03-System Management Configuration Guide
HomeSupportWirelessWX3800X Series Access ControllersConfigure & DeployConfiguration GuidesH3C WX3800X Series Access Controllers Configuration Guides(R1603Pxx)-6W10003-System Management Configuration Guide
05-Information center configuration
05-Information center configuration 396.89 KB
Configuring the information center 1
About the information center 1
Log types· 1
Log levels· 1
Log destinations· 2
Default output rules for logs· 2
Default output rules for diagnostic logs· 2
Default output rules for security logs· 3
Default output rules for hidden logs· 3
Default output rules for trace logs· 3
Log formats and field descriptions· 3
Information center tasks at a glance· 7
Managing standard system logs· 7
Managing hidden logs· 8
Managing security logs· 8
Managing diagnostic logs· 8
Managing trace logs· 9
Enabling the information center 9
Configuring a log output profile· 9
Outputting logs to various destinations· 10
Displaying the log output filters· 10
Outputting logs to the console· 10
Outputting logs to the monitor terminal 11
Outputting logs to log hosts· 12
Outputting logs to the log buffer 14
Saving logs to the log file· 15
Setting the minimum storage period (single general log file supported, module-specific log storage not supported) 16
Setting the minimum storage period (multiple general log files supported, module-specific log storage not supported) 17
About setting the minimum storage period· 17
Procedure· 18
Enabling synchronous information output 18
Configuring the character set encoding used on the information center 18
Configuring log suppression· 19
Enabling duplicate log suppression· 19
Configuring log suppression for a module· 21
Disabling an interface from generating link up or link down logs· 21
Enabling SNMP notifications for system logs· 22
Configuring security logs· 22
Saving security logs to the security log file· 22
Managing the security log file· 23
Displaying security log information· 24
Configuring log file backup to a remote server 24
About this task· 24
Backing up log files to a remote server 24
Displaying and maintaining log file backup to remote server 25
Performing integrity check for a log file· 25
Configuring diagnostic logs· 25
Saving diagnostic logs to the diagnostic log file· 25
Displaying diagnostic log file configuration· 26
Displaying the information center configuration· 26
Displaying and clearing log buffer information· 26
Displaying log file information· 26
Information center configuration examples‌· 27
Example: Outputting logs to the console· 27
Example: Outputting logs to a UNIX log host 27
Example: Outputting logs to a Linux log host 29
The information center on the device receives logs generated by source modules and outputs logs to different destinations according to log output rules. Based on the logs, you can monitor device performance and troubleshoot network problems.
Figure 1 Information center diagram
Log types
Logs are classified into the following types:
·     Standard system logs—Record common system information. Unless otherwise specified, the term "logs" in this document refers to standard system logs.
To achieve centralized management of operation logs and allow administrators to conveniently view logs at any time for monitoring device status, standard system logs are divided into the following types:
¡     Operation logs—Logs automatically generated to record the administrator's operations on the device. For example, if the administrator obtains or configures a parameter value through CLI, Web, NETCONF, or other tools, the device will generate an operation log.
¡     Non-operation logs—Standard system logs other than operation logs.
Operation logs and non-operation logs are output and managed separately. Unless otherwise specified, the term "logs" or "standard system logs" in this document refers to non-operation logs.
·     Diagnostic logs—Record debugging messages.
·     Security logs—Record security information, such as authentication and authorization information.
·     Hidden logs—Record log information not displayed on the terminal, such as input commands.
·     Trace logs—Record system tracing and debugging messages, which can be viewed only after the devkit package is installed.
Log levels
Logs are classified into eight severity levels from 0 through 7 in descending order. The information center outputs logs with a severity level that is higher than or equal to the specified level. For example, if you specify a severity level of 6 (informational), logs that have a severity level from 0 to 6 are output.
Table 1 Log levels
Severity value
Level
0
Emergency
The system is unusable. For example, the system authorization has expired.
1
Alert
Action must be taken immediately. For example, traffic on an interface exceeds the upper limit.
2
Critical
Critical condition. For example, the device temperature exceeds the upper limit, the power module fails, or the fan tray fails.
3
Error
Error condition. For example, the link state changes.
4
Warning
Warning condition. For example, an interface is disconnected, or the memory resources are used up.
5
Notification
Normal but significant condition. For example, a terminal logs in to the device, or the device reboots.
6
Informational
Informational message. For example, a command or a ping operation is executed.
7
Debugging
Debugging message.
Log destinations
The system outputs logs to the following destinations: console, monitor terminal, log buffer, log host, and log file. Log output destinations are independent and you can configure them after enabling the information center. One log can be sent to multiple destinations.
A log output rule specifies the source modules and severity level of logs that can be output to a destination. Logs matching the output rule are output to the destination. Table 2 shows the default log output rules.
Table 2 Default output rules
Destination
Log source modules
Output switch
Severity
Console
All supported modules
Enabled
Debugging
Monitor terminal
Disabled
Debugging
Log host
Enabled
Informational
Log buffer
Enabled
Informational
Log file
Enabled
Informational
Diagnostic logs can only be output to the diagnostic log file, and cannot be filtered by source modules and severity levels. Table 3 shows the default output rule for diagnostic logs.
Table 3 Default output rule for diagnostic logs
Destination
Log source modules
Output switch
Severity
Diagnostic log file
Enabled
Debugging
Security logs can only be output to the security log file, and cannot be filtered by source modules and severity levels. Table 4 shows the default output rule for security logs.
Table 4 Default output rule for security logs
Destination
Log source modules
Output switch
Severity
Security log file
Disabled
Debugging
Hidden logs can be output to the log host, the log buffer, and the log file. Table 5 shows the default output rules for hidden logs.
Table 5 Default output rules for hidden logs
Destination
Log source modules
Output switch
Severity
Log host
Enabled
Informational
Log buffer
Enabled
Informational
Log file
Enabled
Informational
Trace logs can only be output to the trace log file, and cannot be filtered by source modules and severity levels. Table 6 shows the default output rules for trace logs.
Table 6 Default output rules for trace logs
Destination
Log source modules
Output switch
Severity
Trace log file
Enabled
Debugging
Log formats
The format of logs varies by output destinations. Table 7 shows the original format of log information, which might be different from what you see. The actual format varies by the log resolution tool used.
Table 7 Log formats
Output destination
Format
Console, monitor terminal, log buffer, or log file
Prefix Timestamp Sysname Module/Level/Mnemonic: Content
Example:
%Nov 24 14:21:43:502 2019 Sysname SHELL/5/SHELL_LOGIN: VTY logged in from 192.168.1.26
Log host
Standard format:
<PRI>Timestamp Sysname %%vvModule/Level/Mnemonic: Location; Content
Example:
<190>Nov 24 16:22:21 2016 Sysname %%10SHELL/5/SHELL_LOGIN: -DevIP=1.1.1.1; VTY logged in from 192.168.1.26<190>Nov 24 16:22:21 2019 Sysname %%10 SHELL/5/SHELL_LOGIN: -DevIP=1.1.1.1; VTY logged in from 192.168.1.26
Unicom format:
<PRI>Timestamp Hostip vvModule/Level/Serial_number: Content
Example:
<189>Oct 13 16:48:08 2019 10.1.1.1 10SHELL/5/210231a64jx073000020: VTY logged in from 192.168.1.21
CMCC format:
<PRI>Timestamp Sysname %vvModule/Level/Mnemonic: Location; Content
Example:
<189>Oct 9 14:59:04 2019 Sysname %10SHELL/5/SHELL_LOGIN: -DevIP=1.1.1.1; VTY logged in from 192.168.1.21
Security log file
IndexPrefix Timestamp Sysname Module/Level/Mnemonic: SecTitle; Content
Example:
%@1093%Feb 28 17:18:38:219 2024 Sysname SHELL/5/SHELL_LOGIN: -LogType=SYS-StartTime=Feb 28 17:18:38:219250 2024 ; tel logged in from 192.7.0.150.
Log field description
·     Prefix (information type)
A log to a destination other than the log host has an identifier in front of the timestamp:
¡     An identifier of percent sign (%) indicates a log with a level equal to or higher than informational.
¡     An identifier of asterisk (*) indicates a debugging log or a trace log.
¡     An identifier of caret (^) indicates a diagnostic log.
·     PRI (priority)
A log destined for the log host has a priority identifier in front of the timestamp. The priority is calculated by using this formula: facility*8+level, where:
¡     facility is the facility name. Facility names local0 through local7 correspond to values 16 through 23. The facility name can be configured using the info-center loghost command. It is used to identify log sources on the log host, and to query and filter the logs from specific log sources.
¡     level is in the range of 0 to 7. See Table 8 for more information about severity levels.
Table 8 Log levels
Severity value
Level
0
Emergency
1
Alert
2
Critical
3
Error
4
Warning
5
Notification
6
Informational
7
Debugging
Debugging message.
·     Timestamp
A timestamp records the time when the log was generated.
Logs sent to the log host and those sent to the other destinations have different timestamp precisions, and their timestamp formats are configured with different commands. For more information, see Table 9 and Table 10.
Table 9 Timestamp precisions and configuration commands
Item
Destined for the log host
Destined for the console, monitor terminal, log buffer, and log file
Precision
Seconds (default) or milliseconds
Milliseconds
Command used to set the timestamp format
info-center timestamp loghost
Table 10 Description of the timestamp parameters
Timestamp parameters
boot
Time that has elapsed since system startup, in the format of xxx.yyy. xxx represents the higher 32 bits, and yyy represents the lower 32 bits, of milliseconds elapsed.
Logs that are sent to all destinations other than a log host support this parameter.
Example:
%0.109391473 Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully.
0.109391473 is a timestamp in the boot format.
date
Current date and time.
·     For logs output to a log host, the timestamp can be in the format of MMM DD hh:mm:ss YYYY (accurate to seconds) or MMM DD hh:mm:ss.ms YYYY (accurate to milliseconds).
·     For logs output to other destinations, the timestamp is in the format of MMM DD hh:mm:ss:ms YYYY.
All logs support this parameter.
Example:
%May 30 05:36:29:579 2019 Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully.
May 30 05:36:29:579 2019 is a timestamp in the date format in logs sent to the console.
iso
Timestamp format stipulated in ISO 8601, accurate to seconds (default) or milliseconds..
Only logs that are sent to a log host support this parameter.
Example:
<189>2019-05-30T06:42:44 Sysname %%10FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully.
2019-05-30T06:42:44 is a timestamp in the iso format accurate to seconds. A timestamp accurate to milliseconds is like 2019-05-30T06:42:44.708.
none
No timestamp is included.
Example:
% Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully.
no-year-date
Current date and time without year or millisecond information, in the format of MMM DD hh:mm:ss.
Example:
<189>May 30 06:44:22 Sysname %%10FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully.
May 30 06:44:22 is a timestamp in the no-year-date format.
·     Hostip
This field represents the source IP address of the log. If the info-center loghost source command is configured, this field displays the IP address of the specified source interface. Otherwise, this field displays the sysname.
This field exists only in logs that are sent to the log host in unicom format.
·     Serial number
This field represents the serial number of the device that generated the log.
·     Sysname (host name or host IP address)
The sysname is the host name or IP address of the device that generated the log. You can use the sysname command to modify the name of the device.
·     %% (vendor ID)
This field indicates that the information was generated by an H3C device.
This field exists only in logs sent to the log host.
·     vv (version information)
This field identifies the version of the log, and has a value of 10.
This field exists only in logs that are sent to the log host.
·     Module
This field specifies the name of the module that generated the log. You can enter the info-center source ? command in system view to view the module list.
·     Level
This field identifies the level of the log. See Table 11 for more information about severity levels.
Table 11 Log levels
Severity value
Level
0
Emergency
1
Alert
2
Critical
3
Error
4
Warning
5
Notification
6
Informational
7
Debugging
Debugging message.
·     Mnemonic
This field describes the content of the log. It contains a string of up to 32 characters.
·     Location
This field is optional that identifies the log sender. This field exists only in logs that are sent to the log host in standard or CMCC format.
The field contains the following information:
¡     Devlp—IP address of the log sender.
¡     Slot—Member ID of the cloud cluster member device that sent the log.
·     Content
This field provides the content of the log.
1.     Enabling the information center
2.     (Optional.) Configuring a log output profile
Currently only log hosts supporting binding log output profiles.
3.     Outputting logs to various destinations
¡     Outputting logs to the console
¡     Outputting logs to the monitor terminal
¡     Outputting logs to log hosts
¡     Outputting logs to the log buffer
¡     Saving logs to the log file
4.     (Optional.) Setting the minimum storage period (single general log file supported, module-specific log storage not supported)
5.     (Optional.) Setting the minimum storage period (multiple general log files supported, module-specific log storage not supported)
6.     (Optional.) Enabling synchronous information output
7.     (Optional.) Configuring the character set encoding used on the information center
8.     (Optional.) Configuring log suppression
¡     Enabling duplicate log suppression
¡     Configuring log suppression for a module
¡     Disabling an interface from generating link up or link down logs
9.     (Optional.) Enabling SNMP notifications for system logs
10.     (Optional.) Configuring log file backup to a remote server
11.     (Optional.) Performing integrity check for a log file
6.     (Optional.) Configuring the character set encoding used on the information center
7.     (Optional.) Configuring log suppression
2.     (Optional.) Configuring log suppression
3.     Configuring security logs
¡     Saving security logs to the security log file
¡     Managing the security log file
¡     Displaying security log information
4.     (Optional.) Performing integrity check for a log file
5.     (Optional.) Configuring the character set encoding used on the information center
2.     (Optional.) Configuring the character set encoding used on the information center
3.     (Optional.) Configuring log suppression
4.     Configuring diagnostic logs
¡     Saving diagnostic logs to the diagnostic log file
¡     Displaying diagnostic log file configuration
Managing trace logs
The information center can output logs only after it is enabled.
2.     Enable the information center.
info-center enable
The information center is enabled by default.
After you create a log output profile and bind it to log hosts, you can customize log output parameters for the log hosts, such as the encapsulation format, character set encoding, timestamp format, and the inclusion of device serial number in logs.
A log output profile takes effect only when it is bound to a destination. Currently only log hosts supporting binding log output profiles.
You can configure the log timestamp format, log format, and whether to carry the device SN in logs in system view or log output profile view. The configuration in log output profile view takes precedence over the configuration in system view. If a log host is bound to a log output profile, the device will use the configuration in the log output profile when sending logs to the log host. The configuration in system view will not take effect on that log host.
2.     Create a log output profile and enter its view.
info-center output-profile profile-name
3.     Configure the log timestamp.
timestamp [ utc ] { date [ with-milliseconds ] | iso [ with-milliseconds | with-timezone ] * | no-year-date | none }
By default, the log timestamp format is date.
4.     Set the log format.
format { cmcc | telecom | unicom }
By default, the log format is non-customized.
5.     Configure logs to carry the device serial number.
locate-info with-sn
By default, the device serial number is not carried in logs.
The info-center loghost locate-info with-sn command configured in system view takes effect on all log hosts. The locate-info with-sn command configured in log output profile view takes effect on only log hosts applying the log output profile.
6.     Specify the character set encoding for logs.
character-set { gb18030 | utf-8 }
By default, the GB18030 character set encoding is used for logs.
To display information about log output filters, execute the following command in any view:
display info-center filter [ filter-name ]
The terminal monitor, terminal debugging, and terminal logging commands take effect only for the current connection between the terminal and the device. If a new connection is established, the default is restored.
2.     (Optional.) Configure an output rule for sending logs to the console.
info-center source { module-name | default } console { deny | level severity }
For information about the default output rules, see "Default output rules for logs."
3.     (Optional.) Configure the timestamp format.
The default timestamp format is date.
4.     Return to user view.
5.     Enable log output to the console.
terminal monitor
By default, log output to the console is enabled.
6.     Enable output of debugging messages to the console.
terminal debugging
By default, output of debugging messages to the console is disabled.
This command enables output of debugging-level log messages to the console.
7.     Set the lowest severity level of logs that can be output to the console.
The default setting is 6 (informational).
Monitor terminals refer to terminals that log in to the device through the AUX or VTY.
2.     (Optional.) Configure an output rule for sending logs to the monitor terminal.
info-center source { module-name | default } monitor { deny | level severity }
5.     Enable log output to the monitor terminal.
terminal monitor
By default, log output to the monitor terminal is disabled.
6.     Enable output of debugging messages to the monitor terminal.
terminal debugging
By default, output of debugging messages to the monitor terminal is disabled.
This command enables output of debugging-level log messages to the monitor terminal.
7.     Set the lowest level of logs that can be output to the monitor terminal.
Use this feature to send logs generated by the device to log hosts for backup. Some log hosts can also analyze, count, and set alarms for logs, making it easier and more timely for network administrators to manage the device.
Log output filter
To send only logs of interest to a log host, you can create a log output filter to filter the logs sent to the log host. The device supports configuring log output filter rules at the following levels of granularity:
·     Module granularity—This allows for filtering logs based on the log source module and log mnemonic. The device can be configured to either forward or block logs from the specified module that match the designated mnemonic.
·     Class granularity—To facilitate configuration, the device classifies relevant service modules into classes and subclasses. You can specify a log class or subclass in a log output rule. This rule will allow output of the logs from all service modules or submodules included in that class or subclass to the log host. This approach achieves the same outcome as setting up multiple log output rules at the module granularity level. To view the service modules included in a log class/subclass, execute the display info-center class command.
A log output filter can be configured with log output rules at either one granularity or two granularities. If you configure the same log output filter multiple times, the result will be a collection of the configurations from all executions.
Log output profile
A log output profile defines log output parameters, including the log encapsulation format, encoding format, timestamp, and whether to add the device serial number to log messages. You can configure a log output profile and bind it to a log host, so as to customize the output parameters for logs sent to that log host.
Keepalive logs
Keepalive logs are a special type of log designed to confirm the connection status between the device and the log server. The device can periodically send keepalive logs to all configured log hosts, regardless of any log output suppression rules set on the device. These logs indicate that the system is functioning correctly. This mechanism ensures that network administrators can confirm the operational status of network devices through received keepalive logs, even if no other logs are received.
2.     (Optional.) Configure a log output filter or a log output rule. Choose one option as needed:
¡     Configure a log output filter.
info-center filter filter-name { { module-name [ mnemonic mnemonic-value ] | default } { deny | level severity } | class class-name [ sub-class sub-class-name ] permit }
You can create multiple log output filters. When specifying a log host, you can apply a log output filter to the log host to control log output.
¡     Configure a log output rule for the log host output destination.
info-center source { module-name | default } loghost { deny | level severity }
For information about the default log output rules for the log host output destination, see "Default output rules for logs."
The system chooses the settings to control log output to a log host in the following order:
a.     Log output filter applied to the log host.
b.     Log output rules configured for the log host output destination by using the info-center source command.
c.     Default log output rules (see "Default output rules for logs").
3.     (Optional.) Specify a source IP address for logs sent to log hosts.
By default, the source IP address of logs sent to log hosts is the primary IP address of their outgoing interfaces.
4.     (Optional.) Specify the format in which logs are output to log hosts.
info-center format { unicom | cmcc }
By default, logs are output to log hosts in standard format.
5.     (Optional.) Add the device serial number to the location field of logs sent to log hosts.
By default, the device does not add the device serial number to the location field of logs sent to log hosts.
6.      (Optional.) Configure the timestamp format.
info-center timestamp loghost { date [ with-milliseconds ] | iso [ with-milliseconds | with-timezone ] * | no-year-date | none }
7.     Specify a log host and configure related parameters.
info-center loghost { hostname | ipv4-address | ipv6 ipv6-address } [ port port-number ] [ dscp dscp-value ] [ facility local-number ] [ filter filter-name ] [ output-profile profile-name ] [ tcp [ ssl-client-policy policy-name ] [ source-ip source-address ]
By default, no log hosts or related parameters are specified.
The value for the port-number argument must be the same as the value configured on the log host. Otherwise, the log host cannot receive logs.
To use an SSL client policy to encrypt the logs sent to a log host, configure the SSL client policy first. If you have not configured the SSL client policy, the SSL connection cannot be established and logs cannot be sent to the log host. For more information about SSL client policy configuration, see SSL VPN configuration in Security Configuration Guide.
Configuring the sending of keepalive logs
Support for this feature depends on the device model.
Series
Models
Product codes
Feature compatibility
WX3500X series
WX3510X
WX3520X
WX3540X
EWP-WX3510X
EWP-WX3520X
EWP-WX3540X
Yes
WX3500X-E series
WX3508X-E
EWP-WX3508X-E
Yes
Access controller modules
LSEM1WBC120G0
LSEM1WBC120G0
No
Series
Models
Product codes
WX3500X-G series
WX3520X-G
EWP-WX3520X-G
No
Series
Models
Product codes
WX3800X series
WX3820X
WX3840X
EWP-WX3820X
EWP-WX3840X
Yes
2.     Set the interval for sending keepalive logs.
info-center loghost keep-alive interval seconds
The default setting is 60 seconds.
3.     Set the level of keepalive logs.
info-center loghost keep-alive level severity
The default setting is level 6 (informational).
4.     Configure custom information to include in keepalive logs.
info-center loghost keep-alive custom-info text
By default, keepalive logs do not include custom information.
5.     Enable the sending of keepalive logs.
info-center loghost keep-alive enable
By default, the sending of keepalive logs is enabled.
Displaying service modules included in a log class
To help configuring appropriate log output filter rules, execute the following command in any view to display service modules included in a log class:
display info-center class [ class-name [ sub-class sub-class-name ] ]
This feature enables log output to the log buffer. You can use the display logbuffer command to display the log buffer information and the buffered logs.
2.     (Optional.) Configure an output rule for sending logs to the log buffer.
info-center source { module-name | default } logbuffer { deny | level severity }
4.     Enable log output to the log buffer.
info-center logbuffer
By default, log output to the log buffer is enabled.
5.     (Optional.) Set the maximum log buffer size.
By default, a maximum of 512 logs can be buffered.
The log file feature enables log output to the log file. The system saves logs from the log file buffer to the log file. After saving logs to the log file, the system clears the log file buffer.
Log saving from the log file buffer to the log file is triggered by the following situations:
·     Periodic saving.
·     A manual immediate saving of buffered logs to the log file.
·     The log file buffer is full.
A log file is automatically created when needed and has a maximum capacity. The log file capacity restrictions are as follows:
·     When no log file space is available, the device stops saving new logs.
·     (Applicable to single-logfile devices.) When no log file space or storage device space is available, the system will replace the oldest logs with new logs.
·     (Applicable to multi-logfile devices.) When no log file space or storage device space is available, the system creates new log files as needed. The log files are named as logfile1.log, logfile2.log, and so on.
When logfile1.log is full, the system compresses logfile1.log as logfile1.log.gz and creates a new log file named logfile2.log. The process repeats until the last log file is full.
After the last log file is full, the device repeats the following process:
a.     The device locates the oldest compressed log file logfileX.log.gz and creates a new file using the same name (logfileX.log).
b.     When logfileX.log is full, the device compresses the log file as logfileX.log.gz to replace the existing file logfileX.log.gz.
TIP
TIP:
·     Clean up the storage space of the device regularly to ensure sufficient storage space for the log file feature.
·     As a best practice, back up the log files regularly to avoid loss of important logs.
2.     Configure an output rule for sending logs to the log file.
info-center source { module-name | default } logfile { deny | level severity }
3.     Enable the log file feature.
info-center logfile enable
By default, the log file feature is enabled.
4.     (Optional.) Set the maximum log file size.
By default, the maximum log file size is 10 MB.
5.     (Optional.) Specify the log file directory.
The default log file directory is flash:/logfile.
This command cannot survive a cloud cluster reboot or a master/subordinate switchover.
6.     Save logs in the log file buffer to the log file. Choose one or both options as needed:
¡     Configure the automatic log file saving interval.
The default log file saving interval is 86400 seconds.
¡     Immediately save logs from the log file buffer to the log file.
logfile save
This command is available in any view.
Use this feature to set the minimum storage period for logs in the log buffer and log file. This feature ensures that logs will not be overwritten by new logs during a set period of time.
By default, when the log buffer or log file is full, new logs will automatically overwrite the oldest logs. After the minimum storage period is set, the system identifies the storage period of a log to determine whether to delete the log. The system current time minus a log's generation time is the log's storage period.
·     If the storage period of a log is shorter than or equal to the minimum storage period, the system does not delete the log. The new log will not be saved.
·     If the storage period of a log is longer than the minimum storage period, the system deletes the log to save the new log.
Hardware and feature compatibility
Series
Models
Product codes
WX3500X series
WX3510X
WX3520X
WX3540X
EWP-WX3510X
EWP-WX3520X
EWP-WX3540X
Yes
WX3500X-E series
WX3508X-E
EWP-WX3508X-E
Yes
LSEM1WBC120G0
LSEM1WBC120G0
No
Series
Models
Product codes
WX3500X-G series
WX3520X-G
EWP-WX3520X-G
Yes
Series
Models
Product codes
WX3800X series
WX3820X
WX3840X
EWP-WX3820X
EWP-WX3840X
Yes
2.     Set the minimum storage period for logs.
info-center syslog min-age min-age
By default, the log minimum storage period is not set.
Use this feature to set the minimum storage period for logs in the log files and log buffer. This feature ensures that logs will not be overwritten by new logs during a set period of time.
For logs
By default, when the log buffer is full, new logs will automatically overwrite the oldest logs. After the minimum storage period is set, the system identifies the storage period of a log to determine whether to delete the log. The system current time minus a log's generation time is the log's storage period.
For log files
By default, when the last log file is full, the device locates the oldest compressed log file logfileX.log.gz and creates a new file using the same name (logfileX.log). After the minimum storage period is set, the system identifies the storage period of the compressed log file before creating a new log file with the same name. The system current time minus the log file's last modification time is the log file's storage period.
·     If the storage period of the compressed log file is shorter than or equal to the minimum storage period, the system stops saving new logs.
·     If the storage period of the compressed log file is longer than the minimum storage period, the system creates a new file to save new logs.
Series
Models
Product codes
WX3500X series
WX3510X
WX3520X
WX3540X
EWP-WX3510X
EWP-WX3520X
EWP-WX3540X
No
WX3500X-E series
WX3508X-E
EWP-WX3508X-E
No
LSEM1WBC120G0
LSEM1WBC120G0
Yes
Series
Models
Product codes
WX3500X-G series
WX3520X-G
EWP-WX3520X-G
No
Series
Models
Product codes
WX3800X series
WX3820X
WX3840X
EWP-WX3820X
EWP-WX3840X
No
2.     Set the minimum storage period for logs in the log files and log buffer.
By default, the minimum storage period is not set.
System log output interrupts ongoing configuration operations, obscuring previously entered commands. Synchronous information output shows the obscured commands. It also provides a command prompt in command editing mode, or a [Y/N] string in interaction mode so you can continue your operation from where you were stopped.
2.     Enable synchronous information output.
info-center synchronous
By default, synchronous information output is disabled.
The information center supports outputting log messages by using the GB18030 or UTF-8 encoding. By default, the GB18030 encoding is used.
For the login terminal to correctly display Chinese characters in log messages received from the information center, the information center and the terminal must use the same character set encoding.
The encoding method configured by the info-center syslog utf-8 enable command takes effect for logs output in all directions except for the log buffer direction. If a log host uses a log output profile, and the log output profile has the character-set command configured, then the logs sent to that log host will use the encoding method configured by the character-set command. That is, the configuration priority of the character-set command is higher than that of the info-center syslog utf-8 enable command.
2.     Enable the information center to use the UTF-8 encoding.
By default, the information center uses the GB18030 encoding for outputting log messages.
The information center on the device outputs logs generated by service modules. The device identifies logs that have the same module name, level, mnemonic, location, and text as duplicate logs.
In some scenarios, for example, ARP attack or link failure, the service modules will generate a large volume of duplicate logs during a short period of time. Recording and output of consecutive duplicate logs wastes system and network resources. To resolve this issue, you can enable duplicate log suppression.
With this feature enabled, when a service module generates a log, the information center outputs the log and starts the duplicate log suppression timer. The suppression period of the duplicate log suppression timer varies by phase. The suppression periods in phase 1, 2, and later phases are 30 seconds, 2 minutes, and 10 minutes, respectively.
After you enable duplicate log suppression, the system starts suppression upon outputting a log:
·     If only duplicate logs of the log are received during the suppression period of a phase, the information center does not output the duplicate logs. When the suppression period of the phase expires, the information center outputs the suppressed log and the number of times the log is suppressed, and starts the next suppression phase.
·     If a different log is received during the suppression period of a phase, the information center performs the following operations:
¡     Stops suppression on the log, and outputs the suppressed log and the number of times the log is suppressed.
¡     Outputs the different log and starts phase-1 suppression for that log.
·     If no log is received within the suppression period of any phase, the information center deletes the duplicate log suppression timer, stops suppression on the log, and does not output any log.
2.     Enable duplicate log suppression.
info-center logging suppress duplicates
By default, duplicate log suppression is disabled.
The following example uses SHELL_CMD logs to verify the duplicate log suppression feature. After the user executes a command on the device, the information center receives a SHELL_CMD log generated by the shell module, encapsulates the log, and then outputs the log to the log buffer.
1.     Verify the suppression effect in phases 1, 2, 3, and 4 of a log (with suppression period of 30 seconds, 2 minutes, 10 minutes, and 10 minutes):
# In a lab environment, continuously execute the display logbuffer command for 25 minutes.
# View the output logs in the log buffer.
<Sysname> display logbuffer
Log buffer: Enabled
Max buffer size: 1024
Actual buffer size: 512
Dropped messages: 0
Overwritten messages: 0
Current messages: 5
%Jul 20 13:01:20:615 2022 Sysname SHELL/6/SHELL_CMD: -Line=con0-IPAddr=**-User=**; Command is display logbuffer
%Jul 20 13:01:50:718 2022 Sysname SHELL/6/SHELL_CMD: -Line=con0-IPAddr=**-User=**; Command is display logbuffer This message repeated 2 times in last 30 seconds.
%Jul 20 13:03:50:732 2022 Sysname SHELL/6/SHELL_CMD: -Line=con0-IPAddr=**-User=**; Command is display logbuffer This message repeated 5 times in last 2 minutes.
%Jul 20 13:13:50:830 2022 Sysname SHELL/6/SHELL_CMD: -Line=con0-IPAddr=**-User=**; Command is display logbuffer This message repeated 10 times in last 10 minutes.
%Jul 20 13:23:50:211 2022 Sysname SHELL/6/SHELL_CMD: -Line=con0-IPAddr=**-User=**; Command is display logbuffer This message repeated 6 times in last 10 minutes.
¡     The information center received the log SHELL/6/SHELL_CMD: -Line=con0-IPAddr=**-User=**; Command is display logbuffer.
¡     In phase 1, the log was suppressed twice by the information center.
¡     In phase 2, the log was suppressed five times by the information center.
¡     In phase 3, the log was suppressed 10 times by the information center.
¡     In phase 4, the log was suppressed six times by the information center.
2.     Continue to verify how duplicate log suppression works when a different log is received during the suppression period of a log:
# Execute the display logbuffer command three times, and then execute the display interface brief command.
Log buffer: Enabled
Dropped messages: 0
Current messages: 5
%Jul 20 13:24:56:205 2022 Sysname SHELL/6/SHELL_CMD: -Line=con0-IPAddr=**-User=**; Command is display logbuffer This message repeated 3 times in last 1 minute 6 seconds.
%Jul 20 13:25:41:205 2022 Sysname SHELL/6/SHELL_CMD: -Line=con0-IPAddr=**-User=**; Command is display interface brief.
<Sysname>
¡     The information center stopped suppression for the log SHELL/6/SHELL_CMD: -Line=con0-IPAddr=**-User=**; Command is display logbuffer.
¡     The information center output the log SHELL/6/SHELL_CMD: -Line=con0-IPAddr=**-User=**; Command is display interface brief, and started suppression for it.
This feature suppresses output of logs. You can use this feature to filter out the logs that you are not concerned with.
Perform this task to configure a log suppression rule to suppress output of all logs or logs with a specific mnemonic value for a module.
2.     Configure a log suppression rule for a module.
By default, the device does not suppress output of any logs from any modules.
By default, an interface generates link up or link down log information when the interface state changes. In some cases, you might want to disable certain interfaces from generating this information. For example:
·     You are concerned about the states of only some interfaces. In this case, you can use this function to disable other interfaces from generating link up and link down log information.
·     An interface is unstable and continuously outputs log information. In this case, you can disable the interface from generating link up and link down log information.
Use the default setting in normal cases to avoid affecting interface status monitoring.
2.     Enter interface view.
3.     Disable the interface from generating link up or link down logs.
undo enable log updown
By default, an interface generates link up and link down logs when the interface state changes.
This feature enables the device to send an SNMP notification for each log message it outputs. The device encapsulates the logs in SNMP notifications and then sends them to the SNMP module and the log trap buffer.
You can configure the SNMP module to send received SNMP notifications in SNMP traps or informs to remote hosts. For more information, see SNMP configuration in Network Management and Monitoring Configuration Guide.
To view the traps in the log trap buffer, access the MIB corresponding to the log trap buffer.
2.     Enable SNMP notifications for system logs.
snmp-agent trap enable syslog
By default, the device does not send SNMP notifications for system logs.
3.     Set the maximum number of traps that can be stored in the log trap buffer.
By default, the log trap buffer can store a maximum of 1024 traps.
Security logs are very important for locating and troubleshooting network problems. Generally, security logs are output together with other logs. It is difficult to identify security logs among all logs.
To solve this problem, you can save security logs to the security log file without affecting the current log output rules.
After you enable the security log file feature, the system processes security logs as follows:
1.     Outputs security logs to the security log file buffer.
2.     Saves logs from the security log file buffer to the security log file at the specified interval.
If you have the security-audit role, you can also manually save security logs to the security log file.
3.     Clears the security log file buffer immediately after the security logs are saved to the security log file.
The device supports only one security log file. The system will overwrite old logs with new logs when the security log file is full. To avoid security log loss, you can set an alarm threshold for the security log file usage ratio. When the alarm threshold is reached, the system outputs a message to inform you of the alarm. You can log in to the device with the security-audit user role and back up the security log file to prevent the loss of important data.
2.     Enable the security log file feature.
info-center security-logfile enable
By default, the security log file feature is disabled.
3.     Set the interval at which the system saves security logs.
The default security log file saving interval is 86400 seconds.
4.     (Optional.) Set the maximum size for the security log file.
By default, the maximum security log file size is 10 MB.
5.     (Optional.) Set the alarm threshold of the security log file usage.
By default, the alarm threshold of the security log file usage ratio is 80. When the usage of the security log file reaches 80%, the system will send a message.
To use the security log file management commands, you must have the security-audit user role. For information about configuring the security-audit user role, see AAA configuration in User Access and Authentication Configuration Guide.
2.     Change the directory of the security log file.
By default, the security log file is saved in the seclog directory in the root directory of the storage device.
3.     Manually save all logs in the security log file buffer to the security log file.
security-logfile save
4.     (Optional.) Display the summary of the security log file.
display security-logfile summary
The system saves security logs to the security log file buffer before the logs are saved to the security log file automatically or manually.
After saving the buffered security logs to the security log file, the system clears the security log file buffer.
To manage security log file , you must have the security-audit user role. For information about configuring the security-audit user role, see AAA configuration in User Access and Authentication Configuration Guide.
·     Display summary information of the security log file.
·     Display the content of the security log file buffer.
display security-logfile buffer
You can use this feature to back up the following log files to a remote server through FTP, TFTP, or SCP so as to enhance the log file security:
·     General log files under the directory specified by the info-center logfile directory command.
·     Security log files under the directory specified by the info-center security-logfile directory command.
The device supports only one general log file and one security log file. It automatically backs up the general or security log file to the remote server every time logs are written into the log file.
2.     Specify the username and password for logging in to the remote server to back up log files.
info-center file-server user user-name password { cipher | simple } password
By default, the username and password for logging in to the remote server to back up log files are not specified.
3.     Back up log files to the remote server.
info-center file-server transport-type { ftp | scp | tftp } { ipv4-address | ipv6 ipv6-address } [ port port-number ] [ directory directory ] filename-prefix filename-prefix [ file-type { logfile | security-logfile } ]
By default, the device does not back up log files to a remote server.
To display the remote server configuration and backup records, execute the following command in any view:
display info-center file-server
When the information center saves a log message to the log file, it uses the device master key to calculate a digest for the log file and saves the digest in the log file. The digest is used to perform integrity check for the log file. The device provides a device master key by default.
When this feature is configured, the information center uses the master key to recalculate a digest for the log file and then compares the digest with that saved in the log file. If the two digests are consistent, the log file passes the integrity check. If they do not match, the log file fails the integrity check.
In the current software version, only standard system log files and security log files support integrity check. Diagnostic log files and trace log files do not support integrity check.
To perform integrity check for a log file, execute the following command in user view:
check logfile file-path
For successful execution of this command, the file extension must be .log or .log.gz.
By default, the diagnostic log file feature saves diagnostic logs from the diagnostic log file buffer to the diagnostic log file at the specified saving interval. You can also manually trigger an immediate saving of diagnostic logs to the diagnostic log file. After saving diagnostic logs to the diagnostic log file, the system clears the diagnostic log file buffer.
The device supports only one diagnostic log file. The diagnostic log file has a maximum capacity. When the capacity is reached, the system replaces the oldest diagnostic logs with new logs.
2.     Enable the diagnostic log file feature.
info-center diagnostic-logfile enable
By default, the diagnostic log file feature is enabled.
3.     (Optional.) Set the maximum diagnostic log file size.
By default, the maximum diagnostic log file size is 10 MB.
4.     (Optional.) Specify the diagnostic log file directory.
By default, the diagnostic log file is saved in the diagfile folder under the root directory of the default file system.
5.     Save diagnostic logs in the diagnostic log file buffer to the diagnostic log file. Choose one option as needed:
¡     Configure the automatic diagnostic log file saving interval.
The default diagnostic log file saving interval is 86400 seconds.
¡     Manually save diagnostic logs to the diagnostic log file.
diagnostic-logfile save
To display diagnostic log file configuration, execute the following command in any view:
display diagnostic-logfile summary
·     Display the information center configuration.
display info-center
·     Display information about log output rules.
display info-center source [ module module-name ]
·     Display the log buffer summary.
display logbuffer summary [ level severity | slot slot-number ] *
·     Display log buffer information and buffered logs.
display logbuffer [ reverse ] [ level severity | size buffersize | slot slot-number ] * [ last-mins mins ] [ start-time time date ] [ end-time time date ]
To clear the log buffer, execute the following command in user view:
reset logbuffer
·     Display the log file configuration.
display logfile summary
·     Display the content of the log file buffer.
display logfile buffer
Configure the AC to output to the console ACL logs that have a minimum severity level of warning.
Figure 2 Network diagram
# Enable the information center.
<AC> system-view
[AC] info-center enable
# Disable log output to the console.
[AC] info-center source default console deny
To avoid output of unnecessary information, disable all modules from outputting logs to the specified destination (console in this example) before you configure the output rule.
# Configure an output rule to output to the console ACL logs that have a minimum severity level of warning.
[AC] info-center source acl console level warning
[AC] quit
# Enable log output to the console.
<AC> terminal logging level 6
<AC> terminal monitor
Now, if the FTP module generates logs, the information center automatically sends the logs to the console, and the console displays the logs on the monitor terminal.
Configure the AC to output to the UNIX log host ACL logs that have a minimum severity level of informational.
Figure 3 Network diagram
1.     Make sure the AC and the log host can reach each other. (Details not shown.)
2.     Configure the AC:
<AC> system-view
# Specify log host 1.2.0.1/16 with local4 as the logging facility.
[AC] info-center loghost 1.2.0.1 facility local4
# Disable log output to the log host.
[AC] info-center source default loghost deny
To avoid output of unnecessary information, disable all modules from outputting logs to the specified destination (loghost in this example) before you configure an output rule.
# Configure an output rule to output to the log host ACL logs that have a minimum severity level of informational.
[AC] info-center source acl loghost level informational
3.     Configure the log host:
The log host configuration procedure varies by the vendor of the UNIX operating system. The following shows an example:
a.     Log in to the log host as a root user.
b.     Create a subdirectory named AC in directory /var/log/, and then create file info.log in the AC directory to save logs from the AC.
# mkdir /var/log/AC
# touch /var/log/AC/info.log
c.     Edit file syslog.conf in directory /etc/ and add the following contents:
# AC configuration messages
local4.info /var/log/AC/info.log
In this configuration, local4 is the name of the logging facility that the log host uses to receive logs. The value info indicates the informational severity level. The UNIX system records the log information that has a minimum severity level of informational to file /var/log/AC/info.log.
Follow these guidelines while editing file /etc/syslog.conf:
·     Comments must be on a separate line and must begin with a pound sign (#).
·     No redundant spaces are allowed after the file name.
·     The logging facility name and the severity level specified in the /etc/syslog.conf file must be identical to those configured on the AC by using the info-center loghost and info-center source commands. Otherwise, the log information might not be output to the log host correctly.
d.     Display the process ID of syslogd, kill the syslogd process, and then restart syslogd by using the –r option to validate the configuration.
# ps -ae | grep syslogd
147
# kill -HUP 147
# syslogd -r &
Now, the AC can output FTP logs to the log host, which stores the logs to the specified file.
Configure the AC to output to the Linux log host at 1.2.0.1/16 ACL logs that have a minimum severity level of informational.
Figure 4 Network diagram
<AC> system-view
# Specify log host 1.2.0.1/16 with local5 as the logging facility.
[AC] info-center loghost 1.2.0.1 facility local5
To avoid outputting unnecessary information, disable all modules from outputting logs to the specified destination (loghost in this example) before you configure an output rule.
# Configure an output rule to enable output to the log host ACL logs that have a minimum severity level of informational.
The log host configuration procedure varies by the vendor of the Linux operating system. The following shows an example:
# mkdir /var/log/AC
local5.info /var/log/AC/info.log
In this configuration, local5 is the name of the logging facility that the log host uses to receive logs. The value info indicates the informational severity level. The Linux system will store the log information with a severity level equal to or higher than informational to file /var/log/AC/info.log.
d.     Display the process ID of syslogd, kill the syslogd process, and then restart syslogd by using the -r option to validate the configuration.
Make sure the syslogd process is started with the -r option on the Linux log host.
147
# kill -9 147
# syslogd -r &
