match the packets.
· If the mask length of the packet's source and destination addresses is less than that of the microsegment member addresses, the microsegment members specified in the ACL rules will not match the packets.
Configuring Device A
1. Configure interfaces and network connectivity.
# Create VLANs and specify the IP addresses for the VLAN interfaces.
[Sysname] sysname DeviceA
[DeviceA] vlan 10
[DeviceA-vlan10] port hundredgige 1/1/2
[DeviceA-vlan10] quit
[DeviceA-Vlan-interface10] ip address 192.168.1.254 24
[DeviceA-Vlan-interface10] undo shutdown
[DeviceA] interface hundredgige 1/1/2
[DeviceA-HundredGigE1/1/2] undo shutdown
[DeviceA-HundredGigE1/1/2] quit
[DeviceA] vlan 20
[DeviceA-vlan20] port hundredgige 1/1/3
[DeviceA-vlan20] quit
[DeviceA] interface vlan-interface 20
[DeviceA-Vlan-interface20] ip address 192.168.2.254 24
[DeviceA-Vlan-interface20] undo shutdown
[DeviceA-Vlan-interface20] quit
[DeviceA] interface hundredgige 1/1/3
[DeviceA-HundredGigE1/1/3] undo shutdown
[DeviceA-HundredGigE1/1/3] quit
[DeviceA] vlan 12
[DeviceA-vlan12] quit
[DeviceA] interface vlan-interface 12
[DeviceA-Vlan-interface12] ip address 12.0.0.2 30
[DeviceA-Vlan-interface12] undo shutdown
[DeviceA-Vlan-interface12] quit
[DeviceA] interface hundredgige 1/1/1
[DeviceA-HundredGigE1/1/1] undo shutdown
[DeviceA-HundredGigE1/1/1] port link-type trunk
[DeviceA-HundredGigE1/1/1] port trunk permit vlan 12
[DeviceA-HundredGigE1/1/1] quit
# Configure IS-IS to enable route connectivity in the network.
[DeviceA] isis 1
[DeviceA-isis-1] cost-style wide
[DeviceA-isis-1] network-entity 00.0000.0000.0001.00
[DeviceA-isis-1] is-level level-2
[DeviceA-isis-1] address-family ipv4 unicast
[DeviceA-isis-1-ipv4] quit
[DeviceA-isis-1] quit
[DeviceA-Vlan-interface20] isis enable 1
[DeviceA-Vlan-interface30] isis enable 1
[DeviceA-Vlan-interface30] quit
[DeviceA-Vlan-interface12] isis enable 1
2. Configure microsegments:
# Create microsegment 1, and add the IP addresses of Host A and Host B as its members.
[DeviceA] microsegment 1 name EPG1
[DeviceA-microsegment-1] member ipv4 192.168.1.1 24
[DeviceA-microsegment-1] member ipv4 192.168.2.1 24
[DeviceA-microsegment-1] quit
# Create microsegment 2, and add the IP address of the general server as its member.
[DeviceA] microsegment 2 name EPG2
[DeviceA-microsegment-2] member ipv4 192.168.3.1 24
[DeviceA-microsegment-2] quit
# Create microsegment 3, and add the IP address of the file server as its member.
[DeviceA] microsegment 3 name EPG3
[DeviceA-microsegment-3] member ipv4 192.168.4.1 24
[DeviceA-microsegment-3] quit
# Enable microsegmentation.
[DeviceA] microsegment enable
3. Configure ACLs:
# Create an IPv4 advanced ACL named EPG1-EPG3, configure a rule to match the IP packets from microsegment 1 to microsegment 3.
[DeviceA] acl advanced name EPG1-EPG3
[DeviceA-acl-ipv4-adv-EPG1-EPG3] rule 0 permit ip source microsegment 1 destination microsegment 3
[Device-acl-ipv4-adv-EPG1-EPG3] quit
# Create an IPv4 advanced ACL named EPG1-EPG2, configure a rule to match the IP packets from microsegment 1 to microsegment 2.
[DeviceA] acl advanced name EPG1-EPG2
[DeviceA-acl-ipv4-adv-EPG1-EPG2] rule 0 permit ip source microsegment 1 destination microsegment 2
[DeviceA-acl-ipv4-adv-EPG1-EPG2] quit
4. Configuring a QoS policy:
# Create a traffic class named CLASSIFIER-GBP13, and use ACL EPG1-EPG3 as the match criterion.
[DeviceA] traffic classifier CLASSIFIER-GBP13
[DeviceA-classifier-CLASSIFIER-GBP13] if-match acl name EPG1-EPG3
[DeviceA-classifier-CLASSIFIER-GBP13] quit
# Create a traffic behavior named BEHAVIOR-GBP13, configure a permit action, and configure packet statiatics collection.
[DeviceA] traffic behavior BEHAVIOR-GBP13
[DeviceA-behavior-BEHAVIOR-GBP13] filter permit
[DeviceA-behavior-BEHAVIOR-GBP13] accounting packet
[DeviceA-behavior-BEHAVIOR-GBP13] quit
# Create a traffic class named CLASSIFIER-GBP12, and use ACL EPG1-EPG2 as the match criterion.
[DeviceA] traffic classifier CLASSIFIER-GBP12
[DeviceA-classifier-CLASSIFIER-GBP12] if-match acl name EPG1-EPG2
[DeviceA-classifier-CLASSIFIER-GBP12] quit
# Create a traffic behavior named BEHAVIOR-GBP12, configure a deny action, and configure packet statiatics collection.
[DeviceA] traffic behavior BEHAVIOR-GBP12
[DeviceA-behavior-BEHAVIOR-GBP12] filter deny
[DeviceA-behavior-BEHAVIOR-GBP12] accounting packet
[DeviceA-behavior-BEHAVIOR-GBP12] quit
# Create a QoS policy named GBP1, and associate the configured traffic classes and traffic behaviors in the QoS policy.
[DeviceA] qos policy GBP1
[DeviceA-qospolicy-GBP1] classifier CLASSIFIER-GBP13 behavior BEHAVIOR-GBP13
[DeviceA-qospolicy-GBP1] classifier CLASSIFIER-GBP12 behavior BEHAVIOR-GBP12
[DeviceA-qospolicy-GBP1] quit
# Apply QoS policy GBP1 to the inbound direction of HundredGigE 1/1/2.
[DeviceA-HundredGigE1/1/2] qos apply policy GBP1 inbound
# Apply QoS policy GBP1 to the inbound direction of HundredGigE 1/1/3.
[DeviceA-HundredGigE1/1/3] qos apply policy GBP1 inbound
Configuring Device B
[Sysname] sysname DeviceB
[DeviceB] vlan 12
[DeviceB-vlan12] quit
[DeviceB] interface vlan-interface 12
[DeviceB-Vlan-interface12] ip address 12.0.0.1 30
[DeviceB-Vlan-interface12] undo shutdown
[DeviceB-Vlan-interface12] quit
[DeviceB] interface hundredgige 1/1/1
[DeviceB-HundredGigE1/1/1] undo shutdown
[DeviceB-HundredGigE1/1/1] port link-type trunk
[DeviceB-HundredGigE1/1/1] port trunk permit vlan 12
[DeviceB-HundredGigE1/1/1] quit
[DeviceB] vlan 23
[DeviceB-vlan23] quit
[DeviceB] interface vlan-interface 23
[DeviceB-Vlan-interface23] ip address 23.0.0.2 30
[DeviceB-Vlan-interface23] undo shutdown
[DeviceB-Vlan-interface23] quit
[DeviceB] interface hundredgige 1/1/2
[DeviceB-HundredGigE1/1/2] undo shutdown
[DeviceB-HundredGigE1/1/2] port link-type trunk
[DeviceB-HundredGigE1/1/2] port trunk permit vlan 23
[DeviceB-HundredGigE1/1/2] quit
[DeviceB] isis 1
[DeviceB-isis-1] cost-style wide
[DeviceB-isis-1] network-entity 00.0000.0000.0002.00
[DeviceB-isis-1] is-level level-2
[DeviceB-isis-1] address-family ipv4 unicast
[DeviceB-isis-1-ipv4] quit
[DeviceB-isis-1] quit
[DeviceB-Vlan-interface12] isis enable 1
[DeviceB-Vlan-interface23] isis enable 1
Configuring Device C
[Sysname] sysname DeviceC
[DeviceC] vlan 30
[DeviceC-vlan30] port hundredgige 1/1/2
[DeviceC-vlan30] quit
[DeviceC] interface vlan-interface 30
[DeviceC-Vlan-interface30] ip address 192.168.3.254 24
[DeviceC-Vlan-interface30] undo shutdown
[DeviceC-Vlan-interface30] quit
[DeviceC] interface hundredgige 1/1/2
[DeviceC-HundredGigE1/1/2] undo shutdown
[DeviceC-HundredGigE1/1/2] quit
[DeviceC] vlan 40
[DeviceC-vlan40] port hundredgige 1/1/3
[DeviceC-vlan40] quit
[DeviceC] interface vlan-interface 40
[DeviceC-Vlan-interface40] ip address 192.168.2.254 24
[DeviceC-Vlan-interface40] undo shutdown
[DeviceC-Vlan-interface40] quit
[DeviceC] interface hundredgige 1/1/3
[DeviceC-HundredGigE1/1/3] undo shutdown
[DeviceC-HundredGigE1/1/3] quit
[DeviceC] vlan 23
[DeviceC-vlan23] quit
[DeviceC] interface vlan-interface 23
[DeviceC-Vlan-interface23] ip address 23.0.0.1 30
[DeviceC-Vlan-interface23] undo shutdown
[DeviceC-Vlan-interface23] quit
[DeviceC] interface hundredgige 1/1/1
[DeviceC-HundredGigE1/1/1] undo shutdown
[DeviceC-HundredGigE1/1/1] port link-type trunk
[DeviceC-HundredGigE1/1/1] port trunk permit vlan 23
[DeviceC-HundredGigE1/1/1] quit
[DeviceC] isis 1
[DeviceC-isis-1] cost-style wide
[DeviceC-isis-1] network-entity 00.0000.0000.0003.00
[DeviceC-isis-1] is-level level-2
[DeviceC-isis-1] address-family ipv4 unicast
[DeviceC-isis-1-ipv4] quit
[DeviceC-isis-1] quit
[DeviceC-Vlan-interface30] isis enable 1
[DeviceC-Vlan-interface40] isis enable 1
[DeviceC-Vlan-interface23] isis enable 1
<DeviceC> system-view
[DeviceC] microsegment 1 name EPG1
[DeviceC-microsegment-1] member ipv4 192.168.1.1 24
[DeviceC-microsegment-1] member ipv4 192.168.2.1 24
[DeviceC-microsegment-1] quit
[DeviceC] microsegment 2 name EPG2
[DeviceC-microsegment-2] member ipv4 192.168.3.1 24
[DeviceC-microsegment-2] quit
[DeviceC] microsegment 3 name EPG3
[DeviceC-microsegment-3] member ipv4 192.168.4.1 24
[DeviceC-microsegment-3] quit
[DeviceC] microsegment enable
3. Configure ACLs:
# Create an IPv4 advanced ACL named EPG3-EPG1, configure a rule to match the IP packets from microsegment 3 to microsegment 1.
[DeviceC] acl advanced name EPG3-EPG1
[DeviceC-acl-ipv4-adv-EPG3-EPG1] rule 0 permit ip source microsegment 3 destination microsegment 1
[DeviceC-acl-ipv4-adv-EPG3-EPG1] quit
# Create an IPv4 advanced ACL named EPG2-EPG1, configure a rule to match the IP packets from microsegment 2 to microsegment 1.
[DeviceC] acl advanced name EPG2-EPG1
[DeviceC-acl-ipv4-adv-EPG2-EPG1] rule 0 permit ip source microsegment 2 destination microsegment 1
[DeviceC-acl-ipv4-adv-EPG2-EPG1] quit
# Create an IPv4 advanced ACL named EPG2-EPG3, configure a rule to match the IP packets from microsegment 2 to microsegment 3.
[DeviceC] acl advanced name EPG2-EPG3
[DeviceC-acl-ipv4-adv-EPG2-EPG3] rule 0 permit ip source microsegment 2 destination microsegment 3
[DeviceC-acl-ipv4-adv-EPG2-EPG3] quit
# Create an IPv4 advanced ACL named EPG3-EPG2, configure a rule to match the IP packets from microsegment 3 to microsegment 2.
[DeviceC] acl advanced name EPG3-EPG2
[DeviceC-acl-ipv4-adv-EPG3-EPG2] rule 0 permit ip source microsegment 3 destination microsegment 2
[DeviceC-acl-ipv4-adv-EPG3-EPG2] quit
# Create a traffic class named CLASSIFIER-GBP23, and use ACL EPG2-EPG3 as the match criterion.
[DeviceC] traffic classifier CLASSIFIER-GBP23
[DeviceC-classifier-CLASSIFIER-GBP23] if-match acl name EPG2-EPG3
[DeviceC-classifier-CLASSIFIER-GBP23] quit
# Create a traffic behavior named BEHAVIOR-GBP23, configure a permit action, and configure packet statistics collection.
[DeviceC] traffic behavior BEHAVIOR-GBP23
[DeviceC-behavior-BEHAVIOR-GBP23] filter permit
[DeviceC-behavior-BEHAVIOR-GBP23] accounting packet
[DeviceC-behavior-BEHAVIOR-GBP23] quit
# Create a traffic class named CLASSIFIER-GBP21, and use ACL EPG2-EPG1 as the match criterion.
[DeviceC] traffic classifier CLASSIFIER-GBP21
[DeviceC-classifier-CLASSIFIER-GBP21] if-match acl name EPG2-EPG1
[DeviceC-classifier-CLASSIFIER-GBP21] quit
# Create a traffic behavior named BEHAVIOR-GBP21, configure a deny action, and configure packet statistics collection.
[DeviceC] traffic behavior BEHAVIOR-GBP21
[DeviceC-behavior-BEHAVIOR-GBP21] filter deny
[DeviceC-behavior-BEHAVIOR-GBP21] accounting packet
[DeviceC-behavior-BEHAVIOR-GBP21] quit
# Create a QoS policy named GBP2, and associate the configured traffic classes and traffic behaviors in the QoS policy.
[DeviceC] qos policy GBP2
[DeviceC-qospolicy-GBP2] classifier CLASSIFIER-GBP23 behavior BEHAVIOR-GBP23
[DeviceC-qospolicy-GBP2] classifier CLASSIFIER-GBP21 behavior BEHAVIOR-GBP21
[DeviceC-qospolicy-GBP2] quit
# Create a traffic class named CLASSIFIER-GBP31, and use ACL EPG3-EPG1 as the match criterion.
[DeviceC] traffic classifier CLASSIFIER-GBP31
[DeviceC-classifier-CLASSIFIER-GBP31] if-match acl name EPG3-EPG1
[DeviceC-classifier-CLASSIFIER-GBP31] quit
# Create a traffic behavior named BEHAVIOR-GBP31, configure a permit action, and configure packet statistics collection.
[DeviceC] traffic behavior BEHAVIOR-GBP31
[DeviceC-behavior-BEHAVIOR-GBP31] filter permit
[DeviceC-behavior-BEHAVIOR-GBP31] accounting packet
[DeviceC-behavior-BEHAVIOR-GBP31] quit
# Create a traffic class named CLASSIFIER-GBP32, and use ACL EPG3-EPG2 as the match criterion.
[DeviceC] traffic classifier CLASSIFIER-GBP32
[DeviceC-classifier-CLASSIFIER-GBP32] if-match acl name EPG3-EPG2
[DeviceC-classifier-CLASSIFIER-GBP32] quit
# Create a traffic behavior named BEHAVIOR-GBP32, configure a permit action, and configure packet statistics collection.
[DeviceC] traffic behavior BEHAVIOR-GBP32
[DeviceC-behavior-BEHAVIOR-GBP32] filter permit
[DeviceC-behavior-BEHAVIOR-GBP32] accounting packet
[DeviceC-behavior-BEHAVIOR-GBP32] quit
# Create a QoS policy named GBP3, and associate the configured traffic classes and traffic behaviors in the QoS policy.
[DeviceC] qos policy GBP3
[DeviceC-qospolicy-GBP3] classifier CLASSIFIER-GBP31 behavior BEHAVIOR-GBP31
[DeviceC-qospolicy-GBP3] classifier CLASSIFIER-GBP32 behavior BEHAVIOR-GBP32
[DeviceC-qospolicy-GBP3] quit
# Apply QoS policy GBP2 to the inbound direction of HundredGigE 1/1/2.
[DeviceC-HundredGigE1/1/2] qos apply policy GBP2 inbound
# Apply QoS policy GBP3 to the inbound direction of HundredGigE 1/1/3.
[DeviceC-HundredGigE1/1/3] qos apply policy GBP3 inbound
# Verify that Host A and Host B cannot successfully ping the general server.
C:\> ping 192.168.3.1
Pinging 192.168.3.1 with 32 bytes of data:
Request timed out
Request timed out
Request timed out
Request timed out
Ping statistics for 192.168.3.1:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
The output shows that Host A and Host B cannot successfully ping the general server.
# Verify that Host A and Host B can successfully ping the file server.
C:\> ping 192.168.4.1
Pinging 192.168.40.100 with 32 bytes of data:
Reply from 192.168.10.100: bytes=32 time=1ms TTL=255
Reply from 192.168.10.100: bytes=32 time<1ms TTL=255
Ping statistics for 192.168.10.100:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
The output shows that Host A and Host B can successfully ping the file server.
# Display the configuration of each microsegment on Device A.
[DeviceA] display microsegment 1
Microsegment ID : 1
Microsegment name : EPG1
IPv4 member:
192.168.1.1/32
192.168.2.1/32
[DeviceA] display microsegment 2
Microsegment ID : 2
Microsegment name : EPG2
IPv4 member:
192.168.3.1/32
[DeviceA] display microsegment 3
Microsegment ID : 3
Microsegment name : EPG3
IPv4 member:
192.168.4.1/32
# Display summary and state information about microsegments on Device A.
Microsegment status: Enabled
Total microsegments: 3
Microsegment list :
Microsegment ID Members Microsegment name
1 2 EPG1
2 1 EPG2
3 1 EPG3
[DeviceA] display qos policy interface
Interface: HundredGigE1/1/2
Direction: Inbound
Policy: GBP1
Classifier: CLASSIFIER-GBP13
Operator: AND
Rule(s) :
If-match acl name EPG1-EPG3
Behavior: BEHAVIOR-GBP13
Accounting enable:
5 (Packets)
0 (pps)
Filter enable: Permit
Classifier: CLASSIFIER-GBP12
Operator: AND
Rule(s) :
If-match acl name EPG1-EPG2
Behavior: BEHAVIOR-GBP12
Accounting enable:
5 (Packets)
0 (pps)
Filter enable: Deny
Interface: HundredGigE1/1/3
Direction: Inbound
Policy: GBP1
Operator: AND
Rule(s) :
Accounting enable:
5 (Packets)
0 (pps)
Operator: AND
Rule(s) :
Accounting enable:
5 (Packets)
0 (pps)
Filter enable: Deny
# Display the configuration of microsegments, and ACLs, and QoS policies on Device D. (Details not shown.)
Configuration files
· Device A
sysname DeviceA
isis 1
is-level level-2
cost-style wide
vlan 10
vlan 12
vlan 20
microsegment enable
member ipv4 192.168.1.0 255.255.255.0
member ipv4 192.168.2.0 255.255.255.0
member ipv4 192.168.3.0 255.255.255.0
member ipv4 192.168.4.0 255.255.255.0
traffic classifier CLASSIFIER-GBP12 operator and
traffic classifier CLASSIFIER-GBP13 operator and
accounting packet
filter deny
accounting packet
filter permit
qos policy GBP1
interface Vlan-interface10
ip address 192.168.1.254 255.255.255.0
isis enable 1
interface Vlan-interface12
ip address 12.0.0.2 255.255.255.252
isis enable 1
interface Vlan-interface20
ip address 192.168.2.254 255.255.255.0
isis enable 1
interface HundredGigE1/1/1
port trunk permit vlan 1 12
interface HundredGigE1/1/2
port access vlan 10
interface HundredGigE1/1/3
port access vlan 20
· Device B
sysname DeviceB
isis 1
is-level level-2
cost-style wide
vlan 12
vlan 23
ip address 12.0.0.1 255.255.255.252
isis enable 1
interface Vlan-interface23
ip address 23.0.0.2 255.255.255.252
isis enable 1
port trunk permit vlan 1 23
· Device C
sysname DeviceC
isis 1
is-level level-2
cost-style wide
vlan 23
vlan 30
vlan 40
microsegment enable
traffic classifier CLASSIFIER-GBP21 operator and
traffic classifier CLASSIFIER-GBP23 operator and
traffic classifier CLASSIFIER-GBP31 operator and
traffic classifier CLASSIFIER-GBP32 operator and
accounting packet
filter deny
accounting packet
filter permit
accounting packet
filter permit
accounting packet
filter permit
qos policy GBP2
qos policy GBP3
ip address 23.0.0.1 255.255.255.252
isis enable 1
interface Vlan-interface30
ip address 192.168.3.254 255.255.255.0
isis enable 1
interface Vlan-interface40
isis enable 1
port access vlan 30
port access vlan 40
As shown in Figure 5, configure microsegmentation to meet the following requirements:
· Host A and Host B can access the file server.
· Host A cannot access the general server. Host B can access the general server.
Table 2 Interface label and interface name mappings
Interface label |
Interface name |
Interface2 |
HundredGigE1/1/2 |
Interface3 |
HundredGigE1/1/3 |
Analysis
1. Add Host A to microsegment 1, Host B to microsegment 2, and the general server to microsegment 3.
2. Configure PBR to allow microsegment 1 and microsegment 2 to communicate, allow microsegment 2 and microsegment 3 to communicate, and prevent microsegment 1 and microsegment 3 from communicating.
3. Deploy Device A and Device C as distributed EVPN gateways. Add Host A and the general server to VXLAN 10, and Host B and the file server to VXLAN 20. Devices within the same VXLAN communicate at Layer 2, and devices in different VXLANs communicate at Layer 3 through the distributed EVPN gateways.
4. Configure microsegment 1 and microsegment 2 on Device A, and configure microsegment 3 to on Device C. Configure the system to synchronize member information of these microsegments to peer devices through BGP EVPN routes.
Make sure the mask length of the source and destination addresses in the configuration matches the address mask length of the microsegment members. Otherwise, the microsegment members specified in the ACL rules may fail to match the packets.
[DeviceA] vlan 10
[DeviceA] vlan 20
[DeviceA-hundredgige 1/1/3] undo shutdown
[DeviceA-hundredgige 1/1/3] quit
[DeviceA] vlan 12
[DeviceA] isis 1
# Enable L2VPN.
[DeviceA] l2vpn enable
# Disable remote-MAC address learning and disable remote ARP learning.
[DeviceA] vxlan tunnel mac-learning disable
[DeviceA] vxlan tunnel arp-learning disable
# Create an EVPN instance under VSI vpna, and configure the router to automatically generate an RD and a route target for the EVPN instance.
[DeviceA] vsi vpna
[DeviceA-vsi-vpna] evpn encapsulation vxlan
[DeviceA-vsi-vpna-evpn-vxlan] route-distinguisher auto
[DeviceA-vsi-vpna-evpn-vxlan] vpn-target auto
[DeviceA-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[DeviceA-vsi-vpna] vxlan 10
[DeviceA-vsi-vpna-vxlan-10] quit
[DeviceA-vsi-vpna] quit
# Create an EVPN instance under VSI vpnb, and configure the router to automatically generate an RD and a route target for the EVPN instance.
[DeviceA] vsi vpnb
[DeviceA-vsi-vpnb] evpn encapsulation vxlan
[DeviceA-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[DeviceA-vsi-vpnb-evpn-vxlan] vpn-target auto
[DeviceA-vsi-vpnb-evpn-vxlan] quit
# Create VXLAN 20.
[DeviceA-vsi-vpnb] vxlan 20
[DeviceA-vsi-vpnb-vxlan-20] quit
[DeviceA-vsi-vpnb] quit
# Create an EVPN instance under VSI vpnc, and configure the router to automatically generate an RD and a route target for the EVPN instance.
[DeviceA] vsi vpnc
[DeviceA-vsi-vpnc] evpn encapsulation vxlan
[DeviceA-vsi-vpnc-evpn-vxlan] route-distinguisher auto
[DeviceA-vsi-vpnc-evpn-vxlan] vpn-target auto
[DeviceA-vsi-vpnc-evpn-vxlan] quit
# Create VXLAN 30.
[DeviceA-vsi-vpnc] vxlan 30
[DeviceA-vsi-vpnc-vxlan-30] quit
[DeviceA-vsi-vpnc] quit
# Configure BGP to advertise BGP EVPN routes.
[DeviceA] bgp 100
[DeviceA-bgp-default] peer 3.3.3.3 as-number 100
[DeviceA-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[DeviceA-bgp-default] address-family l2vpn evpn
[DeviceA-bgp-default-evpn] peer 3.3.3.3 enable
[DeviceA-bgp-default-evpn] quit
[DeviceA-bgp-default] quit
# On HundredGigE 1/1/2, create Ethernet service instance 1000 to match VLAN 10.
[DeviceA-HundredGigE1/1/2] service-instance 1000
[DeviceA-HundredGigE1/1/2-srv1000] encapsulation s-vid 10
# Map Ethernet service instance 1000 to VSI vpna.
[DeviceA-HundredGigE1/1/2-srv1000] xconnect vsi vpna
[DeviceA-HundredGigE1/1/2-srv1000] quit
# On HundredGigE 1/1/3, create Ethernet service instance 2000 to match VLAN 20.
[DeviceA-HundredGigE1/1/3] service-instance 2000
[DeviceA-HundredGigE1/1/3-srv2000] encapsulation s-vid 20
# Map Ethernet service instance 2000 to VSI vpnb.
[DeviceA-HundredGigE1/1/3-srv2000] xconnect vsi vpnb
[DeviceA-HundredGigE1/1/3-srv2000] quit
# Configure RD and route target settings for VPN instance l3vpna.
[DeviceA] ip vpn-instance l3vpna
[DeviceA-vpn-instance-l3vpna] route-distinguisher 1:1
[DeviceA-vpn-instance-l3vpna] address-family ipv4
[DeviceA-vpn-ipv4-l3vpna] vpn-target 2:2
[DeviceA-vpn-ipv4-l3vpna] quit
[DeviceA-vpn-instance-l3vpna] address-family evpn
[DeviceA-vpn-evpn-l3vpna] vpn-target 1:1
[DeviceA-vpn-evpn-l3vpna] quit
[DeviceA-vpn-instance-l3vpna] quit
# Configure VSI-interface 1.
[DeviceA] interface vsi-interface 1
[DeviceA-Vsi-interface1] ip binding vpn-instance l3vpna
[DeviceA-Vsi-interface1] ip address 192.168.1.254 24
[DeviceA-Vsi-interface1] mac-address 1-1-1
[DeviceA-Vsi-interface1] distributed-gateway local
[DeviceA-Vsi-interface1] local-proxy-arp enable
[DeviceA-Vsi-interface1] quit
# Configure VSI-interface 2.
[DeviceA] interface vsi-interface 2
[DeviceA-Vsi-interface2] ip binding vpn-instance l3vpna
[DeviceA-Vsi-interface2] ip address 192.168.2.254 24
[DeviceA-Vsi-interface2] mac-address 2-2-2
[DeviceA-Vsi-interface2] distributed-gateway local
[DeviceA-Vsi-interface2] local-proxy-arp enable
[DeviceA-Vsi-interface2] quit
# Configure VSI-interface 3.
[DeviceA] interface vsi-interface 3
[DeviceA-Vsi-interface1] ip address 192.168.3.254 24
[DeviceA-Vsi-interface1] mac-address 3-3-3
# Configure VSI-interface 4, associate VSI-interface 4 with VPN instance l3vpna, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[DeviceA] interface vsi-interface 4
[DeviceA-Vsi-interface4] ip binding vpn-instance l3vpna
[DeviceA-Vsi-interface4] l3-vni 1000
[DeviceA-Vsi-interface4] quit
# Specify VSI-interface 1 as the gateway interface for VSI vpna.
[DeviceA] vsi vpna
[DeviceA-vsi-vpna] gateway vsi-interface 1
# Specify VSI-interface 2 as the gateway interface for VSI vpnb.
[DeviceA] vsi vpnb
[DeviceA-vsi-vpnb] gateway vsi-interface 2
# Specify VSI-interface 3 as the gateway interface for VSI vpnc.
[DeviceA] vsi vpnc
[DeviceA-vsi-vpnc] gateway vsi-interface 3
# Create microsegment 1, and add the IP addresses of Host A as its member.
[DeviceA-microsegment-1] member ipv4 192.168.1.1 24 vpn-instance l3vpna
# Create microsegment 2, and add the IP address of Host B as its member.
[DeviceA-microsegment-2] member ipv4 192.168.2.1 24 vpn-instance l3vpna
3. Configure ACLs:
[DeviceA] acl advanced name EPG2-EPG3
[DeviceA-acl-ipv4-adv-EPG2-EPG3] rule 0 permit ip source microsegment 2 destination microsegment 3
[DeviceA-acl-ipv4-adv-EPG2-EPG3] quit
# Create a traffic behavior named BEHAVIOR-GBP13, configure a deny action, and configure packet statiatics collection.
[DeviceA-behavior-BEHAVIOR-GBP13] filter deny
# Create a traffic behavior named BEHAVIOR-GBP12, configure a permit action, and configure packet statiatics collection.
[DeviceA-behavior-BEHAVIOR-GBP12] filter permit
[DeviceA] traffic classifier CLASSIFIER-GBP23
[DeviceA-classifier-CLASSIFIER-GBP23] if-match acl name EPG2-EPG3
[DeviceA-classifier-CLASSIFIER-GBP23] quit
# Create a traffic behavior named BEHAVIOR-GBP23, configure a permit action, and configure packet statiatics collection.
[DeviceA] traffic behavior BEHAVIOR-GBP23
[DeviceA-behavior-BEHAVIOR-GBP23] filter permit
[DeviceA-behavior-BEHAVIOR-GBP23] accounting packet
[DeviceA-behavior-BEHAVIOR-GBP23] quit
# Create a QoS policy named GBP1, associate traffic class CLASSIFIER-GBP13 and traffic behavior BEHAVIOR-GBP13, and associate traffic class CLASSIFIER-GBP12 and traffic behavior BEHAVIOR-GBP12 in the QoS policy.
# Create a QoS policy named GBP2, and associate traffic class CLASSIFIER-GBP23 and traffic behavior BEHAVIOR-GBP23 in the QoS policy.
[DeviceA] qos policy GBP2
[DeviceA-qospolicy-GBP2] classifier CLASSIFIER-GBP23 behavior BEHAVIOR-GBP23
[DeviceA-qospolicy-GBP2] quit
# Apply QoS policy GBP2 to the inbound direction of HundredGigE 1/1/3.
[DeviceA-HundredGigE1/1/3] qos apply policy GBP2 inbound
[DeviceB] vlan 12
[DeviceB] vlan 23
[DeviceB] isis 1
[DeviceB] interface LoopBack0
[DeviceB-LoopBack0] ip address 2.2.2.2 32
[DeviceB-LoopBack0] isis enable 1
[DeviceB-LoopBack0] quit
[DeviceC] vlan 30
[DeviceC] vlan 23
[DeviceC] isis 1
[DeviceC] interface LoopBack0
[DeviceC-LoopBack0] ip address 3.3.3.3 32
[DeviceC-LoopBack0] isis enable 1
[DeviceC-LoopBack0] quit
# Enable L2VPN.
[DeviceC] l2vpn enable
[DeviceC] vxlan tunnel mac-learning disable
[DeviceC] vxlan tunnel arp-learning disable
[DeviceC] vsi vpna
[DeviceC-vsi-vpna] evpn encapsulation vxlan
[DeviceC-vsi-vpna-evpn-vxlan] route-distinguisher auto
[DeviceC-vsi-vpna-evpn-vxlan] vpn-target auto
[DeviceC-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[DeviceC-vsi-vpna] vxlan 10
[DeviceC-vsi-vpna-vxlan-10] quit
[DeviceC-vsi-vpna] quit
[DeviceC] vsi vpnb
[DeviceC-vsi-vpnb] evpn encapsulation vxlan
[DeviceC-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[DeviceC-vsi-vpnb-evpn-vxlan] vpn-target auto
[DeviceC-vsi-vpnb-evpn-vxlan] quit
# Create VXLAN 20.
[DeviceC-vsi-vpnb] vxlan 20
[DeviceC-vsi-vpnb-vxlan-20] quit
[DeviceC-vsi-vpnb] quit
[DeviceC] vsi vpnc
[DeviceC-vsi-vpnc] evpn encapsulation vxlan
[DeviceC-vsi-vpnc-evpn-vxlan] route-distinguisher auto
[DeviceC-vsi-vpnc-evpn-vxlan] vpn-target auto
[DeviceC-vsi-vpnc-evpn-vxlan] quit
# Create VXLAN 30.
[DeviceC-vsi-vpnc] vxlan 30
[DeviceC-vsi-vpnc-vxlan-30] quit
[DeviceC-vsi-vpnc] quit
[DeviceC] bgp 100
[DeviceC-bgp-default] peer 1.1.1.1 as-number 100
[DeviceC-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[DeviceC-bgp-default] address-family l2vpn evpn
[DeviceC-bgp-default-evpn] peer 1.1.1.1 enable
[DeviceC-bgp-default-evpn] quit
[DeviceC-bgp-default] quit
# On HundredGigE 1/1/2, create Ethernet service instance 1000 to match VLAN 30.
[DeviceC-HundredGigE1/1/2] service-instance 1000
[DeviceC-HundredGigE1/1/2-srv1000] encapsulation s-vid 30
[DeviceC-HundredGigE1/1/2-srv1000] xconnect vsi vpna
[DeviceC-HundredGigE1/1/2-srv1000] quit
[DeviceC] ip vpn-instance l3vpna
[DeviceC-vpn-instance-l3vpna] route-distinguisher 1:1
[DeviceC-vpn-instance-l3vpna] address-family ipv4
[DeviceC-vpn-ipv4-l3vpna] vpn-target 2:2
[DeviceC-vpn-ipv4-l3vpna] quit
[DeviceC-vpn-instance-l3vpna] address-family evpn
[DeviceC-vpn-evpn-l3vpna] vpn-target 1:1
[DeviceC-vpn-evpn-l3vpna] quit
[DeviceC-vpn-instance-l3vpna] quit
[DeviceC] interface vsi-interface 1
[DeviceC-Vsi-interface1] ip binding vpn-instance l3vpna
[DeviceC-Vsi-interface1] ip address 192.168.1.254 24
[DeviceC-Vsi-interface1] mac-address 1-1-1
[DeviceC-Vsi-interface1] distributed-gateway local
[DeviceC-Vsi-interface1] local-proxy-arp enable
[DeviceC-Vsi-interface1] quit
[DeviceC] interface vsi-interface 2
[DeviceC-Vsi-interface2] ip binding vpn-instance l3vpna
[DeviceC-Vsi-interface2] ip address 192.168.2.254 24
[DeviceC-Vsi-interface2] mac-address 2-2-2
[DeviceC-Vsi-interface2] distributed-gateway local
[DeviceC-Vsi-interface2] local-proxy-arp enable
[DeviceC-Vsi-interface2] quit
[DeviceC] interface vsi-interface 3
[DeviceC-Vsi-interface1] ip address 192.168.3.254 24
[DeviceC-Vsi-interface1] mac-address 3-3-3
[DeviceC] interface vsi-interface 4
[DeviceC-Vsi-interface4] ip binding vpn-instance l3vpna
[DeviceC-Vsi-interface4] l3-vni 1000
[DeviceC-Vsi-interface4] quit
[DeviceC] vsi vpna
[DeviceC-vsi-vpna] gateway vsi-interface 1
[DeviceC] vsi vpnb
[DeviceC-vsi-vpnb] gateway vsi-interface 2
[DeviceC] vsi vpnc
[DeviceC-vsi-vpnc] gateway vsi-interface 3
# Create microsegment 3, and add the IP addresses of the general server as its member.
[DeviceC-microsegment-3] member ipv4 192.168.3.1 24 vpn-instance l3vpna
# On Device C, execute the display bgp l2vpn evpn command to view detailed EVPN route information. Check the MAC/IP advertisement route for IP address 192.168.1.1, and verify that the extended community attribute Ext-Community carried by this route contains microsegment information, which indicates that EVPN route learning is normal.
[DeviceC] display bgp l2vpn evpn [2][0][48][6e7f-a8c5-0407][32][192.168.1.1]/136
BGP local router ID: 3.3.3.3
Local AS number: 100
Route distinguisher: 1:2(l3vpna)
Total number of routes: 1
Paths: 1 available, 1 best
BGP routing table information of [2][0][48][6e7f-a8c5-0407][32][192.168.1.1]/136:
Rely nexthop : 23.0.0.2
Original nexthop: 1.1.1.1
Route age : 00h02m32s
OutLabel : NULL
Ext-Community : <RT: 1:1>, <RT: 100:10>, <Encapsulation Type: VXLAN>, <Route
r's MAC: 6e7f-9995-0100>, <MicroSegment-id: Type 0x83ff, ID
1>
RxPathID : 0x0
TxPathID : 0x0
AS-path : (null)
Origin : igp
State : valid, internal, best, remoteredist
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : MAC/IP advertisement route
ESI : 0000.0000.0000.0000.0000
Ethernet tag ID : 0
MAC address : 6e7f-a8c5-0407
IP address : 192.168.1.1/32
MPLS label1 : 10
MPLS label2 : 1000
Tunnel policy : NULL
Rely tunnel IDs : N/A
# Verify that Host A cannot ping the general server but Host B can.
Request timed out
Request timed out
Request timed out
Request timed out
Microsegment ID : 1
IPv4 member:
192.168.1.1/24
Microsegment ID : 2
IPv4 member:
192.168.2.1/24
Microsegment ID : 3
IPv4 member:
192.168.2.1/24
# Display summary information about microsegments on Device A.
Microsegment list :
1 1 EPG1
2 1 EPG2
3 1 EPG3
# Display the QoS policy configuration and running status on HundredGigE1/1/2 of Device A.
[DeviceA] display qos policy interface HundredGigE1/1/2
Direction: Inbound
Policy: GBP1
Rule(s) :
Accounting enable:
5 (Packets)
0 (pps)
Filter enable: Deny
Rule(s) :
Accounting enable:
5 (Packets)
0 (pps)
Configuration files
· Device A
sysname DeviceA
address-family ipv4
vpn-target 2:2 import-extcommunity
vpn-target 2:2 export-extcommunity
address-family evpn
vpn-target 1:1 import-extcommunity
vpn-target 1:1 export-extcommunity
isis 1
is-level level-2
cost-style wide
vlan 10
vlan 12
vlan 20
microsegment enable
member ipv4 192.168.1.0 255.255.255.0 vpn-instance l3vpna
member ipv4 192.168.2.0 255.255.255.0 vpn-instance l3vpna
accounting packet
filter permit
accounting packet
filter deny
accounting packet
filter permit
qos policy GBP1
qos policy GBP2
l2vpn enable
vsi vpna
gateway Vsi-interface 1
vxlan 10
vpn-target auto export-extcommunity
vpn-target auto import-extcommunity
vsi vpnb
gateway Vsi-interface 2
vxlan 20
vsi vpnc
gateway Vsi-interface 3
vxlan 30
interface LoopBack0
ip address 1.1.1.1 255.255.255.255
isis enable 1
isis enable 1
port access vlan 10
xconnect vsi vpna
port access vlan 20
xconnect vsi vpnb
interface Vsi-interface1
mac-address 0001-0001-0001
interface Vsi-interface2
mac-address 0002-0002-0002
interface Vsi-interface3
mac-address 0003-0003-0003
interface Vsi-interface4
l3-vni 1000
bgp 100
router-id 1.1.1.1
peer 3.3.3.3 connect-interface LoopBack0
peer 3.3.3.3 enable
· Device B
sysname DeviceB
isis 1
is-level level-2
cost-style wide
vlan 12
vlan 23
interface LoopBack0
ip address 2.2.2.2 255.255.255.255
isis enable 1
isis enable 1
isis enable 1
· Device C
sysname DeviceC
route-distinguisher 1:2
address-family ipv4
address-family evpn
isis 1
is-level level-2
cost-style wide
vlan 23
vlan 30
vlan 40
microsegment enable
member ipv4 192.168.3.0 255.255.255.0 vpn-instance l3vpna
l2vpn enable
vsi vpna
vxlan 10
vsi vpnb
vxlan 20
vsi vpnc
vxlan 30
interface LoopBack0
ip address 3.3.3.3 255.255.255.255
isis enable 1
isis enable 1
port access vlan 30
xconnect vsi vpnc
l3-vni 1000
bgp 100
router-id 3.3.3.3
peer 1.1.1.1 connect-interface LoopBack0
peer 1.1.1.1 enable
