05-Layer 3—IP Services Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S9825 & S9855 Switch Series Command References-R932x-6W10005-Layer 3—IP Services Command Reference
04-IP forwarding basics commands
04-IP forwarding basics commands 75.79 KB
Basic IP forwarding commands
display fib
Use display fib to display FIB entries.
display fib [ vpn-instance vpn-instance-name ] [ ip-address [ mask | mask-length ] ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display the FIB entries for the public network, do not specify any VPN instance.
ip-address: Displays the FIB entry that matches the specified destination IP address.
mask: Specifies the mask for the IP address.
mask-length: Specifies the mask length for the IP address. The value range is 0 to 32.
If you specify an IP address without a mask or mask length, this command displays the longest matching FIB entry.
If you specify an IP address and a mask or mask length, this command displays the exactly matching FIB entry.
# Display all FIB entries of the public network.
<Sysname> display fib
Route destination count: 5
Directly-connected host count: 0
Flag:
  U:Usable    G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
  R:Relay     F:FRR
Destination/Mask   Nexthop         Flag     OutInterface/Token       Label
0.0.0.0/32         127.0.0.1       UH       InLoop0                  Null
1.1.1.0/24         192.168.126.1   USGF     M-GE0/0/0                Null
127.0.0.0/8        127.0.0.1       U        InLoop0                  Null
127.0.0.0/32       127.0.0.1       UH       InLoop0                  Null
127.0.0.1/32       127.0.0.1       UH       InLoop0                  Null
# Display the FIB entries for VPN vpn1.
<Sysname> display fib vpn-instance vpn1
Route destination count: 8
Flag:
  R:Relay     F:FRR
20.20.20.0/24      20.20.20.25     U        M-GE0/0/0                Null
20.20.20.0/32      20.20.20.25     UBH      M-GE0/0/0                Null
20.20.20.25/32     127.0.0.1       UH       InLoop0                  Null
20.20.20.25/32     20.20.20.25     H        M-GE0/0/0                Null
20.20.20.255/32    20.20.20.25     UBH      M-GE0/0/0                Null
20.20.20.255/32    1000:2000:3000:4000:5000:6000:7000:8000 UBH      MGE0
/0/0                Null
# Display the FIB entries matching the destination IP address 10.2.1.1.
<Sysname> display fib 10.2.1.1
FIB entry count: 1
Flag:
  R:Relay     F:FRR
10.2.1.1/32        127.0.0.1       UH       InLoop0                  Null
Number of route destination addresses.
Number of directly connected hosts learned by features such as ARP.
FIB entry count
Total number of FIB entries.
Destination/Mask
Destination address and the mask length.
Nexthop
Next hop address.
Flag
Flags of routes:
·     U—Usable route.
·     G—Gateway route.
·     H—Host route.
·     B—Blackhole route.
·     D—Dynamic route.
·     S—Static route.
·     R—Relay route.
·     F—Fast reroute.
OutInterface/Token
Output interface/LSP index number.
Label
Inner label.
forwarding split-horizon
Use forwarding split-horizon to enable split horizon forwarding.
Use undo forwarding split-horizon to disable split horizon forwarding.
Split horizon forwarding is disabled.
This feature prevents IPv4, IPv6, and MPLS packets from being forwarded out of the physical interface on which they were received, avoiding network loops.
When you use the forwarding split-horizon command, following these restrictions and guidelines:
·     To enable split horizon forwarding globally, use this command in system view.
·     To enable split horizon forwarding on a per-interface basis, use this command in interface view.
·     Split horizon forwarding takes effect on an interface as long as it is enabled globally or on the interface.
·     To disable split horizon forwarding on an interface, disable this feature in both system view and interface view.
This feature is available only on physical interfaces. Logical interfaces, including virtual interfaces and aggregate interfaces, do not support this feature.
In VXLAN networking, enabling split horizon forwarding globally (forwarding split-horizon) might lead to network disconnection. You can configure this feature under the AC port.
When you enable horizontal splitting in system view, port isolation will apply to Layer 3 packets. For information on port isolation, see Layer 2LAN Switching Configuration Guide.
# Enable split horizon forwarding.
[Sysname] forwarding split-horizon
ip forwarding
Use ip forwarding to enable IPv4 packet forwarding on an interface that has no IPv4 address configured.
Use undo ip forwarding to disable IPv4 packet forwarding on an interface that has no IPv4 address configured.
ip forwarding
undo ip forwarding
If an interface has no IPv4 address configured, it cannot forward IPv4 packets.
Interface view
On a device that supports both IPv4 and IPv6, the next hop of an IPv4 packet might be an IPv4 address or an IPv6 address. If the output interface has no IPv4 address configured, the interface cannot forward the IPv4 packet. To resolve this issue, execute this command on the interface. This feature allows the interface to forward IPv4 packets even though the interface has no IPv4 address configured.
# Enable IPv4 packet forwarding on VLAN-interface 1 that has no IPv4 address configured.
[Sysname-Vlan-interface1] ip forwarding
packet-drop statistics enable
Use packet-drop statistics enable to enable packet-drop statistics collection on interfaces.
Use undo packet-drop statistics enable to disable packet-drop statistics collection on interfaces.
packet-drop statistics enable [ in-acl | out-acl | in-illegal-interface | in-l2-mtu | out-l2-mtu | in-l3-header-ipv4 | in-l3-nexthop | in-l3-ttl | in-stp-block | out-stp-block | in-same-interface | in-storm-suppression | in-vlan-mismatch | out-vlan-mismatch ] *
undo packet-drop statistics enable [ in-acl | out-acl | in-illegal-interface | in-l2-mtu | out-l2-mtu | in-l3-header-ipv4 | in-l3-nexthop | in-l3-ttl | in-stp-block | out-stp-block | in-same-interface | in-storm-suppression | in-vlan-mismatch | out-vlan-mismatch ] *
The device does not count packet drops on interfaces.
in-acl: Specifies incoming packets dropped by ACL.
out-acl: Specifies outgoing packets dropped by ACL. Only the S9855 series switches support this keyword.
in-illegal-interface: Specifies incoming packets dropped because no egress interface was found or the egress interface was illegal.
in-l2-mtu: Specifies incoming packets dropped because of Layer 2 MTU exceeding.
out-l2-mtu: Specifies outgoing packets dropped because of Layer 2 MTU exceeding. Only the S9855 series switches support this keyword.
in-l3-header-ipv4: Specifies incoming IPv4 packets dropped because of invalid Layer 3 headers, for example, invalid checksum. Only the S9825 series switches support this keyword.
in-l3-nexthop: Specifies incoming packets dropped because the next-hop action is Drop. Only the S9825 series switches support this keyword.
in-l3-ttl: Specifies incoming packets dropped because their TTLs are less than 1.
in-same-interface: Specifies incoming packets dropped because the ingress interface is the same as the egress one.
in-stp-block: Specifies incoming packets dropped because of spanning tree port blocking.
out-stp-block: Specifies outgoing packets dropped because of spanning tree port blocking.
in-storm-suppression: Specifies incoming packets dropped because of broadcast, multicast, or unknown unicast suppression.
in-vlan-mismatch: Specifies incoming packets dropped because of VLAN mismatch.
out-vlan-mismatch: Specifies outgoing packets dropped because of VLAN mismatch. Only the S9855 series switches support this keyword.
This feature takes effect on only physical interfaces.
After you enable this feature, the device collects statistics on specific packet drops on interfaces and reports the statistics to the collector through gRPC.
For the S9825 switch series, if you specify both the in-illegal-interface and in-vlan-mismatch keywords, the packet quantity collected by the in-illegal-interface keyword includes the packet quantity collected by the in-vlan-mismatch keyword.
For the S9825 switch series, the packet statistics collected by the in-illegal-interface keyword includes those collected by the in-acl, in-l3-ttl, in-same-interface, in-l3-nexthop, in-stp-block, and in-vlan-mismatch keywords.
If the broadcast-suppression, multicast-suppression, or unicast-suppression command is used to specify the ratio or kbps keyword, the in-storm-suppression keyword specified in this command does not take effect. The in-storm-suppression packets will be included in incoming packets discarded due to ACL filtering. For more information about broadcast-suppression, multicast-suppression, or unicast-suppression command, see Interface Command Reference.
If you use this command to specify keywords other than in-l2-mtu on the S9855 switch series and perform the following tasks, the current statistics of packet loss will not be reset:
·     Execute the reset counters interface command on the device.
·     Insert or remove modules on an operational Ethernet interface, which causes a change in the port speed.
·     Switch the Layer 2/Layer 3 work mode on an operational Ethernet interface.
·     Execute the shutdown command on an operational Ethernet interface.
If you execute this command on the S9825 switch series or use this command to specify the in-l2-mtu keyword on the S9855 switch series, executing the shutdown command on an operational Ethernet interface does not clear the current packet loss statistics. Performing the following tasks will clear the current packet loss statistics:
For more information about the reset counters interface and shutdown commands, see Interface Command Reference.
# Enable the device to collect statistics on incoming packets dropped because of Layer 2 MTU exceeding.
[Sysname] packet-drop statistics enable in-l2-mtu
