| 00-Preface | 110.02 KB |
Preface
This command reference describes IRF configuration commands for setting up and maintaining an IRF fabric, including:
· Commands for IRF port binding configuration.
· Commands for IRF member ID and priority configuration.
· Commands for detecting IRF splits and maintaining the IRF fabric.
· Audience
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
