- 03-Security Configuration Guide
- 01-Security zone configuration
- 02-Security policy configuration
- 03-ASPF configuration
- 04-Session management
- 05-IP source guard configuration
- 06-802.1X configuration
- 07-User identification configuration
- 08-Password control configuration
- 09-MAC authentication configuration
- 10-IPoE configuration
- 11-Public key management
- 12-SSH configuration
- 13-Connection limit configuration
- 14-Attack detection and prevention configuration
- 15-Server connection detection configuration
- 16-ARP attack protection configuration
- 17-ND attack defense configuration
- 18-uRPF configuration
- 19-IP-MAC binding configuration
- 20-APR configuration
- 21-Keychain configuration
- 22-MAC learning through a Layer 3 device configuration
- 23-SMS configuration
- 24-Portal configuration
- 25-AAA configuration
- 26-PKI configuration
- 27-SSL configuration
- 28-Crypto engine configuration
- 29-Object group configuration
- 30-Microsegmentation configuration
- 31-IP-SGT mapping configuration
| 20-APR configuration | 150.81 KB |
NBAR (configuration profile-based)
APR signature library management
Restrictions: Licensing requirements for APR
Configuring a user-defined NBAR rule
Configuring a user-defined NBAR rule (configuration profile-based)
Configuring a risk type for a user-defined application
Configuring application groups
Enabling application statistics on an interface
Configuring detection thresholds for categorizing an application as type other
Managing the APR signature library
Restrictions and guidelines for APR signature library management
Scheduling an automatic update for the APR signature library
Triggering an automatic update for the APR signature library
Performing a manual update for the APR signature library
Rolling back the APR signature library
Display and maintenance commands for APR
Configuring APR
About APR
The application recognition (APR) feature recognizes applications of packets for features such as QoS, ASPF, and bandwidth management.
APR uses the following methods to recognize an application:
· Port-based application recognition (PBAR).
· Network-based application recognition (NBAR).
PBAR
PBAR maps a port to an application and recognizes packets of the application according to the port-protocol mapping.
PBAR supports the following port-protocol mappings:
· Predefined—An application uses the port defined by the system. You can modify predefined port-protocol mappings.
· User-defined—An application uses the port defined by the user.
PBAR offers the following mappings to maintain and apply user-defined port configuration:
· General port mapping—Maps a user-defined port to an application. All packets destined for that port are regarded as packets of the application. For example, if port 53222 is mapped to BitTorrent all packets destined for that port are regarded as BitTorrent packets.
· Host-port mapping—Maps a user-defined port to an application for packets to or from some specific hosts. For example, you can establish a host-port mapping so that all packets destined for the network segment 10.110.0.0/16 on port 2121 are regarded as FTP packets. To define the range of the hosts, you can specify the ACL, the host IP address range, or the subnet.
Host-port mapping can be further divided into the following categories:
¡ ACL-based host-port mapping—Maps a port to an application for the packets matching the specified ACL.
¡ Subnet-based host-port mapping—Maps a port to an application for the packets sent to the specified subnet.
¡ IP address-based host-port mapping—Maps a port to an application for the packets destined for the specified IP addresses.
APR selects a port mapping to recognize the application of a packet in the following order:
· IP address-based port mapping.
· Subnet-based port mapping.
· ACL-based host-port mapping.
· General port mapping.
For the same type of mappings, the port mapping with a transport layer protocol has higher priority than the mapping without a transport layer protocol.
NBAR
NBAR uses predefined or user-defined NBAR rules to match packet contents to recognize the applications of packets that match the applied object policy.
NBAR can recognize the following application types:
· Predefined—Defined by NBAR rules in the APR signature library.
· User-defined—Defined by user-configured NBAR rules. Typically, when a new network application emerges, its corresponding application signature usually becomes available somewhat later. If administrators are already familiar with the characteristics of the new network application, they can create custom NBAR applications to supplement the predefined applications. Otherwise, do not configure custom applications.
NBAR uses NBAR rules to match packet contents to recognize the applications of packets that match the applied object policy.
Application group
You can add applications that have similar signatures or restrictions to an application group. APR recognizes packets of the applications by matching the packet contents with the signatures or restrictions. If a packet is recognized as the packet of an application in the application group, the packet is considered to be the packet of the application group. Features such as ASPF and bandwidth management can handle packets belonging to the same group in batch.
You can add applications to an application group by using the following methods:
· Add applications one by one to the application group.
· Copy applications from another application group to the application group.
APR signature library is a resource library of character string signatures for application recognition. It includes PBAR and NBAR signatures. To meet the changing requirements for application recognition, you must update the APR signature library in a timely manner and roll back the APR signature library as needed.
APR signature library update
You can update the APR signature library by using one of the following methods:
· Automatic update.
The device automatically downloads the most up-to-date APR signature file to update its local signature library periodically.
· Triggered update.
The device downloads the most up-to-date APR signature file to update its local signature library immediately after you trigger the update operation.
· Manual update.
Use this method when the device cannot obtain the APR signature file automatically.
You must first download the most up-to-date APR signature file manually. The device then obtains the downloaded file to update its local signature library.
APR signature library rollback
You can perform the rollback operation if high error rate or abnormality occurs when the device uses the current APR signature library for application recognition.
You can roll back the current APR signature library to the factory version.
To update the APR signature library, you must purchase and install the appropriate license. After the license expires, APR can still use the existing signature library but cannot update the signature library. For information about licenses, see license management in Fundamentals Configuration Guide.
APR tasks at a glance
To configure APR, perform the following tasks:
2. Configuring a user-defined NBAR rule
3. Configuring a user-defined NBAR rule (configuration profile-based)
4. Configuring a risk type for a user-defined application
5. Configuring application groups
6. Enabling application statistics on an interface
7. Configuring detection thresholds for categorizing an application as type other
8. Managing the APR signature library
Configuring PBAR
1. Enter system view.
2. Configure a port mapping.
Choose the options to configure as needed:
¡ Configure a general port mapping:
port-mapping application application-name port port-number [ protocol protocol-name ]
¡ Configure an ACL-based host-port mapping:
port-mapping application application-name port port-number [ protocol protocol-name ] acl [ ipv6 ] acl-number
¡ Configure a subnet-based host-port mapping:
port-mapping application application-name port port-number [ protocol protocol-name ] subnet { ip ipv4-address { mask-length | mask } | ipv6 ipv6-address prefix-length } [ vpn-instance vpn-instance-name ]
¡ Configure an IP address-based host-port mapping:
port-mapping application application-name port port-number [ protocol protocol-name ] host { ip | ipv6 } start-ip-address [ end-ip-address ] [ vpn-instance vpn-instance-name ]
By default, all applications are mapped to well-known ports.
If the specified application does not exist, the system first creates the protocol.
You can configure user-defined NBAR rules if predefined NBAR rules cannot meet user needs. The predefined NBAR rules cannot be deleted or modified.
A user-defined NBAR rule can contain the following match criteria:
· Signatures.
· Destination IP subnet.
· Source IP subnet.
· Direction at which the application is recognized.
· Destination port number.
You can configure more than one match criterion for the NBAR rule. To match the NBAR rule, packets must match all the configured match criteria in the rule. If multiple signatures are configured, packets must match a minimum of one signature.
2. Create a user-defined NBAR rule and enter its view.
nbar application application-name protocol { http | tcp | udp }
3. (Optional.) Configure the description of the NBAR rule.
By default, the user-defined NBAR rule is described as User defined application.
4. Configure a signature and enter NBAR rule signature view.
signature [ signature-id ] [ field field-name ] [ offset offset-value ] { hex hex-vector | regex regex-pattern | string string }
By default, no signatures are configured for an NBAR rule.
5. (Optional.) Configure a detection item for the signature.
detection detection-id field field-name match-type { exclude | include } { hex hex-vector | regex regex-pattern | text text-string } [ offset offset-value [ depth depth-value ] | relative-offset relative-offset-value [ relative-depth relative-depth-value ] ]
By default, no detection items are configured for a signature.
6. Return to user-defined NBAR rule view.
7. (Optional.) Specify a destination IP subnet.
destination ip ipv4-address [ mask-length ]
By default, an NBAR rule matches packets with any destination IP address.
8. (Optional.) Specify a source IP subnet.
source ip ipv4-address [ mask-length ]
By default, an NBAR rule matches packets with any source IP address.
9. (Optional.) Specify a direction.
direction { to-client | to-server }
By default, an NBAR rule matches packets in both directions.
10. (Optional.) Specify a port number or port range.
service-port { port-num | range start-port end-port }
By default, an NBAR rule matches packets of all port numbers.
11. (Optional.) Set the maximum detected length.
apr set detectlen bytes
By default, the maximum detected length is not set for an NBAR rule.
12. (Optional.) Disable the user-defined NBAR rule.
disable
By default, a user-defined NBAR rule is enabled.
13. Return to system view.
14. Activate the user-defined NBAR rule.
inspect activate
For information about this command, see DPI engine commands in DPI Command Reference.
You can configure a user-defined NBAR rule if predefined NBAR applications cannot meet user needs.
A user-defined NBAR rule can contain the following content:
· Signature.
· Destination IPv4 match criterion, source IPv4 match criterion, and destination port match criterion.
2. Create a configuration profile and enter its view.
3. Create a user-defined NBAR rule and enter its view.
4. Configure a signature.
signature signature-id [ field field-name ] [ offset offset-value ] { hex hex-vector | regex regex-pattern | string string }
By default, no signature is configured.
5. (Optional.) Configure a destination IPv4 address match criterion.
By default, packets with any destination IPv4 address are matched.
6. (Optional.) Configure a destination port match criterion.
By default, packets with any destination port are matched.
7. (Optional.) Configure a source IPv4 address match criterion.
By default, packets with any source IPv4 address are matched.
A user-defined application can have multiple or no risk types.
The more risk types a user-defined application has, the higher risk level the application has. You can configure protection policies (such as security policies) according to the risk level.
The risk types for predefined applications are automatically generated by the APR signature library.
Before configuring risk types, you must update the APR signature library to the latest version.
The user-defined application must already exist.
2. Enter user-defined application view.
user-defined-application application-name
3. Configure a risk type for the user-defined application.
risk type risk-type
By default, a user-defined application does not have any risk type.
2. Create an application group and enter its view.
app-group group-name
3. (Optional.) Configure the description of the application group.
By default, the description is "User-defined application group".
4. Add applications to the group.
¡ Copy all applications from another group to the group.
copy app-group group-name
Execute this command multiple times to copy applications from multiple groups to the current group.
¡ Add an application to the group.
include application application-name
By default, an application group does not contain any applications.
When the application statistics feature is enabled on an interface, the device separately counts the number of packets or bytes that the interface has received or sent for each application. It also calculates the transmission rates of the interface for these protocols.
To display application statistics, use the display application statistics command.
The application statistics feature consumes a large amount of system memory. When the system generates an alarm for lack of memory, disable the application statistics feature on all interfaces.
2. Enter Layer 3 interface view.
3. Enable application statistics on the interface.
application statistics enable [ inbound | outbound ]
If you do not specify the inbound or outbound keyword, this command enables the application statistics feature in both the inbound and outbound directions of the interface.
If the device cannot identify the application to which the packets of a protocol belongs after detection thresholds are reached, it categorizes the packets as belonging to type other.
You can configure both the packet count threshold and the payload length threshold for the same protocol.
2. Configure detection thresholds for categorizing an application as type other.
apr protocol protocol-name detection-threshold { packet-count count | payload-length length } application-other
By default, the device uses predefined detection thresholds in the signature library for categorizing an application as type other.
For a successful APR signature library update or rollback, do not delete the /dpi/ folder in the root directory on the device storage media.
Do not update or roll back the APR signature library when the remaining system memory reaches any alarm threshold. Insufficient memory causes update or rollback failure and affects the operation of NBAR. For information about memory alarm thresholds, see device management in Fundamentals Configuration Guide.
You can update only one APR signature library at a time. If an APR signature library is being updated, please wait for the update to complete before updating another APR signature library.
If the device can access the signature library services on the official website, you can schedule an automatic update. The automatic update enables the device to automatically update the local APR signature library at the scheduled update time.
For a successful automatic update, make sure the following requirements are met:
· The device can obtain the IP address of the official website through static or dynamic domain name resolution.
· The device can access the signature library services on the official website.
For information about DNS, see Layer 3—IP Services Configuration Guide.
2. Enable the automatic update feature and enter auto-update configuration view.
apr signature auto-update
By default, the automatic update feature is disabled.
3. Configure the update schedule.
By default, the device automatically updates the APR signature library between 02:01:00 to 04:01:00 every day.
Anytime you find a release of new signature version on the official website, you can trigger the device to immediately update the local APR signature library.
For a successful triggered update, make sure the following requirements are met:
2. Trigger an automatic update for the APR signature library.
apr signature auto-update-now
If the device cannot access the signature library services on the official website, use one of the following methods to manually update the APR signature library on the device:
· Local update—By using the locally stored APR signature file.
The APR signature file must be stored on the mater device for a successful update.
· FTP/TFTP update—By using the APR signature file stored on the FTP or TFTP server.
When you manually update the ARP signature library in offline mode, you can specify a specific source IP address for packets generated by the update. For example, in a network where a NAT device exists between the device and the TFTP/FTP server, you can use the source parameter to specify a source IP address that satisfies the NAT rule. In this way, the update packets sent from the device can be processed by the NAT device and reach the TFTP or FTP server successfully. If NAT is performed on an independent NAT device, the specified source IP address and the NAT device must be able to reach each other at Layer 3.
If you configure both the vpn-instance and source parameters, make sure the source IP address or source interface belongs to the VPN instance.
2. Manually update the APR signature library.
apr signature update file-path [ vpn-instance vpn-instance-name ] [ source { ip | ipv6 } { ip-address | interface interface-type interface-number } ]
2. Roll back the APR signature library.
apr signature rollback factory
Task |
Command |
Display information about application groups. |
display app-group [ name group-name ] |
Display information about applications. |
display application [ name application-name | pre-defined | user-defined ] |
Display statistics for applications. |
display application statistics [ direction { inbound | outbound } | interface interface-type interface-number [ slot slot-number ] | name application-name ] * |
Display statistics for applications on an interface in descending order based on the specified criteria. |
display application statistics top number { bps | bytes | packets | pps } interface interface-type interface-number [ slot slot-number ] |
Display detection threshold settings for applications categorized as type other. |
display apr protocol [ protocol-name ] detection-threshold-other |
Display APR signature library information. |
display apr signature library |
Display information about predefined port mappings. |
display port-mapping pre-defined |
Display information about user-defined port mappings. |
display port-mapping user-defined [ application application-name | port port-number ] |
Clear application statistics for interfaces. |
reset application statistics [ interface interface-type interface-number ] |
