H3C FS5500V2-EI iOptic Switch Series Hardware Information and Specifications-6W101
HomeSupportSwitchesS5135 SeriesS5135S-EI SeriesTechnical DocumentsProduct LiteratureHardware Information & SpecificationsH3C FS5500V2-EI iOptic Switch Series Hardware Information and Specifications-6W101
01-Text
01-Text 4.55 MB
1 Product models and technical specifications
Product models
This document is applicable to the FS5500V2-EI switch series. Table1-1 describes the FS5500V2-EI switch series models.
Table1-1 FS5500V2-EI switch series models
Switch series
Model
Product code
FS5500V2-24PMS4X-EI-Q
LS-FS5500V2-24PMS4X-EI-Q
FS5500V2-24UXS6Y-EI
LS-FS5500V2-24UXS6Y-EI
FS5500V2-24UX2C-EI
LS-FS5500V2-24UX2C-EI
FS5500V2-48UXS4Y2Q-EI
LS-FS5500V2-48UXS4Y2Q-EI
Technical specifications
Table1-2 Technical specifications
Item
FS5500V2-24UXS6Y-EI
FS5500V2-24UX2C-EI
Dimensions (H × W × D)
43.6 × 440 × 320 mm (1.72 × 17.32 × 12.60 in)
43.6 × 440 × 400 mm (1.72 × 17.32 × 15.75 in)
Weight
≤ 6.5 kg (14.33 lb)
≤ 7.2 kg (15.87 lb)
≤ 7.2 kg (15.87 lb)
≤ 7.5 kg (16.53 lb)
Console port
1
1
1
1
USB port
1
1
1
1
Management Ethernet port
1
1
1
1
10/100/1000BASE-T autosensing Ethernet port
4 (Each and its corresponding SFP port form a combo interface)
N/A
N/A
N/A
SFP port
4 (SFP ports 21 to 24 and their corresponding 10/100/1000BASE-T autosensing Ethernet ports form combo interfaces)
N/A
N/A
42
2.5G SFP port
20
12
N/A
N/A
SFP+ port
4
12
24
6
SFP28 port
N/A
6
N/A
4
QSFP+ port
N/A
N/A
N/A
2
QSFP28 port
N/A
N/A
2
N/A
Power supply slot
N/A
2, on the rear panel
Fan tray slot
N/A
Input voltage
AC input:
·     Rated voltage range: 100 VAC to 240 VAC @ 50 or 60 Hz
·     Max voltage range: 90 VAC to 290 VAC@ 47 to 63 Hz
Power consumption (static)
Single AC: 24 W
Single AC: 39 W
Dual AC: 46 W
Single AC: 41 W
Dual AC: 48 W
Single AC: 49 W
Dual AC: 58 W
Power consumption (with typical configuration)
Single AC: 27 W
Single AC: 48 W
Dual AC: 55 W
Single AC: 50 W
Dual AC: 57 W
Single AC: 57 W
Dual AC: 64 W
Power consumption (full load)
Single AC: 478 W
Depends on the power supply configuration, as shown in Table1-3.
PoE power capacity
370 W
Depends on the power supply configuration, as shown in Table1-4.
Max PoE power capacity per port
Copper port: 35 W
Fiber port: 100 W
Fiber port: 100 W
Chassis leakage current compliance
UL62368-1/EN62368-1/IEC62368-1/UL60950-1/IEC60950-1/GB4943.1
Melting current of power supply fuse
10 A/250 V
·     PSR600-54A-B: 10 A/250 V
·     PSR920-54A-B: 16 A/250 V
·     PSR1600-54A-B: 16 A/250 V
Operating temperature
–5°C to +45°C (23°F to 113°F)
The maximum acceptable temperature decreases by 0.33°C (0.59°F) for every 100 m (328.08 ft) increase in altitude from 0 m (0 ft).
Operating relative humidity
5% to 95%, noncondensing
Fire resistance compliance
Table1-3 Power consumption of the FS5500V2-EI switch series (full load)
Power supply configuration
FS5500V2-24UXS6Y-EI
FS5500V2-24UX2C-EI
1 × PSR600-54A-B
600 W
589 W
611 W
1 × PSR920-54A-B
969 W
972 W
999 W
1 × PSR1600-54A-B (90 VAC to 176 VAC)
960 W
966 W
1001 W
1 × PSR1600-54A-B (176 VAC to 290 VAC or 180 VDC to 320 VDC)
1638 W
1620 W
1653 W
2 × PSR600-54A-B
1245 W
1270 W
1263 W
2 × PSR920-54A-B
1892 W
1949 W
1964 W
2 × PSR1600-54A-B (90 VAC to 176 VAC)
1939 W
1912 W
1967 W
2 × PSR1600-54A-B (176 VAC to 290 VAC or 180 VDC to 320 VDC)
2638 W
2626 W
3152 W
Table1-4 PoE power capacity of the FS5500V2-EI switch series
FS5500V2-24UXS6Y-EI
FS5500V2-24UX2C-EI
Total PoE power capacity
1 × PSR600-54A-B
450 W
100 W
450 W
100 W
450 W
100 W
1 × PSR920-54A-B
770 W
100 W
770 W
100 W
770 W
100 W
770 W
100 W
770 W
100 W
770 W
100 W
1450 W
100 W
1450 W
100 W
1450 W
100 W
2 × PSR600-54A-B
1020 W
100 W
1020 W
100 W
1020 W
100 W
1 × PSR600-54A-B and 1 × PSR920-54A-B
1020 W
100 W
1020 W
100 W
1020 W
100 W
2 × PSR920-54A-B
1600 W
100 W
1600 W
100 W
1600 W
100 W
1 × PSR920-54A-B and 1 × PSR1600-54A-B (90 VAC to 176 VAC)
1260 W
100 W
1260 W
100 W
1260 W
100 W
1 × PSR920-54A-B and 1 × PSR1600-54A-B (176 VAC to 290 VAC or 180 VDC to 320 VDC)
1600 W
100 W
1600 W
100 W
1600 W
100 W
1600 W
100 W
1600 W
100 W
1600 W
100 W
1 × PSR1600-54A-B (90 VAC to 176 VAC) and 1 × PSR1600-54A-B (176 VAC to 290 VAC or 180 VDC to 320 VDC)
1600 W
100 W
1600 W
100 W
1600 W
100 W
2850 W
100 W
2850 W
100 W
2850 W
100 W
IMPORTANT
IMPORTANT:
Do not install a PSR600-54A-B and a PSR1600-54A-B on the same switch.
2 Chassis views
Figure2-1 Front panel
(1) 10/100/1000BASE-T autosensing Ethernet port LED
(2) 10/100/1000BASE-T autosensing Ethernet port
(3) SFP+ port LED
(4) SFP + port
(5) Management Ethernet port LED (ACT)
(6) Management Ethernet port (MGMT)
(7) Mode button
(8) Management Ethernet port LED (LINK)
(9) USB port
(10) Console port
(11) System status LED (SYS)
(12) Mode LED (MODE)
(13) SFP port
(14) SFP port LED
(15) 2.5G SFP port LED
(16) PoE port
(17) 2.5G SFP port
Each SFP port or 2.5G SFP port and the PoE port under it form a combined photoelectric hybrid port. To provide data transmission and power supply, use combined photoelectric hybrid ports together with transceiver modules, hybrid copper-fiber cables, and combined fiber-copper pigtails.
Figure2-2 Rear panel
(1) Grounding screw
(2) AC power receptacle
FS5500V2-24UXS6Y-EI
Figure2-3 Front panel
(1) SFP port LED
(2) SFP+ port LED
(3) SFP28 port LED
(4) SFP28 port
(6) Management Ethernet port LED (LINK)
(7) Management Ethernet port (MGMT)
(8) USB port
(9) Mode button
(10) Console port
(13) Removable power supply 2 status LED (PWR2)
(14) Removable power supply 1 status LED (PWR1)
(15) SFP + port
(16) PoE port
(17) SFP port
·     Each SFP port or SFP+ port and the PoE port under it form a combined photoelectric hybrid port. To provide data transmission and power supply, use combined photoelectric hybrid ports together with transceiver modules, hybrid copper-fiber cables, and combined fiber-copper pigtails.
·     Ports 13 through 24 on the switch operate at 2.5 Gbps by default. After you install a license on the switch, these ports can operate at 10 Gbps.
Figure2-4 Rear panel
(1) Removable fan tray 1
(2) Removable fan tray 2
(3) Removable power supply 1
(4) Removable power supply 2
(5) Grounding screw
The FS5500V2-24UXS6Y-EI switch came with power supply slot PWR1 empty and power supply slot PWR2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-4, two PSR600-54A-B power supplies are installed in the power supply slots.
The FS5500V2-24UXS6Y-EI switch came with the two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-4, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
FS5500V2-24UX2C-EI
Figure2-5 Front panel
(1) SFP+ port LED
(2) QSFP28 port LED
(3) Management Ethernet port LED (ACT)
(4) Management Ethernet port (MGMT)
(5) Mode button
(7) USB port
(8) Console port
(9) System status LED (SYS)
(10) Mode LED (MODE)
(11) Removable power supply 2 status LED (PWR2)
(12) Removable power supply 1 status LED (PWR1)
(13) QSFP28 port
(14) PoE port
(15) SFP+ port
·     Each SFP+ port and the PoE port under it form a combined photoelectric hybrid port. To provide data transmission and power supply, use combined photoelectric hybrid ports together with transceiver modules, hybrid copper-fiber cables, and combined fiber-copper pigtails.
·     Ports 25 and 26 on the switch operate at 40 Gbps by default. After you install a license on the switch, these ports can operate at 100 Gbps.
Figure2-6 Rear panel
(5) Grounding screw
The FS5500V2-24UX2C-EI switch came with power supply slot PWR1 empty and power supply slot PWR2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-6, two PSR600-54A-B power supplies are installed in the power supply slots.
The FS5500V2-24UX2C-EI switch came with the two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-6, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
Figure2-7 Front panel
(1) SFP port LED
(2) SFP port
(3) PoE port
(4) SFP28 port LED
(5) SFP28 port
(6) QSFP+ port LED
(7) QSFP+ port
(8) Mode button
(9) USB port
(10) Console port
Each SFP port and the PoE port under it form a combined photoelectric hybrid port. To provide data transmission and power supply, use combined photoelectric hybrid ports together with transceiver modules, hybrid copper-fiber cables, and combined fiber-copper pigtails.
Figure2-8 Rear panel
(1) Management Ethernet port LED (ACT)
(2) Management Ethernet port LED (LINK)
(3) Removable fan tray 1
(4) Removable fan tray 2
(5) Removable power supply 1
(6) Removable power supply 2
(8) Grounding screw
The FS5500V2-48UXS4Y2Q-EI switch came with power supply slot PWR1 empty and power supply slot PWR2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-8, two PSR600-54A-B power supplies are installed in the power supply slots.
The FS5500V2-48UXS4Y2Q-EI switch came with the two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-8, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
3 FRUs and compatibility matrixes
Removable components
The FS5500V2-EI switch series (excluding the FS5500V2-24PMS4X-EI-Q switch) supports removable components. Table3-1 describes the removable components available for the switch.
Table3-1 Compatibility matrix between switches and removable components
Removable component model
FS5500V2-24UXS6Y-EI
FS5500V2-24UX2C-EI
Removable power supplies
PSR600-54A-B
Supported
PSR920-54A-B
Supported
PSR1600-54A-B
Supported
Removable fan trays
LSPM1FANSB-SN
Supported
IMPORTANT
IMPORTANT:
·     The power supplies support asset management. You can use the display device manuinfo command to view the name, sequence number, and vendor of the power supplies you have installed on the device.
·     You can install one power supply, or two power supplies for 1+1 redundancy on the FS5500V2-EI switch series (excluding the FS5500V2-24PMS4X-EI-Q switch). PoE capabilities vary by power supply configuration. When a power supply fails, PoE capabilities of the switch might decrease. For more information about PoE power capacity, see Table1-3.
·     The FS5500V2-EI switch series (excluding the FS5500V2-24PMS4X-EI-Q switch) uses removable fan trays. You can power on the switch only when the switch has two fan trays of the same model installed.
The FS5500V2-EI switch series (excluding the FS5500V2-24PMS4X-EI-Q switch) uses removable power supplies. Select power supplies as required.
Table3-2 Removable power supplies
Power supply model
Item
Specification
Reference
PSR600-54A-B
Rated input voltage range
100 VAC to 240 VAC @ 50 Hz or 60 Hz
H3C PSR600-54A-B Power Module User Manual
Max input voltage range
90 VAC to 290 VAC @ 47 Hz to 63 Hz
Maximum power
600 W
PSR920-54A-B
H3C PSR920-54A-B Power Module User Manual
Maximum power
920 W
PSR1600-54A-B
H3C PSR1600-54A-B Power Module User Manual
Maximum power
1600 W
Removable fan trays
The FS5500V2-EI switch series (excluding the FS5500V2-24PMS4X-EI-Q switch) uses removable fan trays. Select fan trays as required.
Figure3-1 Removable fan trays
Item
Specifications
LSPM1FANSB-SN
40 × 40.6 × 105 mm (1.57 × 1.60 × 4.13 in)
Fan speed
20000 R.P.M
Max airflow
20 CFM (0.57 m3/min)
Airflow direction
Draws air from the port side to the power supply side
Input voltage
12 V
Power consumption
9.8 W
Reference
H3C LSPM1FANSA-SN & LSPM1FANSB-SN Fan Trays User Guide
IMPORTANT
IMPORTANT:
4 Removable power supplies
600W power supply (PSR600-54A-B)
View
Figure4-1 PSR600-54A-B AC power supply view
For information about the status LEDs, see "Status LEDs on a 600W/920W/1600W power supply."
Features
PSR600-54A-B is an AC power supply with AC or HVDC input and DC output. Table4-1 describes the features provided by the PSR600-54A-B power supply.
Table4-1 Features provided by the PSR600-54A-B power supply
Feature
Protection function
Protection against input overcurrent, input undervoltage, output overvoltage, output current limiting, output shortcircuit, and overtemperature conditions.
Support for redundancy
Two power supplies can be connected in parallel to achieve 1+1 redundancy and load balancing.
Support for hot swapping
You can remove one of the power supplies in 1+1 redundancy when the switch is operating correctly.
Table4-2 Technical specifications
Item
Specification
40.2 × 73.5 × 213.8 mm (1.58 × 2.89 × 8.42 in), including the handle
Weight
1 kg (2.20 lb)
Rated AC input voltage range
AC input: 100 VAC to 240 VAC @ 50 or 60 Hz
HVDC input: 240 VDC
Max AC input voltage range
AC input: 90 VAC to 290 VAC @ 47 to 63 Hz
HVDC input: 180 to 320 VDC
Rated input current
N/A
Rated output current
11 A
Rated output voltage
56 V
Rated output power
600 W
10 A/250 V
920W power supply (PSR920-54A-B)
View
Figure4-2 PSR920-54A-B AC power supply view
Features
PSR920-54A-B is an AC power supply with AC or HVDC input and DC output. Table4-3 describes the features provided by the PSR920-54A-B power supply.
Table4-3 Features provided by the PSR920-54A-B power supply
Feature
Protection function
Table4-4 Technical specifications
Item
Specification
Weight
1 kg (2.20 lb)
HVDC input: 240 VDC
Rated input current
N/A
16.5 A
56 V
Rated output power
920 W
16 A/250 V
1600W power supply (PSR1600-54A-B)
View
Figure4-3 PSR1600-54A-B AC power supply view
Features
PSR1600-54A-B is an AC power supply with AC or HVDC input and DC output. Table4-5 describes the features provided by the PSR1600-54A-B power supply.
Table4-5 Features provided by the PSR1600-54A-B power supply
Feature
Protection function
Table4-6 Technical specifications
Item
Specification
Weight
1 kg (2.20 lb)
·     AC input: 100 VAC to 240 VAC @ 50 or 60 Hz
·     HVDC input: 240 VDC
·     AC input: 90 VAC to 290 VAC @ 47 to 63 Hz
·     HVDC input: 180 to 320 VDC
Rated input current
N/A
·     AC input:
¡     17 A: 90 to 176 V @ 47 to 63 Hz
¡     29 A: 176 to 290 V @ 47 to 63 Hz
·     HVDC input: 29 A
56 V
Rated output power
·     AC input:
¡     950 W: 90 to 176 V @ 47 to 63 Hz
¡     1600 W: 176 to 290 V @ 47 to 63 Hz
·     HVDC input: 1600 W
16 A/125 V
5 Removable fan trays
LSPM1FANSB-SN
View
Figure5-1 LSPM1FANSB-SN fan tray view
For information about the status LED, see "Fan tray status LED on a fan tray."
Features
The LSPM1FANSB-SN fan tray draws air from the port side to the power supply side. The fan tray features small size, fast heat dissipation, and hot swapping. It can automatically adjust the fan speed, providing powerful heat dissipation for the switch.
Table5-1 Technical specifications
Item
Specification
40 × 40.6 × 105 mm (1.57 × 1.60 × 4.13 in), including the handles
Fan quantity
1
Weight
N/A
Airflow direction
Air exhausted from the fan tray faceplate
Fan speed
20000 R.P.M
Max airflow
Input voltage
12 V
Max power consumption
9.8 W
6 Ports and LEDs
Ports
Console port
Table6-1 Console port specifications
Item
Specification
Connector type
RJ-45
Compliant standard
EIA/TIA-232
Transmission baud rate
9600 bps (default) to 115200 bps
Services
·     Provides connection to an ASCII terminal
·     Provides connection to the serial port of a local PC running terminal emulation program
Available switch models
All switch models
Table6-2 Management Ethernet port specifications
Item
Specification
Connector type
RJ-45
Transmission rate, duplex mode, and auto MDI/MDI-X
·     10 Mbps, half/full-duplex
·     100 Mbps, half/full-duplex
·     1000 Mbps, full-duplex
·     MDI/MDI-X, autosensing
Transmission medium
Category-5 or above twisted pair cable
Max transmission distance
100 m (328.08 ft)
Compliant standard
IEEE 802.3i
IEEE 802.3u
IEEE 802.3ab
Functions and services
Connects to a computer or remote network management work station for upgrading and managing applications and Boot ROM
All switch models
USB port
Table6-3 USB port specifications
Item
Specification
Connector type
USB 2.0
Compliant standard
OHC
Port transmission rate
Uploads and downloads data at a rate up to 480 Mbps
Accesses the file system on the flash of the switch, for example, to upload or download application and configuration files
All switch models
USB devices from different vendors vary in compatibilities and drivers. H3C does not guarantee correct operation of USB devices from other vendors on the switch. If a USB device fails to operate on the switch, replace it with one from another vendor.
10/100/1000BASE-T Ethernet port
Table6-4 10/100/1000BASE-T Ethernet port specifications
Item
Specification
Connector type
RJ-45
Available transceiver modules and cables
100 m (328.08 ft)
Transmission medium
Compliant standard
IEEE 802.3i
IEEE 802.3u
IEEE 802.3ab
Combo interface
The FS5500V2-24PMS4X-EI-Q switch provides four fixed combo interfaces on its front panel. Each combo interface contains an SFP port and a 10/100/1000BASE-T autosensing Ethernet port. Only one of these two ports operates at a time.
SFP port
Table6-5 SFP port specifications
Item
Specification
·     See FE SFP transceiver modules described in Table6-6
·     See GE SFP transceiver modules and cables described in Table6-7
FS5500V2-24PMS4X-EI-Q, FS5500V2-48UXS4Y2Q-EI
·     The FS5500V2-24PMS4X-EI-Q switch does not support transceiver modules with a maximum transmission distance of 40 km (24.86 miles) or 80 km (49.71 miles).
·     The FS5500V2-48UXS4Y2Q-EI switch supports a maximum of 20 SFP-GE-T and SFP-GE-T-D transceiver modules.
Table6-6 FE SFP transceiver modules available for the SFP ports
Central wavelength (nm)
Connector
Fiber type and diameter (µm)
SFP-FE-SX-MM1310-A
1310
LC
Multi-mode, 50/125
2 km (1.24 miles)
Multi-mode, 62.5/125
SFP-FE-LX-SM1310-A
1310
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-LH40-SM1310
1310
LC
Single-mode, 9/125
40 km (24.86 miles)
SFP-FE-LH80-SM1550
1550
LC
Single-mode, 9/125
80 km (49.71 miles)
SFP-FE-LX-SM1310-BIDI
TX: 1310
RX: 1550
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-LX-SM1550-BIDI
TX: 1550
RX: 1310
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-BX15-U-SM1310
1310
LC
Single-mode, 9/125
15 km (9.32 miles)
IMPORTANT
IMPORTANT:
The SFP-FE-LX-SM1310-BIDI and SFP-FE-LX-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses the SFP-FE-LX-SM1310-BIDI transceiver module, the other end must use the SFP-FE-LX-SM1550-BIDI transceiver module.
Table6-7 GE SFP transceiver modules and cables
GE SFP transceiver module/cable
Connector
Cable/Fiber type and diameter (µm)
Modal bandwidth (MHz*km)
Max. transmission distance
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-T-D
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-LX-SM1310-F
1310
LC
Single-mode
N/A
10 km (6.21 miles)
SFP-GE-SX-MM850-A
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
200 m (656.17 ft)
SFP-GE-LX-SM1310-A
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
Multi-mode, 50/125
500/400
550 m (1804.46 ft)
500
550 m (1804.46 ft)
SFP-GE-LH40-SM1310
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-D
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-GE-LH80-SM1550-D
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550
LC
Single-mode, 9/125
N/A
100 km (62.14 miles)
SFP-GE-LX-SM1310-BIDI
TX: 1310
RX: 1490
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI
TX: 1490
RX: 1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310-BIDI
TX: 1310
RX: 1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550-BIDI
TX: 1550
RX: 1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH70-SM1490-BIDI
TX: 1490
RX: 1550
LC
Single-mode, 9/125
N/A
70 km (43.50 miles)
SFP-GE-LH70-SM1550-BIDI
TX: 1550
RX: 1490
LC
Single-mode, 9/125
N/A
70 km (43.50 miles)
SFP cable
SFP-STACK-Kit
N/A
N/A
SFP cable
N/A
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
The SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules, the SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules, and the SFP-GE-LH70-SM1490-BIDI and SFP-GE-LH70-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use an SFP-GE-LX-SM1490-BIDI transceiver module.
·     As a best practice, use H3C transceiver modules and cables for the switch.
·     The H3C transceiver modules and cables are subject to change over time. For the most recent list of H3C transceiver modules and cables, contact your H3C Support or marketing staff.
·     For more information about H3C transceiver modules and cables, see H3C Transceiver Modules User Guide.
2.5G SFP port
Table6-8 2.5G SFP port specifications
Item
Specification
·     See 2.5G SFP transceiver modules described in Table6-9
FS5500V2-24PMS4X-EI-Q, FS5500V2-24UXS6Y-EI
Table6-9 2.5G SFP transceiver module
Connector
SFP-2.5G-LX10-SM1310-DR-I-F
1310
PoDLC
Single-mode, 9/125
N/A
10 km (6.21 miles)
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-2.5G-LX03-SM1310-BIDI
·     TX: 1310
·     RX: 1490
LC
Single-mode, 9/125
N/A
3 km (1.86 miles)
SFP-2.5G-LX03-SM1490-BIDI
·     TX: 1490
·     RX: 1310
LC
Single-mode, 9/125
N/A
3 km (1.86 miles)
SFP+ port
Table6-10 SPF+ port specifications
Item
Specification
·     See 10-GE SFP+ transceiver modules and cables described in Table6-11 and Table6-12
All switch models
Usage guidelines and restrictions
Ports 13 through 24 on the FS5500V2-24UXS6Y-EI switch operate at 2.5 Gbps by default. After you install a license on the switch, these ports can operate at 10 Gbps.
Table6-11 10-GE SFP+ transceiver modules
Connector
SFP-XG-SX-MM850-D
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-LX-SM1310-D
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-F
1310
LC
Single-mode
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1550-D
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1550
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1550-D
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LX-SM1270-BIDI
TX: 1270
RX: 1330
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1330-BIDI
TX: 1330
RX: 1270
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1270-BIDI
TX: 1270
RX: 1330
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1330-BIDI
TX: 1330
RX: 1270
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1490-BIDI
TX: 1490
RX: 1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1550-BIDI
TX: 1550
RX: 1490
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
IMPORTANT
IMPORTANT:
The SFP-XG-LX-SM1270-BIDI and SFP-XG-LX-SM1330-BIDI transceiver modules, SFP-XG-LH40-SM1270-BIDI and SFP-XG-LH40-SM1330-BIDI transceiver modules, and SFP-XG-LH80-SM1490-BIDI and SFP-XG-LH80-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-XG-LX-SM1270-BIDI transceiver module, the other end must use an SFP-XG-LX-SM1330-BIDI transceiver module.
Table6-12 10-GE SFP+ copper and fiber cables available for the SFP+ ports
Item
Cable length
SFP+ copper cable
LSWM1STK
0.65 m (2.13 ft)
LSWM2STK
1.2 m (3.94 ft)
LSWM3STK
3 m (9.84 ft)
LSTM1STK
5 m (16.40 ft)
SFP+ fiber cable
SFP-XG-D-AOC-7M
7 m (22.97 ft)
SFP-XG-D-AOC-10M
10 m (32.81 ft)
SFP-XG-D-AOC-20M
20 m (65.62 ft)
Figure6-1 SFP+ cable
(1) Connector
(2) Pull latch
SFP28 port
Table6-13 SFP28 port specifications
Item
Specification
·     See 25-GE SFP28 transceiver modules and cables described in Table6-14 and Table6-15
FS5500V2-24UXS6Y-EI, FS5500V2-48UXS4Y2Q-EI
Table6-14 25-GE SFP28 transceiver modules available for the SFP28 ports
Connector
Maximum transmission distance
SFP-25G-SR-MM850
850
LC
Multi-mode, 50/125
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
SFP-25G-LR-SM1310
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
Table6-15 25G SFP28 copper and fiber cables available for the SFP28 ports
Item
Cable length
25G SFP28 copper cable
SFP-25G-D-CAB-1M
1 m (3.28 ft)
SFP-25G-D-CAB-3M
3 m (9.84 ft)
SFP-25G-D-CAB-5M
5 m (16.40 ft)
25G SFP28 fiber cable
SFP-25G-D-AOC-3M
3 m (9.84 ft)
SFP-25G-D-AOC-5M
5 m (16.40 ft)
SFP-25G-D-AOC-7M
7 m (22.97 ft)
SFP-25G-D-AOC-10M
10 m (32.81 ft)
SFP-25G-D-AOC-20M
20 m (65.62 ft)
Figure6-2 QSFP28 cable
(1) Connector
(2) Pull latch
QSFP+ port
Table6-16 QSPF+ port specifications
Item
Specification
See QSFP+ transceiver modules and cables described in Table6-17 and Table6-18
Table6-17 QSFP+ transceiver modules available for the QSFP+ ports
Connector
Modal bandwidth (MHz × km)
QSFP-40G-SR4-MM850
850
MPO
Multi-mode, 50/125
2000
100 m (328.08 ft)
4700
150 m (492.13 ft)
QSFP-40G-CSR4-MM850
850
MPO
Multi-mode, 50/125
2000
300 m (984.25 ft)
4700
400 m (1312.34 ft)
QSFP-40G-LR4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
QSFP-40G-LR4L-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 50/125
N/A
2 km (1.24 miles)
QSFP-40G-BIDI-SR-MM850
850
LC
Multi-mode, 50/125
2000
100 m (328.08 ft)
4700
150 m (492.13 ft)
QSFP-40G-BIDI-WDM850
Four lanes:
·     850
·     880
·     910
·     940
LC
Multi-mode, 50/125
2000
240 m (787.40 ft)
4700
350 m (1148.29 ft)
QSFP-40G-ER4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 50/125
N/A
40 km (24.86 miles)
Table6-18 40G QSFP+ copper and fiber cables available for the QSFP+ ports
Item
Cable length
QSFP+ copper cable
LSWM1QSTK0
1 m (3.28 ft)
LSWM1QSTK1
3 m (9.84 ft)
LSWM1QSTK2
5 m (16.40 ft)
QSFP+ fiber cable
QSFP-40G-D-AOC-3M
3 m (9.84 ft)
QSFP-40G-D-AOC-7M
7 m (22.97 ft)
QSFP-40G-D-AOC-10M
10 m (32.81 ft)
QSFP-40G-D-AOC-20M
20 m (65.62 ft)
Figure6-3 40G QSFP+ cable
(1) Connector
(2) Pull latch
QSFP28 port
Table6-19 QSFP28 port specifications
Item
Specification
·     See QSFP+ transceiver modules and cables described in Table6-17 and Table6-18
·     See QSFP28 transceiver modules and cables described in Table6-20 and Table6-21
FS5500V2-24UX2C-EI
QSFP28 ports on an FS5500V2-24UX2C-EI switch operate at 40 Gbps by default. After you install a license on the switch, the QSFP28 ports can operate at 100 Gbps.
Table6-20 QSFP28 transceiver modules available for the QSFP28 ports
Connector
QSFP-100G-SR4-MM850
850
MPO
Multi-mode, 50/125
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
QSFP-100G-LR4-WDM1300
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
QSFP-100G-LR4L-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
2 km (1.24 miles)
QSFP-100G-ER4L-WDM1300
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
QSFP-100G-BIDI-MM850
Two lanes:
·     855
·     908
MPO
Multi-mode, 50/125
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
Table6-21 100G QSFP28 fiber and copper cables available for the QSFP28 ports
Item
Cable length
QSFP28 fiber cable
QSFP-100G-D-AOC-7M
7 m (22.97 ft)
QSFP-100G-D-AOC-10M
10 m (32.81 ft)
QSFP-100G-D-AOC-20M
20 m (65.62 ft)
QSFP28 copper cable
QSFP-100G-D-CAB-1M
1 m (3.28 ft)
QSFP-100G-D-CAB-3M
3 m (9.84 ft)
QSFP-100G-D-CAB-5M
5 m (16.40 ft)
LEDs
System status LED
The system status LED shows the operating status of the switch.
Table6-22 System status LED description
LED mark
Status
SYS
Steady green
The switch has started correctly.
Flashing green (1 Hz)
The switch is performing power-on self test (POST).
Steady red
The switch has failed POST or is faulty.
Off
The switch is powered off.
Power supply status LED
For switch models that support removable power supplies, the PWR1 and PWR2 LEDs on the front panel indicate the operating status of the power supplies
Table6-23 Power supply status LED description
LED mark
Status
PWR1/PWR2
Steady green
A power supply is installed in the power supply slot, and the power supply is outputting power correctly.
Steady yellow
A power supply is installed in the power supply slot, but the power supply is faulty or not powered on.
Off
No power supply is installed in the power supply slot.
Mode LED (MODE)
The mode LED works in conjunction with the port LEDs to indicate the operating state of the ports and the switch.
·     The mode LED indicates the type of information that the port LEDs are showing.
·     You can use the mode button to change the indication of the mode LED. After you press the mode button for the mode LED to steady yellow, flashing green, or flashing yellow, the mode LED keeps that state for only 45 seconds and then turns steady green automatically.
Table6-24 Mode LED description
LED mark
Status
MODE
Steady green
The port LEDs are showing link state of the ports.
Flashing green
The port LEDs are showing the PoE status of the ports.
Flashing yellow
The port LEDs work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 4 is steady green, the IRF member ID of the switch is 4.
SFP port LED
Table6-25 SFP port LED description
Mode LED status
SFP port LED status
Steady green (rate mode)
Steady green
A link is present on the port and the port is operating at 1000 Mbps.
Flashing green
The port is sending or receiving data at 1000 Mbps.
Steady yellow
A link is present on the port and the port is operating at 100 Mbps.
Flashing yellow
The port is sending or receiving data at 100 Mbps.
Off
No link is present on the port.
Flashing green (PoE mode)
Steady green
PoE power supply is normal.
Flashing green
·     The maximum PoE power provided by the port fails to meet the power requirement of the PD.
·     The remaining power of the switch fails to meet the power supply requirement of the port.
Steady yellow
The port has failed to supply power.
Off
The port is not supplying power through PoE.
Flashing yellow (IRF mode)
Steady green
The SFP port LEDs work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 4 is steady green, the IRF member ID of the switch is 4.
2.5G SFP port LED
Table6-26 2.5G SFP port LED description
Mode LED status
2.5G SFP port LED status
Steady green
A link is present on the port and the port is operating at 2.5 Gbps.
Flashing green
The port is sending or receiving data at 2.5 Gbps.
Steady yellow
A link is present on the port and the port is operating at 1 Gbps.
Flashing yellow
The port is sending or receiving data at 1 Gbps.
Off
Steady green
Flashing green
Steady yellow
Off
Steady green
The 2.5G SFP port LEDs work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 4 is steady green, the IRF member ID of the switch is 4.
SFP+ port LED
Table6-27 SFP+ port LED description
Mode LED status
SFP+ port LED status
Steady green
A link is present on the port and the port is operating at 10 Gbps.
Flashing green
The port is sending or receiving data at 10 Gbps.
Steady yellow
A link is present on the port and the port is operating at 2.5 Gbps or 1 Gbps.
Flashing yellow
The port is sending or receiving data at 2.5 Gbps or 1 Gbps.
Off
Steady green
Flashing green
Steady yellow
Off
Off
The mode LED is operating in IRF mode.
SFP28 port LED
Table6-28 SFP28 port LED description
SFP28 port LED status
Steady green
A transceiver module or cable has been correctly installed. The port has a link and is operating at 25 Gbps.
Flashing green
The port is sending or receiving data at 25 Gbps.
Steady yellow
A transceiver module or cable has been correctly installed. The port has a link and is operating at 10 Gbps.
Flashing yellow (3 Hz)
Off
No transceiver module or cable is installed in the port or no link is present on the port.
QSFP+ port LED
Table6-29 SFP28 port LED description
QSFP+ port LED status
Steady green
A transceiver module or cable has been correctly installed. The port has a link and is operating at 40 Gbps.
Flashing green
The port is sending or receiving data at 40 Gbps.
Off
·     No transceiver module or cable is installed in the port or no link is present on the port.
·     The mode LED is operating in IRF mode.
·     The mode LED is operating in PoE mode.
QSFP28 port LED
Table6-30 QSFP28 port LED description
QSFP28 port LED status
Steady green
A transceiver module or cable has been correctly installed. The port has a link and is operating at 100 Gbps.
Flashing green
The port is sending or receiving data at 100 Gbps.
Steady yellow
Flashing yellow
Off
Table6-31 Fan tray status LED description
Status
On
The fan tray is faulty.
Off
The fan tray is operating correctly.
The PSR600-54A-B, PSR920-54A-B, and PSR1600-54A-B power supplies each have two status LEDs to indicate the power input and output status.
Table6-32 Description for the status LEDs on a 600W/920W/1600W power supply
LED
Mark
Status
Output status LED
OUT OK
Steady green
Normal power output.
Steady red
Abnormal power output.
Off
No power output
Input status LED
IN OK
Steady green
Normal power input.
Steady red
Abnormal power input.
Off
No power input.
7 Cooling system
To dissipate heat timely and enhance system stability, the switch uses a high-performance cooling system. Consider the site ventilation design when you plan the installation site for the switch.
The FS5500V2-EI switch series (excluding the FS5500V2-24PMS4X-EI-Q switch) uses removable fan trays. For adequate heat dissipation, install two fan trays of the same model for the switch.
Table7-1 Cooling system
Switch model
Available fan tray
Airflow direction
N/A
Passive cooling
FS5500V2-24UXS6Y-EI
FS5500V2-24UX2C-EI
LSPM1FANSB-SN
From the port side to the power supply side
Figure7-1 Airflow through the FS5500V2-48UXS4Y2Q-EI chassis
