08-MPLS Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S9825 & S9855 Switch Series Command References-R932x-6W10008-MPLS Command Reference
05-Static CRLSP commands
05-Static CRLSP commands 73.56 KB
The static CRLSP feature is not available on the S9825 switch series.
To use the static CRLSP feature on an MPLS-capable device, set the hardware resource mode to the routing mode by using the hardware-resource switch-mode command. For more information about this command, see hardware resource management commands in System Management Command Reference.
display mpls static-cr-lsp
Use display mpls static-cr-lsp to display information about static CRLSPs.
display mpls static-cr-lsp [ lsp-name lsp-name ] [ verbose ]
lsp-name lsp-name: Displays information about the static CRLSP specified by its name, a case-sensitive string of 1 to 15 characters. If you do not specify a static CRLSP, this command displays information about all static CRLSPs.
verbose: Displays detailed information about static CRLSPs. If you do not specify this keyword, the command displays brief information about static CRLSPs.
# Display brief information about static CRLSPs.
<Sysname> display mpls static-cr-lsp
Name            LSR Type    In/Out Label   Out Interface        State
static-cr-lsp-1 Ingress     Null/20        Vlan10               Up
Name
Name of the static CRLSP.
LSR Type
LSR type of the local node on the static CRLSP: Ingress, Transit, or Egress.
In/Out Label
Incoming label/outgoing label.
Out Interface
Output interface.
Current state of the static CRLSP:
·     Down—The static CRLSP is not available.
·     Up—The static CRLSP is available.
·     Idle—The incoming label of the static CRLSP is not available.
·     Dup—The incoming label of the static CRLSP is being used by a static LSP or a static PW.
# Display detailed information about static CRLSPs.
<Sysname> display mpls static-cr-lsp verbose
LSP Name       : Tunnel0
LSR Type       : Ingress
In-Label       : Null
Out-Label      : 60
Out-Interface  : Vlan10
Nexthop        : 20.1.1.2
Class Type     : CT0
Bandwidth      : 0 kbps
LSP State      : Up
LSP Name
LSR Type
In-Label
Incoming label.
Out-Label
Outgoing label.
Out-Interface
Output interface.
Nexthop
Next hop address.
Class Type
Class type of the static CRLSP.
Bandwidth
Bandwidth required by the static CRLSP, in kbps.
LSP State
·     Duplicate—The incoming label of the static CRLSP is being used by a static LSP or a static PW.
static-cr-lsp egress
static-cr-lsp ingress
static-cr-lsp transit
Use static-cr-lsp egress to configure the egress node of a static CRLSP.
Use undo static-cr-lsp egress to delete the egress node configuration of a static CRLSP.
static-cr-lsp egress lsp-name in-label in-label-value
undo static-cr-lsp egress lsp-name
No static CRLSPs exist.
lsp-name: Specifies a name for the static CRLSP, a case-sensitive string of 1 to 67 characters.
in-label in-label-value: Specifies an incoming label. The value range for the incoming label is 16 to 15999.
A static CRLSP must have a different incoming label than an existing static LSP, static SRLSP, or static PW. If the same incoming label is specified, label conflict occurs and the static CRLSP cannot be configured.
# On the egress node, configure a static CRLSP with name static-te-1 and incoming label 233.
[Sysname] static-cr-lsp egress static-te-1 in-label 233
Use static-cr-lsp ingress to configure the ingress node of a static CRLSP.
Use undo static-cr-lsp ingress to delete the ingress node configuration of a static CRLSP.
static-cr-lsp ingress lsp-name { nexthop ip-address | outgoing-interface interface-type interface-number } out-label out-label-value [ bandwidth [ ct0 ] bandwidth-value ]
undo static-cr-lsp ingress lsp-name
nexthop ip-address: Specifies the next hop IP address. The address cannot be a public IP address on the local device.
outgoing-interface interface-type interface-number: Specifies an outgoing interface by its type and number. The specified interface must be a P2P interface.
out-label out-label-value: Specifies an outgoing label. The value range for the out-label-value argument is 0, 3, and 16 to 1048575.
bandwidth: Specifies the CT and required bandwidth for the static CRLSP. If you do not specify this keyword, the bandwidth required by the static CRLSP is 0 kbps.
ct0: Specifies CT 0 for the static CRLSP. The static CRLSP always belongs to CT 0, regardlless of whether the ct0 keyword is specified or not.
bandwidth-value: Specifies the bandwidth required by the static CRLSP, in the range of 1 to 4294967295 kbps. The default is 0 kbps.
# Configure a static CRLSP on the ingress node: specify its name as static-te-2, next hop IP address as 202.55.25.33, outgoing label as 237, CT as CT 0, and required bandwidth as 20 kbps.
[Sysname] static-cr-lsp ingress static-te-2 nexthop 202.55.25.33 out-label 237 bandwidth ct0 20
Use static-cr-lsp transit to configure a transit node for a static CRLSP.
Use undo static-cr-lsp transit to delete the transit node configuration of a static CRLSP.
static-cr-lsp transit lsp-name in-label in-label-value { nexthop ip-address | outgoing-interface interface-type interface-number } out-label out-label-value [ bandwidth [ ct0 ] bandwidth-value ]
undo static-cr-lsp transit lsp-name
ct0: Specifies CT 0 for the static CRLSP. The static CRLSP always belongs to CT 0, regardless of whether you specify the ct0 keyword or not.
# Configure a static CRLSP on the transit node: specify its name as static-te-3, incoming label as 123, next hop IP address as 1.1.1.1, outgoing label as 253, CT as CT 0, and required bandwidth as 20 kbps.
[Sysname] static-cr-lsp transit static-te-3 in-label 123 nexthop 1.1.1.1 out-label 253 bandwidth ct0 20
