11-WLAN Traffic Optimization Configuration Guide
HomeSupportWirelessWX5800X Series Access ControllersConfigure & DeployConfiguration GuidesH3C WX5800X Series Access Controllers Configuration Guides(E5457)-5W10111-WLAN Traffic Optimization Configuration Guide
01-User isolation configuration
01-User isolation configuration 505.42 KB
Configuring user isolation
About user isolation
The user isolation feature isolates packets for users that use the same SSID in the same VLAN or for users that are in the same VLAN. This feature improves user security, relieves the forwarding stress of the device, and reduces consumption of radio resources.
User isolation types
User isolation includes the following types:
·     SSID-based user isolation—Isolates wireless users that use the same SSID in the same VLAN.
·     VLAN-based user isolation—Isolates wired or wireless users in the same VLAN.
·     User group-based user isolation—Isolates wireless users in the same user group or in different user groups.
SSID-based user isolation is applicable to both the local forwarding mode and the centralized forwarding mode.
When SSID-based user isolation is enabled for a service, the device isolates all wireless users that access the network through the service in the same VLAN.
User isolation mechanism in centralized forwarding mode
As shown in Figure 1, the AC centrally forwards the client traffic. Client 1 to Client 3 access the WLAN through AP 1 to AP 3 by using the service named service. Client 1 and Client 2 are in VLAN 100, and Client 3 is in VLAN 200. Enable user isolation on the AC for the service.
·     Client 1 sends broadcast or multicast packets in VLAN 100. When the AC receives the packets, it does not forward them to any APs in the WLAN. The AC forwards the packets only through the wired port to the switch.
·     Client 1 sends unicast packets to Client 2 in VLAN 100. When the AC receives the packets, it discards them instead of forwarding them to AP 2.
Figure 1 Packet forwarding path
User isolation mechanism in local forwarding mode
This mechanism isolates wireless clients on the same AP.
As shown in Figure 2, the APs perform local traffic forwarding for clients. Client 1 to Client 4 access the WLAN through AP 1 to AP 3 by using the service named service. Client 1 to Client 3 are in VLAN 100, and Client 4 is in VLAN 200. Enable SSID-based user isolation on the service for AP 1.
¡     When AP 1 receives the packets, it does not forward them to Client 2 because user isolation is enabled. The AP forwards the packets only through the wired port to the wired devices in the same VLAN, including AP 2, AP 3, and the host.
¡     When AP 2 receives the packets, it forwards them to Client 3 because user isolation is disabled on AP 2.
¡     When AP 3 receives the packets, it does not forward them to Client 4 because Client 1 and Client 4 are in different VLANs.
·     Client 1 sends unicast packets to Client 2 in VLAN 100. When AP 1 receives the packets, it discards them instead of forwarding them to Client 2.
Figure 2 Packet forwarding path
VLAN-based user isolation is applicable to both local and centralized forwarding modes. Table 1 shows the mechanism to isolate traffic of wired users and wireless users.
Table 1 VLAN-based user isolation mechanism
Forwarding mode
Received unicast packets
Received broadcast or multicast packets
Centralized forwarding
The AC discards the packets.
The AC forwards the packets only through wired ports to the wired users in the VLAN, and it does not forward the packets to wireless users in the VLAN.
Local forwarding
The fit AP discards the packets.
The fit AP forwards the packets to wired and wireless users in the VLAN through wired ports. However, the AP does not forward the packets to the local wireless users in the VLAN.
User isolation mechanism in centralized forwarding mode (packets received from wireless users)
As shown in Figure 3, the AC centrally forwards the client traffic. Enable user isolation on the AC for VLAN 100.
·     Client 1 sends broadcast or multicast packets in VLAN 100. When the AC receives the packets, it does not forward them to any APs in the WLAN. The AC forwards the packets only through the wired port to the switch. The switch then forwards the packets to the wired host and server.
·     Client 1 sends unicast packets to Client 3 in VLAN 100. When the AC receives the packets, it discards them instead of forwarding them to AP 2.
Figure 3 Packet forwarding path
User isolation mechanism in centralized forwarding mode (packets received from wired users)
As shown in Figure 4, the AC centrally forwards the client traffic. Enable user isolation on the AC for VLAN 100.
·     The host sends broadcast or multicast packets in VLAN 100. The server and AC can receive the packets. When the AC receives the packets, it discards them instead of forwarding them to any APs in the WLAN.
·     The host sends unicast packets to Client 3 in VLAN 100. When the AC receives the packets, it discards them instead of forwarding them to AP 2.
Figure 4 Packet forwarding path
User isolation mechanism in local forwarding mode (packets received from wireless users)
As shown in Figure 5, AP 1 performs local forwarding for clients. Enable user isolation on AP 1 for VLAN 100.
¡     When AP 1 receives the packets, it forwards them to the server, AP 2, and the host in VLAN 100 through the wired port. However, AP 1 does not forward the packets to Client 2 because user isolation is enabled.
¡     When AP 2 receives the packets, it forwards them to Client 3 since user isolation is not enabled on AP 2.
·     Client 1 sends unicast packets to Client 3 in VLAN 100. When AP 1 receives the packets, it discards them instead of forwarding them to AP 2.
Figure 5 Packet forwarding path
User isolation mechanism in local forwarding mode (packets received from wired users)
As shown in Figure 6, AP 1 performs local forwarding for clients. Enable user isolation on AP 1 for VLAN 100.
·     The host sends broadcast or multicast packets in VLAN 100. The server, AC, AP 1, and AP 2 can receive the packets.
¡     When AP 1 receives the packets, it discards them instead of forwarding them to Client 1 and Client 2.
·     The host sends unicast packets to Client 1 in VLAN 100. When AP 1 receives the packets, it discards them instead of forwarding them to Client 1.
Figure 6 Packet forwarding path
Group-based user isolation
Group-based user isolation isolates wireless clients based on user groups. It supports the intra-group and inter-group user isolation methods and is applicable to the centralized forwarding mode.
Table 2 Group-based user isolation mechanism
Forwarding mode
Access AP
Service VLAN
Isolation mode
User communication
Same or different
Same or different
Intra-group isolation
·     Users in the same group cannot send unicast packets to each other.
·     Users in different groups can send unicast packets to each other.
Inter-group isolation
·     Users in the same group can send unicast packets to each other.
·     Users in different groups cannot send unicast packets to each other.
If wireless users are in different service VLANs, you need to deploy the gateway on the AC to implement group-based user isolation.
As shown in Figure 7, the AC centrally forwards the client traffic. Client 1 through Client 3 are connected to the wireless network through AP 1 through AP 3, respectively. Client 1 and Client 2 belong to VLAN 100 and user group GROUP_100. Client 3 belongs to VLAN 200 and user group GROUP_100. Enable intra-group user isolation on the AC for GROUP_100.
·     Client 1 sends a unicast packet to Client 2 in VLAN 100. After the AC receives the packet, it does not forward the packet to AP 2 but discards the packet.
·     Client 1 send a unicast packet to Client 3 in VLAN 200. After the AC receives the packet, it does not forward the packet to AP 3 but discards the packet.
Figure 7 Packet forwarding path
Enabling SSID-based user isolation
2.     Enter service template view.
wlan service-template service-template-name
3.     Enable SSID-based user isolation.
user-isolation enable
By default, SSID-based user isolation is disabled.
Configuring VLAN-based user isolation
VLAN-based user isolation applies to both the centralized forwarding mode and the local forwarding mode.
·     In centralized forwarding mode, configure this feature directly on the AC.
·     In local forwarding mode, you must prepare a configuration file that contains user isolation command lines in the order as shown in the "Procedure" section. Then, use the map-configuration command on the AC to deploy the configuration file to an AP to enable VLAN-based user isolation for the AP. For more information about configuration file deployment, see WLAN Access Configuration Guide.
To enable users in a VLAN to access the external network, assign the VLAN gateway MAC address to the permitted MAC address list before you enable VLAN-based user isolation.
2.     Configure permitted MAC address list for a list of VLANs.
user-isolation vlan vlan-list permit-mac mac-list
By default, no permitted MAC addresses are configured for a VLAN.
The device can forward unicast, multicast, and broadcast traffic sent by the users of permitted MAC addresses in the specified VLANs. In addition, the device can forward unicast traffic sent from other users to these users.
3.     Enable user isolation for a list of VLANs.
user-isolation vlan vlan-list enable [ permit-unicast ]
By default, user isolation is disabled for a VLAN.
4.     (Optional.) Permit broadcast and multicast traffic sent from wired users to wireless users.
user-isolation permit-broadcast
By default, the device does not forward broadcast or multicast traffic sent from wired users to wireless users in the VLANs where user isolation is enabled.
5.     (Optional.) Permit wireless users in the specified VLANs to receive broadcast and multicast traffic that matches an ACL.
user-isolation vlan vlan-list permit-bmc acl [ ipv6 ] acl-number
By default, wireless users in a VLAN cannot receive broadcast or multicast traffic.
Configuring user isolation for a user group
To isolate wireless clients based on user groups, assign wireless clients to user groups and then configure the user isolation policy for each group. The user isolation policy for a user group can use either or both of the following isolation methods:
·     Intra-group isolation—Prevents the users in the group from communicating with each other at Layer 2 or Layer 3.
·     Inter-group isolation—Prevents the users in the group from communicating with users in other groups.
·     Group-based user isolation policies are applicable only to unicast packets in the centralized forwarding scenario.
·     If wireless users are in different service VLANs, deploy the gateway on the AC to implement group-based user isolation.
·     If a user group has a user isolation policy configured and the user group has been assigned to users, do not delete or edit the user group to avoid isolation policy errors.
2.     Create a user group and enter user group view.
user-group group-name
By default, a system-defined user group exists. The group name is system.
3.     Configure the user isolation policy for the user group.
user-isolation { intra-group | inter-group } *
By default, a user group does not have a user isolation policy.
For more information about user groups and user isolation policies, see AAA in User Access and Authentication Configuration Guide.
Display and maintenance commands for user isolation
Display user isolation statistics for a VLAN or for all VLANs.
display user-isolation statistics [ vlan vlan-id ]
Clear user isolation statistics for a VLAN or for all VLANs.
reset user-isolation statistics [ vlan vlan-id ]
User isolation configuration examples
Example: Configuring SSID-based user isolation (centralized forwarding mode)
As shown in Figure 8, Client 1 and Client 2 use the same SSID to access the Internet. The AC centrally forwards the client traffic.
Configure user isolation on the AC to isolate the clients from each other while providing Internet access for the clients.
Figure 8 Network diagram
# Configure Client 1 and Client 2 to access the Internet through service template service. For more information, see WLAN access in WLAN Access Configuration Guide and AP management in AP and WT Management Configuration Guide. (Details not shown.)
# Enable SSID-based user isolation for service template service.
<AC> system-view
[AC] wlan service-template service
[AC-wlan-st-service] user-isolation enable
[AC-wlan-st-service] quit
# Verify that Client 1 and Client 2 can use service service to access the Internet but cannot access each other. (Details not shown.)
Example: Configuring SSID-based user isolation (local forwarding mode)
As shown in Figure 9, Client 1 and Client 2 use the same SSID to access the Internet. The APs perform local traffic forwarding.
Configure user isolation for AP 1 to isolate the clients from each other while providing Internet access for the clients.
Figure 9 Network diagram
# Configure Client 1 and Client 2 to access the Internet through service template service1. Configure the APs to perform local traffic forwarding for the clients. For more information, see WLAN access in WLAN Access Configuration Guide and AP management in AP and WT Management Configuration Guide. (Details not shown.)
# Enable SSID-based user isolation for service template service1.
<AC> system-view
[AC] wlan service-template service1
[AC-wlan-st-service1] user-isolation enable
[AC-wlan-st-service1] quit
# Verify that Client 1 and Client 2 can use service service1 to access the Internet but cannot access each other. (Details not shown.)
Example: Configuring VLAN-based user isolation (centralized forwarding mode)
As shown in Figure 10, the AC centrally forwards the client traffic and the router acts as the gateway of the devices in VLAN 100. The MAC address of the gateway is 000f-e212-7788.
Configure user isolation for VLAN 100 on the AC to meet the following requirements:
·     Client 1, Client 2, Client 3, the host, and the server can access the Internet. For this purpose, add the MAC address of the gateway to the permitted MAC address list.
·     When Client 1 forwards broadcast packets, only the host and the server can receive the packets.
·     Client 1, Client 2, and Client 3 cannot reach one another.
Figure 10 Network diagram
# Configure Client 1, Client 2, and Client 3 to access the Internet through WLAN. For more information, see WLAN access in WLAN Access Configuration Guide and AP management in AP and WT Management Configuration Guide. (Details not shown.)
# Assign the MAC address of the gateway to the permitted MAC address list.
<AC> system-view
[AC] user-isolation vlan 100 permit-mac 000f-e212-7788
# Enable VLAN-based user isolation for VLAN 100.
[AC] user-isolation vlan 100 enable
# Verify that Client 1, Client 2, Client 3, the host, and the server in VLAN 100 can access the Internet. (Details not shown.)
# Verify that only the host and the server can receive broadcast packets from Client 1. (Details not shown.)
# Verify that Client 1, Client 2, and Client 3 cannot reach one another. (Details not shown.)
Example: Configuring VLAN-based user isolation (local forwarding mode)
As shown in Figure 11, AP 1 performs local traffic forwarding for the clients and the router acts as the gateway of the devices in VLAN 100. The MAC address of the gateway is 000f-e212-7788.
Configure user isolation for VLAN 100 on AP 1 to meet the following requirements:
·     When Client 1 forwards broadcast packets, only the host, the server, and Client 3 can receive the packets.
·     Client 1 and Client 2 cannot reach each other.
Figure 11 Network diagram
# Create configuration file apcfg.txt and add user isolation command lines in the following order into the configuration file. You must place the command for adding the gateway MAC address to the permitted MAC address list before the command for enabling user isolation.
# Upload configuration file apcfg.txt to the AC. (Details not shown.)
# Issue configuration file apcfg.txt to AP 1.
<AC> system-view
[AC] wlan ap ap1 model WA6320
[AC-wlan-ap-ap1] map-configuration apcfg.txt
# Verify that only the host, the server, and Client 3 can receive broadcast packets from Client 1. (Details not shown.)
# Verify that Client 1 and Client 2 cannot reach each other. (Details not shown.)
