13-Security Configuration Guide
HomeSupportRoutersH3C SR8800-X Router SeriesConfigure & DeployConfiguration GuidesH3C SR8800-X Routers Configuration Guides-R8630Pxx-6W10013-Security Configuration Guide
02-Password control configuration
02-Password control configuration 171.45 KB
Configuring password control
About password control
Password control allows you to implement the following features:
·     Manage login and super password setup, expirations, and updates for device management users.
·     Control user login status based on predefined policies.
Device management users are one type of local users. For more information about local users, see AAA configuration in BRAS Services Configuration Guide.  For information about super passwords, see RBAC in Fundamentals Configuration Guide.
Password setting
Minimum password length
You can define the minimum length of user passwords. The system rejects the setting of a password that is shorter than the configured minimum length.
Password composition policy
A password can be a combination of characters from the following types:
·     Uppercase letters A to Z.
·     Lowercase letters a to z.
·     Digits 0 to 9.
·     Special characters in Table 1.
Table 1 Special characters
Character name
Symbol
Character name
Symbol
Ampersand sign
Apostrophe
Asterisk
At sign
Back quote
Back slash
Blank space
N/A
Caret
Colon
Comma
Dollar sign
Dot
Equal sign
Exclamation point
Left angle bracket
Left brace
Left bracket
Left parenthesis
Minus sign
Percent sign
Plus sign
Pound sign
Quotation marks
Right angle bracket
Right brace
Right bracket
Right parenthesis
Semi-colon
Slash
Tilde
Underscore
_
Vertical bar
Depending on the system's security requirements, you can set the minimum number of character types a password must contain and the minimum number of characters for each type, as shown in Table 2.
Table 2 Password composition policy
Password combination level
Minimum number of character types
Minimum number of characters for each type
Level 1
One
One
Level 2
Two
One
Level 3
Three
One
Level 4
Four
One
In non-FIPS mode, all the combination levels are available for a password. In FIPS mode, only the level 4 combination is available for a password.
When a user sets or changes a password, the system checks if the password meets the combination requirement. If it does not, the operation fails.
Password complexity checking policy
A less complicated password is more likely to be cracked, such as a password containing the username or repeated characters. For higher security, you can configure a password complexity checking policy to ensure that all user passwords are relatively complicated. When a user configures a password, the system checks the complexity of the password. If the password is complexity-incompliant, the configuration will fail.
You can apply the following password complexity requirements:
·     A password cannot contain the username, the reverse of the username, or part of the username or the reverse of the username. For example, if the username is abc, a password such as abc982, 2cba, or ab is not complex enough.
·     A minimum of three identical consecutive characters is not allowed. For example, password a111 is not complex enough.
Password updating and expiration
Password updating
This feature allows you to set the minimum interval at which users can change their passwords. A user can only change the password once within the specified interval.
The minimum interval does not apply to the following situations:
·     A user is prompted to change the password at the first login.
·     The password aging time expires.
Password expiration
Password expiration imposes a lifecycle on a user password. After the password expires, the user needs to change the password.
The system displays an error message for a login attempt with an expired password. The user is asked to provide a new password. The new password must be valid, and the user must enter exactly the same password when confirming it.
Telnet users, SSH users, and console users can change their own passwords. FTP users must have their passwords changed by the administrator. Whether NETCONF over SOAP, RESTful, or gRPC (dial-in mode) users can change passwords depends on the support of third-party clients.
Early notice on pending password expiration
When a user logs in, the system checks whether the password will expire in a time equal to or less than the specified notification period. If so, the system notifies the user when the password will expire and provides a choice for the user to change the password.
·     If the user sets a new valid password, the system records the new password and the setup time.
·     If the user does not or fails to change the password, the system allows the user to log in by using the current password until the password expires.
Login with an expired password
You can allow a user to log in a certain number of times within a period of time after the password expires. For example, if you set the maximum number of logins with an expired password to 3 and the time period to 15 days, a user can log in three times within 15 days after the password expires.
Password history
This feature allows the system to store passwords that a user has used. When a user changes the password, the system compares the new password with the current password and those stored in the password history records. The new password must be different from the current one and those stored in the history records by a minimum of four different characters. Otherwise, the system will display an error message, and the password will not be changed.
You can set the maximum number of history password records for the system to maintain for each user. When the number of history password records exceeds the setting, the most recent record overwrites the earliest one.
Current login passwords are not stored in the password history for device management users. Device management users have their passwords saved in cipher text, which cannot be recovered to plaintext passwords.
User login control
First login
By default, if the global password control feature is enabled, users must change the password at first login before they can access the system. In this situation, password changes are not subject to the minimum password update interval. If it is not necessary for users to change the password at first login, disable the password change at first login feature.
Password control blacklist
The device can restrict abnormal users from login by recording the information of users who have failed authentication and maintaining the locking status of entries in the password control blacklist.
If a user fails authentication, the system adds the user to the password control blacklist. The password control blacklist supports the following users:
·     FTP users.
·     VTY, NETCONF over SOAP, RESTful, or gRPC (dial-in mode) users.
·     Users that log in to the device through console ports.
Nonexistent users will not be blacklisted if they fail authentication.
The device supports the following recording modes for adding the user information to the blacklist for users failing authentication:
·     Username only—Adds only usernames to the blacklist. In this mode, a user account matches a blacklist entry as long as the username matches the entry.
·     Username and IP address—Adds both usernames and IP addresses to the blacklist. In this mode, a user account matches a blacklist entry only when both the username and the login IP address match the entry.
The device will create a blacklist entry for each IP address for a user account when the following conditions are both met:
·     Both usernames and IP addresses are added to the password control blacklist.
·     A user uses the same user account to log in to the device from different IP addresses and fails the logins.
When the maximum number of blacklist entries for the user account is reached, a blacklist entry for a new IP address of the user account will overwrite the earliest blacklist entry for the user account.
Login attempt limit
Limiting the number of consecutive login failures can effectively prevent password guessing.
When the user fails the maximum number of consecutive attempts, login attempt limit limits the user and user account in any of the following ways:
·     Locks the user account permanently. No users can use this account to log in to the device unless the account is manually removed from the password control blacklist.
·     Allows the user to continue using the user account. The user account is removed from the password control blacklist when the user uses this account to successfully log in to the device.
·     Locks the user account for a period of time.
The user can use the account to log in when either of the following conditions exists:
¡     The locking timer expires.
¡     The account is manually removed from the password control blacklist before the locking timer expires.
Maximum account idle time
You can set the maximum account idle time for user accounts. When an account is idle for this period of time since the last successful login, the account becomes invalid.
Login control with a weak password
The system checks for weak passwords for Telnet and SSH management users. A password is weak if it does not meet the following requirements:
·     Password composition restriction.
·     Minimum password length restriction.
·     Password complexity checking policy.
By default, the system displays a message about a weak password but does not force the user to change it. To improve the device security, you can enable the mandatory weak password change feature, which forces the users to change the identified weak passwords. The users can log in to the device only after their passwords meet the password requirements.
Weak password library check
A weak password library contains common, easily-guessed, or simple login passwords. After you activate a weak password library, the device prevents users from setting vulnerable common passwords. This reduces the risk of account compromise.
Weak passwords are stored in a .txt file with one password per line, following these restrictions and guidelines:
·     Each line of weak passwords cannot start with a pound sign (#). Lines starting with a pound sign (#) are considered comment lines.
·     Weak passwords support all visible characters except question marks (?), whose ASCII codes range from 32 to 126.
If the weak password library is activated, the system will identify whether a device management user password is in the weak password library during login as follows:
·     If a Telnet user, SSH user, or console user attempts to log in to the device with a password in the library, the system will prompt the user to change the password, but will not enforce the password change. If the user chooses not to change the password or fails to change the password, the user can still use the weak password to log in to the device.
·     If an FTP user attempts to log in to the device with a password in the library, the system will allow the FTP user to log in. However, the administrator is recommended to reset the password for the user and advise the user to log in again with a new password to improve account security.
The passwords in the weak password library will not affect users that have logged in, but the system will still prompt the users to change their passwords upon their next login after a logout.
Password not displayed in any form
For security purposes, nothing is displayed when a user enters a password.
Logging
The system generates a log each time a user changes its password successfully or is added to the password control blacklist because of login failures.
Restrictions and guidelines: Password control configuration
IMPORTANT
IMPORTANT:
To successfully enable the global password control feature and allow device management users to log in to the device, make sure the device have sufficient storage space.
The password control features can be configured in several different views, and different views support different features. The settings configured in different views or for different objects have the following application ranges:
·     Settings for super passwords apply only to super passwords.
·     Settings in local user view apply only to the password of the local user.
·     Settings in user group view apply to the passwords of the local users in the user group if you do not configure password policies for these users in local user view.
·     Global settings in system view apply to the passwords of the local users in all user groups if you do not configure password policies for these users in both local user view and user group view.
For local user passwords, the settings with a smaller application scope have higher priority. The system prefers to use the non-default setting in local user view for a local user.
·     If the default setting is configured for the local user, the system uses the non-default setting for the user group to which the local user belongs.
·     If the default setting is configured for the user group, the system uses the global setting.
Password control tasks at a glance
To configure password control, perform the following tasks:
1.     Enabling password control
2.     (Optional.) Setting global password control parameters
3.     (Optional.) Setting user group password control parameters
4.     (Optional.) Setting local user password control parameters
5.     (Optional.) Setting super password control parameters
6.     (Optional.) Enabling SNMP notifications
For device management users, enabling global password control is a prerequisite for password control functions to take effect except for the following functions:
·     Password composition policy.
·     Minimum password length.
·     Username checking.
For a specific password restriction setting (password expiration or password history management) to take effect, make sure you enable both the global password control feature and the specific password restriction.
For network access users, a password control function can take effect only when the global password control feature is enabled.
After global password control is enabled, follow these restrictions and guidelines:
·     You cannot display the password and super password configurations for device management users by using the corresponding display commands. However, the configuration for network access user passwords can be displayed.
·     The password configured for device management users must contain a minimum of four different characters.
·     To ensure correct function of password control, configure the device to use NTP to obtain the UTC time. After global password control is enabled, password control will record the UTC time when the password is set. The recorded UTC time might not be consistent with the actual UTC time due to power failure or device reboot. The inconsistency will cause the password expiration feature to malfunction. For information about NTP, see Network Management and Monitoring Configuration Guide.
·     The device automatically generates a .dat file and saves the file to the storage media such as a flash or CF card. The file is used to record authentication and login information of the local users. Do not manually delete or modify the file.
2.     Enable the global password control feature.
password-control enable
By default, the global password control feature is disabled.
3.     (Optional.) Enable a password restriction feature.
password-control { aging | composition | history | length } enable
By default, all four password restriction features are enabled.
The global password control parameters in system view apply to all device management local users.
The password aging time, minimum password length, and password composition policy can be configured in system view, user group view, and local user view. The password settings with a smaller application scope have higher priority. For local users, password settings configured in local user view have the highest priority, and global settings in system view have the lowest priority.
The global password control feature enables the system to record history passwords. When the number of history password records of a user reaches the maximum number, the newest history record overwrites the earliest one. To delete the existing history password records, use one of the following methods:
·     Use the undo password-control enable command to disable the password control feature globally.
·     Use the reset password-control history-record command to clear the passwords manually.
The password-control login-attempt command takes effect immediately and can affect the users already in the password control blacklist. If the user information items to add to the password control blacklist change, the system will clear the password control blacklist and restart the recording. Other password control configurations do not take effect on users that have been logged in or passwords that have been configured.
2.     Configure password settings.
¡     Set the minimum password length.
The default setting is 10 characters.
¡     Configure the password composition policy.
By default, a password must contain a minimum of two character types and a minimum of one character for each type.
¡     Configure the password complexity checking policy.
By default, username checking is enabled but repeated character checking is disabled.
¡     Set the maximum number of history password records for each user.
password-control history max-record-number
The default setting is 4.
3.     Configure password updating and expiration.
¡     Set the minimum password update interval.
password-control update interval interval
The default setting is 24 hours.
¡     Set the password aging time.
The default setting is 90 days.
¡     Set the number of days during which a user is notified of the pending password expiration.
The default setting is 7 days.
¡     Set the maximum number of days and maximum number of times that a user can log in after the password expires.
By default, a user can log in three times within 30 days after the password expires.
4.     Configure user login control.
¡     Configure the login attempt limit.
By default, the maximum number of login attempts is 3 and a user failing to log in after the specified number of attempts must wait for 1 minute before trying again.
¡     Add only usernames to the password control blacklist for users failing authentication.
password-control blacklist user-info username-only
By default, both usernames and IP addresses are added to the password control blacklist when the users fail authentication.
¡     Set the maximum number of blacklist entries for a user account.
password-control per-user blacklist-limit max-number
By default, the maximum number of blacklist entries for a user account is 32.
¡     Set the maximum account idle time.
If a user account is idle for this period of time, the account becomes invalid and can no longer be used to log in to the device. To disable the account idle time restriction, set the idle time value to 0.
¡     Disable the password change at first login feature.
undo password-control change-password first-login enable
By default, the password change at first login feature is enabled.
¡     Enable mandatory weak password change.
password-control change-password weak-password enable
By default, the mandatory weak password change feature is disabled.
¡     Add a user password the password control blacklist.
password-control password-blacklist string
By default, no user password is added to the password control blacklist.
¡     Activate the weak password library.
password-control weak-password-file activate filename
¡     Deactivate the weak password library.
password-control weak-password-file deactivate
2.     Create a user group and enter its view.
user-group group-name
For information about how to configure a user group, see AAA configuration in BRAS Services Configuration Guide.
3.     Configure the password aging time for the user group.
By default, the password aging time of the user group equals the global password aging time.
4.     Configure the minimum password length for the user group.
By default, the minimum password length of the user group equals the global minimum password length.
5.     Configure the password composition policy for the user group.
By default, the password composition policy of the user group equals the global password composition policy.
6.     Configure the password complexity checking policy for the user group.
By default, the password complexity checking policy of the user group equals the global password complexity checking policy.
7.     Configure the login attempt limit.
By default, the login-attempt policy of the user group equals the global login-attempt policy.
2.     Create a device management user and enter its view.
local-user user-name class manage
Local user password control applies to device management users instead of network access users.
For information about how to configure a local user, see AAA configuration in BRAS Services Configuration Guide.
3.     Configure the password aging time for the local user.
By default, the setting equals that for the user group to which the local user belongs. If no aging time is configured for the user group, the global setting applies to the local user.
4.     Configure the minimum password length for the local user.
By default, the setting equals that for the user group to which the local user belongs. If no minimum password length is configured for the user group, the global setting applies to the local user.
5.     Configure the password composition policy for the local user.
By default, the settings equal those for the user group to which the local user belongs. If no password composition policy is configured for the user group, the global settings apply to the local user.
6.     Configure the password complexity checking policy for the local user.
By default, the settings equal those for the user group to which the local user belongs. If no password complexity checking policy is configured for the user group, the global settings apply to the local user.
By default, the settings equal those for the user group to which the local user belongs. If no login-attempt policy is configured for the user group, the global settings apply to the local user.
2.     Set the password aging time for super passwords.
3.     Configure the minimum length for super passwords.
4.     Configure the password composition policy for super passwords.
By default, a super password must contain a minimum of two character types and a minimum of one character for each type.
The password control module supports the following types of SNMP notifications:
·     SNMP notifications that are generated when a user is added to the password control blacklist—The password control module generates a notification when a user fails the maximum number of consecutive login attempts and is added to the blacklist.
·     SNMP notifications that are generated when a user is removed from the password control blacklist—The password control module generates a notification when a user is removed from the blacklist. A user can be removed from the blacklist after you execute the reset password-control blacklist command or the locking timer for the user expires.
The notifications generated by the password control module are sent to the SNMP module. You can configure notification sending parameters for the SNMP module to determine notification output attributes. For more information about SNMP notifications, see SNMP configuration in Network Management and Monitoring Configuration Guide.
2.     Enable SNMP notifications.
snmp-agent trap enable password-control [ user-lock | user-unlock ]
By default, all SNMP notifications are enabled.
Display and maintenance commands for password control
Display password control configuration.
display password-control [ super ]
Display information about users in the password control blacklist.
display password-control blacklist [ user-name user-name | ip ipv4-address | ipv6 ipv6-address ]
Display passwords obtained from the weak password library.
display password-control weak-password-file
Delete users from the password control blacklist.
reset password-control blacklist [ user-name user-name ]
Clear history password records.
reset password-control history-record [ user-name user-name | super [ role role name ] ]
Password control configuration examples
Example: Configuring password control
Configure a global password control policy to meet the following requirements:
·     A password must contain a minimum of 16 characters.
·     A password must contain a minimum of four character types and a minimum of four characters for each type.
·     An FTP or VTY user failing to provide the correct password in two successive login attempts is permanently prohibited from logging in with the current IP address.
·     A user can log in five times within 60 days after the password expires.
·     A password expires after 30 days.
·     The minimum password update interval is 36 hours.
·     The maximum account idle time is 30 days.
·     A password cannot contain the username or the reverse of the username or part of the username or the reverse of the username.
·     A minimum of three identical consecutive characters is not allowed in a password.
Configure a super password control policy for user role network-operator to meet the following requirements:
·     A super password must contain a minimum of 24 characters.
·     A super password must contain a minimum of four character types and a minimum of five characters for each type.
Configure a password control policy for local Telnet user test to meet the following requirements:
·     The password must contain a minimum of 24 characters.
·     The password must contain a minimum of four character types and a minimum of five characters for each type.
·     The password for the local user expires after 20 days.
# Enable the password control feature globally.
# Allow a maximum of two consecutive login failures on a user account, and lock the user account and the user's IP address permanently if the limit is reached.
[Sysname] password-control login-attempt 2 exceed lock
# Set all passwords to expire after 30 days.
[Sysname] password-control aging 30
# Globally set the minimum password length to 16 characters.
# Set the minimum password update interval to 36 hours.
# Specify that a user can log in five times within 60 days after the password expires.
# Set the maximum account idle time to 30 days.
# Enable username checking.
# Enable repeated character checking.
[Sysname] password-control complexity same-character check
# Globally specify that all passwords must each contain a minimum of four character types and a minimum of four characters for each type.
[Sysname] password-control composition type-number 4 type-length 4
# Set the minimum super password length to 24 characters.
[Sysname] password-control super length 24
# Specify that a super password must contain a minimum of four character types and a minimum of five characters for each type.
# Configure a super password used for switching to user role network-operator as 123456789ABGFTweuix@#$%! in plain text.
[Sysname] super password role network-operator simple 123456789ABGFTweuix@#$%!
# Create a device management user named test.
# Set the service type of the user to Telnet.
# Set the minimum password length to 24 for the local user.
[Sysname-luser-manage-test] password-control length 24
# Specify that the password of the local user must contain a minimum of four character types and a minimum of five characters for each type.
[Sysname-luser-manage-test] password-control composition type-number 4 type-length 5
# Set the password for the local user to expire after 20 days.
[Sysname-luser-manage-test] password-control aging 20
# Configure the password of the local user in interactive mode.
Password:
Confirm :
# Display the global password control configuration.
 Password control:                     Enabled
 Password aging:                       Enabled (30 days)
 Password length:                      Enabled (16 characters)
 Password composition:                 Enabled (4 types, 4 characters per type)
 Password history:                     Enabled (max history record:4)
 Early notice on password expiration:  7 days
 Maximum login attempts:               2
 Action for exceeding login attempts:  Lock
 Password history was last reset:      0 days ago
 Minimum interval between two updates: 36 hours
 User account idle time:               30 days
 Logins with aged password:            5 times in 60 days
 Password complexity:                  Enabled (username checking)
                                       Enabled (repeated characters checking)
 Password change:                      Enabled (first login)
                                       Disabled (mandatory weak password change)
 User information in blacklist:        Username and IP
# Display the password control configuration for super passwords.
 Password aging:                       Enabled (90 days)
 Password length:                      Enabled (24 characters)
 Password composition:                 Enabled (4 types, 5 characters per type)
# Display the password control configuration for local user test.
<Sysname> display local-user user-name test class manage
Total 1 local users matched.
Device management user test:
  State:                     Active
  Service type:              Telnet
  User group:                system
  Bind attributes:
  Authorization attributes:
    Work directory:          flash:
    User role list:          network-operator
    Password aging:          20 days
    Password length:         24 characters
    Password composition:    4 types, 5 characters per type
    Password complexity:     username checking
