17-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S9825 & S9855 Switch Series Command References-R932x-6W10017-Network Management and Monitoring Command Reference
10-Mirroring commands
10-Mirroring commands 153.21 KB
Port mirroring commands
display mirroring-group
Use display mirroring-group to display mirroring group information.
display mirroring-group { group-id | all | local }
group-id: Specifies a mirroring group by its ID. The value range for this argument is 1 to 6.
all: Specifies all mirroring groups.
local: Specifies local mirroring groups.
Mirroring group information includes the type, status, and content of a mirroring group. It is sorted by mirroring group number.
# Display information about all mirroring groups.
<Sysname> display mirroring-group all
Mirroring group 1:
    Type: Local
    Status: Active
    Mirroring port: HundredGigE1/0/1 Inbound
    Monitor port: HundredGigE1/0/2 truncation
Mirroring group 2:
    Type: Local
    Status: Active
                  Encapsulation: Destination IP address 1.1.1.1
                                 Source IP address 2.2.2.2
                                 DSCP 1
                                 VLAN 2
                                 VRF Instance 3
                                 Destination MAC address 0011-0200-0211
Mirroring group
Number of the mirroring group.
Type of the mirroring group:
Local.
Status
Status of the mirroring group:
·     Active—The mirroring group has taken effect.
·     Incomplete—The mirroring group configuration is not complete and does not take effect.
Mirroring port
Source port.
Mirroring CPU
Source CPU.
Monitor port
Destination port.
Encapsulation
Encapsulation parameters of the mirrored packets.
Destination IP address in the outer header of the GRE-encapsulated mirrored packets.
Source IP address
Source IP address in the outer header of the GRE-encapsulated mirrored packets.
DSCP
DSCP value in the outer header of the GRE-encapsulated mirrored packets.
VLAN
VLAN in the outer header of the GRE-encapsulated mirrored packets.
VRF Instance
VPN instance whose routing table is used to direct forwarding of the mirrored packets.
Destination MAC address in the outer header of the GRE-encapsulated mirrored packets.
mirroring-group
Use mirroring-group to create a mirroring group.
Use undo mirroring-group to delete mirroring groups.
mirroring-group group-id local
undo mirroring-group { group-id | all | local }
No mirroring groups exist.
group-id: Specifies a mirroring group ID. The value range for this argument is 1 to 6.
# Create local mirroring group 1.
[Sysname] mirroring-group 1 local
mirroring-group mirroring-cpu
Use mirroring-group mirroring-cpu to configure source CPUs for a mirroring group.
Use undo mirroring-group mirroring-cpu to remove source CPUs from a mirroring group.
mirroring-group group-id mirroring-cpu slot slot-number-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-cpu slot slot-number-list
No source CPU is configured for a mirroring group.
group-id: Specifies a mirroring group by its number. The specified mirroring group must already exist. The value range for this argument is 1 to 6.
slot slot-number-list: Specifies a space-separated list of up to eight IRF member number items. The value is fixed at 1.
both: Mirrors both received and sent packets.
inbound: Mirrors only received packets.
outbound: Mirrors only sent packets.
You can configure source CPUs only for local mirroring groups and remote source groups.
# Create local mirroring group 1 to monitor the inbound traffic of the CPU on the specified slot.
[Sysname] mirroring-group 1 mirroring-cpu slot 1 inbound
mirroring-group
mirroring-group mirroring-port (interface view)
Use mirroring-group mirroring-port to configure a port as a source port for a mirroring group.
Use undo mirroring-group mirroring-port to restore the default.
mirroring-group group-id mirroring-port { both | inbound | outbound }
undo mirroring-group group-id mirroring-port
A port does not act as a source port for any mirroring groups.
Interface view
A source port cannot be used as a monitor port of any mirroring group.
# Create local mirroring group 1 to monitor the bidirectional traffic of the port HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] mirroring-group 1 mirroring-port both
mirroring-group
mirroring-group mirroring-port (system view)
Use mirroring-group mirroring-port to configure source ports for a mirroring group.
Use undo mirroring-group mirroring-port to remove source ports from a mirroring group.
mirroring-group group-id mirroring-port interface-type interface-number { both | inbound | outbound }
undo mirroring-group group-id mirroring-port interface-type interface-number
No source port is configured for a mirroring group.
# Create local mirroring group 1 to monitor the bidirectional traffic of HundredGigE 1/0/1.
[Sysname] mirroring-group 1 mirroring-port hundredgige 1/0/1 both
mirroring-group
mirroring-group monitor-egress
Use mirroring-group monitor-egress to configure the egress port for a remote source group.
Use undo mirroring-group monitor-egress to restore the default.
In system view:
mirroring-group group-id monitor-egress interface-type interface-number
undo mirroring-group group-id monitor-egress interface-type interface-number
In interface view:
No egress port is configured for a remote source group.
Interface view
group-id: Specifies a mirroring group by its ID in the range of 1 to 8.
interface-type interface-number: Specifies a port by its type and number.
You can configure egress ports only for remote source groups.
For port mirroring to work correctly, disable the following features on the egress port of a mirroring group:
·     Spanning tree.
·     Static ARP.
·     MAC address learning.
The member port of an existing mirroring group cannot be configured as an egress port.
The member port of an aggregate interface cannot be configured as an egress port.
# Create remote source group 1. Configure HundredGigE 1/0/1 as its egress port in system view.
[Sysname] mirroring-group 1 remote-source
[Sysname] mirroring-group 1 monitor-egress  hundredgige 1/0/1
# Create remote source group 2. Configure HundredGigE 1/0/2 as its egress port in interface view.
[Sysname] mirroring-group 2 remote-source
[Sysname] interface  hundredgige 1/0/2
[Sysname-HundredGigE1/0/2] mirroring-group 2 monitor-egress
mirroring-group
mirroring-group monitor-port (interface view)
Use mirroring-group monitor-port to configure a port as the monitor port for a mirroring group.
Use undo mirroring-group monitor-port to restore the default.
mirroring-group group-id monitor-port [ destination-ip destination-ip-address source-ip source-ip-address [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name ] * [ destination-mac mac-address ] | destination-mac mac-address ]
undo mirroring-group group-id monitor-port
A port does not act as the monitor port for any mirroring groups.
Interface view
destination-ip destination-ip-address: Specifies the destination IP address for the mirrored packets.
source-ip source-ip-address: Specifies the source IP address for the mirrored packets.
dscp dscp-value: Specifies the DSCP value for the mirrored packets. The dscp-value argument can be a number in the range of 0 to 63 or a keyword in Table 2. The default DSCP value is 0.
Table 2 DSCP keywords and values
Keyword
DSCP value in binary
DSCP value in decimal
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
default
000000
0
ef
101110
46
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094 for the mirrored packets.
vrf-instance vrf-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. The mirrored packets will be forwarded based on the routing table of the specified VPN instance.
destination-mac mac-address: Specifies the destination MAC address for mirrored packets. The mac-address argument is in the format of H-H-H. If you do not specify this option, the device uses the destination IP address to obtain the destination MAC address. If the destination MAC address cannot be obtained, the default MAC address 000f-e241-5e5b is used.
Only when you configure Layer 3 remote port mirroring through encapsulation parameters, you can configure the following encapsulation parameters for mirrored packets sent to the monitor port:
·     Destination IP address, which is the IP address of the remote data monitoring device.
·     Source IP address.
·     Optional encapsulation parameters, including the DSCP value, VLAN, VPN instance, and destination MAC address.
The mirrored packet is first encapsulated in a GRE packet with a protocol number of 0x88BE. The GRE packet is then encapsulated in a delivery protocol by using the configured encapsulation parameters and routed to the final destination.
Do not enable the spanning tree feature on the monitor port of a mirroring group.
A Layer 2 or Layer 3 aggregate interface cannot be configured as the monitor port for a mirroring group.
An aggregation member port cannot be configured as the monitor port.
Use a monitor port only for port mirroring, so the data monitoring device receives and analyzes only the mirrored traffic.
The member port of an existing mirroring group cannot be configured as a monitor port.
The member port of an aggregate interface cannot be configured as a monitor port.
# Create local mirroring group 1 and configure HundredGigE 1/0/1 as its monitor port.
[Sysname-HundredGigE1/0/1] mirroring-group 1 monitor-port
# Create local mirroring group 3. Specify HundredGigE 1/0/1 as its monitor port and configure the encapsulation parameters including the source and destination IP addresses, DSCP value, VLAN, and VPN instance for the mirrored packets.
[Sysname] mirroring-group 3 local
[Sysname-HundredGigE1/0/1] mirroring-group 3 monitor-port destination-ip 1.1.1.1 source-ip 3.3.3.3 dscp 1 vlan 1 vrf-instance 122
mirroring-group
mirroring-group monitor-port (system view)
Use mirroring-group monitor-port to configure the monitor ports for a mirroring group.
Use undo mirroring-group monitor-port to remove the monitor ports from a mirroring group.
mirroring-group group-id monitor-port interface-type interface-number [ destination-ip destination-ip-address source-ip source-ip-address [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name ] * [ destination-mac mac-address ] | destination-mac mac-address ]
undo mirroring-group group-id monitor-port interface-type interface-number
No monitor port is configured for a mirroring group.
dscp dscp-value: Specifies the DSCP value for the mirrored packets. The dscp-value argument can be a number in the range of 0 to 63 or a keyword in Table 3. The default DSCP value is 0.
Table 3 DSCP keywords and values
Keyword
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
default
000000
0
ef
101110
46
A Layer 2 and Layer 3 aggregate interface cannot be configured as the monitor port for a mirroring group.
Use a monitor port only for port mirroring, so the data monitoring device receives only the mirrored traffic.
[Sysname] mirroring-group 1 monitor-port hundredgige 1/0/1
# Create local mirroring group 3 and configure ports HundredGigE 1/0/1 through HundredGigE 1/0/3 and HundredGigE 1/0/5 as its monitor ports.
[Sysname] mirroring-group 3 monitor-port hundredgige 1/0/1 to hundredgige 1/0/3 hundredgige 1/0/5
# Create local mirroring group 4. Specify HundredGigE 1/0/1 as its monitor port and configure the encapsulation parameters including the source and destination IP addresses, DSCP value, VLAN, and VPN instance for the mirrored packets.
[Sysname] mirroring-group 4 local
[Sysname] mirroring-group 4 monitor-port hundredgige 1/0/1 destination-ip 1.1.1.1 source-ip 3.3.3.3 dscp 1 vlan 1 vrf-instance 122
mirroring-group
mirroring-group remote-probe vlan
Use mirroring-group remote-probe vlan to specify a VLAN as the remote probe VLAN for a mirroring group.
Use undo mirroring-group remote-probe vlan to restore the default.
mirroring-group group-id remote-probe vlan vlan-id
undo mirroring-group group-id remote-probe vlan vlan-id
No remote probe VLAN is configured for a mirroring group.
vlan-id: Specifies a VLAN by its ID.
You can configure remote probe VLANs only for remote source groups and remote destination groups.
When a VLAN is configured as a remote probe VLAN, use the VLAN for port mirroring exclusively.
The remote mirroring groups on the source device and destination device must use the same remote probe VLAN.
Only a static VLAN that already exists can be configured as a remote probe VLAN. A VLAN can be configured as the remote probe VLAN for only one mirroring group.
To delete a VLAN that is configured as a remote probe VLAN, remove the remote probe VLAN configuration first.
# Create remote source group 1 and configure VLAN 10 as its remote probe VLAN.
[Sysname] mirroring-group 1 remote-probe vlan 10
# Create remote destination group 2 and configure VLAN 20 as its remote probe VLAN.
[Sysname] mirroring-group 2 remote-destination
[Sysname] mirroring-group 2 remote-probe vlan 20
mirroring-group
Flow mirroring commands
mirror-to cpu
Use mirror-to cpu to configure a mirroring action that mirrors traffic to the CPU.
Use undo mirror-to cpu to delete the mirroring action that mirrors traffic to the CPU.
mirror-to cpu
undo mirror-to cpu
No mirroring action exists to mirror traffic to the CPU.
Traffic behavior view
# Create traffic behavior 1 and configure the action of mirroring traffic to the CPU for the traffic behavior.
[Sysname] traffic behavior 1
[Sysname-behavior-1] mirror-to cpu
mirror-to ifa-processor
Use mirror-to ifa-processor to configure a mirroring action that mirrors traffic to the in-band network telemetry (INT) processor.
Use undo mirror-to ifa-processor to delete the mirroring action that mirrors traffic to the INT processor.
mirror-to ifa-processor [ sampler sampler-name ]
No mirroring action exists to mirror traffic to the INT processor.
sampler sampler-name: Specifies a sampler by its name. The sampler-name argument is a case-insensitive string of 1 to 31 characters. If you do not specify this option, packets are not sampled, and all matching packets are mirrored.
A sampler selects a packet from sequential packets. Flow mirroring uses the sampler to limit the volume of traffic to be mirrored. Flow mirroring supports using a sampler that has not been created. If you specify a sampler for a mirroring action multiple times, the most recent configuration takes effect. For more information about samplers, see Network Management and Monitoring Configuration Guide.
Example
# Create traffic behavior 1 and configure the action of mirroring traffic to the INT processor. Specify sampler samp for the mirroring action.
[Sysname-behavior-1] mirror-to ifa-processor sampler samp
sampler
mirror-to interface
Use mirror-to interface to configure a mirroring action that mirrors traffic to an interface.
Use undo mirror-to interface to delete a mirroring action that mirrors traffic to an interface.
Syntax I
mirror-to interface interface-type interface-number [ sampler sampler-name ] [ truncation ] [ { destination-ip destination-ip-address source-ip source-ip-address | destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address } [ erspanv3 ] [ dscp dscp-value | vlan vlan-id ] * ] [ destination-mac mac-address ] ]
undo mirror-to interface interface-type interface-number
Syntax II
mirror-to interface { destination-ip destination-ip-address source-ip source-ip-address | destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address } [ erspanv3 ]  [ sampler sampler-name ] [ truncation ] [ dscp dscp-value | vlan vlan-id ] * [ destination-mac mac-address ]
undo mirror-to interface { destination-ip destination-ip-address source-ip source-ip-address | destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address }
No mirroring actions exist to mirror traffic to interfaces.
truncation: Truncates the mirrored packets to retain only the first 192 bytes of each packet.
destination-ipv6 destination-ipv6-address: Specifies the destination IPv6 address for the mirrored packets.
source-ipv6 source-ipv6-address: Specifies the source IPv6 address for the mirrored packets.
erspanv3: Uses the ERSPANv3 encapsulation format for mirrored packets. This keyword is supported only on the S9855 Switch Series.
dscp dscp-value: Specifies the DSCP value for the mirrored packets. The dscp-value argument can be a number in the range of 0 to 63 or a keyword in Table 4.
Table 4 DSCP keywords and values
Keyword
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
default
000000
0
ef
101110
46
destination-mac mac-address: Specifies the destination MAC address for mirrored packets sent to the interface. The mac-address argument is in the format of H-H-H. If you do not specify this option, the device uses the destination IP address to dynamically get the destination MAC address for the mirrored packets.
You can execute this command multiple times for a traffic behavior to mirror traffic to different interfaces.
You can mirror traffic to a maximum of four Ethernet interfaces or Layer 2 aggregate interfaces. If more than four interfaces are configured, all the interfaces configured by using the mirror-to interface command do not take effect.
A sampler selects a packet from sequential packets. Flow mirroring uses a sampler to limit the volume of traffic to be mirrored. It supports using a sampler that has not been created. If you specify a sampler for a mirroring action multiple times, the most recent configuration takes effect. For more information about samplers, see Network Management and Monitoring Configuration Guide.
The encapsulation parameters for the mirrored packets are available only when the mirrored packets are sent out of Ethernet interfaces.
If you use syntax I, traffic is mirrored to the specified interface.
If you use syntax II, traffic is processed as follows:
1.     The device encapsulates the traffic with the specified parameters.
2.     The device looks up the source IP address and destination IP address of the traffic in the routing table and forwards the traffic based on the matching route. The outgoing interface of the route is the destination interface of the mirrored traffic.
Through configuring load sharing in the routing protocols, you can specify multiple destination interfaces for the mirrored traffic. When the current mirroring destination interface fails, the mirrored traffic is forwarded to the outgoing interface re-calculated by the routing protocols.
# Create traffic behavior 1 and configure the action of mirroring traffic to HundredGigE 1/0/1 for the traffic behavior.
[Sysname-behavior-1] mirror-to interface hundredgige 1/0/1
# Create behavior 1, and configure the action of mirroring traffic to an interface as follows:
·     Configure the action to truncate mirrored packets.
·     Encapsulate the mirrored traffic with destination IP address 1.1.1.1 and source IP address 2.2.2.2.
[Sysname-behavior-1] mirror-to interface truncation destination-ip 1.1.1.1 source-ip 2.2.2.2
mirroring erspanv3 switch-id
Use mirroring erspanv3 switch-id to configure the switch ID in ERSPANv3 mirrored packets.
Use undo mirroring erspanv3 switch-id to restore the default.
This command is supported only on the S9855 Switch Series.
mirroring erspanv3 switch-id switch-id
The switch ID in ERSPANv3 mirrored packets is 4.
switch-id: Specifies the switch ID in ERSPANv3 mirrored packets, in the range of 0 to 1023.
In the Layer 3 remote flow mirroring scenario, when packets from multiple source devices are mirrored to the same data monitoring device, the data monitoring device cannot identify the mappings between switch IDs in mirrored packets and source devices by default. As a result, the data mirroring device cannot correctly identify the source device of each mirrored packet. In this case, the administrator can configure this feature on the device to map the switch ID encapsulated in the mirrored packets to the device. Then, the data monitoring device can identify the source device of these mirrored packets.
# Configure the switch ID in ERSPANv3 mirrored packets as 1.
[Sysname] mirroring erspanv3 switch-id 1
