02-System Management Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S9825 & S9855 Switch Series Command References-R932x-6W10002-System Management Command Reference
03-Hardware resource management commands
03-Hardware resource management commands 513.03 KB
Hardware resource management commands· 1
display alarm·· 1
display cpu-usage· 1
display cpu-usage configuration· 3
display cpu-usage history· 3
display device· 5
display device manuinfo· 6
display device manuinfo fan· 6
display device manuinfo power 7
display environment 7
display fan· 8
display hardware-resource switch-mode· 9
display memory· 10
display memory dma· 12
display memory-threshold· 13
display memory-threshold dma· 14
display power 15
display resource-monitor 16
display transceiver active-control 17
display transceiver advertising· 18
display transceiver alarm·· 19
display transceiver application· 22
display transceiver diagnosis· 23
display transceiver history performance-collection· 25
display transceiver interface· 28
display transceiver manuinfo· 29
display transceiver status· 30
display transceiver vdm·· 32
fan auto-control-mode· 33
hardware-alarm disable· 34
hardware-resource switch-mode· 35
memory-threshold· 36
memory-threshold dma· 38
memory-threshold usage· 38
monitor cpu-usage enable· 39
monitor cpu-usage interval 40
monitor cpu-usage statistics-interval core· 41
monitor cpu-usage threshold· 42
monitor resend cpu-usage· 43
monitor resend cpu-usage core-interval 43
monitor resend memory-threshold dma· 44
power-supply policy enable· 45
power-supply policy redundant 45
reset transceiver interface· 46
resource-monitor minor resend enable· 47
resource-monitor output 47
resource-monitor resource· 48
shutdown-interval 50
temperature-limit 51
transceiver diagnostic selector 52
transceiver lane enable· 53
transceiver lane equalization· 54
transceiver lane loopback· 56
transceiver lane pattern· 57
transceiver optical-channel frequency· 58
transceiver optical-channel tx-power 59
transceiver performance-collection enable· 59
transceiver performance-collection interval 60
transceiver phony-alarm-disable· 61
transceiver power-mode· 61
transceiver rx-power high-threshold· 62
transceiver rx-power low-threshold· 63
transceiver rx-power change-threshold· 64
transceiver tx-power high-threshold· 65
transceiver tx-power low-threshold· 66
transceiver tx-power change-threshold· 67
display alarm
Use display alarm to display device hardware alarm information.
display alarm [ slot slot-number ]
slot slot-number: Specifies a device by its ID, which is fixed at 1.
# Display device hardware alarm information.
<Sysname> display alarm
Slot CPU Level   Info
1    0   ERROR   faulty
Slot
Slot that generated the alarm. If the alarm was generated by the frame, this field displays a hyphen (-).
Level
Alarm severity. Possible values include ERROR, WARNING, NOTICE, and INFO, in descending order.
Info
Detailed alarm information:
·     faulty—The slot is starting up or faulty.
·     Fan n is absent—The specified fan is absent.
·     Power n is absent—The specified power module is absent.
·     Power n is faulty—The specified power module is faulty.
·     The temperature of sensor n exceeds the lower limit—The temperature of the specified sensor is lower than the low-temperature threshold.
·     The temperature of sensor n exceeds the upper limit—The temperature of the specified sensor is higher than the high-temperature warning threshold.
display cpu-usage
Use display cpu-usage to display the current CPU usage statistics.
display cpu-usage [ control-plane ] [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
control-plane: Displays CPU usage statistics for the control plane.
summary: Displays CPU usage statistics in table form. If you do not specify this keyword, the command displays CPU usage statistics in text form.
cpu cpu-number: Specifies a CPU by its number.
core core-number: Specifies a CPU core by its number.
core all: Specifies all CPU cores.
If two hyphens (--) are displayed for the CPU usage during the most recent 5-second, 1-minute, and 5-minute intervals, the command might fail to obtain data from the database on the device. Try the command later.
# Display the current CPU usage statistics in text form.
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
       1% in last 5 seconds
       1% in last 1 minute
       1% in last 5 minutes
# Display the current CPU usage statistics in table form.
Slot CPU        Last 5 sec        Last 1 min        Last 5 min
1    0          17%               29%               28%
x% in last 5 seconds
Last 5 sec
Average CPU usage during the most recent 5-second interval. If this statistics collection feature is not supported, two hyphens (--) are displayed.
y% in last 1 minute
Last 1 min
Average CPU usage during the most recent 1-minute interval. If this statistics collection feature is not supported, two hyphens (--) are displayed.
z% in last 5 minutes
Last 5 min
Average CPU usage during the most recent 5-minute interval. If this statistics collection feature is not supported, two hyphens (--) are displayed.
Use display cpu-usage configuration to display CPU usage monitoring settings.
# Display the CPU usage monitoring settings.
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current severe alarm threshold is 99%.
Current minor alarm threshold is 79%.
Current recovery threshold is 69%.
CPU usage tracking is enabled.
Sampling interval for CPU usage tracking is 60 seconds.
Use display cpu-usage history to display the historical CPU usage statistics in a coordinate system.
job job-id: Specifies a process by its ID. The value range for job-id is 1 to 2147483647. If you do not specify a process, this command displays the statistics for the entire system's CPU usage (the total CPU usage of all processes). To view the IDs and names of the running processes, use the display process command. For more information, see Network Management and Monitoring Command Reference.
cpu cpu-number: Specifies a CPU by its number. If you specify a process but do not specify a CPU, this command displays the statistics for the default CPU. If you do not specify a process or CPU, this command displays the historical statistics for all CPUs.
After CPU usage tracking is enabled, the system regularly samples CPU usage and saves the samples to a buffer. This command displays the most recent 60 samples in a coordinate system as follows:
·     The vertical axis represents the CPU usage. If a statistic is not a multiple of the usage step, it is rounded up or down to the closest multiple of the usage step. For example, if the CPU usage step is 5%, the statistic 53% is rounded up to 55%, and the statistic 52% is rounded down to 50%.
·     The horizontal axis represents the time.
·     Pound signs (#) indicate the CPU usage. The value on the vertical axis for the topmost pound sign at a specific time represents the CPU usage at that time.
# Display the historical CPU usage statistics.
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
The output shows the following items:
·     Process name. The name SYSTEM represents the entire system.
·     CPU that is holding the process: CPU 0 in slot 1.
·     Historical CPU usage statistics for the entire system during the last 60 minutes.
¡     12 minutes ago—Approximately 5%.
¡     13 minutes ago—Approximately 10%.
¡     14 minutes ago—Approximately 15%.
¡     15 minutes ago—Approximately 10%.
¡     16 and 17 minutes ago—Approximately 5%.
¡     18 minutes ago—Approximately 10%.
¡     19 minutes ago—Approximately 5%.
¡     Other time—2% or lower.
display device
Use display device to display device hardware information.
display device [ flash | usb ] [ slot slot-number | verbose ]
flash: Displays flash memory information.
usb: Displays USB interface information.
verbose: Displays detailed information. If you do not specify this keyword, this command displays brief information.
If you do not specify the flash or usb keyword, this command displays hardware information about the device.
# Display device hardware information.
<Sysname> display device
Slot  Brd Type             Brd Status  Subslot  Sft Ver              Patch Ver
 1    S9855-48CD8D         Master      0        S9855-48CD8D-9319    None
Device type.
Status
Device role.
Sft Ver
Software version of the device.
Patch Ver
Most recently released patch image version that is running on the device. If no patch image is installed, this field displays None.
If both incremental and non-incremental patch images are running on the device, this field displays the most recently released incremental patch image version. For more information about patch image types, see upgrading software in Fundamentals Configuration Guide.
Use display device manuinfo to display hardware electronic label information for the device.
An electronic label contains the permanent configuration information, including the hardware serial number, manufacturing date, MAC address, and vendor name. The data is written to the storage component during hardware debugging or testing. This command displays only part of the electronic label information.
# Display hardware electronic label information for the device.
<Sysname> display device manuinfo
Use display device manuinfo fan to display electronic label information for a fan tray.
display device manuinfo slot slot-number fan fan-id
fan-id: Specifies a fan tray by its ID.
# Display electronic label information for a fan tray.
<Sysname> display device manuinfo fan 1
Use display device manuinfo power to display electronic label information for a power module.
display device manuinfo slot slot-number power power-id
power-id: Specifies a power module by its ID.
# Display electronic label information for a power module.
<Sysname> display device manuinfo slot 1 power 1
display environment
Use display environment to display temperature information.
# Display information about all temperature sensors on the device.
<Sysname> display environment
 System temperature information (degree centigrade):
 Slot  Sensor       Temperature  Lower       Warning       Alarm       Shutdown
 1     hotspot 1    38           10          40            50          100
 1     hotspot 2    42           10          50            80          100
Table 5 Command output
System Temperature information (degree centigrade)
Temperature information (°C).
sensor
Temperature sensor:
hotspot—Hotspot sensor.
Slot
Sensor position.
Temperature
Current temperature.
Lower
Lower temperature limit. If the device does not support this field, this field displays NA.
Warning
Warning temperature threshold. If the device does not support this field, this field displays NA.
Alarm
Alarming temperature threshold. If the device does not support this field, this field displays NA.
Shutdown
Shutdown temperature threshold. When the sensor temperature reaches the limit, the system shuts down automatically. If the device does not support this field, this field displays NA.
display fan
Use display fan to display fan tray operating status information.
display fan [ slot slot-number [ fan-id ] ]
fan-id: Specifies a fan tray by its ID. If you do not specify a fan tray, this command displays operating status information for all fan trays at the specified position.
# Display the operating states of all fan trays.
<Sysname> display fan
Fan Frame 1  State: Normal
 Airflow Direction: Port-to-power
 Fan Frame 2  State: Normal
 Fan Frame 3  State: Normal
 Fan Frame 4  State: Normal
 Fan Frame 5  State: Normal
 Fan Frame 6  State: Normal
Table 6 Command output
Fan tray status:
·     Absent—The slot is not installed with a fan tray.
·     Normal—The fan tray is operating correctly.
·     Fault—The fan tray is faulty.
·     FanDirectionFault—The actual airflow direction is not the preferred direction.
Airflow Direction
Actual airflow direction:
·     Port-to-power—From the port side to the power supply side.
·     Power-to-port—From the power supply side to the port side.
Use display hardware-resource switch-mode to display hardware resource operating mode information for the MAC address table, ARP and ND tables, and routing tables.
# Display the hardware resource operating mode information for the MAC address table, ARP and ND tables, and routing tables. (Applicable to the S9855-40B, S9855-32D, S9855-24B8D, and S9855-48CD8D switches.)
<Sysname> display hardware-resource switch-mode
Switch-mode resource(switch-mode), all supported modes:
  ROUTING           MAC:32K, ARP and ND:28K, FIB ipv4:980000, FIB ipv6(64B):9800
  MAC               MAC:224k, ARP and ND:28K, FIB ipv4:90000, FIB ipv6(64B):9000
0
  Default         Current         Next
  ROUTING         MAC             MAC
# Display the hardware resource operating mode information for the MAC address table, ARP and ND tables, and routing tables. (Applicable to the S9825-128B and S9825-64D switches.)
  ROUTING           MAC:8K, ARP and ND:16K, FIB ipv4:980000, FIB ipv6(64B):9800
00
  MAC               MAC:128k, ARP and ND:16K, FIB ipv4:90000, FIB ipv6(64B):8000
0
  ROUTING         MAC             MAC
Table 7 Command output
Hardware resource operating modes for the MAC address table, ARP and ND tables, and routing tables supported by the device.
ROUTING
ROUTING mode.
MAC
MAC mode.
Default hardware resource operating mode information for the MAC address table, ARP and ND tables, and routing tables.
Current
Current hardware resource operating mode information for the MAC address table, ARP and ND tables, and routing tables.
Next
Hardware resource operating mode information for the MAC address table, ARP and ND tables, and routing tables at the next device startup.
display memory
Use display memory to display memory usage information.
summary: Displays brief information about memory usage. If you do not specify this keyword, the command displays detailed information about memory usage.
If two hyphens (--) are displayed for all the fields in a line of the output, the command might fail to obtain data from the database on the device. Try the command later.
# Display detailed memory usage information.
<Sysname> display memory
Memory statistics are measured in KB:
Slot 0:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:      16335164   4145632  12189532         0      8596   2472508       77.5%
-/+ Buffers/Cache:   1664528  14670636
Swap:            0         0         0
Container memory statistics are measured in KB:
Slot 0:
             Total      Used      Free  UsageRatio
Mem:      16335164   2357588  12189532       14.4%
# Display brief memory usage information.
<Sysname> display memory summary
Slot CPU        Total      Used      Free  Buffers    Caches FreeRatio
   0   0     16335164   4144720  12190444     8596   2472508     77.5%
Slot CPU        Total      Used      Free  UsageRatio
   0   0     16335164   2358048  12190444       14.4%
Table 8 Command output
Memory usage information on the physical device, in KB.
Mem
Memory usage information.
Total
Total size of the physical memory space that can be allocated.
The memory space is virtually divided into two parts. Part 1 is solely used for kernel code and kernel management functions. Part 2 can be allocated and used for such tasks as running service modules and storing files. The size of part 2 equals the total size minus the size of part 1.
Used
Used physical memory.
Free
Free physical memory.
Shared
Physical memory shared by processes.
If this field is not supported, two hyphens (--) are displayed.
Buffers
Physical memory used for buffers.
Cached
Caches
Physical memory used for caches.
FreeRatio
Free memory ratio.
-/+ Buffers/Cache
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications.
-/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications.
Swap
Memory space for swapping.
Container memory usage information, including:
·     Total—Total size of the physical memory space that can be allocated in the Comware container, in KB.
·     Used—Used physical memory in the Comware container, in KB.
·     Free—Free physical memory in the Comware container, in KB.
·     UsageRatio—Free physical memory usage in the Comware container.
display memory dma
Use display memory dma to display DMA memory usage information.
display memory dma [ slot slot-number [ cpu cpu-number ] ]
# Display DMA memory usage information for slot 1.
<System> display memory dma slot 1
DMA memory statistics measured in KB on slot 1:
Total        Used         Free         FreeRatio
16384        6140         10244        63%
Table 9 Command output
Total
Total size of the DMA memory space, including the free and used DMA memory.
Used
Used DMA memory.
Free
Free DMA memory.
FreeRatio
Free DMA memory ratio.
Use display memory-threshold to display memory alarm thresholds and statistics.
For more information about memory usage notifications, see log information containing MEM_EXCEED_THRESHOLD or MEM_BELOW_THRESHOLD.
# Display memory alarm thresholds and statistics.
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free memory threshold:
    Minor: 256M
    Severe: 192M
    Critical: 128M
    Normal: 320M
Current memory state: Normal
Event statistics:
 [Back to normal state]
    First notification: 0.0
    Latest notification: 0.0
    Total number of notifications sent: 0
 [Enter minor low-memory state]
    First notification at: 0.0
    Latest notification at: 0.0
 [Back to minor low-memory state]
 [Enter severe low-memory state]
 [Back to severe low-memory state]
 [Enter critical low-memory state]
Use display memory-threshold dma to display DMA memory alarm information.
display memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
# Display DMA memory alarm information.
<Sysname> display memory-threshold dma
Free DMA memory thresholds:
    Critical: 2048KB
    Normal: 4096KB
Current DMA memory state: Normal
Free memory event statistics:
 [Entered to critcal state]
    First notificatio: 0.0
display power
Use display power to display power module information.
display power [ slot slot-number [ power-id ]
power-id: Specifies a power module by its ID. If you do not specify a power module, this command displays information about all power modules at the specified position.
# Display brief power module information.
<Sysname> display power
Slot 1:
 Input Power: 99(W)
 PowerID State         Mode   Current(A)  Voltage(V)  Power(W)  FanDirection
 1       Normal        AC        5.40       12.35        66     PowerToPort
 2       Normal        AC        2.85       10.00        33     PortToPower
Table 10 Command output
Input Power
Rated power.
PowerID
Power module ID.
Power module status.
·     Absent—The slot is not installed with a power module.
·     Fault—The power module is faulty.
·     Normal—The power module is operating correctly.
Mode
Mode of the power module:
·     AC—AC power module.
·     DC—DC power module.
Current(A)
Output current of the power module, in amperes.
Voltage(V)
Output voltage of the power module, in volts.
Power(W)
Output power of the power module, in watts.
FanDirection
Airflow direction of the power module:
·     PowerToPort—From the power module side to the port side.
·     PortToPower—From the port side to the power module side.
Use display resource-monitor to display resource monitoring information.
display resource-monitor [ resource resource-name ] [ slot slot-number [ cpu cpu-number ] ]
resource resource-name: Specifies a resource type by its name.
# Display ARP resource monitoring information.
<Sysname> display resource-monitor resource arp
Minor alarms resending: Enabled
Slot 1:
Resource                         Minor Severe Free/Total
                                 (%)   (%)    (absolute)
arp                              50    20     90095/90098
Table 11 Command output
Status of the minor resource depletion alarm resending feature, Enabled or Disabled.
Resource
Monitored resource type.
Minor
Minor resource depletion threshold, in percentage.
Severe
Severe resource depletion threshold, in percentage.
Free/Total
(absolute)
Numbers of available resources and total resources, in absolute values.
Use display transceiver active-control to display active control information of a 400G transceiver module.
display transceiver active-control interface [ interface-type interface-number ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command applies to all interfaces.
# Display active control information of the 400G transceiver module in FourHundredGigE 1/0/1.
<Sysname> display transceiver active-control interface fourhundredgige 1/0/1
FourHundredGigE1/0/1 transceiver active-control setting information:
Current working mode     :400G-SR8
  Lane   LowestHostLane   RxPre-Cursor    RxPost-Cursor   RxAmplitude
  Lane1  Lane1            0.5 dB          1 dB            100-400 mV
  Lane2  Lane1            0.5 dB          1 dB            100-400 mV
  Lane3  Lane1            0.5 dB          1 dB            100-400 mV
  Lane4  Lane1            0.5 dB          1 dB            100-400 mV
  Lane5  Lane5            0.5 dB          1 dB            100-400 mV
  Lane6  Lane5            0.5 dB          1 dB            100-400 mV
  Lane7  Lane5            0.5 dB          1 dB            100-400 mV
  Lane8  Lane5            0.5 dB          1 dB            100-400 mV
Table 12 Command output
Current operating mode of the transceiver module.
Lane
Lane number.
LowestHostLane
Lowest-numbered host lane in the lane group to which the lane belongs.
RxPre-Cursor
Rx output equalization pre-cursor.
RxPost-Cursor
Rx output equalization post-cursor.
RxAmplitude
Rx output amplitude.
Use display transceiver advertising to display advertising information of 400G transceiver modules.
display transceiver advertising interface [ interface-type interface-number ]
# Display the advertising information of the 400G transceiver module in interface FourHundredGigE 1/0/1.
<Sysname> display transceiver advertising interface fourhundredgige 1/0/1
FourHundredGigE1/0/1 transceiver advertising information:
  CMIS Revision                      : 3.0
  Versatile Diagnostic Monitoring    : YES
  Tx clock recovery capabilities     : Tx input lanes 1-4 and 5-8 to be in separate Tx synchronous groups
  Max Tx Input Eq(dB)                : 9
  Max Rx Output Eq Pre-cursor(dB)    : 1.5
  Max Rx Output Eq Post-cursor(dB)   : 3
  Tx disable implemented             : YES
  Tx Force Squelch implemented       : YES
  Tx Squelch implemented             : NO
  Tunable transmitter                : YES
  Tx bypass CDR implemented          : YES
  Rx bypass CDR implemented          : YES
  Tx Input Eq Adaptive               : YES
  CDB implemented                    : NO
Table 13 Command output
CMIS revision
QSFP-DD CMIS version. The value is 3.0 or 4.0.
Versatile diagnostic monitoring
Support for versatile diagnostic monitoring:
·     YES.
·     NO.
Clock recovery capabilities when the transceiver module acts as the transmitter:
·     All Tx input lanes to be in a single Tx synchronous group.
·     Tx input lanes 1-4 and 5-8 to be in separate Tx synchronous groups.
·     Tx input lanes 1-2, 3-4, 5-6, 7-8 to be in separate Tx synchronous groups.
·     Each Tx input lane to be in a separate Tx synchronous group.
Max Tx input Eq (dB)
Maximum Tx Input Equalization control value.
Max Rx output Eq pre-cursor (dB)
Maximum Rx output Eq pre-cursor control value.
Max Rx output Eq post-cursor (dB)
Maximum Rx output Eq post-cursor control value.
Support for Tx disable:
·     YES.
·     NO.
Support for Tx Force Squelch:
·     YES.
·     NO.
Support for Tx Squelch:
·     NO.
·     OMA—Implements Tx Squelch based on OMA.
·     Pave—Implements Tx Squelch based on Pave.
·     Both—Implements Tx Squelch based on OMA or Pave as needed.
Tunable transmitter
Indicates whether the transmitter is tunable:
·     YES.
·     NO.
Support for bypass CDR when the transceiver module acts as the transmitter:
·     YES.
·     NO.
Support for bypass CDR when the transceiver module acts as the receiver:
·     YES.
·     NO.
Tx input Eq adaptive
Support for the input equalization adaptive control when the transceiver module acts as the transmitter:
·     YES.
·     NO.
CDB implemented
Support for CDB:
·     NO.
·     One instance of CDB—Supports one CDB instance.
·     Two instances of CDB—Supports two CDB instances.
·     Unknown.
Use display transceiver alarm to display transceiver alarms.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the alarms present on every transceiver module.
You can use the display transceiver alarm command to display alarms present on transceiver modules.
If no error occurs, None is displayed. The following tables describe the alarm information that might be present on transceiver module.
Table 14 Command output for QSFP-DD transceiver modules
Data path firmware fault
N/A
Module firmware fault
N/A
Module state changed
N/A
Data path state changed in channel x
N/A
TX loss in channel x
Transmit signal loss in channel x.
TX CDR LOL in channel x
Transmit CDR loss of lock in channel x.
TX input eq fault in channel x
Transmit input eq fault in channel x.
RX CDR LOL in channel x
Receive CDR loss of lock in channel x.
Loss of reference clock
N/A
L-host pattern generator LOL in channel x
Pattern generator loss of lock on the host side in channel x.
L-media pattern generator LOL in channel x
Pattern generator loss of lock on the media side in channel x.
L-host pattern checker LOL in channel x
Pattern checker loss of lock on the host side in channel x.
L-media pattern checker LOL in channel x
Pattern checker loss of lock on the media side in channel x.
TEC Current high
Alarm on high TEC current or high TEC rated current.
TEC Current low
Alarm on low TEC current or high TEC rated current.
Laser Temperature high
Alarm on high laser temperature.
Laser Temperature low
Alarm on low laser temperature.
Temp high warning
Early warning on high module temperature.
Temp low warning
Early warning on low module temperature.
Voltage high warning
Early warning on high module voltage.
Voltage low warning
Early warning on low module voltage.
RX power high warning(channel x)
Early warning on high receive power in channel x.
RX power low warning(channel x)
Early warning on low receive power in channel x.
TX power high warning(channel x)
Early warning on high transmit power in channel x.
TX power low warning(channel x)
Early warning on low transmit power in channel x.
TX bias high warning(channel x)
Early warning on high transmit current  in channel x.
TX bias low warning(channel x)
Early warning on low transmit current in channel x.
TEC Current high warning
Early warning on high TEC current or high TEC rated current.
TEC Current low warning
Early warning on low TEC current or high TEC rated current.
Laser Temperature high warning
Early warning on high laser temperature.
Laser Temperature low warning
Early warning on low laser temperature.
VDM: Laser temperature high alarm
Alarm on high laser temperature in versatile diagnostics monitoring (VDM).
VDM: Laser temperature low alarm
Alarm on low laser temperature in VDM.
VDM: Host current pre-FEC BER high alarm(channel x)
Alarm on high pre-FEC bit error rate on the host side in channel x in VDM.
VDM: Host current pre-FEC BER low alarm(channel x)
Alarm on low pre-FEC bit error rate on the host side in channel x in VDM.
VDM: Media current pre-FEC BER high alarm(channel x)
Alarm on high pre-FEC bit error rate on the media side in channel x in VDM.
VDM: Media current pre-FEC BER low alarm(channel x)
Alarm on low pre-FEC bit error rate on the media side in channel x in VDM.
VDM: Media current pre-FEC BER high warning(channel x)
Early warning on high pre-FEC bit error rate on the media side in channel x in VDM.
VDM: Media current pre-FEC BER low warning(channel x)
Early warning on low pre-FEC bit error rate on the media side in channel x in VDM.
VDM: RX Total Power high alarm(channel 1)
Alarm on high total receive power in channel 1 in VDM.
VDM: RX Total Power low alarm(channel 1)
Alarm on low total receive power in channel 1 in VDM.
VDM: RX Total Power high warning(channel 1)
Early warning on high total receive power in channel 1 in VDM.
VDM: RX Total Power low warning(channel 1)
Early warning on low total receive power in channel 1 in VDM.
Media-side Rx Loss of Frame
Lost receive frames on media side.
Media-side Rx Loss of Multi-Frame
Lost receive multi-frames on media side.
VDM: CFO high alarm
Alarm on high carrier frequency offset (CFO) in VDM.
VDM: CFO low alarm
Alarm on low CFO in VDM.
Excessive RX power change(channel x)
Alarm on the excessive receive optical power change in channel x.
Excessive TX power change(channel x)
Alarm on the excessive transmit optical power change in channel x.
Excessive TX bias change(channel x)
Alarm on the excessive bias current change in channel x.
Excessive temp change
Alarm on the excessive temperature change.
User-set TX power high(channel x)
User-set high transmit optical power alarm in channel x.
User-set TX power low(channel x)
User-set low transmit optical power alarm in channel x.
User-set RX power high(channel x)
User-set high receive optical power alarm in channel x.
User-set RX power low(channel x)
User-set low receive optical power alarm in channel x.
# Display the alarms present on the transceiver module in interface HundredGigE 1/0/1.
<Sysname> display transceiver alarm interface hundredgige 1/0/1
HundredGigE1/0/1 transceiver current alarm information:
  RX loss of signal
  RX power low
Table 15 Command output
Alarms present on the transceiver module.
RX loss of signal
Received signals are lost.
RX power low
Received power is low.
Use display transceiver application to display application related information for 400G transceiver modules.
display transceiver application interface [ interface-type interface-number ]
# Display application related information for the 400G transceiver module in interface FourHundredGigE 1/0/1.
<Sysname> display transceiver application interface fourhundredgige 1/0/1
FourHundredGigE1/0/1 transceiver application information:
ApSel code: 0001b
     Host Electrical Interface code     Module Media Interface Code
     400GAUI-8 C2M                      400G-SR8
     Host Lane Count                    Media Lane Count
     8                                  8
     The Lowest host Lane               The Lowest media lane
     1                                  1
ApSel Code: 0010b
     IB EDR                             Undefined
     8                                  8
     1                                  1
Table 16 Command output
ApSel Code
Current application of the transceiver module represented by the
ApSel code.
Lowest-numbered media lane.
Use display transceiver diagnosis to display the current values of the digital diagnosis parameters on transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the current values of the digital diagnosis parameters on every transceiver module.
# Display the current values of the digital diagnosis parameters on the transceiver module in interface HundredGigE 1/0/1.
<Sysname> display transceiver diagnosis interface hundredgige 1/0/1
HundredGigE1/0/1 transceiver diagnostic information:
    Temp(C)  Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    36        3.31        6.13      -35.64          -5.19
  Alarm thresholds:
           Temp(C)   Voltage(V)  Bias(mA)  RX power(dBM)  TX power(dBM)
    High   50         3.55        1.44      -10.00         5.00
    Low    30         3.01        1.01      -30.00         0.00
  Warning thresholds:
    High   45         3.25        1.25      -15.00         4.00
    Low    25         2.85        0.85      -25.00         1.00
  User-set power thresholds:
    High   -11.40         N/A
    Low    -26.00         0.10
# Display the current values of the digital diagnosis parameters on the transceiver module in interface FourHundredGigE 1/0/1.
<Sysname> display transceiver diagnosis interface fourhundredgige 1/0/1
FourHundredGigE1/0/1 transceiver diagnostic information:
  Alarm thresholds:
Media performance monitoring:
    Rx bits                            : 12345678901234567890
    Rx FEC corrected bits              : 12345678901234567890
    Rx frames                          : 12345678901234567890
    Rx uncorrectable frames            : 12345678901234567890
Host performance monitoring:
    Tx bits                            : 12345678901234567890
    Tx FEC corrected bits              : 12345678901234567890
    Tx frames                          : 12345678901234567890
    Tx uncorrectable frames            : 12345678901234567890
Table 17 Command output
Digital diagnosis information for the transceiver module in the interface.
[Module]
Parameters of the transceiver module.
Temp.(C)
Temperature in °C, accurate to 1°C.
Voltage(V)
Voltage in V, accurate to 0.01 V.
TEC Current(%)
TEC current in percentage, accurate to 0.01%.
Laser Temp(C)
Laser temperature in °C, accurate to 0.01°C.
[Channel]
Channel number. A channel is also referred to as a lane.
Bias(mA)
Bias current in mA, accurate to 0.01 mA.
RX power(dBm)
Receive power in dBm, accurate to 0.01 dBm.
TX power(dBm)
Transmit power in dBm, accurate to 0.01 dBm.
TEC Curr. (%)
Laser Temp(C)
Warning threshold
Early warning threshold.
RX power(dBm)
User-set receive optical power threshold in dBm, accurate to 0.01 dBm.
TX power(dBm)
User-set transmit optical power threshold in dBm, accurate to 0.01 dBm.
Table 18 Command output for the CMIS 4.0 transceiver module display transceiver
Rx bits
Number of receive bits.
Number of receive FEC corrected bits.
Rx frames
Number of receive frames.
Number of receive FEC uncorrectable frames.
Tx bits
Number of transmit bits.
Number of transmit FEC corrected bits.
Tx frames
Number of transmit frames.
Number of transmit FEC uncorrectable frames.
Use display transceiver history performance-collection to display history performance sampling information of transceiver modules.
display transceiver history performance-collection interface [ interface-type interface-number ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays history performance sampling information on all transceiver modules.
This command is available only for the QSFPDD-400G-ZR transceiver module.
This command displays transceiver performance information of the most recent two sampling intervals.
# Display history performance sampling information of the transceiver module in FourHundredGigE 1/0/1.
<Sysname> display transceiver history performance interface fourhundredgige 1/0/1
FourHundredGigE1/0/1 transceiver history performance information:
Time 2021-11-09 10:00:00 - 2021-11-09 11:00:00
VDM performance data:
Parameters                         Min            Max            Avg
CD-high granularity(Ps/nm)       : 0              0              0
DGD(Ps)                          : 0.00           0.00           0.00
PDL(dB)                          : 0.00           0.00           0.00
OSNR(dB)                         : 0.00           0.00           0.00
eSNR(dB)                         : 9.00           9.00           9.00
CFO(MHz)                         : 0              0              0
SOP ROC(krad/s)                  : 0              0              0
Tx Power(dBm)                    : -174.80        -9.39          -10.21
Rx total power(dBm)              : -30.22         -25.39         -25.59
Pre-FEC BER Media Input (Lane1)  : 1.00E00        1.00E00        1.00E00
FERC Media Input (Lane1)         : 1.00E00        1.00E00        1.00E00
Pre-FEC BER Host Input (Lane1)   : 0.00E-23       1.00E00        1.29E-07
FERC Host Input (Lane1)          : 0.00E-23       1.00E00        1.27E-04
    Rx bits                            : 3605
    Rx FEC corrected bits              : 3605
    Rx frames                          : 3605
    Rx uncorrectable frames            : 3605
    Rx Min uncorrect frames error      : 1
    Rx Max uncorrect frames error      : 1
    Rx post-FEC BER                    : 1.00E+00
    Tx bits                            : 1267250934611574
    Tx FEC corrected bits              : 164625007
    Tx frames                          : 1733738820
    Tx uncorrectable frames            : 220329
    Tx Min uncorrect frames error      : 0
    Tx Max uncorrect frames error      : 188832
    Tx post-FEC BER                    : 1.27E-04
Time 2021-11-09 09:00:00 - 2021-11-09 10:00:00
CFO(MHz)                         : 0              0              0
Tx Power(dBm)                    : -174.80        -9.39          -10.51
Rx total power(dBm)              : -30.30         -25.44         -25.59
Pre-FEC BER Host Input (Lane1)   : 0.00E-23       1.00E00        1.41E-07
FERC Host Input (Lane1)          : 0.00E-23       1.00E00        1.10E-05
    Rx bits                            : 3604
    Rx FEC corrected bits              : 3604
    Rx frames                          : 3604
    Rx uncorrectable frames            : 3604
    Tx bits                            : 1266782281942900
    Tx FEC corrected bits              : 179431912
    Tx frames                          : 1642561264
    Tx uncorrectable frames            : 18073
    Tx Max uncorrect frames error      : 9211
    Tx post-FEC BER                    : 1.10E-05
Table 19 Command output
Time yyyy-mm-dd hh:mm:ss - yyyy-mm-dd hh:mm:ss
Sampling time range.
Chromatic dispersion (high granularity), accurate to 0.01 ps/nm.
DGD(Ps)
Differential group delay in ps, accurate to 0.01 ps.
PDL(dB)
Polarization-dependent loss in dB, accurate to 0.01 dB
OSNR(dB)
Optical signal to noise ratio in dB, accurate to 0.1 dB.
eSNR(dB)
Echo signal to noise ratio in dB, accurate to 0.1 dB.
CFO(MHz)
Carrier frequency offset in MHz, accurate to 1 MHz.
SOP ROC(krad/s)
State-of-polarization rate-of-change in krad/s, accurate to 1 krad/s.
Tx Power(dBm)
Rx total power(dBm)
Total receive power in dBm, accurate to 0.01 dBm.
Pre-FEC BER Media Input (Lanex)
Pre-FEC bit error rate on the media side in lane x.
Pre-FEC BER Host Input (Lanex)
Pre-FEC bit error rate on the host side in lane x.
FERC Media Input (Lanex)
Frame error count on the media side in lane x.
FERC Host Input (Lanex)
Frame error count on the host side in lane x.
Minimum number of frames uncorrected by FEC during an interval on the receive side.
Maximum number of frames uncorrected by FEC during an interval on the receive side.
Rx post-FEC BER
Post-FEC bit error rate on the receive side.
Frames uncorrected by FEC.
Minimum number of frames uncorrected by FEC during an interval on the transmit side.
Maximum number of frames uncorrected by FEC during an interval on the transmit side.
Tx post-FEC BER
Post-FEC bit error rate on the transmit side.
Use display transceiver interface to display the key parameters of transceiver modules.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the key parameters of every transceiver module.
# Display the key parameters of the transceiver module in interface HundredGigE 1/0/1.
<Sysname> display transceiver interface hundredgige 1/0/1
HundredGigE1/0/1 transceiver information:
  Transceiver type                 : 100G_BASE_SR4_QSFP28
  Connector type                   : MPO
  Wavelength (nm)                  : 850
  Transfer distance (m)            : 70(OM3),100(OM4)
  Max power(W)                     : 12
  Digital diagnostic monitoring    : Yes
  Vendor name                      : H3C
  Ordering Name                    : QSFP-100G-SR4-MM850
Table 20 Command output
Transceiver Type
Model of the transceiver module.
Connector Type
Connector type of the transceiver module:
·     Optical connectors, including SC connector developed by NTT, and 1.25mm/RJ45 LC connector developed by Lucent.
·     Other connectors, including RJ-45 and CX4.
Wavelength(nm)
For the transceiver module, this field displays central wavelength of the laser sent, in nm. If the transceiver module such as 10GBASE-LX4, supports multiple wavelengths, each wavelength value is separated by a comma.
For the electrical transceiver, this field displays N/A.
Transfer Distance(xx)
Transfer distance. For a single-mode transceiver module, the distance is measured in km. For other transceiver modules, the distance is measured in m. If the transceiver module supports multiple transfer media, the transfer distances are separated by commas. The corresponding transfer medium is enclosed in the brackets following the transfer distance value. The following are the transfer media:
·     9um—9/125um single-mode optical fiber.
·     50um—50/125um OM 2 multi-mode optical fiber.
·     62.5um—62.5/125um OM 1 multi-mode optical fiber.
·     CX4—CX4 cable.
·     OM3—50 um OM3 multi-mode optical fiber.
·     OM4—50 um OM4 multi-mode optical fiber.
·     OM5—50 um OM5 multi-mode optical fiber.
·     STACK—Stack cable.
·     TP—Twisted pair cable.
Max power(W)
Maximum power of the transceiver module.
Digital Diagnostic Monitoring
Support for digital diagnostic monitoring:
·     Yes.
·     No.
Vendor Name
Vendor name or vendor name specified for the transceiver module.
Ordering Name
Ordering name of the transceiver module.
Use display transceiver manuinfo to display electronic label information for transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays electronic label information for the transceiver modules on all interfaces.
# Display electronic label information for the transceiver module in interface HundredGigE 1/0/1.
<Sysname> display transceiver manuinfo interface hundredgige 1/0/1
HundredGigE1/0/1 transceiver manufacture information:
  Manu. Serial Number  : 213410A0000054000251
  Manufacturing Date   : 2019-09-01
  Vendor Name          : H3C
Table 21 Command output
Manu. Serial Number
Serial number generated during debugging and testing.
Manufacturing Date
Debugging and testing date. The date takes the value of the system clock of the computer when debugging and testing is performed.
Vendor Name
The value is H3C.
Use display transceiver status to display 400G transceiver module status information.
display transceiver status interface [ interface-type interface-number ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If you do not specify an interface, this command applies to all interfaces.
# Display status information for the 400G transceiver module in interface FourHundredGigE 1/0/1.
<Sysname> display transceiver status interface fourhundredgige 1/0/1
FourHundredGigE1/0/1 transceiver status information:
  Module state        : ModuleReady
  Interrupt           : YES
  Host-fault-detect   : Enabled
  Media-fault-detect  : Disabled
  Lane      Data Path State     Media Lane State
  Lane1     Activated           Enable
  Lane2     Activated           Enable
  Lane3     Activated           Enable
  Lane4     Activated           Enable
  Lane5     Activated           Enable
  Lane6     Activated           Enable
  Lane7     Activated           Enable
  Lane8     Activated           Enable
  Loopback Mode       :
  Lane      Media Output   Media Input    Host Output    Host Input
  Lane1     Disable        Disable        Disable        Disable
  Lane2     Disable        Disable        Disable        Disable
  Lane3     Disable        Disable        Disable        Disable
  Lane4     Disable        Disable        Disable        Disable
  Lane5     Disable        Disable        Disable        Disable
  Lane6     Disable        Disable        Disable        Disable
  Lane7     Disable        Disable        Disable        Disable
  Lane8     Disable        Disable        Disable        Disable
# Display status information for the 400G ZR transceiver module in interface FourHundredGigE 1/0/1. (This example is available only for the QSFPDD-400G-ZR transceiver module.)
  Interrupt           : YES
  Loopback Mode       :
Table 22 Command output
Module status
Transceiver module status:
·     ModuleLowPwr—The transceiver module operates in low power.
·     ModulePwrUp—The transceiver module is powered on.
·     ModuleReady—The transceiver module is ready.
·     ModulePwrDn—The transceiver module is powered off.
·     Fault state—The transceiver module is faulty.
·     Unknown.
Interrupt alarm
Indicates whether the transceiver module is in interrupt alarm status:
·     Yes.
·     No.
Data path state
Data path status:
·     Unknown.
·     Deactivated.
·     Initial—The transceiver module is performing initialization tasks on the data path.
·     Deinit—The data path is deinitialized.
·     Activated.
·     TxTurnOn—Tx output is enabled.
·     TxTurnOff—Tx output is disabled.
·     Initialized—The data path is fully initialized.
Media Lane State
Media lane status:
·     Enabled.
·     Disabled.
Host-fault-detect
Fault detection status on the transceiver host side:
·     Enabled.
·     Disabled.
Media-fault-detect
Fault detection status on the transceiver media side:
·     Enabled.
·     Disabled.
Loopback Mode
Loopback testing mode of a lane on the transceiver module.
Media Output
Loopbacks the signal received by the receiver of the media side to the transmitter of the media side as the output signal of the media:
·     Enabled.
·     Disabled.
Media Input
Loopbacks the signal from the transmitter of the media side to the receiver of the media side as the input signal of the media:
·     Enabled.
·     Disabled.
Host Output
Loopbacks the signal received by the receiver of the host side to the transmitter of the host side as the output signal of the host:
·     Enabled.
·     Disabled.
Host Input
Loopbacks the signal from the transmitter of the host side to the receiver of the host side as the input signal of the host:
·     Enabled.
·     Disabled.
Use display transceiver vdm to display the versatile diagnostics monitoring (VDM) information of a transceiver module.
display transceiver vdm interface interface-type interface-number vdm-id vdm-id
vdm-id vdm-id: Specifies a VDM by its ID. The value range varies by transceiver module model.
This command is available only for some 400G transceiver modules that support CMIS 4.0.
# Display the VDM 1 information of the transceiver module in FourHundredGigE 1/0/1.
<Sysname> display transceiver vdm interface fourhundredgige 1/0/1 vdm-id 1
VDM Description: Laser Temperature
Module/lane         VDM value(C)
Lane1               58.0
Alarm/Warning thresholds:
          Warning(C)     Alarm(C)
  High    80.0           85.0
  Low     0.0            251.0
# Display the VDM 2 information of the transceiver module in FourHundredGigE 1/0/1.
<Sysname> display transceiver vdm interface fourhundredgige 1/0/1 vdm-id 2
VDM Description: eSNR Host Input
Module/lane         VDM value(dB)
Lane1               0.0
          Warning(dB)    Alarm(dB)
  High    99.0           99.0
  Low     226.0          216.0
Use fan auto-control-mode to set the fan operating mode.
Use undo fan auto-control-mode to restore the default.
fan auto-control-mode { balance | low-temperature | silence }
Fans operate in silent mode.
balance: Operates in a balanced way. In this mode, the fan speed is lower than the low-temperature mode and higher than the silence mode to provide balanced noise control and cooling performance.
low-temperature: Operates at a higher speed to provide better cooling service.
silence: Operates at a lower speed to reduce the noise at the cost of lower cooling service quality. This mode applies to noise-sensitive environments.
# Set the fan operating mode to silence.
[Sysname] fan auto-control-mode silence
Use hardware-alarm disable to disable the notification of hardware resource alarms.
hardware-alarm { syslog | trap } resource-type { all | board | bus | chip-channel | chip-port | device | disk | fan | interface | power | subcard | transceiver | voltage } disable
undo hardware-alarm { syslog | trap } resource-type { all | board | bus | chip-channel | chip-portdevice | disk | fan | interface | power | subcard | transceiver | voltage } disable
The notification of all hardware resource alarms is enabled.
all: Specifies all types of resource alarms.
board: Specifies card-related resource alarms.
bus: Specifies bus-related resource alarms.
chip-channel: Specifies chip channel-related resource alarms.
chip-port: Specifies chip port-related resource alarms.
device: Specifies device-related resource alarms.
disk: Specifies disk-related resource alarms.
fan: Specifies fan-related resource alarms.
interface: Specifies interface-related resource alarms.
syslog: Sends hardware resources alarms in syslog messages.
subcard: Specifies subcard-related resource alarms.
transceiver: Specifies transceiver -related resource alarms.
trap: Sends hardware resources alarms in traps.
power: Specifies power supply-related resource alarms.
voltage: Specifies voltage-related resource alarms.
# Disable trap notification for all hardware resource alarms.
<Sysname> system
[Sysname] hardware-alarm trap resource-type all disable
# Disable syslog notification for device-related resource alarms.
<Sysname> system
[Sysname] hardware-alarm syslog resource-type device disable
Use hardware-resource switch-mode to set the hardware resource operating mode for the MAC address table, ARP and ND tables, and routing tables.
Use undo hardware-resource switch-mode to restore the default.
hardware-resource switch-mode { MAC | ROUTING }
The hardware resource operating mode is ROUTING for the MAC address table, ARP and ND tables, and routing tables.
MAC: Specifies the MAC mode.
ROUTING: Specifies the ROUTING mode.
The device supports multiple hardware resource operating modes for the MAC address table, ARP/ND table, and routing tables. The capacities of the tables vary by hardware resource operating mode. For more information, see hardware resource management in System Management Configuration Guide.
This setting takes effect after you save the running configuration and restart the device. Before restarting the device, make sure you know the possible impact on the network.
If you specify the MAC hardware resource operating mode, the VXLAN feature is not supported.
For the S9855 switch series, if you specify the MAC mode by the hardware-resource switch-mode command, but a Layer 3 interface is configured with a non-default MAC address, that Layer 3 interface cannot operate as a routing interface, routing subinterface, or VLAN interface.
# Set the hardware resource operating mode to ROUTING.
[Sysname] hardware-resource switch-mode routing
Do you want to change the specified hardware resource working mode? [Y/N]:y
The hardware resource working mode is changed, please save the configuration and
 reboot the system to make it effective.
memory-threshold
Use memory-threshold to set free-memory thresholds.
Use undo memory-threshold to restore the default.
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
Minor alarm threshold: 256 MB.
Severe alarm threshold: 192 MB.
Critical alarm threshold: 128 MB.
Normal state threshold: 320 MB.
Early-warning threshold: 384 MB.
Sufficient-memory threshold: 448 MB.
ratio: Specifies free-memory thresholds in percentage. If you do not specify this keyword, the command sets free-memory thresholds in MB.
minor minor-value: Specifies the minor alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the minor-value argument. Setting this threshold to 0 disables the minor alarm feature.
severe severe-value: Specifies the severe alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the severe-value argument. Setting this threshold to 0 disables the severe alarm feature.
critical critical-value: Specifies the critical alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the critical-value argument. Setting this threshold to 0 disables the critical alarm feature.
normal normal-value: Specifies the normal state threshold. To view the value range for this threshold, enter a question mark (?) in the place of the normal-value argument.
early-warning early-warning-value: Specifies the early-warning threshold. To view the value range for this threshold, enter a question mark (?) in the place of the early-warning-value argument. Setting this threshold to 0 disables the early warning feature.
secure secure-value: Specifies the sufficient-memory threshold. To view the value range for this threshold, enter a question mark (?) in the place of the secure-value argument.
To ensure correct operation and improve memory efficiency, the system monitors the amount of free memory space in real time. If the amount of free memory space decreases to or below the minor, severe, or critical alarm threshold, the system issues an alarm to affected service modules or processes.
You can use the display memory command to display memory usage information.
The early warning feature warns you of an approaching insufficient-memory condition.
If a memory alarm occurs, delete unused configuration items or disable some features to increase the free memory space. Because the memory space is insufficient, some configuration items might not be able to be deleted.
For more information about the thresholds, see hardware resource management in System Management Configuration Guide.
The system will restart if one of the following conditions is met:
·     After a critical alarm occurs, the remaining free-memory value has been smaller than the critical alarm threshold for 30 seconds.
·     The interval between two consecutive critical alarms is shorter than 30 seconds.
·     The critical alarm has occurred three times within three minutes.
·     After a critical alarm occurs, the system will periodically sample free memory space and predict if the free memory space will be exhausted within 30 seconds. If the prediction result indicates that the free memory space will be exhausted within 30 seconds, the system will restart.
Once the free memory space reaches the minor, severe, or critical alarm threshold, the device will display the current memory usage information when you log in to the device through console or Telnet login, or execute every command.
The sending periods of memory alarm notifications are as follows:
·     If the free memory space has consistently exceeded the minor threshold for 12 hours, a minor alarm notification is sent.
·     If the free memory space has consistently exceeded the severe threshold for 3 hours, a severe alarm notification is sent.
·     If the free memory space has consistently exceeded the critical threshold for 1 hour, a critical alarm notification is sent.
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 64 MB, 48 MB, 32 MB, and 96 MB, respectively.
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 3%, 2%, 1%, and 5% of the total memory size, respectively.
[Sysname] memory-threshold ratio minor 3 severe 2 critical 1 normal 5
Use memory-threshold dma to set DMA memory thresholds.
Use undo memory-threshold dma to restore the default.
memory-threshold dma [ slot slot-number [ cpu cpu-number ] ] [ ratio ] critical critical-value normal normal-value
undo memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
The DMA memory alarm threshold is 2048 KB and the normal state threshold is 4096 KB.
ratio: Specifies DMA memory thresholds in percentage.
critical critical-value: Specifies the DMA memory alarm threshold. If the ratio keyword is specified, the value range for the critical-value argument is 1 to 100 in percentage. If the ratio keyword is not specified, the value is fixed to 0..
normal normal-value: Specifies the normal state threshold. If the ratio keyword is specified, the value range for the normal-value argument is 1 to 100 in percentage. If the ratio keyword is not specified, the device adjusts the value for the normal-value argument equals to the value for the critical-value argument minus 4177920.
To ensure correct operation of the services that require DMA memory, the system monitors the amount of free DMA memory space regularly. If the amount of free DMA memory space decreases to or below the alarm threshold, the system generates a notification indicating that the DMA memory space is insufficient. If the amount of free DMA memory space increases above the normal state threshold, the system generates a notification indicating that the DMA memory space is sufficient.
# Set the DMA memory alarm threshold and the normal state threshold to 32KB and 96 KB, respectively, for slot 1.
<System> system-view
[System] memory-threshold dma slot 1 critical 32 normal 96
Use memory-threshold usage to set the memory usage threshold.
Use undo memory-threshold usage to restore the default.
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
The memory usage threshold is 100%.
memory-threshold: Specifies the memory usage threshold in percentage. The value range is 0 to 100.
The device samples memory usage at 1-minute intervals. If the sample is greater than the memory usage threshold, the device sends a trap.
# Set the memory usage threshold to 80%.
[Sysname] memory-threshold usage 80
Use monitor cpu-usage enable to enable CPU usage tracking.
Use undo monitor cpu-usage enable to disable CPU usage tracking.
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
After you enable CPU usage tracking, the system samples and saves CPU usage at the interval specified by the monitor cpu-usage interval command. You can use the display cpu-usage history command to view recent CPU usage.
# Enable CPU usage tracking.
[Sysname] monitor cpu-usage enable
Use monitor cpu-usage interval to set the sampling interval for CPU usage monitoring.
Use undo monitor cpu-usage interval to restore the default.
undo monitor cpu-usage interval [ slot slot-number [ cpu cpu-number ] ]
The system samples CPU usage every 1 minute.
interval: Specifies the sampling interval for CPU usage monitoring. Valid values include 5Sec (5 seconds), 1Min (1 minute), and 5Min (5 minutes), case insensitive.
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the specified interval. You can use the display cpu-usage history command to view recent CPU usage.
# Set the sampling interval for CPU usage monitoring to 5 seconds.
[Sysname] monitor cpu-usage interval 5Sec
Use monitor cpu-usage statistics-interval core to set a CPU core usage statistics interval.
Use undo monitor cpu-usage statistics-interval core to restore the default.
monitor cpu-usage statistics-interval interval slot slot-number cpu cpu-number core core-id-list
undo monitor cpu-usage statistics-interval slot slot-number cpu cpu-number core core-id-list
The CPU core usage statistics interval is 60 seconds.
interval: Specifies the CPU core usage statistics interval in seconds. The value range for this argument is 10 to 3600. As a best practice, set this argument to an integer multiple of the sampling interval, which is fixed at 5 seconds. If you set this argument to a non-integer multiple of the sampling interval, the effective statistics interval is the integer multiple of the sampling interval that is close to and smaller than the value you set. For example, if you set this argument to 12 seconds, the effective statistics interval is 10 seconds.
core core-id-list: Specifies a space-separated list of up to 10 CPU core items. Each item specifies a CPU core or a range of CPU cores in the form of core-id1 [ to core-id2 ]. The value for core-id2 must be equal to or greater than the value for core-id1.
The device samples CPU core usage at 5-second intervals and calculates the average value during each CPU core usage statistics interval. If the value during an interval is greater than a CPU core usage alarm threshold, the device issues an alarm and logs the event.
# Set the usage statistics interval to 60 seconds for a CPU core.
[Sysname] monitor cpu-usage statistics-interval 60 slot 1 cpu 0 core 0
monitor cpu-usage threshold core
Use monitor cpu-usage threshold to set CPU usage alarm thresholds.
Use undo monitor cpu-usage threshold to restore the default.
monitor cpu-usage threshold severe-threshold [ minor-threshold minor-threshold recovery-threshold recovery-threshold ] [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold  [ minor-threshold recovery-threshold ] [ slot slot-number [ cpu cpu-number ] ]
Severe CPU usage alarm threshold: 99%.
Minor CPU usage alarm threshold: 80%.
CPU usage recovery threshold: 60%.
severe-threshold: Specifies the severe CPU usage alarm threshold in percentage. The value range for this argument is 2 to 100.
minor-threshold minor-threshold: Specifies the minor CPU usage alarm threshold in percentage. The value range for this argument is 1 to the severe CPU usage alarm threshold minus 1. If you do not specify this option, the minor CPU usage alarm threshold is 80 percent of the severe CPU usage alarm threshold.
recovery-threshold recovery-threshold: Specifies the CPU usage recovery threshold in percentage. The value range for this argument is 0 to the minor CPU usage alarm threshold minus 1. If you do not specify this option, the CPU usage recovery threshold is 70 percent of the severe CPU usage alarm threshold.
CAUTION
CAUTION:
If you set the severe CPU usage alarm threshold to a too low value, the device will reach the threshold easily. Normal services will be affected.
The device samples CPU usage at 1-minute intervals. If the sample is greater than the CPU usage threshold, the device sends a trap.
# Set the CPU usage alarm threshold to 90%.
[Sysname] monitor cpu-usage threshold 90
monitor resend cpu-usage
Use monitor resend cpu-usage to set CPU usage alarm resending intervals.
Use undo monitor resend cpu-usage to restore the default.
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
The minor CPU usage alarm resending interval is 300 seconds. The severe CPU usage alarm resending interval is 60 seconds.
minor-interval minor-interval: Specifies the minor CPU usage alarm resending interval in seconds, a multiple of 5 in the range of 10 to 3600.
severe-interval severe-interval: Specifies the severe CPU usage alarm resending interval in seconds, a multiple of 5 in the range of 10 to 3600.
slot slot-number: Specifies a device by its ID, which is fixed at 1.
The device samples CPU usage at intervals, and compares the samples with CPU usage thresholds to identify the CPU usage status and send alarms or notifications accordingly.
In minor alarm state, the device sends minor alarms periodically until the CPU usage increases above the severe threshold or the minor alarm is removed. In severe alarm state, the device sends severe alarms periodically until the severe alarm is removed. This command sets the alarm resending intervals.
If you do not specify a keyword for the undo monitor resend cpu-usage command, the command restores the default minor and severe CPU usage alarm resending intervals.
# Set the minor CPU usage alarm resending interval to 60 seconds for a slot.
[Sysname] monitor resend cpu-usage minor-interval 60 slot 1 cpu 0
monitor resend cpu-usage core-interval
Use monitor resend cpu-usage core-interval to set CPU core usage alarm resending intervals.
Use undo monitor resend cpu-usage core-interval to restore the default.
monitor resend cpu-usage core-interval { minor-interval minor-interval | severe-interval severe-interval } * [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend cpu-usage core-interval [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
The resending interval is 300 seconds for minor CPU core usage alarms and 60 seconds for severe CPU core usage alarms.
minor-interval minor-interval: Specifies the resending interval for minor CPU core usage alarms in seconds, a multiple of 5 in the range of 10 to 3600.
severe-interval severe-interval: Specifies the resending interval for severe CPU core usage alarms in seconds, a multiple of 5 in the range of 10 to 3600.
The device samples CPU core usage at intervals, and compares the samples with CPU core usage thresholds to identify the CPU core usage status and send alarms or notifications accordingly.
In minor alarm state, the device sends minor alarms periodically until the CPU core usage increases above the severe threshold or the minor alarm is removed. In severe alarm state, the device sends severe alarms periodically until the severe alarm is removed. This command sets the alarm resending intervals.
# Set the resending interval for minor CPU core usage alarms to 100 seconds and the resending interval for severe CPU core usage alarms 60 seconds.
[Sysname] monitor resend cpu-usage core-interval minor-interval 100 severe-interval 60
monitor resend memory-threshold dma
Use monitor resend memory-threshold dma to set the DMA memory alarm resending interval.
Use undo monitor resend memory-threshold dma to restore the default.
monitor resend memory-threshold dma critical-interval critical-interval [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend memory-threshold dma critical-interval [ slot slot-number [ cpu cpu-number ] ]
The DMA memory alarm resending interval is 300 seconds.
critical-interval critical-interval: Specifies the resending interval for the DMA memory alarms in seconds, in the range of 10 to 3600.
cpu cpu-number: Specifies a CPU by its number.
The device samples DMA memory usage at intervals, and compares the samples with the DMA memory alarm threshold to identify the DMA memory usage status and send alarms or notifications accordingly.
# Set the resending interval for the DMA memory alarms to 100 seconds.
[Sysname] monitor resend memory-threshold dma critical-interval 100<Sysname> system-view
power-supply policy enable
Use power-supply policy enable to enable power supply management.
Use undo power-supply policy enable to disable power supply management.
Power supply management is enabled.
# Enable power supply management.
[Sysname] power-supply policy enable
power-supply policy redundant
Use power-supply policy redundant to specify the number of redundant power modules.
Use undo power-supply policy redundant to restore the default.
power-supply policy redundant module-count
The number of redundant power supplies is 0.
module-count: Specifies the number of redundant power modules. To view the value range for this argument, enter a question mark (?) in the place of this argument. The upper limit for the value range is the maximum number of redundant power modules supported by the system. The actual number of redundant power modules that you can specify varies by the number of the interface cards and their power consumption. The actual number is smaller than or equal to the maximum number.
This command takes effect only if power supply management is enabled.
# Set the number of redundant power modules to 1.
[Sysname] power-supply policy redundant 1
reset transceiver interface
Use reset transceiver interface to reset a 400G transceiver module.
reset transceiver interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command applies to all interfaces.
This command is disruptive. Use this command only when you cannot troubleshoot transceiver modules by using other methods.
This command will restart the transceiver module.
# Reset the 400G transceiver module in FourHundredGigE 1/0/1.
<Sysname> reset transceiver interface fourhundredgige 1/0/1
This operation causes services on the transceiver module to be down for a while. Continue? [Y/N]: Y
resource-monitor minor resend enable
Use resource-monitor minor resend enable to enable resending of minor resource depletion alarms.
Use undo resource-monitor minor resend enable to disable resending of minor resource depletion alarms.
Resending of minor resource depletion alarms is enabled.
When a resource type enters minor alarm state, the device issues a minor alarm. If the resource type stays in minor alarm state or changes from severe alarm state to minor alarm state, the device identifies whether resending of minor resource depletion alarms is enabled. If the feature is disabled, the device does not issue additional minor alarms. If the feature is enabled, the device resends minor alarms periodically.
The resending interval of severe alarms is 24 hours and the resending interval of minor alarms is 7×24 hours.
# Enable resending of minor resource depletion alarms.
[Sysname] resource-monitor minor resend enable
resource-monitor output
Use resource-monitor output to specify destinations for resource depletion alarms.
Use undo resource-monitor output to remove destinations for resource depletion alarms.
undo resource-monitor output [ netconf-event | snmp-notification | syslog ] *
Resource depletion alarms are sent to NETCONF, SNMP, and the information center.
netconf-event: Sends resource depletion alarms to the NETCONF feature to encapsulate the alarms in NETCONF events. For more information, see NETCONF in Network Management and Monitoring Configuration Guide.
snmp-notification: Sends resource depletion alarms to the SNMP feature to encapsulate the alarms in SNMP traps and informs. For more information, see SNMP in Network Management and Monitoring Configuration Guide.
syslog: Sends resource depletion alarms to the information center to encapsulate the alarms in log messages. For more information, see information center in System Management Configuration Guide.
If you do not specify any keywords for the undo resource-monitor output command, the command disables resource depletion alarm output.
# Specify the information center module as the output destination for resource depletion alarms.
[Sysname] resource-monitor output syslog
Use resource-monitor resource to set resource depletion thresholds.
Use undo resource-monitor resource to disable resource depletion thresholds.
undo resource-monitor resource resource-name slot slot-number cpu cpu-number
The default settings vary by resource type. Use the display resource-monitor command to display the resource depletion thresholds.
resource-name: Specifies a resource type by its name. The values for this argument are case insensitive and cannot be abbreviated. Table 23 shows the resource types that can be monitored.
Table 23 Resource types that can be monitored
Resource type
ac
Number of Ethernet service instances.
arp
ARP hardware resources.
ecmp_group
ECMP group hardware resources.
ecmp_member
ECMP group member hardware resources.
host
Host route hardware resources.
lag
Link aggregation group resources.
lag_member
Count resources of link aggregation group members.
mac
MAC address table hardware resources.
mqc_in
Inbound MQC hardware resources.
mqc_out
Outbound MQC hardware resources.
nd
ND hardware resources.
nexthop
Next-hop resources.
openflow
OpenFlow resources.
pbr_in
Inbound PBR resources.
pfilter_in
Inbound packet filter resources.
pfilter_out
Outbound packet filter resources.
route
Routing hardware resources.
route_aggreation
Layer 3 aggregate interface resources.
rport
Layer 3 Ethernet interface hardware resources.
stp_instance
STP interface resources.
sub_interface
Subinterface resources.
v4route
IPv4 route hardware resources.
v6route
IPv6 route hardware resources.
vlan
Number of VLANs.
vlaninterface
VLAN interface hardware resources.
vrf
VPN instance resources.
vsi
Number of VSIs.
vsiintf
VSI interface hardware resources.
vxlan_tunnel
VXLAN tunnel resources.
by-percent: Specifies resource depletion thresholds in percentage.
minor-threshold minor-threshold: Specifies the minor resource depletion threshold. To view the value range, enter a question mark (?) in the place of the minor-threshold argument.
severe-threshold severe-threshold: Specifies the severe resource depletion threshold. To view the value range, enter a question mark (?) in the place of the severe-threshold argument.
After you execute this command for a resource type, the device monitors the available amount of the type of resources. The device samples the available amount at intervals, compares the sample with the resource depletion thresholds to identify the resource depletion status, and sends alarms as configured.
# Set the minor resource depletion threshold to 30% and the severe resource depletion threshold to 10% for ARP entry resources on slot 1.
[Sysname] resource-monitor resource arp slot 1 cpu 0 by-percent minor-threshold 30 severe-threshold 10
shutdown-interval
Use shutdown-interval to set the port status detection timer.
Use undo shutdown-interval to restore the default.
shutdown-interval interval
The port status detection timer setting is 30 seconds.
interval: Specifies the port status detection timer value in seconds. The value range is 0 to 300. The value of 0 indicates that port status detection is not automatically performed, and you need to execute the undo shutdown command to restore the port status manually.
On a network enabled with loop detection or STP, the device starts a port status detection timer when a port is shut down by a protocol. If the port has been in down state before the timer expires, the device will set the port status to the port's physical status.
If you change the timer setting during port detection, the device compares the new setting (T1) with the time that elapsed since the port was shut down (T).
If T < T1, the port will be brought up after T1 – T seconds.
If T ≥ T1, the port is brought up immediately.
For example, the timer setting is 30 seconds. If you change it to 10 seconds 2 seconds after the port is shut down, the port will come up 8 seconds later. If you change the timer setting to 2 seconds 10 seconds after the port is shut down, the port comes up immediately.
# Set the port status detection timer to 100 seconds.
[Sysname] shutdown-interval 100
temperature-limit
Use temperature-limit to set the temperature alarm thresholds.
Use undo temperature-limit to restore the default.
temperature-limit slot slot-number  hotspot sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number
The default varies by temperature sensor model. To view the default, execute the undo temperature-limit and display environment commands in turn.
hotspot: Configures temperature alarm thresholds for hotspot sensors. A hotspot sensor is typically near the chip that generates a great amount of heat and used to monitor the chip.
sensor-number: Specifies a sensor by its number. To view the value range, enter a question mark (?) in the place of this argument.
lowlimit: Specifies the low-temperature threshold in Celsius degrees. The value range varies by temperature sensor. To view the value range, enter a question mark (?) in the place of this argument.
warninglimit: Specifies the high-temperature warning threshold in Celsius degrees. This threshold must be greater than the low-temperature threshold. To view the value range, enter a question mark (?) in the place of this argument.
alarmlimit: Specifies the high-temperature alarming threshold in Celsius degrees. This threshold must be greater than the warning threshold. To view the value range, enter a question mark (?) in the place of this argument.
When the device temperature drops below the low-temperature threshold or reaches the high-temperature warning or alarming threshold, the device performs the following operations:
·     Sends log messages and traps.
·     Sets LEDs on the device panel.
# Set temperature alarm thresholds for hotspot sensor 1 in a slot.
[Sysname] temperature-limit slot 1 hotspot 1 -10 50 60
display environment
transceiver diagnostic selector
Use transceiver diagnostic selector to specify a diagnostic selector for a transceiver module and display specified diagnostic information.
transceiver diagnostic selector selector-id
No diagnostic selector is specified for a transceiver module.
200-GE interface view
400-GE interface view
selector-id: Specifies a diagnostic selector. The value range varies by transceiver module model.
The command settings will be saved in a register of the transceiver module. If the transceiver module has a power loss, the command settings will be cleared. You must reconfigure the command after a power recovery.
# Specify diagnostic selector 1 for the transceiver module in FourHundredGigE1/0/1 and display  specified diagnostic information.
[Sysname] interface fourhundredgige 1/0/1
[Sysname-FourHundredGigE1/0/1] transceiver diagnostic selector 1
Lane     Host side BER     Media side BER
1        1.00E-7           1.00E-7
2        1.00E-7           1.00E-7
3        1.00E-7           1.00E-7
4        1.00E-7           1.00E-7
5        1.00E-7           1.00E-7
6        1.00E-7           1.00E-7
7        1.00E-7           1.00E-7
8        1.00E-7           1.00E-7
# Specify diagnostic selector 2 for the transceiver module in FourHundredGigE 1/0/1 and display specified diagnostic information.
[Sysname-FourHundredGigE1/0/1] transceiver diagnostic selector 2
Lane     Host error count     Host total bits
1        1234567890           1234567890123456789
2        1234567890           1234567890123456789
3        1234567890           1234567890123456789
4        1234567890           1234567890123456789
# Specify diagnostic selector 6 for the transceiver module in FourHundredGigE 1/0/1 and display specified diagnostic information.
[Sysname-FourHundredGigE1/0/1] transceiver diagnostic selector 6
Lane     Host peak detect        Host SNR        Media peak detect        Media SNR
1        12345                   18.00dB         12345                    18.00dB
2        12345                   18.00dB         12345                    18.00dB
3        12345                   18.00dB         12345                    18.00dB
4        12345                   18.00dB         12345                    18.00dB
5        12345                   18.00dB         12345                    18.00dB
6        12345                   18.00dB         12345                    18.00dB
7        12345                   18.00dB         12345                    18.00dB
8        12345                   18.00dB         12345                    18.00Db
transceiver lane enable
Use transceiver lane enable to enable a lane on a 400G transceiver module.
Use undo transceiver lane to disable a lane on a 400G transceiver module.
transceiver lane [ lane-number ] enable
undo transceiver lane [ lane-number ] enable
All lanes on a transceiver module are enabled.
Ethernet interface view
lane-number: Specifies a lane by its number in the range of 1 to 8. If you do not specify a lane, this command enables all lanes on the transceiver module.
Execute this command only to verify that a transceiver module operates correctly.
Disabling a lane will stop signal transmission on the lane.
Disabling a lane will stop signal transmission on the fiber port where the lane is located.
This setting is saved in a register on the transceiver module. It is not saved to the configuration file.
# Enable lane 1 on the 400G transceiver module in FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] transceiver lane 1 enable
transceiver lane equalization
Use transceiver lane equalization to configure the pre-cursor, post-cursor, and amplitude for a 400G transceiver module.
Use undo transceiver lane equalization to restore the default.
transceiver lane [ lane-number ] equalization { precursor precursor-value | postcursor postcursor-value | amplitude amplitude-value }
undo transceiver lane [ lane-number ] equalization { precursor | postcursor | amplitude }
The default settings vary by transceiver module model.
400-GE Ethernet interface view and its breakout interface view
lane-number: Specifies a lane by its number in the range of 1 to 8. If you do not specify a lane, this command configures the settings for all lanes on the transceiver module.
precursor precursor-value: Specifies the Rx output equalization pre-cursor level code. The level codes include:
·     level0—No equalization.
·     level1—0.5 dB.
·     level2—1 dB.
·     level3—1.5 dB.
·     level4—2 dB.
·     level5—2.5 dB.
·     level6—3 dB.
·     level7—3.5 dB.
postcursor postcursor-value: Specifies the Rx output equalization post-cursor level code. The level codes include:
·     level1—1 dB.
·     level2—2 dB.
·     level3—3 dB.
·     level4—4 dB.
·     level5—5 dB.
·     level6—6 dB.
·     level7—7 dB.
amplitude amplitude-value: Specifies the Rx output amplitude range code. The range codes include:
·     range0—100 to 400 mV.
·     range1—300 to 600 mV.
·     range2—400 to 800 mV.
·     Range3—600 to 1200 mV.
Use this command to adjust and optimize high speed signals of a 400G transceiver module for the optical link to work in the optimum state. Use the default setting unless required otherwise. To change the default settings, contact professional engineers to avoid transceiver module exceptions.
As a best practice, do not execute this command when the interface is transmitting traffic. During execution of this command, the device disables and then enables the transceiver module automatically and traffic transmission will be interrupted.
# Configure the pre-cursor and post-cursor equalizers, and amplitude for the 400G transceiver module in FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] transceiver lane 1 equalization precursor level1
This operation will shut down and then bring up the transceiver module, affecting data transmission. Continue? [Y/N]:Y
display transceiver active-control
transceiver lane loopback
Use transceiver lane loopback to enable loopback testing on a transceiver module lane and specify a loopback testing mode.
Use undo transceiver lane loopback to restore the default.
transceiver lane [ lane-number ] loopback loopback-mode
undo transceiver lane [ lane-number ] loopback loopback-mode
Loopback testing is disabled for transceiver module lanes.
lane-number: Specifies a lane by its number. The value is in the range of 1 to 4 for a 200G transceiver module and in the range of 1 to 8 for a 400G transceiver module. If you do not specify a lane, this command applies to all lanes of the transceiver module.
loopback-mode: Specifies a loopback testing mode.
·     host-input: Loopbacks the signal from the transmitter of the host side to the receiver of the host side as the input signal of the host.
·     host-output: Loopbacks the signal received by the receiver of the host side to the transmitter of the host side as the output signal of the host.
·     media-input: Loopbacks the signal from the transmitter of the media side to the receiver of the media side as the input signal of the media.
·     media-output: Loopbacks the signal received by the receiver of the media side to the transmitter of the media side as the output signal of the media.
This command tests whether messages can be forwarded correctly between the designated transmitter and receiver and helps identify the point of failure when the transceiver module fails to forward messages.
# Enable loopback testing and specify a loopback testing mode for lanes of the transceiver module in FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] transceiver lane loopback media-input
This operation causes the service to be down for a while. Continue? [Y/N]:Y
transceiver lane pattern
Use transceiver lane pattern to configure the signal mode and signal transmission Pseudo Random Binary Sequence (PRBS) pattern for a transceiver module lane.
Use undo transceiver lane pattern to restore the default.
transceiver lane [ lane-number ] pattern [ host-checker | host-generator media-checker | media-generator ] prbs-pattern
undo transceiver lane [ lane-number ] pattern
host-checker: Specifies the host-side signal check mode.
host-generator: Specifies the host-side signal generation mode.
media-checker: Specifies the media-side signal check mode.
media-generator: Specifies the medial-side signal generation mode.
prbs-pattern: Specifies a signal transmission PRBS pattern. The value range varies by transceiver module model.
This command settings will be saved in a register of the transceiver module. If the transceiver module has a power loss, the command settings will be cleared. You must reconfigure the command after a power recovery.
# Specify the host-side signal generation mode and signal transmission pattern of PRBS-31Q for all lanes of the transceiver module in FourHundredGigE1/0/1.
[Sysname-FourHundredGigE1/0/1] transceiver lane pattern host-generator PRBS-31Q
transceiver optical-channel frequency
Use transceiver optical-channel frequency to set the frequency and frequency grid for a transceiver optical channel.
Use undo transceiver optical-channel frequency to restore the default.
transceiver optical-channel optical-channel-number frequency frequency-value [ grid grid-value ]
undo transceiver optical-channel optical-channel-number frequency
The default varies by transceiver module model.
optical-channel-number: Specifies an optical channel by its number. The value is 1.
frequency-value: Specifies an operating frequency for the transceiver optical channel, in the range of 191300000 to 196100000 MHz.
grid grid-value: Specifies the frequency grid for the transceiver optical channel. The value for the grid-value argument varies by transceiver module model. Valid values typically include the grid-value argument include 3125 MHz, 6250 MHz, 12500 MHz, 25000 MHz, 33000 MHz, 50000 MHz, 75000 MHz, and 100000 MHz. To view the grid values supported by a transceiver module, enter a question mark (?) in the place of the grid-value argument.
Only the QSFPDD-400G-ZR transceiver module supports this command
Before executing this command, calculate the frequency for a transceiver optical channel based on the grid and the reference frequency of 193100000 MHz. If the frequency is calculated incorrectly, the configuration by this command will fail. To calculate the frequency for a transceiver optical channel:
Frequency for a transceiver optical channel = 193100000 MHz ± Frequency grid for a transceiver optical channel × n. The value for n is an integer.
If the grid grid-value option is not configured, you can use any supported frequency grid value to calculate the frequency for a transceiver optical channel.
If the grid grid-value option is configured, you must use the specified grid value to calculate the frequency for a transceiver optical channel. If you fail to do so, the system will fail to set the frequency.
# Set the frequency for an optical channel of the transceiver module in FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] transceiver optical-channel 1 frequency ?
  <191000000-195000000>
[Sysname-FourHundredGigE1/0/1] transceiver optical-channel 1 frequency 193200000
transceiver optical-channel tx-power
Use transceiver optical-channel tx-power to set the transmit power for a transceiver optical channel.
Use undo transceiver optical-channel tx-power to restore the default.
Use transceiver optical-channel optical-channel-number tx-power power-value
Use undo transceiver optical-channel optical-channel-number tx-power
The transmit power of a transceiver optical channel is –10 dBm.
power-value: Specifies the transmit power in dBm, accurate to 0.01 dBm. The value range varies by transceiver module model.
Only the QSFPDD-400G-ZR transceiver module supports this command.
# Set the transmit power of optical channel 1 of the transceiver in FourHundredGigE1/0/1 to –5 dBm.
[Sysname-FourHundredGigE1/0/1] transceiver optical-channel 1 tx-power -5
transceiver performance-collection enable
Use transceiver performance-collection enable to enable transceiver performance sampling.
Use undo transceiver performance-collection enable to disable transceiver performance sampling.
Transceiver performance sampling is disabled.
If you enable transceiver performance sampling, the device samples transceiver performance information at intervals and save the samples to a buffer. You can use the display transceiver history performance-collection command to view the recent transceiver performance information.
# Enable transceiver performance sampling
[Sysname] transceiver performance-collection enable
transceiver performance-collection interval
Use transceiver performance-collection interval to specify the transceiver performance sampling interval.
Use undo transceiver performance-collection interval to restore the default.
transceiver performance-collection interval interval
The transceiver performance sampling interval is 15 minutes.
interval: Specifies the transceiver performance sampling interval. Valid values include 5min (5 minutes), 15min (15 minutes), 30min (30 minutes), and 60min (60 minutes), case insensitive. You must enter a valid value completely. If you fail to do so, the system prompts a parameter error.
# Specify the transceiver performance sampling interval as 5 minutes.
[Sysname] transceiver performance-collection interval 5min
transceiver phony-alarm-disable
Use transceiver phony-alarm-disable to disable transceiver module source alarm.
Use undo transceiver phony-alarm-disable to restore the default.
Transceiver module source alarm is enabled.
Disable transceiver module source alarm if the transceiver modules were manufactured or sold by HPE.
The device regularly detects transceiver modules that have a vendor name other than HPE or do not have a vendor name. Upon detecting such a transceiver module, the device repeatedly outputs traps and logs to notify the user to replace the module.
# Disable transceiver module source alarm.
[Sysname] transceiver phony-alarm-disable
transceiver power-mode
Use transceiver power-mode to set the power mode for a 400G transceiver module.
Use undo transceiver power-mode to restore the default.
transceiver power-mode { high | low }
A transceiver module typically operates in high power mode. If a transceiver module will be idle for a long time, you can switch it to low power mode to reduce power consumption. In low power mode, the transceiver module does not transmit signals. For a transceiver module to transmit signals, you must configure it to operate in high power mode.
# Configure the 400G transceiver module in FourHundredGigE 1/0/1 to operate in high power mode.
[Sysname-FourHundredGigE1/0/1] transceiver power-mode high
# Configure the 400G transceiver module in FourHundredGigE 1/0/1 to operate in low power mode.
[Sysname-FourHundredGigE1/0/1] transceiver power-mode low
This command will place the transceiver module in low-power-consumption mode, disabling the transceiver module from transmitting data. Continue? [Y/N]:Y
transceiver rx-power high-threshold
Use transceiver rx-power high-threshold to configure the high RX power threshold for a transceiver module.
Use undo transceiver rx-power high-threshold to restore the default.
transceiver rx-power high-threshold power-value
No high RX power threshold is set for a transceiver module.
power-value: Specifies the high RX power threshold in dBm, accurate to 0.01 dBm. The value range for the power-value argument varies by transceiver module model.
Operating mechanism
You can execute the transceiver rx-power high-threshold command to configure the high RX power threshold for a transceiver module between the default high early-warning threshold and high alarm threshold. If the RX power of a transceiver module exceeds the user-defined threshold, the system generates an alarm message. For example, if the default high threshold range for a transceiver module is 3.00 to 5.00 dBm, you can set the high TX power threshold to 4.40 dBm.
To verify the alarm thresholds for a transceiver module, execute the display transceiver diagnosis command.
This command is available only for the SFP, QSFP, QSFPDD, QSFP56, and DSFP transceiver modules that support digital diagnosis and is not available for the 400G ZR, 400G ZR+, or fiber-to-copper transceiver modules.
If a transceiver module has multiple lanes, the configuration takes effect for all lanes.
# Set the high RX power threshold for the transceiver module in HundredGigE 1/0/1 to 4.40 dBm.
[Sysname-HundredGigE1/0/1] transceiver rx-power high-threshold 4.40
transceiver rx-power change-threshold
transceiver rx-power low-threshold
Use transceiver rx-power low-threshold to configure the low RX power threshold for a transceiver module.
Use undo transceiver rx-power low-threshold to restore the default.
transceiver rx-power low-threshold power-value
No low RX power threshold is set for a transceiver module.
Operating mechanism
You can execute the transceiver rx-power low-threshold command to configure the low RX power threshold for a transceiver module between the default low early-warning threshold and low alarm threshold. If the RX power of a transceiver module drops below the user-defined threshold, the system generates an alarm message. For example, if the default low threshold range for a transceiver module is –14.00 to –11.00 dBm, you can set the low RX power threshold to –13.00 dBm.
# Set the low RX power threshold for the transceiver module in HundredGigE 1/0/1 to –13.00 dBm.
[Sysname-HundredGigE1/0/1] transceiver rx-power low-threshold -13.00
Use transceiver rx-power change-threshold to configure the RX power change threshold for a transceiver module.
Use undo transceiver rx-power change-threshold to restore the default.
transceiver rx-power change-threshold power-value
The RX power change threshold for a transceiver module is 5.00 dBm.
power-value: Specifies the RX power change threshold in dBm, accurate to 0.01 dBm. The value range is 0 to 48.
Application scenarios
This command enables the device to monitor significant RX power changes on transceiver modules and generate alarm messages in time.
Operating mechanism
The device sets the initial RX optical power as the baseline for a transceiver module after the transceiver module starts up and operates correctly for the first time. After you execute the transceiver rx-power change-threshold command, the system checks the RX optical power of a transceiver module periodically. If an RX optical power change exceeds the user-defined threshold compared to the baseline, the system identifies it as a significant change and generates an alarm. For example, the RX power change threshold is set to 20.00 dBm, the initial RX optical power after the link starts up and operates correctly is –15.00 dBm. Then, if the RX optical power decreases to –36.00 dBm or increases to 6.00 dBm, an alarm occurs.
# Set the RX power change threshold for a transceiver module in HundredGigE 1/0/1 to 4.00 dBm.
[Sysname-HundredGigE1/0/1] transceiver rx-power change-threashold 4.00
transceiver tx-power high-threshold
Use transceiver rx-power high-threshold to configure the high TX power threshold for a transceiver module.
transceiver tx-power high-threshold power-value
undo transceiver tx-power high-threshold
No high TX power threshold is set for a transceiver module.
power-value: Specifies the low TX power threshold in dBm, accurate to 0.01 dBm. The value range for the power-value argument varies by transceiver module model.
Operating mechanism
You can execute the transceiver tx-power high-threshold command to configure the high TX power threshold for a transceiver module between the default high early-warning threshold and high alarm threshold. If the TX power of a transceiver module exceeds the user-defined threshold, the system generates an alarm message. For example, if the default high threshold range for a transceiver module is 3.00 to 5.00 dBm, you can set the high TX power threshold to 4.40 dBm.
# Set the high TX power threshold for the transceiver module in HundredGigE 1/0/1 to 4.40 dBm.
[Sysname-HundredGigE1/0/1] transceiver tx-power high-threshold 4.40
transceiver tx-power change-threshold
transceiver tx-power low-threshold
Use transceiver tx-power low-threshold to configure the low TX power threshold for a transceiver module.
Use undo transceiver tx-power low-threshold to restore the default.
transceiver tx-power low-threshold power-value
No low TX power threshold is set for a transceiver module.
Operating mechanism
You can execute the transceiver tx-power low-threshold command to configure the low TX power threshold for a transceiver module between the default low early-warning threshold and low alarm threshold. If the TX power of a transceiver module drops below the user-defined threshold, the system generates an alarm message. For example, if the default low threshold range for a transceiver module is –14.00 to –11.00 dBm, you can set the low RX power threshold to –13.00 dBm.
# Set the low TX power threshold for the transceiver module in HundredGigE 1/0/1 to -13.00 dBm.
[Sysname-HundredGigE1/0/1] transceiver tx-power low-threshold -13.00
Use transceiver tx-power change-threshold to configure the TX power change threshold for a transceiver module.
Use undo transceiver tx-power change-threshold to restore the default.
transceiver tx-power change-threshold power-value
The TX power change threshold for a transceiver module is 4.00 dBm.
power-value: Specifies the TX power change threshold in dBm, accurate to 0.01 dBm. The value range is 0 to 48.
This command enables the device to monitor significant TX power changes on transceiver modules and generate alarm messages in time.
Operating mechanism
The device sets the initial TX optical power as the baseline for a transceiver module after the transceiver module starts up and operates correctly for the first time. After you execute the transceiver tx-power change-threshold command, the system checks the TX optical power of a transceiver module periodically. If a TX optical power change exceeds the user-defined threshold compared to the baseline, the system identifies it as a significant change and generates an alarm. For example, the TX power change threshold is set to 20.00 dBm, the initial TX optical power after the link starts up and operates correctly for the first time is –15.00 dBm. Then, if the TX optical power decreases to –36.00 dBm or increases to 6.00 dBm, an alarm occurs.
# Set the TX power change threshold for a transceiver module in HundredGigE 1/0/1 to 5.00 dBm.
[Sysname-HundredGigE1/0/1] transceiver tx-power change-threashold 5.00
