01-Fundamentals Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S5130S-EI[HI][SI][EI-R]&S5120V2-SI&S3100V3-EI&E100C&E500C[D] Command References-R63xx-6W10501-Fundamentals Command Reference
11-Automatic configuration commands
11-Automatic configuration commands 34.40 KB
autodeploy udisk enable
Use autodeploy udisk enable to enable USB-based automatic configuration.
Use undo autodeploy udisk enable to disable USB-based automatic configuration.
USB-based automatic configuration is enabled.
This command is supported only if the device has standard (not micro or mini) USB interfaces.
# Disable USB-based automatic configuration.
[Sysname] undo autodeploy udisk enable
