| 01-Load balancing overview | 33.06 KB |
Load balancing (LB) is a cluster technology that distributes services among multiple network devices or links.
Advantages of load balancing
Load balancing has the following advantages:
High performance—Improves overall system performance by distributing services to multiple devices or links.
Scalability—Meets increasing service requirements without compromising service quality by easily adding devices or links.
High availability—Improves overall availability by using backup devices or links.
Manageability—Simplifies configuration and maintenance by centralizing management on the load balancing device.
Transparency—Preserves the transparency of the network topology for end users. Adding or removing devices or links does not affect services.
Load balancing types
LB includes the following types:
Server load balancing—Data centers generally use server load balancing for networking. Network services are distributed to multiple servers or firewalls to enhance the processing capabilities of the servers or firewalls. (This type is not supported in the current software version.)
Link load balancing—Link load balancing applies to a network environment where there are multiple carrier links to implement dynamic link selection. This enhances link utilization. Link load balancing supports IPv4 and IPv6, but does not support IPv4-to-IPv6 packet translation. Link load balancing is classified into the following types based on the direction of connection requests:
Outbound link load balancing—Load balances traffic among the links from the internal network to the external network.
Inbound link load balancing—Load balances traffic among the links from the external network to the internal network.
Transparent DNS proxy—Load balances DNS requests among the links from the internal network to the external network.
