| 01-KPI data collection commands | 179.98 KB |
Available data for KPI data collection
kpi file aging threshold remain-disk-size
kpi file aging threshold total-file-size
Table 1 Available data for KPI data collection
Class |
Module |
Object |
Indicator |
Indicator description |
Device-state |
DEV |
Card |
Device restarts |
Number of device reboots. |
IRF (This module is not supported in the current software version.) |
Device |
IRF splits |
Number of IRF splits. |
Device |
IRF dual-active count |
Number of dual-master IRF fabrics. |
DEV |
Card |
LPU failures |
Number of LPU failures. |
DEV |
Card |
MPU state |
State of the MPU: · 0—The MPU is not present. · 1—The MPU is operating correctly. · 2—The MPU has failed. |
DEV |
Card |
MPU failures |
Number of MPU failures. |
DEV |
Card |
SFU state |
State of the SFU: · 0—The SFU is not present. · 1—The SFU is operating correctly. · 2—The SFU has failed. |
DEV |
Card |
SFU failures |
Number of SFU failures. |
DEV |
Subcard |
Subslot failure |
Number of subcard failures. |
FWD |
Device |
Inc H&S entries |
Inconsistent hardware and software entries. |
FAN |
Device |
Fan state |
Fan tray state: · 0—Normal. · 1—Faulty. |
POWER |
Device |
Power state |
Power supply state: · 0—Normal. · 1—Faulty. |
POE |
Device |
PoE state |
PoE power supply state: · 0—Normal. · 1—Faulty. |
TEMP |
Device |
Card temperature |
Card temperature: · 0—Normal. · 1—Faulty. |
FS |
Device |
File exceptions |
Number of save operation failures due to file system error. |
DEV |
Device |
Process abnormal reboot |
Number of process reboot failures. |
DEV |
Device |
Process normal reboot |
Number of successful process reboots. |
Device-resource |
FWD-RES |
Card |
ARP entry usage |
Ratio of the real-time ARP entry count to the upper ARP entry count limit. |
FWD-RES |
Card |
ARP threshold ratio |
Ratio of the real-time ARP entry count to the ARP table usage threshold. |
FWD-RES |
Card |
MAC entry usage |
Ratio of the real-time MAC entry count to the upper MAC entry count limit. |
FWD-RES |
Card |
MAC threshold ratio |
Ratio of the real-time MAC entry count to the MAC table usage threshold. |
FWD-RES |
Card |
FIB entry usage |
Ratio of the real-time FIB entry count to the upper FIB entry count limit. |
FWD-RES |
Card |
FIB threshold ratio |
Ratio of the real-time FIB entry count to the FIB table usage threshold. |
FWD-RES |
Card |
ND entry usage |
Ratio of the real-time ND entry count to the upper ND entry count limit. |
FWD-RES |
Card |
ND threshold ratio |
Ratio of the real-time ND entry count to the ND table usage threshold. |
FWD-RES |
Card |
IPv4L2multicast usage |
Ratio of the real-time IPv4 Layer 2 multicast entry count to the upper IPv4 Layer 2 multicast entry count limit. |
FWD-RES |
Card |
IPv4L2multicast ratio |
Ratio of the real-time IPv4 Layer 2 multicast entry count to the IPv4 Layer 2 multicast entry count threshold. |
FWD-RES |
Card |
IPv6L2multicast usage |
Ratio of the real-time IPv6 Layer 2 multicast entry count to the upper IPv6 Layer 2 multicast entry count limit. |
FWD-RES |
Card |
IPv6L2multicast ratio |
Ratio of the real-time IPv6 Layer 2 multicast entry count to the IPv6 Layer 2 multicast entry count threshold. |
FWD-RES |
Card |
IPv4L3multicast usage |
Ratio of the real-time IPv4 Layer 3 multicast entry count to the upper IPv4 Layer 3 multicast entry count limit. |
FWD-RES |
Card |
IPv4L3multicast ratio |
Ratio of the real-time IPv4 Layer 3 multicast entry count to the IPv4 Layer 3 multicast entry count threshold. |
FWD-RES |
Card |
IPv6L3multicast usage |
Ratio of the real-time IPv6 Layer 3 multicast entry count to the upper IPv6 Layer 3 multicast entry count limit. |
FWD-RES |
Card |
IPv6L3multicast ratio |
Ratio of the real-time IPv6 Layer 3 multicast entry count to the IPv6 Layer 3 multicast entry count threshold. |
ACL-RES |
Card |
ACL usage |
Ratio of the real-time ACL entry count to the upper ACL entry count limit. |
ACL-RES |
Card |
ACL threshold ratio |
Ratio of the real-time ACL entry count to the ACL entry count threshold. |
STOR-RES |
Card |
Storage usage |
Ratio of the used storage space to the total storage space. |
STOR-RES |
Card |
Storage threshold ratio |
Ratio of the used storage space to the storage space usage threshold. |
DEV-RES |
Card |
CPU usage |
Ratio of the used CPU capacity to the total CPU capacity. |
DEV-RES |
Card |
CPU threshold ratio |
Ratio of the used CPU capacity to the CPU usage threshold. |
DEV-RES |
Card |
Memory usage |
Ratio of the used memory to the total memory. |
DEV-RES |
Card |
Memory threshold ratio |
Ratio of the used memory to the memory usage threshold. |
Net-performance |
LOOP-DCT |
Device |
L2 loop state |
Layer 2 loop state: · 0—The Layer 2 loop is operating correctly. · 1—Layer 2 loop has failed. |
IF-CI |
Port congestion |
Number of packets dropped due to traffic congestion. |
IF-ERROR |
Port error |
Number of packets dropped due to error packets. |
CPCAR |
Device |
CPCAR loss |
Number of dropped packets due to traffic policing configured on the control panel. |
STP-SWT |
Device |
STP switchovers |
Number of STP switchovers. |
LACP-SWT |
Device |
LACP switchovers |
Number of link aggregation switchovers. |
IRF-SWT |
Device |
IRF switchovers |
Number of IRF switchovers. |
M-LAG-SWT |
Device |
M-LAG switchovers |
Number of M-LAG switchovers. |
RRPP-SWT |
Device |
RRPP switchovers |
Number of RRPP switchovers. |
VRRP-SWT |
Device |
VRRP switchovers |
Number of VRRP switchovers. |
IF-USAGE |
Device |
Port BW usage |
Bandwidth usage for all ports. |
Port-state |
PORT-ST |
Device |
Down ports |
Number of physical interfaces in down state. |
PORT-ST |
Device |
Port flappings |
Number of port flappings. |
TRAN-ST |
Device |
Opti-module health |
Transceiver module health. |
Net-connection |
RPNCS |
Device |
ISIS peer status |
IS-IS neighbor connection state: · 0—The IS-IS neighbor connection is operating correctly. · 1—The IS-IS neighbor connection has failed. |
RPNCS |
Device |
OSPF peer status |
OSPF neighbor connection state: · 0—The OSPF neighbor connection is operating correctly. · 1—The OSPF neighbor connection has failed. |
RPNCS |
Device |
OSPv3 peer status |
OSPFv3 neighbor connection state: · 0—The OSPFv3 neighbor connection is operating correctly. · 1—The OSPFv3 neighbor connection has failed. |
RPNCS |
Device |
BGP peer status |
BGP neighbor connection state: · 0—The BGP neighbor connection is operating correctly. · 1—The BGP neighbor connection has failed. |
MCRCS |
Device |
Multicast connection status |
Multicast route connection state: · 0—The multicast route connection is operating correctly. · 1—The multicast route connection has failed. |
DHCPCS |
Device |
DHCPv4 server state |
State of the DHCPv4 server: · 0—The DHCPv4 server is operating correctly. · 1—The DHCPv4 server has failed. |
DHCPCS |
Device |
DHCPv6 server state |
State of the DHCPv6 server: · 0—The DHCPv6 server is operating correctly. · 1—The DHCPv6 server has failed. |
DHCPCS |
Device |
DHCPv4 server switching |
Number of DHCPv4 server switchovers. |
DHCPCS |
Device |
DHCPv6 server switching |
Number of DHCPv6 server switchovers. |
DHCPCS |
Device |
DHCPv4 entry failures |
Number of DHCPv4 entry establishment failures. |
DHCPCS |
Device |
DHCPv6 entry failures |
Number of DHCPv6 entry establishment failures. |
Net-securit y |
AAA |
Device |
1X AuthN status |
State of 802.1X authentication: · 0—802.1X authentication succeeded. · 1—802.1X authentication failed. An attack might exist. |
AAA |
Device |
1X Usr&Pwd status |
State of the username and password for 802.1X authentication: · 0—The username and password are correct. · 1—The username and password are incorrect. |
AAA |
Device |
MAC AuthN status |
State of MAC authentication: · 0—MAC authentication succeeded. · 1—MAC authentication failed. An attack might exist. |
AAA |
Device |
MAC Usr&Pwd status |
State of the username and password for MAC authentication: · 0—The username and password are correct. · 1—The username and password are incorrect. |
AAA |
Device |
Portsec AuthN status |
State of the port security authentication: · 0—The authentication succeeded. · 1—The authentication failed. An attack might exist. |
AAA |
Device |
Portsec Usr&Pwd status |
State of the port security access username and password: · 0—The username and password are correct. · 1—The username and password are incorrect. |
AAA |
Device |
StaticUser AuthN status |
State of the static user authentication: · 0—The authentication succeeded. · 1—The authentication failed. An attack might exist. |
AAA |
Device |
StaticUser Usr&Pwd status |
State of the static username and password: · 0—The username and password are correct. · 1—The username and password are incorrect. |
ATTACK |
Device |
All-type attacks |
Number of all types of attacks. |
TCP |
Device |
TCP attacks |
Number of TCP attacks. |
ARP-ATK |
Device |
ARP attacks |
Number of ARP attacks. |
ND-ATK |
Device |
ND attacks |
Number of ND attacks. |
AAA |
Device |
Illegal user detections |
Number of illegal user detections. |
display kpi data
Use display kpi data to display the key performance indicator (KPI) data for service modules and objects within a time range on the storage media.
display kpi data module module-name object object-name from time1 date1 to time2 date2 [ file file-path ]
module module-name: Specifies a module by its name. For more information, see Table 1.
object object-name: Specifies an object by its name. Objects are physical entities to which the indicators belong, such as devices, cards, or subcards. The value for the object-name argument varies by object type. Available values include:
· device—Specifies a device. Indicators for this object describe the overall condition of the device.
· chassis.x/slot.y—Specifies a card. Indicators for this object describe the performance of the card. The value for x is 0, and y represents the slot number of the card.
· chassis.x/slot.y/subslot.z—Specifies a subcard. Indicators for this object describe the performance of the subcard. The value for x is 0, y represents the slot number of the card, and z represents the subcard ID.
· interface-typeinterface-number—Specifies an interface by its type and number. Indicators for this object describe the running status of the physical interface.
from time1 date1: Specifies the start time and date for KPI data collection. The time1 argument specifies the time of the day in hh:mm:ss format (24-hour clock). Its value is in the range of 00:00:00 to 23:59:59. The date1 argument specifies a date in MM/DD/YYYY or YYYY/MM/DD format. MM is the month of the year in the range of 1 to 12, DD is the day of the month with the range varying by MM, and YYYY is the year in the calendar in the range of 2000 to 2035.
to time2 date2: Specifies the end time and date for KPI data collection. The time2 argument has the same format and value range as the time1 argument. The date2 argument has the same format and value range as the date1 argument. The end time must be later than the start time.
file file-path: Specifies the KPI cache file path on the storage media. If you do not specify this option, the command displays the KPI data in all cache files.
# Display the KPI data for the DEV-RES module and chassis.0/slot.2 object in the specified time range.
<Sysname> display kpi data module DEV-RES object chassis.0/slot.2 from 16:35:05 2022/4/1 to 16:41:06 2022/4/1
Module : DEV-RES
Object : chassis.0/slot.2
Slot : 2
Indicator Value Latest collect time
CPU usage 0.7 2022-04-01 16:41:05
Memory usage 0.7 2022-04-01 16:39:05
Module |
Module name. For more information, see Table 1. |
Slot |
Slot on which the object resides. |
Object |
Object for KPI data collection. |
Indicator |
Indicator for KPI data collection. For more information, see Table 1. |
Value |
Value for the indicator. |
Latest collect time |
Most recent time for KPI data collection. |
display kpi module-info
Use display kpi module-info to display KPI data collection information for service modules.
display kpi module-info [ module-name ] [ verbose ]
module-name: Specifies a module by its name. For information about the module names, see Table 1. If you do not specify this argument, the command displays KPI data collection information for all available service modules.
verbose: Displays detailed information about the module. If you do not specify this keyword, the command displays brief information about the module.
# Display brief KPI data collection information for the DEV-RES module.
<Sysname> display kpi module-info DEV-RES
Module : DEV-RES
Class : Device-resource
KPI Collect : Enabled
Collect interval : 300 seconds
Collect times : 2
# Display detailed KPI data collection information for the DEV-RES module.
<Sysname> display kpi module-info DEV-RES verbose
Module : DEV-RES
Collect times : 2
Slot : 2
CPU usage 0.7 2022-03-29 14:36:52
Memory usage 0.7 2022-03-29 14:36:52
Slot : 3
Object : chassis.0/slot.3
Module |
Class |
KPI class to which the module belongs. For more information, see Table 1. |
KPI Collect |
State of KPI data collection: · Enabled—KPI data collection is enabled for the module. · Disabled—KPI data collection is disabled for the module. |
Collect interval |
KPI data collection interval, in seconds. |
Collect times |
Number of KPI data collections. |
Slot |
Object |
Object name. |
Indicator |
Value |
kpi copy-file to active-mpu
Use kpi copy-file to active-mpu to copy the KPI data on the standby MPU to the active MPU.
After an MPU active/standby switchover on the device, the new active MPU cannot automatically obtain the KPI data from the old active MPU (current standby MPU). To ensure service continuity, you must use this feature to copy the KPI data on the old active MPU to the new active MPU.
# Copy the KPI data on the standby MPU to the active MPU.
[Sysname] kpi copy-file to active-mpu
kpi file save-interval
Use kpi file save-interval to specify the interval for saving KPI files to the storage media.
Use undo kpi file save-interval to restore the default.
kpi file save-interval interval
KPI files are saved to the storage media at an interval of 1440 minutes.
interval: Specifies the interval for saving KPI files to the storage media, in the range of 60 to 65535 minutes.
# Set the interval for saving KPI files to the storage media to 60 minutes.
[Sysname] kpi file save-interval 60
Use kpi file aging threshold remain-disk-size to set the remaining storage media capacity threshold for triggering KPI file aging.
Use undo kpi file aging threshold remain-disk-size to restore the default.
kpi file aging threshold remain-disk-size size
The remaining storage media capacity threshold for triggering KPI file aging is 128 MB.
size: Specifies the remaining storage media capacity threshold in the range of 128 to 65535 MB.
When the remaining storage media capacity is less than the specified threshold, the device automatically deletes the earliest saved KPI files until the remaining capacity is greater than or equal to the specified threshold.
# Set the remaining storage media capacity threshold for triggering KPI file aging to 1000 MB.
[Sysname] kpi file aging threshold remain-disk-size 1000
Use kpi file aging threshold total-file-size to set the KPI file size threshold for triggering KPI file aging.
Use undo kpi file aging threshold total-file-size to restore the default.
kpi file aging threshold total-file-size size
The KPI file size threshold for triggering KPI file aging is 128 MB.
size: Specifies the KPI file size threshold in the range of 32 to 2048 MB.
When the total KPI file size on the storage media exceeds the specified threshold, the device automatically deletes the earliest saved KPI files until the total KPI file size is less than or equal to the specified threshold.
# Set the KPI file size threshold for triggering KPI file aging to 500 MB.
[Sysname] kpi file aging threshold total-file-size 500
kpi file directory
Use kpi file directory to specify the KPI file directory.
kpi file directory dir-name
KPI files are stored in the flash:/kpi directory.
dir-name: Specifies a directory, a string of 1 to 64 characters.
# Set the KPI file directory to flash:/.
[Sysname] kpi file directory flash:/
EAI commands
Available indicators for EAI
Table 4 Available indicators for EAI
Class |
Module |
Object |
Indicator |
Device-resource |
FWD-RES |
Card |
ARP entry usage |
FWD-RES |
Card |
MAC entry usage |
FWD-RES |
Card |
FIB entry usage |
FWD-RES |
Card |
ND entry usage |
FWD-RES |
Card |
FWD-RES |
Card |
FWD-RES |
Card |
FWD-RES |
Card |
ACL-RES |
Card |
ACL usage |
STOR-RES |
Card |
Storage usage |
DEV-RES |
Card |
CPU usage |
DEV-RES |
Card |
Memory usage |
eai artificial intelligence
Use eai artificial intelligence to enter the Embedded Artificial Intelligence (EAI) view.
EAI monitoring and prediction are disabled.
You can enable EAI monitoring and prediction only in EAI view. Based on the collected history KPI data, EAI predicts the indicator values by using intelligent algorithms. EAI helps the administrator analyze the trend of key indicators on the device and proactively prevent possible failures.
# Enter EAI view.
[Sysname] eai artificial intelligence
eai monitoring enable
Use eai monitoring enable to enable EAI monitoring.
Use undo eai monitoring enable to disable EAI monitoring.
EAI monitoring is disabled.
EAI view
Based on the collected history KPI data, the device dynamically generates reasonable alarm thresholds and recovery thresholds for the indicators in Table 4.
· When an indicator value is out of the alarm threshold range, the device logs the threshold violation event and reports it to an NMS through SNMP.
· When the indicator value restores to be within the alarm threshold range, the device records the recovery event and reports it to an NMS through SNMP.
# Enable EAI monitoring.
[Sysname-eai] eai monitoring enable
display eai monitoring
eai prediction enable
Use eai prediction enable to enable EAI prediction.
Use undo eai prediction enable to disable EAI prediction.
EAI prediction is disabled.
EAI view
Enabled with this feature, the device dynamically calculates and predicts the indicator values 30 days later based on the history KPI data.
· When the predicted indicator value is out of the alarm threshold range, the device logs the threshold violation event and reports it to an NMS through SNMP.
· When the predicted indicator value restores to be within the alarm threshold range, the device logs the recovery and reports it to an NMS through SNMP.
This feature can help the administrator analyze the trend of key indicators on the device and proactively prevent possible failures.
# Enable EAI prediction.
[Sysname-eai] eai prediction enable
display eai prediction
Use display eai monitoring to display EAI monitoring information.
# Display EAI monitoring information.
<Sysname> display eai monitoring
Indicator : CPU usage
Module : DEV-RES
Monitoring status: On
Chassis : 0 Slot : 2 CPU : 0
Value : 0.4 Status : Normal
Limit : [0.30, 0.80] Recover : [0.40, 0.70]
Chassis : 0 Slot : 3 CPU : 0
Value : 0.5 Status : Normal
Limit : [0.35, 0.85] Recover : [0.40, 0.70]
Table 5 Command output
Indicator |
Indicator name. |
Monitoring status |
Enabling status of EAI monitoring: · On—EAI monitoring is enabled. · Off—EAI monitoring is disabled. |
Chassis |
Chassis number. |
Slot |
Slot number. |
CPU |
CPU number. |
Module |
Module name. |
Object |
Object name. |
Value |
Indicator value. |
Status |
State of the indicator: · Normal—The indicator is within the upper and lower limits. · Above upper limit—The indicator exceeds the upper limit. · Below lower limit—The indicator drops below the lower limit. |
Limit |
Alarm threshold range dynamically generated for the indicator, in the format of [lower limit, upper limit]. |
Recover |
Recovery threshold range dynamically generated for the indicator, in the format of [lower limit, upper limit]. |
Use display eai prediction to display EAI predicted information and history KPI data.
# Display EAI predicted information and history KPI data.
<Sysname> display eai prediction
Module : DEV-RES
Object : chassis.0/slot.1/subslot.0
Chassis : 0 Slot : 1 CPU : 0
No History value Collect time
1 0.7 2022-03-22 17:36:39
2 0.7 2022-03-22 17:28:39
3 0.7 2022-03-22 17:30:39
4 0.7 2022-03-22 17:32:39
5 0.7 2022-03-22 17:34:39
Predicted value in 30 days: 0.7
Table 6 Command output
Chassis |
Chassis number. |
Slot |
Slot number. |
CPU |
CPU number. |
Module |
Module name. |
Object |
Object name. |
Indicator |
Indicator type. |
No |
Number of the entry. |
History value |
Most recent five collected indicator values. |
Collect time |
Time when the most recent five collections happened. |
Predicted value in 30 days |
Predicted indicator value in 30 days. |
