17-BRAS Services Configuration Guide
HomeSupportRoutersH3C SR8800-X Router SeriesConfigure & DeployConfiguration GuidesH3C SR8800-X Routers Configuration Guides-R8630Pxx-6W10017-BRAS Services Configuration Guide
06-User profile configuration
06-User profile configuration 237.76 KB
Configuring user profiles
About user profiles
A user profile defines a set of parameters, such as a QoS policy, for a single user or interface. A user profile can be reused when a user connected to the network on a different interface.
You can use user profiles in the following ways:
·     Authorize a user profile to a user. Each time a user passes authentication, the server sends the device the name of the user profile specified for the user. The device applies the parameters in the user profile to the user. For more information about authorizing a user profile to a user, see AAA in Security Configuration Guide. In this way, user profiles are typically used for the following purposes:
¡     Resource allocation per user—Interface-based traffic policing limits the total amount of bandwidth available to all users that are connected through one interface. However, user-profile-based traffic policing can limit the amount of bandwidth available to a single user.
¡     User access control—When a user passes authentication but the account is overdue, only the resources defined by the ACL permit rules in the free rules are accessible for this user.
·     Apply a user profile to an interface. The user profile takes effect on all traffic on the interface.
About session group profiles and user group profiles
Concepts
Session group profiles and user group profiles are a particular type of user profile for a group of users. It implements QoS traffic control on a per-group basis. A user group can include multiple users and multiple services. For example, you can configure a session group profile or user group profile to limit the total bandwidth for the user group in addition to configuring a user profile for each user.
A session group profile and a user group profile implement the same function. However, the ways they associate user profiles differ.
·     A session group profile is associated with a user profile when they are authorized to the same online user. The online user is subject to both the user profile and session group profile.
·     A user group profile is associated with a user profile by using CLI command. The authentication server authorizes only the user profile to the online user. The online user is subject to both the user profile and the user group profile associated with the user profile.
Online user-based hierarchical scheduling
A user profile limits traffic of a single online user. A session group profile or user group profile limits the total traffic of multiple online users. The following queue types are available for hierarchical scheduling:
·     Traffic queue—Caches packets of different priorities of a user. You can apply a queue scheduing profile to a user profile to schedule the packets of a traffic queue.
·     User queue—Schedules packets of traffic queues by using a queue scheduling profile applied to the user profile, and rate limits the packets of the user queue by using QoS policy and traffic policing settings.
·     User group queue—Schedules packets of user queues by using a queue scheduling profile applied to the user group profile or session group profile, and rate limits the packets of the user group queue by using QoS policy, traffic policing, traffic shaping settings.
Traffic queues are physical queues and have cache units. User queues and user group queues are virtual queues that participate in hierarchical scheduling and do not have cache units.
Figure 1 Hierarchical scheduling
Interface-based hierarchical scheduling
This feature can achieve queue scheduling for a specific service under a subinterface, limit the traffic rate of a single subinterface, and limit the total traffic rate of multiple subinterfaces, meeting the needs of fine-grained service management.
As shown in , configure interface-based hierarchical scheduling as follows:
1.     Apply user profiles to different subinterfaces (A.1 and A.2) of the same interface (A) and specify the same user group queue name. Alternatively, you can apply user profiles to subinterfaces without specifying the same user group queue name.
2.     In the applied user profiles, use the qos user-queue command to specify the same user group profile, and then configure rate-limiting parameters or specify queue scheduling profiles.
The operating mechanism of interface-based hierarchical scheduling is as follows:
3.     Different service traffic enters the traffic queues under the interface based on priority mapping rules. For traffic queues of different subinterfaces, the queue scheduling profile specified in the qos user-queue command is executed on each subinterface.
4.     Different traffic queues on a subinterface enter the user queue. Each subinterface logically corresponds to a user queue, and the traffic in the user queue is rate limited according to the rate-limiting parameters specified in the qos user-queue command.
5.     Different user queues on multiple subinterfaces share a single user group queue. The user group queue is rate limited according to the user group profile specified in the qos user-queue command.
Figure 2 Interface-based hierarchical scheduling
Restrictions and guidelines: User profile configuration
In SDN-WAN system operating mode, the system does not support authorizing user profiles.
For more information about system operating modes, see device management in Fundamentals Configuration Guide.
In standard system operating mode, only the following cards support authorizing user profiles:
Card category
Cards
CEPC
CEPC-XP4LX, CEPC-XP24LX, CEPC-XP48RX, CEPC-CP4RX, CEPC-CP4RX-L
CSPEX
CSPEX-1304X, CSPEX-1304S, CSPEX-1404X, CSPEX-1404S, CSPEX-1502X, CSPEX-1504X, CSPEX-1504S, CSPEX-1602X, CSPEX-1804X, CSPEX-1512X, CSPEX-1612X, CSPEX-1812X, CSPEX-1802XB, CSPEX-1802X, CSPEX-1812X-E, CSPEX-2304X-G, CSPEX-2304X-LG
SPE
RX-SPE200, RX-SPE200-E
Only the following cards support applying a user profile to an interface:
Card category
Cards
CEPC
CEPC-XP4LX, CEPC-XP24LX, CEPC-XP48RX, CEPC-CP4RX, CEPC-CP4RX-L, CEPC-CQ8L, CEPC-CQ16L1, CEPC-DQ2L1-G
CSPC
CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E
CSPEX
CSPEX-1304X, CSPEX-1304S, CSPEX-1404X, CSPEX-1404S, CSPEX-1502X, CSPEX-1504X, CSPEX-1504S, CSPEX-1602X, CSPEX-1804X, CSPEX-1512X, CSPEX-1612X, CSPEX-1812X, CSPEX-1802XB, CSPEX-1802X, CSPEX-1812X-E, CSPEX-2304X-G, CSPEX-2304X-LG, CSPEX-2314X-G, CSPEX-2314X-G1, CSPEX-2314X-G2, CSPEX-2612X-E, CSPEX-1104-E
SPE
Only the following cards support applying a user profile to a PW:
Card category
Cards
CEPC
CSPEX
SPE
RX-SPE200-E
Because a session group profile and a user group profile implement the same function, a user profile cannot be associated with both a session group profile and a user group profile.
You can configure traffic regulation, QoS policy, traffic scheduling, queue scheduling profile, connection limits, and auth-free rule for a user profile as required.
Prerequisites for user profile
If a user profile is applied to an interface, no authentication settings are required.
If a user profile works with authentication, you must configure authentication settings for a user profile. For information about supported authentication methods, see the configuration guides for the related authentication modules.
Configuring a user profile
For information about CAR policies and QoS policies, see ACL and QoS Configuration Guide.
For information about connection limits, see "Configuring connection limits."
The system supports authorizing users profiles to users and supports the following settings in the user profile:
·     Traffic regulation.
·     QoS policy.
·     Traffic scheduling.
·     Queue scheduling profile for user queues.
·     Connection limits.
·     Auth-free rule.
The system supports applying user profiles to interfaces and supports only rate regulation and queue scheduling profile settings in the user profile.
2.     Create a user profile and enter user profile view.
user-profile profile-name
3.     Configure traffic regulation. Choose the options to configure as needed:
If the qos user-queue qmprofile command is used for traffic scheduling, to ensure successful traffic scheduling, you can only use the qos user-queue command to configure traffic regulation.
¡     Configure a CAR policy for the user profile.
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
By default, no CAR policy is configured for a user profile.
This command is available only for the following cards:
Card category
Cards
CEPC
CSPEX
SPE
¡     Configure rate limiting for the user profile.
qos user-queue { cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ queue-length queue-length ] } * outbound
qos user-queue { cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ queue-length queue-length ] } * outbound
qos user-queue { cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] } inbound
qos user-queue { cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] } inbound
By default, rate limiting is not configured for a user profile.
The queue-length queue-length option is supported only in standard system operating mode.
When AAA authorizes a user profile, this command takes effect only on the following cards:
Card category
Cards
CEPC
CSPEX
SPE
If a user profile is applied to the inbound direction of an interface, this command takes effect only on the following cards:
Card category
Cards
CEPC
CSPEX
SPE
If a user profile is applied to the outbound direction of an interface, this command takes effect only on the following cards:
Card category
Cards
CEPC
CSPC
CSPEX
SPE
4.     Apply an existing QoS policy to the user profile.
By default, no QoS policy is applied to a user profile.
This command is not available in SDN-WAN system operating mode.
In standard system operating mode, this command is available only for the following cards:
Card category
Cards
CSPEX
SPE
RX-SPE200-E
5.     Configure queue scheduling for user queues.
¡     Specify a queue for session packets that use the user profile.
qos queue { queue-id | queue-name }
By default, no queue for session packets is specified for a user profile.
Session packets are scheduled based on the scheduling priority of the specified queue, implementing session-based congestion management.
Card category
Cards
CEPC
CSPEX
SPE
¡     Set the outbound weight value for the user profile.
qos weight weight-value outbound
By default, no outbound weight value is set for a user profile.
Bandwidth resources are allocated based on the weight value.
Card category
Cards
CEPC
CSPEX
SPE
6.     Specify an existing queue scheduling profile for the user profile.
qos user-queue qmprofile qmprofile-name { inbound | outbound }
By default, no scheduling profile is specified for a user profile.
Table 1 Card information
Card category
Cards
CEPC
CSPEX
CSPEX-1304X, CSPEX-1304S, CSPEX-1404X, CSPEX-1404S, CSPEX-1502X, CSPEX-1504X, CSPEX-1504S, CSPEX-1602X, CSPEX-1804X, CSPEX-1512X, CSPEX-1612X, CSPEX-1812X, CSPEX-1502XA, CSPEX-1802X, CSPEX-1812X-E, CSPEX-2304X-G
SPE
RX-SPE200 RX-SPE200-E
For a user profile applied to an interface:
¡     In a user profile applied to the inbound direction of an interface, this command takes effect only on the following cards:
Table 2 Card information
Card category
Cards
CEPC
CSPEX
SPE
¡     In a user profile applied to the outbound direction of an interface, this command takes effect only on the following cards:
Table 3 Card information
Card category
Cards
CEPC
CSPC
CSPEX
SPE
7.     Configure connection limits.
¡     Set the maximum number of user connections.
connection-limit amount amount
By default, the number of user connections is not limited for a user profile.
¡     Set the maximum connection establishment rate.
connection-limit rate rate
By default, the connection establishment rate is not limited for a user profile.
For support of cards for user profile-based connection limits, see connection limit configuration in BRAS Services Configuration Guide.
8.     Create a user profile free rule.
free-rule acl [ ipv6 ] { acl-number | name acl-name }
By default, no user profile free rule is configured for a user profile.
This command is supported only in standard system operating mode.
Configuring a session group profile
This feature is not available in SDN-WAN system operating mode.
In standard system operating mode, this feature is available only for the following cards:
Card category
Cards
CEPC
CSPEX
SPE
2.     Enter interface view.
3.     Identify a session group on the interface.
qos session-group identify { customer-vlan | service-vlan | customer-service-vlan | subscriber-id }
By default, no session group is identified on the interface.
The interface identifies packets according to the specified method and classifies packets with the same characteristics to the same user group.
4.     Return to system view.
5.     Create a session group profile and enter session group profile view.
user-profile profile-name type session-group
You can use the command to enter the view of an existing session group profile.
6.     Configure traffic regulation.
¡     Configure GTS for the session group profile.
qos gts { any | queue queue-id } cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ queue-length queue-length ]
qos gts { any | queue queue-id } cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ queue-length queue-length ]
By default, no GTS is configured for a session group profile.
7.     Apply an existing queue scheduling profile to the session group profile.
By default, no queue scheduling profile is applied to a session group profile.
For information about GTS and queue scheduling profiles, see ACL and QoS Configuration Guide.
Configuring a user group profile
After you execute the qos session-group identify command on an interface, the system can identify the user group to which users in the same home belong. When authorizing user profiles for different users, you can use the following methods to limit the bandwidth available to all users in the same home:
·     Use AAA to limit the total traffic rate for all users in the same home through RADIUS subattributes 114, 115, 116, and 117. For information about RADIUS subattributes, see AAA in BRAS Services Configuration Guide.
·     Use the qos user-queue user-group-profile command to associate the user profiles with the same user group profile.
If you associate the user profiles for users from the same home with different user group profiles, the total bandwidth available to the users will change among the bandwidth limits configured for the user group profiles. Suppose you associate user profile A and user profile B with user group profile A and with user group profile B, respectively. When user A first comes online, the total bandwidth for user A and user B is the bandwidth limit configured for user group profile A. When user B comes online later, the total bandwidth for user A and user B changes to the bandwidth limit configured for user group profile B. If user A goes offline and then comes online, the total bandwidth for user A and user B changes back to the bandwidth limit configured for user group profile A.
Card category
Cards
CEPC
CSPEX
SPE
5.     Create a user group profile and enter user group profile view.
user-group-profile profile-name
¡     Configure GTS for the user group profile.
qos gts [ inbound ] any cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ queue-length queue-length ]
qos gts [ inbound ] any cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ queue-length queue-length ]
By default, no GTS is configured for a user group profile.
If you have configured rate limiting by using the qos user-queue command for a user profile and associated the user profile with a user group profile, the queue-length queue-length option in GTS cannot take effect for the user group profile.
7.     Apply an existing queue scheduling profile to the user group profile.
By default, no queue scheduling profile is applied to a user group profile.
8.     Set the weight value for the user group profile.
qos weight weight-value { inbound | outbound }
By default, no outbound weight value is set for a user group profile.
Bandwidth resources are allocated among user group profiles based on the weight value.
9.     Return to system view.
10.     Enter user profile view.
11.     Associate the user profile with the user group profile.
qos user-queue user-group-profile user-group-profile-name outbound
By default, a user profile is not associated with any user group profile.
Applying a user profile to an interface
A user profile applied to an interface supports only traffic policing, rate limiting, and queue scheduling profiles.
The following rules apply if you specify a direction when applying a user profile to an interface:
·     The settings in the user profile take effect only if the direction of the settings is the same as the application direction.
·     Only one user profile can be applied to the same direction.
The following rules apply if you do not specify a direction when applying a user profile to an interface:
·     The settings in the user profile take effect in the direction as they are configured.
·     No other user profile can be applied to the interface, regardless of whether it is applied with a direction.
This feature is mutually exclusive with any of the following configurations:
·     Bind the interface to a VSI by using the xconnect vsi command.
·     Bind the interface to a cross-connect by using the ac interface command.
·     Enable IPoE on the interface and configure an IPoE access mode for users by using the ip subscriber enable command.
If a user profile containing a CAR policy is applied to an interface:
·     The CAR policy is mutually exclusive with traffic policing configured on an interface by using the qos car command.
·     The CAR policy on a main interface does not take effect on its subinterfaces.
·     The CAR policy does not take effect on member ports of an aggregation group.
·     The CAR policy supports only the single rate two color algorithm. If you configure the pir peak-information-rate option, tokens are put into the token bucket at the PIR.
If a user profile containing a queue scheduling profile is applied to an interface, the maximum bandwidth in the queue scheduling profile can take effect on the CSPEX-1104-E, CSPC-GE16XP4L-E, CSPC-GE24L-E, and CSPC-GP24GE8XP2L-E cards in addition to the cards in Configuring a user profile and Configuring a user profile.
3.     Apply a user profile to the interface.
qos apply user-profile profile-name [ inbound | outbound ]
By default, no user profile is applied to an interface.
Configuring interface-based hierarchical scheduling
If you want to apply individual rate limiting to multiple subinterfaces of an interface and then enforce unified rate limiting, this can be achieved through hierarchical QoS scheduling with a shared user group queue. For detailed information about hierarchical QoS scheduling, see the qos user-queue command. The configuration must meet the following requirements:
1.     Use the qos apply user-profile command to apply user profiles to different subinterfaces of an interface.
2.     Use the qos user-queue command to configure rate-limiting parameters or specify queue scheduling profiles in these user profiles and specify the same user group profile.
3.     When you apply user profiles to subinterfaces, specify the same user group queue name or do not specify a user group queue name.
If the user profile applied to a subinterface already includes the group group-name parameter, this parameter cannot be modified directly. To modify the user group name, first use the undo qos apply user-profile command to remove the user profile from the subinterface, then reapply the user profile to the subinterface with the new user group name.
You can use the display user-profile hierarchical topology interface command to view the hierarchical QoS scheduling topology information for user profiles applied to interfaces.
If you configure hierarchical QoS scheduling, do not configure other QoS features (for example, rate limiting) on the same subinterface. Conflicts might prevent QoS features from taking effect.
3.     Configure scheduling parameters for traffic queues, user queues, and user group queues. Choose one option as needed:
¡     Configure rate limit parameters, specify a queue scheduling profile, and associate a user group profile.
qos user-queue cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ queue-length queue-length ] { inbound | outbound }
qos user-queue cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ queue-length queue-length ] { inbound | outbound }
qos user-queue user-group-profile user-group-profile-name { inbound | outbound }
¡     Configure rate limit parameters and associate a user group profile.
¡     Specify a queue scheduling profile and associate a user group profile.
If you create multiple user profiles, associate them with the same user group profile to ensure that the subinterfaces applied with the user profiles share the same user group queue.
4.     Set the weight value for the user profile.
5.     Return to system view.
6.     Enter subinterface view.
interface interface-type interface-number.subnumber
7.     Apply a user profile to the subinterface.
qos apply user-profile profile-name [ inbound | outbound ] [ group group-name ]
To implement hierarchical scheduling, specify the same group name when you apply user profiles to multiple subinterfaces of an interface.
Applying a user profile to a PW
You can apply a user profile to a PW to perform rate limiting and queue scheduling.
·     You can use the qos user-queue command to configure rate limiting for a user profile. Only the single rate two color mechanism is supported.
·     You can use the qos user-queue qmprofile command to specify a queue scheduling profile for a user profile. In the queue scheduling profile, do not configure a maximum allowed bandwidth in percentage, a minimum guaranteed bandwidth in percentage, or the maximum bandwidth allowed for a group.
If you configure both this feature and traffic policing (qos car) for a PW on the same card, only this feature takes effect.
You can apply only one user profile to a PW. The settings in the user profile take effect only if the direction of the settings is the same as the application direction.
Applying a user profile to a VSI LDP PW
2.     Enter VSI view.
vsi vsi-name [ hub-spoke ]
3.     Specify LDP signaling for PWs, and enter VSI LDP signaling view.
pwsignaling ldp
By default, no PW signaling protocol is specified.
4.     Configure an LDP PW, and enter VSI LDP PW view.
peer ip-address [ pw-id pw-id ] [ dci | hub | ignore-standby-state | no-split-horizon | pw-class class-name | tunnel-policy tunnel-policy-name ] *
5.     Apply a user profile to the VSI LDP PW.
qos apply user-profile profile-name outbound
By default, no user profile is applied to a VSI LDP PW.
Applying a user profile to a VSI static PW
2.     Enter VSI view.
3.     Specify static signaling for PWs, and enter VSI static view.
pwsignaling static
4.     Configure a static PW and enter VSI static PW view.
peer ip-address [ pw-id pw-id ] [ in-label label-value out-label label-value ] [ dci | hub | no-split-horizon | pw-class class-name | tunnel-policy tunnel-policy-name ] *
5.     Apply a user profile to the VSI static PW.
By default, no user profile is applied to a VSI static PW.
Applying a user profile to a cross-connect PW
2.     Enter cross-connect group view.
xconnect-group group-name
3.     Enter cross-connect view.
connection connection-name
4.     Configure an LDP or static PW and enter cross-connect PW view.
¡     Configure an LDP PW and enter cross-connect PW view.
peer ip-address pw-id pw-id [ ignore-standby-state ] [ admin | pw-class class-name | tunnel-policy tunnel-policy-name ] *
¡     Configure a static PW and enter cross-connect PW view.
peer ip-address pw-id pw-id in-label label-value out-label label-value [ admin | pw-class class-name | tunnel-policy tunnel-policy-name ] *
5.     Apply a user profile to the cross-connect PW.
By default, no user profile is applied to a cross-connect PW.
Applying a user profile to an auto-discovery VSI LDP signaling PW
2.     Enter VSI view.
3.     Configure the VSI to automatically discover neighbors through BGP and enter auto-discovery VSI view.
auto-discovery bgp
By default, a VSI does not automatically discover neighbors through BGP.
4.     Use LDP to create a PW to an automatically discovered remote PE and enter auto-discovery VSI LDP signaling view.
signaling-protocol ldp
By default, no signaling protocol is specified.
5.     (Optional.) Configure an auto-discovery VSI LDP signaling PW and enter its view.
peer ip-address
By default, no PWs exist for auto-discovery VSI LDP signaling PW.
6.     Apply a user profile to the auto-discovery VSI LDP signaling PW.
By default, no user profile is applied to an auto-discovery VSI LDP signaling PW.
Applying a user profile to an auto-discovery VSI BGP signaling PW
2.     Enter VSI view.
auto-discovery bgp
4.     Use BGP to create a PW to an automatically discovered remote PE and enter auto-discovery VSI LDP signaling view.
signaling-protocol bgp
5.     (Optional.) Configure an auto-discovery VSI BGP signaling PW and enter its view.
peer ip-address
By default, no PWs exist for auto-discovery VSI BGP signaling PW.
6.     Apply a user profile to the auto-discovery VSI BGP signaling PW.
By default, no user profile is applied to an auto-discovery VSI BGP signaling PW.
Display and maintenance commands for user profiles
Display the configuration and traffic policing statistics for a user profile applied to an interface.
In standalone mode:
display user-profile interface [ interface-type interface-number ] [ slot slot-number [ cpu cpu-number ] ] [ inbound | outbound ]
In IRF mode:
display user-profile interface [ interface-type interface-number ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ inbound | outbound ]
Display the configuration and statistics for a user profile applied to a PW.
In standalone mode:
display user-profile l2vpn-pw [ vsi vsi-name peer ip-address [ pw-id pw-id | remote-site-id remote-site-id ] | xconnect-group group-name connection connection-name peer ip-address pw-id pw-id ] { outbound } [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display user-profile l2vpn-pw [ vsi vsi-name peer ip-address [ pw-id pw-id | remote-site-id remote-site-id ] | xconnect-group group-name connection connection-name peer ip-address pw-id pw-id ] { outbound } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Display configuration and online user information for the specified user group profile or all user group profiles.
In standalone mode:
display user-group-profile [ name profile-name ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display user-group-profile [ name profile-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Display configuration and online user information for the specified user profile or all user profiles.
In standalone mode:
display user-profile [ session-group ] [ name profile-name ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display user-profile [ session-group ] [ name profile-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Display the hierarchical scheduling configuration for an interface.
display user-profile hierarchical topology interface interface-type interface-number [ inbound | outbound ]
Clear the traffic policing statistics for a user profile applied to an interface.
reset user-profile interface [ interface-type interface-number ] [ inbound | outbound ]
User profile configuration examples
Example: Configuring hierachical scheduing for multiple users in the same user group
As shown in Figure 3, the RADIUS server performs authentication, authorization,a nd accounting for the home user group accessing the network.
Configure common user profiles and a user group profile to meet the following requirements:
·     Limit the total traffic rate to 100 Mbps for all users in the home user group.
·     Limit the traffic rate to 40000 kbps for User A.
·     Limit the traffic rate to 80000 kbps for User B.
·     Limit the traffic rate to 20000 kbps for User C.
Figure 3 Network diagram
Table 4 Interface label and interface name mappings
Interface label
Interface name
Interface1
Ten-GigabitEthernet3/1/1
1.     Configure the RADIUS server:
a.     Authorize user profiles a, b, and c for User A, User B, and User C. (Details not shown.)
b.     Specify user group profile ugp for each user. (Details not shown.)
2.     Configure the device:
# Create a queue scheduling profile named qm.
[Device] qos qmprofile qm
[Device-qmprofile-qm] quit
# Identify a session group on an interface.
[Device] interface ten-gigabitethernet 3/1/1
[Device-Ten-GigabitEthernet3/1/1] qos session-group identify service-vlan
This operation will affect online users from now on. Continue? [Y/N]:y
[Device-Ten-GigabitEthernet3/1/1] quit
# Create a user group profile named ugp.
[Device] user-group-profile ugp
# Apply queue scheduling profile named qm to user group profile named ugp.
[Device-user-group-profile-ugp] qos apply qmprofile qm
# Configure GTS for all traffic, with the CIR as 100000 kbps.
[Device-user-group-profile-ugp] qos gts any cir 100000
[Device-user-group-profile-ugp] qos gts inbound any cir 100000
[Device-user-group-profile-ugp] quit
# Create a user profile named a, configure CAR (CIR 40000 kbps) for it, and associate it with user profile group ugp.
[Device] user-profile a
[Device-user-profile-a] qos car inbound any cir 40000
[Device-user-profile-a] qos car outbound any cir 40000
[Device-user-profile-a] qos user-queue user-group-profile ugp inbound
[Device-user-profile-a] qos user-queue user-group-profile ugp outbound
[Device-user-profile-a] quit
# Create a user profile named b, configure CAR (CIR 80000 kbps) for it, and associate it with user profile group ugp.
[Device] user-profile b
[Device-user-profile-b] qos car inbound any cir 80000
[Device-user-profile-b] qos car outbound any cir 80000
[Device-user-profile-b] qos user-queue user-group-profile ugp inbound
[Device-user-profile-b] qos user-queue user-group-profile ugp outbound
[Device-user-profile-b] quit
# Create a user profile named c, configure CAR (CIR 20000 kbps) for it, and associate it with user profile group ugp.
[Device] user-profile c
[Device-user-profile-c] qos car inbound any cir 20000
[Device-user-profile-c] qos car outbound any cir 20000
[Device-user-profile-c] qos user-queue user-group-profile ugp inbound
[Device-user-profile-c] qos user-queue user-group-profile ugp outbound
[Device-user-profile-c] quit
# Verify that the user profiles are correctly configured and are effective on online users.
<Device> display user-profile
  User Profile: a
    Direction: Inbound
      Committed Access Rate:
        CIR 40000 (kbps), CBS 2500000 (Bytes), EBS 0 (Bytes)
      User queue:
        User group profile: ugp
    Direction: Outbound
      User queue:
  User Profile: b
    Direction: Inbound
        CIR 80000 (kbps), CBS 5000000 (Bytes), EBS 0 (Bytes)
      User queue:
    Direction: Outbound
      User queue:
  User Profile: c
    Direction: Inbound
        CIR 20000 (kbps), CBS 1250000 (Bytes), EBS 0 (Bytes)
      User queue:
    Direction: Outbound
      User queue:
# Verify that user group profile upg is correctly configured and is active for users.
<Device> display user-group-profile name ugp
  User Group Profile: ugp
    Direction: Inbound
      General Traffic Shaping:
        If-match any:
        CIR 100000 (kbps), CBS 6250000 (Bytes), EBS 0 (Bytes)
    Direction: Outbound
        If-match any:
      QMProfile: qm
