16-BRAS Services Command Reference
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesCommand ReferencesH3C SR8800-F Routers Command Reference-R8630Pxx-6W10016-BRAS Services Command Reference
04-DHCP commands
04-DHCP commands 1.44 MB
DHCP commands· 1
Common DHCP commands· 1
dhcp client-detect‌ 1
dhcp conflict-ip-address offline· 1
dhcp dscp· 2
dhcp enable· 3
dhcp flood-protection aging-time· 4
dhcp flood-protection enable· 4
dhcp flood-protection global enable· 5
dhcp flood-protection threshold· 6
dhcp interface-rate-suppression aging-time· 7
dhcp interface-rate-suppression enable· 8
dhcp interface-rate-suppression global enable· 9
dhcp interface-rate-suppression threshold· 9
dhcp log enable· 10
dhcp rate-limit 11
dhcp select 11
dhcp session-mismatch action· 12
dhcp user offline· 13
display dhcp flood-protection· 14
display dhcp interface-rate-suppression· 18
display dhcp rate-limit 21
display dhcp control-plane distribute‌· 23
remote-server 24
reset dhcp flood-protection· 25
reset dhcp interface-rate-suppression· 26
reset dhcp rate-limit 26
DHCP server commands· 27
address range· 27
allocate-new-ip enable· 28
bims-server 29
bootfile-name· 30
class ip-pool 31
class option-group· 32
class range· 33
default ip-pool 34
dhcp apply-policy· 34
dhcp authorized-ip-conflict ignore· 35
dhcp class· 36
dhcp option-group· 36
dhcp policy· 37
dhcp route-log enable· 38
dhcp server allocated-ip threshold· 39
dhcp server always-broadcast 39
dhcp server apply ip-pool 40
dhcp server bootp ignore· 41
dhcp server bootp reply-rfc-1048· 41
dhcp server check mac-address· 42
dhcp server database filename· 42
dhcp server database update interval 44
dhcp server database update now· 45
dhcp server database update stop· 45
dhcp server forbidden-ip· 46
dhcp server multi-ip per-mac enable· 47
dhcp server ping packets· 47
dhcp server ping timeout 48
dhcp server policy-first enable· 49
dhcp server relay information enable· 50
dhcp server reply-exclude-option60· 50
dhcp server request-ip-address check· 51
display dhcp address offline-record· 52
display dhcp gateway-route· 54
display dhcp network-route· 56
display dhcp pool-group-usage· 59
display dhcp pool-usage· 59
display dhcp server conflict 61
display dhcp server database· 62
display dhcp server expired· 63
display dhcp server free-ip· 65
display dhcp server ip-in-use· 66
display dhcp server packet statistics· 70
display dhcp server statistics· 72
display dhcp-access count 74
display dhcp-access packet statistics· 75
display dhcp-access user-table· 76
display ip pool 81
display ip pool ip-status· 89
display ip pool network item·· 91
display ip pool network statistics· 92
display ip pool-group· 94
dns-list 100
domain-name· 100
exhaustion log enable· 101
exhaustion trap enable· 102
expired· 103
export host-route· 104
forbidden-ip· 105
forbidden-ip-range· 106
gateway· 107
gateway-list 108
if-match· 109
ip pool 111
ip pool-group· 112
ip-pool algorithm round-robin· 113
ip unr 114
ip-in-use threshold· 115
lock· 116
nbns-list 117
netbios-type· 118
network· 119
next-server 120
option· 121
pool 122
reserve expired-ip enable· 123
reserve expired-ip mode· 124
reset dhcp address offline-record· 125
reset dhcp pool-usage peak· 125
reset dhcp server conflict 126
reset dhcp server expired· 127
reset dhcp server ip-in-use· 127
reset dhcp server packet statistics· 128
reset dhcp-access packet statistics· 129
route-log enable· 129
snmp-agent trap enable dhcp server 130
static-bind· 132
tftp-server domain-name· 133
tftp-server ip-address· 134
unr preference· 134
unr tag· 135
valid class· 136
verify class· 136
voice-config· 137
vpn-instance (IP pool view) 138
vpn-instance (IP pool group view) 139
Old-style DHCP server commands‌· 139
dhcp pool-group· 139
dhcp server ip-pool 140
display dhcp pool-group· 141
display dhcp server pool 145
DHCP relay agent commands· 150
dhcp-proxy enable· 150
dhcp relay always-unicast 150
dhcp relay check mac-address· 151
dhcp relay client-information record· 152
dhcp relay client-information refresh· 152
dhcp relay client-information refresh enable· 153
dhcp relay dhcp-server timeout 154
dhcp relay forward reply by-option82· 155
dhcp relay gateway· 155
dhcp relay information circuit-id· 156
dhcp relay information enable· 158
dhcp relay information remote-id· 159
dhcp relay information strategy· 160
dhcp relay master-server switch-delay· 161
dhcp relay non-first-hop enable· 162
dhcp relay release ip· 162
dhcp relay release-agent 163
dhcp relay server-address· 164
dhcp relay server-address algorithm·· 165
dhcp relay source-address· 166
dhcp server 168
dhcp-server nak-count 170
dhcp-server remote-ip-check bypass· 171
dhcp-server source-address· 172
dhcp-server timeout 174
dhcp smart-relay enable· 174
discover-nak-count 175
display dhcp relay client-information· 176
display dhcp relay information· 178
display dhcp relay packet statistics· 180
display dhcp relay remote-server-info· 181
display dhcp relay server-address· 183
gateway-list 184
master-server switch-delay· 185
remote-server algorithm·· 186
reset dhcp relay client-information· 187
reset dhcp relay packet statistics· 188
Old-style DHCP relay agent commands‌· 188
dhcp select relay proxy· 188
DHCP client commands· 190
dhcp client dad enable· 190
dhcp client dscp· 190
dhcp client identifier 191
display dhcp client 192
ip address dhcp-alloc· 194
snmp-agent trap enable dhcp-client 195
DHCP snooping commands· 195
dhcp snooping binding database filename· 196
dhcp snooping binding database update interval 197
dhcp snooping binding database update now· 198
dhcp snooping binding record· 198
dhcp snooping check mac-address· 199
dhcp snooping check request-message· 199
dhcp snooping deny· 200
dhcp snooping enable· 201
dhcp snooping information circuit-id· 201
dhcp snooping information enable· 203
dhcp snooping information remote-id· 204
dhcp snooping information strategy· 205
dhcp snooping log enable· 206
dhcp snooping max-learning-num·· 207
dhcp snooping trust 207
display dhcp snooping binding· 208
display dhcp snooping binding database· 209
display dhcp snooping information· 210
display dhcp snooping packet statistics· 211
display dhcp snooping trust 212
reset dhcp snooping binding· 213
reset dhcp snooping packet statistics· 213
BOOTP client commands· 214
display bootp client 214
ip address bootp-alloc· 215
DHCP commands
dhcp client-detect
Use dhcp client-detect to enable client offline detection on the DHCP server or DHCP relay agent.
Use undo dhcp client-detect to disable client offline detection on the DHCP server or DHCP relay agent.
dhcp client-detect
Client offline detection is disabled on the DHCP server or DHCP relay agent.
Interface view
The client offline detection feature on the DHCP server reclaims an assigned IP address and deletes the binding entry when the ARP entry ages out for the IP address.
This feature on the DHCP relay agent deletes the related relay entry and sends a RELEASE message to the DHCP server when an ARP entry ages out.
This feature is not supported in BRAS scenarios.
# Enable client offline detection.
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] dhcp client-detect
Use dhcp conflict-ip-address offline to enable the IP conflicting user offline feature. When the IP addresses assigned to new DHCP clients and the IP addresses of online DHCP client conflict, the conflicting IP addresses are released, and both the new and existing online users are offline.
Use undo dhcp conflict-ip-address offline to restore the default.
The IP conflicting user offline feature is disabled. When the IP address assigned to a new DHCP client conflicts with the IP address of an online DHCP client, the online DHCP client still stays online.
The following IP address conflicts might occur in a DHCP network:
·     The IP address assigned by the authentication and authorization module to a new user is the same as the IP address of an online DHCP client.
·     The IP address assigned by the DHCP server to a new DHCP client is the same as the IP address in the DHCP relay entry of an online DHCP client.
If these conflicts occur, by default, the conflicting online DHCP clients still stay online, and new users cannot come online. You can configure this feature to release conflicting IP addresses so that new users can obtain IP addresses next time they request IP addresses through DHCP.
With this feature enabled on the DHCP server, the DHCP server releases the conflicting IP address of the online DHCP client and informs the access module that this address is not available.
With this feature enabled on the DHCP relay agent, the relay agent processes the conflicts as follows:
·     If the IP address assigned to a new user by the authentication and authorization module conflicts with the DHCP relay entry of an online client, the relay agent performs the following operations:
a.     Sends a DHCP-RELEASE packet to the DHCP server to release the conflicting IP address.
b.     Informs the access module of the new user that this IP address is not available.
·     If the IP address in the DHCP reply for a new user conflicts with the DHCP relay entry of an online client, the relay agent performs the following operations:
c.     Sends a DHCP-RELEASE packet to the server to release the conflicting IP address.
d.     Drops the DHCP reply.
This feature takes effect on the DHCP relay agent only after you enable the recording of relay entries on it.
# Enable the IP conflicting user offline feature.
[Sysname] dhcp conflict-ip-address offline
dhcp dscp
Use dhcp dscp to set the DSCP value for DHCP packets sent by the DHCP server or the DHCP relay agent.
Use undo dhcp dscp to restore the default.
dhcp dscp dscp-value
undo dhcp dscp
The DSCP value is 56 in DHCP packets sent by the DHCP server or the DHCP relay agent.
dscp-value: Specifies the DSCP value for DHCP packets, in the range of 0 to 63.
The DSCP value of a packet specifies the priority level of the packet and affects the transmission priority of the packet. A bigger DSCP value represents a higher priority.
# Set the DSCP value to 30 for DHCP packets sent by the DHCP server or the DHCP relay agent.
[Sysname] dhcp dscp 30
dhcp enable
Use dhcp enable to enable DHCP.
Use undo dhcp enable to disable DHCP.
dhcp enable
undo dhcp enable
DHCP is disabled.
DHCP related configuration takes effect only after you enable DHCP.
Enable DHCP before you configure the DHCP server or relay agent.
# Enable DHCP.
[Sysname] dhcp enable
Use dhcp flood-protection aging-time to set the aging time of DHCP flood attack protection entries.
Use undo dhcp flood-protection aging-time to restore the default.
dhcp flood-protection aging-time time
The aging time is 300 seconds for DHCP flood attack protection entries.
time: Specifies the aging time of DHCP flood attack protection entries, in seconds. The value range is 30 to 600.
When the aging time of a DHCP flood attack protection entry for a MAC address is reached, the DHCP device examines the drop rate of DHCP packets sent from the MAC address.
·     If the packet drop rate is lower than the DHCP flood attack threshold, the device deletes the entry. If later a DHCP packet from that MAC address arrives, the DHCP device will create a new flood attack protection entry and count the number of incoming DHCP packets for that client again.
·     If the packet drop rate is equal to or higher than the DHCP flood attack threshold, the device resets the aging time for the entry.
This command takes effect only after you execute the dhcp flood-protection enable command.
If you execute the command multiple times, the most recent configuration takes effect.
# Set the aging time to 90 seconds for DHCP flood attack protection entries.
[Sysname] dhcp flood-protection aging-time 90
Use dhcp flood-protection enable to enable DHCP flood attack protection on an interface.
Use undo dhcp flood-protection enable to disable DHCP flood attack protection on an interface.
DHCP flood attack protection is disabled on an interface.
Interface view
When the device receives a DHCP packet from a client, it creates a DHCP flood attack protection entry in check state. In the entry, the client is identified by its MAC address. If the number of incoming DHCP packets from the same MAC address reaches the upper limit in the detection duration, the device determines that the client is launching a DHCP flood attack. The DHCP flood attack protection entry changes to the restrain state, and the device discards the DHCP packets from that client.
You can configure DHCP flood attack protection globally or on a per-interface basis.
DHCP flood attack protection takes effect on an interface if it is enabled globally or on that interface. To enable DHCP flood attack protection only on some of the interfaces, disable the feature globally and enable it on the desired interfaces.
# Enable DHCP flood attack protection on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp flood-protection enable
Use dhcp flood-protection global enable to enable global DHCP flood attack protection.
Use undo dhcp flood-protection global enable to disable global DHCP flood attack protection.
Global DHCP flood attack protection is enabled.
This command enables DHCP flood attack protection on all interfaces of the device.
When the device receives a DHCP packet from a client, it creates a DHCP flood attack protection entry in check state for that client. In the entry, the client is identified by its MAC address. If the number of incoming DHCP packets from that client reaches the upper limit in the detection duration, the device determines that the client is launching a DHCP flood attack. The DHCP flood attack protection entry changes to the restrain state, and the device discards the DHCP packets from that client.
You can configure DHCP flood attack protection globally by using this command, or on a per-interface basis by using the dhcp flood-protection enable command.
DHCP flood attack protection takes effect on an interface as long as it is enabled globally or on that interface. To enable DHCP flood attack protection only on some of the interfaces, disable the feature globally and enable it on the desired interfaces.
# Enable global DHCP flood attack protection.
[Sysname] dhcp flood protection global enable
Use dhcp flood-protection threshold to set the DHCP packet rate threshold for triggering DHCP flood attack protection.
Use undo dhcp flood-protection threshold to restore the default.
dhcp flood-protection threshold packet-number milliseconds
The device allows a maximum of 10 DHCP packets per 5000 milliseconds from each DHCP client.
packet-number: Specifies the maximum number of DHCP packets in the range of 2 to 200.
milliseconds: Specifies the DHCP flood attack detection duration in milliseconds. The value range is 1000 to 30000.
The DHCP flood attack protection enables the DHCP device to detect DHCP flood attacks according to the DHCP packet rate threshold on a per-MAC basis. If the number of incoming DHCP packets from the same MAC address exceeds the upper limit in the detection duration, the client at that MAC address is launching a DHCP flood attack.
# Configure the device to allow a maximum of two DHCP packets per 9000 milliseconds from each DHCP client.
[Sysname] dhcp flood-protection threshold 2 9000
Use dhcp interface-rate-suppression aging-time to set the aging time of interface-based DHCP attack suppression entries.
Use undo dhcp interface-rate-suppression aging-time to restore the default.
dhcp interface-rate-suppression aging-time time
The aging time is 300 seconds for interface-based DHCP attack suppression entries.
time: Specifies the aging time of interface-based DHCP attack suppression entries, in seconds. The value range is 30 to 600.
When the aging time of a DHCP attack suppression entry on an interface is reached, the device examines the packet receiving rate on the interface.
·     If the packet receiving rate is below the suppression threshold, the device deletes the entry. If later a DHCP packet arrives on that interface, the device will create a new attack suppression entry and count the number of incoming DHCP packets on that interface again.
·     If the packet receiving rate is above the suppression threshold, the device resets the aging time.
This command takes effect only after you execute the dhcp interface-rate-suppression enable command.
# Set the aging time to 90 seconds for interface-based DHCP attack suppression entries.
[Sysname] dhcp interface-rate-suppression aging-time 90
Use dhcp interface-rate-suppression enable to enable DHCP attack suppression on an interface.
Use undo dhcp interface-rate-suppression enable to disable DHCP attack suppression on an interface.
DHCP attack suppression is disabled on an interface.
Interface view
When an interface enabled with this feature receives a DHCP packet, the device creates a DHCP attack suppression entry in check state for the interface. If the DHCP packet receiving rate on the interface reaches or exceeds the threshold, a DHCP attack occurs on the interface. The suppression entry changes to the restrain state. To protect the CPU against DHCP attack packets, the device limits the DHCP packet receiving rate on the interface before the aging time of the suppression entry is reached.
# Enable DHCP attack suppression on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp interface-rate-suppression enable
Use dhcp interface-rate-suppression global enable to enable DHCP attack suppression globally.
Use undo dhcp interface-rate-suppression global enable to disable DHCP attack suppression globally.
Global DHCP attack suppression is disabled.
To enable DHCP attack suppression on all interfaces, use this command.
DHCP attack suppression protects an interface from DHCP attacks by limiting the rate of incoming DHCP packets after the specified threshold is crossed.
After you enable DHCP attack suppression globally on all interfaces, the device creates a DHCP attack suppression entry in check state for each interface and counts their incoming DHCP packets. If the incoming DHCP packet rate on an interface reaches or exceeds the threshold, the device determines that the interface is under a DHCP attack. Then, it changes the suppression entry for the interface to the restrain state. To protect the CPU against DHCP attack packets, the device limits the incoming DHCP packet rate on the interface until the suppression entry ages out.
You can enable DHCP attack suppression globally by using this command, or on a per-interface basis by using the dhcp interface-rate-suppression enable command.
·     DHCP attack suppression takes effect on an interface as long as it is enabled globally or on the interface.
·     To suppress DHCP attacks only on some of the interfaces, you must disable DHCP attack suppression globally, and then enable the feature on the target interfaces.
# Enable DHCP attack suppression globally.
[Sysname] dhcp interface-rate-suppression global enable
Use dhcp interface-rate-suppression threshold to set the DHCP packet rate threshold for triggering interface-based DHCP attack suppression.
Use undo dhcp interface-rate-suppression threshold to restore the default.
dhcp interface-rate-suppression threshold packet-number milliseconds
The device can receive a maximum of 3000 DHCP packets per 5000 milliseconds on an interface.
packet-number: Specifies the maximum number of DHCP packets received on an interface, in the range of 2 to 6000.
milliseconds: Specifies the interface-based DHCP attack detection duration in milliseconds. The value range is 1000 to 10000.
A DHCP attack occurs on an interface if the DHCP packet receiving rate on the interface reaches the threshold.
# Set the DHCP packet rate threshold to 2000 DHCP packets per 9000 milliseconds for triggering interface-based DHCP attack suppression.
[Sysname] dhcp interface-rate-suppression threshold 2000 9000
dhcp log enable
Use dhcp log enable to enable DHCP server logging.
Use undo dhcp log enable to disable DHCP server logging.
dhcp log enable
DHCP server logging is disabled.
This command enables the DHCP server to generate DHCP logs and send them to the information center. For information about the log destination and output rule configuration in the information center, see Network Management and Monitoring Configuration Guide.
As a best practice, disable this feature if the log generation affects the device performance or reduces the address allocation efficiency. For example, this situation might occur when a large number of clients frequently come online or go offline.
# Enable DHCP server logging.
[Sysname] dhcp log enable
dhcp rate-limit
Use dhcp rate-limit to enable DHCP packet rate limit on an interface and set the limit value.
Use undo dhcp rate-limit to disable DHCP packet rate limit.
dhcp rate-limit rate
The DHCP packet rate limit is disabled on an interface.
Interface view
rate: Specifies the maximum rate in Kbps. The value range for this argument is 1 to 10240.
With this feature enabled, an interface discards DHCP packets that exceed the maximum rate.
# Set the DHCP packet rate limit to 64 Kbps on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp rate-limit 64
dhcp select
Use dhcp select to enable the DHCP server or DHCP relay agent on an interface.
Use undo dhcp select to disable the DHCP server or DHCP relay agent on an interface. The interface will discard incoming DHCP packets.
dhcp select { relay | server }
undo dhcp select { relay | server }
The interface operates in the DHCP server mode and responds to DHCP requests with configuration parameters.
Interface view
relay: Enables the DHCP relay agent on the interface.
server: Enables the DHCP server on the interface.
Before enabling a DHCP server to operate as a DHCP relay agent, use the reset dhcp server ip-in-use command to clear address bindings and authorization ARP entries. These authorization ARP entries might conflict with ARP entries that are created after the DHCP relay agent is enabled.
# Enable the DHCP relay agent on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp select relay
Use dhcp session-mismatch action to specify a DHCP request processing method for roaming DHCP clients.
Use undo dhcp session-mismatch action to restore the default.
dhcp session-mismatch action { fast-renew | roam }
The DHCP device discards DHCP address requests sent from roaming DHCP clients.
Interface view
fast-renew: Releases existing leases for roaming clients and assigns new IP addresses to them.
roam: Assigns addresses to roaming clients based on their existing address leases and renews the leases. This keyword is applicable only to IPoE users roaming among the interfaces that belong to the same roaming group.
This command is applicable only to IPoE networks.
When a DHCP client roams in a network, the client sends an offline request to the DHCP device (DHCP server or relay agent) before requesting a new address. If the DHCP device does not receive the offline request, it will discard the DHCP client's new address request because it determines that the request is an attack packet.
This feature allows the DHCP device to process address requests as follows upon receiving them from roaming DHCP clients:
·     If the fast-renew keyword is specified:
¡     The DHCP server releases existing address leases of the roaming clients and assigns them new IP addresses.
¡     The DHCP relay agent informs the DHCP server to release the existing address leases of roaming clients and forwards the requests to the DHCP server.
·     If the roam keyword is specified:
¡     The DHCP server assigns addresses to the roaming clients based on their existing address leases and renews the leases.
¡     The DHCP relay agent forwards the address requests of the roaming clients to the DHCP server.
The roam keyword allows the clients to use the original IP addresses to access the network without another access authentication.
This feature might make online users go offline. Enable this feature for roaming DHCP clients only when no DHCP attacks exist in the network.
This command is mutually exclusive with the dhcp server multi-ip per-mac enable command.
# On Ten-GigabitEthernet 3/1/1, configure the DHCP server to use the fast-renew method for roaming clients.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp session-mismatch action fast-renew
ip subscriber roaming enable (BRAS Service Command Reference)
dhcp user offline
Use dhcp user offline to enable the DHCP server to release the existing IP address lease of a client after it receives an IP address request from that client again.
Use undo dhcp user offline to restore the default.
dhcp { discover | reboot-request } * user offline
undo dhcp { discover | reboot-request } * user offline
On receipt of an IP address request from a client that already has a lease, the DHCP server answers the request with the IP address in that lease.
discover: Specify the DHCPDISCOVER message.
reboot-request: Specify the DHCPREQUEST message sent after a reboot.
When a client goes offline, the DHCP server might not be aware of the offline event and cannot release the client lease timely. If the client comes online again from a different authentication domain, information in Options 16, 17, and 60 in the DHCP request sent by the client will change. If the DHCP server returns the IP address in the existing lease to the client without parsing Option information in the request, the client will be unable to access the network. This is because the obtained IP address does not match the new authentication domain.
To resolve this issue, you can use this command specifying a DHCP message type. The DHCP server will perform the following tasks when it receives an IP address request from a client that already has a lease:
·     If the type of the address request matches the specified DHCP message type, the DHCP server will do the following:
¡     Release the existing IP address lease for that client.
¡     Select a correct IP pool based on the Option information and assign a new IP address to the client.
·     If the type of the address request does not match the specified DHCP message type, the DHCP server answers the request with the IP address in that lease.
# Enable the DHCP server to release the existing IP address lease of a client if it receives a DHCP-DISCOVER from that client again.
[Sysname] dhcp discover user offline
# Enable the DHCP server to release the existing IP address lease of a client if it receives a DHCP-REQUEST from that client again.
[Sysname] dhcp reboot-request user offline
Use display dhcp flood-protection to display information about DHCP flood attack protection entries.
In standalone mode:
display dhcp flood-protection slot slot-number [ mac-address mac-address [ interface interface-type interface-number ] | state { check | restrain } [ verbose ] | statistics | verbose ]
In IRF mode:
display dhcp flood-protection chassis chassis-number slot slot-number [ mac-address mac-address [ interface interface-type interface-number ] | state { check | restrain } [ verbose ] | statistics | verbose ]
mac-address mac-address: Specifies a MAC address in the format of H-H-H. If you specify this option, the command displays detailed information about the DHCP flood attack protection entries for the specified MAC address. If you do not specify this option, the command displays brief information about DHCP flood attack protection entries.
interface interface-type interface-number: Displays information about the DHCP flood attack protection entries for the specified interface.
state { check | restrain }: Displays information about DHCP flood attack protection entries in the specified state. The check keyword specifies the check state. The restrain keyword specifies the restrain state.
slot slot-number: Specifies a card by its slot number. On this device, the slot-number argument represents the entire device and its value is fixed. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. (In IRF mode.)
statistics: Displays statistics for DHCP flood attack protection entries.
verbose: Displays detailed information about DHCP flood attack protection entries.
If you do not specify any parameters, this command displays brief information about all DHCP flood attack protection entries on the device.
# (In standalone mode.) Display brief information about DHCP flood attack protection entries on a slot.
<Sysname> display dhcp flood-protection slot 3
Global DHCP flood protection: Enabled
DHCP flood protection threshold: 100 packets/ 2000 milliseconds
Index         MAC address          UDP port     SVLAN/CVLAN     State
0             4211-cc00-0116       67           4091/4094       Restrain
1             60d0-d50a-0231       68           4091/4094       Check
2             4211-cc00-0117       67           4091/4094       Restrain
3             000f-3d81-7faf       67           4091/4094       Check
4             4211-cc00-0118       67           4091/4094       Restrain
Total entries: 5
# (In standalone mode.) Display detailed information about DHCP flood attack protection entries on a slot.
<Sysname> display dhcp flood-protection slot 3 verbose
Interface: Ten-GigabitEthernet3/1/1
MAC address: 78a8-3e93-0216
Hardware status: Succeeded
SVLAN/CVLAN: -/-
State: Restrain
SRv6 ID: ::
Entry created at: 2021/06/24 11:23:45
Entry aging time: 21 seconds
Total passed packets: 1
Total restrain packets: 2
Interface: Ten-GigabitEthernet3/1/2
MAC address: 78a8-3e93-0217
SVLAN/CVLAN: -/-
State: Restrain
SRv6 ID: ::
Entry created at: 2021/06/24 11:23:43
Interface: Ten-GigabitEthernet3/1/3
MAC address: 78a8-3e93-0218
SVLAN/CVLAN: -/-
State: Restrain
SRv6 ID: ::
Entry created at: 2021/06/24 11:23:41
Total entries: 3
# (In standalone mode.) Display detailed information about DHCP flood attack protection entries for MAC address 4211-cc00-0116 on a slot.
<Sysname> display dhcp flood-protection slot 3 mac-address 4211-cc00-0116
MAC address: 4211-cc00-0116
SVLAN/CVLAN: 4091/4094
State: Restrain
SRv6 ID: ::
Entry created at: 2018/01/08 15:51:50
Total passed packets: 2
Total restrain packets: 3
Total entries: 1
# (In standalone mode.) Displays statistics for DHCP flood attack protection entries.
<Sysname> display dhcp flood-protection slot 3 statistics
Total entries: 5
Entries in check state: 2
Entries in restrain state: 3
Whether global DHCP flood attack protection is enabled.
DHCP flood protection threshold: xxx packets/ yyy milliseconds
The DHCP packet count limit is xxx and the detection duration is yyy milliseconds.
Index
Sequence number of the DHCP flood attack protection entry.
MAC address
Source MAC address in DHCP packets.
UDP port
Destination UDP port number in DHCP packets.
SVLAN/CVLAN
Inner VLAN ID and outer VLAN ID in DHCP packets. If a DHCP packet does not belong to any VLAN, this field displays a hyphen (-).
State of the DHCP flood attack protection entry:
·     Check.
·     Restrain.
Interface that received DHCP packets.
Hardware status
Result of issuing the entry to the hardware:
·     Succeeded—Succeeded in issuing the entry to the hardware.
·     Failed—Failed to issue the entry to the hardware because of a device failure or insufficient hardware resources.
·     N/A—The entry was not issued to the hardware because the packet was not an attack packet.
·     Not support—DHCP attack protection is not supported in hardware.
SRv6 ID
SRv6 SID of the interface that received DHCP packets.
Entry created at
Time when the DHCP flood attack protection entry was created. The entry is in check state when it is created.
Entry aging time
Remaining lifetime of the DHCP flood attack protection entry.
Number of packets that have been passed through when the DHCP flood attack protection entry is in check state.
Number of dropped packets when the DHCP flood attack protection entry is in restrain state.
Total entries
Total number of DHCP flood attack protection entries.
Total number of DHCP flood attack protection entries in check state.
Total number of DHCP flood attack protection entries in restrain state.
Use display dhcp interface-rate-suppression to display information about interface-based DHCP attack suppression entries.
In standalone mode:
display dhcp interface-rate-suppression slot slot-number [ interface interface-type interface-number | state { check | restrain } [ verbose ] | statistics | verbose ]
In IRF mode:
display dhcp interface-rate-suppression chassis chassis-number slot slot-number [ interface interface-type interface-number | state { check | restrain } [ verbose ] | statistics | verbose ]
interface interface-type interface-number: Displays detailed information about the DHCP attack suppression entry for the specified interface.
state { check | restrain }: Displays information about interface-based DHCP attack suppression entries in the specified state. The check keyword specifies the check state. The restrain keyword specifies the restrain state.
statistics: Displays interface-based DHCP attack suppression statistics.
verbose: Displays detailed information about interface-based DHCP attack suppression entries.
If you do not specify any parameters, this command displays brief information about all interface-based DHCP attack suppression entries on the device.
# (In standalone mode.) Display brief information about interface-based DHCP attack suppression entries on a slot.
<Sysname> display dhcp interface-rate-suppression slot 3
DHCP attack suppression threshold: 100 packets/ 2000 milliseconds
Index         Interface         State
0             XGE3/1/1          Restrain
1             XGE3/1/2          Check
2             XGE3/1/3          Restrain
Total entries: 3
# (In standalone mode.) Display detailed information about interface-based DHCP attack suppression entries on a slot.
<Sysname>display dhcp interface-rate-suppression slot 3 verbose
State: Restrain
Entry created at 2021/06/24 11:23:45
Total passed packets: 7
Total restrain packets: 0
State: Restrain
Entry created at 2021/06/24 11:23:43
State: Restrain
Entry created at 2021/06/24 11:23:41
Total passed packets: 6
Total entries: 3
# (In standalone mode.) Display detailed information about the DHCP attack suppression entry for Ten-GigabitEthernet 3/1/1 on a slot.
<Sysname> display dhcp interface-rate-suppression slot 3 interface Ten-GigabitEthernet 3/1/1
State: Restrain
Entry created at 2018/07/08 15:51:50
# (In standalone mode.) Display interface-based DHCP attack suppression statistics on a slot.
<Sysname> display dhcp interface-rate-suppression slot 3 statistics
Interfaces enabled with DHCP attack suppression: 3
Entries in restrain state: 1
DHCP attack suppression threshold: xxx packets/ yyy milliseconds
Index
Sequence number of the interface-based DHCP attack suppression entry.
State of the interface-based DHCP attack suppression entry:
·     Check.
·     Restrain.
Hardware status
Entry created at
Time when the interface-based DHCP attack suppression entry was created.
Entry aging time
Remaining lifetime of the interface-based DHCP attack suppression entry.
Number of forwarded DHCP packets when the DHCP flood attack suppression entry is in restrain state.
Number of dropped DHCP packets when the DHCP flood attack suppression entry is in restrain state.
Total entries
Total number of interface-based DHCP attack suppression entries.
Total number of interfaces on which DHCP attack suppression is enabled.
Check state count
Total number of interface-based DHCP attack suppression entries in check state.
Restrain state count
Total number of interface-based DHCP attack suppression entries in restrain state.
Use display dhcp rate-limit to display packet statistics for the DHCP packet rate-limiting feature.
In standalone mode:
display dhcp rate-limit slot slot-number
In IRF mode:
display dhcp rate-limit chassis chassis-number slot slot-number
To limit the incoming DHCP packet rate, use the ip subscriber dhcp rate-limit command. To display packet statistics for the DHCP packet rate-limiting feature, use the display dhcp rate-limit command.
The real DHCP rate limit value and the number of packet drops depend on the following factors:
·     CPU usage
When the CPU usage reaches the minor or severe level, the system reduces the DHCP rate limit value according to the adjustment percentage configured by using the access-user adjustment access-rate-limit command:
¡     If a DHCP rate limit value is configured by using the ip subscriber dhcp rate-limit command, the system adjusts the rate limit value according to the configured adjustment percentage.
¡     If no DHCP rate limit value is configured, the system adjusts the predefined backup rate limit value according to the configured adjustment percentage.
¡     If the DHCP rate limit value is smaller than 1 after adjustment, the real rate limit value equals the minimum value of 1.
·     Maximum number of concurrent access users
When the number of DHCP access users exceeds the upper limit configured by using the access-user max-connections command, the device directly discards DHCP packets received from users (including DISCOVER packets, and REQUEST packets received from unauthenticated users).
# (In standalone mode.) Display packet statistics for the DHCP packet rate-limiting feature on a slot.
<Sysname> display dhcp rate-limit slot 3
DHCP rate-limit packet statistics:
  Dropped since last poll:12
  Total dropped packets:22
  Total passed packets:1000
  Adjustment ratelimit ratio: 100%
  Ratelimit threshold : 100 (configured)
DHCP forbidden-access packet statistics:
  Last dropped out-of-limit packets: 0
  Total dropped out-of-limit packets: 0
Packet statistics for the DHCP packet rate-limiting feature.
Number of packets dropped by the DHCP packet rate-limiting feature since the most recent data poll.
Total number of packets dropped by the DHCP packet rate-limiting feature.
Total number of packets permitted by the DHCP packet rate-limiting feature.
DHCP rate limit adjustment ratio for the related CPU usage level.
Ratelimit threshold
Real DHCP packet rate limit:
·     Not configuredNo DHCP packet rate limit is configured.
·     xxx (configured)—The xxx argument equals the rate limit value configured by using the ip subscriber dhcp rate-limit command multiplied by the DHCP rate limit adjustment percentage.
·     xxx (fallback)—No DHCP packet rate limit is configured. After a CPU usage alarm is generated, the xxx argument equals the predefined backup rate limit value multiplied by the DHCP rate limit adjustment percentage.
DHCP packet statistics collected for forbidden DHCP access users after the number of concurrent DHCP access users exceeded the upper limit. This field collects DHCP packet drop statistics each time the number of concurrent DHCP access users exceeds the upper limit.
Number of DHCP user packets (including DISCOVER packets, and REQUEST packets received from unauthenticated users) dropped during the last round of DHCP packet drop statistics collection.
Number of DHCP user packets (including DISCOVER packets, and REQUEST packets received from unauthenticated users) dropped during the most recent round of DHCP packet drop statistics collection.
ip subscriber dhcp rate-limit (BRAS Services Command Reference)
access-user adjustment access-rate-limit (BRAS Services Command Reference)
access-user max-connections (BRAS Services Command Reference)
Use display dhcp control-plane distribute to display the DHCP configuration issued by the CP on the UP.
In standalone mode:
display dhcp control-plane distribute [ slot slot-number ]
In IRF mode:
display dhcp control-plane distribute [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a slot, this command displays DHCP configuration information for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays DHCP configuration information on the global active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
In standalone mode: # Display the DHCP configuration information issued by the CP on the UP.
<Sysname> display dhcp control-plane distribute slot 1
User mode:
  RenewProxy: Enabled
  LeaseTime: 60min
  OnlyServer: Enabled
Kernel mode:
  RenewProxy: Enabled
User mode
User mode configuration.
Kernel mode
Kernel mode configuration.
RenewProxy
Whether the UP renewal proxy feature is enabled.
LeaseTime
Lease duration to be extended.
OnlyServer
Whether the UP renewal proxy feature takes effect on the CP only when the CP acts as DHCP server:
·     Enabled—The UP renewal proxy feature takes effect on the CP only when the CP acts as DHCP server.
·     Disabled—The UP renewal proxy feature takes effect on the CP when the CP acts as either DHCP server or DHCP relay agent.
dhcp user-plane renew proxy
remote-server
Use remote-server to specify DHCP servers for an IP pool.
Use undo remote-server to remove DHCP servers from an IP pool.
remote-server ip-address&<1-8> [ public | vpn-instance vpn-instance-name ]
undo remote-server [ ip-address&<1-8> ]
No DHCP server is specified for an IP pool.
IP pool view
ip-address&<1-8>: Specifies a space-separated list of up to eight DHCP server addresses.
public: Specifies the DHCP servers on the public network.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the DHCP servers belong. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the servers belong to the public network, do not specify this option.
If you do not specify any DHCP server address, the undo remote-server command removes all DHCP servers from the IP pool.
If neither the public keyword nor the vpn-instance vpn-instance-name option is specified, DHCP servers on the same network as the DHCP client are selected.
# Specify DHCP server 10.1.1.1 for IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] remote-server 10.1.1.1
Use reset dhcp flood-protection to delete DHCP flood attack protection entries.
In standalone mode:
reset dhcp flood-protection slot slot-number [ mac-address mac-address [ interface interface-type interface-number ] ] [ packet-statistics ]
In IRF mode:
reset dhcp flood-protection chassis chassis-number slot slot-number [ mac-address mac-address [ interface interface-type interface-number ] ] [ packet-statistics ]
mac-address mac-address: Deletes DHCP flood attack protection entries with the specified MAC address in the format of H-H-H. If you do not specify this option, the command deletes all DHCP flood attack protection entries.
interface interface-type interface-number: Deletes DHCP flood attack protection entries for the specified interface.
packet-statistics: Clears the packet statistics in the specified entries. If you do not specify this keyword, this command deletes the specified DHCP flood attack protection entries.
If you do not specify any parameters, this command deletes all DHCP flood attack protection entries on the device.
# (In standalone mode.) Delete all DHCP flood attack protection entries on a slot.
<Sysname> reset dhcp flood-protection slot 3
Use reset dhcp interface-rate-suppression to delete interface-based DHCP attack suppression entries.
In standalone mode:
reset dhcp interface-rate-suppression slot slot-number [ interface interface-type interface-number ] [ packet-statistics ]
In IRF mode:
reset dhcp interface-rate-suppression chassis chassis-number slot slot-number [ interface interface-type interface-number ] [ packet-statistics ]
interface interface-type interface-number: Deletes the DHCP attack suppression entry for the specified interface.
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. (In standalone mode.)
packet-statistics: Clears the packet statistics in the specified entries. If you do not specify this keyword, this command deletes the specified interface-based DHCP attack suppression entries.
If you do not specify any parameters, this command deletes all interface-based DHCP attack suppression entries on the device.
# (In standalone mode.) Delete all interface-based DHCP attack suppression entries on a slot.
<Sysname> reset dhcp interface-rate-suppression slot 3
Use reset dhcp rate-limit to clear packet statistics for the DHCP packet rate-limiting feature.
In standalone mode:
reset dhcp rate-limit slot slot-number
In IRF mode:
reset dhcp rate-limit chassis chassis-number slot slot-number
This command clears the DHCP packet statistics collected for the DHCP packet rate-limiting feature. You can enable that feature by using the ip subscriber dhcp rate-limit command.
# (In standalone mode.) Clear packet statistics for the DHCP packet rate-limiting feature on a slot.
<Sysname> reset dhcp rate-limit slot 3
address range
Use address range to configure an IP address range in an IP pool for dynamic allocation.
Use undo address range to restore the default.
undo address range
No IP address range exists.
IP pool view
Secondary network segment view
start-ip-address: Specifies the start IP address.
end-ip-address: Specifies the end IP address.
CAUTION
CAUTION:
To ensure successful IP address allocation, the address range specified by using the address range command must be within the network segment specified by using the network, gateway, or network secondary command.
If no IP address range is specified in IP pool view or secondary network segment view, the following addresses are assignable:
·     All IP addresses in the network segment specified by using the network command or the gateway command.
·     All IP addresses in the secondary network segment specified by using the network secondary command.
If you specify an IP address range in IP pool view or secondary network segment view, only addresses in both the address range and the network segment are assignable.
When you configure this command in an IP address pool configured with the forbidden-ip or forbidden-ip-range command, make sure the specified address range includes the excluded IP addresses or IP address ranges.
# Specify an address range of 192.168.8.1 through 192.168.8.150 in IP pool 1.
[Sysname] ip pool 1
[Sysname-ip-pool-1] network 192.168.8.1 mask 255.255.255.0
[Sysname-ip-pool-1] address range 192.168.8.1 192.168.8.150
# Specify an address range of 192.168.8.1 through 192.168.8.150 for the secondary network segment in IP pool 1.
[Sysname] ip pool 1
[Sysname-ip-pool-1] network 192.168.8.1 secondary
[Sysname-ip-pool-1-secondary] address range 192.168.8.1 192.168.8.150
class
dhcp class
display ip pool
network
Use allocate-new-ip enable to enable random IP address allocation.
Use undo allocate-new-ip enable to disable random IP address allocation.
Random IP address allocation is disabled.
IP pool view
CAUTION
CAUTION:
Enable this feature on the DHCP server with caution if it works in conjunction with a DHCP relay agent that is located on an access device. In this situation, this feature might prevent access users from coming online again after an abnormal offline event.
By default, the DHCP server tries to allocate the same IP address as the previous allocation to the same user.
With this feature enabled, the DHCP server tries to allocate a new IP address to a user every time the user acquires an IP address. This feature is applicable to the scenarios where each user is identified by IP address. In such a network scenario, it is required that a user must obtain different IP addresses for each IP address acquisition.
With this feature enabled, the DHCP server deletes the existing lease (if any) for a user and assigns that user a new IP address when the following events occur:
·     The server receives a DHCP-DISCOVER message from the user.
·     The server receives a DHCP-REQUEST message sent by the user in an attempt to reconnect to the network after a disconnection.
# Enable random IP address allocation.
[Sysname] ip pool 1
[Sysname-ip-pool-1] allocate-new-ip enable
This command will enable the random address allocation mode. Enable it? [Y/N]:
bims-server
Use bims-server to specify the IP address, port number, and shared key of the BIMS server in an IP pool.
Use undo bims-server to restore the default.
undo bims-server
No BIMS server information is specified.
IP pool view
ip ip-address: Specifies the IP address of the BIMS server.
port port-number: Specifies the port number of the BIMS server, in the range of 1 to 65534.
simple: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key string. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 1 to 53 characters. The DHCP client uses the shared key to encrypt packets sent to the BIMS server.
# Specify BIMS server IP address 1.1.1.1, port number 80, and shared key aabbcc in IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] bims-server ip 1.1.1.1 port 80 sharekey simple aabbcc
display ip pool
bootfile-name
Use bootfile-name to specify a configuration file name or URL.
Use undo bootfile-name to restore the default.
bootfile-name { bootfile-name | url }
undo bootfile-name
No configuration file name or URL is specified.
IP pool view
bootfile-name: Specifies the configuration file name, a case-sensitive string of 1 to 127 characters.
url: Specifies the HTTP URL of the configuration file. It is a case-sensitive string of 1 to 127 characters.
To specify a configuration file on a TFTP server, use the bootfile-name argument.
To specify a configuration file on an HTTP server, use the url argument.
# Specify configuration file name boot.cfg in IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] bootfile-name boot.cfg
# Specify configuration file URL http://10.1.1.1/boot.cfg in IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] bootfile-name http://10.1.1.1/boot.cfg
display ip pool
next-server
class ip-pool
Use class ip-pool to specify an IP pool for a DHCP user class.
Use undo class ip-pool to remove the IP pool specified for a DHCP user class.
undo class class-name ip-pool
No IP pool is specified for a DHCP user class.
DHCP policy view
class-name: Specifies a DHCP user class by its name, a case-insensitive string of 1 to 63 characters.
pool-name: Specifies an IP pool by its name, a case-insensitive string of 1 to 63 characters.
You can specify only one IP pool for a DHCP user class in a DHCP policy. If you execute this command multiple times for a user class, the most recent configuration takes effect.
# Specify IP pool pool1 for DHCP user class test in DHCP policy 1.
[Sysname] dhcp policy 1
[Sysname-dhcp-policy-1] class test ip-pool pool1
default ip-pool
dhcp policy
ip pool
class option-group
Use class option-group to specify a DHCP option group for a DHCP user class.
Use undo class option-group to remove the configuration.
undo class class-name option-group
No DHCP option group is specified for a DHCP user class.
IP pool view
option-group-number: Specifies a DHCP option group by its number in the range of 1 to 32768.
When receiving a DHCP-DISCOVER message, the server compares the client against the user classes in the order that they are specified by this command. If a match is found, the server assigns the client the DHCP options in the option group. If multiple matches are found, the server selects option groups by using the following methods:
·     If the option groups have options in common, the server selects the option group specified for the first matching user class.
·     If the option groups have different options, the server selects all the matching option groups.
You can specify only one option group for a DHCP user class in an IP pool. If you execute this command multiple times for a user class, the most recent configuration takes effect.
# Specify DHCP option group 1 for user class user in IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] class user option-group 1
dhcp option-group
class range
Use class range to specify an IP address range for a DHCP user class.
Use undo class range to remove the IP address range for the DHCP user class.
undo class class-name range
No IP address range is specified for a DHCP user class.
IP pool view
class-name: Specifies a DHCP user class name, a case-insensitive string of 1 to 63 characters. If the specified user class does not exist, the DHCP server will not assign the addresses in the address range specified for the user class to any clients.
The class range command allows you to divide an address range into multiple address ranges for different DHCP user classes. The address range for a user class must be within the primary network segment specified by the network command. If the DHCP client does not match any DHCP user class, the DHCP server selects an address in the IP address range specified by the address range command. If the address range has no assignable IP addresses or no address range is configured, the address allocation fails.
After you specify an address range for a user class, you cannot use the network secondary command to specify a secondary network segment in the IP pool.
You can specify only one address range for a DHCP user class in an IP pool. If you execute this command multiple times for a DHCP user class, the most recent configuration takes effect.
# Specify an IP address range of 192.168.8.1 through 192.168.8.150 for DHCP user class user in IP pool 1.
[Sysname] ip pool 1
[Sysname-ip-pool-1] class user range 192.168.8.1 192.168.8.150
address range
dhcp class
display ip pool
default ip-pool
Use default ip-pool to specify the default IP pool.
Use undo default ip-pool to restore the default.
default ip-pool pool-name
No default IP pool is specified.
DHCP policy view
In a DHCP policy, the DHCP server uses the default IP pool to assign IP addresses and other parameters to clients that do not match any user classes. If no default IP pool is specified or the default IP pool does not have assignable IP addresses, the address assignment fails.
You can specify only one default IP pool in a DHCP policy. If you execute this command multiple times, the most recent configuration takes effect.
# Specify IP pool pool1 as the default IP pool in DHCP policy 1.
[Sysname-dhcp-policy-1] default ip-pool pool1
class ip-pool
dhcp policy
dhcp apply-policy
Use dhcp apply-policy to apply a DHCP policy to an interface.
Use undo dhcp apply-policy to restore the default.
dhcp apply-policy policy-name
No DHCP policy is applied to an interface.
Interface view
policy-name: Specifies a DHCP policy by its name, a case-insensitive string of 1 to 63 characters.
You can apply only one DHCP policy to an interface. If you execute this command multiple times, the most recent configuration takes effect.
# Apply DHCP policy test to Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp apply-policy test
dhcp policy
Use dhcp authorized-ip-conflict ignore to ignore authorization IP address conflicts.
Use undo dhcp authorized-ip-conflict ignore to restore the default.
Authorization IP address conflicts are not ignored. After DHCP is enabled on the DHCP server, the server performs conflict detection for authorization IP addresses.
An AAA server might authorize a new user an IP address the same as the IP address of an online user. The DHCP server can detect this conflict and inform the access module that this IP address is not available. As a result, the new user cannot come online.
In some networks, a user might come online and go offline frequently, and the AAA server might authorize the user the same IP address each time the user comes online. To ensure that the user can obtain the IP address and come online successfully, configure the DHCP server to ignore authorization IP address conflicts. For more information about AAA, see BRAS Services Configuration Guide.
This feature is applicable only to PPPoE access networks. For more information about PPPoE, see BRAS Services Configuration Guide.
# Ignore authorization IP address conflicts.
[Sysname] dhcp authorized-ip-conflict ignore
dhcp class
Use dhcp class to create a DHCP user class and enter its view, or enter the view of an existing DHCP user class.
Use undo dhcp class to delete the specified DHCP user class.
dhcp class class-name
undo dhcp class class-name
No DHCP user classes exist.
class-name: Specifies the name of a DHCP user class, a case-insensitive string of 1 to 63 characters.
In the DHCP user class view, you can use the if-match command to configure match rules to group clients to the user class.
# Create DHCP user class test and enter DHCP user class view.
[Sysname] dhcp class test
[Sysname-dhcp-class-test]
address range
class ip-pool
class option-group
class range
dhcp policy
if-match
dhcp option-group
Use dhcp option-group to create a DHCP option group and enter its view, or enter the view of an existing DHCP option group.
Use undo dhcp option-group to delete a DHCP option group.
undo dhcp option-group option-group-number
No DHCP option groups exist.
option-group-number: Assigns a number to the DHCP option group, in the range of 1 to 32768.
# Create DHCP option group 1 and enter DHCP option group view.
[Sysname] dhcp option-group 1
[Sysname-dhcp-option-group-1]
class option-group
option
dhcp policy
Use dhcp policy to create a DHCP policy and enter its view, or enter the view of an existing DHCP policy.
Use undo dhcp policy to delete a DHCP policy.
dhcp policy policy-name
undo dhcp policy policy-name
No DHCP policies exist.
policy-name: Assigns a name to the DHCP policy. The policy name is a case-insensitive string of 1 to 63 characters.
In DHCP policy view, you can specify IP pools for different user classes. Clients matching a user class will obtain IP addresses and other parameters from the specified IP pool.
For a DHCP policy to take effect, you must apply it to an interface.
# Create DHCP policy test and enter its view.
[Sysname] dhcp policy test
[Sysname-dhcp-policy-test]
class ip-pool
default ip-pool
dhcp apply-policy
dhcp class
dhcp route-log enable
Use dhcp route-log enable to enable route logging for all IP address pools.
Use undo dhcp route-log enable to disable route logging for all IP address pools.
Route logging is disabled for all IP address pools.
This feature enables the DHCP server to generate log messages for route events that occur in IP address pools. Route events include network route adding or deletion.
To enable route logging for IP address pools, use one of the following commands:
·     dhcp route-log enable
This command enables route logging for all types of IP address pools on the DHCP server.
·     route-log enable
This command enables route logging for a single IP address pool on the DHCP server. To enable route logging for only one IP address pool, perform the following task:
a.     Verify that route logging is disabled for all IP address pools on the DHCP server.
b.     You can use the undo dhcp route-log enable command to disable route logging for all IP address pools.
c.     Use the route-log enable command in the view of the target IP address pool.
# Enable route logging for all IP address pools on the DHCP server.
[Sysname] dhcp route-log enable
route-log enable
dhcp server allocated-ip threshold
Use dhcp server allocated-ip threshold to set the IP address allocation success rate threshold. The success rate is the rate of successfully allocated IP addresses to received DHCP requests within 5 minutes.
Use undo dhcp server allocated-ip threshold to restore the default.
dhcp server allocated-ip threshold threshold-value
No SNMP notification is sent for an IP address allocation success rate threshold violation.
threshold-value: Specifies the success rate threshold in percentage in the range of 1 to 100.
If the IP address allocation success rate is lower than the threshold, the DHCP module sends an SNMP notification to report the event.
# Set the IP address allocation success rate threshold to 85%.
[Sysname] dhcp server allocated-ip threshold 85
snmp-agent trap enable dhcp server
dhcp server always-broadcast
Use dhcp server always-broadcast to enable the DHCP server to always broadcast responses.
Use undo dhcp server always-broadcast to restore the default.
The DHCP server reads the broadcast flag in a DHCP request to decide whether to broadcast or unicast the response.
This command enables the DHCP server to ignore the broadcast flag in DHCP requests and always broadcast all responses.
The DHCP server always unicasts a response in the following situations, regardless of whether this command is executed:
·     The DHCP request is from a DHCP client that has an IP address (the ciaddr field is not 0).
·     The DHCP request is forwarded by a DHCP relay agent from a DHCP client (the giaddr field is not 0).
# Enable the DHCP server to always broadcast all responses.
[Sysname] dhcp server always-broadcast
dhcp server apply ip-pool
Use dhcp server apply ip-pool to apply an IP pool to an interface.
Use undo dhcp server apply ip-pool to restore the default.
No IP pool is applied to an interface.
Interface view
pool-name: Specifies the name of an IP pool, a case-insensitive string of 1 to 63 characters.
Upon receiving a DHCP request from the interface, the DHCP server searches for a static binding for the client from all IP pools. If no static binding is found, the server assigns configuration parameters from the IP pool applied on the interface to the client. If the IP pool has no assignable IP address or does not exist, the DHCP client cannot obtain an IP address.
When you apply an IP pool to an interface, make sure the IP pool contains a network segment that belongs to the same network segment as the IP address of the interface. If this requirement is not met, the clients attached to the interface will be unable to obtain an IP address from the IP pool.
# Apply IP pool 0 to Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp server apply ip-pool 0
ip pool
dhcp server bootp ignore
Use dhcp server bootp ignore to configure the DHCP server to ignore BOOTP requests.
Use undo dhcp server bootp ignore to restore the default.
The DHCP server does not ignore BOOTP requests.
The lease duration of IP addresses obtained by BOOTP clients is unlimited. For scenarios that do not allow unlimited leases, you can configure the DHCP server to ignore BOOTP requests.
# Configure the DHCP server to ignore BOOTP requests.
[Sysname] dhcp server bootp ignore
dhcp server bootp reply-rfc-1048
Use dhcp server bootp reply-rfc-1048 to enable the sending of BOOTP responses in RFC 1048 format.
Use undo dhcp server bootp reply-rfc-1048 to disable this feature.
This feature is disabled. The DHCP server does not process the Vend field of RFC 1048-incompliant requests but copies the Vend field into responses.
Not all BOOTP clients can send requests compliant with RFC 1048. This command enables the DHCP server to fill the Vend field in RFC 1048-compliant format in DHCP responses to RFC 1048-incompliant requests sent by BOOTP clients.
This command takes effect only when BOOTP is used to request statically bound IP addresses.
# Enable the sending of BOOTP responses in RFC 1048 format on the DHCP server.
[Sysname] dhcp server bootp reply-rfc-1048
dhcp server check mac-address
Use dhcp server check mac-address to enable MAC address check on the DHCP server.
Use undo dhcp server check mac-address to disable MAC address check on the DHCP server.
MAC address check is disabled on the DHCP server.
Interface view
This feature enables the DHCP server to compare the chaddr field of a received DHCP request with the source MAC address in the frame header. If they are the same, the DHCP server verifies the packet legal and continues processing the packet. If they are not the same, the DHCP server discards the request.
# Enable MAC address check on the DHCP server.
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] dhcp server check mac-address
dhcp server database filename
Use dhcp server database filename to configure the DHCP server to back up the DHCP bindings to a file.
Use undo dhcp server database filename to restore the default.
The DHCP server does not back up the DHCP bindings.
filename: Specifies the name of a local backup file, a case-insensitive string of 1 to 255 characters. For information about the filename argument, see Fundamentals Configuration Guide.
url url: Specifies the URL of a remote backup file, a case-sensitive string of 1 to 255 characters. Do not include a username or password in the URL.
username username: Specifies the username for accessing the URL of the remote backup file, a case-sensitive string of 1 to 32 characters. Do not specify this option if a username is not required for accessing the URL of the remote backup file.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 32 characters. Its encrypted form is a case-sensitive string of 1 to 73 characters. Do not specify this argument if a password is not required for accessing the URL of the remote backup file.
The command automatically creates the file if you specify a nonexistent file.
With this command executed, the DHCP server backs up its bindings immediately and runs auto backup. The server, by default, waits 300 seconds after a binding change to update the backup file. You can use the dhcp server database update interval command to change the waiting time. If no DHCP binding changes, the backup file is not updated.
As a best practice, back up the bindings to a remote file. If you use the local storage medium, the frequent erasing and writing might damage the medium and then cause the DHCP server to malfunction.
When the backup file is on a remote device, follow these restrictions and guidelines to specify the URL, username, and password:
·     If the file is on an FTP server, enter URL in the following format: ftp://server address:port/file path, where the port number is optional.
·     If the file is on a TFTP server, enter URL in the following format: tftp://server address:port/file path, where the port number is optional.
·     The username and password must be the same as those configured on the FTP server. If the server authenticates only the username, the password can be omitted.
·     If the IP address of the server is an IPv6 address, enclose the address in a pair of brackets, for example, ftp://[1::1]/database.dhcp.
·     You can also specify the DNS domain name for the server address field, for example, ftp://company/database.dhcp.
# Configure the DHCP server to back up its bindings to file database.dhcp.
[Sysname] dhcp server database filename database.dhcp
# Configure the DHCP server to back up its bindings to file database.dhcp in the working directory of the FTP server at 10.1.1.1.
[Sysname] dhcp server database filename url ftp://10.1.1.1/database.dhcp username 1 password simple 1
dhcp server database update now
dhcp server database update stop
Use dhcp server database update interval to set the waiting time for the DHCP server to update the backup file after a DHCP binding change.
Use undo dhcp server database update interval to restore the default.
The DHCP server waits 300 seconds to update the backup file after a DHCP binding change. If no DHCP binding changes, the backup file is not updated.
interval: Specifies the waiting time in the range of 60 to 864000 seconds.
When a DHCP binding is created, updated, or removed, the waiting period starts. The DHCP server updates the backup file when the waiting period is reached. All bindings changed during the period will be saved to the backup file.
The waiting time takes effect only after you configure the DHCP binding auto backup by using the dhcp server database filename command.
# Set the waiting time to 10 minutes for the DHCP server to update the backup file.
[Sysname] dhcp server database update interval 600
Use dhcp server database update now to manually save the DHCP bindings to the backup file.
Each time this command is executed, the DHCP bindings are saved to the backup file.
For this command to take effect, you must configure the DHCP auto backup by using the dhcp server database filename command.
# Manually save the DHCP bindings to the backup file.
[Sysname] dhcp server database update now
Use dhcp server database update stop to terminate the download of DHCP bindings from the backup file.
The DHCP server does not provide services during the binding download process. If the connection disconnects during the process, the waiting timeout timer is 60 minutes. When the timer expires, the DHCP server stops waiting and starts providing address allocation services.
To enable the DHCP server to provide services without waiting for the connection to be repaired, use this command to terminate the download immediately. The IP addresses associated with the undownloaded bindings will be assigned to clients. Address conflicts might occur.
# Terminate the download of the backup DHCP bindings.
[Sysname] dhcp server database update stop
dhcp server forbidden-ip
Use dhcp server forbidden-ip to exclude IP addresses from DHCP allocation globally.
Use undo dhcp server forbidden-ip to remove IP addresses from the forbidden IP list.
undo dhcp server forbidden-ip start-ip-address [ end-ip-address ] [ vpn-instance vpn-instance-name ]
No IP addresses are excluded from DHCP allocation globally.
end-ip-address: Specifies the end IP address, which cannot be lower than the start IP address. To exclude a range of IP addresses from DHCP allocation, you must specify the end IP address. If you do not specify this argument, only the start IP address is excluded from DHCP allocation.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the excluded IP addresses belong to the public network, do not specify this option.
Application scenarios
The IP addresses of some devices such as the gateway and FTP server cannot be assigned to clients. Use this command to exclude such addresses from DHCP allocation.
If an IP address already has a static DHCP binding, you cannot specify that IP address in this command. To configure a static binding for an IP address, use the static-bind command.
The address or address range specified for the undo dhcp server forbidden-ip command must be the same as that specified for the dhcp server forbidden-ip command. To remove an IP address from the specified address range, you must remove the entire address range.
You can execute this command multiple times to exclude multiple IP address ranges from DHCP allocation.
# Exclude the IP addresses of 10.110.1.1 through 10.110.1.63 from DHCP allocation globally.
[Sysname] dhcp server forbidden-ip 10.110.1.1 10.110.1.63
forbidden-ip
static-bind
Use dhcp server multi-ip per-mac enable to enable allocation of different IP addresses to DHCP clients with the same MAC address.
Use undo dhcp server multi-ip per-mac enable to disable allocation of different IP addresses to DHCP clients with the same MAC address.
If the DHCP server has assigned IP addresses to DHCP clients, you cannot enable or disable this feature. If you do so, the system displays an error message.
This command is mutually exclusive with the dhcp session-mismatch action command.
# Enable allocation of different IP addresses to DHCP clients with the same MAC address.
[Sysname] dhcp server multi-ip per-mac enable
dhcp server ping packets
Use dhcp server ping packets to set the maximum number of ping packets.
Use undo dhcp server ping packets to restore the default.
The maximum number of ping packets is 1.
number: Sets the maximum number of ping packets, in the range of 0 to 10. To disable the address conflict detection, set the value to 0.
To avoid IP address conflicts, the DHCP server pings an IP address before assigning it to a DHCP client.
If a ping attempt succeeds, the server determines that the IP address is in use and picks a new IP address. If all the ping attempts fail, the server assigns the IP address to the requesting DHCP client.
IP address conflict detection is available only for common IP address pools in non-BRAS scenarios.
# Set the maximum number of ping packets to 10.
[Sysname] dhcp server ping packets 10
dhcp server ping timeout
display dhcp server conflict
reset dhcp server conflict
Use dhcp server ping timeout to set the ping response timeout time on the DHCP server.
Use undo dhcp server ping timeout to restore the default.
The ping response timeout time is 500 milliseconds.
milliseconds: Specifies the timeout time in the range of 0 to 10000 milliseconds. To disable the ping operation for address conflict detection, set the value to 0 milliseconds.
# Set the response timeout time to 1000 milliseconds.
[Sysname] dhcp server ping timeout 1000
dhcp server policy-first enable
Use dhcp server policy-first enable to enable policy-first IP pool selection for IPoE users.
Use undo dhcp server policy-first enable to restore the default.
The device uses the AAA authorization IP pool for IPoE users.
Layer 3 Ethernet interface
Layer 3 aggregate interface
This feature enables the DHCP server to preferentially select the IP pool specified for the DHCP policy for IPoE users.
You must determine the IP pool selection method before IPoE users come online. If you modify the IP pool selection method after IPoE users come online, IPoE users that have obtained addresses cannot correctly extend the lease duration. When an address lease expires, the IPoE user goes offline, and the IPoE session is deleted.
Example
# Enable policy-first IP pool selection for IPoE users on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp server policy-first enable
authorization-attribute (BRAS Services Command Reference)
dhcp server relay information enable
Use dhcp server relay information enable to enable the DHCP server to handle Option 82.
Use undo dhcp server relay information enable to configure the DHCP server to ignore Option 82.
The DHCP server handles Option 82.
Upon receiving a DHCP request that contains Option 82, the server copies the original Option 82 into the response. If the server is configured to ignore Option 82, the response will not contain Option 82.
# Configure the DHCP server to ignore Option 82.
[Sysname] undo dhcp server relay information enable
dhcp server reply-exclude-option60
Use dhcp server reply-exclude-option60 to disable the DHCP server from encapsulating Option 60 in DHCP replies.
Use undo dhcp server reply-exclude-option60 to restore the default.
The DHCP server can encapsulate Option 60 in DHCP replies.
If you do not disable the capability, the DHCP server encapsulates Option 60 in a DHCP reply in the following situations:
·     The received DHCP packet contains Option 60.
·     Option 60 is configured for the IP pool.
If you disable the capability, the DHCP server does not encapsulate Option 60 in DHCP replies.
# Disable the DHCP server from encapsulating Option 60 in DHCP replies.
[Sysname] dhcp server reply-exclude-option60
dhcp server request-ip-address check
Use dhcp server request-ip-address check to enable the DHCP server to return a DHCP-NAK message if the client notions of their IP addresses are incorrect.
Use undo dhcp server request-ip-address check to restore the default.
The DHCP server does not return a DHCP-NAK message if the client notions of their IP addresses are incorrect.
A DHCP client can send a DHCP-REQUEST message directly or upon receiving a DHCP-OFFER message. Upon receiving the request, the DHCP server will check if the client notion of its IP address is correct. If the requested IP address is different from the allocated one or has no matching lease record, the DHCP server remains silent by default. After the allocated IP address lease for the client expires, the DHCP server will make response to request from the client.
This feature enables the DHCP server to return DHCP-NAK messages if the client notions of their IP addresses are incorrect. After receiving the DHCP-NAK message, the DHCP client will request an IP address again.
# Enable the DHCP server to return a DHCP-NAK message if the client notions of their IP addresses are incorrect.
[Sysname] dhcp server request-ip-address check
dhcp select server
display dhcp address offline-record
Use display dhcp address offline-record to display DHCP user offline records.
display dhcp address offline-record [ ip-address ip-address | mac-address mac-address | start-time start-time start-date end-time end-time end-date | user-id user-id ]
ip-address ip-address: Specifies a DHCP user by its IP address.
mac-address mac-address: Specifies a DHCP user by its MAC address.
start-time start-time start-date end-time end-time end-date: Displays the user offline records generated within the specified time range.
·     start-time start-time start-date: Specifies the start date and time. The start-time argument represents the start time in HH:MM:SS (hour:minute:second) format, and its value range is 0:0:0 to 23.59:59. The start-date argument represents the start date in MM/DD/YYYY (month/day/year) or YYYY/MM/DD (year/month/day) format.
¡     MM—The value range is 1 to 12.
¡     DD—The value range varies by month.
¡     YYYY—The value range is 2000 to 2035.
·     end-time end-time end-date: Specifies the end date and time. The end-time argument represents the end time in HH:MM:SS (hour:minute:second) format, and its value range is 0:0:0 to 23.59:59. The end-date argument represents the end date in MM/DD/YYYY (month/day/year) or YYYY/MM/DD (year/month/day) format.
user-id user-id: Specifies a DHCP user by its user ID. The user ID is a case-insensitive string in the range of 1 to fffffffe.
# Display DHCP user offline records.
<Sysname> display dhcp address offline-record
DHCP-OFFLINE-RECORD-BRIEF(Total: 1)
  Entry type: Address (Server Add)
  IP address: 84.64.0.2
  MAC address: 0010-9400-006e
  Access type: IPoE
  Access interface: Ten-GigabitEthernet3/1/1
  VPN instance: N/A
  User ID: 0x8410000e
  SVLAN: 203
  CVLAN: N/A
  Offline time: Oct 12 04:34:06 2023
  Online time: Oct 12 04:31:21 2023
  Update time: Oct 12 04:31:21 2023
  Offline reason: : Release message received
  Offline code: 20
  BackUp Info: VSRP BackUp
  IP address: 200.144.0.2
  MAC address: 0010-9438-2824
  Access type: IPoE
  Access interface: Ten-GigabitEthernet3/1/2
  VPN instance: N/A
  User ID: 0x713e
  SVLAN: 3735
  CVLAN: 1
  Offline time: Apr 12 14:00:00 2024
  Online time: Jan  1 00:00:00 1970
  Offline reason: No error code
  Offline code: 0
Table 5 Command output
BackUp Info
Backup type.
·     HA BackUp—HA.
·     CPDR BackUp—CPDR.
·     VSRP BackUp—VSRP.
Entry type
Type of the DHCP entry:
·     Address (Relay Add)— Address lease entry on the DHCP relay agent.
·     Address (Server Add) —Address lease entry on the DHCP server.
·     Address Cinfo—Address Cinfo entry.
·     Address Reserve—Address reservation entry.
·     Address Static—Static address binding entry.
IP address
IPv4 address of the user. If the user does not have an IPv4 address, this field displays N/A.
MAC address
MAC address of the user. If the user does not have an MAC address, this field displays N/A.
Access type
Access type of the user:
·     COMMON—DHCP user.
·     IPoE—IPoE user.
·     PPPoE—PPPoE user.
·     PPP-AUTH-IP—PPP authorization address user.
·     PKT-TRIGGER—Unknown-source user.
·     STATIC—IPoE static user.
·     SUBNET—IPoE subnet-leased user.
Access interface
Access interface to which the user is attached. If the user does not use an access interface, this field displays N/A.
VPN instance
Name of the VPN instance to which the user belongs. If the user belongs to the public network, this field displays N/A.
User ID
Unique ID of the user in the UCM module. If the user does not have an ID, this field displays N/A.
SVLAN
Outer VLAN to which the DHCP access user belongs. If the user does not belong to a VLAN, this field displays N/A.
CVLAN
Inner VLAN to which the DHCP access user belongs. If the user does not belong to a VLAN, this field displays N/A.
Offline time
Time when the user went offline.
Online time
Time when the lease state of the user changed to Committed. If the time is an invalid value, this field will display N/A.
Update time
Time when the lease in Committed state was updated for the user. If the time is an invalid value, this field will display N/A.
Offline reason
Reason why the user went offline.
Offline code
Code of the reason why the user went offline.
reset dhcp address offline-record
display dhcp gateway-route
Use display dhcp gateway-route to display information about the gateway routes that the UP received from the CP.
display dhcp gateway-route [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about the gateway routes issued by the CP on the public network.
Use this command on a UP to view information about gateway routes received from the CP.
After you specify a gateway in a BAS or ODAP IP pool on the CP by using the gateway command, the CP issues a gateway route for the pool to UPs as follows:
·     If the IP pool type is BAS, the CP issues the gateway route to the following UPs:
¡     UPs in the UP backup profile bound to the IP pool.
¡     UPs bound to the IP pool.
¡     UPs whose remote interfaces or subinterfaces are bound to the IP pool.
·     If the IP pool type is ODAP, the CP issues the gateway route to all UPs connected to the CP.
# Display information about the gateway routes received from the CP on the public network.
<Sysname> display dhcp gateway-route
Gateway route count: 1
IP address: 100.100.100.100
VPN instance:
Virtual MAC: 1122-3344-5566
Timeout: 100(sec)
Valid flag: 1
Creation time: Apr 20 13:18:22 2021
Update time: Apr 20 14:18:22 2021
# Display information about the gateway routes received from the CP in VPN instance a.
<Sysname> display dhcp gateway-route vpn-instance a
VPN instance: a
Timeout: 100(sec)
Valid flag: 1
Table 6 Command output
Gateway route count
Number of gateway routes.
IP address
IP address of the gateway.
VPN instance
Name of the VPN instance. If the route is issued on the public network, this field is empty.
Virtual MAC
Virtual MAC address bound to the gateway IP address.
Timeout
Aging time of the gateway route, in seconds. If the route will never age out, this field displays 0.
Valid flag
Whether the route is effective:
·     0Ineffective. The route has not issued to the RIB.
·     1—Effective. The route has issued to the RIB.
Creation time
Date and time when the route was created. The format is MM DD hh:mm:ss YYYY.
·     MM—Represents the month.
·     DD—Represents the day.
·     hh—Represents the hours.
·     mm—Represents the minutes.
·     ss—Represents the seconds.
·     YYYY—Represents the year.
Update time
Date and time when the route was updated. The format is MM DD hh:mm:ss YYYY.
display dhcp network-route
Use display dhcp network-route to display information about the IPv4 subnet routes that the UP received from the CP.
display dhcp network-route [ ipv4-address mask-length ] [ vpn-instance vpn-instance-name ]
ipv4-address mask-length: Specifies a subnet by subnet address and mask length. The ipv4-address argument represents the IPv4 subnet address in dotted decimal notation. The mask-length argument represents the mask length for the subnet in the range of 1 to 30. If you do not specify a subnet, this command displays all subnet route information issued by the CP.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays subnet route information issued by the CP on the public network.
Use this command on a UP to view information about subnet routes received from the CP.
When a DHCP client comes online through a UP, the CP issues a route message for the subnet on which the client resides to the UP. The route message carries the tag for the subnet route and information about the client-attached interface on the UP.
The UP processes a subnet route message as follows:
·     If the UP is a physical UP, it directly adds the message to the RIB.
·     If the UP is a vUP, it performs the following tasks:
a.     Replace the original route tag in the message with that configured for the auto scaling group. For more information about route tag configuration for vUP auto scaling groups, see vUP auto scaling configuration in CP and UP Separation Configuration Guide.
b.     Add the new message to the RIB.
# Display information about the subnet routes received from the CP on the public network.
<Sysname>display dhcp network-route
Network route count: 1
IP address: 10.50.0.0
Mask length: 24
VPN instance:
Cost: 10, Preference: 0, Tag: 0
Tunnel source: 0.0.0.0, destination: 0.0.0.0
Interface: N/A, Scale-group: N/A, Tag-vUP: N/A
Valid flag: 1
Creation time: May 13 01:58:56 2021
Update time: May 13 01:58:56 2021
VirtualMAC: 0000-5e00-0102
Renew proxy info:
  DNS servers: 1.2.3.4
  Domain name: abc
  Option 125: N/A
  NBNS list: 1.3.4.5
  NetBIOS type: b-node
  Mode: server
  Client mask: 24
  Gateway: 10.50.0.1
# Display information about the subnet routes received from the CP in VPN instance a.
<Sysname> display dhcp network-route 1.1.1.0 24 vpn-instance a
IP address: 1.1.1.0
Mask length: 24
VPN instance: a
Cost: 10, Preference: 255, Tag: 10
Tunnel source: 10.0.0.1, destination: 10.0.0.2
Interface: VSI-Interface1, Scale-group: 100, Tag-vUP: 20
Valid flag: 1
Table 7 Command output
Network route count
Number of subnet routes.
IP address
IP address of the subnet.
Mask length
Mask length for the subnet.
VPN instance
Cost
Routing cost.
Preference
Priority value for the route.
Tag
Tag value for the route.
Tunnel source
Source address of the VSRP protection tunnel.
destination
Destination address of the VSRP protection tunnel.
User access interface on the vUP. Only VSI interface is supported. If the user does not come online through any vUP, this field displays N/A.
Scale-group
ID of the auto scaling group.
Tag-vUP
Route tag for the auto scaling group.
Valid flag
·     0—Ineffective. The route has not issued to the RIB.
Creation time
Update time
VirtualMAC
Virtual MAC address bound to the subnet route.
Renew proxy info
Lease renewal proxy information issued by the CP to the UP.
DNS servers
DNS server address. This field displays N/A if no DNS server address exists.
Domain name
Name of the ISP domain assigned to the DHCP client. This field displays N/A if no ISP domain is assigned.
Option 125
Option 125 assigned to the DHCP client. This field displays N/A if Option 125 is not assigned.
NBNS list
WINS server address assigned to the DHCP client. This field displays N/A if no WINS server address is assigned.
NetBIOS type
NetBIOS node type. Options include the following:
·     b-node—Broadcast node
·     h-node—Hybrid node
·     m-node—Mixed node
·     p-node—Peer-to-peer node
This field displays N/A if no NetBIOS node exists.
Mode
DHCP role of the CP that issued the IPv4 UNR information:
·     server—DHCP server.
·     relay—DHCP relay agent.
Client mask
Address mask of the DHCP client.
Gateway
Gateway address.
display dhcp pool-group-usage
Use display dhcp pool-group-usage to display address usage information for an IP pool group.
display dhcp pool-group-usage [ pool-group pool-group-name ]
pool-group pool-group-name: Specifies an IP pool group by its name. The pool-group-name argument is a case-insensitive string of 1 to 63 characters. If you do not specify this option, this command displays address usage information for all IP pool groups.
# Display address usage information for all IP pool groups.
<Sysname> display dhcp pool-group-usage
Pool group name         Total     Used      Utilization(%)
poolgroup1              91        1         1.10%
poolgroup2              245       1         0.41%
# Display address usage information for pool group poolgroup1.
<Sysname> display dhcp pool-group-usage pool-group poolgroup1
Table 8 Command output
Pool group name
Name of the IP pool group.
Total
Number of IP addresses in the IP pool group.
Used
Number of assigned IP addresses in the IP pool group.
Utilization(%)
Address usage of the IP pool group, in percentage.
display dhcp pool-usage
Use display dhcp pool-usage to display address usage information for an IP pool.
display dhcp pool-usage [ peak ] [ pool pool-name ]
peak: Displays peak address usage information for an IP pool. The displayed value is the highest address usage of the IP pool before you execute this command. If you do not specify this keyword, this command displays the real-time address usage of the IP pool.
pool pool-name: Specifies an IP pool by its name. The pool-name argument is a case-insensitive string of 1 to 63 characters. If you do not specify this option, this command displays address usage information for all IP pools.
If the peak address usage of an IP pool appeared multiple times, this command displays the peak address usage that appeared earliest.
# Display address usage information for all IP pools.
<Sysname> display dhcp pool-usage
Pool name             Total     Used      Utilization(%)
pool1                 91        1         1.10%
pool2                 245       1         0.41%
# Display address usage information for pool pool1.
<Sysname> display dhcp pool-usage pool pool1
pool1                 91        1         1.10%
# Display peak address usage information for all IP pools.
<Sysname> display dhcp pool-usage peak
Pool name             Peak utilization(%)   Time
pool1                 1.10%                 Mar 11 07:22:43 2021
pool2                 0.41%                 Mar 11 07:22:43 2021
# Display peak usage information for pool pool1.
<Sysname> display dhcp pool-usage peak pool pool1
pool1                 1.10%                 Mar 11 07:23:02 2021
Table 9 Command output
Pool name
Name of the IP pool.
Total
Number of IP addresses in the IP pool.
Used
Number of assigned IP addresses in the IP pool.
Utilization(%)
Address usage of the IP pool, in percentage.
Peak utilization(%)
Peak address usage of the IP pool, in percentage.
Time
Date and time when the address usage of the IP pool reached the peak, in the format of MM DD hh:mm:ss YYYY.
reset dhcp pool-usage peak
Use display dhcp server conflict to display information about IP address conflicts.
display dhcp server conflict [ interface interface-type interface-number | ip ip-address | vxlan vxlan-id ] [ vpn-instance vpn-instance-name ]
ip ip-address: Specifies an IP address.
vxlan vxlan-id: Specifies a VXLAN by its ID in the range of 0 to 16777215.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about IP address conflicts for the public network.
The DHCP server generates IP address conflict information in the following situations:
·     Before assigning an IP address to a DHCP client, the DHCP server pings the IP address and discovers that another host is using the address.
·     The DHCP client sends a DECLINE packet to the DHCP server to inform the server of an IP address conflict.
·     The DHCP server discovers that the only assignable address in the IP pool is its own IP address.
If you do not specify any parameters, this command displays information about all IP address conflicts.
# Display information about all IP address conflicts.
<Sysname> display dhcp server conflict
IP address          Detect time
4.4.4.1             Apr 25 16:57:20 2019
4.4.4.2             Apr 25 17:00:10 2019
Table 10 Command output
IP address
Conflicted IP address. If the IP address is reusable, the command displays an asterisk (*) in parentheses next to it.
Detect time
Time when the conflict was detected.
display dhcp server database
Use display dhcp server database to display information about DHCP binding auto backup.
# Display information about DHCP binding auto backup.
<Sysname> display dhcp server database
 Username                :
 Password                :
 Latest write time       :   Feb  8 16:09:53 2014
Table 11 Command output
File name
Name of the DHCP binding backup file.
Username
Username for accessing the URL of the remote backup file.
Password
Password for accessing the URL of the remote backup file. This field displays ****** if a password is configured.
Update interval
Waiting time in seconds after a DHCP binding change for the DHCP server to update the backup file.
Latest write time
Time of the latest update.
Status
Update state:
·     Writing—The backup file is being updated.
·     Last write succeeded—The backup file was successfully updated.
·     Last write failed—The backup file failed to be updated.
display dhcp server expired
Use display dhcp server expired to display information about expired leases.
display dhcp server expired [ [ interface interface-type interface-number | ip ip-address | mac mac-address | vxlan vxlan-id ] [ vpn-instance vpn-instance-name ] | pool pool-name ] [ verbose ]
mac mac-address: Specifies a MAC address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays the lease expiration information for the public network.
pool pool-name: Displays lease expiration information about the specified IP pool. The pool name is a case-insensitive string of 1 to 63 characters.
verbose: Displays detailed lease expiration information. If you do not specify this keyword, the command displays brief lease expiration information about all IP addresses.
DHCP assigns these expired IP addresses to DHCP clients when all available addresses have been assigned.
If you do not specify any parameters, this command displays information about all expired leases.
# Display information about all expired leases.
<Sysname> display dhcp server expired
IP address       Client-identifier/Hardware address    Lease expiration
4.4.4.6          3030-3066-2e65-3230-302e-3130-3234    Apr 25 17:10:47 2019
                 -2d45-7468-6572-6e65-7430-2f31
Table 12 Command output
IP address
Expired IP address.
Client ID or MAC address.
Lease expiration
Time when the lease expired.
# Display detailed information about all expired leases.
<Sysname> display dhcp server expired verbose
IP address: 192.168.56.3
  Pool name: 1
  Client-identifier: N/A
  Hardware address type: Ethernet
  Hardware address: 0000-0000-0002
  Lease expiration: Mar 16 16:00:22 2017
  Remaining reservation time: 136 years 2 months 6 hours 28 minutes 11 seconds
  IP address reservation mode: Based on client MAC
IP address: 5.5.5.5
  Pool name: 2
  Client-identifier: 0061-6161-612e-6161-6161-2e61-6161-612d-4745-302f-302f-33
  Hardware address: 0000-0000-0003
  Lease expiration: Mar 16 16:00:33 2017
  Remaining reservation time: 136 years 2 months 6 hours 28 minutes 22 seconds
  IP address reservation mode: Based on client ID
IP address: 3.3.3.5
  Pool name: abc
  Client-identifier: 0100-0000-0000-05
  Hardware address: 0000-0000-0005
  Lease expiration: Mar 16 16:10:33 2017
  Remaining reservation time: 2 months 6 hours 27 minutes 22 seconds
Table 13 Command output
IP address
Expired IP address.
Pool name
IP pool to which the expired IP address belongs.
Client-identifier
Client ID. If the request does not contain Option 61, this field displays N/A.
Hardware address type of the client: Ethernet, Token ring, or Unknown.
Lease expiration
Remaining time for reserving the expired IP address. If the reservation time expires, this field displays 0, and the expired IP address is deleted.
Reservation mode of the expired IP address:
·     Based on client ID—Reserve an expired IP address based on the client ID.
·     Based on client MAC—Reserve an expired IP address based on the client MAC address.
reserve expired-ip enable
reset dhcp server expired
display dhcp server free-ip
Use display dhcp server free-ip to display information about assignable IP addresses.
pool pool-name: Displays assignable IP addresses in the specified IP pool. The pool name is a case-insensitive string of 1 to 63 characters. If you do not specify an IP pool, this command displays all assignable IP addresses for all IP pools.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays assignable IP addresses in IP pools for the public network.
# Display assignable IP addresses in all IP pools.
<Sysname> display dhcp server free-ip
Pool name: 1
  Network: 10.0.0.0 mask 255.0.0.0
    IP ranges from 10.0.0.10 to 10.0.0.100
    IP ranges from 10.0.0.105 to 10.0.0.255
  Secondary networks:
    10.1.0.0 mask 255.255.0.0
      IP ranges from 10.1.0.0 to 10.1.0.255
    10.2.0.0 mask 255.255.0.0
      IP Ranges from 10.2.0.0 to 10.2.0.255
Pool name: 2
  Network: 20.1.1.0 mask 255.255.255.0
    IP ranges from 20.1.1.0 to 20.1.1.255
Table 14 Command output
Pool name
Network
Assignable network.
IP ranges
Assignable IP address ranges.
Secondary networks
Assignable secondary networks.
address range
ip pool
network
display dhcp server ip-in-use
Use display dhcp server ip-in-use to display DHCP address bindings.
display dhcp server ip-in-use [ [ interface interface-type interface-number | ip ip-address | subnet network-address mask-length | vxlan vxlan-id ] [ vpn-instance vpn-instance-name ] | pool pool-name | pool-group pool-group-name ] [ verbose ]
subnet network-address mask-length: Specifies a subnet by the network address and subnet mask length.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays DHCP address bindings for the public network.
pool pool-name: Displays DHCP address bindings in the specified IP pool. The pool name is a case-insensitive string of 1 to 63 characters.
verbose: Displays detailed information about DHCP address bindings. If you do not specify this keyword, this command displays brief information about DHCP address bindings.
If you do not specify any parameters, this command displays all DHCP address bindings.
The binding information can be used by other security modules only when the DHCP server is configured on the gateway of DHCP clients.
If the lease deadline exceeds the year 2100, the lease expiration time is displayed as After 2100.
# Display brief information about all DHCP address bindings.
<Sysname> display dhcp server ip-in-use
IP address       Client-identifier/    Lease expiration      Type
                 Hardware address
10.1.1.1         4444-4444-4444        Not used              Static(F)
10.1.1.2         0030-3030-2e30-3030-  May 1 14:02:49 2015   Auto(C)
                 662e-3030-3033-2d45-
                 7468-6572-6e65-74
10.1.1.3         0133-3037-392e-3933-  May 1 14:18:22 2016   Auto(C)
                 3037-2e39-3030-32
10.1.1.4         1111-1111-1111        After 2100            Static(C)
# Display brief binding information about IP address 10.1.1.2.
<Sysname> display dhcp server ip-in-use ip 10.1.1.2
IP address: 10.1.1.2/24
Giaddr: 10.1.1.10
Gateway: 10.1.1.1
Client identifier/Hardware address: 3030-3030-2e30-3030-662e-3030-3033-2d45-7468
-6572-6e65-74
Lease expiration: May 1 14:02:49 2015
Type: Auto(C)
Client access interface: XGE3/1/1
Outer VLAN: N/A
Inner VLAN: N/A
User ID: 0x3fffff
Table 15 Command output
IP address
IP address and mask length assigned.
Giaddr
IP address of the first DHCP relay agent that the DHCP request passes through.
Gateway
Default gateway address.
Client ID or hardware address. Client ID is a string of hexadecimal numbers, in which the first two characters represents the hardware type value.
·     If an ASCII string is used, the hardware type value is 00, which means no type.
·     If the hardware type is Ethernet, the type value is 01.
·     If the hardware type is token ring, the type value is 06.
Lease expiration
Lease expiration time:
·     Exact time (for example, May 1 14:02:49 2015)—Time when the lease will expire.
·     Not used—The IP address of the static binding has not been assigned to the specific client.
·     Unlimited—Infinite lease expiration time.
·     After 2100—The lease will expire after the year 2100.
Binding types:
·     Static(F)—A free static binding whose IP address has not been assigned.
·     Static(O)—An offered static binding whose IP address has been selected and sent by the DHCP server in a DHCP-OFFER packet to the client.
·     Static(C)—A committed static binding whose IP address has been assigned to the DHCP client.
·     Auto(O)—An offered dynamic binding whose IP address has been dynamically selected by the DHCP server and sent in a DHCP-OFFER packet to the DHCP client.
·     Auto(C)—A committed dynamic binding whose IP address has been dynamically assigned to the DHCP client.
Interface connected to the DHCP client.
Outer VLAN
Outer VLAN tag contained in the client's DHCP requests. If the request does not contain an outer VLAN tag, this field displays N/A.
Inner VLAN
Inner VLAN tag contained in the client's DHCP requests. If the request does not contain an inner VLAN tag, this field displays N/A.
User ID
ID of the DHCP user. If no user ID is configured, this field displays N/A.
# Display detailed information about all DHCP address bindings.
<Sysname> display dhcp server ip-in-use verbose
Basic information:
  IP address: 1.1.1.3
  Client ID: 0061-3230-652e-6537-6161-2e30-3230-362d-47
  Hardware address: a20e-e7aa-0206
  Lease expiration: Feb 29 19:33:13 2024
  Type: Auto(C)
  Pool: 1
  Network: 1.1.1.0/24
  VPN instance name:
  VPN instance index: 0
  Primary DNS server: 2.1.1.1
  Secondary DNS server: 3.1.1.1
  Online time: Feb 28 19:33:13 2024
  Update time: Feb 28 19:33:13 2024
Access information:
  Access type: CommonV4
  User ID: N/A
  Port: N/A
  SVLAN/CVLAN: -/-
  VSI Index: N/A
  Link ID: N/A
  UP-ID: N/A
  UP-ID for RMDB: N/A
  Virtual MAC: N/A
  Unr tag: 0
  Host name: N/A
  Option125: N/A
Interaction information:
  Gateway: 1.1.1.1
  Giaddr: N/A
  Server ID: N/A
  Relay gateway: N/A
ODAP information:
  Odap pool group: N/A
Table 16 Command output
IP address
Client-identifier
Client ID. Client ID is a string of hexadecimal numbers, in which the first two characters represents the hardware type value.
Hardware address
Hardware address of the DHCP client.
Lease expiration
·     Exact time—Time when the lease will expire, for example, May 1 14:02:49 2015.
Binding types:
Pool
Name of the address pool to which the lease belongs.
Network
Network segment to which the lease belongs.
VPN instance name
Name of the VPN instance to which the lease belongs.
VPN instance index
Index of the VPN instance to which the lease belongs.
Primary DNS server
Primary DNS server.
Secondary DNS server.
Online time
Update time
Access type
·     CommonV4—DHCP.
·     IPoEv4—IPoE.
·     PPPv4—PPP.
User ID
Unique ID of the user.
Access interface
Port
Incoming port for packets. If packets are not received on a Layer 2 port, this field displays N/A.
SVLAN/CVLAN
Outer VLAN tag and inner VLAN tag contained in the client's DHCP requests. If the request does not contain an inner or outer VLAN tag, this field displays a hyphen (-).
VSI Index
VSI name.
UP-ID
ID of the UP to which the user is attached.
UP-ID for RMDB
ID of the UP through which the user went online. The UP ID is stored in the RMDB.
Virtual MAC
Virtual MAC address of the user.
Unr tag
UNR tag.
Host name
Hostname (Option 12).
Gateway
Gateway address.
Giaddr
IP address that the DHCP relay agent uses for DHCP packet relaying. The IP address is recorded by the DHCP server.
Server ID
DHCP server ID. Only DHCP relay agents support this field.
Relay gateway
DHCP relay gateway addresses.
ODAP pool group
Name of the ODAP address pool group to which the lease belongs. If the lease does not belong an ODAP address pool group, this field displays N/A.
reset dhcp server ip-in-use
display dhcp server packet statistics
Use display dhcp server packet statistics to display packet statistics on the DHCP server.
display dhcp server packet statistics [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays DHCP server packet statistics for the public network.
# Display packet statistics on the DHCP server.
<Sysname> display dhcp server packet statistics
Messages received:                       0
  DHCPDISCOVER:                          0
  DHCPREQUEST:                           0
  DHCPDECLINE:                           0
  DHCPRELEASE:                           0
  DHCPINFORM:                            0
  BOOTPREQUEST:                          0
  ODAP DHCPOFFER:                        0
  ODAP DHCPACK:                          0
  ODAP DHCPNAK:                          0
  ODAP DHCPDISCOVER:                     0
  ODAP DHCPREQUEST:                      0
  ODAP DHCPRELEASE:                      0
  ODAP DHCPDECLINE:                      0
  ODAP DHCPFORCERENEW:                   0
  ODAP CPADDRESS:                        0
Messages sent:                           0
  DHCPOFFER:                             0
  DHCPACK:                               0
  DHCPNAK:                               0
  BOOTPREPLY:                            0
  ODAP DHCPOFFER:                        0
  ODAP DHCPACK:                          0
  ODAP DHCPNAK:                          0
  ODAP DHCPREQUEST:                      0
  ODAP DHCPRELEASE:                      0
  ODAP DHCPDECLINE:                      0
Bad Messages:                            0
Table 17 Command output
Messages received
DHCP messages received from clients:
·     DHCPDISCOVER.
·     DHCPREQUEST.
·     DHCPDECLINE.
·     DHCPRELEASE.
·     DHCPINFORM.
·     BOOTPREQUEST.
·     ODAP DHCPOFFER
·     ODAP DHCPACK
·     ODAP DHCPNAK
·     ODAP DHCPDISCOVER
·     ODAP DHCPREQUEST
·     ODAP DHCPRELEASE
·     ODAP DHCPDECLINE
·     ODAP DHCPFORCERENEW
Messages sent
DHCP messages sent to clients:
·     DHCPOFFER.
·     DHCPACK.
·     DHCPNAK.
·     BOOTPREPLY.
·     ODAP DHCPOFFER
·     ODAP DHCPACK
·     ODAP DHCPNAK
·     ODAP DHCPDISCOVER
·     ODAP DHCPREQUEST
·     ODAP DHCPRELEASE
·     ODAP DHCPDECLINE
Bad Messages
Number of error messages.
display dhcp server statistics
Use display dhcp server statistics to display the DHCP server statistics.
display dhcp server statistics [ pool pool-name | pool-group pool-group-name | domain domain-name | vpn-instance vpn-instance-name ]
pool pool-name: Specifies an IP address pool by its name, a case-insensitive string of 1 to 63 characters.
pool-group pool-group-name: Specifies an IP address pool group by its name, a case-insensitive string of 1 to 63 characters.
domain domain-name: Specifies an ISP domain by its name, a case-insensitive string of 1 to 255 characters.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays DHCP server statistics for the public network.
# Display the DHCP server statistics.
<Sysname> display dhcp server statistics
Pool number:                             10
Pool utilization:                        0.08%
Bindings:
  Automatic:                             300
  Manual:                                1
  Expired:                               0
Reserve:                               0
Conflicts:                               0
# Display statistics about IP address pool pool1.
<Sysname> display dhcp server statistics pool pool1
Total IP addresses:                      256
  Idle:                                  200
    Free:                                190
    Expired:                             9
    Conflict reusable:                   1
  Used:                                  50
    Automatic:                           40
    Manual:                              9
    Reserve:                             0
  Conflicts:                             3
  PreAlloc:                              0
  Forbidden:                             2
  Gateway:                               1
  Pool utilization:                      22.00%
# Display statistics about IP address pool group group1.
<Sysname> display dhcp server statistics pool-group group1
Bound pools: 1
Total IP addresses:                      254
  Idle:                                  253
    Free:                                253
    Expired:                             0
    Conflict reusable:                   0
  Used:                                  0
    Automatic:                           0
    Manual:                              0
    Reserve:                             0
  Conflicts:                             0
  PreAlloc:                              0
  Forbidden:                             0
  Gateway:                               0
  Pool utilization:                      0.39%
pool name: 1
  Idle:                                  253
    Free:                                253
    Expired:                             0
  Used:                                  0
    Automatic:                           0
    Manual:                              0
    Reserve:                             0
  Conflicts:                             0
  PreAlloc:                              0
  Forbidden:                             0
  Gateway:                               0
Table 18  Command output
Pool number
Total number of IP address pools. This field is not displayed when you display statistics for a specific IP address pool.
Pool name
Name of the IP address pool.
Pool utilization
Address usage of the IP address pool.
Bound pools
Number of IP address pools bound to the IP address pool group.
Total IP addresses
Total number of IP addresses in the IP address pool.
Idle
Number of idle IP addresses including:
·     FreeNumber of IP addresses that have not been assigned.
·     Expired—Number of IP addresses that are reclaimed after their leases expire and can be assigned again.
·     Conflict reusable—Number of conflicting IP addresses that can be assigned after one hour.
Used
Number of IP addresses that have been assigned:
·     AutomaticNumber of dynamically assigned IP addresses.
·     Manual—Number of statically assigned IP addresses.
·     Reserve—Number of reserved IP addresses.
PreAlloc
Number of pre-assigned IP addresses.
Conflicts
Number of conflicting IP addresses.
Forbidden
Number of IP addresses excluded from dynamic address assignment.
Gateway
Number of gateway addresses configured in the IP address pool.
reset dhcp server statistics
display dhcp-access count
Use display dhcp-access count to display the number of DHCP access users.
To display DHCP access user information, use the display dhcp-access user-table command.
# Display the number of DHCP access users on the device.
<Sysname> display dhcp-access count
Total access-user count:            20
Table 19 Command output
Number of DHCP access users.
display dhcp-access packet statistics
Use display dhcp-access packet statistics to display packet statistics for the DHCP access module.
# Display packet statistics for the DHCP access module.
<Sysname> display dhcp-access packet statistics
Received packets
  Received from clients                : 0
    DHCPDISCOVER                       : 0
    DHCPREQUEST                        : 0
    DHCPDECLINE                        : 0
    DHCPRELEASE                        : 0
    DHCPINFORM                         : 0
  Received from servers                : 0
    DHCPOFFER                          : 0
    DHCPACK                            : 0
    DHCPNAK                            : 0
Sent packets
  Send to clients                      : 0
    DHCPOFFER                          : 0
    DHCPACK                            : 0
    DHCPNAK                            : 0
  Send to servers                      : 0
    DHCPDISCOVER                       : 0
    DHCPREQUEST                        : 0
    DHCPDECLINE                        : 0
    DHCPRELEASE                        : 0
Table 20 Command output
Received packets
Statistics about received packets.
Number of packets received from DHCP clients.
DHCPDISCOVER
Number of received DHCP-DISCOVER packets.
DHCPREQUEST
Number of received DHCP-REQUEST packets.
DHCPDECLINE
Number of received DHCP-DECLINE packets.
DHCPRELEASE
Number of received DHCP-RELEASE packets.
DHCPINFORM
Number of received DHCP-INFORM packets.
Number of packets received from DHCP servers.
DHCPOFFER
Number of received DHCP-OFFER packets.
DHCPACK
Number of received DHCP-ACK packets.
DHCPNAK
Number of received DHCP-NAK packets.
Sent packets
Statistics about sent packets.
Send to clients
Number of packets sent to DHCP clients.
DHCPOFFER
Number of sent DHCP-OFFER packets.
DHCPACK
Number of sent DHCP-ACK packets.
DHCPNAK
Number of sent DHCP-NAK packets.
Send to servers
Number of packets sent to DHCP servers.
DHCPDISCOVER
Number of sent DHCP-DISCOVER packets.
DHCPREQUEST
Number of sent DHCP-REQUEST packets.
DHCPDECLINE
Number of sent DHCP-DECLINE packets.
DHCPRELEASE
Number of sent DHCP-RELEASE packets.
reset dhcp-access packet statistics
Use display dhcp-access user-table to display information about DHCP access users.
display dhcp-access user-table [ index index-value | mac-address mac-address | user-id user-id ]
index index-value: Specifies a DHCP user index in the range of 1 to 4294967294.
mac-address mac-address: Specifies the MAC address of a user, in the format of H-H-H.
user-id user-id: Specifies a user ID, in the range of 1 to fffffffe. The user ID is case insensitive.
If you do not specify any parameters, this command displays information about all DHCP access users on the device.
# Display information about all DHCP users on the device.
<Sysname> display dhcp-access user-table
DHCP-ACCESS-USER-INFO-BRIEF(Total:3)
  User ID                  : 0x40000001
  User index               : 1
  Interface                : Ten-GigabitEthernet3/1/1
  SVLAN                    : N/A
  CVLAN                    : N/A
  User MAC address         : 0000-0000-0007
  User state               : ONLINE
  VPN instance             : N/A
  User IP address          : 10.1.1.254/24
  Renew time               : 43200 seconds
  Rebind time              : 75600 seconds
  Gateway                  : 10.1.1.1
  Primary DNS server       : 10.1.1.2
  Second DNS server        : N/A
  Authorized pool          : test
  Authorized pool group    : N/A
  Real pool                : test1
  Option12 string          : N/A
  Option60 string          : N/A
  Option82 CircuitID       : N/A
  Option82 RemoteID        : N/A
  Option82 Vendor          : N/A
  Client ID                : 0032387
  Remaining Renew Time     : 43197 seconds
  Remaining Rebind Time    : 75597 seconds
  Remaining Lease Time     : 86397 seconds
  User ID                  : 0x40000002
  User index               : 2
  SVLAN                    : N/A
  CVLAN                    : N/A
  User MAC address         : 0000-0000-0008
  User state               : ONLINE
  VPN instance             : N/A
  User IP address          : 10.1.1.200/24
  Gateway                  : 10.1.1.1
  Real pool                : test1
  Client ID                : 003238671
  User ID                  : 0x13
  User index               : 13
  SVLAN                    : N/A
  CVLAN                    : N/A
  User MAC address         : 0010-9400-0005
  User state               : WAIT-SERVER-OFFER
  VPN instance             : N/A
  User IP address          : 0.0.0.0
  Gateway                  : N/A
  Primary DNS server       : N/A
  Real pool                : test1
  Client ID                : 003238612
  User entry aging time    : Mar  4 15:38:14 2021
# Display information about the DHCP user with MAC address 0050-ba50-7349.
<Sysname> display dhcp-access user-table mac-address 0050-ba50-7349
  User index               : 2
  SVLAN                    : N/A
  CVLAN                    : N/A
  User state               : ONLINE
  VPN instance             : N/A
  Gateway                  : N/A
  Real pool                : test1
  Client ID                : 010050ba507349
Table 21 Command output
DHCP-ACCESS-USER-INFO-BRIEF (Total:x)
Brief information about a DHCP user, and the number of DHCP users.
User ID
ID of the DHCP user, in hexadecimal notation.
User index
Index of the DHCP user, in decimal notation.
Interface from which the DHCP user came online.
SVLAN
SVLAN to which the DHCP user belongs. If the user does not belong to any SVLAN, this field displays N/A.
CVLAN
CVLAN to which the DHCP user belongs. If the user does not belong to any CVLAN, this field displays N/A.
User MAC address
MAC address of the DHCP user.
User state
Status of the DHCP user:
·     INIT—Initial state.
·     WAIT_UCM_REQ_ACK—Expecting an acknowledgment from UCM.
·     WAIT_SERVER_OFFER—Expecting a DHCP-OFFER from the DHCP server.
·     WAIT_CLIENT_REQ—Expecting a DHCP-REQUEST from the DHCP client.
·     WAIT_UCM_UP_ACK—Expecting a lease acknowledgment from UCM.
·     ONLINE—The user is online.
·     WAIT_UCM_OFFLINE_COMPLETE—Expecting an acknowledgment for lease release from UCM.
·     RENEW_WAIT_SERVER_REPLY—Expecting a DHCP-ACK for a lease renewal request from the DHCP server.
·     WAIT_SERVER_ACK—Expecting a DHCP-ACK from the DHCP server.
VPN instance
VPN instance to which the DHCP user belongs. If the user is on the public network, this field displays N/A.
User IP address
IP address and mask length that the DHCP user has obtained.
Renew time
Lease renewal time.
Rebind time
Lease rebind time.
Gateway
Default gateway.
Primary DNS server
IP address of the primary DNS server.
Second DNS server
IP address of the secondary DNS server.
Authorized pool
Name of the IP address pool used to authorize the DHCP access user.
Name of the IP address pool group used to authorize the DHCP access user.
Real pool
Name of the real IP address pool from which the DHCP access user obtained an IP address.
Date and time when the user entry will age out, in the format of MM DD hh:mm:ss YYYY.
When the aging timer expires, the DHCP server deletes the user entry.
If the DHCP user is online, the command does not display this field.
Option12 String
Host name of the DHCP client, in hexadecimal format. If Option 12 does not exist, this field displays N/A.
Option60 string
Vendor ID, in hexadecimal format. If Option 60 is not contained in user packets, this field displays N/A.
Option82 CircuitID
Circuit ID (in hexadecimal format) in Option 82. If no circuit ID exists, this field displays N/A.
Option82 RemoteID
Remote ID (in hexadecimal format) in Option 82. If no remote ID exists, this field displays N/A.
Option82 Vendor
Vendor-specific suboption (in hexadecimal format) in Option 82. If no vendor-specific suboption exists, this field displays N/A.
Client ID
DHCP client ID.
Remaining lease renewal time.
Remaining lease rebind time.
Remaining lifetime of the lease.
display ip pool
Use display ip pool to display information about IP pools.
display ip pool [ all | name pool-name | pool-group pool-group-name | [ vpn-instance vpn-instance-name ] [ bas { local | remote } ] ] [ verbose ]
all: Displays information about all IP pools for the public network and VPN instances.
name pool-name: Specifies an IP pool by its name. The pool-name argument is a case-insensitive string of 1 to 63 characters.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IP pool information for the public network.
bas{ local | remote }: Displays information about BAS IP pools. The local keyword represents local BAS IP pools. The remote keyword represents remote BAS IP pools.
verbose: Displays detailed IP pool information. If you do not specify this keyword, the command displays brief IP pool information.
If you do not specify the bas keyword, this command displays information about common IP pools.
# Display brief information about all common IP pools.
<Sysname> display ip pool
Pool name: 0 (lock strict)
  Pool index: 1
  Pool type: Common
  VPN instance:
    N/A
  Network 20.1.1.0 mask 255.255.255.0
  undo exhaustion log enable
  exhaustion trap enable
  route-log enable
  dhcp-server nak-count 10
  class a range 20.1.1.50 20.1.1.60
  bootfile-name abc.cfg
  dns-list 20.1.1.66 20.1.1.67 20.1.1.68
  domain-name www.aabbcc.com
  bims-server ip 192.168.0.51 sharekey cipher $c$3$K13OmQPi791YvQoF2Gs1E+65LOU=
  option 2 ip-address 1.1.1.1
  expired day 1 hour 2 minute 3 second 0
  reserve expired-ip mode client-id time 4294967295 limit 256000
  verify class
  ip-in-use threshold 100
  undo allocate-new-ip enable
  export host-route
Pool name: 1
  Pool index: 2
  Pool type: Common
  VPN instance:
    N/A
  route-log enable
  bims-server ip 192.168.0.51 port 50 sharekey cipher $c$3$K13OmQPi791YvQoF2Gs1E+65LOU=
  forbidden-ip 20.1.1.22 20.1.1.36 20.1.1.37
  forbidden-ip 20.1.1.22 20.1.1.23 20.1.1.24
  forbidden-ip-range 20.1.1.50 20.1.2.55
  gateway-list 1.1.1.1 2.2.2.2 4.4.4.4
  nbns-list 5.5.5.5 6.6.6.6 7.7.7.7
  netbios-type m-node
  expired day 1 hour 0 minute 0 second 0 allow-hint
  reserve expired-ip disable
  secondary networks: 20.1.2.0 mask 255.255.255.0
    address range 20.1.2.10 to 20.1.2.30
  secondary networks: 20.1.3.0 mask 255.255.255.0
    address range 20.1.3.10 to 20.1.3.30
Pool name: 2
  Pool index: 3
  Pool type: Common
  VPN instance:
    N/A
  undo exhaustion trap enable
  route-log enable
  address range 20.1.1.1 to 20.1.1.15
  class departmentA range 20.1.1.20 to 20.1.1.29
  class departmentB range 20.1.1.30 to 20.1.1.40
  next-server 20.1.1.33
  tftp-server domain-name www.example.org.cn
  tftp-server ip-address 192.168.0.120
  voice-config ncp-ip 10.1.1.2
  voice-config as-ip 10.1.1.5
  voice-config voice-vlan 3 enable
  voice-config fail-over 10.1.1.1 123*
  option 2 ip-address 1.1.1.3
  reserve expired-ip mode mac time 100 limit 100
  dhcp-server timeout 20
  master-server switch-delay 10
Pool name: 3
  Pool index: 4
  Pool type: Common
  VPN instance:
    N/A
  route-log enable
  expired unlimited
  static bindings:
    ip-address 10.10.1.2 mask 255.0.0.0
      hardware-address 00e0-00fc-0001 ethernet
    ip-address 10.10.1.3 mask 255.0.0.0
      client-identifier aaaa-bbbb
# Display brief information about local BAS IP pools.
<Sysname> display ip pool bas local
Pool name: 10
  Pool index: 5
  Pool type: Bas local
  VPN instance:
    N/A
  route-log enable
  gateway 11.1.1.0 mask 255.255.255.0
  class a range 11.1.1.50 20.1.1.60
  dns-list 11.1.1.66 20.1.1.67 11.1.1.68
  unr tag 100
  verify class
Table 22 Command output
Pool name (lock strict)
Name of the IP pool. The field in parentheses represents the lock state of the IP pool.
·     lockLocked in loose mode. The server responds to the lease renewal requests from online DHCP clients for IP addresses in the pool, but it does not assign IP addresses from the pool to new DHCP clients.
·     lock strict—Locked in strict mode. The server does not respond to the lease renewal requests from online DHCP clients for IP addresses in the pool or assign IP addresses from the pool to new DHCP clients.
If you do not lock the IP pool, this command will not display lock state information.
Pool index
Index of the IP pool.
Pool type
Type of the IP pool.
VPN instance
VPN instance to which the IP pool is applied. If the IP pool belongs to the public network, this field displays N/A.
gateway
Gateway IP address and network mask of the BAS IP pool.
Network
Network segment used to assign subnets.
IP resource exhaustion logging is enabled to record IP resource exhaustion events and recoveries from the IP resource exhaustion state. If this feature is disabled, this field displays undo exhaustion log enable.
IP resource exhaustion alarming is disabled. If this feature is enabled, this field displays exhaustion trap enable.
route-log enable
Route logging is enabled for the IP address pool. If route logging is disabled, this field displays undo route-log enable.
Maximum number of DHCP-NAK packets that the DHCP relay agent can receive from a DHCP server.
secondary networks
Assignable secondary network segments.
ip-address mask mask
Secondary network segment information:
·     IP address.
·     Mask.
address range
Assignable address range.
class class-name range
DHCP user class and its address range.
static bindings
Static IP-to-MAC/client ID bindings.
unr tag
Tag value of the network route.
option
Customized DHCP option.
expired
Lease duration. For example, expired day 1 hour 2 minute 3 second 4 indicates a lease of 1 day, 2 hours, 3 minutes, and 4 seconds.
If the lease never expires, this field displays unlimited.
If the DHCP server is allowed to use the DHCP client-suggested lease duration, allow-hint is displayed on the right of the lease duration.
remote server
DHCP server address in the remote BAS IP pool. After you create a remote BAS IP pool on the DHCP relay agent and execute the remote-server command, this field is displayed.
active remote server
Active DHCP server address.
After you create a remote BAS IP pool on the DHCP relay agent and execute the remote-server command, this field is displayed. The displayed value depends on the DHCP server selection algorithm configuration.
·     If the polling algorithm is used, this field displays all. The DHCP relay agent forwards DHCP requests to all DHCP servers.
·     If the master-backup algorithm is used, this field displays the IP address of the active DHCP server. The DHCP relay agent forwards DHCP requests to the active DHCP server first.
remote server pool status
Status of the remote BAS IP pool.
·     Available—The pool has assignable IP addresses.
·     Unavailable—The pool has no assignable IP addresses.
dhcp-server timeout
DHCP server response timeout time for DHCP server switchover, in seconds.
bootfile-name
Boot file name.
dns-list
DNS server IP address.
domain-name
Domain name suffix.
bims-server
BIMS server information.
forbidden-ip
IP addresses excluded from DHCP allocation in an address pool.
forbidden-ip-range
IP range excluded from DHCP allocation in an address pool.
gateway mask
IP address and mask of the gateway in the IP pool.
The delay (in minutes) to switch back to the master DHCP server.
ip-in-use threshold
IP address usage threshold for the IP address pool, in percentage.
Random IP address allocation is disabled. If this feature is enabled, this field displays allocate-new-ip enable.
reserve expired-ip
Whether IP address reservation is enabled.
IP address reservation mode, reservation time for expired IP addresses, and the maximum number of IP addresses that can be reserved in the IP pool.
In this example, the reservation mode is client ID, the reservation time is 4294967295 seconds, and the maximum number of IP addresses is 256000.
verify class
DHCP user class whitelist is enabled. If this feature is disabled, the command output does not display this field.
sub-networks
Subnets.
export-route
Advertise the network route.
preference
Preference for the network route to be advertised.
tag
Tag value for the network route to be advertised.
locked network(strict)
Locked subnet.
·     If the subnet is locked in loose mode, this field does not include a parenthesized strict string. The server responds to the lease renewal requests from online DHCP clients for IP addresses in the subnet. However, it does not assign IP addresses from the subnet to new DHCP clients.
·     If the subnet is locked in strict mode, this field includes a parenthesized strict string. The server does not respond to the lease renewal requests from online DHCP clients for IP addresses in the subnet or assign IP addresses from the subnet to new DHCP clients.
export host-route
Host route advertisement is enabled. If this feature is disabled, the command output does not display this field.
# Display detailed information about all common IP pools.
<Sysname> display ip pool verbose
Pool name: pool1 (lock strict)
  Pool index: 1
  VPN instance:
    N/A
  Pool-group-name:
    group1
  Network: 10.1.1.0 mask 255.255.255.0
  route-log enable
  IP address statistics
  Idle:                                    254
    Free:                                  0
    Expired:                               0
  Used:                                    50
    Automatic:                             0
    Manual:                                0
    Reserve:                               0
  Conflicts:                               0
  PreAlloc:                                0
  Forbidden:                               0
  Gateway:                                 0
  Pool utilization:                        0.00%
Pool name: pool2
  Pool index: 2
  VPN instance:
    N/A
  Pool-group-name:
    group1
  Network: 10.2.1.0 mask 255.255.255.0
  route-log enable
  Idle:                                    254
    Free:                                  0
    Expired:                               0
  Used:                                    50
    Automatic:                             0
    Manual:                                0
    Reserve:                               0
  Conflicts:                               0
  PreAlloc:                                0
  Forbidden:                               0
  Gateway:                                 0
Table 23 Command output
·     lock—Locked. The server responds to the lease renewal requests from online DHCP clients for IP addresses in the pool, but it does not assign IP addresses from the pool to new DHCP clients.
·     lock strict—Strictly locked. The server does not respond to the lease renewal requests from online DHCP clients for IP addresses in the pool or assign IP addresses from the pool to new DHCP clients.
Pool index
VPN instance
VPN instance the IP pool is applied. If the IP pool belongs to the public network, this field displays N/A.
Pool-group-name
Network
Assignable network segment.
IP resource exhaustion logging is enabled to record IP resource exhaustion events and recoveries from the IP exhaustion resource state. If this feature is disabled, this field displays undo exhaustion log enable.
expired
Lease duration.
If the DHCP server is allowed to use the DHCP client-suggested lease duration, allow-hint is displayed next to the lease duration.
IP address reservation mode, amount of time for expired IP addresses to be reserved, and the maximum number of IP addresses that can be reserved in the IP pool.
In this example, the reservation mode is client ID, the amount of reservation time is 4294967295 seconds, and the maximum number of IP addresses is 256000.
verify class
route-log enable
ip-in-use threshold
IP address usage threshold for the IP address pool.
Total IP addresses
Idle
·     Free—Number of IP addresses that have not been assigned.
Used
·     Automatic—Number of dynamically assigned IP addresses.
PreAlloc
Conflicts
Number of conflicting IP addresses. The Reusable field displays the number of conflicting IP addresses that can be re-used.
Forbidden
Number of IP addresses excluded from dynamic address assignment. The Used or Reserved field displays the number of excluded IP addresses that are already in use or are occupied.
Gateway
gateway
ip pool
display ip pool ip-status
Use display ip pool ip-status to display the state of each IP address within an IP address range.
display ip pool ip-status start-ip-address [ end-ip-address ] [ vpn-instance vpn-instance-name ]
start-ip-address [ end-ip-address ]: Specifies an IP address range that contains up to 1024 IP addresses. The end IP address must not be lower than the start IP address. If you do not specify an end IP address, this command displays the state of the specified IP address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the public network is specified.
To view the status of IP addresses within an IP address range specified in an IP address pool, use this command.
# Display the state of each IP address within an IP address range.
<Sysname> display ip pool ip-status 20.0.0.0 20.0.0.255
Status flags:  A--Not Found    B--Gateway     C--Conflict   D--Free
               E--Expired      F--Offered     G--Commited   H--Staticfree
               I--Forbidden    J--Reserved    K--Deviceip   L--Preallocated
               M--Network or Broadcast        N--Occupied(Nat or L2tp)
Pool name: pool1
IP address        Hardware address    User-ID        Status
20.0.0.0          N/A                  N/A            M
20.0.0.1          N/A                  N/A            B
20.0.0.2          N/A                  N/A            C
20.0.0.3          N/A                  N/A            C
20.0.0.5          N/A                  N/A            D
20.0.0.6          N/A                  N/A            E
20.0.0.7          N/A                  N/A            D
20.0.0.8          000e-5501-0001       1              G
20.0.0.9          000e-5501-0002       N/A            H
20.0.0.10         000e-5501-0003       2              G
20.0.0.11         000e-5501-0004       3              J
20.0.0.12         N/A                  N/A            I
20.0.0.13         N/A                  N/A            L
20.0.0.255        N/A                  N/A            M
Table 24 Command output
Hardware address
Hardware address of the client that obtained the IP address. If the IP address is not assigned, this field displays N/A.
User-ID
ID of the DHCP user. If no user ID exists, this field displays N/A.
Status
IP address state. Supported IP address states include:
·     A(Not Found)The IP address is in the specified IP address range, but its state information is not found.
·     B(Gateway)—Gateway IP address.
·     C(Conflict)—Conflicting IP address.
·     D(Free)—Free IP address.
·     E(Expired)—Lease-expired IP address.
·     F(Offered)—IP address with a temporary lease. The DHCP server has dynamically selected the IP address and sent it in a DHCP-OFFER message to the DHCP client.
·     G(Commited)—IP address with a committed lease. The DHCP server has sent a DHCP-ACK message about the IP address to the DHCP client. The IP address has been dynamically assigned to the DHCP client.
·     H(Staticfree)—IP address in a free static binding. The IP address has not been assigned.
·     I(Forbidden)IP address excluded from dynamic address assignment.
·     J(Reserved)Reserved IP address.
·     K(Deviceip)—Device IP address, such as local interface address or IP address issued to the address management module.
·     L(Preallocated)—Pre-assigned IP address. The DHCP server has offered the IP address in a DHCP-OFFER message to the DHCP client.
·     M(Network or Broadcast)—Network address or broadcast address within a network.
·     N(Occupied(Nat or L2tp))—Occupied IP address in a NAT-central or L2TP address pool.
display ip pool network item
Use display ip pool network item to display information about the network segments in an IP address pool.
display ip pool network item { domain domain-name | pool pool-name | pool-group pool-group-name | subnet network-address mask-length [ vpn-instance vpn-instance-name ] } [ status { unused | used } ]
domain domain-name: Specifies an ISP domain by its name, a case-sensitive string of 1 to 50 characters.
subnet network-address mask-length: Specify a network segment by its address and mask length.
status: Specifies a network segment state. Values include:
unused: Specifies the network segment that has no address assigned.
used: Specifies the network segment that has addresses assigned.
For a common or BAS IP address pool, this command displays information about the network segments configured for dynamic address assignment in that address pool.
# Display information about the network segments in IP address pool pool1.
<Sysname> display ip pool network item pool pool1
Pool name: pool1
network             gateway       status
40.0.1.0/24         40.0.1.1      Used
40.0.2.0/24         40.0.2.1      Unused
40.0.3.0/24         40.0.3.1      Used
50.0.1.0/24         50.0.1.1      Used
Table 25 Command output
Pool name
network
Network segment specified for dynamic address assignment in the address pool.
gateway
Gateway address in the network segment.
status
State of the network segment:
·     UsedSome addresses in the network segment have been assigned.
·     Unused—All addresses in the network segment are not assigned.
display ip pool network statistics
Use display ip pool network statistics to display IP address statistics for the network segments in an IP address pool.
display ip pool network statistics { domain domain-name | pool pool-name | pool-group pool-group-name | subnet network-address mask-length [ vpn-instance vpn-instance-name ] } [ status { unused | used } ]
For a common or BAS IP address pool, this command displays IP address statistics for the network segments configured for dynamic address assignment in that address pool.
# Display IP address statistics for the network segments in IP address pool pool1.
<Sysname> display ip pool network statistics pool Pool1
Pool name: Pool1
  network            total    used   idle    ratio
  10.0.0.0/24        255      5      250     1.96%
  10.0.1.0/24        255      10     245     3.92%
  10.0.2.0/24        255      20     235     7.84%
Table 26 Command output
Pool name
network
Assigned subnet.
total
Number of IP addresses in the network segment.
used
Number of IP addresses that have been assigned from the network segment.
idle
Number of idle IP addresses in the network segment. Idle IP addresses include IP addresses that have not been assigned, lease-expired IP addresses, and assignable conflicting IP addresses.
ratio
IP address usage of the network segment.
display ip pool-group
Use display ip pool-group to display information about IP pool groups.
display ip pool-group [ all | name pool-group-name | vpn-instance vpn-instance-name ] [ verbose ]
all: Displays information about all IP pool groups for the public network and VPN instances.
name pool-group-name: Specifies an IP pool group name, a case-insensitive string of 1 to 63 characters.
verbose: Displays detailed information about IP pool groups and their IP pools. If you do not specify this keyword, the command displays brief information about IP pool groups and their IP pools.
If you do not specify any parameters, this command displays information about all IP pool groups on the public network.
# Display brief information about IP pool group group1.
<Sysname> display ip pool-group name group1
Pool-group: group1
  VPN instance name: abc
  Discover-nak-count: 3 10(sec)
  Ip-in-use threshold: 100
  Exhaustion trap enable
  Undo exhaustion log enable
  Undo ip-pool algorithm round-robin local remote
  Total IP addresses: 100
  Used IP addresses: 0
    Automatic: 0
    Manual: 0
  Idle IP addresses: 0
    Free IP addresses: 0
    Expired IP addresses: 0
    Conflict reusable IP addresses: 0
  Forbidden IP addresses: 0
  Gateway IP addresses: 0
  Pre allocated IP addresses: 0
  Reserved IP addresses: 0
  Conflict IP addresses: 0
  Current pool: pool1
  Pool group usage: 0.00%
  Bound pools: 2
    pool1 priority 1
    pool2 priority 2
# Display brief information about all IP pool groups on the public network.
Pool-group: group1
  VPN instance name: N/A
  Total IP addresses: 200
    Automatic: 0
    Manual: 0
  Current pool: pool2
  Bound pools: 2
    Pool2 priority 1
    Pool3 priority 3
Pool-group: group2
  VPN-instance name: N/A
  Discover-nak-count: 0 0(sec)
  Total IP addresses: 300
    Automatic: 0
    Manual: 0
  Current pool: pool3
  Bound pools: 3
    pool3 priority 2
    pool4 priority 3
    pool5 priority 4
Table 27 Command output
Pool-group
VPN instance name
Name of the VPN instance to which the IP pool group is applied. This field displays N/A if the IP pool group is on the public network.
Discover-nak-count: xx yy(sec)
If the relay agent has received more than xx DHCP-NAK messages from a DHCP server in response to DHCP-DISCOVER messages within yy seconds, the relay agent forwards DHCP-DISCOVER messages to the DHCP server in the next remote BAS IP pool.
Ip-in-use threshold
IP address usage threshold for the IP address pool group, in percentage.
IP resource exhaustion alarming is enabled for the IP address pool group. If this feature is disabled, this field displays Undo exhaustion trap enable.
IP resource exhaustion logging is disabled for the IP address pool group. If this feature is enabled, this field displays Exhaustion log enable.
Round-robin address pool selection is enabled for the address pool group:
·     If the address pool group selects local address pools for address allocation in a round-robin manner, this field displays Ip-pool algorithm round-robin local.
·     If the address pool group selects remote BAS address pools for address allocation in a round-robin manner, this field displays Ip-pool algorithm round-robin remote.
·     If the address pool group uses the default method to select address pools for address allocation, this field displays Undo ip-pool algorithm round-robin local remote.
Total IP addresses
Total number of IP addresses in the IP pool group.
Used IP addresses
Idle IP addresses
Number of idle IP addresses in the IP pool group:
·     Free IP addresses—Number of IP addresses that have not been assigned.
·     Expired IP addresses—Number of IP addresses that are reclaimed after their leases expire and can be assigned again.
·     Conflict reusable IP addresses—Number of conflicting IP addresses that can be assigned after one hour.
Number of IP addresses excluded from dynamic address assignment in the IP pool group.
Number of gateway addresses configured in the IP pool group.
Number of pre-assigned IP addresses in the IP pool group.
Number of reserved IP addresses in the IP pool group.
Number of conflicting IP addresses in the IP pool group.
Current pool
IP pool in use. If the IP pool group does not have any IP pools, this field displays N/A.
Pool group usage
Address usage of the IP pool group.
Bound pools
Number of bound IP pools and their names. Each line displays one IP pool name and its priority.
# Display detailed information about all IP pool groups on the public network.
<Sysname> display ip pool-group verbose
Pool-group: group1
  Total IP addresses: 508
    Automatic: 0
    Manual: 0
  Idle IP addresses: 508
    Free IP addresses: 508
  Current pool: pool1
  Bound pools: 2
    pool1
Pool name: pool1
  Pool index: 1
  Pool type: Common
  VPN instance:
    N/A
  Pool-group-name:
    group1
  Idle:                                  254
    Free:                                0
    Expired:                             0
  Used:                                  50
    Automatic:                           0
    Manual:                              0
    Reserve:                             0
  Conflicts:                             0
  PreAlloc:                              0
  Forbidden:                             0
  Gateway:                               0
    pool2
Pool name: pool2
  Pool index: 2
  Pool type: Common
  VPN instance:
    N/A
  Pool-group-name:
    group1
  Idle:                                  254
    Free:                                0
    Expired:                             0
  Used:                                  50
    Automatic:                           0
    Manual:                              0
    Reserve:                             0
  Conflicts:                             0
  PreAlloc:                              0
  Forbidden:                             0
  Gateway:                               0
Table 28 Command output
Pool-group
VPN instance name
‌Name of the VPN instance to which the IP pool group is applied. This field displays N/A if the IP pool group is on the public network.
IP-in-use threshold
IP exhaustion logging is disabled for the IP address pool group. If this feature is enabled, this field displays Exhaustion log enable.
Total IP addresses
Used IP addresses
Number of allocated IP addresses in the IP pool group.
Idle IP addresses
Current pool
Pool group usage
Bound pools
Pool name
Name of an IP pool in the IP pool group. For more information about IP pool fields, see the field description table for the output of the display ip pool verbose command.
ip pool-group
dns-list
Use dns-list to specify DNS server addresses in an IP pool.
Use undo dns-list to remove DNS server addresses from an IP pool.
dns-list ip-address&<1-8>
undo dns-list [ ip-address&<1-8> ]
No DNS server address is specified.
IP pool view
ip-address&<1-8>: Specifies a space-separated list of up to eight DNS servers.
If you do not specify any parameters, the undo dns-list command deletes all DNS server addresses in the IP pool.
# Specify DNS server address 10.1.1.254 in IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] dns-list 10.1.1.254
display ip pool
domain-name
Use domain-name to specify a domain name in an IP pool.
Use undo domain-name to restore the default.
domain-name domain-name
undo domain-name
No domain name is specified.
IP pool view
domain-name: Specifies the domain name, a case-sensitive string of 1 to 50 characters.
# Specify domain name example.com in IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] domain-name example.com
display ip pool
Use exhaustion log enable to enable IP resource exhaustion logging for an IP pool or IP pool group.
Use undo exhaustion log enable to restore the default.
The DHCP module does not generate logs for IP resource exhaustion events that occur in an IP address pool or IP address pool group.
IP pool view
IP pool group view
This feature enables the DHCP module to send IP resource exhaustion logs to the information center.
IP resource exhaustion events include IP resource exhaustion alarms and recoveries from IP resource exhaustion alarm conditions.
An IP resource exhaustion log message is generated for an IP pool or IP pool group when one of the following events occurs:
·     The IP pool or IP pool group does not have assignable IP addresses or subnets.
·     The IP address usage of the IP pool or IP pool group drops below 90% after IP address exhaustion. The IP address usage is calculated by using the following formula:
(Total number of IP addresses – number of assignable IP addresses)/total number of IP addresses
For log messages to be sent correctly, configure the information center to set log message filtering and output rules, including output destinations. For information about the information center configuration, see Network Management and Monitoring Configuration Guide.
# Enable IP resource exhaustion logging for IP pool pool1.
[Sysname] ip pool pool1
[Sysname-ip-pool-pool1] exhaustion log enable
# Enable IP resource exhaustion logging for IP pool group group1.
[Sysname] ip pool-group group1
[Sysname-ip-group-group1] exhaustion log enable
Use exhaustion trap enable to enable IP resource exhaustion alarming for an IP pool or IP pool group.
Use undo exhaustion trap enable to disable IP resource exhaustion alarming for an IP pool or IP pool group.
IP resource exhaustion alarming is enabled for IP pools.
IP resource exhaustion alarming is disabled for IP pool groups.
IP pool view
BAS IP pool view
IP pool group view
With this feature enabled, the device generates a notification when all assignable IP resources in an IP pool or IP pool group are used up.
·     To calculate the IP address usage of an IP pool or IP pool group, use the following formula:
This feature can take effect only after you enable SNMP notifications for the DHCP server by using the snmp-agent trap enable dhcp server address-exhaust or snmp-agent trap enable dhcp server pool-group-exhaust command first.
The snmp-agent trap enable dhcp server address-exhaust command takes effect on all IP address pools on the DHCP server. The DHCP server might generate too many IP resource exhaustion notifications. To reduce the number of alarm notifications, disable IP resource exhaustion alarming for some IP pools by using the undo exhaustion trap enable command.
# Disable IP resource exhaustion alarming for IP pool pool1.
[Sysname-pool-pool1] undo exhaustion trap enable
# Disable IP resource exhaustion alarming for IP pool group group1.
[Sysname] ip pool-pool group1
[Sysname-pool-group-group1] exhaustion trap enable
display ip pool
expired
Use expired to set the lease duration in an IP pool.
Use undo expired to restore the default lease duration for an IP pool.
expired { allow-hint | { day day [ hour hour [ minute minute [ second second ] ] ] | unlimited } [ allow-hint ] }
undo expired
The lease duration of a dynamic IP pool is 1 day.
IP pool view
allow-hint: Allows the DHCP server to use the DHCP client-suggested lease duration. The DHCP server uses the DHCP client-suggested lease duration if the DHCP client-suggested lease duration is shorter than the lease duration in the IP pool. If you do not specify this keyword, the DHCP server always uses the lease duration in the IP pool.
day day: Specifies the number of days, in the range of 0 to 365.
hour hour: Specifies the number of hours, in the range of 0 to 23. The default is 0.
minute minute: Specifies the number of minutes, in the range of 0 to 59. The default is 0.
second second: Specifies the number of seconds, in the range of 0 to 59. The default is 0.
unlimited: Specifies the unlimited lease duration, which is actually 136 years.
The DHCP server assigns an IP address together with the lease duration to the DHCP client. Before the lease expires, the DHCP client must extend the lease duration.
·     If the lease extension operation succeeds, the DHCP client can continue to use the IP address.
·     If the lease extension operation does not succeed, both of the following events occur:
¡     The DHCP client cannot use the IP address after the lease duration expires.
¡     The DHCP server will label the IP address as expired.
# Set the lease duration to 1 day, 2 hours, 3 minutes, and 4 seconds in IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] expired day 1 hour 2 minute 3 second 4
# Set the lease duration to 1 day, 2 hours, 3 minutes, and 4 seconds in IP pool 0. Allow the DHCP server to use the DHCP client-suggested lease duration.
[Sysname] ip pool 0
[Sysname-ip-pool-0] expired day 1 hour 2 minute 3 second 4 allow-hint
display ip pool
export host-route
Use export host-route to enable host route advertisement.
Use undo export host-route to disable host route advertisement.
export host-route
Host route advertisement is disabled.
IP pool view
Application scenarios
The network export-route command enables the DHCP server to advertise the network route for each assigned IP address in the pool. If multiple pools share the same segment, the same network route will be advertised for assigned IP addresses in these pools. This will make the clients using these IP addresses inaccessible to external devices. To resolve this issue, enable host route advertisement for each IP pool to advertise a host route for each assigned IP address.
Operating mechanism
The command does not affect the generation of host routes. By default, after a host route is generated for an assigned IP address in an IP address pool, the route cannot be advertised to other devices through routing protocols (for example, BGP). To resolve this issue, enable host route advertisement for the address pool:
·     The device will delete the UNRs generated after the network export-route or gateway command is executed.
·     After the device generates host routes for assigned IP addresses in the address pool, routing protocols can advertise those routes to other devices.
Before you enable host route advertisement for an IP pool, make sure this pool has not assigned any IP addresses.
# Enable host route advertisement for IP pool 1.
[Sysname] ip pool 1
[Sysname-ip-pool-1] export host-route
ip pool
forbidden-ip
Use forbidden-ip to exclude IP addresses from dynamic allocation in an IP pool.
Use undo forbidden-ip to remove the configuration.
forbidden-ip ip-address&<1-8>
undo forbidden-ip [ ip-address&<1-8> ]
Except for the DHCP server IP address, all IP addresses in the IP pool are assignable.
IP pool view
ip-address&<1-8>: Specifies a space-separated list of up to eight excluded IP addresses.
The excluded IP addresses in an IP pool are still assignable in other IP pools.
You can exclude multiple IP addresses in an IP pool by executing this command multiple times.
If you do not specify any parameters, the undo forbidden-ip command removes all excluded IP addresses.
# Exclude IP addresses 192.168.1.3 and 192.168.1.10 from dynamic allocation in IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] forbidden-ip 192.168.1.3 192.168.1.10
dhcp server forbidden-ip
display ip pool
forbidden-ip-range
Use forbidden-ip-range to exclude an IP address range from DHCP allocation in an address pool.
Use undo forbidden-ip-range to remove an IP address range from the forbidden IP range list.
forbidden-ip-range start-ip-address [ end-ip-address ]
undo forbidden-ip-range [ start-ip-address [ end-ip-address ] ]
No IP address ranges are excluded from DHCP allocation in an address pool.
IP address pool view
start-ip-address: Specifies a start IP address.
end-ip-address: Specifies an end IP address. The end IP address cannot be lower than the start IP address. If you do not specify this argument, the excluded IP range includes only the start IP address.
The forbidden IP ranges in an address pool are still assignable in other address pools.
To specify multiple forbidden IP ranges, execute the forbidden-ip-range command multiple times. The forbidden IP ranges can overlap.
When you execute the undo form of this command to remove forbidden IP ranges, follow these guidelines:
·     To remove all forbidden IP ranges, execute the undo forbidden-ip-range command without specifying any parameters.
·     To remove a subrange of IP addresses from a forbidden IP range, specify only that subrange of IP addresses.
·     To remove a forbidden IP range as a whole, specify that IP range or an IP range broader than it.
# Exclude IP address range from 192.168.1.3 to 192.168.1.10 from DHCP allocation in IP address pool 1.
[Sysname-ip-pool-pool1] forbidden-ip-range 192.168.1.3 192.168.1.10
display ip pool
gateway
Use gateway to specify the gateway IP address and the network mask for an IP pool.
Use undo gateway to restore the default
gateway ip-address { mask | mask-len }
undo gateway
No gateway IP address or network mask is specified for an IP pool.
Local BAS IP pool view
Remote BAS IP pool view
ip-address: Specifies the IP address of the gateway.
mask: Specifies the network mask in dotted decimal notation.
mask-len: Specifies the network mask length in the range of 1 to 30.
In a BAS network, execute this task on the DHCP server. When the DHCP server receives a DHCP request from an authenticated access user, the server selects an IP address from the IP pool and assigns it to the user.
Operating mechanism
A BAS IP pool supports only one gateway IP address and its network mask. If you execute this command multiple times, the most recent configuration takes effect.
The gateway IP address and mask settings cannot be modified or deleted for an IP pool if the pool has leases of assigned IP addresses.
# In local BAS IP pool p1, specify gateway IP address 1.1.1.1 and network mask length 24.
[Sysname] ip pool p1 bas local
[Sysname-ip-pool-p1] gateway 1.1.1.1 24
display ip pool
network
gateway-list
Use gateway-list to specify gateway addresses to be assigned to DHCP clients.
Use undo gateway-list to remove the specified gateway addresses.
gateway-list ip-address&<1-64> [ export-route ]
undo gateway-list [ ip-address&<1-64> ] [ export-route ]
No gateway addresses are specified in an IP pool or a DHCP secondary network segment.
Common IP address pool view
DHCP secondary network segment view
ip-address&<1-64>: Specifies a space-separated list of up to 64 gateway addresses. Gateway addresses must reside on the same subnet as the assignable IP addresses.
export-route: Binds the gateways to the device's MAC address in the address management module. The ARP module will use the entries to reply to ARP requests from the DHCP clients. If you do not specify this keyword, the gateways will not be bound to the device's MAC address.
The DHCP server assigns gateway addresses to clients on a secondary network segment in the following ways:
·     If gateways are specified in both IP pool view and secondary network segment view, DHCP assigns those specified in the secondary network segment view.
·     If gateways are specified in IP pool view but not in secondary network segment view, DHCP assigns those specified in IP pool view.
If you do not specify any parameters, the undo gateway-list command deletes all gateway addresses.
To avoid forwarding failure, do not delete a gateway address from a gateway list if that gateway address is being used by online clients.
# Specify gateway address 10.1.1.1 in IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] gateway-list 10.1.1.1
display ip pool
if-match
Use if-match to configure a match rule for a DHCP user class.
Use undo if-match to delete a match rule for a DHCP user class.
No match rules are configured for the DHCP user class.
DHCP user class view
rule rule-number: Assigns the match rule an ID in the range of 1 to 16. A smaller ID represents a higher match priority.
hardware-address hardware-address: Specifies a hardware address, a string of 4 to 39 characters. The string contains hyphen-separated hexadecimal numbers. The last hexadecimal number can be a two-digit or four-digit number, and the other hexadecimal numbers must be four-digit numbers. For example, aabb-ccdd-ee is valid, and aabb-c-dddd or aabb-cc-dddd is invalid.
mask hardware-address-mask: Specifies the mask to be ANDed with the specified hardware address for the match operation. The length of the mask must be the same as that of the hardware address.
option option-code: Specifies a DHCP option by its number in the range of 1 to 254.
ascii ascii-string: Specifies an ASCII string of 1 to 128 characters.
offset offset: Specifies the offset in bytes after which the match operation starts. The value range is 0 to 254. If you do not specify an offset value, the match starts from the first byte of the option content. If you specify an ASCII string, a packet matches the rule if the option after the offset has the same length and content as the ASCII string. If you specify a hexadecimal number, a packet matches the rule if the option after the offset has the same length and content as the hexadecimal number.
partial: Enables partial match. A packet matches a rule if the specified option in the packet contains the ASCII string or hexadecimal number specified in the rule. For example, if you specify abc in the rule, option content xabc, xyzabca, xabcyz, and abcxyz all match the rule.
hex hex-string: Specifies a hexadecimal number. The length of the hexadecimal number must be an even number in the range of 2 to 256.
mask mask: Specifies a hexadecimal mask for the match operation. The mask length must be an even number in the range of 2 to 256 and be the same as the hex-string length. The DHCP server selects option content of the mask length from the start and ANDs the selected option content and the specified hexadecimal number with the mask. The packet matches the rule if the two AND operation results are the same.
length length: Specifies the length of the option content to be matched, in the range of 1 to 128 bytes. The length must be the same as the hex-string length.
relay-agent gateway-address: Specifies a giaddr field value. The value is an IPv4 address in the dotted decimal notation. A packet matches the rule if its giaddr field value is the same as that in the rule.
If a DHCP request sent by a DHCP client matches a rule in a DHCP user class, the DHCP client matches the user class.
You can configure multiple match rules for a DHCP user class. Each match rule is uniquely identified by a rule ID within its type (hardware address, option, or relay agent address).
·     If the rule that you are configuring has the same ID and type as an existing rule, the new rule overwrites the existing rule.
·     If the rule that you are configuring has the same ID as an existing rule but a different type, the new rule takes effect and coexists with the existing rule. As a best practice, do not assign the same ID to rules of different types.
·     Rules of different IDs cannot have the same rule content.
When you configure an if-match hardware-address rule, follow these guidelines:
·     The hardware address type supports only the MAC address. A rule does not match clients with hardware addresses of other types.
·     The specified hardware address must be of the same length as the client hardware addresses to be matched. To match MAC addresses, the specified hardware address must be six bytes long.
·     The fs and 0s in the mask for the hardware match operation can be noncontiguous. For example, the rule if-match rule 1 hardware-address 0094-0000-1100 mask ffff-0000-ff00 matches hardware addresses in which the first two bytes are 0094 and the fifth byte is 11.
When you configure an if-match option rule, follow these guidelines:
·     To match packets that contain an option, specify only the option-code argument.
·     To match a hexadecimal number by AND operations, specify the option option-code hex hex-string mask mask options.
·     To match a hexadecimal number directly, specify the option option-code hex hex-string [ offset offset length length | partial ] options. If you do not specify the offset, length, or partial parameter, a packet matches a rule if the option has the same length and content as the hexadecimal number.
·     To match an ASCII string, specify the option option-code ascii ascii-string [ offset offset | partial ] options. If you do not specify the offset or partial parameter, a packet matches a rule if the option has the same length and content as the ASCII string.
# Configure match rule 1 for DHCP user class exam to match DHCP requests in which the hardware address is six bytes long and begins with 0094.
[Sysname] dhcp class exam
[Sysname-dhcp-class-exam] if-match rule 1 hardware-address 0094-0000-0101 mask ffff-0000-0000
# Configure match rule 2 for DHCP user class exam to match DHCP requests that contain Option 82.
[Sysname-dhcp-class-exam] if-match rule 2 option 82
# Configure match rule 3 for DHCP user class exam. The rule matches DHCP requests in which the highest bit of the fourth byte in Option 82 is the hexadecimal number 1.
[Sysname-dhcp-class-exam] if-match rule 3 option 82 hex 00000080 mask 00000080
# Configure match rule 4 for DHCP user class exam. The rule matches DHCP requests in which the first three bytes of Option 82 are the hexadecimal number 13ae92.
[Sysname-dhcp-class-exam] if-match rule 4 option 82 hex 13ae92 offset 0 length 3
# Configure match rule 5 for DHCP user class exam. The rule matches DHCP requests in which the Option 82 contains the hexadecimal number 13ae.
[Sysname-dhcp-class-exam] if-match rule 5 option 82 hex 13ae partial
# Configure match rule 6 for DHCP user class exam. The rule matches DHCP requests in which Option 61 contains the ASCII string abcd.
[Sysname-dhcp-class-exam] if-match rule 6 option 61 ascii abcd
# Configure match rule 7 for DHCP user class exam to match DHCP requests in which the giaddr field is 10.1.1.1.
[Sysname-dhcp-class-exam] if-match rule 7 relay-agent 10.1.1.1
dhcp class
ip pool
Use ip pool to create an IP pool and enter its view, or enter the view of an existing IP pool.
Use undo ip pool to delete the specified IP pool.
ip pool pool-name [ bas { local | remote } ]
undo ip pool pool-name
No IP pools exist.
pool-name: Specifies an IP pool name, a case-insensitive string of 1 to 63 characters.
bas { local | remote }: Creates the pool as a BAS IP pool. To create a local BAS IP pool, specify the local keyword. To create a remote BAS IP pool, specify the remote keyword.
On some networks (such as an IPoE network), users must pass authentication before they can obtain an IP address from a DHCP server. On such a network, configure a BAS IP pool depending on the location of the BAS device and the DHCP server:
·     If the DHCP server is configured on the BAS device, configure a local BAS IP pool on the BAS device.
·     If the BAS device relays requests to the DHCP server, perform the following tasks:
a.     On the BAS device, configure a remote BAS IP pool and execute the remote-server command to specify the DHCP server.
b.     On the DHCP server, configure a local BAS IP pool.
If you do not specify the bas keyword this command creates a common IP pool.
IP pool names must be unique on one device.
You can create multiple IP pools of the same type on one device.
# Create a local BAS IP pool and enter its view.
display ip pool
ip pool-group
Use ip pool-group to create an IP pool group and enter its view, or enter the view of an existing IP pool group.
Use undo ip pool-group to delete an IP pool group.
ip pool-group pool-group-name
undo ip pool-group pool-group-name
No IP pool groups exist.
For a user that matches an IP pool group, the DHCP server selects an IP address from an available IP pool in the matching group.
If both an IP pool and an IP pool group exist in AAA authorization user attributes, authenticated users can only obtain IP addresses from the IP pool. The users cannot obtain IP addresses from the IP pool group even if the authorization IP pool has no assignable IP addresses.
If a DHCP client matches a remote BAS IP pool in an IP pool group, the relay agent cannot determine whether the DHCP server in the remote BAS IP pool has assignable IP addresses. To resolve this issue, perform the following tasks for the remote pool:
·     Execute the gateway command to specify the IP address resources configured on the remote DHCP server.
·     Execute the dhcp server forbidden-ip, forbidden-ip, and forbidden-ip-range commands to specify the excluded IP addresses configured on the remote DHCP server.
Upon receiving an IP address from the remote DHCP server, the relay agent considers that IP address as assigned in the remote BAS IP pool. This mechanism ensures that the relay agent and the DHCP server have the same free address information. The relay agent can then determine whether the DHCP server has free addresses by examining free addresses in the remote BAS IP pool.
# Create an IP pool group named poolgroup1 and enter its view.
[Sysname] ip pool-group poolgroup1
[Sysname-ip-pool-group-poolgroup1]
pool
Use ip-pool algorithm round-robin to enable round-robin IP pool selection in an IP pool group for address allocation.
Use undo ip-pool algorithm round-robin to restore the default.
ip-pool algorithm round-robin { local | remote } *
undo ip-pool algorithm round-robin { local | remote } *
The DHCP server moves from one IP pool to the next only when that IP pool does not have assignable IP addresses.
IP pool group view
local: Selects local IP pools for address allocation in a round-robin manner.
remote: Selects remote IP pools for address allocation in a round-robin manner.
The default pool selection mechanism leads to uneven address resource distribution among IP pools. To balance resource usage across the IP pools in a pool group, enable the round-robin algorithm on that pool group.
The round-robin IP pool selection mechanism operates as follows:
1.     On receipt of the first DHCP request, the DHCP server selects the first available IP pool for address allocation from the pool group.
2.     When a new DHCP request arrives, the DHCP server selects the next available IP pool for address allocation.
3.     After the DHCP server iterates through all the IP pool in the group, the server starts over again from the first IP pool.
When you use this command, follow these guidelines:
·     If you specify only the local keyword, the server will first select local IP pools in a round-robin manner. If none of the local IP pools has assignable IP addresses, the DHCP server selects remote IP pools by using the default pool selection mechanism.
·     If you specify only the remote keyword, the server will first select local IP pools by using the default pool selection mechanism. It moves to remote IP pools for round-robin selection only if none of the local IP pools has assignable IP addresses.
·     If you specify both the local and remote keywords, the server will first select local IP pools in a round-robin manner. It moves to remote IP pools for round-robin selection only if none of the local IP pools has assignable IP addresses.
# Enable round-robin selection of local IP pools in IP pool group 1.
[Sysname] ip pool-group 1
[Sysname-ip-pool-group-1] ip-pool algorithm round-robin local
ip unr
Use ip unr to set an IPv4 user network route (UNR) tag.
Use undo ip unr to restore the default.
ip unr { framed-ip-address-tag tag-value | framed-ip-netmask-tag tag-value | framed-route-tag tag-value | local-pool-tag tag-value | remote-pool-tag tag-value } *
undo ip unr { framed-ip-address-tag | framed-ip-netmask-tag | framed-route-tag | local-pool-tag | remote-pool-tag } *
No IPv4 UNR tag is set.
framed-ip-address-tag tag-value: Sets a tag value for host routes that are generated based on the Framed-IP-Address attribute assigned by the RADIUS server. The tag value range is 1 to 4294967295.
framed-ip-netmask-tag tag-value: Sets a tag value for network routes that are generated based on the Framed-IP-Netmask attribute assigned by the RADIUS server. The tag value range is 1 to 4294967295.
framed-route-tag tag-value: Sets a tag value for network routes that are generated based on the Framed-Routing attribute assigned by the RADIUS server. The tag value range is 1 to 4294967295.
local-pool-tag tag-value: Sets a UNR tag value for common IP pools and local BAS IP pools. The tag value range is 1 to 4294967295.
remote-pool-tag tag-value: Sets a UNR tag value for remote BAS IP pools. The tag value range is 1 to 4294967295.
When the DHCP server assigns an IP address, it adds the network route for the IP address to the route management module. In a BAS network, you can classify user network routes based on their UNR tag values for route redistribution.
The tag value modification does not affect the tag values for network routes that have been advertised.
You can set a route tag value in system view or in IP pool view. For BAS access users, the value set in IP pool view has higher priority than the one set in system view.
# Set the UNR tag value to 1 for local BAS IP pools.
[Sysname] ip unr local-pool-tag 1
unr tag
ip-in-use threshold
Use ip-in-use threshold to set the IP address usage threshold for an IP address pool or IP address pool group.
Use undo ip-in-use threshold to restore the default.
The IP address usage threshold for an IP address pool or IP address pool group is 100%.
IP pool view
IP pool group view
threshold-value: Specifies an IP address usage threshold, in percentage. The value range for this argument is 0 to 100.
If the IP address usage of an IP address pool or IP address pool group reaches or exceeds the threshold, the DHCP module sends an SNMP notification and a log message to report the event. You can optimize the IP pool configuration accordingly. When the IP address usage drops below 90% of the threshold after the threshold violation, DHCP also sends an SNMP notification and a log message to the information center. If the threshold value is set to 100% for an IP address pool or IP address pool group, the DHCP module generates only an SNMP notification when the IP address usage reaches 100% or drops below 90%.
For DHCP notifications to be sent correctly, you must configure SNMP on the device. For log messages to be sent correctly, you must configure the information center. For more information about SNMP configuration and the information center configuration, see Network Management and Monitoring Configuration Guide.
If you execute this command multiple times in the same IP pool view, the most recent configuration takes effect.
If the IP address usage threshold for an IP address pool or address pool group is 0, the device does not generate any related alarm or log messages for that IP address pool or address pool group.
# Set the IP address usage threshold to 75% for IP address pool pool1.
[Sysname-ip-pool-pool1] ip-in-use threshold 75
# Set the IP address usage threshold to 75% for IP address pool group group1.
[Sysname-ip-pool-group-group1] ip-in-use threshold 75
lock
Use lock to lock an IP pool.
Use undo lock to restore the default.
lock [ strict ]
undo lock
IP pools are not locked.
IP pool view
strict: Locks the IP pool in strict mode.
Lock an IP pool in loose mode or strict mode depending on the IP pool management requirements.
·     Lock an IP pool in loose mode if you are using that pool only to assign addresses to existing DHCP clients on the network.
·     Lock an IP pool in strict mode if you are deleting or changing the IP space assigned to the IP pool. You can delete or change the IP space for an IP pool only when the IP pool does not contain assigned IP addresses. Locking the IP pool in strict mode ensures that you can perform the delete or change operation as soon as all assigned IP addresses in the pool are reclaimed.
If you specify the strict keyword, the server does not perform the following tasks:
·     Respond to the lease renewal requests from online DHCP clients for IP addresses in the pool.
·     Assign IP addresses from the pool to new DHCP clients.
Locking an IP pool in strict mode ensures that you can perform the delete or change operation as soon as all assigned IP addresses in the pool are reclaimed.
If you do not specify the strict keyword, the IP pool is locked in loose mode. When the IP pool is locked in loose mode, the server responds to the lease renewal requests from online DHCP clients for IP addresses in the pool. However, it does not assign IP addresses from the pool to new DHCP clients.
# Lock IP pool 1 in loose mode.
[Sysname] ip pool 1
[Sysname-ip-pool-1] lock
The IP pool will answer only renewal requests of online users but will not assign addresses to new users. Continue? [Y/N]:
# Lock IP pool 1 in strict mode.
[Sysname] ip pool 1
[Sysname-ip-pool-1] lock strict
The IP pool will not answer renewal requests of online users or assign addresses to new users. Continue? [Y/N]:
display ip pool
nbns-list
Use nbns-list to specify WINS server addresses in an IP pool.
Use undo nbns-list to remove the specified WINS server addresses.
nbns-list ip-address&<1-8>
undo nbns-list [ ip-address&<1-8> ]
No WINS server address is specified.
IP pool view
ip-address&<1-8>: Specifies a space-separated list of up to eight WINS server IP addresses.
If you do not specify any parameters, the undo nbns-list command deletes all WINS server addresses.
# Specify WINS server address 10.1.1.1 in IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] nbns-list 10.1.1.1
display ip pool
netbios-type
netbios-type
Use netbios-type to specify the NetBIOS node type in an IP pool.
Use undo netbios-type to restore the default.
undo netbios-type
No NetBIOS node type is specified.
IP pool view
b-node: Specifies the broadcast node. A b-node client sends the destination name in a broadcast message to get the name-to-IP mapping from a server.
h-node: Specifies the hybrid node. An h-node client unicasts the destination name to a WINS server. If it does not receive a response, the h-node client broadcasts the destination name to get the mapping from a server.
m-node: Specifies the mixed node. An m-node client broadcasts the destination name. If it does not receive a response, the m-node client unicasts the destination name to the WINS server to get the mapping.
p-node: Specifies the peer-to-peer node. A p-node client sends the destination name in a unicast message to get the mapping from the WINS server.
# Specify the NetBIOS node type as p-node in IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] netbios-type p-node
display ip pool
nbns-list
network
Use network to specify a network segment for dynamic allocation in an IP pool.
Use undo network to remove the specified network segment.
network network-address [ mask-length | mask mask ] [ secondary ] [ export-route [ preference preference | tag tag ] * ]
undo network network-address [ mask-length | mask mask ] [ secondary ]
No network segment is specified in an IP pool.
network-address: Specifies the network segment for dynamic allocation. If no mask length or mask is specified, the natural mask will be used.
mask-length: Specifies the mask length for the network segment. The value range for this argument is 1 to 30.
mask mask: Specifies the mask in dotted decimal notation.
secondary: Specifies the network segment as a secondary network segment. If you do not specify this keyword, this command specifies the primary network segment. If the addresses in the primary network segment are used up, the DHCP server can select addresses from a secondary network segment for clients.
export-route: Advertises the network route assigned to DHCP clients. If you do not specify this keyword, the network route will not be advertised.
preference preference: Sets a preference for the network route to be advertised, in the range of 1 to 255. The default preference is 65.
tag tag: Sets a tag value for the network route to be advertised, in the range of 0 to 4294967295. The default tag value is 0. Tags are route identifications for routing policies to filter routes. For more information about routing policies, see routing policy configuration in Layer 3—IP Routing Configuration Guide.
You must specify a minimum of one network segment for an IP pool before you can use it to assign addresses to DHCP clients.
Operating mechanism
To edit the preference or tag value for the route to a network segment and host routes inside the network segment, execute the network export-route command with the preference or tag keyword specified. If you edit the tag value for host routes, the new tag value takes effect only on the host routes generated after the tag change. The tag value for existing host routes remains unchanged.
You can specify only one primary network segment for an IP pool. If you execute the network command multiple times to specify primary network segments, the most recent configuration takes effect.
You can specify up to 96 secondary network segments for a common IP pool.
The primary network segment and secondary network segments in an IP pool must not have the same network address and mask.
If you have used the address range or class command in an IP pool, you cannot specify a secondary network segment in the same IP pool.
If the IP pool has assigned IP addresses, you cannot use the network command to modify or remove the network segments in the IP pool.
# Specify primary network segment 192.168.8.0/24 and secondary network segment 192.168.10.0/24 in IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] network 192.168.8.0 mask 255.255.255.0
[Sysname-ip-pool-0] network 192.168.10.0 mask 255.255.255.0 secondary
[Sysname-ip-pool-0-secondary]
display ip pool
gateway-list
next-server
Use next-server to specify the IP address of a server in an IP pool.
Use undo next-server to restore the default.
next-server ip-address
undo next-server
No server's IP address is specified in an IP pool.
IP pool view
ip-address: Specifies the IP address of a server.
Upon startup, the DHCP client obtains an IP address and the specified server IP address. Then it contacts the specified server, such as a TFTP server, to get other boot information.
# Specify a server's IP address 10.1.1.254 in IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] next-server 10.1.1.254
display ip pool
option
Use option to customize a DHCP option.
Use undo option to remove a customized DHCP option.
undo option code
No DHCP option is customized.
IP pool view
DHCP option group view
code: Specifies the number of the customized option, in the range of 2 to 254, excluding 50 through 54, 56, 58, 59, 61, and 82.
ascii ascii-string: Specifies a case-sensitive ASCII string of 1 to 255 characters as the option content.
hex hex-string: Specifies a hexadecimal number as the option content. The length of the hexadecimal number must be an even number in the range of 2 to 256.
ip-address ip-address&<1-8>: Specifies a space-separated list of up to eight IP addresses as the option content.
The DHCP server fills the customized option with the specified ASCII string, hexadecimal number, or IP addresses, and sends it in a response to the client.
You can customize options for the following purposes:
·     Add newly released options.
·     Add options for which the vendor defines the contents, for example, Option 43.
·     Add options for which the CLI does not provide a dedicated configuration command. For example, you can use the option 4 ip-address 1.1.1.1 command to define the time server address 1.1.1.1 for DHCP clients.
·     Add all option values if the actual requirement exceeds the limit for a dedicated option configuration command. For example, the dns-list command can specify up to eight DNS servers. To specify more than eight DNS server, you must use the option 6 command to define all DNS servers.
DHCP options specified by dedicated commands take precedence over those specified by the option commands. For example, if a DNS server address is specified by both the dns-list command and the option 6 command, the server uses the address specified by the dns-list command.
DHCP options specified in DHCP option groups take precedence over those specified in IP pools.
If multiple DHCP option groups have the same option, the server selects the option in the DHCP option group first matching the user class.
If you execute this command multiple times with the same code specified, the most recent configuration takes effect.
# Configure Option 7 to specify log server address 2.2.2.2 in IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] option 7 ip-address 2.2.2.2
display ip pool
pool
Use pool to add an IP pool to the IP pool group.
Use undo pool to remove an IP pool from the IP pool group.
pool pool-name [ priority priority-value ]
undo pool [ pool-name ]
No IP pools exist in an IP pool group.
IP pool group view
pool-name: Specifies an IP pool name, a case-insensitive string of 1 to 63 characters. The undo pool command removes all IP pools from the IP pool group if you do not specify this argument.
priority priority-value: Specifies the priority of the IP pool, The value range is 0 to 65535, and the default value is 0. A smaller value represents a higher priority.
For a user that matches an IP pool group, the DHCP server selects an IP address from an available IP pool in the IP pool group according to the descending order of the pool priority. If multiple IP pools share the same priority, the server selects the pool displayed first in the output from the display ip pool-group command.
An IP pool supports a maximum of 1024 IP pools. An IP pool can be added to multiple IP pool groups.
Before you add an IP pool to an IP pool group, make sure the IP pool is on the public network or in the same VPN instance as the IP pool group.
Before you remove an IP pool from an IP pool group, make sure the IP pool has not assigned any IP addresses.
# Create an IP pool named poolgroup1, and assign IP pool pool1 to the IP pool group.
[Sysname-ip-pool-group-poolgroup1] pool pool1
# Remove IP pool pool1 from IP address pool group poolgroup1.
[Sysname-ip-pool-group-poolgroup1] undo pool pool1
ip pool-group
reserve expired-ip enable
Use reserve expired-ip enable to enable IP address reservation in an IP pool.
Use undo reserve expired-ip enable to disable IP address reservation in an IP pool.
IP pool view
This feature enables the DHCP server to reserve IP addresses for clients that are going offline. When a client goes offline, the DHCP server reserves the client IP address as an expired lease. When the client comes online again, the DHCP server assigns the IP address in the reserved lease to the client.
Disable the IP address reservation feature if you want the DHCP server to reclaim IP addresses immediately after clients go offline.
# Disable IP address reservation in IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] undo reserve expired-ip enable
reserve expired-ip mode
display dhcp server expired
Use reserve expired-ip enable to configure the IP address reservation mode in an IP pool.
Use undo reserve expired-ip enable to restore the default.
reserve expired-ip mode { client-id | mac } [ limit limit-number | time time ] *
undo reserve expired-ip mode
With IP address reservation enabled, a DHCP server reserves IP addresses based on client IDs.
IP pool view
client-id: Reserves IP addresses based on client IDs.
mac: Reserves IP addresses based on client MAC addresses.
limit limit-number: Specifies the maximum number of IP addresses that can be reserved in an IP pool. The value range is 1 to 2560000, and the default value is 256000.
time time: Specifies the reservation time for expired IP addresses, in the range of 60 to 4294967295 seconds. If you do not specify this option or set the reservation time to 4294967295 seconds, the reservation time equals the lease duration specified in the IP address pool.
With IP address reservation enabled, the DHCP server reserves IP addresses for DHCP clients in the following modes:
·     Reservation based on client IDs—The DHCP server records the IP-to-client ID bindings for online clients. When these clients come online again, the server assigns them the IP addresses in the bindings based on their client IDs.
·     Reservation based on client MAC addresses—The DHCP server records the IP-to-MAC bindings for online clients. When these clients come online again, the server assigns them the IP addresses in the bindings based on their MAC addresses.
When you change the IP address reservation mode, the device deletes all expired leases that are saved in the old reservation mode.
# Configure the DHCP server to reserve IP addresses based on client IDs in IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] reserve expired-ip enable
[Sysname-ip-pool-0] reserve expired-ip mode client-id
reset dhcp address offline-record
Use reset dhcp address offline-record to clear DHCP user offline records.
# Clear DHCP user offline records.
<Sysname> reset dhcp address offline-record
display dhcp address offline-record
reset dhcp pool-usage peak
Use reset dhcp pool-usage peak to clear peak address usage information for an IP pool.
reset dhcp pool-usage peak [ pool pool-name ]
pool pool-name: Specifies an IP pool by its name. The pool-name argument is a case-insensitive string of 1 to 63 characters. If you do not specify this option, this command clears peak address usage information for all IP pools.
To clear peak address usage information for all IP pools, execute the reset dhcp pool-usage peak command without specifying an IP pool. Then, if you execute the display dhcp pool-usage peak command again, the command displays the new peak address usage data collected for each IP pool after you executed the reset command.
# Clear peak address usage information for all IP pools.
<Sysname> reset dhcp pool-usage peak
reset dhcp server conflict
Use reset dhcp server conflict to clear IP address conflict information.
reset dhcp server conflict [ ip start-ip-address [ end-ip-address ] ] [ vpn-instance vpn-instance-name ]
ip start-ip-address [ end-ip-address ]: Clears conflict information for IP addresses in the specified IP address range. If you do not specify this option, this command clears all address conflict information.
·     start-ip-address: Specifies a start IP address.
·     end-ip-address: Specifies an end IP address. The end IP address cannot be lower than the start IP address. If you do not specify this argument, this command clears conflict information for the start IP address (if any).
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears conflict information about IP addresses for the public network.
Address conflicts occur when dynamically assigned IP addresses have been statically configured for other hosts. After you modify the IP pool configuration, the conflicted addresses might become assignable. To assign these addresses, use the reset dhcp server conflict command to clear the conflict information first.
If you do not specify a keyword, this command clears all public-network IP address conflict information.
# Clear all IP address conflict information.
<Sysname> reset dhcp server conflict
display dhcp server conflict
reset dhcp server expired
Use reset dhcp server expired to clear binding information about lease-expired IP addresses.
reset dhcp server expired [ [ ip start-ip-address [ end-ip-address ] ] [ vpn-instance vpn-instance-name ] | pool pool-name ]
ip start-ip-address [ end-ip-address ]: Clears binding information for lease-expired IP addresses in the specified IP address range. If you do not specify an IP address, this command clears binding information for all lease-expired IP addresses.
·     end-ip-address: Specifies an end IP address. The end IP address cannot be lower than the start IP address. If you do not specify this argument, this command clears binding information for the start IP address (if lease-expired).
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears lease expiration information about IP addresses for the public network.
pool pool-name: Clears binding information about the expired IP addresses in the specified IP pool. The pool name is a case-insensitive string of 1 to 63 characters. If you do not specify an IP pool, this command clears binding information for lease-expired IP addresses in all IP pools.
If you do not specify a keyword, this command clears all lease-expired IP address bindings in the public network.
# Clear binding information for all lease-expired IP addresses.
<Sysname> reset dhcp server expired
reset dhcp server ip-in-use
Use reset dhcp server ip-in-use to clear binding information about assigned IP addresses.
reset dhcp server ip-in-use [ [ ip start-ip-address [ end-ip-address ] | relay-address ip-address ] [ vpn-instance vpn-instance-name ] | pool pool-name [ relay-address ip-address ] ]
ip start-ip-address [ end-ip-address ]: Clears binding information for assigned IP addresses in the specified IP address range. If you do not specify an IP address, this command clears binding information for all assigned IP addresses.
·     end-ip-address: Specifies an end IP address. The end IP address cannot be lower than the start IP address. If you do not specify this argument, this command clears binding information for the start IP address (if any).
relay-address ip-address: Specifies the IP address of a relay interface that connects to the DHCP clients. This command clears the bindings that use this address as the gateway address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears binding information for the public network.
pool pool-name: Clears binding information about assigned IP addresses in the specified IP pool. The pool name is a case-insensitive string of 1 to 63 characters. If you do not specify an IP pool, this command clears binding information for assigned IP addresses in all IP pools.
relay-address ip-address: Specifies the IP address of a relay interface that connects to the DHCP clients. This command clears the bindings that use this address as the gateway address in the IP pool.
If no parameters are specified, this command clears all public-network address bindings on the device.
If you use this command to clear information about an assigned static binding, the static binding becomes a free static binding.
# Clear binding information for IP address 10.110.1.1.
<Sysname> reset dhcp server ip-in-use ip 10.110.1.1
This command will reclaim the IP addresses and might make online users offline.
Continue?[Y/N]:
display dhcp server ip-in-use
reset dhcp server packet statistics
Use reset dhcp server packet statistics to clear DHCP server packet statistics.
reset dhcp server packet statistics [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears DHCP server packet statistics for the public network.
# Clear packet statistics for all DHCP servers.
<Sysname> reset dhcp server packet statistics
reset dhcp-access packet statistics
Use reset dhcp-access packet statistics to clear packet statistics for the DHCP access module.
# Clear packet statistics for the DHCP access module.
<Sysname> reset dhcp-access packet statistics
display dhcp-access packet statistics
route-log enable
Use route-log enable to enable route logging for an IP address pool.
Use undo route-log enable to disable route logging for an IP address pool.
route-log enable
Route logging is disabled for an IP address pool.
IP pool view
After you enable this feature for an IP address pool, the DHCP server generates log messages for route events that occur in the IP address pool. Route events include network route adding or deletion.
To enable route logging for IP address pools, use one of the following commands:
·     dhcp route-log enable
This command enables route logging for all types of IP address pools on the DHCP server.
·     route-log enable
This command enables route logging for a single IP address pool on the DHCP server. To enable route logging for only one IP address pool, perform the following task:
a.     Verify that route logging is disabled for all IP address pools on the DHCP server.
b.     You can use the undo dhcp route-log enable command to disable route logging for all IP address pools.
c.     Use the route-log enable command in the view of the target IP address pool.
# Enable route logging for IP address pool 1.
[Sysname] ip pool 1
[Sysname-ip-pool-1] route-log enable
Use snmp-agent trap enable dhcp server to enable SNMP notifications for the DHCP server.
Use undo snmp-agent trap enable dhcp server to disable SNMP notifications for the DHCP server.
snmp-agent trap enable dhcp server [ address-exhaust | allocated-ip | ip-alloc-failed | ip-conflict | ip-in-use | pool-group-exhaust | pool-group-threshold ] *
undo snmp-agent trap enable dhcp server [ address-exhaust | allocated-ip | ip-alloc-failed | ip-conflict | ip-in-use | pool-group-exhaust | pool-group-threshold ] *
SNMP notifications are enabled for the DHCP server.
address-exhaust: Generates alarm notifications for address exhaustion events. This type of alarm notifications is generated when the IP address usage of an IP pool has reached 100% or an IP pool has recovered from an IP exhaustion alarm condition.
allocated-ip: Generates IP allocation alarm notifications. This type of alarm notifications occurs when the IP allocation success rates of all IP pools on the server are lowered than the IP allocation success rate threshold. The threshold is set by using the dhcp server allocated-ip threshold command.
ip-alloc-failed: Generates alarm notifications for IP allocation failure.
ip-conflict: Generates alarm notifications for IP allocation conflict.
ip-in-use: Generates IP address usage alarm notifications. This type of alarm notifications is generated when the IP address usage of an IP pool reaches or exceeds the threshold, or an IP pool has recovered from an IP usage alarm condition. The threshold is set by using the ip-in-use threshold command.
pool-group-exhaust: Generates alarm notifications for address exhaustion events. This type of alarm notifications is generated when the IP address usage of an IP pool group has reached 100% or an IP pool group has recovered from an IP exhaustion alarm condition.
pool-group-threshold: Generates IP address usage alarm notifications. This type of alarm notifications is generated when the IP address usage of an IP pool group reaches or exceeds the threshold, or an IP pool group has recovered from an IP usage alarm condition. The threshold is set by using the ip-in-use threshold command.
If you do not specify any parameters, this command enables SNMP notifications for all types of DHCP server events.
To report critical DHCP server events to an NMS, enable SNMP notifications for the DHCP server. For DHCP server event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Disable SNMP notifications of all types of DHCP server events.
[Sysname] undo snmp-agent trap enable dhcp server
# Disable SNMP IP exhaustion notifications.
[Sysname] undo snmp-agent trap enable dhcp server address-exhaust
# Disable SNMP IP allocation alarm notifications.
[Sysname] undo snmp-agent trap enable dhcp server allocated-ip
# Disable SNMP IP usage alarm notifications.
[Sysname] undo snmp-agent trap enable dhcp server ip-in-use
# Disable SNMP IP exhaustion notifications for IP pool groups.
[Sysname] undo snmp-agent trap enable dhcp server pool-group-exhaust
ip-in-use threshold
snmp-agent target-host (Network Management and Monitoring Command Reference)
static-bind
Use static-bind to statically bind a client ID or MAC address to an IP address.
Use undo static-bind to remove a static binding.
undo static-bind ip-address ip-address
No static binding is specified in an IP pool.
Common IP pool view
ip-address ip-address: Specifies the IP address of the static binding. The natural mask is used if no mask length or mask is specified. The subnet masks for Class A, B, and C IP addresses are 255.0.0.0, 255.255.0.0, and 255.255.255.0, respectively.
mask-length: Specifies the mask length in the range of 1 to 30.
mask mask: Specifies the mask, in dotted decimal format.
client-identifier client-identifier: Specifies the client ID of the static binding, a string of 4 to 254 characters. The string can contain only hexadecimal numbers and hyphen (-), in the format of H-H-H…. The last H can be a two-digit or four-digit hexadecimal number while the other Hs must be all four-digit hexadecimal numbers. For example, aabb-cccc-dd is correct, and aabb-c-dddd and aabb-cc-dddd are not correct. IPoE users do not support this option.
hardware-address hardware-address: Specifies the client hardware address of the static binding, a string of 4 to 39 characters. The string can contain only hexadecimal numbers and hyphen (-), in the format of H-H-H…. The last H can be a two-digit or four-digit hexadecimal number while the other Hs must be all four-digit hexadecimal numbers. For example, aabb-cccc-dd is correct, and aabb-c-dddd and aabb-cc-dddd are not correct. PPPoE users do not support this option.
ethernet: Specifies the client hardware address type as Ethernet. The default type is Ethernet.
token-ring: Specifies the client hardware address type as token ring.
When you configure a static binding in an address pool, make sure the IP address is within a network segment specified for dynamic address allocation in that address pool.
The IP address of a static binding must not be an interface address of the DHCP server. Otherwise, an IP address conflict occurs, and the bound client cannot obtain the IP address.
To avoid unexpected user offline events, do not specify any dynamically assigned IP addresses in this command.
If an IP address is already excluded from dynamic DHCP address allocation, you cannot use this command to configure a static DHCP binding for that IP address. To exclude an IP address from dynamic DHCP address allocation, use the dhcp server forbidden-ip command.
You can repeat this command to specify multiple static bindings in an IP pool.
An IP address can be bound to only one DHCP client. To modify the binding for a DHCP client, first execute the undo form of the command to delete the existing binding and then create a new binding.
This command is not supported in common IP address pools that are configured with the remote-server command and act as DHCP relay address pools.
# Bind IP address 10.1.1.1/24 to client ID 00aa-aabb in IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] static-bind ip-address 10.1.1.1 mask 255.255.255.0 client-identifier 00aa-aabb
display ip pool
tftp-server domain-name
Use tftp-server domain-name to specify a TFTP server name in an IP pool.
Use undo tftp-server domain-name to restore the default.
No TFTP server name is specified.
IP pool view
domain-name: Specifies the TFTP server name, a case-sensitive string of 1 to 63 characters.
# Specify TFTP server name aaa in IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] tftp-server domain-name aaa
display ip pool
tftp-server ip-address
Use tftp-server ip-address to specify a TFTP server address in an IP pool.
Use undo tftp-server ip-address to restore the default.
No TFTP server address is specified.
IP pool view
ip-address: Specifies the IP address of a TFTP server.
# Specify TFTP server address 10.1.1.1 in IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] tftp-server ip-address 10.1.1.1
display ip pool
unr preference
Use unr preference to set a UNR preference value for a BAS IP pool.
Use undo unr preference to restore the default.
unr preference preference-value
undo unr preference
The UNR preference value is 65 for a BAS IP pool.
preference-value: Sets a UNR preference value. The value range for this argument is 1 to 255.
When the DHCP server assigns an IP address, it adds the network route for the IP address to the route management module. A smaller UNR preference value indicates a higher priority.
The preference value modification does not affect the preference value for network routes that have been advertised.
# Set the UNR preference value to 1 for local BAS IP pool p1.
[Sysname-ip-pool-p1] unr preference 1
unr tag
Use unr tag to set a UNR tag value for a BAS IP pool.
Use undo unr tag to restore the default.
unr tag tag-value
undo unr tag
No UNR tag value is set for a BAS IP pool.
tag-value: Sets a UNR tag value. The value range for this argument is 0 to 4294967294.
The tag value modification does not affect the tag value for network routes that have been advertised.
This command takes effect only on BAS IP pools.
You can set a UNR tag value in system view or in IP pool view. For BAS access users, the value set in BAS IP pool view has higher priority than the one set in system view.
# Set the UNR tag value to 1 for local BAS IP pool p1.
[Sysname-ip-pool-p1] unr tag 1
ip unr
valid class
Use valid class to add DHCP user classes to the whitelist.
Use undo valid class to remove DHCP user classes from the whitelist.
valid class class-name&<1-8>
undo valid class class-name&<1-8>
No DHCP user class is listed on the whitelist.
IP pool view
class-name&<1-8>: Specifies a space-separated list of up to eight DHCP user classes by their names, a case-insensitive string of 1 to 63 characters.
For this command to take effect, you must enable the DHCP user class whitelist.
# Add DHCP user classes test1 and test2 to the whitelist in IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] valid class test1 test2
dhcp class
verify class
verify class
Use verify class to enable the DHCP user class whitelist.
Use undo verify class to disable the DHCP user class whitelist.
verify class
undo verify class
The DHCP user class whitelist is disabled.
IP pool view
After you enable the DHCP user class whitelist, the DHCP server processes requests only from clients on the DHCP user class whitelist.
The DHCP user class whitelist does not take effect on clients that request static IP addresses, and the server always processes their requests.
# Enable the DHCP user class whitelist in IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] verify class
valid class
voice-config
Use voice-config to configure the content for Option 184 in an IP pool.
Use undo voice-config to remove the Option 184 content from an IP pool.
voice-config { as-ip ip-address | fail-over ip-address dialer-string | ncp-ip ip-address | voice-vlan vlan-id { disable | enable } }
undo voice-config [ as-ip | fail-over | ncp-ip | voice-vlan ]
No Option 184 content is configured in an IP pool.
IP pool view
as-ip ip-address: Specifies the IP address of the backup network calling processor.
fail-over ip-address dialer-string: Specifies the failover IP address and dialer string. The dialer-string is a string of 1 to 39 characters. Valid characters are digits and asterisk (*).
ncp-ip ip-address: Specifies the IP address of the primary network calling processor.
voice-vlan vlan-id: Specifies the voice VLAN ID in the range of 2 to 4094.
·     disable: Disables the specified VLAN. DHCP clients will not take this VLAN as their voice VLAN.
·     enable: Enables the specified VLAN. DHCP clients will take this VLAN as their voice VLAN.
# Configure Option 184 in IP pool 0. The primary and backup network calling processors are at 10.1.1.1 and 10.2.2.2, respectively. The voice VLAN 3 is enabled. The failover IP address is 10.3.3.3. The dialer string is 99*.
[Sysname] ip pool 0
[Sysname-ip-pool-0] voice-config ncp-ip 10.1.1.1
[Sysname-ip-pool-0] voice-config as-ip 10.2.2.2
[Sysname-ip-pool-0] voice-config voice-vlan 3 enable
[Sysname-ip-pool-0] voice-config fail-over 10.3.3.3 99*
display ip pool
vpn-instance (IP pool view)
Use vpn-instance to apply an IP pool to a VPN instance.
Use undo vpn-instance to restore the default.
undo vpn-instance
The IP pool is not applied to any VPN instance.
IP pool view
If an IP pool is applied to a VPN instance, the DHCP server assigns IP addresses in this IP pool to clients in the specified VPN instance.
The DHCP server identifies the VPN instance to which a DHCP client belongs according to the following information:
·     The client's VPN information stored in authentication modules.
·     The VPN information of the DHCP server's interface that receives DHCP packets from the client.
The VPN information from authentication modules takes priority over the VPN information of the receiving interface.
# Apply IP pool 0 to VPN instance abc.
[Sysname] ip pool 0
[Sysname-ip-pool-0] vpn-instance abc
vpn-instance (IP pool group view)
Use vpn-instance to apply an IP pool group to a VPN instance.
undo vpn-instance
The IP pool group is not applied to any VPN instance.
IP pool group view
If an IP pool group is applied to a VPN instance, the IP pool group provides DHCP services for DHCP clients in the specified VPN instance.
If an IP pool group is not applied to a VPN instance, the IP pool group provides DHCP services for DHCP clients on the public network.
# Apply IP pool group g1 to VPN instance abc.
[Sysname] ip pool-group g1
[Sysname-ip-pool-group-g1] vpn-instance abc
Old-style DHCP server commands
This chapter introduces the old-style commands reserved for network management system (NMS) software compatibility. They are usable when the following conditions exist:
·     The NMS software does not support the related new-style commands.
·     Users want to use old-style commands for BRAS management purposes.
dhcp pool-group
Use dhcp pool-group to create a DHCP address pool group and enter its view, or enter the view of an existing DHCP address pool group.
Use undo dhcp pool-group to delete a DHCP address pool group.
dhcp pool-group pool-group-name
undo dhcp pool-group pool-group-name
No DHCP address pool groups exist.
pool-group-name: Specifies a DHCP address pool group name, a case-insensitive string of 1 to 63 characters.
Application scenarios
A BRAS might require software upgrade to provide support for new features, meeting the needs of business development. After software upgrade, the syntaxes of some configuration commands might change. To manage the upgraded BRAS without upgrading the NMS software, execute the bras compatible old-style-commands enable command to enable compatibility with old-style commands on the BRAS.
If compatibility with old-style commands is enabled on the BRAS, you cannot execute the new-style commands. If compatibility with old-style commands is disabled on the BRAS, you cannot execute the old-style commands.
Operating mechanism
For a DHCP client that matches a DHCP address pool group, the DHCP server selects an IP address from an available address pool in the matching address pool group.
# Create DHCP address pool group poolgroup1 and enter its view.
[Sysname] dhcp pool-group poolgroup1
bras compatible old-style-commands enable (BRAS Services Command Reference)
ip pool-group (new style)
dhcp server ip-pool
Use dhcp server ip-pool to create a DHCP address pool and enter its view, or enter the view of an existing DHCP address pool.
Use undo dhcp server ip-pool to delete a DHCP address pool.
dhcp server ip-pool pool-name
undo dhcp server ip-pool pool-name
No DHCP address pools exist.
pool-name: Specifies a DHCP address pool name, a case-insensitive string of 1 to 63 characters. Each pool name uniquely identifies a DHCP address pool.
Operating mechanism
You can use this command to create common IP address pools.
If compatibility with old-style commands is enabled on the BRAS, you can use the ip pool pool-name bas local command or its undo form to create or delete local BAS IP address pools as needed.
# Create DHCP address pool pool1 and enter its view.
[Sysname] dhcp server ip-pool pool1
ip pool (new style)
display dhcp pool-group
Use display dhcp pool-group to display information about DHCP address pool groups.
display dhcp pool-group [ all | [ name pool-group-name ] [ vpn-instance vpn-instance-name ] ] [ verbose ]
all: Displays information about all DHCP address pool groups for the public network and VPN instances.
name pool-group-name: Specifies a DHCP address pool group name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all DHCP address pool groups.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about DHCP address pool groups for the public network.
verbose: Displays detailed information about DHCP address pool groups and their address pools. If you do not specify this keyword, the command displays brief information about DHCP address pool groups and their address pools.
If you specify neither of the name and vpn-instance keywords, this command displays information about all DHCP address pool groups on the public network.
After you enable compatibility with old-style commands on a BRAS by using the bras compatible old-style-commands enable command, the display dhcp pool-group command displays information about DHCP address pool groups on the BRAS as follows:
·     Information supported by both the old and new styles is displayed in old style.
·     Information supported by only the new style is displayed in new style.
# Display brief information about DHCP address pool group group1.
<Sysname> display dhcp pool-group name group1
Pool-group: group1
  VPN instance name: N/A
  Discover-nak-count: 0 0(sec)
  Ip-in-use threshold: 100
  Undo exhaustion trap enable
  Undo exhaustion log enable
  Undo ip-pool algorithm round-robin local remote
  Total IP addresses: 254
  Used IP addresses: 0
    Automatic: 0
    Manual: 0
  Idle IP addresses: 253
    Free IP addresses: 253
    Expired IP addresses: 0
    Conflict reusable IP addresses: 0
  Forbidden IP addresses: 0
  Gateway IP addresses: 0
  Pre allocated IP addresses: 0
  Reserved IP addresses: 0
  Conflict IP addresses: 0
  Current pool: 1
  Pool group usage: 0.39%
  Bound pools: 1
    group1
# Display detailed information about all DHCP address pool groups.
<Sysname> display dhcp pool-group verbose
Pool-group: 1
    Automatic: 0
    Manual: 0
  Current pool: 1
  Bound pools: 1
Pool name: 1
  Pool index: 1
  Pool type: Common
  Pool-group-name:
    1
  Network: 10.1.1.0 mask 255.255.255.0
  undo exhaustion log enable
  dhcp-server nak-count 10
  expired day 1 hour 0 minute 0 second 0
  reserve expired-ip mode client-id time 4294967295 limit 256000
  ip-in-use threshold 100
  undo allocate-new-ip enable
  IP address statistics
    Used:                              0
    Pool utilization:                  0.39%
    Bindings:
      Automatic:                       0
      Manual:                          0
      Expired:                         0
      Reserve:                         0
    Conflicts:                         0
    PreAlloc:                          0
    Forbidden:                         0
    Gateway:                           0
Table 29 Command output
Pool-group
Name of the DHCP address pool group.
VPN instance name
Name of the VPN instance to which the DHCP address pool group is applied. This field displays N/A if the DHCP address pool group is on the public network.
Ip-in-use threshold
IP address usage threshold for the DHCP address pool group, in percentage.
Discover-nak-count: xx yy(sec)
If the relay agent has received more than xx DHCP-NAK messages from a DHCP server in response to DHCP-DISCOVER messages within yy seconds, the relay agent forwards DHCP-DISCOVER messages to the DHCP server in the next remote BAS IP pool.
Exhaustion trap enable
IP resource exhaustion alarming is enabled for the DHCP address pool group. If this feature is disabled, this field displays Undo exhaustion trap enable.
IP resource exhaustion logging is disabled for the DHCP address pool group. If this feature is enabled, this field displays Exhaustion log enable.
Round-robin address pool selection is enabled for the DHCP address pool group:
·     If the DHCP address pool group selects local address pools for address allocation in a round-robin manner, this field displays Ip-pool algorithm round-robin local.
·     If the DHCP address pool group selects remote BAS address pools for address allocation in a round-robin manner, this field displays Ip-pool algorithm round-robin remote.
·     If the DHCP address pool group uses the default method to select address pools for address allocation, this field displays Undo ip-pool algorithm round-robin local remote.
Total IP addresses
Total number of IP addresses in the DHCP address pool group.
Used IP addresses
Number of assigned IP addresses in the DHCP address pool group.
Conflicting IP addresses
Number of conflicting IP addresses in the DHCP address pool group.
Free IP addresses
Number of free IP addresses in the DHCP address pool group.
Static bindings
Number of statically bound IP addresses in the DHCP address pool group.
Excluded IP addresses
Number of IP addresses excluded from dynamic allocation in the DHCP address pool group.
Current pool
Address pool in use by the DHCP address pool group. If the pool group does not have any address pools, this field displays N/A.
Pool group usage
Address usage of the DHCP address pool group.
Bound pools
Number of bound address pools and their names. Each line displays only one address pool name.
Pool name
Information about the bound address pool. For more information about the related fields, see the field description table for the output of the display dhcp server pool command.
display ip pool-group (new style)
Use display dhcp server pool to display DHCP address pool information.
display dhcp server pool [ all | name pool-name | pool-group pool-group-name | vpn-instance vpn-instance-name ] [ verbose ]
all: Displays information about all DHCP address pools for the public network and VPN instances.
name pool-name: Specifies a DHCP address pool by its name. The pool-name argument is a case-insensitive string of 1 to 63 characters.
pool-group pool-group-name: Specifies a DHCP address pool group by its name. The pool-group-name argument is a case-insensitive string of 1 to 63 characters.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays DHCP address pool information for the public network.
verbose: Displays detailed DHCP address pool information. If you do not specify this keyword, the command displays brief DHCP address pool information.
If you specify none of the name pool-name, pool-group pool-group-name, and vpn-instance vpn-instance-name options, this command displays information about all DHCP address pools on the public network.
After you enable compatibility with old-style commands on a BRAS by using the bras compatible old-style-commands enable command, the display dhcp server pool command displays information about DHCP address pools on the BRAS as follows:
# Display brief information about DHCP address pool pool1.
<Sysname> display dhcp server pool name pool1
Pool name: pool1
  Pool index: 1
  Pool type: Common
  Pool-group-name:
    1
  Network: 20.1.1.0 mask 255.255.255.0
  address range 20.1.1.1 to 20.1.1.15
  class departmentA range 20.1.1.20 to 20.1.1.29
  class departmentB range 20.1.1.30 to 20.1.1.40
  next-server 20.1.1.33
  tftp-server domain-name www.example.org.cn
  tftp-server ip-address 192.168.0.120
  voice-config ncp-ip 10.1.1.2
  voice-config as-ip 10.1.1.5
  voice-config fail-over 10.1.1.1 123*
  option 2 ip-address 1.1.1.3
  secondary networks:
# Display detailed information about DHCP address pool pool1.
<Sysname> display dhcp server pool name pool1 verbose
Pool name: pool1
  Pool index: 1
  Pool type: Common
  Pool-group-name:
    1
    Free IP addresses:                 254
    Used:                              0
    Pool utilization:                  0.00%
    Bindings:
      Automatic:                       0
      Manual:                          0
      Expired:                         0
      Reserve:                         0
    Conflicts:                         0
    PreAlloc:                          0
    Forbidden:                         0
    Gateway:                           0
Table 30 Command output
Pool name (lock strict )
Name of the DHCP address pool. The field in parentheses represents the lock state of the DHCP address pool.
·     lock—Locked in loose mode. The server responds to the lease renewal requests from online DHCP clients for IP addresses in the pool, but it does not assign IP addresses from the pool to new DHCP clients.
·     lock strict—Locked in strict mode. The server does not respond to the lease renewal requests from online DHCP clients for IP addresses in the pool or assign IP addresses from the pool to new DHCP clients.
If you do not lock the DHCP address pool, this command will not display lock state information.
Pool group name
Name of the DHCP address pool group to which the address pool is added.
If the address pool does not belong to any DHCP address pool group, this field is not displayed.
If the address pool belongs to multiple DHCP address pool groups, each line displays only one DHCP address pool group name.
Pool index
Index of the DHCP address pool.
Pool type
Type of the DHCP address pool.
Network
Network segment used for dynamic address allocation.
Maximum number of DHCP-NAK packets that the DHCP relay agent can receive from a DHCP server.
IP resource exhaustion logging is enabled to record IP resource exhaustion events and recoveries from the IP resource exhaustion state. If this feature is disabled, this field displays undo exhaustion log enable.
undo exhaustion trap enable
IP resource exhaustion alarming is disabled. If this feature is enabled, this field displays exhaustion trap enable.
route-log enable
Route logging is enabled for the DHCP address pool. If route logging is disabled, this field displays undo route-log enable.
secondary networks
Secondary network segments configured for dynamic address allocation.
address range
Address range configured for dynamic address allocation.
class class-name range
DHCP user class and its address range.
static bindings
Static IP-to-MAC/client ID bindings.
option
Customized DHCP option.
expired
Lease duration. For example, expired day 1 hour 2 minute 3 second 4 indicates a lease of 1 day, 2 hours, 3 minutes, and 4 seconds.
If the lease never expires, this field displays unlimited.
If the DHCP server is allowed to use the DHCP client-suggested lease duration, allow-hint is displayed on the right of the lease duration.
remote server
DHCP server address in the DHCP relay address pool. After you create a relay address pool on the DHCP relay agent and execute the remote-server command, this field is displayed.
active remote server
Active DHCP server address.
After you create a relay address pool on the DHCP relay agent and execute the remote-server command, this field is displayed. The displayed value depends on the DHCP server selection algorithm configuration.
·     If the polling algorithm is used, this field displays all. The DHCP relay agent forwards DHCP requests to all DHCP servers.
·     If the master-backup algorithm is used, this field displays the IP address of the active DHCP server. The DHCP relay agent forwards DHCP requests to the active DHCP server first.
remote server pool status
Status of the DHCP address pool on the remote DHCP server side.
·     Available—The pool has assignable IP addresses. A minimum of one address pool has assignable IP addresses on the remote DHCP server side.
·     Unavailable—The pool has no assignable IP addresses. None of the address pools have assignable IP addresses on the remote DHCP server side.
This field is supported by only remote DHCP address pools.
bootfile-name
Boot file name to be assigned to DHCP clients.
dns-list
DNS server IP addresses to be assigned to DHCP clients.
domain-name
Domain name suffix to be assigned to DHCP clients.
bims-server
BIMS server information to be assigned to DHCP clients.
forbidden-ip
IP addresses excluded from DHCP allocation in the address pool.
dhcp-server source-address
Source address specified for DHCP packets that are relayed from the DHCP relay agent to the DHCP server.
gateway-list
Gateway addresses to be assigned to DHCP clients.
nbns-list
WINS server addresses to be assigned to DHCP clients.
netbios-type
NetBIOS node type to be assigned to DHCP clients.
next-server
IP address of the server that provides services for DHCP clients after they obtain IP addresses.
TFTP server name to be assigned to DHCP clients.
TFTP server IP address to be assigned to DHCP clients.
voice-config ncp-ip
IP address of the primary network calling processor to be assigned to DHCP clients.
voice-config as-ip
IP address of the backup network calling processor to be assigned to DHCP clients.
Voice VLAN ID to be assigned to DHCP clients.
Failover IP address and dialer string to be assigned to DHCP clients.
IP address reservation is enabled for the DHCP address pool.
reserve expired-ip disable
IP address reservation is disabled for the DHCP address pool.
IP address reservation mode, reservation time for expired IP addresses, and the maximum number of IP addresses that can be reserved in the DHCP address pool.
In this example, the reservation mode is client ID, the reservation time is 4294967295 seconds, and the maximum number of IP addresses is 256000.
ip-in-use threshold
IP address usage threshold specified in the DHCP address pool.
Statistics about the IP addresses in the DHCP address pool.
Total IP addresses
Total number of IP addresses in the DHCP address pool.
Free IP addresses
Number of free IP addresses in the DHCP address pool.
Used
Number of assigned IP addresses in the DHCP address pool.
Pool utilization
IP address usage of the DHCP address pool.
Bindings
Number of IP address bindings in different states:
·     Automatic—Number of dynamically assigned IP addresses.
·     Manual—Number of manually assigned IP addresses.
·     Expired—Number of lease-expired IP addresses.
·     Reserve—Number of reserved IP addresses.
Conflicts
Number of conflicting IP addresses.
PreAlloc
Number of pre-assigned IP addresses.
Forbidden
Number of IP addresses excluded from dynamic address assignment. The Used or Reserved field displays the number of excluded IP addresses that are already in use or are occupied.
Gateway
Number of gateway addresses configured in the DHCP address pool.
display ip pool (new style)
DHCP relay agent commands
dhcp-proxy enable
Use dhcp-proxy enable to enable DHCP proxy.
Use undo dhcp-proxy enable to disable DHCP proxy.
dhcp-proxy enable
DHCP proxy is enabled.
Interface view
When DHCP proxy is enabled on the device, the proxy forwards packets between DHCP clients and DHCP servers.
·     When receiving DHCP requests from DHCP clients, the proxy forwards them to DHCP servers.
·     When receiving DHCP responses from DHCP servers, the proxy performs the following task:
a.     Changes the DHCP server's IP address in these responses to the IP address of the output interface or the IP address in the giaddr field.
b.     Sends the responses to the DHCP clients.
# Enable DHCP proxy on Ten-GigabitEthernet 3/1/1.
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] dhcp-proxy enable
dhcp relay always-unicast
Use dhcp relay always-unicast to enable the DHCP relay agent to always unicast relayed DHCP responses.
Use undo dhcp relay always-unicast to restore the default.
The DHCP relay agent reads the broadcast flag in a DHCP response to decide whether to broadcast or unicast the relayed response.
This command enables the DHCP server to ignore the broadcast flag in DHCP responses and always unicast all relayed responses.
# Enable the DHCP relay agent to always unicast relayed DHCP responses.
[Sysname] dhcp relay always-unicast
dhcp select relay
dhcp relay check mac-address
Use dhcp relay check mac-address to enable MAC address check on the relay agent.
Use undo dhcp relay check mac-address to disable MAC address check on the relay agent.
The MAC address check feature is disabled.
Interface view
This feature enables the DHCP relay agent to compare the chaddr field of a received DHCP request with the source MAC address in the frame header. If they are the same, the DHCP relay agent forwards the request to the DHCP server. If they are not the same, the DHCP relay agent discards the request.
The MAC address check feature takes effect only when the dhcp select relay command has already been configured on the interface.
Enable the MAC address check feature only on the DHCP relay agent directly connected to the DHCP clients. A DHCP relay agent changes the source MAC address of DHCP packets before sending them.
# Enable MAC address check on the DHCP relay agent.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp relay check mac-address
dhcp select relay
dhcp relay client-information record
Use dhcp relay client-information record to enable recording client information in relay entries.
Use undo dhcp relay client-information record to disable the feature.
The DHCP relay agent does not record client information in relay entries.
Client information is recorded only when the DHCP relay agent is configured on the gateway of DHCP clients. A relay entry contains information about a client such as the client's IP and MAC addresses.
Disabling the recording of client information deletes all recorded relay entries.
The following information applies to WAN access users (for example, IPoE and PPPoE):
·     The relay agent does not record client information for WAN access users if it has an authorization IP pool.
·     The relay agent always records client information for WAN access users if it does not have an authorization IP pool. You cannot disable the relay agent from doing so.
# Enable the recording of relay entries on the relay agent.
[Sysname] dhcp relay client-information record
dhcp conflict-ip-address offline
dhcp relay client-information refresh
dhcp relay client-information refresh enable
Use dhcp relay client-information refresh to set the interval at which the DHCP relay agent refreshes relay entries.
Use undo dhcp relay client-information refresh to restore the default.
dhcp relay client-information refresh { auto | interval interval }
The refresh interval is automatically calculated based on the number of relay entries.
auto: Automatically calculates the refresh interval. The more the entries, the shorter the refresh interval. The shortest interval is 50 ms.
interval interval: Specifies the refresh interval in the range of 1 to 120 seconds.
This command does not take effect on WAN access users (for example, IPoE and PPPoE).
# Set the refresh interval to 100 seconds.
[Sysname] dhcp relay client-information refresh interval 100
Use dhcp relay client-information refresh enable to enable the DHCP relay agent to periodically refresh dynamic relay entries.
Use undo dhcp relay client-information refresh enable to disable the DHCP relay agent to periodically refresh dynamic relay entries.
The DHCP relay agent periodically refreshes relay entries.
A DHCP client unicasts a DHCP-RELEASE message to the DHCP server to release its IP address. The DHCP relay agent conveys the message to the DHCP server and does not remove the IP-to-MAC entry of the client.
With this feature, the DHCP relay agent uses a client's IP address and the relay interface's MAC address to periodically send a DHCP-REQUEST message to the DHCP server.
·     If the server returns a DHCP-ACK message or does not return any message within an interval, the DHCP relay agent performs the following operations:
¡     Removes the relay entry.
¡     Sends a DHCP-RELEASE message to the DHCP server to release the IP address.
·     If the server returns a DHCP-NAK message, the relay agent keeps the entry.
With this feature disabled, the DHCP relay agent does not remove relay entries automatically. After a DHCP client releases its IP address, you must use the reset dhcp relay client-information command on the relay agent to remove the corresponding relay entry.
This feature does not take effect on WAN access users (for example, IPoE and PPPoE). If the relay agent does not have an authorization IP pool, the relay agent removes the relay entry for a WAN access user after the lease for that user expires.
# Disable periodic refresh of relay entries.
[Sysname] undo dhcp relay client-information refresh enable
dhcp relay dhcp-server timeout
Use dhcp relay dhcp-server timeout to set the DHCP server response timeout time for DHCP server switchover.
Use undo dhcp relay dhcp-server timeout to restore the default.
dhcp relay dhcp-server timeout time
The DHCP server response timeout time is 30 seconds.
Interface view
time: Specifies the DHCP server response timeout time in the range of 1 to 65535 seconds.
# Set the DHCP server response timeout time to 60 seconds for DHCP server switchover on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp relay dhcp-server timeout 60
dhcp relay server-address algorithm
dhcp relay forward reply by-option82
Use dhcp relay forward reply by-option82 to configure the DHCP relay agent to forward DHCP replies based on Option 82.
Use undo dhcp relay forward reply by-option82 to restore the default.
The DHCP relay agent does not forward DHCP replies based on Option 82.
Interface view
This command takes effect only after you execute the dhcp relay information enable and dhcp relay information circuit-id commands.
# Configure the DHCP relay agent to forward DHCP replies based on Option 82.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp relay forward reply by-option82
dhcp relay gateway
Use dhcp relay gateway to specify the DHCP relay agent address to be padded to DHCP requests.
Use undo dhcp relay gateway to restore the default.
dhcp relay gateway ip-address
The primary IP address of the interface is padded to DHCP requests as the DHCP relay agent address.
Interface view
ip-address: Specifies the DHCP relay agent address. It must be an IP address of the interface.
The DHCP relay agent uses the specified IP address instead of the primary IP address of the relay interface as the DHCP relay agent address.
# Specify 10.1.1.1 as the DHCP relay agent address to be padded to DHCP requests on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp relay gateway 10.1.1.1
gateway-list
Use dhcp relay information circuit-id to configure the padding mode and padding format for the Circuit ID sub-option of Option 82.
Use undo dhcp relay information circuit-id to restore the default.
dhcp relay information circuit-id { bas [ sub-interface-vlan ] [ with-vxlan ] | string circuit-id | { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] [ interface [ vlan-in-vlan ] ] } [ sub-interface-vlan ] [ format { ascii | hex } ] }
The padding mode is normal and the padding format is hex.
Interface view
bas: Specifies the bas mode that uses the interface and VLAN information to pad the Circuit ID sub-option. The device encapsulates the information in the format of interface-type slot/subslot/port vxlan_id.vlan_id.subvlan_id.
sub-interface-vlan: Specifies the VLAN ID of the L2VE subinterface as the content for the Circuit ID sub-option. If you do not specify this keyword, the VLAN ID of the interface on which you configure this command is written to the sub-option. This keyword is available only for L3VE interfaces. This keyword is not supported by the device.
with-vxlan: Specifies the bas mode with VXLAN ID. If you do not specify this keyword, you specify the bas mode without VXLAN ID.
string circuit-id: Specifies the string mode that uses a case-sensitive string of 3 to 63 characters as the content of the Circuit ID sub-option.
normal: Specifies the normal mode, in which the padding content consists of the VLAN ID and port number.
verbose: Specifies the verbose mode. The padding content includes the node identifier, interface information, and VLAN ID. The default node identifier is the MAC address of the access node. The default interface information consists of the Ethernet type (fixed to eth), chassis number, slot number, sub-slot number, and interface number.
node-identifier { mac | sysname | user-defined node-identifier }: Specifies the access node identifier.
·     mac: Uses the MAC address of the access node as the node identifier.
·     sysname: Uses the device name as the node identifier. You can set the device name by using the sysname command in system view. The padding format for the device name is always ASCII regardless of the specified padding format. If you specify this keyword, do not include any spaces when you set the device name. Otherwise, the DHCP relay agent fails to add or replace Option 82.
·     user-defined node-identifier: Uses a case-sensitive string of 1 to 50 characters as the node identifier. The padding format for the specified character string is always ASCII regardless of the specified padding format.
interface: Uses the interface name as the interface information. If you specify this keyword, the padding format for the interface name and VLAN ID is always ASCII regardless of what padding format is specified.
vlan-in-vlan: Pads the Circuit ID sub-option with the inner and outer VLAN information of  request packets. The padding format for the VLAN information is always ASCII. This field is supported only when sysname is specified as the node identifier.
format: Specifies the padding format for the Circuit ID sub-option.
ascii: Specifies the ASCII padding format.
hex: Specifies the hex padding format.
The Circuit ID sub-option cannot carry information about interface splitting or subinterfaces. For more information about interface splitting and subinterfaces, see Interface Configuration Guide.
The padding format for the string mode, the normal mode, or the verbose mode varies by command configuration. Table 31 shows how the padding format is determined for different modes.
Table 31 Padding format for different modes
Keyword (mode)
If no padding format is set
If the padding format is ascii
If the padding format is hex
string circuit-id
The padding format is ASCII, and is not configurable.
N/A
N/A
normal
Hex.
ASCII.
Hex.
verbose
Hex for the VLAN ID.
ASCII for the node identifier, Ethernet type, chassis number, slot number, sub-slot number, and interface number.
ASCII.
ASCII for the node identifier and Ethernet type.
Hex for the chassis number, slot number, sub-slot number, interface number, and VLAN ID.
# Specify the content mode as verbose, node identifier as the device name, and the padding format as ASCII for the Circuit ID sub-option.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp relay information enable
[Sysname-Ten-GigabitEthernet3/1/1] dhcp relay information strategy replace
[Sysname-Ten-GigabitEthernet3/1/1] dhcp relay information circuit-id verbose node-identifier sysname format ascii
display dhcp relay information
Use dhcp relay information enable to enable the DHCP relay agent to support Option 82.
Use undo dhcp relay information enable to disable Option 82 support.
The DHCP relay agent does not support Option 82.
Interface view
This command enables the DHCP relay agent to add Option 82 to DHCP requests that do not contain Option 82 before forwarding the requests to the DHCP server. The content of Option 82 is determined by the dhcp relay information circuit-id and dhcp relay information remote-id commands. If the DHCP requests contain Option 82, the relay agent handles the requests according to the strategy configured with the dhcp relay information strategy command.
If this feature is disabled, the relay agent forwards requests that contain or do not contain Option 82 to the DHCP server.
# Enable Option 82 support on the relay agent.
Use dhcp relay information remote-id to configure the padding mode and padding format for the Remote ID sub-option of Option 82.
Use undo dhcp relay information remote-id to restore the default.
Interface view
normal: Specifies the normal mode in which the padding content is the MAC address of the receiving interface.
format: Specifies the padding format for the Remote ID sub-option. The default padding format is hex.
string remote-id: Specifies the string mode that uses a case-sensitive string of 1 to 63 characters as the content of the Remote ID sub-option.
sysname: Specifies the sysname mode that uses the device name as the content of the Remote ID sub-option. You can set the device name by using the sysname command.
The padding format for the specified character string (string) or the device name (sysname) is always ASCII. The padding format for the normal mode is determined by the command.
# Specify the padding content for the Remote ID sub-option of Option 82 as device001.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp relay information remote-id string device001
Use dhcp relay information strategy to configure the strategy for the DHCP relay agent to handle messages containing Option 82.
Use undo dhcp relay information strategy to restore the default handling strategy.
The handling strategy for messages that contain Option 82 is replace.
Interface view
drop: Drops DHCP messages that contain Option 82 messages.
keep: Keeps the original Option 82 intact and forwards the DHCP messages.
replace: Replaces the original Option 82 with the configured Option 82 before forwarding the DHCP messages.
This command takes effect only on DHCP requests that contain Option 82.
For DHCP requests that do not contain Option 82, the DHCP relay agent always adds Option 82 to the requests before forwarding the requests to the DHCP server.
If the handling strategy is replace, configure a padding mode and padding format for Option 82. If the handling strategy is keep or drop, you do not need to configure any padding mode or padding format. The settings do not take effect even if you configure them.
# Specify the handling strategy for Option 82 as keep.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp relay information strategy keep
dhcp relay master-server switch-delay
Use dhcp relay master-server switch-delay to enable the switchback to the master DHCP server and set the switchback delay time.
Use undo dhcp relay master-server switch-delay to restore the default.
dhcp relay master-server switch-delay delay-time
The DHCP relay agent does not switch back to the master DHCP server.
Interface view
delay-time: Specifies the delay time in the range of 1 to 65535 minutes.
# Configure the DHCP relay agent to switch back to the master DHCP server 3 minutes after it switches to a backup DHCP server on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp relay master-server switch-delay 3
dhcp relay non-first-hop enable
Use dhcp relay non-first-hop enable to enable the non-first-hop DHCP relay agent feature.
Use undo dhcp relay non-first-hop enable to disable the non-first-hop DHCP relay agent feature.
The non-first-hop DHCP relay agent feature is disabled.
Interface view
Multiple DHCP relay agents might exist between a DHCP client and the DHCP server. By default, only the first DHCP relay agent that the DHCP request passes through processes the request and the subsequent DHCP relay agents only forward the request. If access authentication is enabled on a non-first DHCP relay agent, execute this command on this relay agent for the relay agent to deliver the packet to the authentication module for authentication and authorization.
Enable this feature only on the non-first-hop DHCP relay agent where access authentication is enabled.
To have this feature function correctly, follow these restrictions and guidelines when you configure it on a non-first-hop DHCP relay device:
·     Enable DHCP relay agent on the downstream interface of the device.
·     Enable the non-first-hop DHCP relay agent feature on both the upstream and downstream interfaces of the device.
·     Do not use the following commands to change the value in the giaddr field:
¡     dhcp relay gateway
¡     dhcp relay source-address
# Enable the non-first-hop DHCP relay agent feature on Ten-GigabitEthernet3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp relay non-first-hop enable
dhcp select relay
dhcp relay release ip
Use dhcp relay release ip to release a client IP address.
ip-address: Specifies the IP address to be released.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the specified IP address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command releases the IP address on the public network.
Operating mechanism
After you execute this command, the relay agent sends a DHCP-RELEASE message to the DHCP server and removes the relay entry of the IP address. Upon receiving the message, the server removes binding information about the specified IP address to release the IP address.
Before you release a client's IP address, first execute the dhcp relay release-agent` command on the client-attached relay interface. This ensures that the DHCP server is notified to release the lease of this IP address while the relay agent removes the user relay entry.
# Release IP address 1.1.1.1.
[Sysname] dhcp relay release ip 1.1.1.1
Use dhcp relay release-agent to enable lease release notification.
Use undo dhcp relay release-agent to disable lease release notification.
Lease release notification is enabled.
Interface view
This command enables the DHCP relay agent to send a Release message to the DHCP server after it deletes a DHCP relay entry. After the DHCP server receives the message, it reclaims the IP address and marks the lease as expired.
This command does not take effect on PPPoE users after you use the cut access-user command to forcibly log out users. The DHCP relay agent will always send Release messages to the DHCP server. For more information about the cut access-user command, see UCM commands in BRAS Services Command Reference.
# Disable lease release notification on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp select relay
[Sysname-Ten-GigabitEthernet3/1/1] undo dhcp relay release-agent
cut access-user (BRAS Services Command Reference)
dhcp select relay
Use dhcp relay server-address to specify DHCP servers on the DHCP relay agent.
Use undo dhcp relay server-address to remove DHCP servers.
dhcp relay server-address ip-address [ public | vpn-instance vpn-instance-name ]
undo dhcp relay server-address [ ip-address [ public | vpn-instance vpn-instance-name ] ]
No DHCP server is specified on the DHCP relay agent.
Interface view
ip-address: Specifies the IP address of a DHCP server. The DHCP relay agent forwards DHCP packets received from DHCP clients to this DHCP server.
public: Specifies this option if the specified DHCP server is on the public network.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the specified DHCP server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters.
To ensure a successful address allocation, the DHCP server must be located on a different subnet from the DHCP relay agent interface.
The DHCP relay agent forwards the packets from clients to the specified DHCP server in the specified virtual network (MPLS L3VPN instance or the public network). If you do not specify an MPLS L3VPN instance or the public network, the DHCP relay agent forwards the packets from a client in the same virtual network as the client.
You can specify a maximum of eight DHCP servers on an interface. The DHCP relay agent forwards the packets from the clients to all the specified DHCP servers.
If you do not specify an IP address, the undo dhcp relay server-address command removes all DHCP servers on the interface.
# Specify DHCP server address 1.1.1.1 on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp relay server-address 1.1.1.1
dhcp select relay
display dhcp relay interface
display dhcp relay remote-server-info
Use dhcp relay server-address algorithm to specify the DHCP server selection algorithm.
Use undo dhcp relay server-address algorithm to restore the default.
dhcp relay server-address algorithm { master-backup | polling }
The polling algorithm is used. The DHCP relay agent forwards DHCP requests to all DHCP servers at the same time.
Interface view
master-backup: Forwards DHCP requests to the master DHCP server first. If the master server is not available or does not have assignable IP addresses, the relay agent forwards DHCP requests to backup DHCP servers in the order they are specified.
polling: Forwards DHCP requests to all DHCP servers at the same time.
# Specify master-backup as the DHCP server selection algorithm on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp relay server-address algorithm master-backup
remote-server algorithm
Use dhcp relay source-address to specify the source IP address for DHCP requests.
Use undo dhcp relay source-address to restore the default.
dhcp relay source-address { ip-address [ option code [ option-text ] ] | gateway | relay-interface }
undo dhcp relay source-address { ip-address [ option code [ option-text ] ] | gateway | relay-interface }
The relay agent chooses the default source IP address for relayed requests depending on whether its server-side interface and the DHCP server belong to the same VPN instance:
·     If they belong to the same VPN instance, the relay agent uses the IP address of the output interface for relayed requests as the default source IP address.
·     If they belong to different VPN instances, the relay agent uses the lowest IP address that is in the same VPN instance as the DHCP server as the default source address.
Interface view
ip-address: Specifies the source IP address for DHCP requests. This IP address will also be filled in the giaddr field.
option code [ option-text ]: Changes the source IP address and the giaddr field of a DHCP request if the DHCP request carries the specified option. If you do not specify any option, this command changes the source IP address and the giaddr field of all DHCP requests that the interface receives.
·     The code argument represents the option code and the value range for this argument is 1 to 254.
·     To match DHCP requests by the content of Option 60, specify the option-text argument. This argument is available only when the value for the code argument is 60. The value for this argument is a case-sensitive string of 1 to 128 characters.
gateway: Uses the IP address in the giaddr field as the source IP address of the DHCP requests. If the giaddr field is empty, the relay agent follows the default rule to specify the source IP address for DHCP requests.
relay-interface: Uses the primary IP address of the relay interface as the source IP address. If this interface does not have an IP address, the relay agent follows the default rule to specify the source IP address for DHCP requests.
Operating mechanism
If you specify the ip-address argument, the relay agent changes not only the source IP address but also the giaddr field of a DHCP request. The DHCP server assigns the client an IP address on the same subnet as the specified IP address in the giaddr field. As a result, the DHCP client might not be on the same subnet as the DHCP relay interface (the gateway). To avoid this problem, you must configure Option 82 on the relay agent before specifying the ip-address argument. This configuration enables the DHCP relay agent to insert the primary IP address of the relay interface in Option 82. Based on this option, the DHCP server assigns an IP address on the same subnet as the IP address of the relay interface. The DHCP relay agent looks up the MAC address table for the output interface to forward the DHCP reply.
If you do not specify any options, the undo dhcp relay source-address command removes all configured source IP addresses for DHCP requests on the interface.
The source IP addresses specified by the following commands overwrite each other and only the source IP address configured at last can take effect.
·     The dhcp relay source-address ip-address command without any DHCP options specified.
·     The dhcp relay source-address gateway command.
·     The dhcp relay source-address relay-interface command.
The dhcp relay source-address ip-address option code [ option-text ] and dhcp relay source-address { gateway | relay-interface } commands do not overwrite each other.
If multiple sources IP addresses are specified on an interface, their match order is as follows:
1.     Source IP addresses specified with DHCP options.
The relay agent matches these IP addresses against the DHCP options of a DHCP request in descending order of option values. The first matching IP address will be used as the source IP address for the DHCP request.
When the relay agent matches source IP addresses against Option 60, the source IP address with an option-text value take precedence over that without an option-text value.
2.     Source IP address specified by the dhcp relay source-address relay-interface command.
3.     Source IP address specified by the dhcp relay source-address gateway command.
4.     Source IP address specified by the dhcp relay source-address ip-address command without any DHCP option specified.
To ensure that DHCP clients can obtain IP addresses, do not configure this command in conjunction with the dhcp smart-relay enable command.
# Specify 1.1.1.1 as the source IP address for DHCP requests on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp relay source-address 1.1.1.1
dhcp server
Use dhcp server to configure DHCP server liveness detection.
Use undo dhcp server to restore the default.
dhcp server [ ip-address [ vpn-instance vpn-instance-name ] ] { dead-count dead-count-value | dead-time dead-time | nak-count nak-count-value | timeout timeout } *
undo dhcp server [ ip-address [ vpn-instance vpn-instance-name ] ] { dead-count | dead-time | nak-count | timeout } *
If the DHCP relay agent does not receive a reply from a DHCP server within 25 seconds, the DHCP relay agent determines that the DHCP server is down or has no free addresses.
ip-address: Specifies an IP address of the DHCP server. If you do not specify this keyword, the criteria apply to all DHCP servers.
vpn-instance vpn-instance name: Specifies an MPLS L3VPN instance to which DHCP servers belongs. The vpn-instance-name argument specifies a VPN instance name, a case-sensitive string of 1 to 31 characters. If you do not specify this keyword, the criteria apply to DHCP servers on the public network.
dead-count dead-count-value: Specifies a maximum number of consecutive communication failures before the relay agent marks a DHCP server as down. The value range for the dead-count-value argument is 1 to 64, and the default value is 0.
dead-time dead-time: Specifies a time period in seconds for the relay agent to wait before communicating with the DHCP server. The value range for the dead-time augment is 1 to 65536, and the default value is 3.
nak-count nak-count-value: Specifies the maximum number of DHCP-NAK packets that the relay agent can receive. The value range for the nak-count-value argument is 0 to 255, and the default value is 10.
timeout timeout: Specifies a communication failure check timer in seconds. The value range for the argument is 1 to 60, and the default value is 25.
The command is applicable to a network where a DHCP server is selected from a remote BAS IP pool in an IP pool group.
Operating mechanism
This feature enables the DHCP relay agent to detect the liveness of the specified remote DHCP servers. Upon relaying the first DHCP request to a DHCP server, the DHCP relay agent starts the timeout timer and the request counter. The DHCP relay agent starts the timeout timer each time it relays a DHCP request. When the timeout timer expires, the DHCP relay agent checks the total number of DHCP requests relayed to the DHCP server. A communication failure occurs if the relay agent does not receive a reply within the timeout timer.
The mechanism of DHCP server liveness detection varies by the DHCP server selection algorithm:
·     If the DHCP server selection algorithm is master-backup, the server liveness detection mechanism is as follows:
¡     Upon relaying the first DHCP request to the selected DHCP server, the DHCP relay agent starts the timeout timer configured for the DHCP server, and the request counter.
¡     If a reply is received within the timeout timer, the DHCP relay agent resets the request counter and disables the timeout timer. The relay agent starts the timer and the counter again when it relays a new request.
¡     At the end of every timeout period, the relay agent checks the total number of consecutive communication failures to determine whether the DHCP server is unavailable.
An unavailable DHCP server is a DHCP server in down ("dead") state or has no assignable IP addresses.
-     If the failure count does not exceed the dead-count-value value, the DHCP relay agent continues counting the number of requests. The DHCP relay agent marks the DHCP server unavailable if the dead-count-value value is reached at next check.
-     If the failure count exceeds the dead-count-value value, the DHCP relay agent marks the DHCP server unavailable. The DHCP relay agent will relay new requests to other available remote DHCP servers.
If all remote DHCP servers are marked unavailable, the DHCP relay agent will relay new requests to all remote DHCP servers without starting the timeout timer.
¡     If the total number of consecutively received DHCP-NAK messages for the relayed lease renewal packets reaches the nak-count value, the DHCP relay agent also marks the DHCP server unavailable.
·     If the DHCP server selection algorithm is polling, the server liveness detection mechanism is as follows:
¡     Upon relaying the first DHCP request to all of the specified remote DHCP servers, the DHCP relay agent starts the timeout timer and the request counter.
When different liveness detection settings are configured for the remote DHCP servers specified in the remote BAS IP pool, the DHCP relay agent uses the liveness detection settings that include the greatest timeout value. The relay agent detects only the liveness of the DHCP server corresponding to the used liveness detection settings. If the DHCP server is marked unavailable, the other DHCP servers in the remote BAS IP pool are also marked unavailable.
¡     If a reply that contains a usable address is received from a DHCP server within the timeout timer, the DHCP relay agent marks the DHCP server available. Meanwhile, the DHCP relay agent resets the request counter, and disables the timeout timer. The relay agent starts the timer and the counter again when it relays a new request.
¡     If a reply that notifies an address assignment failure is received from a DHCP server within the timeout timer, the DHCP relay agent marks the DHCP server unavailable. In this situation, the timeout timer keeps running and the DHCP relay agent continues counting the number of requests.
-     If the failure count does not exceed the dead-count-value value, the DHCP relay agent continues counting the number of requests and starts the timeout timer again when it relays a new request.
-     If the failure count exceeds the dead-count-value value, the DHCP relay agent marks all remote DHCP servers unavailable. In this situation, the DHCP relay agent relays new requests to all remote DHCP servers without starting the timeout timer.
When a DHCP server is marked unavailable, the relay agent starts the dead-time timer for the server. Within the dead-time timer, the relay agent does not relay any requests to the DHCP server even if the DHCP server is matched. After the dead-time timer expires, the relay agent determines that the DHCP server becomes available, and starts forwarding packets to this server.
When the DHCP relay agent receives a new DHCP request and all DHCP servers are marked unavailable, it treats all DHCP servers as available and relays the request to the first DHCP server.
The liveness detection settings specific to a DHCP server have a higher priority than the shared settings. If no DHCP server-specific settings are configured, the shared ones apply.
You can specify multiple server liveness detection rules for different DHCP server addresses. If you do not specify a DHCP server for the command, you are creating a shared detection rule. The DHCP server-specific detection rule or the shared rule takes effect as follows:
·     If you specify the same rule keyword but with different values in each command execution, the most recent configuration takes effect.
·     If you specify different rule keywords in each command execution, all configurations take effect.
# Configure DHCP server liveness detection for DHCP server at 1.1.1.1. Set the maximum number of consecutive communication failures to 10, set the communication failure check timer to 20 seconds, and set the DHCP server dead period to 3 minutes.
[Sysname] dhcp server 1.1.1.1 dead-count 10 timeout 20 dead-time 3
Use dhcp-server nak-count to set the maximum number of DHCP-NAK packets that the DHCP relay agent can receive from one DHCP server.
Use undo dhcp-server nak-count to restore the default.
dhcp-server nak-count nak-count-value [ gateway-only ]
The DHCP relay agent can receive a maximum of 10 DHCP-NAK packets from one DHCP server.
Remote BAS IP pool view
Common IP pool view
nak-count-value: Specifies the maximum number of DHCP-NAK packets, in the range of 0 to 255.
gateway-only: Disables the DHCP relay agent from sending a lease renew request to the next DHCP server. If you do not specify this keyword, the DHCP relay agent will turn to the next DHCP server when the maximum number of DHCP-NAK packets is reached.
This feature is applicable to a network where the DHCP relay agent uses the master-backup server selection in the remote BAS IP pool. In such a network, you can use the gateway command to specify gateway addresses for users that match the remote BAS IP pool. When the relay agent receives a lease renew request from a DHCP client, the relay agent forwards the request to the currently selected DHCP server. When the number of DHCP-NAK packets from the DHCP server reaches the upper limit, the DHCP relay agent performs one of the following operations, depending on the configuration:
·     If the gateway-only keyword is not configured, the DHCP relay agent forwards the request to the next DHCP server.
·     If the gateway-only keyword is configured and smart relay is enabled, the relay agent uses the next gateway address configured in the gateway command to fill the giaddr field in DHCP-DISCOVER messages.
·     If the gateway-only keyword is not configured and smart relay is enabled, the relay agent performs the following operations:
a.     Uses the next gateway address in the gateway command to fill the giaddr field in DHCP-DISCOVER messages.
b.     Forwards the request to the next DHCP server.
If the value for the nak-count-value argument is set to 0, both the master/backup DHCP server selection algorithm setting and the smart relay feature do not take effect.
# Allow the DHCP relay agent can receive the maximum number of 20 DHCP-NAK packets from a DHCP server.
[Sysname] ip poo1 1 bas remote
[Sysname-ip-pool-1] dhcp-server nak-count 20
remote-server algorithm master-backup
dhcp-server remote-ip-check bypass
Use dhcp-server remote-ip-check bypass to disable remote IP address check.
Use undo dhcp-server remote-ip-check bypass to restore the default.
Remote IP address check is enabled in IP address pools on the DHCP relay agent. Upon receiving an IP address from the server, the relay agent identifies whether that IP address belongs to the same subnet as the related gateway address in the relay address pool. If they do not belong to the same subnet, the DHCP user will fail to come online.
Common IP pool view
IP pool sharing is an addressing policy used in DHCP relay networks. This policy enables a DHCP client to obtain an IP address that does not belong to the same subnet as the giaddr address. When the address pool matching the giaddr address does not have usable addresses, the DHCP server can turn to other address pools that are in a sharing relationship with the matching address pool. This addressing policy ensures that DHCP clients can obtain valid IP addresses and guarantees stable network connections.
IP pool sharing is applicable to BRAS access authentication environments. It establishes a sharing relationship among authorization IP pools to ensure that DHCP clients can still obtain IP addresses when the IP pool that matches the giaddr address is exhausted.
Operating mechanism
On a DHCP relay network that does not deploy shared IP address pools, the DHCP relay agent performs remote IP address check by default. Upon receiving an IP address from the server, the relay agent identifies whether that IP address belongs to the same subnet as the related gateway address in the relay address pool. If they do not belong to the same subnet, the DHCP user will fail to come online.
To resolve this issue, use this command to disable remote IP address check in the related IP address pools and configure them as shared IP address pools. When the DHCP server cannot find an assignable IP address in the address pool matching the giaddr address, it assigns the requesting DHCP user an IP address from an address pool that is in a sharing relationship with the matching address pool. Upon receiving the assigned IP address, the relay agent directly sends it to the requesting DHCP user. As a result, the user can come online normally.
To achieve IP pool sharing in an authorization IP pool group of an authentication domain on a BRAS access network, you must execute this command on all member pools of that IP pool group.
# Disable remote IP address check in IP address pool pool1.
[Sysname] ip pool pool1 bas remote
[Sysname-ip-pool-pool1] dhcp-server remote-ip-check bypass
Use dhcp-server source-address to specify the source IP address of the packets that the relay agent forwards to the DHCP server.
Use undo dhcp-server source-address to restore the default.
dhcp-server source-address { ip-address | gateway | interface interface-type interface-number }
Common IP pool view
interface interface-type interface-number: Uses the IP address of the specified interface as the source IP address. The interface-type interface-number argument specifies the interface type and the interface number.
This command is required if multiple relay interfaces share the same IP address or if a relay interface does not have routes to DHCP servers. You can use this command to specify the IP address of another interface, typically a loopback interface, on the DHCP relay agent as the source IP address for relayed DHCP requests.
If multiple relay interfaces share the same IP address, the DHCP relay agent cannot locate the output interface for DHCP reply packets based on the destination IP address. To avoid this problem, configure the DHCP relay agent to support Option 82 before executing dhcp-server source-address command. This configuration enables the DHCP relay agent to insert the subnet information in sub-option 5 in Option 82 for the received DHCP request. The DHCP server then assigns an IP address according to sub-option 5. The DHCP relay agent looks up the output interface in the MAC address table to forward the DHCP reply packets.
# In remote BAS IP pool 0, specify 1.1.1.1 as the source IP address for DHCP requests.
[Sysname] ip pool 0 bas remote
[Sysname-ip-pool-0] dhcp-server source-address 1.1.1.1
dhcp-server timeout
Use dhcp-server timeout to set the DHCP server response timeout time for DHCP server switchover.
Use undo dhcp-server timeout to restore the default.
Common IP pool view
# Set the DHCP server response timeout time to 60 seconds for DHCP server switchover in remote BAS IP pool 0.
[Sysname-ip-pool-0] dhcp-server timeout 60
Use dhcp smart-relay enable to enable the DHCP smart relay feature.
Use undo dhcp smart-relay enable to disable the DHCP smart relay feature.
The DHCP smart relay feature is disabled.
Operating mechanism
When the smart relay feature is disabled, the relay agent always uses the primary IP address as the gateway address.
The smart relay feature allows the relay agent to use secondary IP addresses of relay interfaces as gateway addresses when the DHCP server does not reply to DHCP-DISCOVER messages. When the relay agent initially forwards a DHCP-DISCOVER message, it adds the primary IP address of the relay interface to the giaddr field of the message. The relay agent will forward the DHCP-DISCOVER message with a secondary IP address of the relay interface in the giaddr field of the message in the following situations:
·     The DHCP relay does not receive a response from the DHCP server after three consecutive forwarding attempts.
·     The DHCP relay does not receive a response from the DHCP server within 30 seconds of a single attempt.
To ensure that DHCP clients can obtain IP addresses, do not use this command in conjunction with the dhcp relay source-address command.
# Enable the DHCP smart relay feature.
[Sysname] dhcp smart-relay enable
dhcp select
gateway-list
discover-nak-count
Use discover-nak-count to set the DHCP-NAK threshold and statistic period for DHCP-NAK-triggered remote BAS IP pool switchover in an IP pool group.
Use undo discover-nak-count to restore the default.
discover-nak-count nak-count seconds
The relay agent forwards DHCP-DISCOVER messages to the server in the current remote BAS IP pool, regardless of how many DHCP-NAK messages it has received from that server.
IP pool group view
nak-count: Sets the threshold on the number of DHCP-NAK responses to DHCP-DISCOVER messages. The value range for this argument is 1 to 255. If you set this argument to 1, the relay agent forwards DHCP-DISCOVER messages to the server in the next remote BAS IP pool after it receives one DHCP-NAK message from the current server.
seconds: Sets the statistic period in seconds. The value range for this argument is 1 to 180.
Some DHCP servers respond with DHCP-NAK messages to the DHCP-DISCOVER messages from clients when they have no assignable IP addresses. By default, the relay agent continues to forward DHCP-DISCOVER messages to the server, regardless of how many DHCP-NAK messages it has received from that server. If the server is in one remote BAS IP pool in an IP pool group, the relay agent does not move to the next remote BAS IP pool, if any.
For clients to obtain an IP address as soon as possible from one of the remote BAS IP pools in an IP pool group, set the DHCP-NAK threshold and statistic period to trigger remote BAS IP pool switchover.
# Set the DHCP-NAK threshold and the statistic period for triggering remote BAS IP pool switchover in IP pool group poolgroup1 to 3 and 10, respectively. If a DHCP server has returned more than three DHCP-NAK messages to DHCP-DISCOVER messages within 10 seconds, the relay agent moves to the next remote BAS IP pool.
[Sysname] ip pool-group poolgroup1
[Sysname-ip-pool-group-poolgroup1] discover-nak-count 3 10
display dhcp relay client-information
Use display dhcp relay client-information to display relay entries on the relay agent.
display dhcp relay client-information [ interface interface-type interface-number | [ ip ip-address ] [ vpn-instance vpn-instance-name ] ]
interface interface-type interface-number: Displays relay entries on the specified interface. If you do not specify an interface, this command displays relay entries on all interfaces.
ip ip-address: Displays the relay entry for the specified IP address. If you do not specify an IP address, this command displays relay entries for all IP addresses.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the specified IP address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command applies to the public network and all private networks.
Support for the relay entry recording feature varies by user type, as follows:
·     For non-WAN access users (for example, IPoE and PPPoE), the DHCP relay agent generates relay entries only after you configure the dhcp relay client-information record command.
·     For WAN access users, the DHCP relay agent generates relay entries as follows:
¡     Without an authorization IP pool, the relay agent generates relay entries for WAN access users (for example, IPoE and PPPoE) automatically, which cannot be disabled.
¡     Having an authorization IP pool, the relay agent does not generate relay entries for WAN access users (for example, IPoE and PPPoE). To display the client address information for such users, execute the display dhcp server ip-in-use command on the DHCP server.
# Display all relay entries on the relay agent.
<Sysname> display dhcp relay client-information
Total number of client-information items: 2
Total number of dynamic items: 1
Total number of temporary items: 1
IP address       MAC address      Type        Interface            VPN name
10.1.1.1         00e0-0000-0001   Dynamic     XGE3/1/1             N/A
10.1.1.5         00e0-0000-0000   Temporary   XGE3/1/1             N/A
# Display relay entries for the specified IP address.
<Sysname> display dhcp relay client-information ip 10.1.1.1
Total number of client-information items: 1
Total number of temporary items: 0
IP address          : 10.1.1.1
MAC address         : 00e0-0000-0000
Type                : Dynamic
Port index          : N/A
Interface           : Vlan2
VPN name            : N/A
Server address      : 12.1.1.2
Access type         : CommonV4
Outer VLAN          : N/A
Inner VLAN          : N/A
PPP index           : 0
User ID             : 0x40000001
Table 32 Command output
Total number of relay entries.
Total number of dynamic relay entries.
Total number of temporary relay entries.
IP address
IP address of the DHCP client.
MAC address
MAC address of the DHCP client.
Relay entry type:
·     Dynamic—The relay agent creates a dynamic relay entry upon receiving an ACK response from the DHCP server.
·     Temporary—The relay agent creates a temporary relay entry upon receiving a REQUEST packet from a DHCP client.
Layer 3 interface connected to the DHCP client. N/A is displayed for relay entries without interface information.
VPN name
Name of the VPN instance to which the DHCP client belongs. If the DHCP client does not belong to any VPN, this field displays N/A.
Port index
Layer 2 port that receives the DHCP request. If the request is not received through a Layer 2 port, this field displays N/A.
Server address
Access type
Access type of the user:
·     CommonV4—DHCP.
·     IPoEv4—IPoE.
·     PPPv4—PPP.
Outer VLAN
Outer VLAN tag contained in DHCP requests. If the request does not contain an outer VLAN tag, this field displays N/A.
Inner VLAN
Inner VLAN tag contained in DHCP requests. If the request does not contain an inner VLAN tag, this field displays N/A.
PPP index
PPP session index. If no PPP session index exists, this field displays N/A.
User ID
ID of the access user, in hexadecimal notation.
Use display dhcp relay information to display Option 82 configuration information for the DHCP relay agent.
interface interface-type interface-number: Displays Option 82 configuration information for the specified interface. If you do not specify an interface, this command displays Option 82 configuration information about all interfaces.
# Display Option 82 configuration information for all interfaces.
<Sysname> display dhcp relay information
Interface: Ten-GigabitEthernet3/1/1
   Status: Enable
   Strategy: Replace
   Circuit ID Pattern: Verbose
   Remote ID Pattern: Sysname
   Circuit ID format: Undefined
   Remote ID format: ASCII
   Node identifier: aabbcc
Interface: Ten-GigabitEthernet3/1/2
   Status: Enable
   Strategy: Replace
   Circuit ID Pattern: User Defined
   Remote ID Pattern: User Defined
   Circuit ID format: ASCII
   User defined:
   Circuit ID: vlan100
   Remote ID: device001
Table 33 Command output
Interface name.
Status
Option 82 states:
·     Enable—DHCP relay agent support for Option 82 is enabled.
·     Disable—DHCP relay agent support for Option 82 is disabled.
Strategy
Handling strategy for request messages containing Option 82, Drop, Keep, or Replace.
Circuit ID Pattern
Padding content mode of the Circuit ID sub-option, Verbose, Normal, or User Defined.
Remote ID Pattern
Padding content mode of the Remote ID sub-option, Sysname, Normal, or User Defined.
Circuit ID format-type
Padding format of the Circuit ID sub-option, ASCII, Hex, or Undefined.
Remote ID format-type
Padding format of the Remote ID sub-option, ASCII, Hex, or Undefined.
Node identifier
Access node identifier.
User defined
Content of the user-defined sub-options.
Circuit ID
User-defined content of the Circuit ID sub-option.
Remote ID
User-defined content of the Remote ID sub-option.
display dhcp relay packet statistics
Use display dhcp relay packet statistics to display DHCP packet statistics on the DHCP relay agent.
display dhcp relay packet statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Displays DHCP packet statistics on the specified interface. If you do not specify an interface, this command displays all DHCP packet statistics on the DHCP relay agent.
# Display all DHCP packet statistics on the DHCP relay agent.
<Sysname> display dhcp relay packet statistics
DHCP packets dropped:                  0
DHCP packets received from clients:    0
   DHCPDISCOVER:                       0
   DHCPREQUEST:                        0
   DHCPINFORM:                         0
   DHCPRELEASE:                        0
   DHCPDECLINE:                        0
   BOOTPREQUEST:                       0
DHCP packets received from servers:    0
   DHCPOFFER:                          0
   DHCPACK:                            0
   DHCPNAK:                            0
   BOOTPREPLY:                         0
DHCP packets relayed to servers:       0
   DHCPDISCOVER:                       0
   DHCPREQUEST:                        0
   DHCPINFORM:                         0
   DHCPRELEASE:                        0
   DHCPDECLINE:                        0
   BOOTPREQUEST:                       0
DHCP packets relayed to clients:       0
   DHCPOFFER:                          0
   DHCPACK:                            0
   DHCPNAK:                            0
   BOOTPREPLY:                         0
DHCP packets sent to servers:          0
   DHCPDISCOVER:                       0
   DHCPREQUEST:                        0
   DHCPINFORM:                         0
   DHCPRELEASE:                        0
   DHCPDECLINE:                        0
   BOOTPREQUEST:                       0
DHCP packets sent to clients:          0
   DHCPOFFER:                          0
   DHCPACK:                            0
   DHCPNAK:                            0
   BOOTPREPLY:                         0
Table 34 Command output
Number of DHCP messages dropped by the relay agent.
Number of DHCP messages received from clients.
Number of DHCP messages received from servers.
Number of DHCP messages forwarded to servers.
Number of DHCP messages forwarded to clients.
Number of DHCP messages sent by the relay agent to servers upon periodic dynamic relay entry refreshing.
Number of unsolicited DHCP messages sent by the relay agent to clients. In the current software version, the device does not send unsolicited DHCP packets to clients when it acts as a DHCP relay agent.
reset dhcp relay packet statistics
Use display dhcp relay remote-server-info command to display the DHCP server configuration and status in the remote BAS IP pool on the DHCP relay agent.
In standalone mode:
display dhcp relay remote-server-info [ vpn-instance vpn-name ] [ slot slot-number ]
In IRF mode:
display dhcp relay remote-server-info [ vpn-instance vpn-name ] [ chassis chassis-number slot slot-number ]
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. To specify DHCP servers on the public network, do not specify this option.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays DHCP server information on the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays DHCP server information on the global active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
# Display the DHCP server configuration and status in the remote BAS IP pool on the DHCP relay agent.
<Sysname> display dhcp relay remote-server-info
Remote server count: 2
Remote server: 1.1.1.1 *
  RemoteSrvRefCnt: 2  State: Up
  CfgNakCount: 10  CfgTimeOut: 25(s)  CfgDeadCount: 0  CfgDeadTime: 3(m)
  RunDeadCnt: 0  RunNakCnt: 0  RunDeadTime: 1622(s)
  Recent state changes:
    Jun 24 17:38:52 2023 Changed to down, reason: NoResponse
    Jun 24 17:38:49 2023 Changed to up, reason: DeadTimeout
    Jun 24 17:38:42 2023 Changed to down, reason: NoResponse
    Jun 24 17:38:39 2023 Changed to up, reason: DeadTimeout
    Jun 24 17:38:31 2023 Changed to down, reason: NoResponse
Remote server: 1.1.1.2
  RemoteSrvRefCnt: 3  State: Up
    Jun 24 17:45:36 2023 Changed to down, reason: NoResponse
    Jun 24 17:45:23 2023 Changed to up, reason: DeadTimeout
    Jun 24 17:44:23 2023 Changed to down, reason: NoResponse
    Jun 24 17:43:49 2023 Changed to up, reason: DeadTimeout
    Jun 24 17:40:49 2023 Changed to down, reason: NoResponse
Table 35 Command output
Remote server count
Number of the DHCP servers.
Remote server
The asterisk * represents the DHCP server liveness detection is configured for the DHCP server. If the detection is not configured, no asterisk is displayed.
RemoteSrvRefCnt
Number of times that the DHCP server is referenced by remote BAS IP pools.
State of the DHCP server:
·     Up—The server is available.
·     Down—The server is not available.
·     Unknown—The server state is not unknown.
CfgNakCount
Maximum number of DHCP-NAK that the DHCP relay agent can receive.
CfgTimeOut
Communication failure check timer in seconds.
CfgDeadCount
Maximum number of consecutive communication failures before the relay agent marks a DHCP server as down.
CfgDeadTime
Time period in minutes for the relay agent to wait before communicating with the DHCP server.
RunDeadCnt
Number of consecutive communication failures.
RunNakCnt
Number of DHCP-NAK messages that the DHCP relay agent receives.
RunDeadTime
Dead time in seconds of the DHCP server.
Five most recent state changes on the remote DHCP server.
reason
Reason for the state change:
·     NoResponse: No response was received from the remote DHCP server, and the number of consecutive communication failures reached the upper limit.
·     NakReachLimit: The number of received NAK messages reached the upper limit.
·     DeadTimeout: No response was received from the remote DHCP server, and the number of consecutive communication failures did not reach the upper limit. The DHCP relay agent initiated a connection request to the remote DHCP server.
·     LeaseSetUp: A lease entry was set up.
·     CinfoSetUp: A Cinfo entry was set up.
·     AllSvrDown: All servers were down.
·     Unknown: Unknown reason.
dhcp server
remote-server
display dhcp relay server-address
Use display dhcp relay server-address to display DHCP server addresses configured on an interface.
interface interface-type interface-number: Displays DHCP server addresses on the specified interface. If you do not specify an interface, this command displays DHCP server addresses on all interfaces.
# Display DHCP server addresses on all interfaces.
<Sysname> display dhcp relay server-address
Interface name      Server IP address   Public/VRF name
XGE3/1/1            2.2.2.2             Y/--
# Display DHCP server addresses on Ten-GigabitEthernet 3/1/1.
<Sysname> display dhcp relay server-address interface ten-gigabitethernet 3/1/1
Active server address: 2.2.2.2
Table 36 Command output
Active DHCP server address. The displayed value depends on the DHCP server selection algorithm configuration.
·     If the polling algorithm is used, this field displays all. The DHCP relay agent forwards DHCP requests to all DHCP servers.
·     If the master-backup algorithm is used, this field displays the IP address of the active DHCP server. The DHCP relay agent forwards DHCP requests to the active DHCP server first.
Interface name
Interface name.
Server IP address
DHCP server IP address.
Public/VRF name
Virtual network on which the DHCP server is located. The displayed value depends on the setting for the dhcp relay server-address command.
·     If you do not specify an MPLS L3VPN instance or the public network, this field displays --/--.
·     If you specify the public network, this field displays Y/--.
·     If you specify an MPLS L3VPN instance, this field displays --/VPN-instance-name.
gateway-list
Use gateway-list to specify gateway addresses for DHCP clients in an IP pool.
Use undo gateway-list to remove gateway addresses from an IP pool.
gateway-list ip-address&<1-64> [ export-route ]
undo gateway-list [ ip-address&<1-64> ] [ export-route ]
No gateway address is specified in an IP pool.
Common IP pool view
ip-address&<1-64>: Specifies a space-separated list of up to 64 addresses.
export-route: Binds the gateways to the device's MAC address in the address management module. The ARP module will use the entries to reply to ARP requests from the DHCP clients. If you do not specify this keyword, the gateways will not be bound to the device's MAC address.
Application scenarios
DHCP clients of the same access type can be classified into different types by their locations. In this case, the relay interface typically has no IP address configured. You can use the gateway-list command to specify gateway addresses for clients matching the same IP pool and bind the gateway addresses to the device's MAC address.
Upon receiving a DHCP DISCOVER or REQUEST from a client that matches an IP pool, the relay agent processes the packet as follows:
1.     Fills the giaddr field of the packet with a specified gateway address.
2.     Forwards the packet to all DHCP servers in the matching IP pool.
The DHCP servers select an IP pool according to the gateway address.
To avoid forwarding failure, do not delete a gateway address from a gateway list if that gateway address is being used by online clients.
# Specify gateway address 10.1.1.1 in IP pool 0.
[Sysname] ip pool 0
[Sysname-ip-pool-0] gateway-list 10.1.1.1
Use master-server switch-delay to enable the switchback to the master DHCP server and set the switchback delay time.
Use undo master-server switch-delay to restore the default.
Common IP pool view
# Configure the DHCP relay agent to switch back to the master DHCP server 3 minutes after it switches to a backup DHCP server in remote BAS IP pool 0.
[Sysname-ip-pool-0] master-server switch-delay 3
Use remote-server algorithm to specify the DHCP server selection algorithm.
Use undo remote-server algorithm to restore the default.
remote-server algorithm { master-backup | polling }
Common IP pool view
# Specify master-backup as the DHCP server selection algorithm in remote BAS IP pool 0.
[Sysname-ip-pool-0] remote-server algorithm master-backup
dhcp server
dhcp-server timeout
remote-server
Use reset dhcp relay client-information to clear relay entries on the DHCP relay agent.
interface interface-type interface-number: Clears relay entries on the specified interface. If you do not specify an interface, this command clears relay entries on all interfaces.
ip ip-address: Clears the relay entry for the specified IP address. If you do not specify an IP address, this command clears relay entries for all IP addresses.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the specified IP address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears the relay entry for the specified IP address on the public network.
# Clear all relay entries on the DHCP relay agent.
<Sysname> reset dhcp relay client-information
Use reset dhcp relay packet statistics to clear packet statistics on the DHCP relay agent.
reset dhcp relay packet statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears packet statistics on all DHCP relay agents.
# Clear DHCP relay agent packet statistics.
<Sysname> reset dhcp relay packet statistics
Old-style DHCP relay agent commands
This chapter introduces the old-style commands reserved for network management system (NMS) software compatibility. They are usable when the following conditions exist:
·     The NMS software does not support the related new-style commands.
·     Users want to use old-style commands for BRAS management purposes.
dhcp select relay proxy
Use dhcp select relay proxy to enable the DHCP server proxy feature on an interface.
Use undo dhcp select relay to disable the DHCP relay agent feature on an interface.
The DHCP server proxy feature is enabled on an interface.
Interface view
A BRAS might require software upgrade to provide support for new features, meeting the needs of business development. After software upgrade, the syntaxes of some configuration commands might change. To manage the upgraded BRAS without upgrading the NMS software, execute the bras compatible old-style-commands enable command to enable compatibility with old-style commands on the BRAS. After you enable this feature, the device supports both old-style commands and new-style commands. The new-style configuration information and the old-style configuration information are all deployed in old style on the device. You can use the display current-configuration command to view the running configuration of the device. Therefore, even if old-style commands are used to manage the device, the device still can recognize them and execute the related features correctly.
Operating mechanism
The DHCP server proxy feature isolates DHCP servers from DHCP clients and protects DHCP servers against attacks by illegal users. Upon receiving a reply from the DHCP server, the DHCP relay agent modifies the server's IP address in the reply as the relay interface's IP address before sending out the reply. After obtaining network settings from the reply, the DHCP client takes the DHCP relay agent as the DHCP server for subsequent DHCP interactions.
This command enables both the DHCP relay agent and DHCP server proxy features on an interface.
The configuration information about this feature is displayed as follows:
·     If compatibility with old-style commands is disabled, the configuration information is displayed as dhcp select relay after you execute the dhcp select relay proxy command. This is because configuration information is displayed in new style in the current compatibility mode and DHCP server proxy is enabled by default.
·     If compatibility with old-style commands is enabled, the configuration information is displayed as dhcp select relay proxy after you execute the dhcp select relay command. This is because configuration information is displayed in old style in the current compatibility mode and DHCP server proxy is enabled by default.
·     If compatibility with old-style commands is enabled, the displayed configuration information includes both dhcp select relay proxy and undo dhcp-proxy enable after you execute the undo dhcp-proxy enable command on the DHCP relay agent. However, the undo dhcp-proxy enable command takes precedence over the dhcp select relay proxy command.
Only the undo dhcp-proxy enable command can disable the DHCP server proxy feature without disabling the DHCP relay agent feature.
# Enable the DHCP server proxy feature on Ten-GigabitEthernet 3/1/1.
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] dhcp select relay proxy
bras compatible old-style-commands enable (BRAS Services Command Reference)
dhcp-proxy enable (new style)
DHCP client commands
dhcp client dad enable
Use dhcp client dad enable to enable duplicate address detection.
Use undo dhcp client dad enable to disable duplicate address detection.
Duplicate address detection is disabled.
DHCP client detects IP address conflict through ARP packets. An attacker can act as the IP address owner to send an ARP reply. This makes the client unable to use the IP address assigned by the server. As a best practice, disable duplicate address detection when ARP attacks exist on the network.
# Enable the duplicate address.
[Sysname] dhcp client dad enable
dhcp client dscp
Use dhcp client dscp to set the DSCP value for DHCP packets sent by the DHCP client.
Use undo dhcp client dscp to restore the default.
dhcp client dscp dscp-value
The DSCP value is 56 in DHCP packets sent by the DHCP client.
dscp-value: Sets the DSCP value for DHCP packets, in the range of 0 to 63.
The DSCP value of a packet specifies the priority level of the packet and affects the transmission priority of the packet. A bigger DSCP value represents a higher priority.
# Set the DSCP value to 30 for DHCP packets sent by the DHCP client.
[Sysname] dhcp client dscp 30
dhcp client identifier
Use dhcp client identifier to configure a DHCP client ID for an interface.
Use undo dhcp client identifier to restore the default.
An interface generates the DHCP client ID based on its MAC address. If the interface has no MAC address, it uses the MAC address of the first Ethernet interface to generate its client ID.
Interface view
ascii ascii-string: Specifies a case-sensitive ASCII string of 1 to 63 characters as the client ID.
hex hex-string: Specifies a hexadecimal number of 4 to 64 characters as the client ID.
mac interface-type interface-number: Uses the MAC address of the specified interface as a DHCP client ID. The interface-type interface-number argument specifies an interface by its type and number.
A DHCP client ID is added to the DHCP option 61. A DHCP server can specify IP addresses for clients based on the DHCP client ID. You can specify a DHCP client ID by performing one of the following operations:
·     Naming an ASCII string or hexadecimal number as the client ID.
·     Using the MAC address of an interface to generate a client ID.
Whichever method you use, make sure the IDs for different DHCP clients are unique.
# Use the MAC address of Ten-GigabitEthernet 3/1/2 as the DHCP client ID for Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp client identifier mac ten-gigabitethernet 3/1/2
display dhcp client
display dhcp client
Use display dhcp client to display DHCP client information.
verbose: Displays detailed DHCP client information. If you do not specify this keyword, the command displays brief DHCP client information.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays DHCP client information on all interfaces.
# Display brief DHCP client information on all interfaces.
<Sysname> display dhcp client
Ten-GigabitEthernet3/1/1 DHCP client information:
 Current state: BOUND
 Allocated IP: 40.1.1.20 255.255.255.0
 Allocated lease: 259200 seconds, T1: 129600 seconds, T2: 226800 seconds
 DHCP server: 40.1.1.2
# Display detailed DHCP client information on all interfaces.
<Sysname> display dhcp client verbose
 Transaction ID: 0x1c09322d
Classless static routes:
   Destination: 1.1.0.1, Mask: 255.0.0.0, NextHop: 192.168.40.16
   Destination: 10.198.122.63, Mask: 255.255.255.255, NextHop: 192.168.40.16
 DNS servers: 44.1.1.11 44.1.1.12
 Domain name: example.com
 Boot servers: 200.200.200.200  1.1.1.1
 ACS parameter:
   URL: https://192.168.1.1:7547/acs
   Username: bims
   Password: ******
 Client ID value: 000c.29d3.8659-XGE3/1/1
                            6433-2e38-3635-392d-
                            4574-6830-2f30-2f32
 T1 will timeout in 1 day 11 hours 58 minutes 52 seconds.
Table 37 Command output
Information about the interface that acts as the DHCP client.
Current state
Current state of the DHCP client:
·     HALT—The client stops applying for an IP address.
·     INIT—The initialization state.
·     SELECTING—The client has sent out a DHCP-DISCOVER message in search for a DHCP server and is waiting for the response from DHCP servers.
·     REQUESTING—The client has sent out a DHCP-REQUEST message requesting for an IP address and is waiting for the response from DHCP servers.
·     BOUND—The client has received the DHCP-ACK message from a DHCP server and obtained an IP address successfully.
·     RENEWING—The T1 timer expires.
·     REBOUNDING—The T2 timer expires.
Allocated IP
IP address allocated by the DHCP server.
Allocated lease
Allocated lease time.
T1
1/2 lease time (in seconds) of the DHCP client IP address.
T2
7/8 lease time (in seconds) of the DHCP client IP address.
Lease from…to…
Start and end time of the lease.
DHCP server
DHCP server IP address that assigned the IP address.
Transaction ID
Transaction ID, a random number chosen by the client to identify an IP address allocation.
Default router
Gateway address assigned to the client.
Classless static routes assigned to the client.
Static routes
Classful static routes assigned to the client.
DNS servers
DNS server address assigned to the client.
Domain name
Domain name suffix assigned to the client.
Boot servers
PXE server addresses (up to 16 addresses) specified for the DHCP client, which are obtained through Option 43.
ACS parameter
Parameters about the ACS.
URL
URL of the ACS.
Username
Username for logging in to the ACS.
Password
Password for logging in to the ACS. If a password is configured, this field displays ******. If no password is configured, this field is not displayed.
Client ID type
DHCP client ID type:
·     If an ASCII string is used as the client ID value, the type value is 00.
·     If the MAC address of a specific interface is used as the client ID value, the type value is 01.
·     If a hexadecimal number is used as the client ID value, the type value is the first two characters in the string.
Client ID value
Value of the DHCP client ID.
DHCP client ID with the type field, a hexadecimal number.
How long the T1 (1/2 lease time) timer will timeout.
ip address dhcp-alloc
Use ip address dhcp-alloc to configure an interface to use DHCP for IP address acquisition.
Use undo ip address dhcp-alloc to cancel an interface from using DHCP.
If the device starts up with the initial configuration, an interface does not use DHCP for IP address acquisition.
If the device starts up with the factory defaults, only the management interface uses DHCP for IP address acquisition.
For more information about initial configuration and factory defaults, see configuration file management configuration in Fundamentals Configuration Guide.
Interface view
When you execute the undo ip address dhcp-alloc command, the interface sends a DHCP-RELEASE message to release the IP address obtained through DHCP. If the interface is down, the message cannot be sent out. This situation can occur when a subinterface obtained an IP address through DHCP, and the shutdown command is executed on its primary interface. The subinterface will fail to send a DHCP-RELEASE message.
# Configure Ten-GigabitEthernet 3/1/1 to use DHCP for IP address acquisition.
[Sysname-Ten-GigabitEthernet3/1/1] ip address dhcp-alloc
snmp-agent trap enable dhcp-client
Use snmp-agent trap enable dhcp-client to enable SNMP notifications for the DHCP client module.
Use undo snmp-agent trap enable dhcp-client to disable SNMP notifications for the DHCP client module.
snmp-agent trap enable dhcp-client [ arp-conflict | local-conflict ] *
undo snmp-agent trap enable dhcp-client [ arp-conflict | local-conflict ] *
All SNMP notifications are enabled for the DHCP client module.
arp-conflict: Specifies ARP conflict notifications. An ARP conflict notification is generated when the DHCP client module detects an IP address conflict through gratuitous ARP after obtaining an IP address.
local-conflict: Specifies local address conflict notifications. A local address conflict notification is generated when the DHCP client module obtains an IP address that is in the same subnet as one of the local interface addresses.
To enable all SNMP notifications for the DHCP client module, do not specify any parameters.
After you enable SNMP notifications for the DHCP client module, this module reports critical DHCP client events in SNMP notifications to the SNMP module. For DHCP client event notifications to be sent correctly, you must also configure SNMP on the device.
For more information about SNMP configuration, see SNMP configuration in Network Management and Monitoring Configuration Guide.
# Enable local address conflict notifications for the DHCP client module.
[Sysname] snmp-agent trap enable dhcp-client local-conflict
DHCP snooping commands
DHCP snooping works between the DHCP client and the DHCP server or between the DHCP client and the relay agent. DHCP snooping does not work between the DHCP server and the DHCP relay agent.
dhcp snooping binding database filename
Use dhcp snooping binding database filename to configure the DHCP snooping device to back up DHCP snooping entries to a file.
Use undo dhcp snooping binding database filename to restore the default.
dhcp snooping binding database filename { filename | url url [ username username [ password { cipher | simple } string ] ] }
The DHCP snooping device does not back up DHCP snooping entries.
filename: Specifies the name of a local backup file. For information about the filename argument, see Fundamentals Configuration Guide.
url url: Specifies the URL of a remote backup file, a case-sensitive string of 1 to 255 characters. Do not include a username or password in the URL. Supported path format type varies by server.
username username: Specifies the username for accessing the URL of the remote backup file, a case-sensitive string of 1 to 32 characters. Do not specify this option if a username is not required for accessing the URL.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 32 characters. Its encrypted form is a case-sensitive string of 1 to 73 characters. Do not specify this argument if a password is not required for accessing the URL of the remote backup file.
This command automatically creates the file if you specify a nonexistent file.
With this command executed, the DHCP snooping device backs up DHCP snooping entries immediately and runs auto backup. The DHCP snooping device, by default, waits 300 seconds after a DHCP snooping entry change to update the backup file. To change the waiting period, use the dhcp snooping binding database update interval command. If no DHCP snooping entry changes, the backup file is not updated.
As a best practice, back up the DHCP snooping entries to a remote file. If you use the local storage medium, the frequent erasing and writing might damage the medium and then cause the DHCP snooping device to malfunction.
When the file is on a remote device, follow these restrictions and guidelines to specify the URL, username, and password:
·     If the file is on an FTP server, enter URL in the following format: ftp://server address:port/file path, where the port number is optional.
·     If the file is on a TFTP server, enter URL in the following format: tftp://server address:port/file path, where the port number is optional.
·     The username and password must be the same as those configured on the FTP server. If the server authenticates only the username, the password can be omitted.
·     If the IP address of the server is an IPv6 address, enclose the address in a pair of brackets, for example, ftp://[1::1]/database.dhcp.
·     You can also specify the DNS domain name for the server address field, for example, ftp://company/database.dhcp.
# Configure the DHCP snooping device to back up DHCP snooping entries to file database.dhcp.
[Sysname] dhcp snooping binding database filename database.dhcp
# Configure the DHCP snooping device to back up DHCP snooping entries to file database.dhcp in the working directory of the FTP server at 10.1.1.1.
[Sysname] dhcp snooping binding database filename url ftp://10.1.1.1/database.dhcp username 1 password simple 1
# Configure the DHCP snooping device to back up DHCP snooping entries to file database.dhcp in the working directory of the TFTP server at 10.1.1.1.
[Sysname] dhcp snooping binding database filename tftp://10.1.1.1/database.dhcp
Use dhcp snooping binding database update interval to set the waiting time for the DHCP snooping device to update the backup file after a DHCP snooping entry change.
Use undo dhcp snooping binding database update interval to restore the default.
dhcp snooping binding database update interval interval
The DHCP snooping device waits 300 seconds to update the backup file after a DHCP snooping entry change. If no DHCP snooping entry changes, the backup file is not updated.
interval: Specifies the waiting time in seconds, in the range of 60 to 864000.
When a DHCP snooping entry is learned, updated, or removed, the waiting period starts. The DHCP snooping device updates the backup file when the waiting period is reached. All changed entries during the period will be saved to the backup file.
The waiting time takes effect only after you configure the DHCP snooping entry auto backup by using the dhcp snooping binding database filename command.
# Set the waiting time to 600 seconds for the DHCP snooping device to update the backup file.
[Sysname] dhcp snooping binding database update interval 600
dhcp snooping binding database update now
Use dhcp snooping binding database update now to manually save DHCP snooping entries to the backup file.
Each time this command is executed, the DHCP snooping entries are saved to the backup file.
This command takes effect only after you configure the DHCP snooping auto backup by using the dhcp snooping binding database filename command.
# Manually save DHCP snooping entries to the backup file.
[Sysname] dhcp snooping binding database update now
dhcp snooping binding record
Use dhcp snooping binding record to enable recording of client information in DHCP snooping entries.
Use undo dhcp snooping binding record to disable recording of client information in DHCP snooping entries.
DHCP snooping does not record client information.
Layer 2 Ethernet interface/Layer 2 aggregate interface view
This command enables DHCP snooping on the port directly connecting to the clients to record client information in DHCP snooping entries.
# Enable the recording of client information in DHCP snooping entries on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp snooping binding record
dhcp snooping check mac-address
Use dhcp snooping check mac-address to enable MAC address check for DHCP snooping.
Use undo dhcp snooping check mac-address to disable MAC address check for DHCP snooping.
MAC address check for DHCP snooping is disabled.
Layer 3 Ethernet interface/Layer 3 aggregate interface view
With MAC address check enabled, DHCP snooping compares the chaddr field of a received DHCP request with the source MAC address field in the frame header. If they are the same, DHCP snooping considers this request valid and forwards it to the DHCP server. If they are not the same, DHCP snooping discards the DHCP request.
# Enable MAC address check for DHCP snooping.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp snooping check mac-address
dhcp snooping check request-message
Use dhcp snooping check request-message to enable DHCP-REQUEST check for DHCP snooping.
Use undo dhcp snooping check request-message to disable DHCP-REQUEST check for DHCP snooping.
DHCP-REQUEST check for DHCP snooping is disabled.
DHCP-REQUEST packets include lease renewal packets, DHCP-DECLINE packets, and DHCP-RELEASE packets. This feature prevents unauthorized clients that forge DHCP-REQUEST packets from attacking the DHCP server.
With this feature enabled, DHCP snooping looks for a matching DHCP snooping entry for each received DHCP-REQUEST message.
·     If a match is found, DHCP snooping compares the entry with the message. If they have consistent information, DHCP snooping considers the packet valid and forwards it to the DHCP server. If they have different information, DHCP snooping considers the message invalid and discards it.
·     If no match is found, DHCP snooping forwards the message to the DHCP server.
# Enable DHCP-REQUEST check for DHCP snooping.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp snooping check request-message
dhcp snooping deny
Use dhcp snooping deny to configure a port as DHCP packet blocking port.
Use undo dhcp snooping deny to restore the default.
dhcp snooping deny
A port does not block DHCP requests.
CAUTION
CAUTION:
To avoid IP address acquisition failure, configure a port to block DHCP packets only if no DHCP clients are attached to it.
To enable a port on the snooping device to drop all incoming DHCP requests, configure that port as a DHCP packet blocking port.
# Configure Ten-GigabitEthernet 3/1/1 as a DHCP packet blocking port.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp snooping deny
dhcp snooping enable
Use dhcp snooping enable to enable DHCP snooping.
Use undo dhcp snooping enable to disable DHCP snooping.
Use the DHCP snooping feature together with the trusted port configuration. Trusted ports forward responses from DHCP servers and untrusted ports discard responses from DHCP servers. This mechanism ensures that DHCP clients obtain IP addresses from authorized DHCP servers.
When DHCP snooping is disabled, all ports on the device forward responses from DHCP servers.
# Enable DHCP snooping.
[Sysname] dhcp snooping enable
dhcp snooping information circuit-id
Use dhcp snooping information circuit-id to configure the padding mode and padding format for the Circuit ID sub-option.
Use undo dhcp snooping information circuit-id to restore the default.
dhcp snooping information circuit-id { [ vlan vlan-id ] string circuit-id | { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] } [ format { ascii | hex } ] }
undo dhcp snooping information circuit-id [ vlan vlan-id ]
The padding mode is normal and the padding format is hex.
vlan vlan-id: Pads the Circuit ID sub-option for packets received from the specified VLAN. If you do not specify a VLAN, the device pads the Circuit ID sub-option for packets received from the default VLAN.
string circuit-id: Specifies the string mode, in which the padding content for the Circuit ID sub-option is a case-sensitive string of 3 to 63 characters.
normal: Specifies the normal mode. The padding content includes the VLAN ID and interface number.
verbose: Specifies the verbose mode. The padding content includes the node identifier, interface information, and VLAN ID. The default node identifier is the MAC address of the access node. The default interface information consists of the Ethernet type (fixed to eth), chassis number, slot number, sub-slot number, and interface number.
node-identifier { mac | sysname | user-defined node-identifier }: Specifies the access node identifier.
·     mac: Uses the MAC address of the access node as the node identifier.
·     sysname: Uses the device name as the node identifier. You can set the device name by using the sysname command in system view. The padding format for the device name is always ASCII regardless of the specified padding format. If you specify this keyword, do not include any spaces when you set the device name. Otherwise, the DHCP snooping device fails to add or replace Option 82.
·     user-defined node-identifier: Uses a case-sensitive string of 1 to 50 characters as the node identifier. The padding format for the specified character string is always ASCII regardless of the specified padding format.
format: Specifies the padding format for the Circuit ID sub-option.
ascii: Specifies the ASCII padding format.
hex: Specifies the hex padding format.
The Circuit ID sub-option cannot carry information about interface splitting or subinterfaces. For more information about interface splitting and subinterfaces, see Interface Configuration Guide.
The padding format for the string mode, the normal mode, or the verbose mode varies by command configuration. Table 38 shows how the padding format is determined for different modes.
Table 38 Padding format for different modes
Keyword (mode)
If no padding format is set
If the padding format is ascii
If the padding format is hex
string circuit-id
The padding format is always ASCII, and is not configurable.
N/A
N/A
normal
Hex.
ASCII.
Hex.
verbose
Hex for the VLAN ID.
ASCII for the node identifier, Ethernet type, chassis number, slot number, sub-slot number, and interface number.
ASCII.
ASCII for the node identifier and Ethernet type.
Hex for the chassis number, slot number, sub-slot number, interface number, and VLAN ID.
# Configure verbose as the padding mode, device name as the node identifier, and ASCII as the padding format for the Circuit ID sub-option.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp snooping information enable
[Sysname-Ten-GigabitEthernet3/1/1] dhcp snooping information strategy replace
[Sysname-Ten-GigabitEthernet3/1/1] dhcp snooping information circuit-id verbose node-identifier sysname format ascii
display dhcp snooping information
Use dhcp snooping information enable to enable DHCP snooping to support Option 82.
Use undo dhcp snooping information enable to disable this feature.
DHCP snooping does not support Option 82.
This command enables DHCP snooping to add Option 82 into DHCP requests that do not contain Option 82 before forwarding the requests to the DHCP server. The content of Option 82 is determined by the dhcp snooping information circuit-id and dhcp snooping information remote-id commands. If the received DHCP request packets contain Option 82, DHCP snooping handles the packets according to the strategy configured by the dhcp snooping information strategy command.
# Enable DHCP snooping to support Option 82.
Use dhcp snooping information remote-id to configure the padding mode and padding format for the Remote ID sub-option.
Use undo dhcp snooping information remote-id to restore the default.
dhcp snooping information remote-id { normal [ format { ascii | hex } ] | [ vlan vlan-id ] { string remote-id | sysname } }
undo dhcp snooping information remote-id [ vlan vlan-id ]
vlan vlan-id: Pads the Remote ID sub-option for packets received from the specified VLAN. If you do not specify a VLAN, the device pads the Remote ID sub-option for packets received from the default VLAN.
string remote-id: Specifies the string mode that uses a case-sensitive string of 1 to 63 characters as the content of the Remote ID sub-option.
sysname: Specifies the sysname mode that uses the device name as the Remote ID sub-option. You can configure the device name by using the sysname command in system view.
normal: Specifies the normal mode. The padding content is the bridge MAC address of the device. For more information about bridge MAC addresses, see IRF configuration in Virtual Technologies Configuration Guide.
format: Specifies the padding format for the Remote ID sub-option. The default padding format is hex.
DHCP snooping uses ASCII to pad the specified string or device name for the Remote ID sub-option. The padding format for the normal padding mode is determined by the command configuration.
# Pad the Remote ID sub-option with a character string of device001.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp snooping information remote-id string device001
Use dhcp snooping information strategy to configure the handling strategy for Option 82 in request messages.
Use undo dhcp snooping information strategy to restore the default.
dhcp snooping information strategy { drop | keep | replace }
The handling strategy for Option 82 in request messages is replace.
drop: Drops DHCP messages that contain Option 82.
keep: Keeps the original Option 82 intact and forwards the DHCP messages.
replace: Replaces the original Option 82 with the configured Option 82 before forwarding the DHCP messages.
This command takes effect only on DHCP requests that contain Option 82. For DHCP requests that do not contain Option 82, the DHCP snooping device always adds Option 82 into the requests before forwarding them to the DHCP server.
If the handling strategy is replace, configure a padding mode and a padding format for Option 82. If the handling strategy is keep or drop, you do not need to configure a padding mode or padding format for Option 82.
# Specify the handling strategy for Option 82 in request messages as keep.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp snooping information strategy keep
dhcp snooping log enable
Use dhcp snooping log enable to enable DHCP snooping logging.
Use undo dhcp snooping log enable to disable DHCP snooping logging.
DHCP snooping logging is disabled.
This command enables the DHCP snooping device to generate DHCP snooping logs and send them to the information center. For information about the log destination and output rule configuration in the information center, see Network Management and Monitoring Configuration Guide.
As a best practice, disable this feature if the log generation affects the device performance.
# Enable DHCP snooping logging.
[Sysname] dhcp snooping log enable
dhcp snooping max-learning-num
Use dhcp snooping max-learning-num to set the maximum number of DHCP snooping entries that an interface can learn.
Use undo dhcp snooping max-learning-num to restore the default.
dhcp snooping max-learning-num max-number
The maximum number of DHCP snooping entries for an interface to learn is unlimited.
max-number: Specifies the maximum number of DHCP snooping entries for an interface to learn. The value range for this argument is 1 to 4294967295.
When an interface learns the maximum number of DHCP snooping entries, the interface stops learning DHCP snooping entries. This does not affect the operating of the DHCP snooping feature.
# Allow Layer 2 Ethernet interface Ten-GigabitEthernet 3/1/1 to learn a maximum of 10 DHCP snooping entries.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp snooping max-learning-num 10
dhcp snooping trust
Use dhcp snooping trust to configure a port as a trusted port.
Use undo dhcp snooping trust to restore the default state of a port.
dhcp snooping trust
After you enable DHCP snooping, all ports are untrusted.
Specify the ports facing the DHCP server as trusted ports and specify the other ports as untrusted ports so DHCP clients can obtain valid IP addresses.
# Specify Layer 2 Ethernet interface Ten-GigabitEthernet 3/1/1 as a trusted port.
[Sysname-Ten-GigabitEthernet3/1/1] dhcp snooping trust
display dhcp snooping trust
display dhcp snooping binding
Use display dhcp snooping binding to display DHCP snooping entries.
display dhcp snooping binding [ ip ip-address [ vlan vlan-id ] ] [ verbose ]
ip ip-address: Displays the DHCP snooping entry for the specified IP address. If you do not specify an IP address, this command displays DHCP snooping entries for all IP addresses.
vlan vlan-id: Specifies the VLAN ID where the IP address resides. If you do not specify a VLAN, this command displays DHCP snooping entries for the IP address in all VLANs.
verbose: Displays detailed information about DHCP snooping entries. If you do not specify this keyword, the command displays brief information about DHCP snooping entries.
# Display brief information about DHCP snooping entries.
<Sysname> display dhcp snooping binding
 2 DHCP snooping entries found
 IP address      MAC address    Lease        SVLAN  CVLAN Interface
 1.1.1.7         0000-0101-0107 16907533     2      3     XGE3/1/1
 1.1.1.11        0000-0101-010b 16907537     2      3     XGE3/1/3
# Display detailed information about DHCP snooping entries.
<Sysname> display dhcp snooping binding verbose
 IP address: 1.1.1.7
 MAC address: 0000-0101-0107
 Lease: 16907553 seconds
 SVLAN: 2
 CVLAN: 3
 Parameter request list: 03 06 21
 IP address: 1.1.1.104
 MAC address: 0000-0101-010b
 Lease: 16907537 seconds
 SVLAN: 2
 CVLAN: 3
 Interface: Ten-GigabitEthernet3/1/3
 Parameter request list: 37 0B 01 0F 03 06 2C 2E 2F 1F 21 F9 2B
Table 39 Command output
Number of DHCP snooping entries.
IP address
IP address assigned to the DHCP client.
MAC address
Lease
Remaining lease duration in seconds.
SVLAN
When both DHCP snooping and QinQ are enabled or the DHCP packet contains two VLAN tags, this field identifies the outer VLAN tag. Otherwise, it identifies the VLAN where the port connecting the DHCP client resides.
CVLAN
When both DHCP snooping and QinQ are enabled or the DHCP packet contains two VLAN tags, this field identifies the inner VLAN tag. Otherwise, it displays N/A.
Port connected to the DHCP client.
Parameters requested by the DHCP client.
reset dhcp snooping binding
display dhcp snooping binding database
Use display dhcp snooping binding database to display information about DHCP snooping entry auto backup.
# Display information about DHCP snooping entry auto backup.
<Sysname> display dhcp snooping binding database
Username                :
Password                :
Latest write time       :   Feb 27 18:48:04 2012
Table 40 Command output
File name
Name of the DHCP snooping entry backup file.
Username
Username for accessing the URL of the remote backup file.
Password
Password for accessing the URL of the remote backup file. This field displays ****** if a password is configured.
Update interval
Waiting time in seconds after a DHCP snooping entry change for the DHCP snooping device to update the backup file.
Latest write time
Time of the latest update.
Status
Update state:
·     Writing—The backup file is being updated.
·     Last write succeeded—The backup file was successfully updated.
·     Last write failed—The backup file failed to be updated.
Use display dhcp snooping information to display Option 82 configuration on the DHCP snooping device.
display dhcp snooping information { all | interface interface-type interface-number }
all: Displays Option 82 configuration on all Layer 2 Ethernet interfaces.
# Display Option 82 configuration on all interfaces.
<Sysname> display dhcp snooping information all
Interface: Bridge-Aggregation1
   Status: Disable
   Strategy: Drop
   Circuit ID:
     Padding format: User Defined
       User defined: abcd
     Format: ASCII
   Remote ID:
     Padding format: Normal
     Format: ASCII
   VLAN 10:
     Circuit ID: abcd
     Remote ID: company
Table 41 Command output
Interface name.
Status
Option 82 status, Enable or Disable.
Strategy
Handling strategy for DHCP requests that contain Option 82, Drop, Keep, or Replace.
Circuit ID
Content of the Circuit ID sub-option.
Padding format
Padding format of Option 82:
·     For Circuit ID sub-option, the padding format can be Normal, User Defined, Verbose (sysname), Verbose (MAC), or Verbose (user defined).
·     For Remote ID sub-option, the padding format can be Normal, Sysname, or User Defined.
Node identifier
User defined
Content of the user-defined sub-option.
Format
Code type of Option 82 sub-option:
·     For Circuit ID sub-option, the code type can be ASCII, Default, or Hex.
·     For Remote ID sub-option, the code type can be ASCII or Hex.
Remote ID
Content of the Remote ID sub-option.
VLAN
Pads Circuit ID sub-option and Remote ID sub-option in the DHCP packets received in the specified VLAN.
display dhcp snooping packet statistics
Use display dhcp snooping packet statistics to display DHCP packet statistics for DHCP snooping.
In standalone mode:
display dhcp snooping packet statistics [ slot slot-number ]
In IRF mode:
display dhcp snooping packet statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by the slot number. If you do not specify a card, this command displays DHCP packet statistics on the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays DHCP packet statistics on the global active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
# Display DHCP packet statistics for DHCP snooping.
<Sysname> display dhcp snooping packet statistics
 DHCP packets received                  : 100
 DHCP packets sent                      : 200
 Invalid DHCP packets dropped           : 0
reset dhcp snooping packet statistics
Use display dhcp snooping trust to display information about trusted ports.
# Display information about trusted ports.
<Sysname> display dhcp snooping trust
 DHCP snooping is enabled.
 Interface                                       Trusted
  Ten-GigabitEthernet3/1/1                        Trusted
dhcp snooping trust
Use reset dhcp snooping binding to clear DHCP snooping entries.
reset dhcp snooping binding { all | ip ip-address [ vlan vlan-id ] }
all: Clears all DHCP snooping entries.
ip ip-address: Clears the DHCP snooping entry for the specified IP address.
vlan vlan-id: Clears DHCP snooping entries for the specified VLAN. If you do not specify a VLAN, this command clears DHCP snooping entries for the default VLAN.
This command applies to all slots on a distributed device.
# Clear all DHCP snooping entries.
<Sysname> reset dhcp snooping binding all
Use reset dhcp snooping packet statistics to clear DHCP packet statistics for DHCP snooping.
In standalone mode:
reset dhcp snooping packet statistics [ slot slot-number ]
In IRF mode:
reset dhcp snooping packet statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by the slot number. If you do not specify a card, this command clears DHCP packet statistics on the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears DHCP packet statistics on the global active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
# Clear DHCP packet statistics for DHCP snooping.
<Sysname> reset dhcp snooping packet statistics
BOOTP client commands
display bootp client
Use display bootp client to display information about a BOOTP client.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays BOOTP client information on all interfaces.
# Display BOOTP client information on Ten-GigabitEthernet 3/1/1.
<Sysname> display bootp client interface ten-gigabitethernet 3/1/1
Ten-GigabitEthernet3/1/1 BOOTP client information:
Allocated IP: 169.254.0.2 255.255.0.0
Transaction ID: 0x3d8a7431
MAC Address: 00e0-fc0a-c3ef
Table 42 Command output
Information about the interface that acts as a BOOTP client.
Allocated IP
BOOTP client's IP address allocated by the BOOTP server.
Transaction ID
Value of the XID field in a BOOTP message. The BOOTP client chooses a random number for the XID field when sending a BOOTP request to the BOOTP server. It is used to match a response message from the BOOTP server. If the values of the XID field are different in the BOOTP response and request, the BOOTP client drops the BOOTP response.
Mac Address
MAC address of a BOOTP client.
ip address bootp-alloc
Use ip address bootp-alloc to configure an interface to use BOOTP for IP address acquisition.
Use undo ip address bootp-alloc to cancel an interface from using BOOTP.
An interface does not use BOOTP for IP address acquisition.
Interface view
# Configure Ten-GigabitEthernet 3/1/1 to use BOOTP for IP address acquisition.
[Sysname-Ten-GigabitEthernet3/1/1] ip address bootp-alloc
