12-Security Command Reference
HomeSupportRoutersSR8800-F SeriesReference GuidesCommand ReferencesH3C SR8800-F Routers Command Reference-R8530Pxx-6W10212-Security Command Reference
04-Public key management commands
04-Public key management commands 205.93 KB
clear master-key
Use clear master-key to clear master keys.
clear master-key
Application scenarios
You can use this command to clear master keys in the following situations:
·     You do not need to use the master key feature.
·     The storage space for master keys is insufficient, and you want to clear existing master keys to release storage space.
Operating mechanism
The default master key of the device uses the fixed factory default value. With this command executed, all set master keys will be cleared and the default master key will be restored.
After you execute this command, you must wait for more than 3 minutes before you can clear master keys again or set a master key (through the set master-key command).
# Clear master keys.
[Sysname] clear master-key
This operation will delete all history master keys, change the current master key to the default master key and save configurations. Continue? [Y/N]:y
Enter the user password:
Operating, please wait for a moment...
Operation succeeded.
set master-key
display master-key type
Use display master-key type to display the type of the current master key.
# Display the type of the current master key.
<Sysname> display master-key type
The current master key is default.
The current master key is the device's default master key.
The current master key is user-defined.
The current master key is entered by the user.
The current master key is random.
The current master key is randomly generated by the device.
clear master-key
set master-key
display public-key local public
Use display public-key local public to display local public keys.
display public-key local { dsa | ecdsa | rsa | sm2 } public [ name key-name ]
dsa: Specifies the DSA key pair type.
ecdsa: Specifies the ECDSA key pair type.
rsa: Specifies the RSA key pair type.
sm2: Specifies the SM2 key pair type.
name key-name: Specifies a local key pair by its name, a case-insensitive string of 1 to 64 characters. Valid characters are letters, digits, and hyphens (-). If you do not specify a key pair, this command displays the public keys of all local key pairs of the specified type.
You can copy and distribute the public key of a local key pair to peer devices.
You cannot display a host public key that has the default key pair name by specifying the name key-name option. To view a host public key that has the default key pair name, display all local public keys by using this command without specifying a key pair name.
# Display all local RSA public keys.
<Sysname> display public-key local rsa public
Key name: hostkey(default)
Key type: RSA
Key length: 1024
Time when key pair created: 15:40:48 2011/05/12
Key code:
   30819F300D06092A864886F70D010101050003818D0030818902818100DAA4AAFEFE04C2C9
   667269BB8226E26331E30F41A8FF922C7338208097E84332610632B49F75DABF6D871B80CE
   C1BA2B75020077C74745C933E2F390DC0B39D35B88283D700A163BB309B19F8F87216A44AB
   FBF6A3D64DEB33E5CEBF2BCF26296778A26A84F4F4C5DBF8B656ACFA62CD96863474899BC1
   2DA4C04EF5AE0835090203010001
Key name: serverkey(default)
Key type: RSA
Key length: 768
Key code:
   307C300D06092A864886F70D0101010500036B003068026100CAB4CACCA16442AD5F453442
   762F03897E0D494FEDE69224F5C051A441D290976733A278C9F0C0F5A198E66143EAB54A64
   DB608269CAE844B1E7CC64AD7E808972E7CF887F3B657F056E7930FC84FBF1AD83A01CC47E
   9D85C13413996ECD093B0203010001
Key name: rsa1
Key type: RSA
Key length: 1024
Time when key pair created: 15:42:26 2011/05/12
Key code:
   30819F300D06092A864886F70D010101050003818D0030818902818100DEBC46F217DDF11D
   426E7095AA45CD6BF1F87343D952569AC223A01365E0D8C91D49D347C143C5D8FAADA896AA
   1A827E580F2502F1926F52197230E1DE391A64015C43DD79DC4E9E171BAEA1DEB4C71DAED7
   9A6EDFD460D8945D27D39B7C9822D56AEA5B7C2CCFF1B6BC524AD498C3B87D4BD6EB36AF03
   92D8C6D940890BF4290203010001
# Display all local DSA public keys.
<Sysname> display public-key local dsa public
Key name: dsakey(default)
Key type: DSA
Key length: 1024
Time when key pair created: 15:41:37 2011/05/12
Key code:
   308201B73082012C06072A8648CE3804013082011F02818100D757262C4584C44C211F18BD
   96E5F061C4F0A423F7FE6B6B85B34CEF72CE14A0D3A5222FE08CECE65BE6C265854889DC1E
   DBD13EC8B274DA9F75BA26CCB987723602787E922BA84421F22C3C89CB9B06FD60FE01941D
   DD77FE6B12893DA76EEBC1D128D97F0678D7722B5341C8506F358214B16A2FAC4B36895038
   7811C7DA33021500C773218C737EC8EE993B4F2DED30F48EDACE915F0281810082269009E1
   4EC474BAF2932E69D3B1F18517AD9594184CCDFCEAE96EC4D5EF93133E84B47093C52B20CD
   35D02492B3959EC6499625BC4FA5082E22C5B374E16DD00132CE71B020217091AC717B6123
   91C76C1FB2E88317C1BD8171D41ECB83E210C03CC9B32E810561C21621C73D6DAAC028F4B1
   585DA7F42519718CC9B09EEF0381840002818041912CE34D12BCD2157E7AB1C2F03B3EF395
   100F3DB4A9E2FDFE860C1BD663D676438F7DA40A9406D61CA9079AF13E330489F1C76785DE
   52DA649AC8BC04B6D39CD7C52CD0A14F75F7491A91D31D6AC22340B5981B27A915CDEC4F09
   887E541EC1E5302D500F68E7AC29A084463C60F9EE266985A502FC92193E1CF4D265C4BA
Key name: dsa1
Key type: DSA
Key length: 1024
Time when key pair created: 15:35:42 2011/05/12
Key code:
   308201B83082012C06072A8648CE3804013082011F02818100D757262C4584C44C211F18BD
   585DA7F42519718CC9B09EEF0381850002818100A1E456C8DA2AD1BB83B1BDF2A1A6B5A6E8
   3642B460402445DA7E4036715F468F76655E114D460B7112F57143EE020AEF4A5BFAD07B74
   0FBCB1C64DA8A2BCE619283421445EEC77D3CF0D11866E9656AD6511F4926F8376967B0AB7
   15F9FB7B514BC1174155DD6E073B1FCB3A2749E6C5FEA81003E16729497D0EAD9105E3E76A
# Display all local ECDSA public keys.
<Sysname> display public-key local ecdsa public
Key name: ecdsakey(default)
Key type: ECDSA
Key length: 192
Time when key pair created: 15:42:04 2011/05/12
Key code:
   3049301306072A8648CE3D020106082A8648CE3D03010103320004C10CF7CE42193F7FC2AF
   68F5DC877835A43009DB6135558A7FB8316C361B0690B4FD84A14C0779C76DD6145BF9362B
   1D
Key name: ecdsa1
Key type: ECDSA
Key length: 192
Time when key pair created: 15:43:33 2011/05/12
Key code:
   3049301306072A8648CE3D020106082A8648CE3D03010103320004A1FB84D92315B8DB72D1
   AE672C7CFA5135D5F5B02377F2F092F182EC83B5819795BC94CCBD3EBA7D4F0F2B2EB20C58
   4D
# Display the public keys of all local SM2 key pairs.
<Sysname> display public-key local sm2 public
Key name: sm2key(default)
Key type: SM2
Key length: 256
Time when key pair created: 15:42:04 2016/08/15
Key code:
   3059301306072A8648CE3D020106082A811CCF5501822D03420004DC5D3CCDD4F5E7AC9803
   D7F55ADC0668C067859482999C390B1648BE91FB567150A6C909706BB04AFE8709D5EC884C
   BD4EE36F38E8AD7DBCFB52286BF22CB146
Key name: sm21
Key type: SM2
Key length: 256
Time when key pair created: 15:43:33 2016/08/15
Key code:
   3059301306072A8648CE3D020106082A811CCF5501822D034200047A8EF255A75A90FA9239
   1B2BDD58B6F19E7D0158200E80297E434109A68A66160A20B5267ECB1706CA50A7ED04A89A
   007AFEFF8335441347EB2EB69CFB4CD459
# Display the public key of local RSA key pair rsa1.
<Sysname> display public-key local rsa public name rsa1
Key name: rsa1
Key type: RSA
Key length: 1024
Key code:
# Display the public key of local DSA key pair dsa1.
<Sysname> display public-key local dsa public name dsa1
Key name: dsa1
Key type: DSA
Key length: 1024
Key code:
# Display the public key of local ECDSA key pair ecdsa1.
<Sysname> display public-key local ecdsa public name ecdsa1
Key name: ecdsa1
Key type: ECDSA
Key length: 192
Key code:
   4D
# Display the public key of local SM2 key pair sm21.
<Sysname> display public-key local sm2 public name sm21
Key name: sm21
Key type: SM2
Key length: 256
Key code:
# Display the public key of SM2 key pair sm-hardware (created by a hardware crypto device).
<Sysname> display public-key local sm2 public name sm2-hardware
Key name: sm2-hardware
Key type: SM2
Key length: 256
Storage device serial number: 2016091400125014
Time when key pair created: 08:52:02 2017/09/06
Key code:
   043685DF5943674D61D096D3218C235728467ED4699893777EB2D4D77D302B44DC87C587A0
   7A9EC72802BCB13EFAF77E0E744FB49FA8C2A23BCDE7BB1E91462697
Key name
Name of the local key pair.
If you did not specify a name when creating the key pair, the default name is used followed by the word default in brackets.
The following is the default key pair name for each key algorithm:
·     hostkey—Default RSA host key pair name.
·     serverkey—Default RSA server key pair name.
·     dsakey—Default DSA host key pair name.
·     ecdsakey—Default ECDSA host key pair name.
·     sm2key—Default SM2 host key pair name.
Key type
Options include:
·     RSA.
·     DSA.
·     ECDSA.
·     SM2.
Key length
Key length in bits.
Serial number of the crypto device that generated the key pair. This field is not displayed if the key pair is created by a software algorithm.
Date and time when the local key pair was created.
Key code
Public key string.
public-key local create
display public-key peer
Use display public-key peer to display information about peer host public keys.
display public-key peer [ brief | name publickey-name ]
brief: Displays brief information about all peer host public keys. The brief information includes only the key type, key modulus, and key name.
name publickey-name: Displays detailed information about a peer host public key, including its key code. The publickey-name argument specifies a peer host public by its name, a case-sensitive string of 1 to 64 characters.
If you do not specify any keywords, this command displays detailed information about all peer host public keys configured on the local device.
You can use the public-key peer command or the public-key peer import sshkey command to configure a peer host public key on the local device.
# Display detailed information about peer host public key idrsa.
<Sysname> display public-key peer name idrsa
Key name: idrsa
Key type: RSA
Key length: 1024
Key code:
   30819F300D06092A864886F70D010101050003818D0030818902818100C5971581A78B5388
   B3C9063EC6B53D395A6704D9752B6F9B7B1F734EEB5DD509F0B050662C46FFB8D27F797E37
   918F6270C5793F1FC63638970A0E4D51A3CEF7CFF6E92BFAFD73F530E0BDE27056E81F2525
   6D0883836FD8E68031B2C272FE2EA75C87734A7B8F85B8EBEB3BD51CC26916AF3B3FDC32C3
   42C142D41BB4884FEB0203010001
Key name
Name of the peer host public key.
Key type
Key type: RSA, DSA or ECDSA.
Key length
Key length in bits.
Key code
Public key string.
# Display brief information about all peer host public keys.
<Sysname> display public-key peer brief
Type  Modulus  Name
RSA   1024    idrsa
DSA   1024    10.1.1.1
Modulus
Key modulus length in bits.
Name
public-key peer
peer-public-key end
Use peer-public-key end to exit public key view to system view and save the configured peer host public key.
peer-public-key end
Public key view
After you type the peer host public key on the local device, use this command to exit public key view and to save the peer host public key.
The system verifies the public key before saving it. If the key is not in the correct format, the system discards the key and displays an error message. If the key is valid, for example, the key was displayed by the display public-key local public command, the system saves the key.
# Exit public key view and save the configured peer host public key.
[Sysname] public-key peer key1
Enter public key view. Return to system view with "peer-public-key end" command.
[Sysname-pkey-public-key-key1]30819F300D06092A864886F70D010101050003818D0030818902818100C0EC8014F82515F6335A0A
[Sysname-pkey-public-key-key1]EF8F999C01EC94E5760A079BD73E4F4D97F3500EDB308C29481B77E719D1643135877E13B1C531B4
[Sysname-pkey-public-key-key1]FF1877A5E2E7B1FA4710DB0744F66F6600EEFE166F1B854E2371D5B952ADF6B80EB5F52698FCF3D6
[Sysname-pkey-public-key-key1]1F0C2EAAD9813ECB16C5C7DC09812D4EE3E9A0B074276FFD4AF2050BD4A9B1DDE675AC30CB020301
[Sysname-pkey-public-key-key1]0001
[Sysname-pkey-public-key-key1] peer-public-key end
[Sysname]
public-key peer
Use public-key local create to create local key pairs.
public-key local create { dsa | ecdsa [ secp192r1 | secp256r1 | secp384r1 | secp521r1 ] | rsa } [ name key-name ]
public-key local create sm2 [ name key-name ] [ on device-name ]
No local key pairs exist.
·     secp192r1: Uses the secp192r1 curve to create a 192-bit ECDSA key pair. The secp192r1 curve is used by default in non-FIPS mode.
·     secp256r1: Uses the secp256r1 curve to create a 256-bit ECDSA key pair. The secp256r1 curve is used by default in FIPS mode.
·     secp384r1: Uses the secp384r1 curve to create a 384-bit ECDSA key pair.
·     secp521r1: Uses the secp521r1 curve to create a 521-bit ECDSA key pair.
By default, the secp192r1 curve is used.
name key-name: Assigns a name to the key pair. The key-name argument is a case-insensitive string of 1 to 64 characters. Valid characters are letters, digits, and hyphens (-). If you do not assign a name to the key pair, the key pair takes the default name (see Table 5).
on device-name: Specifies the crypto device to be used to generate the SM2 key pair. The device-name argument specifies the device name, a case-sensitive string of 1 to 31 characters. If you do not specify a crypto device, the SM2 key pair will be created by a software algorithm. You can view the names of available crypto devices by entering a question mark (?) after the on keyword.
Table 5 Default local key pair names
Default name
RSA
·     Host key pair: hostkey
·     Server key pair: serverkey
DSA
dsakey
ECDSA
ecdsakey
SM2
sm2key
The key algorithm must be the same as required by the security application.
When you create an RSA or DSA key pair, enter an appropriate key modulus length at the prompt. The longer the key modulus length, the higher the security, and the longer the key generation time.
When you create an ECDSA key pair, choose the appropriate elliptic curve. The elliptic curve determines the ECDSA key length. The longer the key length, the higher the security, and the longer the key generation time.
When you create an SM key pair, you do not need to specify the key length. Only a 256-bit SM2 key pair can be created.
See Table 6 for more information about key modulus lengths and key lengths.
If you do not assign the key pair a name, the system assigns the default name to the key pair and marks the key pair as default. You can also assign the default name to another key pair, but the system does not mark the key pair as default. The name of a key pair must be unique among all manually named key pairs that use the same key algorithm. If a name conflict occurs, the system asks whether you want to overwrite the existing key pair.
The key pairs are automatically saved and can survive system reboots.
Table 6 A comparison of different types of asymmetric key algorithms
Generated key pairs
Modulus/key length
RSA
·     One host key pair, if you specify a key pair name.
·     One server key pair and one host key pair, if you do not specify a key pair name.
Both key pairs use their default names
Only SSH 1.5 uses the RSA server key pair.
Key modulus length: 512 to 2048 bits, 1024 bits by default.
To ensure security, use a minimum of 768 bits.
DSA
One host key pair.
ECDSA
One host key pair.
Key length: 192, 256, 384, or 521 bits.
SM2
One host key pair.
Key length: 256 bits.
# Create local RSA key pairs with default names.
[Sysname] public-key local create rsa
The range of public key modulus is (512 ~ 2048).
If the key modulus is greater than 512, it will take a few minutes.
Press CTRL+C to abort.
Generating Keys...
# Create a local DSA key pair with the default name.
[Sysname] public-key local create dsa
Generating Keys...
# Create a local ECDSA key pair with the default name.
[Sysname] public-key local create ecdsa
Generating Keys...
# Create a local SM2 key pair with the default name.
[Sysname] public-key local create sm2
Generating Keys...
# Create local RSA key pair rsa1.
[Sysname] public-key local create rsa name rsa1
Generating Keys...
# Create local DSA key pair dsa1.
[Sysname] public-key local create dsa name dsa1
Generating Keys...
# Create local ECDSA key pair ecdsa1.
[Sysname] public-key local create ecdsa name ecdsa1
Generating Keys...
# Create a local SM2 key pair named sm2.
[Sysname] public-key local create sm2 name sm2
Generating Keys...
public-key local destroy
Use public-key local destroy to destroy local key pairs.
public-key local destroy { dsa | ecdsa | rsa | sm2 } [ name key-name ]
name key-name: Specifies a local key pair by its name, a case-insensitive string of 1 to 64 characters. Valid characters are letters, digits, and hyphens (-). If you do not specify a key pair, this command destroys all key pairs of the specified type.
To ensure security, destroy the local key pair and generate a new key pair in any of the following situations:
·     An intrusion event has occurred.
·     The storage media of the device is replaced.
·     The local certificate has expired. For more information about local certificates, see Security Configuration Guide.
# Destroy the local RSA key pairs with the default names.
[Sysname] public-key local destroy rsa
Confirm to destroy the key pair? [Y/N]:y
# Destroy the local DSA key pair with the default name.
[Sysname] public-key local destroy dsa
Confirm to destroy the key pair? [Y/N] :y
# Destroy the local ECDSA key pair with the default name.
[Sysname] public-key local destroy ecdsa
# Destroy local RSA key pair rsa1.
[Sysname] public-key local destroy rsa name rsa1
# Destroy local DSA key pair dsa1.
[Sysname] public-key local destroy dsa name dsa1
# Destroy local ECDSA key pair ecdsa1.
[Sysname] public-key local destroy ecdsa name ecdsa1
# Destroy local SM2 key pair sm2.
[Sysname] public-key local destroy sm2 name sm2
public-key local export dsa
Use public-key local export dsa to export a local DSA host public key.
public-key local export dsa [ name key-name ] { openssh | ssh2 } [ filename ]
name key-name: Specifies a local DSA key pair by its name, a case-insensitive string of 1 to 64 characters. Valid characters are letters, digits, and hyphens (-). If you do not specify a key pair, this command exports the host public key of the local DSA key pair with the default name.
openssh: Exports the host public key in OpenSSH format.
ssh2: Exports the host public key in SSH 2.0 format.
filename: Specifies the name of the file for saving the DSA host public key. The file name is a case-insensitive string of 1 to 128 characters. The name cannot be all dots (.), hostkey, serverkey, dsakey, or ecdsakey, and cannot start with a slash (/) or contain ./ and ../. For more information about file names, see Fundamentals Configuration Guide. If you do not specify a file name, this command displays the key on the monitor screen.
You can use this command to export a local DSA host public key before distributing it to a peer device.
To distribute a local DSA host public key to a peer device:
1.     Save the exported local host public key to a file by using one of the following methods:
¡     Use the public-key local export dsa [ name key-name ] { openssh | ssh2 } command to export the local host public key to the monitor screen, and then copy and paste the key to a file.
¡     Use the public-key local export dsa [ name key-name ] { openssh | ssh2 } filename command to export the key to a file. You cannot export the key to the folder pkey or its subfolders.
2.     Transfer a copy of the file to the peer device, for example, by using FTP in binary mode or TFTP. For more information about FTP and TFTP, see Fundamentals Configuration Guide.
3.     On the peer device, use the public-key peer import sshkey command to import the host public key from the file.
SSH 2.0 and OpenSSH are different public key formats. Choose the correct format that is supported on the device where you import the host public key.
# Export the host public key of the local DSA key pair with the default name in OpenSSH format to file key.pub.
[Sysname] public-key local export dsa openssh key.pub
# Export the host public key of the local DSA key pair with the default name to the monitor screen and in SSH 2.0 format.
[Sysname] public-key local export dsa ssh2
---- BEGIN SSH2 PUBLIC KEY ----
Comment: "dsa-key-2011/05/12"
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
---- END SSH2 PUBLIC KEY ----
# Export the host public key of the local DSA key pair with the default name to the monitor screen and in OpenSSH format.
ssh-dss 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 dsa-key
# Export the host public key of local DSA key pair dsa1 in OpenSSH format to file dsa1.pub.
[Sysname] public-key local export dsa name dsa1 openssh dsa1.pub
# Export the host public key of local DSA key pair dsa1 to the monitor screen in SSH 2.0 format.
[Sysname] public-key local export dsa name dsa1 ssh2
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
# Export the host public key of local DSA key pair dsa1 to the monitor screen in OpenSSH format.
ssh-dss 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 dsa-key
public-key local export ecdsa
Use public-key local export ecdsa to export a local ECDSA host public key.
public-key local export ecdsa [ name key-name ] { openssh | ssh2 } [ filename ]
name key-name: Specifies a local ECDSA key pair by its name, a case-insensitive string of 1 to 64 characters. Valid characters are letters, digits, and hyphens (-). If you do not specify a key pair, this command exports the host public key of the local ECDSA key pair with the default name.
filename: Specifies the name of the file for saving the local host public key. The file name is a case-insensitive string of 1 to 128 characters. The name cannot be dots (.), hostkey, serverkey, dsakey, or ecdsakey, and cannot start or contain ./ and ../. For more information about file names, see Fundamentals Configuration Guide. If you do not specify a file name, this command does not export the key to a file but displays to the monitor screen.
You can use this command to export a local ECDSA host public key before distributing it to a peer device.
To distribute a local ECDSA host public key to a peer device:
1.     Save the exported ECDSA host public key to a file by using one of the following methods:
¡     Use the public-key local export ecdsa [ name key-name ] { openssh | ssh2 } command to export the local host public key to the monitor screen, and then copy and paste it to a file.
¡     Use the public-key local export ecdsa [ name key-name ] { openssh | ssh2 } filename command to export the host public key to a file. You cannot export the key to the folder pkey or its subfolders.
SSH 2.0 and OpenSSH are different public key formats. Choose the correct format that is supported by the device where you import the host public key.
# Export the host public key of the local ECDSA key pair with the default name in OpenSSH format to file key.pub.
[Sysname] public-key local export ecdsa openssh key.pub
# Export the host public key of the local ECDSA key pair with the default name to the monitor screen and in SSH 2.0 format.
[Sysname] public-key local export ecdsa ssh2
Comment: "ecdsa-sha2-nistp256-2014/07/06"
AAAAE2VjZHNhLXNoYTItbmlzdHAyNTYAAAAIbmlzdHAyNTYAAABBBBREw5tkARpbV+sYArt/xcW+UJEAevx7OckTtTLPBiLP5bWkSdKbvo+3oHRuIyZqmNTIcxuBjuBap+pHc919C58=
# Export the host public key of the local ECDSA key pair with the default name to the monitor screen and in OpenSSH format.
ecdsa-sha2-nistp256 AAAAE2VjZHNhLXNoYTItbmlzdHAyNTYAAAAIbmlzdHAyNTYAAABBBBREw5tkARpbV+sYArt/xcW+UJEAevx7OckTtTLPBiLP5bWkSdKbvo+3oHRuIyZqmNTIcxuBjuBap+pHc919C58=
 ecdsa-key
public-key local export rsa
Use public-key local export rsa to export a local RSA host public key.
public-key local export rsa [ name key-name ] { openssh | ssh1 | ssh2 } [ filename ]
name key-name: Specifies a local RSA key pair by its name, a case-insensitive string of 1 to 64 characters. Valid characters are letters, digits, and hyphens (-). If you do not specify a key pair, this command exports the host public key of the local RSA key pair with the default name.
ssh1: Exports the host public key in SSH 1.5 format.
filename: Specifies the name of the file for saving the RSA host public key. The file name is a case-insensitive string of 1 to 128 characters. The name cannot be all dots (.), hostkey, serverkey, dsakey, or ecdsakey, and cannot start or contain ./ and ../. For more information about file names, see Fundamentals Configuration Guide. If you do not specify a file name, this command displays the key on the monitor screen.
You can use this command to export a local RSA host public key before distributing it to a peer device.
To distribute a local RSA host public key to a peer device:
¡     Use the public-key local export rsa [ name key-name ] { openssh | ssh2 } command to export the key to the monitor screen, and then copy and paste it to a file.
¡     Use the public-key local export rsa [ name key-name ] { openssh | ssh2 } filename command to export key to a file. You cannot export the key to the folder pkey or its subfolders.
Choose the correct public key format that is supported on the device where you import the host public key.
# Export the host public key of the local RSA key pair with the default name in OpenSSH format to file key.pub.
[Sysname] public-key local export rsa openssh key.pub
# Export the host public key of the local RSA key pair with the default name to the monitor screen and in SSH 2.0 format.
[Sysname] public-key local export rsa ssh2
Comment: "rsa-key-2011/05/12"
AAAAB3NzaC1yc2EAAAADAQABAAAAgQDapKr+/gTCyWZyabuCJuJjMeMPQaj/kixzOCCAl+hDMmEGMrSfddq/bYcbgM7Buit1AgB3x0dFyTPi85DcCznTW4goPXAKFjuzCbGfj4chakSr+/aj1k3rM+XOvyvPJilneKJqhPT0xdv4tlas+mLNloY0dImbwS2kwE71rgg1CQ==
# Export the host public key of the local RSA key pair with the default name to the monitor screen and in OpenSSH format.
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAgQDapKr+/gTCyWZyabuCJuJjMeMPQaj/kixzOCCAl+hDMmEGMrSfddq/bYcbgM7Buit1AgB3x0dFyTPi85DcCznTW4goPXAKFjuzCbGfj4chakSr+/aj1k3rM+XOvyvPJilneKJqhPT0xdv4tlas+mLNloY0dImbwS2kwE71rgg1CQ== rsa-key
# Export the host public key of local RSA key pair rsa1 in OpenSSH format to file rsa1.pub.
[Sysname] public-key local export rsa name rsa1 openssh rsa1.pub
# Export the host public key of local RSA key pair rsa1 to the monitor screen and in SSH 2.0 format.
[Sysname] public-key local export rsa name rsa1 ssh2
AAAAB3NzaC1yc2EAAAADAQABAAAAgQDevEbyF93xHUJucJWqRc1r8fhzQ9lSVprCI6ATZeDYyR1J00fBQ8XY+q2olqoagn5YDyUC8ZJvUhlyMOHeORpkAVxD3XncTp4XG66h3rTHHa7Xmm7f1GDYlF0n05t8mCLVaupbfCzP8ba8UkrUmMO4fUvW6zavA5LYxtlAiQv0KQ==
# Export the host public key of local RSA key pair rsa1 to the monitor screen and in OpenSSH format.
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAgQDevEbyF93xHUJucJWqRc1r8fhzQ9lSVprCI6ATZeDYyR1J00fBQ8XY+q2olqoagn5YDyUC8ZJvUhlyMOHeORpkAVxD3XncTp4XG66h3rTHHa7Xmm7f1GDYlF0n05t8mCLVaupbfCzP8ba8UkrUmMO4fUvW6zavA5LYxtlAiQv0KQ== rsa-key
public-key local export sm2
Use public-key local export sm2 to export a local SM2 host public key.
public-key local export sm2 [ name key-name ] { openssh | ssh2 } [ filename ]
name key-name: Specifies a local SM2 key pair by its name, a case-insensitive string of 1 to 64 characters. Valid characters are letters, digits, and hyphens (-). If you do not specify a key pair, this command exports the host public key of the local SM2 key pair with the default name.
ssh2: Exports the host public key in SSH2.0 format.
filename: Specifies the name of the file for saving the local host public key. The name cannot be all dots (.), hostkey, serverkey, dsakey, ecdsakey, or sm2key, and cannot start with a slash (/) or contain ./ or ../. The file name is a case-insensitive string of 1 to 128 characters.For more information about file names, see file system management in Fundamentals Configuration Guide. If you do not specify a file name, this command displays the key on the monitor screen.
You can use this command to export a local SM2 host public key before distributing it to a peer device.
To distribute a local SM2 host public key to a peer device:
¡     Use the public-key local export sm2 [ name key-name ] { openssh | ssh2 } command to export the key, and then copy and paste it to a file.
¡     Use the public-key local export sm2 [ name key-name ] { openssh | ssh2 } filename command to export key to a file. You cannot export the key to the pkey folder or its subfolders.
SSH2.0 and OpenSSH are different public key formats. Choose the correct public key format that is supported on the device where you import the host public key.
# Export the host public key of the local SM2 key pair with the default name in OpenSSH format to file key.pub.
[Sysname] public-key local export sm2 openssh key.pub
# Display the host public key of the local SM2 key pair with the default name in SSH2.0 format.
[Sysname] public-key local export sm2 ssh2
Comment: "sm2-key-2016/09/12"
AAAAB3NtMi1rZXkAAABBBJo0XIySNcZiJq/N81QQozLcdBneur2w/E1gIRAfHM5SwDspD22aMdg5dRQr
IFrN6XMXdftV5vwI9qWX/tGMH0g=
# Display the host public key of the local SM2 key pair with the default name in OpenSSH format.
ssh-sm2 AAAAB3NtMi1rZXkAAABBBJo0XIySNcZiJq/N81QQozLcdBneur2w/E1gIRAfHM5SwDspD22a
Mdg5dRQrIFrN6XMXdftV5vwI9qWX/tGMH0g= sm2-key
public-key peer
Use public-key peer to assign a name to a peer host public key and enter public key view, or enter the view of an existing peer host public key.
Use undo public-key peer to delete a peer host public key.
public-key peer keyname
undo public-key peer keyname
No peer host public keys exist.
keyname: Specifies a key name, a case-sensitive string of 1 to 64 characters.
After you execute this command to enter the public key view, type the public key. Spaces and carriage returns are allowed, but are not saved.
To configure a peer host public key on the local device, first obtain the peer public key in hexadecimal notation, and then perform the following tasks on the local device:
1.     Execute the public-key peer command to enter public key view.
2.     Type the public key.
3.     Execute the peer-public-key end command to save the public key and return to system view.
The public key you type in the public key view must be in a correct format. If the peer device is an H3C device, use the display public-key local public command to display and record its public key.
# Assign name key1 to the peer host public key and enter public key view.
peer-public-key end
Use public-key peer import sshkey to import a peer host public key from a public key file.
Use undo public-key peer to remove a peer host public key.
public-key peer keyname import sshkey filename
keyname: Specifies a name for a peer host public key, a case-sensitive string of 1 to 64 characters.
filename: Specifies a public key file by its name, a case-insensitive string of 1 to 128 characters. The file name cannot be all dots (.), hostkey, serverkey, dsakey, or ecdsakey, and cannot start or contain ./ and ../. For more information about file names, see Fundamentals Configuration Guide.
After you configure this command, the system automatically transforms the host public key to the PKCS format, and saves the key.
Before you use this command, make sure you have got a copy of the public key file from the peer device through FTP in binary mode or through TFTP.
The device supports importing public keys in the format of SSH 1.5, SSH 2.0 and OpenSSH.
# Import peer host public key key2 from public key file key.pub.
[Sysname] public-key peer key2 import sshkey key.pub
set master-key
Use clear master-key to set a master key.
set master-key
Operating mechanism
By default, a device uses the unified default master key to encrypt the key strings configured for each service module on the device. After you load the exported configuration file of a device on another device, you can use the default master key to decrypt and obtain the configured key strings. In this way, keys can be copied between devices, bringing security risks.
To improve the security and reliability of data, you can set a master key for the device. After you execute this command on the device, you need to configure the relevant settings as prompted:
1.     Validate your identity:
¡     If the login authentication mode is password or scheme, the CLI prompts you to enter your password for login. After you pass the authentication, you go to step 2.
¡     If the login authentication mode is none, you do not need to perform identity authentication but go to step 2 directly.
For more information about login authentication modes, see login management in Fundamentals Configuration Guide.
2.     Select whether to enter the master key:
¡     If you enter N or n, the device will automatically and randomly generate a master key.
¡     If you enter Y or y, manually enter the prepared master key and confirm it.
The device stores the master key in the hard disk. Power-off or reboot of the device will not affect the set master key. The device uses the master key to encrypt the key strings configured for each service module on the device.
You can only use the display master-key type command to view the type of the master key. You cannot view or obtain the value of the master key by any means. This prevents copying the keys on the device to another device.
To manually enter a master key, prepare the master key and keep it safe before configuring this command.
The master key must be a string of 20 to 32 characters, and must contain uppercase letters, lowercase letters, digits, and special characters.
When the storage space for master keys is insufficient, the device prompts whether to overwrite the oldest master key.
When the login authentication mode is password or scheme, you will be logged off after three consecutive authentication failures and thus cannot perform master key-related operations.
The minimum interval between setting master keys is 3 minutes.
# Randomly generate a master key. (password or scheme login authentication mode.)
[Sysname] set master-key
This operation will automatically save configurations. Continue? [Y/N]:y
Enter the master key? (If you enter Y, you need to enter the master key. If you enter N, the system will automatically generate the master key.) [Y/N]:N
# Manually enter a master key. (password or scheme login authentication mode.)
Enter the master key? (If you enter Y, you need to enter the master key. If you enter N, the system will automatically generate the master key.) [Y/N]:Y
Enter a master key (20-32 characters):
Confirm the master key:
# Manually enter a master key. (none login authentication mode.)
# Set a master key when the storage space for master keys is insufficient. (none login authentication mode.)
The storage space for history master keys is insufficient. Overwrite the oldest master key? [Y/N]:y
clear master-key
