- 05-Layer 3—IP Services Configuration Guide
- 01-Adjacency table configuration
- 02-ADVPN configuration
- 03-ARP configuration
- 04-DNS configuration
- 05-Fast forwarding configuration
- 06-GRE configuration
- 07-HTTP redirect configuration
- 08-IP addressing configuration
- 09-IP forwarding basics configuration
- 10-IP performance optimization configuration
- 11-IPv6 basics configuration
- 12-IPv6 fast forwarding configuration
- 13-IRDP configuration
- 14-Tunneling configuration
- 15-UDP helper configuration
- 16-WAAS configuration
| 10-IP performance optimization configuration | 262.19 KB |
IP performance optimization tasks at a glance
Enabling an interface to forward directed broadcasts destined for the directly connected network
Setting the interface MTU for IPv4 packets
Enabling IPv4 local fragment reassembly
Enabling Layer 3 packet statistics collection
Enabling processing IP options in IP packets
Enabling processing the source route option
Enabling IP packet isolation between management port and service port
Enabling sending ICMP error messages
About sending ICMP error messages
Enabling sending ICMP redirect messages
Enabling sending ICMP time exceeded messages
Enable sending ICMP destination unreachable messages
Configuring rate limit for ICMP error messages
Disabling forwarding ICMP fragments
Specifying the source address for ICMP packets
Disabling sending a specific type of ICMP messages
Disabling receiving a specific type of ICMP messages
Setting the forwarding priority value for ICMP echo replies in hardware
Setting TCP MSS for an interface
Modifying the TCP MSS value in TCP SYN packets
Configuring TCP path MTU discovery
Enabling the Timestamps option encapsulation in outgoing TCP packets
Enabling SNMP notifications for TCP events
Configuring the packet following feature
Display and maintenance commands for IP performance optimization
Optimizing IP performance
All IP performance optimization tasks are optional.
1. Configuring features for IP packets
¡ Enabling an interface to forward directed broadcasts destined for the directly connected network
¡ Setting the interface MTU for IPv4 packets
¡ Enabling IPv4 local fragment reassembly
¡ Enabling Layer 3 packet statistics collection
¡ Enabling processing IP options in IP packets
¡ Enabling processing the source route option
¡ Enabling IP packet isolation between management port and service port
2. Configuring features for ICMP messages
¡ Enabling sending ICMP error messages
¡ Configuring rate limit for ICMP error messages
¡ Specifying the source address for ICMP packets
¡ Disabling sending a specific type of ICMP messages
¡ Disabling receiving a specific type of ICMP messages
¡ Setting the forwarding priority value for ICMP echo replies in hardware
3. Configuring features for TCP packets
¡ Setting TCP MSS for an interface
¡ Modifying the TCP MSS value in TCP SYN packets
¡ Configuring TCP path MTU discovery
¡ Enabling the Timestamps option encapsulation in outgoing TCP packets
¡ Enabling SNMP notifications for TCP events
¡ Configuring the packet following feature
About enabling an interface to forward directed broadcasts destined for the directly connected network
A directed broadcast packet is destined for all hosts on a specific network. In the destination IP address of the directed broadcast, the network ID identifies the target network, and the host ID is made up of all ones.
Hackers can use directed broadcasts to attack the target network. In some scenarios, however, an interface must send such directed broadcast packets to support the following features:
· UDP helper—Converts the directed broadcasts to unicasts and forwards them to a specific server.
· Wake on LAN—Sends the directed broadcasts to wake up the hosts on the target network.
You can configure this function to enable the interface to forward directed broadcast packets that are destined for directly connected network.
2. Enter interface view.
3. Enable the interface to forward directed broadcasts destined for the directly connected network.
ip forward-broadcast [ acl acl-number ]
By default, an interface cannot forward directed broadcasts destined for the directly connected network.
Example: Enabling an interface to forward directed broadcasts destined for the directly connected network
As shown in Figure 1, the default gateway of the host is the IP address 1.1.1.2/24 of Ten-GigabitEthernet 3/0/1 of Router A. Configure a static route destined for the host on Router B. Router B can receive directed broadcasts from the host to IP address 2.2.2.255.
Table 1 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Ten-GigabitEthernet3/0/1 |
Interface2 |
Ten-GigabitEthernet3/0/2 |
1. Configure Router A:
# Specify IP addresses for Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2.
[RouterA] interface ten-gigabitethernet 3/0/1
[RouterA-Ten-GigabitEthernet3/0/1] ip address 1.1.1.2 24
[RouterA-Ten-GigabitEthernet3/0/1] quit
[RouterA] interface ten-gigabitethernet 3/0/2
[RouterA-Ten-GigabitEthernet3/0/2] ip address 2.2.2.2 24
# Enable Ten-GigabitEthernet 3/0/2 to forward directed broadcasts destined for the directly connected network.
[RouterA-Ten-GigabitEthernet3/0/2] ip forward-broadcast
2. Configure Router B:
# Configure a static route to the host.
<RouterB> system-view
[RouterB] ip route-static 1.1.1.1 24 2.2.2.2
# Specify an IP address for Ten-GigabitEthernet 3/0/2.
[RouterB] interface ten-gigabitethernet 3/0/2
[RouterB-Ten-GigabitEthernet3/0/2] ip address 2.2.2.1 24
After the configurations are completed, if you ping the subnet-directed broadcast address 2.2.2.255 on the host, Ten-GigabitEthernet 3/0/2 of Router B can receive the ping packets. If you delete the ip forward-broadcast configuration on any router, Ten-GigabitEthernet 3/0/2 of Router B cannot receive the ping packets.
The interface MTU for IPv4 packets defines the largest size of an IPv4 packet that an interface can transmit without fragmentation. When a packet exceeds the MTU of the sending interface, the device processes the packet in one of the following ways:
· If the packet disallows fragmentation, the device discards it.
· If the packet allows fragmentation, the device fragments it and forwards the fragments.
Fragmentation and reassembling consume system resources, so set the MTU based on the network environment to avoid fragmentation.
1. Enter system view.
3. Set the interface MTU for IPv4 packets.
ip mtu mtu-size
By default, the interface MTU is not set.
By default, an LPU delivers received packet fragments to the active MPU for centralized fragment reassembly. To improve fragment reassembly efficiency, use this feature. When an LPU receives fragments of an IPv4 packet, it reassembles them directly.
Use this feature with caution, because fragment reassembly fails on an LPU when the fragments of an IPv4 packet are received on different LPUs.
2. Enable IPv4 local fragment reassembly.
ip reassemble local enable
By default, IPv4 local fragment reassembly is disabled.
With this feature enabled on an interface, the device counts incoming and outgoing IP packets on the interface. To display the collected statistics, execute the display ip statistics command.
If too many interfaces are enabled with this feature, the device might have a high CPU usage. If the statistics are not necessary, to ensure the device performance, disable this feature.
3. Enable Layer 3 packet statistics collection.
statistics l3-packet enable
By default, Layer 3 packet statistics collection is disabled.
IP options are typically used for network path diagnosis or temporary transmission of specific services. When a packet with IP options arrives at an intermediate device, the device sends the packet to CPU to process IP options before forwarding it out. In a network with excessive packet exchanges, processing IP options will prevent the intermediate device from processing packets in a timely manner and cause packet loss. To avoid this situation, execute the undo ip option enable command to disable the device from processing IP options in packets to be forwarded. Then packets will be forwarded through hardware.
Disable this feature only when IP options are not used in the network.
If both undo ip option enable and undo ip option source-route enable are configured, the device forwards IP packets that contain the source route option instead of dropping them.
2. Enable the device to process IP options in IP packets.
ip option enable
By default, the device processes IP options in IP packets.
The source route option in the IP header is used for network diagnosis and specific service transmission. By default, the device supports processing the source route option. If the option is forged by an attacker, the device will obtain incorrect source route information, affecting network diagnosis and service transmission. To avoid the situation, you can execute the undo ip option source-route enable command to drop IP packets that contain source route option.
Before you enable or disable this feature, make sure you have fully evaluated the probability of the source route option attack in the network.
2. Enable processing IP packets that contain the source route option.
By default, the device processes IP packets that contain the source route option.
With this feature enabled, the device discards IP packets received and sent on different types of ports (management or service), for example, packets received on the management port but sent out of the service port. This isolates management IP traffic and service IP traffic from each other, preventing attacks against the management network through the service network.
In scenarios where the management port forwards IP service traffic, do not enable this feature as a best practice.
2. Enable IP packet isolation between management port and service port.
management-port isolate enable
By default, IP packet isolation between management port and service port is disabled.
ICMP messages are used by network layer and transport layer protocols to communicate updates and errors with other devices, facilitating network management.
Sending excessive ICMP messages increases network traffic. The device performance degrades if it receives a lot of malicious ICMP messages that cause it to respond with ICMP error messages. To prevent such problems, the sending of ICMP error messages is disabled by default. You can enable sending ICMP error messages of different types as needed.
ICMP error messages include redirect messages, time exceeded messages, and destination unreachable messages.
A host that has only one default route sends all packets to the default gateway. The default gateway sends an ICMP redirect message to inform the host of a correct next hop by following these rules:
· The receiving and sending interfaces are the same.
· The packet source IP address and the IP address of the packet receiving interface are on the same segment.
· There is no source route option in the received packet.
ICMP redirect messages simplify host management and enable hosts to gradually optimize their routing table.
2. Enable sending ICMP redirect messages.
3. ip redirects enable
By default, the device does not send ICMP redirect messages.
A device sends ICMP time exceeded messages by following these rules:
· The device sends the source an ICMP TTL exceeded in transit message when the following conditions are met:
¡ The received packet is not destined for the device.
¡ The TTL field of the packet is 1.
· When the device receives the first fragment of an IP datagram destined for it, it starts a timer. If the timer expires before all the fragments of the datagram are received, the device sends an ICMP fragment reassembly time exceeded message to the source.
If the ICMP time exceeded message sending is disabled, the device does not send ICMP TTL exceeded in transit messages. However, it can still send ICMP fragment reassembly time exceeded messages.
2. Enable sending ICMP time exceeded messages.
3. ip ttl-expires enable
By default, the device does not send ICMP time exceeded messages.
A device sends ICMP destination unreachable messages by following these rules:
· The device sends the source an ICMP network unreachable message when the following conditions are met:
¡ The packet does not match any route.
¡ No default route exists in the routing table.
· The device sends the source an ICMP protocol unreachable message when the following conditions are met:
¡ The packet is destined for the device.
¡ The transport layer protocol of the packet is not supported by the device.
· The device sends the source an ICMP port unreachable message when the following conditions are met:
¡ The UDP packet is destined for the device.
¡ The packet's port number does not match the corresponding process.
· The device sends the source an ICMP source route failed message when the following conditions are met:
¡ The source uses Strict Source Routing to send packets.
¡ The intermediate device finds that the next hop specified by the source is not directly connected.
· The device sends the source an ICMP fragmentation needed and DF set message when the following conditions are met:
¡ The MTU of the sending interface is smaller than the packet.
¡ The packet has DF set.
If a DHCP-enabled device receives an ICMP echo reply without sending any ICMP echo requests, the device does not send any ICMP protocol unreachable messages to the source. To enable DHCP, use the dhcp enable command. For more information about this command, see BRAS Services Command Reference.
2. Enable sending ICMP destination unreachable messages.
3. ip unreachables enable
By default, the device does not send ICMP destination unreachable messages.
To avoid sending excessive ICMP error messages within a short period that might cause network congestion, you can limit the rate at which ICMP error messages are sent. A token bucket algorithm is used with one token representing one ICMP error message.
A token is placed in the bucket at intervals until the maximum number of tokens that the bucket can hold is reached.
A token is removed from the bucket when an ICMP error message is sent. When the bucket is empty, ICMP error messages are not sent until a new token is placed in the bucket.
2. Set the interval for tokens to arrive in the bucket for ICMP error messages and set the bucket size.
By default, a token is placed in the bucket at an interval of 100 milliseconds, and the bucket allows a maximum of 10 tokens.
To disable the ICMP rate limit, set the interval to 0 milliseconds.
Disabling forwarding ICMP fragments can protect your device from ICMP fragment attacks.
2. Disable forwarding ICMP fragments.
ip icmp fragment discarding
By default, forwarding ICMP fragments is enabled.
Specifying the source IP address for outgoing ping echo requests and ICMP error messages helps a network administrator to locate the sending device easily. As a best practice, specify the IP address of the loopback interface as the source IP address.
If you specify an IP address in the ping command, ping echo requests use the specified address as the source IP address rather than the IP address specified by the ip icmp source command.
2. Specify the source address for outgoing ICMP packets.
By default, no source address is specified for outgoing ICMP packets. The default source IP addresses for different types of ICMP packets vary as follows:
¡ For an ICMP error message, the source IP address is the IP address of the receiving interface of the packet that triggers the ICMP error message. ICMP error messages include Time Exceeded, Port Unreachable, and Parameter Problem messages.
¡ For an ICMP echo request, the source IP address is the IP address of the sending interface.
¡ For an ICMP echo reply, the source IP address is the destination IP address of the ICMP echo request specific to this reply.
By default, the device sends all types of ICMP messages except Destination Unreachable, Time Exceeded, and Redirect messages. Attackers might obtain information from specific types of ICMP messages, causing security issues.
For security purposes, you can perform this task disable sending ICMP messages of specific types.
Disabling sending ICMP messages of a specific type might affect network operation. Please use this feature with caution.
To enable sending Destination Unreachable, Time Exceeded, or Redirect messages, you can perform one of the following tasks:
· Execute the ip icmp send enable command.
· Execute one of the following commands as needed:
¡ ip unreachables enable
¡ ip ttl-expires enable
¡ ip redirects enable
2. Disable the device from sending a specific type of ICMP messages.
undo ip icmp { name icmp-name | type icmp-type code icmp-code } send enable
By default, the device receives all types of ICMP messages. Such a setting might affect device performance if a large number of ICMP responses are received within a short time. To resolve this issue, you can perform this task to disable the device from receiving a specific type of ICMP messages.
Disabling receiving ICMP messages of a specific type might affect network operation. Please use this feature with caution.
2. Disable the device from receiving a specific type of ICMP messages.
undo ip icmp { name icmp-name | type icmp-type code icmp-code } receive enable
When you perform an ICMP echo test to test whether an NQA client can reach the NQA server, the NQA client sends ICMP echo requests to the NQA server. By default, the hardware of the NQA server responds to these ICMP echo requests with the lowest priority. When the NQA server forwards a large amount of packets with higher priority than ICMP echo replies, the hardware might fail to send those ICMP echo replies in time. As a result, the ICMP echo replies will be discarded due to sending timeout errors, which causes the ICMP echo test to fail.
To avoid this issue, use this feature on the NQA server to increase the forwarding priority value for ICMP echo replies in hardware. When the NQA server forwards a large amount of high-priority packets, the forwarding of ICMP echo replies will not be affected in hardware.
For more information about ICMP echo-type NQA tests, see NQA configuration in Network Management and Monitoring Configuration Guide.
After you configure this feature, the hardware forwards ICMP echo replies according to the priority value configured in the ip icmp echo-reply traffic-priority command rather than the original priority values in those ICMP echo replies.
After you undo this feature, the hardware forwards ICMP echo replies according to the priority values in those ICMP echo replies.
2. Set the forwarding priority value for ICMP echo replies in hardware.
ip icmp echo-reply traffic-priority priority-value
By default, the hardware responds to ICMP echo requests according to their priorities.
The maximum segment size (MSS) option informs the receiver of the largest segment that the sender can accept. Each end announces its MSS during TCP connection establishment. If the size of a TCP segment is smaller than the MSS of the receiver, TCP sends the TCP segment without fragmentation. If not, it fragments the segment according to the receiver's MSS.
· If you set the TCP MSS on an interface, the size of each TCP segment received or sent on the interface cannot exceed the MSS value.
· This configuration takes effect only for TCP connections established after the configuration rather than the TCP connections that already exist.
· This configuration is effective only for IP packets. If MPLS is enabled on the interface, do not set the TCP MSS on the interface.
The following matrix shows support of different interfaces for this feature:
Table 2 Interface support for this feature
IPv4 forwarding |
IPv4 traffic sending from the local device |
IPv6 forwarding |
IPv6 traffic sending from the local device |
Management interface on the MPU |
N/A |
Not configurable |
N/A |
Not configurable |
Interfaces on service modules |
Ineffective |
Both [syn] and [syn ack] are effective. |
Ineffective |
Both [syn] and [syn ack] are ineffective. |
3. Set the TCP MSS for the interface.
tcp mss value
By default, the TCP MSS is not set.
TCP MSS represents the maximum length of the data segment (excluding the TCP header) that the local device can receive in a TCP packet.
During TCP connection establishment, devices negotiate the TCP MSS value through TCP SYN packets and use the value to limit the data segment size in subsequent transmissions. If the TCP MSS supported by both devices is too large and cannot be adjusted, it might exceed the intermediate device MSS (MTU minus 40). This could lead to packet drops or increased latency due to packet fragmentation.
To resolve the issue, you can perform this task to adjust the value of the MSS field in the TCP SYN packets on either end or on the intermediary devices.
Table 3 Interface support for this feature
IPv4 forwarding |
IPv6 forwarding |
N/A |
N/A |
Effective |
Effective |
[syn] is ineffective, but [syn ack] is effective. |
· This configuration takes effect only on TCP connections that are established after the configuration and not on the TCP connections that already exist.
· This command specifies the MSS of TCP SYN packets on an intermediate device. If MPLS is enabled on the interface, do not execute the command on the interface.
· This configuration does not take effect on tunneled TCP SYN packets.
· If both ip tcp modify-mss and tcp modify-mss are configured, the ip tcp modify-mss configuration takes effect.
Modifying the TCP MSS value in both IPv4 and IPv6 packets
2. Adjust the TCP MSS of IPv4 and IPv6 TCP SYN packets that go through the device.
tcp modify-mss value
By default, the device does not adjust the MSS value in the IPv4 and IPv6 TCP SYN packets that go through it.
Modifying the TCP MSS value in IPv4 packets
2. Adjust the TCP MSS of IPv4 TCP SYN packets that go through the device.
ip tcp modify-mss value
By default, the device does not adjust the MSS value in the IPv4 TCP SYN packets that go through it.
TCP path MTU discovery (in RFC 1191) discovers the path MTU between the source and destination ends of a TCP connection. The device uses the path MTU to calculate the MSS to avoid IP fragmentation. The path MTU uses an aging mechanism to ensure that the source device can increase the path MTU when the minimum link MTU on the path increases.
TCP path MTU discovery works as follows:
1. A TCP source device sends a packet with the Don't Fragment (DF) bit set.
2. A router discards the packet that exceeds the MTU of the outgoing interface and returns an ICMP error message. The error message contains the MTU of the outgoing interface.
3. Upon receiving the ICMP message, the TCP source device calculates the current path MTU of the TCP connection.
4. The TCP source device sends subsequent TCP segments that are smaller than the MSS (MSS = path MTU – IP header length – TCP header length).
If the TCP source device still receives ICMP error messages when the MSS is smaller than 32 bytes, the TCP source device will fragment packets.
An ICMP error message received from a router that does not support RFC 1191 has the MTU of the outgoing interface set to 0. Upon receiving the ICMP message, the TCP source device selects the path MTU smaller than the current path MTU from the MTU table as described in RFC 1191. Based on the selected path MTU, the TCP source device calculates the TCP MSS. The MTU table contains MTUs of 68, 296, 508, 1006, 1280, 1492, 2002, 4352, 8166, 17914, 32000, and 65535 bytes. Because the minimum TCP MSS specified by the system is 32 bytes, the actual minimum MTU is 72 bytes.
The aging mechanism of the path MTU is as follows:
· When the TCP source device receives an ICMP error message, it reduces the path MTU and starts an aging timer for the path MTU.
· After the aging timer expires, the source device uses a larger MSS in the MTU table, as described in RFC 1191.
· If no ICMP error message is received within two minutes, the source device increases the MSS again until the MSS negotiated during TCP three-way handshake is reached.
Make sure all devices on a TCP connection are enabled to send ICMP error messages by using the ip unreachables enable command.
2. Enable TCP path MTU discovery.
By default, TCP path MTU discovery is disabled.
Enabling SYN Cookie
A TCP connection is established through a three-way handshake. An attacker can exploit this mechanism to mount SYN Flood attacks. The attacker sends a large number of SYN packets, but does not respond to the SYN ACK packets from the server. As a result, the server establishes a large number of TCP semi-connections and can no longer handle normal services.
SYN Cookie can protect the server from SYN Flood attacks. When the server receives a SYN packet, it responds with a SYN ACK packet without establishing a TCP semi-connection. The server establishes a TCP connection and enters ESTABLISHED state only when it receives an ACK packet from the client.
2. Enable SYN Cookie.
tcp syn-cookie enable
By default, SYN Cookie is disabled.
Setting the TCP buffer size
2. Set the size of TCP receive/send buffer.
tcp window window-size
The default buffer size is 63 KB.
Setting TCP timers
You can set the following TCP timers:
· SYN wait timer—TCP starts the SYN wait timer after sending a SYN packet. Within the SYN wait timer if no response is received or the upper limit on TCP connection tries is reached, TCP fails to establish the connection.
· FIN wait timer—TCP starts the FIN wait timer when TCP changes the connection state to FIN_WAIT_2. If no FIN packet is received within the timer interval, TCP terminates the connection. If a FIN packet is received, TCP changes the connection state to TIME_WAIT. If a non-FIN packet is received, TCP restarts the timer, and tears down the connection when the timer expires.
2. Set the TCP SYN wait timer.
3. tcp timer syn-timeout time-value
¡ By default, the TCP SYN wait timer is 75 seconds.
4. Set the TCP FIN wait timer.
5. tcp timer fin-timeout time-value
By default, the TCP FIN wait timer is 675 seconds.
Devices at each end of the TCP connection can calculate the RTT value by using the TCP Timestamps option carried in TCP packets. For security purpose in some networks, you can disable this feature at one end of the TCP connection to prevent intermediate devices from obtaining the Timestamps option information.
This feature takes effect only on new connections that are established after you configure this feature. Existing TCP connections are not affected.
2. Enable the device to encapsulate the TCP Timestamps option in outgoing TCP packets.
tcp timestamps enable
By default, the TCP timestamps option is encapsulated in outgoing TCP packets.
Enabling TCP logging
The logs are sent to the information center of the device. For the logs to be output correctly, you must also configure the information center on the device. For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
To avoid memory consumption caused by log recording, you can use the undo fib log enable command to disable TCP logging.
2. Enable TCP logging.
tcp log enable
By default, TCP logging is disabled.
The snmp-agent trap enable tcp [ md5fail | syn-flood ] * command enables the device to generate SNMP notifications for critical events in the TCP module:
· To enable SNMP notification for MD5 authentication failures, specify the md5fail keyword. When the device fails MD5 authentication during TCP connection establishment, the device generates an SNMP notification.
· To enable SNMP notification for TCP SYN flood attacks, specify the syn-flood keyword. When the device detects a flow-based or interface-based TCP SYN flood attack, the device generates an SNMP notification.
The syn-flood keyword takes effect only after you configure the tcp anti-syn-flood flow-based enable or tcp anti-syn-flood interface-based enable command on the device. For more information about these commands, see IP-based attack prevention commands in Security Command Reference.
· If you specify neither the md5fail keyword nor the syn-flood keyword, SNMP notifications are enabled for both MD5 authentication failures and TCP SYN flood attacks.
The SNMP notifications are sent to the SNMP module. For the SNMP notifications to be sent correctly, you must also configure SNMP. For more information about SNMP configuration, see SNMP configuration in Network Management and Monitoring Configuration Guide.
2. Enable SNMP notifications for TCP events.
By default, SNMP notifications for TCP events are enabled.
The packet following feature can follow and locate the packet processing flow from Layer 2 to Layer 4 in the OSI model. By setting packet following rules, you can trace packets by packet type, input interface, or ACL. When a packet is lost, you can view the statistics and debug information collected by the packet following feature for troubleshooting purposes, such as whether the packet is dropped by the TCP protocol stack or BGP.
To have the packet following feature collect statistics, use one of the following methods:
· Configure packet following rules and execute the debugging packet-follow command to enable debugging the packet following feature.
The device will generate debug information during packet following.
· Configure packet following rules, enable the packet following feature to collect statistics, and then execute the display packet-follow statistics command to view the statistics collected by the packet following feature.
The packet following feature only collects statistics about the packet that match the configured packet following rules. If no packet following rules are configured or no packets successfully match the rules, this feature does not collect statistics.
NOTE: Execute the following commands in user view. |
1. Configure packet following rules. Choose the following options as needed.
¡ Configure a packet following rule for incoming packets.
packet-follow receive match-rule rule-id [ { { ipv4 | ipv6 | l2 | l4 | application } rule-string rule-mask offset } &<1-8> ]
By default, no packet following rules are configured for incoming packets.
¡ Configure an ACL-type packet following rule for incoming packets.
packet-follow receive match-rule rule-id acl { [ ipv6 ] { advanced-acl-number | basic-acl-number } | mac mac-acl-number }
By default, no ACL-type packet following rules are configured for incoming packets.
¡ Configure a packet following rule based on input interfaces.
packet-follow receive interface interface-type interface-number
By default, no packet following rules are configured based on input interfaces.
¡ Configure a packet following rule for outgoing packets.
packet-follow send match-rule rule-id [ { { ipv4 | ipv6 | l4 | application } rule-string rule-mask offset } &<1-8> ]
By default, no packet following rules are configured for outgoing packets.
¡ Configure an ACL-type packet following rule for outgoing packets.
packet-follow send match-rule rule-id acl { [ ipv6 ] { advanced-acl-number | basic-acl-number } | mac mac-acl-number }
By default, no ACL-type packet following rules are configured for outgoing packets.
2. (Optional.) Enable the packet following feature to focus on a packet processing node.
packet-follow care phase [ tag-id ]
By default, the packet following feature does not focus on any packet processing node. It follows all packet processing nodes.
3. Enable the packet following feature to collect statistics.
packet-follow counting [ max-packet-number | no-limit ]
By default, the packet following feature does not collect statistics.
Task |
Command |
Display configuration of the packet following feature. |
display packet-follow configuration [ slot slot-number ] |
Display the statistics collected by the packet following feature. |
display packet-follow statistics [ slot slot-number ] |
Display brief information about RawIP connections. |
display rawip [ slot slot-number ] |
Display detailed information about RawIP connections. |
display rawip verbose [ slot slot-number [ pcb pcb-index ] ] |
Display brief information about TCP connections. |
display tcp [ slot slot-number ] |
Display brief information about TCP proxy. |
display tcp-proxy slot slot-number |
Display the usage of non-well-known ports for TCP proxy. |
display tcp-proxy port-info slot slot-number |
Display detailed information about TCP connections. |
display tcp verbose [ slot slot-number [ pcb pcb-index ] ] |
Display brief information about UDP connections. |
display udp [ slot slot-number ] |
Display detailed information about UDP connections. |
display udp verbose [ slot slot-number [ pcb pcb-index ] ] |
Display IP packet statistics. |
display ip statistics [ slot slot-number ] |
Display TCP traffic statistics. |
display tcp statistics [ slot slot-number ] |
Display UDP traffic statistics. |
display udp statistics [ slot slot-number ] |
Display ICMP statistics. |
display icmp statistics [ slot slot-number ] |
Display statistics about dropped IP packets that contain the source route option. |
display ip option source-route statistics [ slot slot-number ] |
Clear IP packet statistics. |
reset ip statistics [ slot slot-number ] |
Clear the statistics collected by the packet following feature. |
display packet-follow statistics [ receive | send ] [ slot slot-number ] |
Clear TCP traffic statistics. |
reset tcp statistics |
Clear UDP traffic statistics. |
reset udp statistics |
Clear statistics about dropped IP packets that contain the source route option. |
reset ip option source-route statistics [ slot slot-number ] |
