- 04-Layer 2—LAN Switching Command Reference
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-M-LAG commands
- 04-Port isolation commands
- 05-VLAN commands
- 06-QinQ commands
- 07-Loop detection commands
- 08-Spanning tree commands
- 09-LLDP commands
- 10-PFC commands
- 11-Layer 2 forwarding commands
| 00-Preface | 109.80 KB |
Preface
This command reference covers the commands for configuring Layer 2 technologies and features in a LAN switched network.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S9825 & S9855 switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
